[PATCH v1] rockchip: use OF_UPSTREAM for rk3066a/rk3188
The device tree for rk3066a/rk3188 combined is now available in the /dts/upstream directory. Use imply OF_UPSTREAM to migrate all rk3066a/rk3188 boards.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3066a-mk808.dts | 241 -------- arch/arm/dts/rk3066a-u-boot.dtsi | 20 - arch/arm/dts/rk3066a.dtsi | 880 ------------------------------ arch/arm/dts/rk3188-radxarock.dts | 389 ------------- arch/arm/dts/rk3188-u-boot.dtsi | 17 - arch/arm/dts/rk3188.dtsi | 815 --------------------------- arch/arm/dts/rk3xxx.dtsi | 488 ----------------- arch/arm/mach-rockchip/Kconfig | 2 + configs/mk808_defconfig | 4 +- configs/rock_defconfig | 4 +- 10 files changed, 6 insertions(+), 2854 deletions(-) delete mode 100644 arch/arm/dts/rk3066a-mk808.dts delete mode 100644 arch/arm/dts/rk3066a.dtsi delete mode 100644 arch/arm/dts/rk3188-radxarock.dts delete mode 100644 arch/arm/dts/rk3188.dtsi delete mode 100644 arch/arm/dts/rk3xxx.dtsi
diff --git a/arch/arm/dts/rk3066a-mk808.dts b/arch/arm/dts/rk3066a-mk808.dts deleted file mode 100644 index 06790f05b395..000000000000 --- a/arch/arm/dts/rk3066a-mk808.dts +++ /dev/null @@ -1,241 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Paweł Jarosz paweljarosz3691@gmail.com - */ - -/dts-v1/; -#include <dt-bindings/input/input.h> -#include "rk3066a.dtsi" - -/ { - model = "Rikomagic MK808"; - compatible = "rikomagic,mk808", "rockchip,rk3066a"; - - aliases { - mmc0 = &mmc0; - mmc1 = &mmc1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - memory@60000000 { - reg = <0x60000000 0x40000000>; - device_type = "memory"; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <2500000>; - poll-interval = <100>; - - button-recovery { - label = "recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <0>; - }; - }; - - gpio-leds { - compatible = "gpio-leds"; - - blue_led: led-0 { - label = "mk808:blue:power"; - gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "default-on"; - }; - }; - - hdmi_con { - compatible = "hdmi-connector"; - type = "c"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - vcc_2v5: vcc-2v5 { - compatible = "regulator-fixed"; - regulator-name = "vcc_2v5"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - }; - - vcc_io: vcc-io { - compatible = "regulator-fixed"; - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&host_drv>; - pinctrl-names = "default"; - regulator-always-on; - regulator-name = "host-pwr"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_otg: usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&otg_drv>; - pinctrl-names = "default"; - regulator-always-on; - regulator-name = "vcc_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&sdmmc_pwr>; - pinctrl-names = "default"; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_wifi: sdio-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 RK_PD0 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&wifi_pwr>; - pinctrl-names = "default"; - regulator-name = "vcc_wifi"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; -}; - -&hdmi { - status = "okay"; -}; - -&hdmi_in_vop1 { - status = "disabled"; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&mmc0 { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&mmc1 { - bus-width = <4>; - non-removable; - pinctrl-0 = <&sd1_clk &sd1_cmd &sd1_bus4>; - pinctrl-names = "default"; - vmmc-supply = <&vcc_wifi>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - }; -}; - -&nfc { - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - nand@0 { - reg = <0>; - label = "rk-nand"; - nand-bus-width = <8>; - nand-ecc-mode = "hw"; - nand-ecc-step-size = <1024>; - nand-ecc-strength = <40>; - nand-is-boot-medium; - rockchip,boot-blks = <8>; - rockchip,boot-ecc-strength = <24>; - }; -}; - -&pinctrl { - usb-host { - host_drv: host-drv { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_default>; - }; - }; - - usb-otg { - otg_drv: otg-drv { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_default>; - }; - }; - - sdmmc { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_default>; - }; - }; - - sdio { - wifi_pwr: wifi-pwr { - rockchip,pins = <3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&saradc { - vref-supply = <&vcc_2v5>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host { - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&vop0 { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3066a-u-boot.dtsi b/arch/arm/dts/rk3066a-u-boot.dtsi index 06f405ca2c5e..d99db7853b59 100644 --- a/arch/arm/dts/rk3066a-u-boot.dtsi +++ b/arch/arm/dts/rk3066a-u-boot.dtsi @@ -3,26 +3,6 @@ #include "rockchip-u-boot.dtsi" #include "rk3xxx-u-boot.dtsi"
-&gpio0 { - gpio-ranges = <&pinctrl 0 0 32>; -}; - -&gpio1 { - gpio-ranges = <&pinctrl 0 32 32>; -}; - -&gpio2 { - gpio-ranges = <&pinctrl 0 64 32>; -}; - -&gpio3 { - gpio-ranges = <&pinctrl 0 96 32>; -}; - -&gpio4 { - gpio-ranges = <&pinctrl 0 128 32>; -}; - &gpio6 { status = "disabled"; }; diff --git a/arch/arm/dts/rk3066a.dtsi b/arch/arm/dts/rk3066a.dtsi deleted file mode 100644 index de9915d946f7..000000000000 --- a/arch/arm/dts/rk3066a.dtsi +++ /dev/null @@ -1,880 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2013 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/clock/rk3066a-cru.h> -#include <dt-bindings/power/rk3066-power.h> -#include "rk3xxx.dtsi" - -/ { - compatible = "rockchip,rk3066a"; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - enable-method = "rockchip,rk3066-smp"; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x0>; - operating-points = - /* kHz uV */ - <1416000 1300000>, - <1200000 1175000>, - <1008000 1125000>, - <816000 1125000>, - <600000 1100000>, - <504000 1100000>, - <312000 1075000>; - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - }; - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x1>; - }; - }; - - display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vop0_out>, <&vop1_out>; - }; - - sram: sram@10080000 { - compatible = "mmio-sram"; - reg = <0x10080000 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x10080000 0x10000>; - - smp-sram@0 { - compatible = "rockchip,rk3066-smp-sram"; - reg = <0x0 0x50>; - }; - }; - - vop0: vop@1010c000 { - compatible = "rockchip,rk3066-vop"; - reg = <0x1010c000 0x19c>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_LCDC0>, - <&cru DCLK_LCDC0>, - <&cru HCLK_LCDC0>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3066_PD_VIO>; - resets = <&cru SRST_LCDC0_AXI>, - <&cru SRST_LCDC0_AHB>, - <&cru SRST_LCDC0_DCLK>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vop0_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vop0_out_hdmi: endpoint@0 { - reg = <0>; - remote-endpoint = <&hdmi_in_vop0>; - }; - }; - }; - - vop1: vop@1010e000 { - compatible = "rockchip,rk3066-vop"; - reg = <0x1010e000 0x19c>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_LCDC1>, - <&cru DCLK_LCDC1>, - <&cru HCLK_LCDC1>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3066_PD_VIO>; - resets = <&cru SRST_LCDC1_AXI>, - <&cru SRST_LCDC1_AHB>, - <&cru SRST_LCDC1_DCLK>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vop1_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vop1_out_hdmi: endpoint@0 { - reg = <0>; - remote-endpoint = <&hdmi_in_vop1>; - }; - }; - }; - - hdmi: hdmi@10116000 { - compatible = "rockchip,rk3066-hdmi"; - reg = <0x10116000 0x2000>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HDMI>; - clock-names = "hclk"; - pinctrl-names = "default"; - pinctrl-0 = <&hdmii2c_xfer>, <&hdmi_hpd>; - power-domains = <&power RK3066_PD_VIO>; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - hdmi_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - hdmi_in_vop0: endpoint@0 { - reg = <0>; - remote-endpoint = <&vop0_out_hdmi>; - }; - - hdmi_in_vop1: endpoint@1 { - reg = <1>; - remote-endpoint = <&vop1_out_hdmi>; - }; - }; - - hdmi_out: port@1 { - reg = <1>; - }; - }; - }; - - i2s0: i2s@10118000 { - compatible = "rockchip,rk3066-i2s"; - reg = <0x10118000 0x2000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s0_bus>; - clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1_s 4>, <&dmac1_s 5>; - dma-names = "tx", "rx"; - rockchip,playback-channels = <8>; - rockchip,capture-channels = <2>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s1: i2s@1011a000 { - compatible = "rockchip,rk3066-i2s"; - reg = <0x1011a000 0x2000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s1_bus>; - clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1_s 6>, <&dmac1_s 7>; - dma-names = "tx", "rx"; - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s2: i2s@1011c000 { - compatible = "rockchip,rk3066-i2s"; - reg = <0x1011c000 0x2000>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s2_bus>; - clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1_s 9>, <&dmac1_s 10>; - dma-names = "tx", "rx"; - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - cru: clock-controller@20000000 { - compatible = "rockchip,rk3066a-cru"; - reg = <0x20000000 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = <&cru PLL_CPLL>, <&cru PLL_GPLL>, - <&cru ACLK_CPU>, <&cru HCLK_CPU>, - <&cru PCLK_CPU>, <&cru ACLK_PERI>, - <&cru HCLK_PERI>, <&cru PCLK_PERI>; - assigned-clock-rates = <400000000>, <594000000>, - <300000000>, <150000000>, - <75000000>, <300000000>, - <150000000>, <75000000>; - }; - - timer2: timer@2000e000 { - compatible = "snps,dw-apb-timer"; - reg = <0x2000e000 0x100>; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_TIMER2>, <&cru PCLK_TIMER2>; - clock-names = "timer", "pclk"; - }; - - efuse: efuse@20010000 { - compatible = "rockchip,rk3066a-efuse"; - reg = <0x20010000 0x4000>; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&cru PCLK_EFUSE>; - clock-names = "pclk_efuse"; - - cpu_leakage: cpu_leakage@17 { - reg = <0x17 0x1>; - }; - }; - - timer0: timer@20038000 { - compatible = "snps,dw-apb-timer"; - reg = <0x20038000 0x100>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_TIMER0>, <&cru PCLK_TIMER0>; - clock-names = "timer", "pclk"; - }; - - timer1: timer@2003a000 { - compatible = "snps,dw-apb-timer"; - reg = <0x2003a000 0x100>; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_TIMER1>, <&cru PCLK_TIMER1>; - clock-names = "timer", "pclk"; - }; - - tsadc: tsadc@20060000 { - compatible = "rockchip,rk3066-tsadc"; - reg = <0x20060000 0x100>; - clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; - clock-names = "saradc", "apb_pclk"; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - #io-channel-cells = <1>; - resets = <&cru SRST_TSADC>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3066a-pinctrl"; - rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - gpio0: gpio@20034000 { - compatible = "rockchip,gpio-bank"; - reg = <0x20034000 0x100>; - interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO0>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@2003c000 { - compatible = "rockchip,gpio-bank"; - reg = <0x2003c000 0x100>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@2003e000 { - compatible = "rockchip,gpio-bank"; - reg = <0x2003e000 0x100>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@20080000 { - compatible = "rockchip,gpio-bank"; - reg = <0x20080000 0x100>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@20084000 { - compatible = "rockchip,gpio-bank"; - reg = <0x20084000 0x100>; - interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO4>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio6: gpio@2000a000 { - compatible = "rockchip,gpio-bank"; - reg = <0x2000a000 0x100>; - interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO6>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - pcfg_pull_default: pcfg-pull-default { - bias-pull-pin-default; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - emac { - emac_xfer: emac-xfer { - rockchip,pins = <1 RK_PC0 2 &pcfg_pull_none>, /* mac_clk */ - <1 RK_PC1 2 &pcfg_pull_none>, /* tx_en */ - <1 RK_PC2 2 &pcfg_pull_none>, /* txd1 */ - <1 RK_PC3 2 &pcfg_pull_none>, /* txd0 */ - <1 RK_PC4 2 &pcfg_pull_none>, /* rx_err */ - <1 RK_PC5 2 &pcfg_pull_none>, /* crs_dvalid */ - <1 RK_PC6 2 &pcfg_pull_none>, /* rxd1 */ - <1 RK_PC7 2 &pcfg_pull_none>; /* rxd0 */ - }; - - emac_mdio: emac-mdio { - rockchip,pins = <1 RK_PD0 2 &pcfg_pull_none>, /* mac_md */ - <1 RK_PD1 2 &pcfg_pull_none>; /* mac_mdclk */ - }; - }; - - emmc { - emmc_clk: emmc-clk { - rockchip,pins = <3 RK_PD7 2 &pcfg_pull_default>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = <4 RK_PB1 2 &pcfg_pull_default>; - }; - - emmc_rst: emmc-rst { - rockchip,pins = <4 RK_PB2 2 &pcfg_pull_default>; - }; - - /* - * The data pins are shared between nandc and emmc and - * not accessible through pinctrl. Also they should've - * been already set correctly by firmware, as - * flash/emmc is the boot-device. - */ - }; - - hdmi { - hdmi_hpd: hdmi-hpd { - rockchip,pins = <0 RK_PA0 1 &pcfg_pull_default>; - }; - - hdmii2c_xfer: hdmii2c-xfer { - rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>, - <0 RK_PA2 1 &pcfg_pull_none>; - }; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = <2 RK_PD4 1 &pcfg_pull_none>, - <2 RK_PD5 1 &pcfg_pull_none>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = <2 RK_PD6 1 &pcfg_pull_none>, - <2 RK_PD7 1 &pcfg_pull_none>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = <3 RK_PA0 1 &pcfg_pull_none>, - <3 RK_PA1 1 &pcfg_pull_none>; - }; - }; - - i2c3 { - i2c3_xfer: i2c3-xfer { - rockchip,pins = <3 RK_PA2 2 &pcfg_pull_none>, - <3 RK_PA3 2 &pcfg_pull_none>; - }; - }; - - i2c4 { - i2c4_xfer: i2c4-xfer { - rockchip,pins = <3 RK_PA4 1 &pcfg_pull_none>, - <3 RK_PA5 1 &pcfg_pull_none>; - }; - }; - - pwm0 { - pwm0_out: pwm0-out { - rockchip,pins = <0 RK_PA3 1 &pcfg_pull_none>; - }; - }; - - pwm1 { - pwm1_out: pwm1-out { - rockchip,pins = <0 RK_PA4 1 &pcfg_pull_none>; - }; - }; - - pwm2 { - pwm2_out: pwm2-out { - rockchip,pins = <0 RK_PD6 1 &pcfg_pull_none>; - }; - }; - - pwm3 { - pwm3_out: pwm3-out { - rockchip,pins = <0 RK_PD7 1 &pcfg_pull_none>; - }; - }; - - spi0 { - spi0_clk: spi0-clk { - rockchip,pins = <1 RK_PA5 2 &pcfg_pull_default>; - }; - spi0_cs0: spi0-cs0 { - rockchip,pins = <1 RK_PA4 2 &pcfg_pull_default>; - }; - spi0_tx: spi0-tx { - rockchip,pins = <1 RK_PA7 2 &pcfg_pull_default>; - }; - spi0_rx: spi0-rx { - rockchip,pins = <1 RK_PA6 2 &pcfg_pull_default>; - }; - spi0_cs1: spi0-cs1 { - rockchip,pins = <4 RK_PB7 1 &pcfg_pull_default>; - }; - }; - - spi1 { - spi1_clk: spi1-clk { - rockchip,pins = <2 RK_PC3 2 &pcfg_pull_default>; - }; - spi1_cs0: spi1-cs0 { - rockchip,pins = <2 RK_PC4 2 &pcfg_pull_default>; - }; - spi1_rx: spi1-rx { - rockchip,pins = <2 RK_PC6 2 &pcfg_pull_default>; - }; - spi1_tx: spi1-tx { - rockchip,pins = <2 RK_PC5 2 &pcfg_pull_default>; - }; - spi1_cs1: spi1-cs1 { - rockchip,pins = <2 RK_PC7 2 &pcfg_pull_default>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = <1 RK_PA0 1 &pcfg_pull_default>, - <1 RK_PA1 1 &pcfg_pull_default>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = <1 RK_PA2 1 &pcfg_pull_default>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = <1 RK_PA3 1 &pcfg_pull_default>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = <1 RK_PA4 1 &pcfg_pull_default>, - <1 RK_PA5 1 &pcfg_pull_default>; - }; - - uart1_cts: uart1-cts { - rockchip,pins = <1 RK_PA6 1 &pcfg_pull_default>; - }; - - uart1_rts: uart1-rts { - rockchip,pins = <1 RK_PA7 1 &pcfg_pull_default>; - }; - }; - - uart2 { - uart2_xfer: uart2-xfer { - rockchip,pins = <1 RK_PB0 1 &pcfg_pull_default>, - <1 RK_PB1 1 &pcfg_pull_default>; - }; - /* no rts / cts for uart2 */ - }; - - uart3 { - uart3_xfer: uart3-xfer { - rockchip,pins = <3 RK_PD3 1 &pcfg_pull_default>, - <3 RK_PD4 1 &pcfg_pull_default>; - }; - - uart3_cts: uart3-cts { - rockchip,pins = <3 RK_PD5 1 &pcfg_pull_default>; - }; - - uart3_rts: uart3-rts { - rockchip,pins = <3 RK_PD6 1 &pcfg_pull_default>; - }; - }; - - sd0 { - sd0_clk: sd0-clk { - rockchip,pins = <3 RK_PB0 1 &pcfg_pull_default>; - }; - - sd0_cmd: sd0-cmd { - rockchip,pins = <3 RK_PB1 1 &pcfg_pull_default>; - }; - - sd0_cd: sd0-cd { - rockchip,pins = <3 RK_PB6 1 &pcfg_pull_default>; - }; - - sd0_wp: sd0-wp { - rockchip,pins = <3 RK_PB7 1 &pcfg_pull_default>; - }; - - sd0_bus1: sd0-bus-width1 { - rockchip,pins = <3 RK_PB2 1 &pcfg_pull_default>; - }; - - sd0_bus4: sd0-bus-width4 { - rockchip,pins = <3 RK_PB2 1 &pcfg_pull_default>, - <3 RK_PB3 1 &pcfg_pull_default>, - <3 RK_PB4 1 &pcfg_pull_default>, - <3 RK_PB5 1 &pcfg_pull_default>; - }; - }; - - sd1 { - sd1_clk: sd1-clk { - rockchip,pins = <3 RK_PC5 1 &pcfg_pull_default>; - }; - - sd1_cmd: sd1-cmd { - rockchip,pins = <3 RK_PC0 1 &pcfg_pull_default>; - }; - - sd1_cd: sd1-cd { - rockchip,pins = <3 RK_PC6 1 &pcfg_pull_default>; - }; - - sd1_wp: sd1-wp { - rockchip,pins = <3 RK_PC7 1 &pcfg_pull_default>; - }; - - sd1_bus1: sd1-bus-width1 { - rockchip,pins = <3 RK_PC1 1 &pcfg_pull_default>; - }; - - sd1_bus4: sd1-bus-width4 { - rockchip,pins = <3 RK_PC1 1 &pcfg_pull_default>, - <3 RK_PC2 1 &pcfg_pull_default>, - <3 RK_PC3 1 &pcfg_pull_default>, - <3 RK_PC4 1 &pcfg_pull_default>; - }; - }; - - i2s0 { - i2s0_bus: i2s0-bus { - rockchip,pins = <0 RK_PA7 1 &pcfg_pull_default>, - <0 RK_PB0 1 &pcfg_pull_default>, - <0 RK_PB1 1 &pcfg_pull_default>, - <0 RK_PB2 1 &pcfg_pull_default>, - <0 RK_PB3 1 &pcfg_pull_default>, - <0 RK_PB4 1 &pcfg_pull_default>, - <0 RK_PB5 1 &pcfg_pull_default>, - <0 RK_PB6 1 &pcfg_pull_default>, - <0 RK_PB7 1 &pcfg_pull_default>; - }; - }; - - i2s1 { - i2s1_bus: i2s1-bus { - rockchip,pins = <0 RK_PC0 1 &pcfg_pull_default>, - <0 RK_PC1 1 &pcfg_pull_default>, - <0 RK_PC2 1 &pcfg_pull_default>, - <0 RK_PC3 1 &pcfg_pull_default>, - <0 RK_PC4 1 &pcfg_pull_default>, - <0 RK_PC5 1 &pcfg_pull_default>; - }; - }; - - i2s2 { - i2s2_bus: i2s2-bus { - rockchip,pins = <0 RK_PD0 1 &pcfg_pull_default>, - <0 RK_PD1 1 &pcfg_pull_default>, - <0 RK_PD2 1 &pcfg_pull_default>, - <0 RK_PD3 1 &pcfg_pull_default>, - <0 RK_PD4 1 &pcfg_pull_default>, - <0 RK_PD5 1 &pcfg_pull_default>; - }; - }; - }; -}; - -&gpu { - compatible = "rockchip,rk3066-mali", "arm,mali-400"; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "gp", - "gpmmu", - "pp0", - "ppmmu0", - "pp1", - "ppmmu1", - "pp2", - "ppmmu2", - "pp3", - "ppmmu3"; - power-domains = <&power RK3066_PD_GPU>; -}; - -&grf { - compatible = "rockchip,rk3066-grf", "syscon", "simple-mfd"; - - usbphy: usbphy { - compatible = "rockchip,rk3066a-usb-phy"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - usbphy0: usb-phy@17c { - reg = <0x17c>; - clocks = <&cru SCLK_OTGPHY0>; - clock-names = "phyclk"; - #clock-cells = <0>; - #phy-cells = <0>; - }; - - usbphy1: usb-phy@188 { - reg = <0x188>; - clocks = <&cru SCLK_OTGPHY1>; - clock-names = "phyclk"; - #clock-cells = <0>; - #phy-cells = <0>; - }; - }; -}; - -&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; -}; - -&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_xfer>; -}; - -&i2c4 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_xfer>; -}; - -&mmc0 { - clock-frequency = <50000000>; - dmas = <&dmac2 1>; - dma-names = "rx-tx"; - max-frequency = <50000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sd0_clk &sd0_cmd &sd0_cd &sd0_bus4>; -}; - -&mmc1 { - dmas = <&dmac2 3>; - dma-names = "rx-tx"; - pinctrl-names = "default"; - pinctrl-0 = <&sd1_clk &sd1_cmd &sd1_cd &sd1_bus4>; -}; - -&emmc { - dmas = <&dmac2 4>; - dma-names = "rx-tx"; -}; - -&pmu { - power: power-controller { - compatible = "rockchip,rk3066-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RK3066_PD_VIO { - reg = <RK3066_PD_VIO>; - clocks = <&cru ACLK_LCDC0>, - <&cru ACLK_LCDC1>, - <&cru DCLK_LCDC0>, - <&cru DCLK_LCDC1>, - <&cru HCLK_LCDC0>, - <&cru HCLK_LCDC1>, - <&cru SCLK_CIF1>, - <&cru ACLK_CIF1>, - <&cru HCLK_CIF1>, - <&cru SCLK_CIF0>, - <&cru ACLK_CIF0>, - <&cru HCLK_CIF0>, - <&cru HCLK_HDMI>, - <&cru ACLK_IPP>, - <&cru HCLK_IPP>, - <&cru ACLK_RGA>, - <&cru HCLK_RGA>; - pm_qos = <&qos_lcdc0>, - <&qos_lcdc1>, - <&qos_cif0>, - <&qos_cif1>, - <&qos_ipp>, - <&qos_rga>; - #power-domain-cells = <0>; - }; - - power-domain@RK3066_PD_VIDEO { - reg = <RK3066_PD_VIDEO>; - clocks = <&cru ACLK_VDPU>, - <&cru ACLK_VEPU>, - <&cru HCLK_VDPU>, - <&cru HCLK_VEPU>; - pm_qos = <&qos_vpu>; - #power-domain-cells = <0>; - }; - - power-domain@RK3066_PD_GPU { - reg = <RK3066_PD_GPU>; - clocks = <&cru ACLK_GPU>; - pm_qos = <&qos_gpu>; - #power-domain-cells = <0>; - }; - }; -}; - -&pwm0 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_out>; -}; - -&pwm1 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_out>; -}; - -&pwm2 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_out>; -}; - -&pwm3 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm3_out>; -}; - -&spi0 { - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; -}; - -&spi1 { - pinctrl-names = "default"; - pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; -}; - -&uart0 { - compatible = "rockchip,rk3066-uart", "snps,dw-apb-uart"; - dmas = <&dmac1_s 0>, <&dmac1_s 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; -}; - -&uart1 { - compatible = "rockchip,rk3066-uart", "snps,dw-apb-uart"; - dmas = <&dmac1_s 2>, <&dmac1_s 3>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer>; -}; - -&uart2 { - compatible = "rockchip,rk3066-uart", "snps,dw-apb-uart"; - dmas = <&dmac2 6>, <&dmac2 7>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_xfer>; -}; - -&uart3 { - compatible = "rockchip,rk3066-uart", "snps,dw-apb-uart"; - dmas = <&dmac2 8>, <&dmac2 9>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_xfer>; -}; - -&vpu { - power-domains = <&power RK3066_PD_VIDEO>; -}; - -&wdt { - compatible = "rockchip,rk3066-wdt", "snps,dw-wdt"; -}; - -&emac { - compatible = "rockchip,rk3066-emac"; -}; diff --git a/arch/arm/dts/rk3188-radxarock.dts b/arch/arm/dts/rk3188-radxarock.dts deleted file mode 100644 index 118deacd38c4..000000000000 --- a/arch/arm/dts/rk3188-radxarock.dts +++ /dev/null @@ -1,389 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2013 Heiko Stuebner heiko@sntech.de - */ - -/dts-v1/; -#include <dt-bindings/input/input.h> -#include "rk3188.dtsi" - -/ { - model = "Radxa Rock"; - compatible = "radxa,rock", "rockchip,rk3188"; - - aliases { - mmc0 = &mmc0; - }; - - memory@60000000 { - device_type = "memory"; - reg = <0x60000000 0x80000000>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - key-power { - gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - linux,code = <KEY_POWER>; - label = "GPIO Key Power"; - linux,input-type = <1>; - wakeup-source; - debounce-interval = <100>; - }; - }; - - gpio-leds { - compatible = "gpio-leds"; - - green_led: led-0 { - label = "rock:green:user1"; - gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - blue_led: led-1 { - label = "rock:blue:user2"; - gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - sleep_led: led-2 { - label = "rock:red:power"; - gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "SPDIF"; - - simple-audio-card,dai-link@1 { /* S/PDIF - S/PDIF */ - cpu { sound-dai = <&spdif>; }; - codec { sound-dai = <&spdif_out>; }; - }; - }; - - spdif_out: spdif-out { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - }; - - ir_recv: ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_recv_pin>; - }; - - vcc_otg: usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PD7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "otg-vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_sd0: sdmmc-regulator { - compatible = "regulator-fixed"; - regulator-name = "sdmmc-supply"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 RK_PA1 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_pwr>; - startup-delay-us = <100000>; - vin-supply = <&vcc_io>; - }; - - vcc_host: usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "host-pwr"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vsys: vsys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vsys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-boot-on; - }; -}; - -&emac { - phy = <&phy0>; - phy-supply = <&vcc_rmii>; - pinctrl-names = "default"; - pinctrl-0 = <&emac_xfer>, <&emac_mdio>, <&phy_int>; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - phy0: ethernet-phy@0 { - reg = <0>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PD2 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&gpu { - status = "okay"; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; - - rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PB5 IRQ_TYPE_EDGE_FALLING>; - pinctrl-names = "default"; - pinctrl-0 = <&rtc_int>; - #clock-cells = <0>; - clock-output-names = "xin32k"; - }; - - act8846: act8846@5a { - compatible = "active-semi,act8846"; - reg = <0x5a>; - status = "okay"; - system-power-controller; - - pinctrl-names = "default"; - pinctrl-0 = <&act8846_dvs0_ctl>; - - vp1-supply = <&vsys>; - vp2-supply = <&vsys>; - vp3-supply = <&vsys>; - vp4-supply = <&vsys>; - inl1-supply = <&vcc_io>; - inl2-supply = <&vsys>; - inl3-supply = <&vsys>; - - regulators { - vcc_ddr: REG1 { - regulator-name = "VCC_DDR"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-always-on; - }; - - vdd_log: REG2 { - regulator-name = "VDD_LOG"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vdd_arm: REG3 { - regulator-name = "VDD_ARM"; - regulator-min-microvolt = <875000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - }; - - vcc_io: REG4 { - regulator-name = "VCC_IO"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vdd_10: REG5 { - regulator-name = "VDD_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - }; - - vdd_hdmi: REG6 { - regulator-name = "VDD_HDMI"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - regulator-always-on; - }; - - vcc18: REG7 { - regulator-name = "VCC_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcca_33: REG8 { - regulator-name = "VCCA_33"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vcc_rmii: REG9 { - regulator-name = "VCC_RMII"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vccio_wl: REG10 { - regulator-name = "VCCIO_WL"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - }; - - vcc_18: REG11 { - regulator-name = "VCC18_IO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc28: REG12 { - regulator-name = "VCC_28"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - }; - }; - }; -}; - -&mmc0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&sd0_clk>, <&sd0_cmd>, <&sd0_cd>, <&sd0_bus4>; - vmmc-supply = <&vcc_sd0>; - - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&pwm3 { - status = "okay"; -}; - -&pinctrl { - pcfg_output_low: pcfg-output-low { - output-low; - }; - - act8846 { - act8846_dvs0_ctl: act8846-dvs0-ctl { - rockchip,pins = <3 RK_PD3 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - hym8563 { - rtc_int: rtc-int { - rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - lan8720a { - phy_int: phy-int { - rockchip,pins = <3 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - ir-receiver { - ir_recv_pin: ir-recv-pin { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sd0 { - sdmmc_pwr: sdmmc-pwr { - rockchip,pins = <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - host_vbus_drv: host-vbus-drv { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <2 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&spdif { - status = "okay"; -}; - -&uart0 { - status = "okay"; -}; - -&uart1 { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&usb_host { - status = "okay"; -}; - -&usb_otg { - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3188-u-boot.dtsi b/arch/arm/dts/rk3188-u-boot.dtsi index 176f9e65c267..8f2849dda241 100644 --- a/arch/arm/dts/rk3188-u-boot.dtsi +++ b/arch/arm/dts/rk3188-u-boot.dtsi @@ -6,25 +6,8 @@ #include "rockchip-u-boot.dtsi" #include "rk3xxx-u-boot.dtsi"
-&global_timer { - status = "okay"; -}; - &gpio0 { compatible = "rockchip,gpio-bank"; - gpio-ranges = <&pinctrl 0 0 32>; -}; - -&gpio1 { - gpio-ranges = <&pinctrl 0 32 32>; -}; - -&gpio2 { - gpio-ranges = <&pinctrl 0 64 32>; -}; - -&gpio3 { - gpio-ranges = <&pinctrl 0 96 32>; };
&pmu { diff --git a/arch/arm/dts/rk3188.dtsi b/arch/arm/dts/rk3188.dtsi deleted file mode 100644 index 44b54af0bbf9..000000000000 --- a/arch/arm/dts/rk3188.dtsi +++ /dev/null @@ -1,815 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2013 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/clock/rk3188-cru.h> -#include <dt-bindings/power/rk3188-power.h> -#include "rk3xxx.dtsi" - -/ { - compatible = "rockchip,rk3188"; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - enable-method = "rockchip,rk3066-smp"; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x0>; - clock-latency = <40000>; - clocks = <&cru ARMCLK>; - operating-points-v2 = <&cpu0_opp_table>; - resets = <&cru SRST_CORE0>; - }; - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x1>; - operating-points-v2 = <&cpu0_opp_table>; - resets = <&cru SRST_CORE1>; - }; - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x2>; - operating-points-v2 = <&cpu0_opp_table>; - resets = <&cru SRST_CORE2>; - }; - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a9"; - next-level-cache = <&L2>; - reg = <0x3>; - operating-points-v2 = <&cpu0_opp_table>; - resets = <&cru SRST_CORE3>; - }; - }; - - cpu0_opp_table: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-312000000 { - opp-hz = /bits/ 64 <312000000>; - opp-microvolt = <875000>; - clock-latency-ns = <40000>; - }; - opp-504000000 { - opp-hz = /bits/ 64 <504000000>; - opp-microvolt = <925000>; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <950000>; - opp-suspend; - }; - opp-816000000 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <975000>; - }; - opp-1008000000 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <1075000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1150000>; - }; - opp-1416000000 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1250000>; - }; - opp-1608000000 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1350000>; - }; - }; - - display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vop0_out>, <&vop1_out>; - }; - - sram: sram@10080000 { - compatible = "mmio-sram"; - reg = <0x10080000 0x8000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x10080000 0x8000>; - - smp-sram@0 { - compatible = "rockchip,rk3066-smp-sram"; - reg = <0x0 0x50>; - }; - }; - - vop0: vop@1010c000 { - compatible = "rockchip,rk3188-vop"; - reg = <0x1010c000 0x1000>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_LCDC0>, <&cru DCLK_LCDC0>, <&cru HCLK_LCDC0>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3188_PD_VIO>; - resets = <&cru SRST_LCDC0_AXI>, <&cru SRST_LCDC0_AHB>, <&cru SRST_LCDC0_DCLK>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vop0_out: port { - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - vop1: vop@1010e000 { - compatible = "rockchip,rk3188-vop"; - reg = <0x1010e000 0x1000>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_LCDC1>, <&cru DCLK_LCDC1>, <&cru HCLK_LCDC1>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - power-domains = <&power RK3188_PD_VIO>; - resets = <&cru SRST_LCDC1_AXI>, <&cru SRST_LCDC1_AHB>, <&cru SRST_LCDC1_DCLK>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vop1_out: port { - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - timer3: timer@2000e000 { - compatible = "rockchip,rk3188-timer", "rockchip,rk3288-timer"; - reg = <0x2000e000 0x20>; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_TIMER3>, <&cru SCLK_TIMER3>; - clock-names = "pclk", "timer"; - }; - - timer6: timer@200380a0 { - compatible = "rockchip,rk3188-timer", "rockchip,rk3288-timer"; - reg = <0x200380a0 0x20>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER6>; - clock-names = "pclk", "timer"; - }; - - i2s0: i2s@1011a000 { - compatible = "rockchip,rk3188-i2s", "rockchip,rk3066-i2s"; - reg = <0x1011a000 0x2000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s0_bus>; - clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1_s 6>, <&dmac1_s 7>; - dma-names = "tx", "rx"; - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - spdif: sound@1011e000 { - compatible = "rockchip,rk3188-spdif", "rockchip,rk3066-spdif"; - reg = <0x1011e000 0x2000>; - #sound-dai-cells = <0>; - clocks = <&cru SCLK_SPDIF>, <&cru HCLK_SPDIF>; - clock-names = "mclk", "hclk"; - dmas = <&dmac1_s 8>; - dma-names = "tx"; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&spdif_tx>; - status = "disabled"; - }; - - cru: clock-controller@20000000 { - compatible = "rockchip,rk3188-cru"; - reg = <0x20000000 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - efuse: efuse@20010000 { - compatible = "rockchip,rk3188-efuse"; - reg = <0x20010000 0x4000>; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&cru PCLK_EFUSE>; - clock-names = "pclk_efuse"; - - cpu_leakage: cpu_leakage@17 { - reg = <0x17 0x1>; - }; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3188-pinctrl"; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmu>; - - #address-cells = <1>; - #size-cells = <1>; - ranges; - - gpio0: gpio@2000a000 { - compatible = "rockchip,rk3188-gpio-bank0"; - reg = <0x2000a000 0x100>; - interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO0>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@2003c000 { - compatible = "rockchip,gpio-bank"; - reg = <0x2003c000 0x100>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@2003e000 { - compatible = "rockchip,gpio-bank"; - reg = <0x2003e000 0x100>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@20080000 { - compatible = "rockchip,gpio-bank"; - reg = <0x20080000 0x100>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - pcfg_pull_up: pcfg-pull-up { - bias-pull-up; - }; - - pcfg_pull_down: pcfg-pull-down { - bias-pull-down; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - emmc { - emmc_clk: emmc-clk { - rockchip,pins = <0 RK_PD0 2 &pcfg_pull_none>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = <0 RK_PD2 2 &pcfg_pull_up>; - }; - - emmc_rst: emmc-rst { - rockchip,pins = <0 RK_PD3 2 &pcfg_pull_none>; - }; - - /* - * The data pins are shared between nandc and emmc and - * not accessible through pinctrl. Also they should've - * been already set correctly by firmware, as - * flash/emmc is the boot-device. - */ - }; - - emac { - emac_xfer: emac-xfer { - rockchip,pins = <3 RK_PC0 2 &pcfg_pull_none>, /* tx_en */ - <3 RK_PC1 2 &pcfg_pull_none>, /* txd1 */ - <3 RK_PC2 2 &pcfg_pull_none>, /* txd0 */ - <3 RK_PC3 2 &pcfg_pull_none>, /* rxd0 */ - <3 RK_PC4 2 &pcfg_pull_none>, /* rxd1 */ - <3 RK_PC5 2 &pcfg_pull_none>, /* mac_clk */ - <3 RK_PC6 2 &pcfg_pull_none>, /* rx_err */ - <3 RK_PC7 2 &pcfg_pull_none>; /* crs_dvalid */ - }; - - emac_mdio: emac-mdio { - rockchip,pins = <3 RK_PD0 2 &pcfg_pull_none>, - <3 RK_PD1 2 &pcfg_pull_none>; - }; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>, - <1 RK_PD1 1 &pcfg_pull_none>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = <1 RK_PD2 1 &pcfg_pull_none>, - <1 RK_PD3 1 &pcfg_pull_none>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = <1 RK_PD4 1 &pcfg_pull_none>, - <1 RK_PD5 1 &pcfg_pull_none>; - }; - }; - - i2c3 { - i2c3_xfer: i2c3-xfer { - rockchip,pins = <3 RK_PB6 2 &pcfg_pull_none>, - <3 RK_PB7 2 &pcfg_pull_none>; - }; - }; - - i2c4 { - i2c4_xfer: i2c4-xfer { - rockchip,pins = <1 RK_PD6 1 &pcfg_pull_none>, - <1 RK_PD7 1 &pcfg_pull_none>; - }; - }; - - lcdc1 { - lcdc1_dclk: lcdc1-dclk { - rockchip,pins = <2 RK_PD0 1 &pcfg_pull_none>; - }; - - lcdc1_den: lcdc1-den { - rockchip,pins = <2 RK_PD1 1 &pcfg_pull_none>; - }; - - lcdc1_hsync: lcdc1-hsync { - rockchip,pins = <2 RK_PD2 1 &pcfg_pull_none>; - }; - - lcdc1_vsync: lcdc1-vsync { - rockchip,pins = <2 RK_PD3 1 &pcfg_pull_none>; - }; - - lcdc1_rgb24: lcdc1-rgb24 { - rockchip,pins = <2 RK_PA0 1 &pcfg_pull_none>, - <2 RK_PA1 1 &pcfg_pull_none>, - <2 RK_PA2 1 &pcfg_pull_none>, - <2 RK_PA3 1 &pcfg_pull_none>, - <2 RK_PA4 1 &pcfg_pull_none>, - <2 RK_PA5 1 &pcfg_pull_none>, - <2 RK_PA6 1 &pcfg_pull_none>, - <2 RK_PA7 1 &pcfg_pull_none>, - <2 RK_PB0 1 &pcfg_pull_none>, - <2 RK_PB1 1 &pcfg_pull_none>, - <2 RK_PB2 1 &pcfg_pull_none>, - <2 RK_PB3 1 &pcfg_pull_none>, - <2 RK_PB4 1 &pcfg_pull_none>, - <2 RK_PB5 1 &pcfg_pull_none>, - <2 RK_PB6 1 &pcfg_pull_none>, - <2 RK_PB7 1 &pcfg_pull_none>, - <2 RK_PC0 1 &pcfg_pull_none>, - <2 RK_PC1 1 &pcfg_pull_none>, - <2 RK_PC2 1 &pcfg_pull_none>, - <2 RK_PC3 1 &pcfg_pull_none>, - <2 RK_PC4 1 &pcfg_pull_none>, - <2 RK_PC5 1 &pcfg_pull_none>, - <2 RK_PC6 1 &pcfg_pull_none>, - <2 RK_PC7 1 &pcfg_pull_none>; - }; - }; - - pwm0 { - pwm0_out: pwm0-out { - rockchip,pins = <3 RK_PD3 1 &pcfg_pull_none>; - }; - }; - - pwm1 { - pwm1_out: pwm1-out { - rockchip,pins = <3 RK_PD4 1 &pcfg_pull_none>; - }; - }; - - pwm2 { - pwm2_out: pwm2-out { - rockchip,pins = <3 RK_PD5 1 &pcfg_pull_none>; - }; - }; - - pwm3 { - pwm3_out: pwm3-out { - rockchip,pins = <3 RK_PD6 1 &pcfg_pull_none>; - }; - }; - - spi0 { - spi0_clk: spi0-clk { - rockchip,pins = <1 RK_PA6 2 &pcfg_pull_up>; - }; - spi0_cs0: spi0-cs0 { - rockchip,pins = <1 RK_PA7 2 &pcfg_pull_up>; - }; - spi0_tx: spi0-tx { - rockchip,pins = <1 RK_PA5 2 &pcfg_pull_up>; - }; - spi0_rx: spi0-rx { - rockchip,pins = <1 RK_PA4 2 &pcfg_pull_up>; - }; - spi0_cs1: spi0-cs1 { - rockchip,pins = <1 RK_PB7 1 &pcfg_pull_up>; - }; - }; - - spi1 { - spi1_clk: spi1-clk { - rockchip,pins = <0 RK_PD6 1 &pcfg_pull_up>; - }; - spi1_cs0: spi1-cs0 { - rockchip,pins = <0 RK_PD7 1 &pcfg_pull_up>; - }; - spi1_rx: spi1-rx { - rockchip,pins = <0 RK_PD4 1 &pcfg_pull_up>; - }; - spi1_tx: spi1-tx { - rockchip,pins = <0 RK_PD5 1 &pcfg_pull_up>; - }; - spi1_cs1: spi1-cs1 { - rockchip,pins = <1 RK_PB6 2 &pcfg_pull_up>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = <1 RK_PA0 1 &pcfg_pull_up>, - <1 RK_PA1 1 &pcfg_pull_none>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = <1 RK_PA2 1 &pcfg_pull_none>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = <1 RK_PA3 1 &pcfg_pull_none>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = <1 RK_PA4 1 &pcfg_pull_up>, - <1 RK_PA5 1 &pcfg_pull_none>; - }; - - uart1_cts: uart1-cts { - rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none>; - }; - - uart1_rts: uart1-rts { - rockchip,pins = <1 RK_PA7 1 &pcfg_pull_none>; - }; - }; - - uart2 { - uart2_xfer: uart2-xfer { - rockchip,pins = <1 RK_PB0 1 &pcfg_pull_up>, - <1 RK_PB1 1 &pcfg_pull_none>; - }; - /* no rts / cts for uart2 */ - }; - - uart3 { - uart3_xfer: uart3-xfer { - rockchip,pins = <1 RK_PB2 1 &pcfg_pull_up>, - <1 RK_PB3 1 &pcfg_pull_none>; - }; - - uart3_cts: uart3-cts { - rockchip,pins = <1 RK_PB4 1 &pcfg_pull_none>; - }; - - uart3_rts: uart3-rts { - rockchip,pins = <1 RK_PB5 1 &pcfg_pull_none>; - }; - }; - - sd0 { - sd0_clk: sd0-clk { - rockchip,pins = <3 RK_PA2 1 &pcfg_pull_none>; - }; - - sd0_cmd: sd0-cmd { - rockchip,pins = <3 RK_PA3 1 &pcfg_pull_none>; - }; - - sd0_cd: sd0-cd { - rockchip,pins = <3 RK_PB0 1 &pcfg_pull_none>; - }; - - sd0_wp: sd0-wp { - rockchip,pins = <3 RK_PB1 1 &pcfg_pull_none>; - }; - - sd0_pwr: sd0-pwr { - rockchip,pins = <3 RK_PA1 1 &pcfg_pull_none>; - }; - - sd0_bus1: sd0-bus-width1 { - rockchip,pins = <3 RK_PA4 1 &pcfg_pull_none>; - }; - - sd0_bus4: sd0-bus-width4 { - rockchip,pins = <3 RK_PA4 1 &pcfg_pull_none>, - <3 RK_PA5 1 &pcfg_pull_none>, - <3 RK_PA6 1 &pcfg_pull_none>, - <3 RK_PA7 1 &pcfg_pull_none>; - }; - }; - - sd1 { - sd1_clk: sd1-clk { - rockchip,pins = <3 RK_PC5 1 &pcfg_pull_none>; - }; - - sd1_cmd: sd1-cmd { - rockchip,pins = <3 RK_PC0 1 &pcfg_pull_none>; - }; - - sd1_cd: sd1-cd { - rockchip,pins = <3 RK_PC6 1 &pcfg_pull_none>; - }; - - sd1_wp: sd1-wp { - rockchip,pins = <3 RK_PC7 1 &pcfg_pull_none>; - }; - - sd1_bus1: sd1-bus-width1 { - rockchip,pins = <3 RK_PC1 1 &pcfg_pull_none>; - }; - - sd1_bus4: sd1-bus-width4 { - rockchip,pins = <3 RK_PC1 1 &pcfg_pull_none>, - <3 RK_PC2 1 &pcfg_pull_none>, - <3 RK_PC3 1 &pcfg_pull_none>, - <3 RK_PC4 1 &pcfg_pull_none>; - }; - }; - - i2s0 { - i2s0_bus: i2s0-bus { - rockchip,pins = <1 RK_PC0 1 &pcfg_pull_none>, - <1 RK_PC1 1 &pcfg_pull_none>, - <1 RK_PC2 1 &pcfg_pull_none>, - <1 RK_PC3 1 &pcfg_pull_none>, - <1 RK_PC4 1 &pcfg_pull_none>, - <1 RK_PC5 1 &pcfg_pull_none>; - }; - }; - - spdif { - spdif_tx: spdif-tx { - rockchip,pins = <1 RK_PB6 1 &pcfg_pull_none>; - }; - }; - }; -}; - -&emac { - compatible = "rockchip,rk3188-emac"; -}; - -&global_timer { - interrupts = <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_EDGE_RISING)>; -}; - -&local_timer { - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_EDGE_RISING)>; -}; - -&gpu { - compatible = "rockchip,rk3188-mali", "arm,mali-400"; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "gp", - "gpmmu", - "pp0", - "ppmmu0", - "pp1", - "ppmmu1", - "pp2", - "ppmmu2", - "pp3", - "ppmmu3"; - power-domains = <&power RK3188_PD_GPU>; -}; - -&grf { - compatible = "rockchip,rk3188-grf", "syscon", "simple-mfd"; - - io_domains: io-domains { - compatible = "rockchip,rk3188-io-voltage-domain"; - status = "disabled"; - }; - - usbphy: usbphy { - compatible = "rockchip,rk3188-usb-phy"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - usbphy0: usb-phy@10c { - reg = <0x10c>; - clocks = <&cru SCLK_OTGPHY0>; - clock-names = "phyclk"; - #clock-cells = <0>; - #phy-cells = <0>; - }; - - usbphy1: usb-phy@11c { - reg = <0x11c>; - clocks = <&cru SCLK_OTGPHY1>; - clock-names = "phyclk"; - #clock-cells = <0>; - #phy-cells = <0>; - }; - }; -}; - -&i2c0 { - compatible = "rockchip,rk3188-i2c"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; -}; - -&i2c1 { - compatible = "rockchip,rk3188-i2c"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; -}; - -&i2c2 { - compatible = "rockchip,rk3188-i2c"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; -}; - -&i2c3 { - compatible = "rockchip,rk3188-i2c"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_xfer>; -}; - -&i2c4 { - compatible = "rockchip,rk3188-i2c"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_xfer>; -}; - -&pmu { - power: power-controller { - compatible = "rockchip,rk3188-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RK3188_PD_VIO { - reg = <RK3188_PD_VIO>; - clocks = <&cru ACLK_LCDC0>, - <&cru ACLK_LCDC1>, - <&cru DCLK_LCDC0>, - <&cru DCLK_LCDC1>, - <&cru HCLK_LCDC0>, - <&cru HCLK_LCDC1>, - <&cru SCLK_CIF0>, - <&cru ACLK_CIF0>, - <&cru HCLK_CIF0>, - <&cru ACLK_IPP>, - <&cru HCLK_IPP>, - <&cru ACLK_RGA>, - <&cru HCLK_RGA>; - pm_qos = <&qos_lcdc0>, - <&qos_lcdc1>, - <&qos_cif0>, - <&qos_ipp>, - <&qos_rga>; - #power-domain-cells = <0>; - }; - - power-domain@RK3188_PD_VIDEO { - reg = <RK3188_PD_VIDEO>; - clocks = <&cru ACLK_VDPU>, - <&cru ACLK_VEPU>, - <&cru HCLK_VDPU>, - <&cru HCLK_VEPU>; - pm_qos = <&qos_vpu>; - #power-domain-cells = <0>; - }; - - power-domain@RK3188_PD_GPU { - reg = <RK3188_PD_GPU>; - clocks = <&cru ACLK_GPU>; - pm_qos = <&qos_gpu>; - #power-domain-cells = <0>; - }; - }; -}; - -&pwm0 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_out>; -}; - -&pwm1 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_out>; -}; - -&pwm2 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_out>; -}; - -&pwm3 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm3_out>; -}; - -&spi0 { - compatible = "rockchip,rk3188-spi", "rockchip,rk3066-spi"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; -}; - -&spi1 { - compatible = "rockchip,rk3188-spi", "rockchip,rk3066-spi"; - pinctrl-names = "default"; - pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; -}; - -&uart0 { - compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; -}; - -&uart1 { - compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer>; -}; - -&uart2 { - compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_xfer>; -}; - -&uart3 { - compatible = "rockchip,rk3188-uart", "snps,dw-apb-uart"; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_xfer>; -}; - -&vpu { - compatible = "rockchip,rk3188-vpu", "rockchip,rk3066-vpu"; - power-domains = <&power RK3188_PD_VIDEO>; -}; - -&wdt { - compatible = "rockchip,rk3188-wdt", "snps,dw-wdt"; -}; diff --git a/arch/arm/dts/rk3xxx.dtsi b/arch/arm/dts/rk3xxx.dtsi deleted file mode 100644 index cb4e42ede56a..000000000000 --- a/arch/arm/dts/rk3xxx.dtsi +++ /dev/null @@ -1,488 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2013 MundoReader S.L. - * Author: Heiko Stuebner heiko@sntech.de - */ - -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> - -/ { - #address-cells = <1>; - #size-cells = <1>; - - interrupt-parent = <&gic>; - - aliases { - ethernet0 = &emac; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - spi0 = &spi0; - spi1 = &spi1; - }; - - xin24m: oscillator { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - #clock-cells = <0>; - clock-output-names = "xin24m"; - }; - - gpu: gpu@10090000 { - compatible = "arm,mali-400"; - reg = <0x10090000 0x10000>; - clocks = <&cru ACLK_GPU>, <&cru ACLK_GPU>; - clock-names = "bus", "core"; - assigned-clocks = <&cru ACLK_GPU>; - assigned-clock-rates = <100000000>; - resets = <&cru SRST_GPU>; - status = "disabled"; - }; - - vpu: video-codec@10104000 { - compatible = "rockchip,rk3066-vpu"; - reg = <0x10104000 0x800>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vepu", "vdpu"; - clocks = <&cru ACLK_VDPU>, <&cru HCLK_VDPU>, - <&cru ACLK_VEPU>, <&cru HCLK_VEPU>; - clock-names = "aclk_vdpu", "hclk_vdpu", - "aclk_vepu", "hclk_vepu"; - }; - - L2: cache-controller@10138000 { - compatible = "arm,pl310-cache"; - reg = <0x10138000 0x1000>; - cache-unified; - cache-level = <2>; - }; - - scu@1013c000 { - compatible = "arm,cortex-a9-scu"; - reg = <0x1013c000 0x100>; - }; - - global_timer: global-timer@1013c200 { - compatible = "arm,cortex-a9-global-timer"; - reg = <0x1013c200 0x20>; - interrupts = <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_EDGE_RISING)>; - clocks = <&cru CORE_PERI>; - status = "disabled"; - /* The clock source and the sched_clock provided by the arm_global_timer - * on Rockchip rk3066a/rk3188 are quite unstable because their rates - * depend on the CPU frequency. - * Keep the arm_global_timer disabled in order to have the - * DW_APB_TIMER (rk3066a) or ROCKCHIP_TIMER (rk3188) selected by default. - */ - }; - - local_timer: local-timer@1013c600 { - compatible = "arm,cortex-a9-twd-timer"; - reg = <0x1013c600 0x20>; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_EDGE_RISING)>; - clocks = <&cru CORE_PERI>; - }; - - gic: interrupt-controller@1013d000 { - compatible = "arm,cortex-a9-gic"; - interrupt-controller; - #interrupt-cells = <3>; - reg = <0x1013d000 0x1000>, - <0x1013c100 0x0100>; - }; - - uart0: serial@10124000 { - compatible = "snps,dw-apb-uart"; - reg = <0x10124000 0x400>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <1>; - clock-names = "baudclk", "apb_pclk"; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - status = "disabled"; - }; - - uart1: serial@10126000 { - compatible = "snps,dw-apb-uart"; - reg = <0x10126000 0x400>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <1>; - clock-names = "baudclk", "apb_pclk"; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - status = "disabled"; - }; - - qos_gpu: qos@1012d000 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012d000 0x20>; - }; - - qos_vpu: qos@1012e000 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012e000 0x20>; - }; - - qos_lcdc0: qos@1012f000 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f000 0x20>; - }; - - qos_cif0: qos@1012f080 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f080 0x20>; - }; - - qos_ipp: qos@1012f100 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f100 0x20>; - }; - - qos_lcdc1: qos@1012f180 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f180 0x20>; - }; - - qos_cif1: qos@1012f200 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f200 0x20>; - }; - - qos_rga: qos@1012f280 { - compatible = "rockchip,rk3066-qos", "syscon"; - reg = <0x1012f280 0x20>; - }; - - usb_otg: usb@10180000 { - compatible = "rockchip,rk3066-usb", "snps,dwc2"; - reg = <0x10180000 0x40000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG0>; - clock-names = "otg"; - dr_mode = "otg"; - g-np-tx-fifo-size = <16>; - g-rx-fifo-size = <275>; - g-tx-fifo-size = <256 128 128 64 64 32>; - phys = <&usbphy0>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - - usb_host: usb@101c0000 { - compatible = "snps,dwc2"; - reg = <0x101c0000 0x40000>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG1>; - clock-names = "otg"; - dr_mode = "host"; - phys = <&usbphy1>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - - emac: ethernet@10204000 { - compatible = "snps,arc-emac"; - reg = <0x10204000 0x3c>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - - rockchip,grf = <&grf>; - - clocks = <&cru HCLK_EMAC>, <&cru SCLK_MAC>; - clock-names = "hclk", "macref"; - max-speed = <100>; - phy-mode = "rmii"; - - status = "disabled"; - }; - - mmc0: mmc@10214000 { - compatible = "rockchip,rk2928-dw-mshc"; - reg = <0x10214000 0x1000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>; - clock-names = "biu", "ciu"; - dmas = <&dmac2 1>; - dma-names = "rx-tx"; - fifo-depth = <256>; - resets = <&cru SRST_SDMMC>; - reset-names = "reset"; - status = "disabled"; - }; - - mmc1: mmc@10218000 { - compatible = "rockchip,rk2928-dw-mshc"; - reg = <0x10218000 0x1000>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>; - clock-names = "biu", "ciu"; - dmas = <&dmac2 3>; - dma-names = "rx-tx"; - fifo-depth = <256>; - resets = <&cru SRST_SDIO>; - reset-names = "reset"; - status = "disabled"; - }; - - emmc: mmc@1021c000 { - compatible = "rockchip,rk2928-dw-mshc"; - reg = <0x1021c000 0x1000>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>; - clock-names = "biu", "ciu"; - dmas = <&dmac2 4>; - dma-names = "rx-tx"; - fifo-depth = <256>; - resets = <&cru SRST_EMMC>; - reset-names = "reset"; - status = "disabled"; - }; - - nfc: nand-controller@10500000 { - compatible = "rockchip,rk2928-nfc"; - reg = <0x10500000 0x4000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_NANDC0>; - clock-names = "ahb"; - status = "disabled"; - }; - - pmu: pmu@20004000 { - compatible = "rockchip,rk3066-pmu", "syscon", "simple-mfd"; - reg = <0x20004000 0x100>; - - reboot-mode { - compatible = "syscon-reboot-mode"; - offset = <0x40>; - mode-normal = <BOOT_NORMAL>; - mode-recovery = <BOOT_RECOVERY>; - mode-bootloader = <BOOT_FASTBOOT>; - mode-loader = <BOOT_BL_DOWNLOAD>; - }; - }; - - grf: grf@20008000 { - compatible = "syscon", "simple-mfd"; - reg = <0x20008000 0x200>; - }; - - dmac1_s: dma-controller@20018000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x20018000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMA1>; - clock-names = "apb_pclk"; - }; - - dmac1_ns: dma-controller@2001c000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x2001c000 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMA1>; - clock-names = "apb_pclk"; - status = "disabled"; - }; - - i2c0: i2c@2002d000 { - compatible = "rockchip,rk3066-i2c"; - reg = <0x2002d000 0x1000>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - - rockchip,grf = <&grf>; - - clock-names = "i2c"; - clocks = <&cru PCLK_I2C0>; - - status = "disabled"; - }; - - i2c1: i2c@2002f000 { - compatible = "rockchip,rk3066-i2c"; - reg = <0x2002f000 0x1000>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - - rockchip,grf = <&grf>; - - clocks = <&cru PCLK_I2C1>; - clock-names = "i2c"; - - status = "disabled"; - }; - - pwm0: pwm@20030000 { - compatible = "rockchip,rk2928-pwm"; - reg = <0x20030000 0x10>; - #pwm-cells = <2>; - clocks = <&cru PCLK_PWM01>; - status = "disabled"; - }; - - pwm1: pwm@20030010 { - compatible = "rockchip,rk2928-pwm"; - reg = <0x20030010 0x10>; - #pwm-cells = <2>; - clocks = <&cru PCLK_PWM01>; - status = "disabled"; - }; - - wdt: watchdog@2004c000 { - compatible = "snps,dw-wdt"; - reg = <0x2004c000 0x100>; - clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - pwm2: pwm@20050020 { - compatible = "rockchip,rk2928-pwm"; - reg = <0x20050020 0x10>; - #pwm-cells = <2>; - clocks = <&cru PCLK_PWM23>; - status = "disabled"; - }; - - pwm3: pwm@20050030 { - compatible = "rockchip,rk2928-pwm"; - reg = <0x20050030 0x10>; - #pwm-cells = <2>; - clocks = <&cru PCLK_PWM23>; - status = "disabled"; - }; - - i2c2: i2c@20056000 { - compatible = "rockchip,rk3066-i2c"; - reg = <0x20056000 0x1000>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - - rockchip,grf = <&grf>; - - clocks = <&cru PCLK_I2C2>; - clock-names = "i2c"; - - status = "disabled"; - }; - - i2c3: i2c@2005a000 { - compatible = "rockchip,rk3066-i2c"; - reg = <0x2005a000 0x1000>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - - rockchip,grf = <&grf>; - - clocks = <&cru PCLK_I2C3>; - clock-names = "i2c"; - - status = "disabled"; - }; - - i2c4: i2c@2005e000 { - compatible = "rockchip,rk3066-i2c"; - reg = <0x2005e000 0x1000>; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - - rockchip,grf = <&grf>; - - clocks = <&cru PCLK_I2C4>; - clock-names = "i2c"; - - status = "disabled"; - }; - - uart2: serial@20064000 { - compatible = "snps,dw-apb-uart"; - reg = <0x20064000 0x400>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <1>; - clock-names = "baudclk", "apb_pclk"; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - status = "disabled"; - }; - - uart3: serial@20068000 { - compatible = "snps,dw-apb-uart"; - reg = <0x20068000 0x400>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <1>; - clock-names = "baudclk", "apb_pclk"; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - status = "disabled"; - }; - - saradc: saradc@2006c000 { - compatible = "rockchip,saradc"; - reg = <0x2006c000 0x100>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - #io-channel-cells = <1>; - clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_SARADC>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - spi0: spi@20070000 { - compatible = "rockchip,rk3066-spi"; - clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x20070000 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - dmas = <&dmac2 10>, <&dmac2 11>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - spi1: spi@20074000 { - compatible = "rockchip,rk3066-spi"; - clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x20074000 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - dmas = <&dmac2 12>, <&dmac2 13>; - dma-names = "tx", "rx"; - status = "disabled"; - }; - - dmac2: dma-controller@20078000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x20078000 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - #dma-cells = <1>; - arm,pl330-broken-no-flushp; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMA2>; - clock-names = "apb_pclk"; - }; -}; diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 269c219a6f8c..4d3157b2edd3 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -48,6 +48,7 @@ config ROCKCHIP_RK3066 select TPL select TPL_ROCKCHIP_BACK_TO_BROM select TPL_ROCKCHIP_EARLYRETURN_TO_BROM + imply OF_UPSTREAM imply ROCKCHIP_COMMON_BOARD imply SPL_ROCKCHIP_COMMON_BOARD imply SPL_SERIAL @@ -84,6 +85,7 @@ config ROCKCHIP_RK3188 select SPL_ROCKCHIP_EARLYRETURN_TO_BROM select SPL_ROCKCHIP_BACK_TO_BROM select BOARD_LATE_INIT + imply OF_UPSTREAM imply ROCKCHIP_COMMON_BOARD imply SPL_ROCKCHIP_COMMON_BOARD help diff --git a/configs/mk808_defconfig b/configs/mk808_defconfig index 12a37054b4da..e47d0b594f35 100644 --- a/configs/mk808_defconfig +++ b/configs/mk808_defconfig @@ -14,7 +14,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x78000000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_SIZE=0x8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3066a-mk808" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3066a-mk808" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3066=y # CONFIG_ROCKCHIP_STIMER is not set @@ -35,7 +35,7 @@ CONFIG_SPL_PAYLOAD="u-boot.bin" CONFIG_DEBUG_UART=y CONFIG_SD_BOOT=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3066a-mk808.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3066a-mk808.dtb" CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/rock_defconfig b/configs/rock_defconfig index d7f11310cba1..9c05bf451465 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -11,7 +11,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x60100000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3188-radxarock" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3188-radxarock" CONFIG_ROCKCHIP_RK3188=y # CONFIG_ROCKCHIP_STIMER is not set CONFIG_TARGET_ROCK=y @@ -25,7 +25,7 @@ CONFIG_DEBUG_UART_BASE=0x20064000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y -CONFIG_DEFAULT_FDT_FILE="rk3188-radxarock.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3188-radxarock.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x7800 -- 2.39.5
Hi Johan,
Did you test on related boards? There seems have more difference in dts for older SoCs like rk3066/rk3188.
On 2024/12/9 01:43, Johan Jonker wrote:
The device tree for rk3066a/rk3188 combined is now available in the /dts/upstream directory. Use imply OF_UPSTREAM to migrate all rk3066a/rk3188 boards.
Signed-off-by: Johan Jonker jbx6244@gmail.com
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/dts/rk3066a-mk808.dts | 241 -------- arch/arm/dts/rk3066a-u-boot.dtsi | 20 - arch/arm/dts/rk3066a.dtsi | 880 ------------------------------ arch/arm/dts/rk3188-radxarock.dts | 389 ------------- arch/arm/dts/rk3188-u-boot.dtsi | 17 - arch/arm/dts/rk3188.dtsi | 815 --------------------------- arch/arm/dts/rk3xxx.dtsi | 488 ----------------- arch/arm/mach-rockchip/Kconfig | 2 + configs/mk808_defconfig | 4 +- configs/rock_defconfig | 4 +- 10 files changed, 6 insertions(+), 2854 deletions(-) delete mode 100644 arch/arm/dts/rk3066a-mk808.dts delete mode 100644 arch/arm/dts/rk3066a.dtsi delete mode 100644 arch/arm/dts/rk3188-radxarock.dts delete mode 100644 arch/arm/dts/rk3188.dtsi delete mode 100644 arch/arm/dts/rk3xxx.dtsi
diff --git a/arch/arm/dts/rk3066a-mk808.dts b/arch/arm/dts/rk3066a-mk808.dts deleted file mode 100644 index 06790f05b395..000000000000 --- a/arch/arm/dts/rk3066a-mk808.dts +++ /dev/null @@ -1,241 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2016 Paweł Jarosz paweljarosz3691@gmail.com
-/dts-v1/; -#include <dt-bindings/input/input.h> -#include "rk3066a.dtsi"
- model = "Rikomagic MK808";
- compatible = "rikomagic,mk808", "rockchip,rk3066a";
- aliases {
mmc0 = &mmc0;
mmc1 = &mmc1;
- chosen {
stdout-path = "serial2:115200n8";
- memory@60000000 {
reg = <0x60000000 0x40000000>;
- adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 1>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <2500000>;
poll-interval = <100>;
button-recovery {
label = "recovery";
linux,code = <KEY_VENDOR>;
press-threshold-microvolt = <0>;
- gpio-leds {
blue_led: led-0 {
label = "mk808:blue:power";
gpios = <&gpio0 RK_PA3 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "default-on";
- hdmi_con {
compatible = "hdmi-connector";
type = "c";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
- vcc_2v5: vcc-2v5 {
regulator-name = "vcc_2v5";
- vcc_io: vcc-io {
regulator-name = "vcc_io";
enable-active-high;
gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&host_drv>;
enable-active-high;
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&otg_drv>;
regulator-name = "vcc_otg";
- vcc_sd: sdmmc-regulator {
gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_LOW>;
regulator-name = "vcc_sd";
- vcc_wifi: sdio-regulator {
enable-active-high;
gpio = <&gpio3 RK_PD0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&wifi_pwr>;
regulator-name = "vcc_wifi";
-&hdmi {
- status = "okay";
-&hdmi_in_vop1 {
-&hdmi_out {
- hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
-&mmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- vmmc-supply = <&vcc_sd>;
- status = "okay";
-&mmc1 {
- bus-width = <4>;
- non-removable;
- pinctrl-0 = <&sd1_clk &sd1_cmd &sd1_bus4>;
- vmmc-supply = <&vcc_wifi>;
- status = "okay";
- brcmf: wifi@1 {
compatible = "brcm,bcm4329-fmac";
reg = <1>;
-&nfc {
- status = "okay";
- nand@0 {
reg = <0>;
label = "rk-nand";
nand-bus-width = <8>;
nand-ecc-mode = "hw";
nand-ecc-step-size = <1024>;
nand-ecc-strength = <40>;
nand-is-boot-medium;
rockchip,boot-blks = <8>;
rockchip,boot-ecc-strength = <24>;
-&pinctrl {
- usb-host {
host_drv: host-drv {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_default>;
- usb-otg {
otg_drv: otg-drv {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_default>;
- sdmmc {
rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_default>;
- sdio {
wifi_pwr: wifi-pwr {
rockchip,pins = <3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
-&saradc {
- vref-supply = <&vcc_2v5>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host {
- status = "okay";
-&usb_otg {
- status = "okay";
-&usbphy {
- status = "okay";
-&vop0 {
- status = "okay";
-&wdt {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3066a-u-boot.dtsi b/arch/arm/dts/rk3066a-u-boot.dtsi index 06f405ca2c5e..d99db7853b59 100644 --- a/arch/arm/dts/rk3066a-u-boot.dtsi +++ b/arch/arm/dts/rk3066a-u-boot.dtsi @@ -3,26 +3,6 @@ #include "rockchip-u-boot.dtsi" #include "rk3xxx-u-boot.dtsi"
-&gpio0 {
-&gpio1 {
-&gpio2 {
-&gpio3 {
-&gpio4 {
- gpio-ranges = <&pinctrl 0 128 32>;
- &gpio6 { status = "disabled"; };
diff --git a/arch/arm/dts/rk3066a.dtsi b/arch/arm/dts/rk3066a.dtsi deleted file mode 100644 index de9915d946f7..000000000000 --- a/arch/arm/dts/rk3066a.dtsi +++ /dev/null @@ -1,880 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2013 MundoReader S.L.
- Author: Heiko Stuebner heiko@sntech.de
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/clock/rk3066a-cru.h> -#include <dt-bindings/power/rk3066-power.h> -#include "rk3xxx.dtsi"
- compatible = "rockchip,rk3066a";
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
operating-points =
/* kHz uV */
<1416000 1300000>,
<1200000 1175000>,
<1008000 1125000>,
<816000 1125000>,
<600000 1100000>,
<504000 1100000>,
<312000 1075000>;
cpu1: cpu@1 {
reg = <0x1>;
reg = <0x10080000 0x10000>;
#size-cells = <1>;
ranges = <0 0x10080000 0x10000>;
smp-sram@0 {
reg = <0x0 0x50>;
compatible = "rockchip,rk3066-vop";
reg = <0x1010c000 0x19c>;
<&cru DCLK_LCDC0>,
<&cru HCLK_LCDC0>;
power-domains = <&power RK3066_PD_VIO>;
vop0_out: port {
#size-cells = <0>;
vop0_out_hdmi: endpoint@0 {
reg = <0>;
remote-endpoint = <&hdmi_in_vop0>;
reg = <0x1010e000 0x19c>;
<&cru DCLK_LCDC1>,
<&cru HCLK_LCDC1>;
vop1_out: port {
#size-cells = <0>;
vop1_out_hdmi: endpoint@0 {
reg = <0>;
remote-endpoint = <&hdmi_in_vop1>;
- hdmi: hdmi@10116000 {
compatible = "rockchip,rk3066-hdmi";
reg = <0x10116000 0x2000>;
clocks = <&cru HCLK_HDMI>;
clock-names = "hclk";
pinctrl-0 = <&hdmii2c_xfer>, <&hdmi_hpd>;
ports {
#size-cells = <0>;
hdmi_in: port@0 {
reg = <0>;
#size-cells = <0>;
hdmi_in_vop0: endpoint@0 {
reg = <0>;
remote-endpoint = <&vop0_out_hdmi>;
hdmi_in_vop1: endpoint@1 {
reg = <1>;
remote-endpoint = <&vop1_out_hdmi>;
hdmi_out: port@1 {
reg = <1>;
- i2s0: i2s@10118000 {
compatible = "rockchip,rk3066-i2s";
reg = <0x10118000 0x2000>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&dmac1_s 4>, <&dmac1_s 5>;
rockchip,playback-channels = <8>;
- i2s1: i2s@1011a000 {
pinctrl-0 = <&i2s1_bus>;
clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1>;
- i2s2: i2s@1011c000 {
reg = <0x1011c000 0x2000>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&i2s2_bus>;
clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2>;
dmas = <&dmac1_s 9>, <&dmac1_s 10>;
compatible = "rockchip,rk3066a-cru";
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
assigned-clocks = <&cru PLL_CPLL>, <&cru PLL_GPLL>,
<&cru ACLK_CPU>, <&cru HCLK_CPU>,
<&cru PCLK_CPU>, <&cru ACLK_PERI>,
<&cru HCLK_PERI>, <&cru PCLK_PERI>;
assigned-clock-rates = <400000000>, <594000000>,
<300000000>, <150000000>,
<75000000>, <300000000>,
<150000000>, <75000000>;
- timer2: timer@2000e000 {
compatible = "snps,dw-apb-timer";
reg = <0x2000e000 0x100>;
clocks = <&cru SCLK_TIMER2>, <&cru PCLK_TIMER2>;
clock-names = "timer", "pclk";
compatible = "rockchip,rk3066a-efuse";
#size-cells = <1>;
reg = <0x17 0x1>;
- timer0: timer@20038000 {
reg = <0x20038000 0x100>;
interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_TIMER0>, <&cru PCLK_TIMER0>;
- timer1: timer@2003a000 {
reg = <0x2003a000 0x100>;
interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_TIMER1>, <&cru PCLK_TIMER1>;
- tsadc: tsadc@20060000 {
compatible = "rockchip,rk3066-tsadc";
reg = <0x20060000 0x100>;
clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
resets = <&cru SRST_TSADC>;
compatible = "rockchip,rk3066a-pinctrl";
#size-cells = <1>;
ranges;
gpio0: gpio@20034000 {
reg = <0x20034000 0x100>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
bias-disable;
emac {
emmc {
hdmi {
i2c0 {
i2c1 {
i2c2 {
i2c3 {
i2c4 {
pwm0 {
pwm1 {
pwm2 {
pwm3 {
spi0 {
spi0_tx: spi0-tx {
spi0_rx: spi0-rx {
spi1 {
spi1_rx: spi1-rx {
spi1_tx: spi1-tx {
uart0 {
uart1 {
uart2 {
uart3 {
sd0 {
sd0_clk: sd0-clk {
sd0_cmd: sd0-cmd {
sd0_cd: sd0-cd {
sd0_wp: sd0-wp {
sd1 {
sd1_clk: sd1-clk {
sd1_cmd: sd1-cmd {
sd1_cd: sd1-cd {
sd1_wp: sd1-wp {
i2s0 {
i2s1 {
i2s2 {
-&gpu {
"gpmmu",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1",
"pp2",
"ppmmu2",
"pp3",
"ppmmu3";
-&grf {
- usbphy: usbphy {
#size-cells = <0>;
reg = <0x17c>;
#clock-cells = <0>;
#phy-cells = <0>;
reg = <0x188>;
#clock-cells = <0>;
#phy-cells = <0>;
-&i2c0 {
-&i2c1 {
-&i2c2 {
-&i2c3 {
-&i2c4 {
-&mmc0 {
-&mmc1 {
-&emmc {
-&pmu {
#size-cells = <0>;
<&cru ACLK_LCDC1>,
<&cru DCLK_LCDC0>,
<&cru DCLK_LCDC1>,
<&cru HCLK_LCDC0>,
<&cru HCLK_LCDC1>,
<&cru SCLK_CIF1>,
<&cru ACLK_CIF1>,
<&cru HCLK_CIF1>,
<&cru SCLK_CIF0>,
<&cru ACLK_CIF0>,
<&cru HCLK_CIF0>,
<&cru HCLK_HDMI>,
<&cru ACLK_IPP>,
<&cru HCLK_IPP>,
<&cru ACLK_RGA>,
<&cru HCLK_RGA>;
<&qos_lcdc1>,
<&qos_cif0>,
<&qos_cif1>,
<&qos_ipp>,
<&qos_rga>;
<&cru ACLK_VEPU>,
<&cru HCLK_VDPU>,
<&cru HCLK_VEPU>;
-&pwm0 {
-&pwm1 {
-&pwm2 {
-&pwm3 {
-&spi0 {
-&spi1 {
-&uart0 {
-&uart1 {
-&uart2 {
-&uart3 {
-&vpu {
-&wdt {
-&emac {
- Copyright (c) 2013 Heiko Stuebner heiko@sntech.de
- aliases {
mmc0 = &mmc0;
- memory@60000000 {
- gpio-keys {
autorepeat;
key-power {
wakeup-source;
- gpio-leds {
green_led: led-0 {
blue_led: led-1 {
sleep_led: led-2 {
- sound {
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
-&emac {
- phy = <&phy0>;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <0>;
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- status = "okay";
-&i2c1 {
- status = "okay";
- rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
reg = <0x5a>;
status = "okay";
regulators {
vcc_ddr: REG1 {
vdd_log: REG2 {
vdd_arm: REG3 {
vcc_io: REG4 {
vdd_10: REG5 {
vdd_hdmi: REG6 {
vcc18: REG7 {
vcca_33: REG8 {
vcc_rmii: REG9 {
vccio_wl: REG10 {
vcc_18: REG11 {
vcc28: REG12 {
-&mmc0 {
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
-&pwm1 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&pwm3 {
- status = "okay";
-&pinctrl {
output-low;
- act8846 {
- hym8563 {
rtc_int: rtc-int {
- lan8720a {
phy_int: phy-int {
- ir-receiver {
- sd0 {
- usb {
-&spdif {
- status = "okay";
-&uart0 {
- status = "okay";
-&uart1 {
- status = "okay";
-&uart2 {
- status = "okay";
-&uart3 {
- status = "okay";
-&usbphy {
- status = "okay";
-&usb_host {
- status = "okay";
-&usb_otg {
- status = "okay";
-&wdt {
- status = "okay";
-&global_timer {
- status = "okay";
-&gpio1 {
-&gpio2 {
-&gpio3 {
&pmu {
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
cpu1: cpu@1 {
reg = <0x1>;
cpu2: cpu@2 {
reg = <0x2>;
cpu3: cpu@3 {
reg = <0x3>;
opp-shared;
opp-312000000 {
opp-504000000 {
opp-600000000 {
opp-suspend;
opp-816000000 {
opp-1008000000 {
opp-1200000000 {
opp-1416000000 {
opp-1608000000 {
#size-cells = <1>;
smp-sram@0 {
reg = <0x0 0x50>;
vop0_out: port {
#size-cells = <0>;
vop1_out: port {
#size-cells = <0>;
dma-names = "tx";
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <1>;
reg = <0x17 0x1>;
#size-cells = <1>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
bias-pull-up;
bias-pull-down;
bias-disable;
emmc {
emac {
i2c0 {
i2c1 {
i2c2 {
i2c3 {
i2c4 {
lcdc1 {
pwm0 {
pwm1 {
pwm2 {
pwm3 {
spi0 {
spi0_tx: spi0-tx {
spi0_rx: spi0-rx {
spi1 {
spi1_rx: spi1-rx {
spi1_tx: spi1-tx {
uart0 {
uart1 {
uart2 {
uart3 {
sd0 {
sd0_clk: sd0-clk {
sd0_cmd: sd0-cmd {
sd0_cd: sd0-cd {
sd0_wp: sd0-wp {
sd0_pwr: sd0-pwr {
sd1 {
sd1_clk: sd1-clk {
sd1_cmd: sd1-cmd {
sd1_cd: sd1-cd {
sd1_wp: sd1-wp {
i2s0 {
spdif {
-&emac {
-&global_timer {
-&local_timer {
-&gpu {
"gpmmu",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1",
"pp2",
"ppmmu2",
"pp3",
"ppmmu3";
-&grf {
- usbphy: usbphy {
#size-cells = <0>;
reg = <0x10c>;
#clock-cells = <0>;
#phy-cells = <0>;
reg = <0x11c>;
#clock-cells = <0>;
#phy-cells = <0>;
-&i2c0 {
-&i2c1 {
-&i2c2 {
-&i2c3 {
-&i2c4 {
-&pmu {
#size-cells = <0>;
<&cru ACLK_LCDC1>,
<&cru DCLK_LCDC0>,
<&cru DCLK_LCDC1>,
<&cru HCLK_LCDC0>,
<&cru HCLK_LCDC1>,
<&cru SCLK_CIF0>,
<&cru ACLK_CIF0>,
<&cru HCLK_CIF0>,
<&cru ACLK_IPP>,
<&cru HCLK_IPP>,
<&cru ACLK_RGA>,
<&cru HCLK_RGA>;
<&qos_lcdc1>,
<&qos_cif0>,
<&qos_ipp>,
<&qos_rga>;
<&cru ACLK_VEPU>,
<&cru HCLK_VDPU>,
<&cru HCLK_VEPU>;
-&pwm0 {
-&pwm1 {
-&pwm2 {
-&pwm3 {
-&spi0 {
-&spi1 {
-&uart0 {
-&uart1 {
-&uart2 {
-&uart3 {
-&vpu {
-&wdt {
- aliases {
ethernet0 = &emac;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
spi0 = &spi0;
spi1 = &spi1;
#clock-cells = <0>;
cache-unified;
cache-level = <2>;
- scu@1013c000 {
reg-shift = <2>;
reg-io-width = <1>;
reg-shift = <2>;
reg-io-width = <1>;
dr_mode = "otg";
phys = <&usbphy0>;
dr_mode = "host";
phys = <&usbphy1>;
max-speed = <100>;
phy-mode = "rmii";
dmas = <&dmac2 1>;
fifo-depth = <256>;
dmas = <&dmac2 3>;
fifo-depth = <256>;
dmas = <&dmac2 4>;
fifo-depth = <256>;
reboot-mode {
offset = <0x40>;
#dma-cells = <1>;
#dma-cells = <1>;
#size-cells = <0>;
#size-cells = <0>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#pwm-cells = <2>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
reg-shift = <2>;
reg-io-width = <1>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
#size-cells = <0>;
#dma-cells = <1>;
- imply OF_UPSTREAM imply ROCKCHIP_COMMON_BOARD imply SPL_ROCKCHIP_COMMON_BOARD imply SPL_SERIAL
- imply OF_UPSTREAM imply ROCKCHIP_COMMON_BOARD imply SPL_ROCKCHIP_COMMON_BOARD help
Johan Jonker
Kever Yang
