[U-Boot] [PATCH] Add initial support for mx6slevk board
mx6slevk board is a development board from Freescale based on the mx6 solo lite processor.
For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&...
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- MAINTAINERS | 1 + arch/arm/cpu/armv7/mx6/clock.c | 38 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 63 +- arch/arm/include/asm/arch-mx6/mx6-pins.h | 4 + arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 1374 ++++++++++++++++++++++++++++ board/freescale/mx6slevk/Makefile | 28 + board/freescale/mx6slevk/imximage.cfg | 118 +++ board/freescale/mx6slevk/mx6slevk.c | 102 +++ boards.cfg | 1 + include/configs/mx6slevk.h | 189 ++++ 11 files changed, 1916 insertions(+), 3 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sl_pins.h create mode 100644 board/freescale/mx6slevk/Makefile create mode 100644 board/freescale/mx6slevk/imximage.cfg create mode 100644 board/freescale/mx6slevk/mx6slevk.c create mode 100644 include/configs/mx6slevk.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0f19078..723a316 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -665,6 +665,7 @@ Fabio Estevam fabio.estevam@freescale.com mx6qsabresd i.MX6Q mx6qsabreauto i.MX6Q wandboard i.MX6DL/S + mx6slevk i.MX6SL
Daniel Gorsulowski daniel.gorsulowski@esd.eu
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index a50db70..8cba4fd 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -186,12 +186,16 @@ static u32 get_ipg_per_clk(void) static u32 get_uart_clk(void) { u32 reg, uart_podf; - + u32 freq = PLL3_80M; reg = __raw_readl(&imx_ccm->cscdr1); +#ifdef CONFIG_MX6SL + if (reg & MXC_CCM_CSCDR1_UART_CLK_SEL) + freq = MXC_HCLK; +#endif reg &= MXC_CCM_CSCDR1_UART_CLK_PODF_MASK; uart_podf = reg >> MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET;
- return PLL3_80M / (uart_podf + 1); + return freq / (uart_podf + 1); }
static u32 get_cspi_clk(void) @@ -252,6 +256,35 @@ static u32 get_emi_slow_clk(void) return root_freq / (emi_slow_pof + 1); }
+#ifdef CONFIG_MX6SL +static u32 get_mmdc_ch0_clk(void) +{ + u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); + u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); + u32 freq, podf; + + podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH1_PODF_MASK) \ + >> MXC_CCM_CBCDR_MMDC_CH1_PODF_OFFSET; + + switch ((cbcmr & MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_MASK) >> + MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_OFFSET) { + case 0: + freq = decode_pll(PLL_BUS, MXC_HCLK); + break; + case 1: + freq = PLL2_PFD2_FREQ; + break; + case 2: + freq = PLL2_PFD0_FREQ; + break; + case 3: + freq = PLL2_PFD2_DIV_FREQ; + } + + return freq / (podf + 1); + +} +#else static u32 get_mmdc_ch0_clk(void) { u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); @@ -260,6 +293,7 @@ static u32 get_mmdc_ch0_clk(void)
return get_periph_clk() / (mmdc_ch0_podf + 1); } +#endif
static u32 get_usdhc_clk(u32 port) { diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7676457..ede384d 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -246,6 +246,7 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x3F #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0 +#define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6)
/* Define the bits in register CS1CDR */ #define MXC_CCM_CS1CDR_ESAI_CLK_PODF_MASK (0x3F << 25) diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index eaa7439..2d8fe69 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -25,6 +25,13 @@
#define ROMCP_ARB_BASE_ADDR 0x00000000 #define ROMCP_ARB_END_ADDR 0x000FFFFF + +#ifdef CONFIG_MX6SL +#define GPU_2D_ARB_BASE_ADDR 0x02200000 +#define GPU_2D_ARB_END_ADDR 0x02203FFF +#define OPENVG_ARB_BASE_ADDR 0x02204000 +#define OPENVG_ARB_END_ADDR 0x02207FFF +#else #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00103FFF #define APBH_DMA_ARB_BASE_ADDR 0x00110000 @@ -37,9 +44,14 @@ #define GPU_2D_ARB_END_ADDR 0x00137FFF #define DTCP_ARB_BASE_ADDR 0x00138000 #define DTCP_ARB_END_ADDR 0x0013BFFF - +#endif /* CONFIG_MX6SL */ /* GPV - PL301 configuration ports */ +#ifdef CONFIG_MX6SL +#define GPV2_BASE_ADDR 0x00D00000 +#else #define GPV2_BASE_ADDR 0x00200000 +#endif + #define GPV3_BASE_ADDR 0x00300000 #define GPV4_BASE_ADDR 0x00800000 #define IRAM_BASE_ADDR 0x00900000 @@ -70,10 +82,17 @@ #define WEIM_ARB_BASE_ADDR 0x08000000 #define WEIM_ARB_END_ADDR 0x0FFFFFFF
+#ifdef CONFIG_MX6SL +#define MMDC0_ARB_BASE_ADDR 0x80000000 +#define MMDC0_ARB_END_ADDR 0xFFFFFFFF +#define MMDC1_ARB_BASE_ADDR 0xC0000000 +#define MMDC1_ARB_END_ADDR 0xFFFFFFFF +#else #define MMDC0_ARB_BASE_ADDR 0x10000000 #define MMDC0_ARB_END_ADDR 0x7FFFFFFF #define MMDC1_ARB_BASE_ADDR 0x80000000 #define MMDC1_ARB_END_ADDR 0xFFFFFFFF +#endif
#define IPU_SOC_BASE_ADDR IPU1_ARB_BASE_ADDR #define IPU_SOC_OFFSET 0x00200000 @@ -89,6 +108,16 @@ #define ECSPI2_BASE_ADDR (ATZ1_BASE_ADDR + 0x0C000) #define ECSPI3_BASE_ADDR (ATZ1_BASE_ADDR + 0x10000) #define ECSPI4_BASE_ADDR (ATZ1_BASE_ADDR + 0x14000) +#ifdef CONFIG_MX6SL +#define UART5_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) +#define UART1_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x20000) +#define UART2_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) +#define SSI1_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x28000) +#define SSI2_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x2C000) +#define SSI3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x30000) +#define UART3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) +#define UART4_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x38000) +#else #define ECSPI5_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) #define UART1_BASE (ATZ1_BASE_ADDR + 0x20000) #define ESAI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) @@ -96,6 +125,8 @@ #define SSI2_BASE_ADDR (ATZ1_BASE_ADDR + 0x2C000) #define SSI3_BASE_ADDR (ATZ1_BASE_ADDR + 0x30000) #define ASRC_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) +#endif + #define SPBA_BASE_ADDR (ATZ1_BASE_ADDR + 0x3C000) #define VPU_BASE_ADDR (ATZ1_BASE_ADDR + 0x40000) #define AIPS1_ON_BASE_ADDR (ATZ1_BASE_ADDR + 0x7C000) @@ -128,18 +159,35 @@ #define SRC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x58000) #define GPC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x5C000) #define IOMUXC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x60000) +#ifdef CONFIG_MX6SL +#define CSI_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) +#define SIPIX_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) +#define SDMA_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#else #define DCIC1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define DCIC2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) #define DMA_REQ_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#endif
#define AIPS2_ON_BASE_ADDR (ATZ2_BASE_ADDR + 0x7C000) #define AIPS2_OFF_BASE_ADDR (ATZ2_BASE_ADDR + 0x80000) #define CAAM_BASE_ADDR (ATZ2_BASE_ADDR) #define ARM_BASE_ADDR (ATZ2_BASE_ADDR + 0x40000) +#ifdef CONFIG_MX6SL +#define USBO2H_PL301_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x0000) +#define USBO2H_USB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4000) +#else #define USBOH3_PL301_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x0000) #define USBOH3_USB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4000) +#endif + #define ENET_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x8000) +#ifdef CONFIG_MX6SL +#define MSHC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0xC000) +#else #define MLB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0xC000) +#endif + #define USDHC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x10000) #define USDHC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x14000) #define USDHC3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x18000) @@ -149,7 +197,12 @@ #define I2C3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x28000) #define ROMCP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x2C000) #define MMDC_P0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x30000) +#ifdef CONFIG_MX6SL +#define RNGB_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#else #define MMDC_P1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#endif + #define WEIM_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x38000) #define OCOTP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x3C000) #define CSU_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x40000) @@ -364,12 +417,20 @@ struct cspi_regs { #define MXC_CSPICON_POL 4 #define MXC_CSPICON_PHA 0 #define MXC_CSPICON_SSPOL 12 +#ifdef CONFIG_MX6SL +#define MXC_SPI_BASE_ADDRESSES \ + ECSPI1_BASE_ADDR, \ + ECSPI2_BASE_ADDR, \ + ECSPI3_BASE_ADDR, \ + ECSPI4_BASE_ADDR +#else #define MXC_SPI_BASE_ADDRESSES \ ECSPI1_BASE_ADDR, \ ECSPI2_BASE_ADDR, \ ECSPI3_BASE_ADDR, \ ECSPI4_BASE_ADDR, \ ECSPI5_BASE_ADDR +#endif
struct iim_regs { u32 ctrl; diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 63f4856..ce865a6 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -24,7 +24,11 @@ #if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) #include "mx6dl_pins.h" #else +#if defined(CONFIG_MX6SL) +#include "mx6sl_pins.h" +#else #error "Please select cpu" +#endif /* CONFIG_MX6SL */ #endif /* CONFIG_MX6DL or CONFIG_MX6S */ #endif /* CONFIG_MX6Q */
diff --git a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h new file mode 100644 index 0000000..cd974d8 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h @@ -0,0 +1,1374 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef __ASM_ARCH_MX6_MX6SL_PINS_H__ +#define __ASM_ARCH_MX6_MX6SL_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +/* Use to set PAD control */ +#define PAD_CTL_HYS (1 << 16) +#define PAD_CTL_PUS_100K_DOWN (0 << 14) +#define PAD_CTL_PUS_47K_UP (1 << 14) +#define PAD_CTL_PUS_100K_UP (2 << 14) +#define PAD_CTL_PUS_22K_UP (3 << 14) + +#define PAD_CTL_PUE (1 << 13) +#define PAD_CTL_PKE (1 << 12) +#define PAD_CTL_ODE (1 << 11) +#define PAD_CTL_SPEED_LOW (1 << 6) +#define PAD_CTL_SPEED_MED (2 << 6) +#define PAD_CTL_SPEED_HIGH (3 << 6) +#define PAD_CTL_DSE_DISABLE (0 << 3) +#define PAD_CTL_DSE_240ohm (1 << 3) +#define PAD_CTL_DSE_120ohm (2 << 3) +#define PAD_CTL_DSE_80ohm (3 << 3) +#define PAD_CTL_DSE_60ohm (4 << 3) +#define PAD_CTL_DSE_48ohm (5 << 3) +#define PAD_CTL_DSE_40ohm (6 << 3) +#define PAD_CTL_DSE_34ohm (7 << 3) +#define PAD_CTL_SRE_FAST (1 << 0) +#define PAD_CTL_SRE_SLOW (0 << 0) + +#define IOMUX_CONFIG_SION 0x10 +#define NO_MUX_I 0 +#define NO_PAD_I 0 +enum { + MX6_PAD_AUD_MCLK__AUDMUX_AUDIO_CLK_OUT = IOMUX_PAD(0x02A4, 0x004C, 0, 0x0000, 0, 0), + MX6_PAD_AUD_MCLK__PWM4_PWMO = IOMUX_PAD(0x02A4, 0x004C, 1, 0x0000, 0, 0), + MX6_PAD_AUD_MCLK__ECSPI3_RDY = IOMUX_PAD(0x02A4, 0x004C, 2, 0x06B4, 0, 0), + MX6_PAD_AUD_MCLK__FEC_MDC = IOMUX_PAD(0x02A4, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_AUD_MCLK__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x02A4, 0x004C, 4, 0x0000, 0, 0), + MX6_PAD_AUD_MCLK__GPIO_1_6 = IOMUX_PAD(0x02A4, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_AUD_MCLK__SPDIF_SPDIF_EXT_CLK = IOMUX_PAD(0x02A4, 0x004C, 6, 0x07F4, 0, 0), + MX6_PAD_AUD_MCLK__TPSMP_HDATA_27 = IOMUX_PAD(0x02A4, 0x004C, 7, 0x0000, 0, 0), + MX6_PAD_AUD_RXC__AUDMUX_AUD3_RXC = IOMUX_PAD(0x02A8, 0x0050, 0, 0x0000, 0, 0), + MX6_PAD_AUD_RXC__I2C1_SDA = IOMUX_PAD(0x02A8, 0x0050, 17, 0x0720, 0, 0), + MX6_PAD_AUD_RXC__UART3_TXD = IOMUX_PAD(0x02A8, 0x0050, 2, 0x0000, 0, 0), + MX6_PAD_AUD_RXC__UART3_RXD = IOMUX_PAD(0x02A8, 0x0050, 2, 0x080C, 0, 0), + MX6_PAD_AUD_RXC__FEC_TX_CLK = IOMUX_PAD(0x02A8, 0x0050, 3, 0x070C, 0, 0), + MX6_PAD_AUD_RXC__I2C3_SDA = IOMUX_PAD(0x02A8, 0x0050, 20, 0x0730, 0, 0), + MX6_PAD_AUD_RXC__GPIO_1_1 = IOMUX_PAD(0x02A8, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_AUD_RXC__ECSPI3_SS1 = IOMUX_PAD(0x02A8, 0x0050, 6, 0x06C4, 0, 0), + MX6_PAD_AUD_RXC__PL301_SIM_MX6_PER1_HREADYOUT = IOMUX_PAD(0x02A8, 0x0050, 7, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__AUDMUX_AUD3_RXD = IOMUX_PAD(0x02AC, 0x0054, 0, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__ECSPI3_MOSI = IOMUX_PAD(0x02AC, 0x0054, 1, 0x06BC, 0, 0), + MX6_PAD_AUD_RXD__UART4_TXD = IOMUX_PAD(0x02AC, 0x0054, 2, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__UART4_RXD = IOMUX_PAD(0x02AC, 0x0054, 2, 0x0814, 0, 0), + MX6_PAD_AUD_RXD__FEC_RX_ER = IOMUX_PAD(0x02AC, 0x0054, 3, 0x0708, 0, 0), + MX6_PAD_AUD_RXD__USDHC1_LCTL = IOMUX_PAD(0x02AC, 0x0054, 4, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__GPIO_1_2 = IOMUX_PAD(0x02AC, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__SRC_INT_BOOT = IOMUX_PAD(0x02AC, 0x0054, 6, 0x0000, 0, 0), + MX6_PAD_AUD_RXD__PL301_SIM_MX6_PER1_HRESP = IOMUX_PAD(0x02AC, 0x0054, 7, 0x0000, 0, 0), + MX6_PAD_AUD_RXFS__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x02B0, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_AUD_RXFS__I2C1_SCL = IOMUX_PAD(0x02B0, 0x0058, 17, 0x071C, 0, 0), + MX6_PAD_AUD_RXFS__UART3_TXD = IOMUX_PAD(0x02B0, 0x0058, 2, 0x0000, 0, 0), + MX6_PAD_AUD_RXFS__UART3_RXD = IOMUX_PAD(0x02B0, 0x0058, 2, 0x080C, 1, 0), + MX6_PAD_AUD_RXFS__FEC_MDIO = IOMUX_PAD(0x02B0, 0x0058, 3, 0x06F4, 0, 0), + MX6_PAD_AUD_RXFS__I2C3_SCL = IOMUX_PAD(0x02B0, 0x0058, 20, 0x072C, 0, 0), + MX6_PAD_AUD_RXFS__GPIO_1_0 = IOMUX_PAD(0x02B0, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_AUD_RXFS__ECSPI3_SS0 = IOMUX_PAD(0x02B0, 0x0058, 6, 0x06C0, 0, 0), + MX6_PAD_AUD_RXFS__PL301_SIM_MX6_PER1_HPROT_1 = IOMUX_PAD(0x02B0, 0x0058, 7, 0x07EC, 0, 0), + MX6_PAD_AUD_TXC__AUDMUX_AUD3_TXC = IOMUX_PAD(0x02B4, 0x005C, 0, 0x0000, 0, 0), + MX6_PAD_AUD_TXC__ECSPI3_MISO = IOMUX_PAD(0x02B4, 0x005C, 1, 0x06B8, 0, 0), + MX6_PAD_AUD_TXC__UART4_TXD = IOMUX_PAD(0x02B4, 0x005C, 2, 0x0000, 0, 0), + MX6_PAD_AUD_TXC__UART4_RXD = IOMUX_PAD(0x02B4, 0x005C, 2, 0x0814, 1, 0), + MX6_PAD_AUD_TXC__FEC_RX_DV = IOMUX_PAD(0x02B4, 0x005C, 3, 0x0704, 0, 0), + MX6_PAD_AUD_TXC__USDHC2_LCTL = IOMUX_PAD(0x02B4, 0x005C, 4, 0x0000, 0, 0), + MX6_PAD_AUD_TXC__GPIO_1_3 = IOMUX_PAD(0x02B4, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_AUD_TXC__SRC_SYSTEM_RST = IOMUX_PAD(0x02B4, 0x005C, 6, 0x0000, 0, 0), + MX6_PAD_AUD_TXC__TPSMP_HDATA_24 = IOMUX_PAD(0x02B4, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__AUDMUX_AUD3_TXD = IOMUX_PAD(0x02B8, 0x0060, 0, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__ECSPI3_SCLK = IOMUX_PAD(0x02B8, 0x0060, 1, 0x06B0, 0, 0), + MX6_PAD_AUD_TXD__UART4_CTS = IOMUX_PAD(0x02B8, 0x0060, 2, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__UART4_RTS = IOMUX_PAD(0x02B8, 0x0060, 2, 0x0810, 0, 0), + MX6_PAD_AUD_TXD__FEC_TDATA_0 = IOMUX_PAD(0x02B8, 0x0060, 3, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__USDHC4_LCTL = IOMUX_PAD(0x02B8, 0x0060, 4, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__GPIO_1_5 = IOMUX_PAD(0x02B8, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__ANATOP_ANATOP_TESTI_1 = IOMUX_PAD(0x02B8, 0x0060, 6, 0x0000, 0, 0), + MX6_PAD_AUD_TXD__TPSMP_HDATA_26 = IOMUX_PAD(0x02B8, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x02BC, 0x0064, 0, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__PWM3_PWMO = IOMUX_PAD(0x02BC, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__UART4_CTS = IOMUX_PAD(0x02BC, 0x0064, 2, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__UART4_RTS = IOMUX_PAD(0x02BC, 0x0064, 2, 0x0810, 1, 0), + MX6_PAD_AUD_TXFS__FEC_RDATA_1 = IOMUX_PAD(0x02BC, 0x0064, 3, 0x06FC, 0, 0), + MX6_PAD_AUD_TXFS__USDHC3_LCTL = IOMUX_PAD(0x02BC, 0x0064, 4, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__GPIO_1_4 = IOMUX_PAD(0x02BC, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__ANATOP_ANATOP_TESTI_0 = IOMUX_PAD(0x02BC, 0x0064, 6, 0x0000, 0, 0), + MX6_PAD_AUD_TXFS__TPSMP_HDATA_25 = IOMUX_PAD(0x02BC, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_BOOT_MODE0__SRC_BOOT_MODE_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_BOOT_MODE1__SRC_BOOT_MODE_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x02C0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A1__MMDC_DRAM_A_1 = IOMUX_PAD(0x02C4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A10__MMDC_DRAM_A_10 = IOMUX_PAD(0x02C8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A11__MMDC_DRAM_A_11 = IOMUX_PAD(0x02CC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A12__MMDC_DRAM_A_12 = IOMUX_PAD(0x02D0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A13__MMDC_DRAM_A_13 = IOMUX_PAD(0x02D4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A14__MMDC_DRAM_A_14 = IOMUX_PAD(0x02D8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A15__MMDC_DRAM_A_15 = IOMUX_PAD(0x02DC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A2__MMDC_DRAM_A_2 = IOMUX_PAD(0x02E0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A3__MMDC_DRAM_A_3 = IOMUX_PAD(0x02E4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A4__MMDC_DRAM_A_4 = IOMUX_PAD(0x02E8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A5__MMDC_DRAM_A_5 = IOMUX_PAD(0x02EC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A6__MMDC_DRAM_A_6 = IOMUX_PAD(0x02F0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A7__MMDC_DRAM_A_7 = IOMUX_PAD(0x02F4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A8__MMDC_DRAM_A_8 = IOMUX_PAD(0x02F8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A9__MMDC_DRAM_A_9 = IOMUX_PAD(0x02FC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CAS__MMDC_DRAM_CAS = IOMUX_PAD(0x0300, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CS0__MMDC_DRAM_CS_0 = IOMUX_PAD(0x0304, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CS1__MMDC_DRAM_CS_1 = IOMUX_PAD(0x0308, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D0__MMDC_DRAM_D_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D1__MMDC_DRAM_D_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D10__MMDC_DRAM_D_10 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D11__MMDC_DRAM_D_11 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D12__MMDC_DRAM_D_12 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D13__MMDC_DRAM_D_13 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D14__MMDC_DRAM_D_14 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D15__MMDC_DRAM_D_15 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D16__MMDC_DRAM_D_16 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D17__MMDC_DRAM_D_17 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D18__MMDC_DRAM_D_18 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D19__MMDC_DRAM_D_19 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D2__MMDC_DRAM_D_2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D20__MMDC_DRAM_D_20 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D21__MMDC_DRAM_D_21 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D22__MMDC_DRAM_D_22 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D23__MMDC_DRAM_D_23 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D24__MMDC_DRAM_D_24 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D25__MMDC_DRAM_D_25 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D26__MMDC_DRAM_D_26 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D27__MMDC_DRAM_D_27 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D28__MMDC_DRAM_D_28 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D29__MMDC_DRAM_D_29 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D3__MMDC_DRAM_D_3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D30__MMDC_DRAM_D_30 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D31__MMDC_DRAM_D_31 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D4__MMDC_DRAM_D_4 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D5__MMDC_DRAM_D_5 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D6__MMDC_DRAM_D_6 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D7__MMDC_DRAM_D_7 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D8__MMDC_DRAM_D_8 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D9__MMDC_DRAM_D_9 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x030C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x0310, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0314, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM3__MMDC_DRAM_DQM_3 = IOMUX_PAD(0x0318, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_RAS__MMDC_DRAM_RAS = IOMUX_PAD(0x031C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_RESET__MMDC_DRAM_RESET = IOMUX_PAD(0x0320, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA0__MMDC_DRAM_SDBA_0 = IOMUX_PAD(0x0324, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA1__MMDC_DRAM_SDBA_1 = IOMUX_PAD(0x0328, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA2__MMDC_DRAM_SDBA_2 = IOMUX_PAD(0x032C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCKE0__MMDC_DRAM_SDCKE_0 = IOMUX_PAD(0x0330, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCKE1__MMDC_DRAM_SDCKE_1 = IOMUX_PAD(0x0334, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCLK_0__MMDC_DRAM_SDCLK0 = IOMUX_PAD(0x0338, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDODT0__MMDC_DRAM_ODT_0 = IOMUX_PAD(0x033C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDODT1__MMDC_DRAM_ODT_1 = IOMUX_PAD(0x0340, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS0__MMDC_DRAM_SDQS_0 = IOMUX_PAD(0x0344, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS1__MMDC_DRAM_SDQS_1 = IOMUX_PAD(0x0348, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS2__MMDC_DRAM_SDQS_2 = IOMUX_PAD(0x034C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS3__MMDC_DRAM_SDQS_3 = IOMUX_PAD(0x0350, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x0354, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MISO__ECSPI1_MISO = IOMUX_PAD(0x0358, 0x0068, 0, 0x0684, 0, 0), + MX6_PAD_ECSPI1_MISO__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x0358, 0x0068, 1, 0x05F8, 0, 0), + MX6_PAD_ECSPI1_MISO__UART5_CTS = IOMUX_PAD(0x0358, 0x0068, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MISO__UART5_RTS = IOMUX_PAD(0x0358, 0x0068, 2, 0x0818, 0, 0), + MX6_PAD_ECSPI1_MISO__EPDC_BDR_0 = IOMUX_PAD(0x0358, 0x0068, 3, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MISO__USDHC2_WP = IOMUX_PAD(0x0358, 0x0068, 4, 0x0834, 0, 0), + MX6_PAD_ECSPI1_MISO__GPIO_4_10 = IOMUX_PAD(0x0358, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MISO__CCM_PLL3_BYP = IOMUX_PAD(0x0358, 0x0068, 6, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MISO__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x0358, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__ECSPI1_MOSI = IOMUX_PAD(0x035C, 0x006C, 0, 0x0688, 0, 0), + MX6_PAD_ECSPI1_MOSI__AUDMUX_AUD4_TXC = IOMUX_PAD(0x035C, 0x006C, 1, 0x05F4, 0, 0), + MX6_PAD_ECSPI1_MOSI__UART5_TXD = IOMUX_PAD(0x035C, 0x006C, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__UART5_RXD = IOMUX_PAD(0x035C, 0x006C, 2, 0x081C, 0, 0), + MX6_PAD_ECSPI1_MOSI__EPDC_VCOM_1 = IOMUX_PAD(0x035C, 0x006C, 3, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__USDHC2_VSELECT = IOMUX_PAD(0x035C, 0x006C, 4, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__GPIO_4_9 = IOMUX_PAD(0x035C, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__CCM_PLL2_BYP = IOMUX_PAD(0x035C, 0x006C, 6, 0x0000, 0, 0), + MX6_PAD_ECSPI1_MOSI__MMDC_MMDC_DEBUG_49 = IOMUX_PAD(0x035C, 0x006C, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SCLK__ECSPI1_SCLK = IOMUX_PAD(0x0360, 0x0070, 0, 0x067C, 0, 0), + MX6_PAD_ECSPI1_SCLK__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0360, 0x0070, 1, 0x05E8, 0, 0), + MX6_PAD_ECSPI1_SCLK__UART5_TXD = IOMUX_PAD(0x0360, 0x0070, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SCLK__UART5_RXD = IOMUX_PAD(0x0360, 0x0070, 2, 0x081C, 1, 0), + MX6_PAD_ECSPI1_SCLK__EPDC_VCOM_0 = IOMUX_PAD(0x0360, 0x0070, 3, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SCLK__USDHC2_RST = IOMUX_PAD(0x0360, 0x0070, 4, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SCLK__GPIO_4_8 = IOMUX_PAD(0x0360, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SCLK__USB_USBOTG2_OC = IOMUX_PAD(0x0360, 0x0070, 6, 0x0820, 0, 0), + MX6_PAD_ECSPI1_SCLK__TPSMP_HDATA_18 = IOMUX_PAD(0x0360, 0x0070, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SS0__ECSPI1_SS0 = IOMUX_PAD(0x0364, 0x0074, 0, 0x068C, 0, 0), + MX6_PAD_ECSPI1_SS0__AUDMUX_AUD4_RXD = IOMUX_PAD(0x0364, 0x0074, 1, 0x05E4, 0, 0), + MX6_PAD_ECSPI1_SS0__UART5_CTS = IOMUX_PAD(0x0364, 0x0074, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SS0__UART5_RTS = IOMUX_PAD(0x0364, 0x0074, 2, 0x0818, 1, 0), + MX6_PAD_ECSPI1_SS0__EPDC_BDR_1 = IOMUX_PAD(0x0364, 0x0074, 3, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SS0__USDHC2_CD = IOMUX_PAD(0x0364, 0x0074, 4, 0x0830, 0, 0), + MX6_PAD_ECSPI1_SS0__GPIO_4_11 = IOMUX_PAD(0x0364, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SS0__USB_USBOTG2_PWR = IOMUX_PAD(0x0364, 0x0074, 6, 0x0000, 0, 0), + MX6_PAD_ECSPI1_SS0__PL301_SIM_MX6_PER1_HADDR_23 = IOMUX_PAD(0x0364, 0x0074, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__GPIO_4_14 = IOMUX_PAD(0x0368, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__USB_USBOTG1_OC = IOMUX_PAD(0x0368, 0x0078, 6, 0x0824, 0, 0), + MX6_PAD_ECSPI2_MISO__TPSMP_HDATA_23 = IOMUX_PAD(0x0368, 0x0078, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__ECSPI2_MISO = IOMUX_PAD(0x0368, 0x0078, 0, 0x06A0, 0, 0), + MX6_PAD_ECSPI2_MISO__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x0368, 0x0078, 1, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__UART3_CTS = IOMUX_PAD(0x0368, 0x0078, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__UART3_RTS = IOMUX_PAD(0x0368, 0x0078, 2, 0x0808, 0, 0), + MX6_PAD_ECSPI2_MISO__CSI_MCLK = IOMUX_PAD(0x0368, 0x0078, 3, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MISO__USDHC1_WP = IOMUX_PAD(0x0368, 0x0078, 4, 0x082C, 0, 0), + MX6_PAD_ECSPI2_MOSI__ECSPI2_MOSI = IOMUX_PAD(0x036C, 0x007C, 0, 0x06A4, 0, 0), + MX6_PAD_ECSPI2_MOSI__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x036C, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MOSI__UART3_TXD = IOMUX_PAD(0x036C, 0x007C, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MOSI__UART3_RXD = IOMUX_PAD(0x036C, 0x007C, 2, 0x080C, 2, 0), + MX6_PAD_ECSPI2_MOSI__CSI_HSYNC = IOMUX_PAD(0x036C, 0x007C, 3, 0x0670, 0, 0), + MX6_PAD_ECSPI2_MOSI__USDHC1_VSELECT = IOMUX_PAD(0x036C, 0x007C, 4, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MOSI__GPIO_4_13 = IOMUX_PAD(0x036C, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MOSI__ANATOP_ANATOP_TESTO_1 = IOMUX_PAD(0x036C, 0x007C, 6, 0x0000, 0, 0), + MX6_PAD_ECSPI2_MOSI__TPSMP_HDATA_22 = IOMUX_PAD(0x036C, 0x007C, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SCLK__ECSPI2_SCLK = IOMUX_PAD(0x0370, 0x0080, 0, 0x069C, 0, 0), + MX6_PAD_ECSPI2_SCLK__SPDIF_SPDIF_EXT_CLK = IOMUX_PAD(0x0370, 0x0080, 1, 0x07F4, 1, 0), + MX6_PAD_ECSPI2_SCLK__UART3_TXD = IOMUX_PAD(0x0370, 0x0080, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SCLK__UART3_RXD = IOMUX_PAD(0x0370, 0x0080, 2, 0x080C, 3, 0), + MX6_PAD_ECSPI2_SCLK__CSI_PIXCLK = IOMUX_PAD(0x0370, 0x0080, 3, 0x0674, 0, 0), + MX6_PAD_ECSPI2_SCLK__USDHC1_RST = IOMUX_PAD(0x0370, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SCLK__GPIO_4_12 = IOMUX_PAD(0x0370, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SCLK__USB_USBOTG2_OC = IOMUX_PAD(0x0370, 0x0080, 6, 0x0820, 1, 0), + MX6_PAD_ECSPI2_SCLK__TPSMP_HDATA_21 = IOMUX_PAD(0x0370, 0x0080, 7, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SS0__ECSPI2_SS0 = IOMUX_PAD(0x0374, 0x0084, 0, 0x06A8, 0, 0), + MX6_PAD_ECSPI2_SS0__ECSPI1_SS3 = IOMUX_PAD(0x0374, 0x0084, 1, 0x0698, 0, 0), + MX6_PAD_ECSPI2_SS0__UART3_CTS = IOMUX_PAD(0x0374, 0x0084, 2, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SS0__UART3_RTS = IOMUX_PAD(0x0374, 0x0084, 2, 0x0808, 1, 0), + MX6_PAD_ECSPI2_SS0__CSI_VSYNC = IOMUX_PAD(0x0374, 0x0084, 3, 0x0678, 0, 0), + MX6_PAD_ECSPI2_SS0__USDHC1_CD = IOMUX_PAD(0x0374, 0x0084, 4, 0x0828, 0, 0), + MX6_PAD_ECSPI2_SS0__GPIO_4_15 = IOMUX_PAD(0x0374, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SS0__USB_USBOTG1_PWR = IOMUX_PAD(0x0374, 0x0084, 6, 0x0000, 0, 0), + MX6_PAD_ECSPI2_SS0__PL301_SIM_MX6_PER1_HADDR_24 = IOMUX_PAD(0x0374, 0x0084, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__EPDC_BDR_0 = IOMUX_PAD(0x0378, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__USDHC4_CLK = IOMUX_PAD(0x0378, 0x0088, 1, 0x0850, 0, 0), + MX6_PAD_EPDC_BDR0__UART3_CTS = IOMUX_PAD(0x0378, 0x0088, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__UART3_RTS = IOMUX_PAD(0x0378, 0x0088, 2, 0x0808, 2, 0), + MX6_PAD_EPDC_BDR0__WEIM_WEIM_A_26 = IOMUX_PAD(0x0378, 0x0088, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__TCON_RL = IOMUX_PAD(0x0378, 0x0088, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__GPIO_2_5 = IOMUX_PAD(0x0378, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__EPDC_SDCE_7 = IOMUX_PAD(0x0378, 0x0088, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR0__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x0378, 0x0088, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__EPDC_BDR_1 = IOMUX_PAD(0x037C, 0x008C, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__USDHC4_CMD = IOMUX_PAD(0x037C, 0x008C, 1, 0x0858, 0, 0), + MX6_PAD_EPDC_BDR1__UART3_CTS = IOMUX_PAD(0x037C, 0x008C, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__UART3_RTS = IOMUX_PAD(0x037C, 0x008C, 2, 0x0808, 3, 0), + MX6_PAD_EPDC_BDR1__WEIM_WEIM_CRE = IOMUX_PAD(0x037C, 0x008C, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__TCON_UD = IOMUX_PAD(0x037C, 0x008C, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__GPIO_2_6 = IOMUX_PAD(0x037C, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__EPDC_SDCE_8 = IOMUX_PAD(0x037C, 0x008C, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_BDR1__MMDC_MMDC_DEBUG_8 = IOMUX_PAD(0x037C, 0x008C, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__EPDC_SDDO_0 = IOMUX_PAD(0x0380, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__ECSPI4_MOSI = IOMUX_PAD(0x0380, 0x0090, 1, 0x06D8, 0, 0), + MX6_PAD_EPDC_D0__LCDIF_DAT_24 = IOMUX_PAD(0x0380, 0x0090, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__CSI_D_0 = IOMUX_PAD(0x0380, 0x0090, 3, 0x0630, 0, 0), + MX6_PAD_EPDC_D0__TCON_E_DATA_0 = IOMUX_PAD(0x0380, 0x0090, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__GPIO_1_7 = IOMUX_PAD(0x0380, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x0380, 0x0090, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D0__OBSERVE_MUX_OUT_0 = IOMUX_PAD(0x0380, 0x0090, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__EPDC_SDDO_1 = IOMUX_PAD(0x0384, 0x0094, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__ECSPI4_MISO = IOMUX_PAD(0x0384, 0x0094, 1, 0x06D4, 0, 0), + MX6_PAD_EPDC_D1__LCDIF_DAT_25 = IOMUX_PAD(0x0384, 0x0094, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__CSI_D_1 = IOMUX_PAD(0x0384, 0x0094, 3, 0x0634, 0, 0), + MX6_PAD_EPDC_D1__TCON_E_DATA_1 = IOMUX_PAD(0x0384, 0x0094, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__GPIO_1_8 = IOMUX_PAD(0x0384, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0384, 0x0094, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D1__OBSERVE_MUX_OUT_1 = IOMUX_PAD(0x0384, 0x0094, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__EPDC_SDDO_10 = IOMUX_PAD(0x0388, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__ECSPI3_SS0 = IOMUX_PAD(0x0388, 0x0098, 1, 0x06C0, 1, 0), + MX6_PAD_EPDC_D10__EPDC_PWRCTRL_2 = IOMUX_PAD(0x0388, 0x0098, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__WEIM_WEIM_A_18 = IOMUX_PAD(0x0388, 0x0098, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__TCON_E_DATA_10 = IOMUX_PAD(0x0388, 0x0098, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__GPIO_1_17 = IOMUX_PAD(0x0388, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D10__USDHC4_WP = IOMUX_PAD(0x0388, 0x0098, 6, 0x087C, 0, 0), + MX6_PAD_EPDC_D10__MMDC_MMDC_DEBUG_29 = IOMUX_PAD(0x0388, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__EPDC_SDDO_11 = IOMUX_PAD(0x038C, 0x009C, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__ECSPI3_SCLK = IOMUX_PAD(0x038C, 0x009C, 1, 0x06B0, 1, 0), + MX6_PAD_EPDC_D11__EPDC_PWRCTRL_3 = IOMUX_PAD(0x038C, 0x009C, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__WEIM_WEIM_A_19 = IOMUX_PAD(0x038C, 0x009C, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__TCON_E_DATA_11 = IOMUX_PAD(0x038C, 0x009C, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__GPIO_1_18 = IOMUX_PAD(0x038C, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D11__USDHC4_CD = IOMUX_PAD(0x038C, 0x009C, 6, 0x0854, 0, 0), + MX6_PAD_EPDC_D11__MMDC_MMDC_DEBUG_28 = IOMUX_PAD(0x038C, 0x009C, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__EPDC_SDDO_12 = IOMUX_PAD(0x0390, 0x00A0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__UART2_TXD = IOMUX_PAD(0x0390, 0x00A0, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__UART2_RXD = IOMUX_PAD(0x0390, 0x00A0, 1, 0x0804, 0, 0), + MX6_PAD_EPDC_D12__EPDC_PWRCOM = IOMUX_PAD(0x0390, 0x00A0, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__WEIM_WEIM_A_20 = IOMUX_PAD(0x0390, 0x00A0, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__TCON_E_DATA_12 = IOMUX_PAD(0x0390, 0x00A0, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__GPIO_1_19 = IOMUX_PAD(0x0390, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D12__ECSPI3_SS1 = IOMUX_PAD(0x0390, 0x00A0, 6, 0x06C4, 1, 0), + MX6_PAD_EPDC_D12__MMDC_MMDC_DEBUG_27 = IOMUX_PAD(0x0390, 0x00A0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__EPDC_SDDO_13 = IOMUX_PAD(0x0394, 0x00A4, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__UART2_TXD = IOMUX_PAD(0x0394, 0x00A4, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__UART2_RXD = IOMUX_PAD(0x0394, 0x00A4, 1, 0x0804, 1, 0), + MX6_PAD_EPDC_D13__EPDC_PWRIRQ = IOMUX_PAD(0x0394, 0x00A4, 2, 0x06E8, 0, 0), + MX6_PAD_EPDC_D13__WEIM_WEIM_A_21 = IOMUX_PAD(0x0394, 0x00A4, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__TCON_E_DATA_13 = IOMUX_PAD(0x0394, 0x00A4, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__GPIO_1_20 = IOMUX_PAD(0x0394, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D13__ECSPI3_SS2 = IOMUX_PAD(0x0394, 0x00A4, 6, 0x06C8, 0, 0), + MX6_PAD_EPDC_D13__MMDC_MMDC_DEBUG_26 = IOMUX_PAD(0x0394, 0x00A4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__EPDC_SDDO_14 = IOMUX_PAD(0x0398, 0x00A8, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__UART2_CTS = IOMUX_PAD(0x0398, 0x00A8, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__UART2_RTS = IOMUX_PAD(0x0398, 0x00A8, 1, 0x0800, 0, 0), + MX6_PAD_EPDC_D14__EPDC_PWRSTAT = IOMUX_PAD(0x0398, 0x00A8, 2, 0x06EC, 0, 0), + MX6_PAD_EPDC_D14__WEIM_WEIM_A_22 = IOMUX_PAD(0x0398, 0x00A8, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__TCON_E_DATA_14 = IOMUX_PAD(0x0398, 0x00A8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__GPIO_1_21 = IOMUX_PAD(0x0398, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D14__ECSPI3_SS3 = IOMUX_PAD(0x0398, 0x00A8, 6, 0x06CC, 0, 0), + MX6_PAD_EPDC_D14__MMDC_MMDC_DEBUG_25 = IOMUX_PAD(0x0398, 0x00A8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__EPDC_SDDO_15 = IOMUX_PAD(0x039C, 0x00AC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__UART2_CTS = IOMUX_PAD(0x039C, 0x00AC, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__UART2_RTS = IOMUX_PAD(0x039C, 0x00AC, 1, 0x0800, 1, 0), + MX6_PAD_EPDC_D15__EPDC_PWRWAKE = IOMUX_PAD(0x039C, 0x00AC, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__WEIM_WEIM_A_23 = IOMUX_PAD(0x039C, 0x00AC, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__TCON_E_DATA_15 = IOMUX_PAD(0x039C, 0x00AC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__GPIO_1_22 = IOMUX_PAD(0x039C, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D15__ECSPI3_RDY = IOMUX_PAD(0x039C, 0x00AC, 6, 0x06B4, 1, 0), + MX6_PAD_EPDC_D15__MMDC_MMDC_DEBUG_24 = IOMUX_PAD(0x039C, 0x00AC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__EPDC_SDDO_2 = IOMUX_PAD(0x03A0, 0x00B0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__ECSPI4_SS0 = IOMUX_PAD(0x03A0, 0x00B0, 1, 0x06DC, 0, 0), + MX6_PAD_EPDC_D2__LCDIF_DAT_26 = IOMUX_PAD(0x03A0, 0x00B0, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__CSI_D_2 = IOMUX_PAD(0x03A0, 0x00B0, 3, 0x0638, 0, 0), + MX6_PAD_EPDC_D2__TCON_E_DATA_2 = IOMUX_PAD(0x03A0, 0x00B0, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__GPIO_1_9 = IOMUX_PAD(0x03A0, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x03A0, 0x00B0, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D2__TPSMP_HDATA_28 = IOMUX_PAD(0x03A0, 0x00B0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__EPDC_SDDO_3 = IOMUX_PAD(0x03A4, 0x00B4, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__ECSPI4_SCLK = IOMUX_PAD(0x03A4, 0x00B4, 1, 0x06D0, 0, 0), + MX6_PAD_EPDC_D3__LCDIF_DAT_27 = IOMUX_PAD(0x03A4, 0x00B4, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__CSI_D_3 = IOMUX_PAD(0x03A4, 0x00B4, 3, 0x063C, 0, 0), + MX6_PAD_EPDC_D3__TCON_E_DATA_3 = IOMUX_PAD(0x03A4, 0x00B4, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__GPIO_1_10 = IOMUX_PAD(0x03A4, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x03A4, 0x00B4, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D3__TPSMP_HDATA_29 = IOMUX_PAD(0x03A4, 0x00B4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__EPDC_SDDO_4 = IOMUX_PAD(0x03A8, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__ECSPI4_SS1 = IOMUX_PAD(0x03A8, 0x00B8, 1, 0x06E0, 0, 0), + MX6_PAD_EPDC_D4__LCDIF_DAT_28 = IOMUX_PAD(0x03A8, 0x00B8, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__CSI_D_4 = IOMUX_PAD(0x03A8, 0x00B8, 3, 0x0640, 0, 0), + MX6_PAD_EPDC_D4__TCON_E_DATA_4 = IOMUX_PAD(0x03A8, 0x00B8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__GPIO_1_11 = IOMUX_PAD(0x03A8, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x03A8, 0x00B8, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D4__TPSMP_HDATA_30 = IOMUX_PAD(0x03A8, 0x00B8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__EPDC_SDDO_5 = IOMUX_PAD(0x03AC, 0x00BC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__ECSPI4_SS2 = IOMUX_PAD(0x03AC, 0x00BC, 1, 0x06E4, 0, 0), + MX6_PAD_EPDC_D5__LCDIF_DAT_29 = IOMUX_PAD(0x03AC, 0x00BC, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__CSI_D_5 = IOMUX_PAD(0x03AC, 0x00BC, 3, 0x0644, 0, 0), + MX6_PAD_EPDC_D5__TCON_E_DATA_5 = IOMUX_PAD(0x03AC, 0x00BC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__GPIO_1_12 = IOMUX_PAD(0x03AC, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x03AC, 0x00BC, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D5__TPSMP_HDATA_31 = IOMUX_PAD(0x03AC, 0x00BC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__EPDC_SDDO_6 = IOMUX_PAD(0x03B0, 0x00C0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__ECSPI4_SS3 = IOMUX_PAD(0x03B0, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__LCDIF_DAT_30 = IOMUX_PAD(0x03B0, 0x00C0, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__CSI_D_6 = IOMUX_PAD(0x03B0, 0x00C0, 3, 0x0648, 0, 0), + MX6_PAD_EPDC_D6__TCON_E_DATA_6 = IOMUX_PAD(0x03B0, 0x00C0, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__GPIO_1_13 = IOMUX_PAD(0x03B0, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x03B0, 0x00C0, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D6__TPSMP_HDATA_20 = IOMUX_PAD(0x03B0, 0x00C0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__EPDC_SDDO_7 = IOMUX_PAD(0x03B4, 0x00C4, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__ECSPI4_RDY = IOMUX_PAD(0x03B4, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__LCDIF_DAT_31 = IOMUX_PAD(0x03B4, 0x00C4, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__CSI_D_7 = IOMUX_PAD(0x03B4, 0x00C4, 3, 0x064C, 0, 0), + MX6_PAD_EPDC_D7__TCON_E_DATA_7 = IOMUX_PAD(0x03B4, 0x00C4, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__GPIO_1_14 = IOMUX_PAD(0x03B4, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x03B4, 0x00C4, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D7__MMDC_MMDC_DEBUG_32 = IOMUX_PAD(0x03B4, 0x00C4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__EPDC_SDDO_8 = IOMUX_PAD(0x03B8, 0x00C8, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__ECSPI3_MOSI = IOMUX_PAD(0x03B8, 0x00C8, 1, 0x06BC, 1, 0), + MX6_PAD_EPDC_D8__EPDC_PWRCTRL_0 = IOMUX_PAD(0x03B8, 0x00C8, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__WEIM_WEIM_A_16 = IOMUX_PAD(0x03B8, 0x00C8, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__TCON_E_DATA_8 = IOMUX_PAD(0x03B8, 0x00C8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__GPIO_1_15 = IOMUX_PAD(0x03B8, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__USDHC4_RST = IOMUX_PAD(0x03B8, 0x00C8, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D8__MMDC_MMDC_DEBUG_31 = IOMUX_PAD(0x03B8, 0x00C8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__EPDC_SDDO_9 = IOMUX_PAD(0x03BC, 0x00CC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__ECSPI3_MISO = IOMUX_PAD(0x03BC, 0x00CC, 1, 0x06B8, 1, 0), + MX6_PAD_EPDC_D9__EPDC_PWRCTRL_1 = IOMUX_PAD(0x03BC, 0x00CC, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__WEIM_WEIM_A_17 = IOMUX_PAD(0x03BC, 0x00CC, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__TCON_E_DATA_9 = IOMUX_PAD(0x03BC, 0x00CC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__GPIO_1_16 = IOMUX_PAD(0x03BC, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__USDHC4_VSELECT = IOMUX_PAD(0x03BC, 0x00CC, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_D9__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x03BC, 0x00CC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__EPDC_GDCLK = IOMUX_PAD(0x03C0, 0x00D0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__ECSPI2_SS2 = IOMUX_PAD(0x03C0, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__TCON_YCKR = IOMUX_PAD(0x03C0, 0x00D0, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__CSI_PIXCLK = IOMUX_PAD(0x03C0, 0x00D0, 3, 0x0674, 1, 0), + MX6_PAD_EPDC_GDCLK__TCON_YCKL = IOMUX_PAD(0x03C0, 0x00D0, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__GPIO_1_31 = IOMUX_PAD(0x03C0, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__USDHC2_RST = IOMUX_PAD(0x03C0, 0x00D0, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_GDCLK__MMDC_MMDC_DEBUG_15 = IOMUX_PAD(0x03C0, 0x00D0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__EPDC_GDOE = IOMUX_PAD(0x03C4, 0x00D4, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__ECSPI2_SS3 = IOMUX_PAD(0x03C4, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__TCON_YOER = IOMUX_PAD(0x03C4, 0x00D4, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__CSI_HSYNC = IOMUX_PAD(0x03C4, 0x00D4, 3, 0x0670, 1, 0), + MX6_PAD_EPDC_GDOE__TCON_YOEL = IOMUX_PAD(0x03C4, 0x00D4, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__GPIO_2_0 = IOMUX_PAD(0x03C4, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__USDHC2_VSELECT = IOMUX_PAD(0x03C4, 0x00D4, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_GDOE__MMDC_MMDC_DEBUG_14 = IOMUX_PAD(0x03C4, 0x00D4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__EPDC_GDRL = IOMUX_PAD(0x03C8, 0x00D8, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__ECSPI2_RDY = IOMUX_PAD(0x03C8, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__TCON_YDIOUR = IOMUX_PAD(0x03C8, 0x00D8, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__CSI_MCLK = IOMUX_PAD(0x03C8, 0x00D8, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__TCON_YDIOUL = IOMUX_PAD(0x03C8, 0x00D8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__GPIO_2_1 = IOMUX_PAD(0x03C8, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_GDRL__USDHC2_WP = IOMUX_PAD(0x03C8, 0x00D8, 6, 0x0834, 1, 0), + MX6_PAD_EPDC_GDRL__MMDC_MMDC_DEBUG_13 = IOMUX_PAD(0x03C8, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__EPDC_GDSP = IOMUX_PAD(0x03CC, 0x00DC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__PWM4_PWMO = IOMUX_PAD(0x03CC, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__TCON_YDIODR = IOMUX_PAD(0x03CC, 0x00DC, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__CSI_VSYNC = IOMUX_PAD(0x03CC, 0x00DC, 3, 0x0678, 1, 0), + MX6_PAD_EPDC_GDSP__TCON_YDIODL = IOMUX_PAD(0x03CC, 0x00DC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__GPIO_2_2 = IOMUX_PAD(0x03CC, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_GDSP__USDHC2_CD = IOMUX_PAD(0x03CC, 0x00DC, 6, 0x0830, 1, 0), + MX6_PAD_EPDC_GDSP__MMDC_MMDC_DEBUG_12 = IOMUX_PAD(0x03CC, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCOM__EPDC_PWRCOM = IOMUX_PAD(0x03D0, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCOM__USDHC4_DAT0 = IOMUX_PAD(0x03D0, 0x00E0, 1, 0x085C, 0, 0), + MX6_PAD_EPDC_PWRCOM__LCDIF_DAT_20 = IOMUX_PAD(0x03D0, 0x00E0, 2, 0x07C8, 0, 0), + MX6_PAD_EPDC_PWRCOM__WEIM_WEIM_BCLK = IOMUX_PAD(0x03D0, 0x00E0, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCOM__ANATOP_USBOTG1_ID = IOMUX_PAD(0x03D0, 0x00E0, 4, 0x05DC, 0, 0), + MX6_PAD_EPDC_PWRCOM__GPIO_2_11 = IOMUX_PAD(0x03D0, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCOM__USDHC3_RST = IOMUX_PAD(0x03D0, 0x00E0, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCOM__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x03D0, 0x00E0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__EPDC_PWRCTRL_0 = IOMUX_PAD(0x03D4, 0x00E4, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03D4, 0x00E4, 1, 0x0604, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__LCDIF_DAT_16 = IOMUX_PAD(0x03D4, 0x00E4, 2, 0x07B8, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__WEIM_WEIM_RW = IOMUX_PAD(0x03D4, 0x00E4, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__TCON_YCKL = IOMUX_PAD(0x03D4, 0x00E4, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__GPIO_2_7 = IOMUX_PAD(0x03D4, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__USDHC4_RST = IOMUX_PAD(0x03D4, 0x00E4, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL0__MMDC_MMDC_DEBUG_7 = IOMUX_PAD(0x03D4, 0x00E4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__EPDC_PWRCTRL_1 = IOMUX_PAD(0x03D8, 0x00E8, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x03D8, 0x00E8, 1, 0x0610, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__LCDIF_DAT_17 = IOMUX_PAD(0x03D8, 0x00E8, 2, 0x07BC, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__WEIM_WEIM_OE = IOMUX_PAD(0x03D8, 0x00E8, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__TCON_YOEL = IOMUX_PAD(0x03D8, 0x00E8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__GPIO_2_8 = IOMUX_PAD(0x03D8, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__USDHC4_VSELECT = IOMUX_PAD(0x03D8, 0x00E8, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL1__MMDC_MMDC_DEBUG_6 = IOMUX_PAD(0x03D8, 0x00E8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__EPDC_PWRCTRL_2 = IOMUX_PAD(0x03DC, 0x00EC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__AUDMUX_AUD5_TXD = IOMUX_PAD(0x03DC, 0x00EC, 1, 0x0600, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__LCDIF_DAT_18 = IOMUX_PAD(0x03DC, 0x00EC, 2, 0x07C0, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__WEIM_WEIM_CS_0 = IOMUX_PAD(0x03DC, 0x00EC, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__TCON_YDIOUL = IOMUX_PAD(0x03DC, 0x00EC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__GPIO_2_9 = IOMUX_PAD(0x03DC, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL2__USDHC4_WP = IOMUX_PAD(0x03DC, 0x00EC, 6, 0x087C, 1, 0), + MX6_PAD_EPDC_PWRCTRL2__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x03DC, 0x00EC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__EPDC_PWRCTRL_3 = IOMUX_PAD(0x03E0, 0x00F0, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__AUDMUX_AUD5_TXC = IOMUX_PAD(0x03E0, 0x00F0, 1, 0x060C, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__LCDIF_DAT_19 = IOMUX_PAD(0x03E0, 0x00F0, 2, 0x07C4, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__WEIM_WEIM_CS_1 = IOMUX_PAD(0x03E0, 0x00F0, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__TCON_YDIODL = IOMUX_PAD(0x03E0, 0x00F0, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__GPIO_2_10 = IOMUX_PAD(0x03E0, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRCTRL3__USDHC4_CD = IOMUX_PAD(0x03E0, 0x00F0, 6, 0x0854, 1, 0), + MX6_PAD_EPDC_PWRCTRL3__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x03E0, 0x00F0, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRINT__EPDC_PWRIRQ = IOMUX_PAD(0x03E4, 0x00F4, 0, 0x06E8, 1, 0), + MX6_PAD_EPDC_PWRINT__USDHC4_DAT1 = IOMUX_PAD(0x03E4, 0x00F4, 1, 0x0860, 0, 0), + MX6_PAD_EPDC_PWRINT__LCDIF_DAT_21 = IOMUX_PAD(0x03E4, 0x00F4, 2, 0x07CC, 0, 0), + MX6_PAD_EPDC_PWRINT__WEIM_ACLK_FREERUN = IOMUX_PAD(0x03E4, 0x00F4, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRINT__ANATOP_USBOTG2_ID = IOMUX_PAD(0x03E4, 0x00F4, 4, 0x05E0, 0, 0), + MX6_PAD_EPDC_PWRINT__GPIO_2_12 = IOMUX_PAD(0x03E4, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRINT__USDHC3_VSELECT = IOMUX_PAD(0x03E4, 0x00F4, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRINT__MMDC_MMDC_DEBUG_2 = IOMUX_PAD(0x03E4, 0x00F4, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRSTAT__EPDC_PWRSTAT = IOMUX_PAD(0x03E8, 0x00F8, 0, 0x06EC, 1, 0), + MX6_PAD_EPDC_PWRSTAT__USDHC4_DAT2 = IOMUX_PAD(0x03E8, 0x00F8, 1, 0x0864, 0, 0), + MX6_PAD_EPDC_PWRSTAT__LCDIF_DAT_22 = IOMUX_PAD(0x03E8, 0x00F8, 2, 0x07D0, 0, 0), + MX6_PAD_EPDC_PWRSTAT__WEIM_WEIM_WAIT = IOMUX_PAD(0x03E8, 0x00F8, 3, 0x0884, 0, 0), + MX6_PAD_EPDC_PWRSTAT__KITTEN_EVENTI = IOMUX_PAD(0x03E8, 0x00F8, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRSTAT__GPIO_2_13 = IOMUX_PAD(0x03E8, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRSTAT__USDHC3_WP = IOMUX_PAD(0x03E8, 0x00F8, 6, 0x084C, 0, 0), + MX6_PAD_EPDC_PWRSTAT__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x03E8, 0x00F8, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__EPDC_PWRWAKE = IOMUX_PAD(0x03EC, 0x00FC, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__USDHC4_DAT3 = IOMUX_PAD(0x03EC, 0x00FC, 1, 0x0868, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__LCDIF_DAT_23 = IOMUX_PAD(0x03EC, 0x00FC, 2, 0x07D4, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__WEIM_WEIM_DTACK_B = IOMUX_PAD(0x03EC, 0x00FC, 3, 0x0880, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__KITTEN_EVENTO = IOMUX_PAD(0x03EC, 0x00FC, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__GPIO_2_14 = IOMUX_PAD(0x03EC, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__USDHC3_CD = IOMUX_PAD(0x03EC, 0x00FC, 6, 0x0838, 0, 0), + MX6_PAD_EPDC_PWRWAKEUP__MMDC_MMDC_DEBUG_0 = IOMUX_PAD(0x03EC, 0x00FC, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__EPDC_SDCE_0 = IOMUX_PAD(0x03F0, 0x0100, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__ECSPI2_SS1 = IOMUX_PAD(0x03F0, 0x0100, 1, 0x06AC, 0, 0), + MX6_PAD_EPDC_SDCE0__PWM3_PWMO = IOMUX_PAD(0x03F0, 0x0100, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__WEIM_WEIM_CS_2 = IOMUX_PAD(0x03F0, 0x0100, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__TCON_YCKR = IOMUX_PAD(0x03F0, 0x0100, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__GPIO_1_27 = IOMUX_PAD(0x03F0, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x03F0, 0x0100, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE0__MMDC_MMDC_DEBUG_19 = IOMUX_PAD(0x03F0, 0x0100, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__EPDC_SDCE_1 = IOMUX_PAD(0x03F4, 0x0104, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__WDOG2_WDOG_B = IOMUX_PAD(0x03F4, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__PWM4_PWMO = IOMUX_PAD(0x03F4, 0x0104, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__WEIM_WEIM_LBA = IOMUX_PAD(0x03F4, 0x0104, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__TCON_YOER = IOMUX_PAD(0x03F4, 0x0104, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__GPIO_1_28 = IOMUX_PAD(0x03F4, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x03F4, 0x0104, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE1__MMDC_MMDC_DEBUG_18 = IOMUX_PAD(0x03F4, 0x0104, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__EPDC_SDCE_2 = IOMUX_PAD(0x03F8, 0x0108, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__I2C3_SCL = IOMUX_PAD(0x03F8, 0x0108, 17, 0x072C, 1, 0), + MX6_PAD_EPDC_SDCE2__PWM1_PWMO = IOMUX_PAD(0x03F8, 0x0108, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__WEIM_WEIM_EB_0 = IOMUX_PAD(0x03F8, 0x0108, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__TCON_YDIOUR = IOMUX_PAD(0x03F8, 0x0108, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__GPIO_1_29 = IOMUX_PAD(0x03F8, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x03F8, 0x0108, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE2__MMDC_MMDC_DEBUG_17 = IOMUX_PAD(0x03F8, 0x0108, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__EPDC_SDCE_3 = IOMUX_PAD(0x03FC, 0x010C, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__I2C3_SDA = IOMUX_PAD(0x03FC, 0x010C, 17, 0x0730, 1, 0), + MX6_PAD_EPDC_SDCE3__PWM2_PWMO = IOMUX_PAD(0x03FC, 0x010C, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__WEIM_WEIM_EB_1 = IOMUX_PAD(0x03FC, 0x010C, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__TCON_YDIODR = IOMUX_PAD(0x03FC, 0x010C, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__GPIO_1_30 = IOMUX_PAD(0x03FC, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x03FC, 0x010C, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCE3__MMDC_MMDC_DEBUG_16 = IOMUX_PAD(0x03FC, 0x010C, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCLK__EPDC_SDCLK = IOMUX_PAD(0x0400, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCLK__ECSPI2_MOSI = IOMUX_PAD(0x0400, 0x0110, 1, 0x06A4, 1, 0), + MX6_PAD_EPDC_SDCLK__I2C2_SCL = IOMUX_PAD(0x0400, 0x0110, 18, 0x0724, 0, 0), + MX6_PAD_EPDC_SDCLK__CSI_D_8 = IOMUX_PAD(0x0400, 0x0110, 3, 0x0650, 0, 0), + MX6_PAD_EPDC_SDCLK__TCON_CL = IOMUX_PAD(0x0400, 0x0110, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCLK__GPIO_1_23 = IOMUX_PAD(0x0400, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCLK__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x0400, 0x0110, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDCLK__MMDC_MMDC_DEBUG_23 = IOMUX_PAD(0x0400, 0x0110, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDLE__EPDC_SDLE = IOMUX_PAD(0x0404, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDLE__ECSPI2_MISO = IOMUX_PAD(0x0404, 0x0114, 1, 0x06A0, 1, 0), + MX6_PAD_EPDC_SDLE__I2C2_SDA = IOMUX_PAD(0x0404, 0x0114, 18, 0x0728, 0, 0), + MX6_PAD_EPDC_SDLE__CSI_D_9 = IOMUX_PAD(0x0404, 0x0114, 3, 0x0654, 0, 0), + MX6_PAD_EPDC_SDLE__TCON_LD = IOMUX_PAD(0x0404, 0x0114, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDLE__GPIO_1_24 = IOMUX_PAD(0x0404, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDLE__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x0404, 0x0114, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDLE__MMDC_MMDC_DEBUG_22 = IOMUX_PAD(0x0404, 0x0114, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__EPDC_SDOE = IOMUX_PAD(0x0408, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__ECSPI2_SS0 = IOMUX_PAD(0x0408, 0x0118, 1, 0x06A8, 1, 0), + MX6_PAD_EPDC_SDOE__TCON_XDIOR = IOMUX_PAD(0x0408, 0x0118, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__CSI_D_10 = IOMUX_PAD(0x0408, 0x0118, 3, 0x0658, 0, 0), + MX6_PAD_EPDC_SDOE__TCON_XDIOL = IOMUX_PAD(0x0408, 0x0118, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__GPIO_1_25 = IOMUX_PAD(0x0408, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x0408, 0x0118, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDOE__MMDC_MMDC_DEBUG_21 = IOMUX_PAD(0x0408, 0x0118, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__EPDC_SDSHR = IOMUX_PAD(0x040C, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__ECSPI2_SCLK = IOMUX_PAD(0x040C, 0x011C, 1, 0x069C, 1, 0), + MX6_PAD_EPDC_SDSHR__EPDC_SDCE_4 = IOMUX_PAD(0x040C, 0x011C, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__CSI_D_11 = IOMUX_PAD(0x040C, 0x011C, 3, 0x065C, 0, 0), + MX6_PAD_EPDC_SDSHR__TCON_XDIOR = IOMUX_PAD(0x040C, 0x011C, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__GPIO_1_26 = IOMUX_PAD(0x040C, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x040C, 0x011C, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_SDSHR__MMDC_MMDC_DEBUG_20 = IOMUX_PAD(0x040C, 0x011C, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__EPDC_VCOM_0 = IOMUX_PAD(0x0410, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0410, 0x0120, 1, 0x0608, 0, 0), + MX6_PAD_EPDC_VCOM0__UART3_TXD = IOMUX_PAD(0x0410, 0x0120, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__UART3_RXD = IOMUX_PAD(0x0410, 0x0120, 2, 0x080C, 4, 0), + MX6_PAD_EPDC_VCOM0__WEIM_WEIM_A_24 = IOMUX_PAD(0x0410, 0x0120, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__TCON_VCOM_0 = IOMUX_PAD(0x0410, 0x0120, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__GPIO_2_3 = IOMUX_PAD(0x0410, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__EPDC_SDCE_5 = IOMUX_PAD(0x0410, 0x0120, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM0__MMDC_MMDC_DEBUG_11 = IOMUX_PAD(0x0410, 0x0120, 7, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__EPDC_VCOM_1 = IOMUX_PAD(0x0414, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0414, 0x0124, 1, 0x05FC, 0, 0), + MX6_PAD_EPDC_VCOM1__UART3_TXD = IOMUX_PAD(0x0414, 0x0124, 2, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__UART3_RXD = IOMUX_PAD(0x0414, 0x0124, 2, 0x080C, 5, 0), + MX6_PAD_EPDC_VCOM1__WEIM_WEIM_A_25 = IOMUX_PAD(0x0414, 0x0124, 3, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__TCON_VCOM_1 = IOMUX_PAD(0x0414, 0x0124, 4, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__GPIO_2_4 = IOMUX_PAD(0x0414, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__EPDC_SDCE_6 = IOMUX_PAD(0x0414, 0x0124, 6, 0x0000, 0, 0), + MX6_PAD_EPDC_VCOM1__MMDC_MMDC_DEBUG_10 = IOMUX_PAD(0x0414, 0x0124, 7, 0x0000, 0, 0), + MX6_PAD_FEC_CRS_DV__FEC_RX_DV = IOMUX_PAD(0x0418, 0x0128, 0, 0x0704, 1, 0), + MX6_PAD_FEC_CRS_DV__USDHC4_DAT1 = IOMUX_PAD(0x0418, 0x0128, 1, 0x0860, 1, 0), + MX6_PAD_FEC_CRS_DV__AUDMUX_AUD6_TXC = IOMUX_PAD(0x0418, 0x0128, 2, 0x0624, 0, 0), + MX6_PAD_FEC_CRS_DV__ECSPI4_MISO = IOMUX_PAD(0x0418, 0x0128, 3, 0x06D4, 1, 0), + MX6_PAD_FEC_CRS_DV__GPT_CMPOUT2 = IOMUX_PAD(0x0418, 0x0128, 4, 0x0000, 0, 0), + MX6_PAD_FEC_CRS_DV__GPIO_4_25 = IOMUX_PAD(0x0418, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_FEC_CRS_DV__KITTEN_TRACE_31 = IOMUX_PAD(0x0418, 0x0128, 6, 0x0000, 0, 0), + MX6_PAD_FEC_CRS_DV__PL301_SIM_MX6_PER1_HADDR_3 = IOMUX_PAD(0x0418, 0x0128, 7, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x041C, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__USDHC4_DAT4 = IOMUX_PAD(0x041C, 0x012C, 1, 0x086C, 0, 0), + MX6_PAD_FEC_MDC__AUDMUX_AUDIO_CLK_OUT = IOMUX_PAD(0x041C, 0x012C, 2, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__USDHC1_RST = IOMUX_PAD(0x041C, 0x012C, 3, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__USDHC3_RST = IOMUX_PAD(0x041C, 0x012C, 4, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__GPIO_4_23 = IOMUX_PAD(0x041C, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__KITTEN_TRACE_29 = IOMUX_PAD(0x041C, 0x012C, 6, 0x0000, 0, 0), + MX6_PAD_FEC_MDC__PL301_SIM_MX6_PER1_HADDR_8 = IOMUX_PAD(0x041C, 0x012C, 7, 0x0000, 0, 0), + MX6_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x0420, 0x0130, 0, 0x06F4, 1, 0), + MX6_PAD_FEC_MDIO__USDHC4_CLK = IOMUX_PAD(0x0420, 0x0130, 1, 0x0850, 1, 0), + MX6_PAD_FEC_MDIO__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0420, 0x0130, 2, 0x0620, 0, 0), + MX6_PAD_FEC_MDIO__ECSPI4_SS0 = IOMUX_PAD(0x0420, 0x0130, 3, 0x06DC, 1, 0), + MX6_PAD_FEC_MDIO__GPT_CAPIN1 = IOMUX_PAD(0x0420, 0x0130, 4, 0x0710, 0, 0), + MX6_PAD_FEC_MDIO__GPIO_4_20 = IOMUX_PAD(0x0420, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_FEC_MDIO__KITTEN_TRACE_26 = IOMUX_PAD(0x0420, 0x0130, 6, 0x0000, 0, 0), + MX6_PAD_FEC_MDIO__PL301_SIM_MX6_PER1_HADDR_15 = IOMUX_PAD(0x0420, 0x0130, 7, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__FEC_REF_OUT = IOMUX_PAD(0x0424, 0x0134, 0x10, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__USDHC4_RST = IOMUX_PAD(0x0424, 0x0134, 1, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__WDOG1_WDOG_B = IOMUX_PAD(0x0424, 0x0134, 2, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__PWM4_PWMO = IOMUX_PAD(0x0424, 0x0134, 3, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__CCM_PMIC_RDY = IOMUX_PAD(0x0424, 0x0134, 4, 0x062C, 0, 0), + MX6_PAD_FEC_REF_CLK__GPIO_4_26 = IOMUX_PAD(0x0424, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_FEC_REF_CLK__SPDIF_SPDIF_EXT_CLK = IOMUX_PAD(0x0424, 0x0134, 6, 0x07F4, 2, 0), + MX6_PAD_FEC_REF_CLK__PL301_SIM_MX6_PER1_HADDR_0 = IOMUX_PAD(0x0424, 0x0134, 7, 0x0000, 0, 0), + MX6_PAD_FEC_RX_ER__GPIO_4_19 = IOMUX_PAD(0x0428, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_FEC_RX_ER__KITTEN_TRACE_25 = IOMUX_PAD(0x0428, 0x0138, 6, 0x0000, 0, 0), + MX6_PAD_FEC_RX_ER__PL301_SIM_MX6_PER1_HADDR_5 = IOMUX_PAD(0x0428, 0x0138, 7, 0x0000, 0, 0), + MX6_PAD_FEC_RX_ER__FEC_RX_ER = IOMUX_PAD(0x0428, 0x0138, 0, 0x0708, 1, 0), + MX6_PAD_FEC_RX_ER__USDHC4_DAT0 = IOMUX_PAD(0x0428, 0x0138, 1, 0x085C, 1, 0), + MX6_PAD_FEC_RX_ER__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0428, 0x0138, 2, 0x0614, 0, 0), + MX6_PAD_FEC_RX_ER__ECSPI4_MOSI = IOMUX_PAD(0x0428, 0x0138, 3, 0x06D8, 1, 0), + MX6_PAD_FEC_RX_ER__GPT_CMPOUT1 = IOMUX_PAD(0x0428, 0x0138, 4, 0x0000, 0, 0), + MX6_PAD_FEC_RXD0__FEC_RDATA_0 = IOMUX_PAD(0x042C, 0x013C, 0, 0x06F8, 0, 0), + MX6_PAD_FEC_RXD0__USDHC4_DAT5 = IOMUX_PAD(0x042C, 0x013C, 1, 0x0870, 0, 0), + MX6_PAD_FEC_RXD0__ANATOP_USBOTG1_ID = IOMUX_PAD(0x042C, 0x013C, 2, 0x05DC, 1, 0), + MX6_PAD_FEC_RXD0__USDHC1_VSELECT = IOMUX_PAD(0x042C, 0x013C, 3, 0x0000, 0, 0), + MX6_PAD_FEC_RXD0__USDHC3_VSELECT = IOMUX_PAD(0x042C, 0x013C, 4, 0x0000, 0, 0), + MX6_PAD_FEC_RXD0__GPIO_4_17 = IOMUX_PAD(0x042C, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_FEC_RXD0__KITTEN_TRACE_24 = IOMUX_PAD(0x042C, 0x013C, 6, 0x0000, 0, 0), + MX6_PAD_FEC_RXD0__PL301_SIM_MX6_PER1_HADDR_7 = IOMUX_PAD(0x042C, 0x013C, 7, 0x0000, 0, 0), + MX6_PAD_FEC_RXD1__FEC_RDATA_1 = IOMUX_PAD(0x0430, 0x0140, 0, 0x06FC, 1, 0), + MX6_PAD_FEC_RXD1__USDHC4_DAT2 = IOMUX_PAD(0x0430, 0x0140, 1, 0x0864, 1, 0), + MX6_PAD_FEC_RXD1__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0430, 0x0140, 2, 0x0628, 0, 0), + MX6_PAD_FEC_RXD1__ECSPI4_SS1 = IOMUX_PAD(0x0430, 0x0140, 3, 0x06E0, 1, 0), + MX6_PAD_FEC_RXD1__GPT_CMPOUT3 = IOMUX_PAD(0x0430, 0x0140, 4, 0x0000, 0, 0), + MX6_PAD_FEC_RXD1__GPIO_4_18 = IOMUX_PAD(0x0430, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_FEC_RXD1__FEC_COL = IOMUX_PAD(0x0430, 0x0140, 6, 0x06F0, 0, 0), + MX6_PAD_FEC_RXD1__PL301_SIM_MX6_PER1_HADDR_9 = IOMUX_PAD(0x0430, 0x0140, 7, 0x0000, 0, 0), + MX6_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x0434, 0x0144, 0, 0x070C, 1, 0), + MX6_PAD_FEC_TX_CLK__USDHC4_CMD = IOMUX_PAD(0x0434, 0x0144, 1, 0x0858, 1, 0), + MX6_PAD_FEC_TX_CLK__AUDMUX_AUD6_RXC = IOMUX_PAD(0x0434, 0x0144, 2, 0x061C, 0, 0), + MX6_PAD_FEC_TX_CLK__ECSPI4_SCLK = IOMUX_PAD(0x0434, 0x0144, 3, 0x06D0, 1, 0), + MX6_PAD_FEC_TX_CLK__GPT_CAPIN2 = IOMUX_PAD(0x0434, 0x0144, 4, 0x0714, 0, 0), + MX6_PAD_FEC_TX_CLK__GPIO_4_21 = IOMUX_PAD(0x0434, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_FEC_TX_CLK__KITTEN_TRACE_27 = IOMUX_PAD(0x0434, 0x0144, 6, 0x0000, 0, 0), + MX6_PAD_FEC_TX_CLK__PL301_SIM_MX6_PER1_HADDR_4 = IOMUX_PAD(0x0434, 0x0144, 7, 0x0000, 0, 0), + MX6_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x0438, 0x0148, 0, 0x0000, 0, 0), + MX6_PAD_FEC_TX_EN__USDHC4_DAT6 = IOMUX_PAD(0x0438, 0x0148, 1, 0x0874, 0, 0), + MX6_PAD_FEC_TX_EN__SPDIF_IN1 = IOMUX_PAD(0x0438, 0x0148, 2, 0x07F0, 0, 0), + MX6_PAD_FEC_TX_EN__USDHC1_WP = IOMUX_PAD(0x0438, 0x0148, 3, 0x082C, 1, 0), + MX6_PAD_FEC_TX_EN__USDHC3_WP = IOMUX_PAD(0x0438, 0x0148, 4, 0x084C, 1, 0), + MX6_PAD_FEC_TX_EN__GPIO_4_22 = IOMUX_PAD(0x0438, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_FEC_TX_EN__KITTEN_TRACE_28 = IOMUX_PAD(0x0438, 0x0148, 6, 0x0000, 0, 0), + MX6_PAD_FEC_TX_EN__PL301_SIM_MX6_PER1_HADDR_1 = IOMUX_PAD(0x0438, 0x0148, 7, 0x0000, 0, 0), + MX6_PAD_FEC_TXD0__FEC_TDATA_0 = IOMUX_PAD(0x043C, 0x014C, 0, 0x0000, 0, 0), + MX6_PAD_FEC_TXD0__USDHC4_DAT3 = IOMUX_PAD(0x043C, 0x014C, 1, 0x0868, 1, 0), + MX6_PAD_FEC_TXD0__AUDMUX_AUD6_TXD = IOMUX_PAD(0x043C, 0x014C, 2, 0x0618, 0, 0), + MX6_PAD_FEC_TXD0__ECSPI4_SS2 = IOMUX_PAD(0x043C, 0x014C, 3, 0x06E4, 1, 0), + MX6_PAD_FEC_TXD0__GPT_CLKIN = IOMUX_PAD(0x043C, 0x014C, 4, 0x0718, 0, 0), + MX6_PAD_FEC_TXD0__GPIO_4_24 = IOMUX_PAD(0x043C, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_FEC_TXD0__KITTEN_TRACE_30 = IOMUX_PAD(0x043C, 0x014C, 6, 0x0000, 0, 0), + MX6_PAD_FEC_TXD0__PL301_SIM_MX6_PER1_HADDR_2 = IOMUX_PAD(0x043C, 0x014C, 7, 0x0000, 0, 0), + MX6_PAD_FEC_TXD1__FEC_TDATA_1 = IOMUX_PAD(0x0440, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_FEC_TXD1__USDHC4_DAT7 = IOMUX_PAD(0x0440, 0x0150, 1, 0x0878, 0, 0), + MX6_PAD_FEC_TXD1__SPDIF_OUT1 = IOMUX_PAD(0x0440, 0x0150, 2, 0x0000, 0, 0), + MX6_PAD_FEC_TXD1__USDHC1_CD = IOMUX_PAD(0x0440, 0x0150, 3, 0x0828, 1, 0), + MX6_PAD_FEC_TXD1__USDHC3_CD = IOMUX_PAD(0x0440, 0x0150, 4, 0x0838, 1, 0), + MX6_PAD_FEC_TXD1__GPIO_4_16 = IOMUX_PAD(0x0440, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_FEC_TXD1__FEC_RX_CLK = IOMUX_PAD(0x0440, 0x0150, 6, 0x0700, 0, 0), + MX6_PAD_FEC_TXD1__PL301_SIM_MX6_PER1_HADDR_6 = IOMUX_PAD(0x0440, 0x0150, 7, 0x0000, 0, 0), + MX6_PAD_HSIC_DAT__USB_H_DATA = IOMUX_PAD(0x0444, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_HSIC_DAT__I2C1_SCL = IOMUX_PAD(0x0444, 0x0154, 17, 0x071C, 1, 0), + MX6_PAD_HSIC_DAT__PWM1_PWMO = IOMUX_PAD(0x0444, 0x0154, 2, 0x0000, 0, 0), + MX6_PAD_HSIC_DAT__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x0444, 0x0154, 3, 0x0000, 0, 0), + MX6_PAD_HSIC_DAT__OSC32K_32K_OUT = IOMUX_PAD(0x0444, 0x0154, 4, 0x0000, 0, 0), + MX6_PAD_HSIC_DAT__GPIO_3_19 = IOMUX_PAD(0x0444, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_HSIC_STROBE__USB_H_STROBE = IOMUX_PAD(0x0448, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_HSIC_STROBE__I2C1_SDA = IOMUX_PAD(0x0448, 0x0158, 17, 0x0720, 1, 0), + MX6_PAD_HSIC_STROBE__PWM2_PWMO = IOMUX_PAD(0x0448, 0x0158, 2, 0x0000, 0, 0), + MX6_PAD_HSIC_STROBE__ANATOP_ANATOP_32K_OUT = IOMUX_PAD(0x0448, 0x0158, 3, 0x0000, 0, 0), + MX6_PAD_HSIC_STROBE__GPIO_3_20 = IOMUX_PAD(0x0448, 0x0158, 5, 0x0000, 0, 0), + MX6_PAD_I2C1_SCL__I2C1_SCL = IOMUX_PAD(0x044C, 0x015C, 16, 0x071C, 2, 0), + MX6_PAD_I2C1_SCL__UART1_CTS = IOMUX_PAD(0x044C, 0x015C, 1, 0x0000, 0, 0), + MX6_PAD_I2C1_SCL__UART1_RTS = IOMUX_PAD(0x044C, 0x015C, 1, 0x07F8, 0, 0), + MX6_PAD_I2C1_SCL__ECSPI3_SS2 = IOMUX_PAD(0x044C, 0x015C, 2, 0x06C8, 1, 0), + MX6_PAD_I2C1_SCL__FEC_RDATA_0 = IOMUX_PAD(0x044C, 0x015C, 3, 0x06F8, 1, 0), + MX6_PAD_I2C1_SCL__USDHC3_RST = IOMUX_PAD(0x044C, 0x015C, 4, 0x0000, 0, 0), + MX6_PAD_I2C1_SCL__GPIO_3_12 = IOMUX_PAD(0x044C, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_I2C1_SCL__ECSPI1_SS1 = IOMUX_PAD(0x044C, 0x015C, 6, 0x0690, 0, 0), + MX6_PAD_I2C1_SCL__PL301_SIM_MX6_PER1_HSIZE_0 = IOMUX_PAD(0x044C, 0x015C, 7, 0x0000, 0, 0), + MX6_PAD_I2C1_SDA__I2C1_SDA = IOMUX_PAD(0x0450, 0x0160, 16, 0x0720, 2, 0), + MX6_PAD_I2C1_SDA__UART1_CTS = IOMUX_PAD(0x0450, 0x0160, 1, 0x0000, 0, 0), + MX6_PAD_I2C1_SDA__UART1_RTS = IOMUX_PAD(0x0450, 0x0160, 1, 0x07F8, 1, 0), + MX6_PAD_I2C1_SDA__ECSPI3_SS3 = IOMUX_PAD(0x0450, 0x0160, 2, 0x06CC, 1, 0), + MX6_PAD_I2C1_SDA__FEC_TX_EN = IOMUX_PAD(0x0450, 0x0160, 3, 0x0000, 0, 0), + MX6_PAD_I2C1_SDA__USDHC3_VSELECT = IOMUX_PAD(0x0450, 0x0160, 4, 0x0000, 0, 0), + MX6_PAD_I2C1_SDA__GPIO_3_13 = IOMUX_PAD(0x0450, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_I2C1_SDA__ECSPI1_SS2 = IOMUX_PAD(0x0450, 0x0160, 6, 0x0694, 0, 0), + MX6_PAD_I2C1_SDA__PL301_SIM_MX6_PER1_HSIZE_1 = IOMUX_PAD(0x0450, 0x0160, 7, 0x0000, 0, 0), + MX6_PAD_I2C2_SCL__I2C2_SCL = IOMUX_PAD(0x0454, 0x0164, 16, 0x0724, 1, 0), + MX6_PAD_I2C2_SCL__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x0454, 0x0164, 1, 0x05F0, 0, 0), + MX6_PAD_I2C2_SCL__SPDIF_IN1 = IOMUX_PAD(0x0454, 0x0164, 2, 0x07F0, 1, 0), + MX6_PAD_I2C2_SCL__FEC_TDATA_1 = IOMUX_PAD(0x0454, 0x0164, 3, 0x0000, 0, 0), + MX6_PAD_I2C2_SCL__USDHC3_WP = IOMUX_PAD(0x0454, 0x0164, 4, 0x084C, 2, 0), + MX6_PAD_I2C2_SCL__GPIO_3_14 = IOMUX_PAD(0x0454, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_I2C2_SCL__ECSPI1_RDY = IOMUX_PAD(0x0454, 0x0164, 6, 0x0680, 0, 0), + MX6_PAD_I2C2_SCL__PL301_SIM_MX6_PER1_HSIZE_2 = IOMUX_PAD(0x0454, 0x0164, 7, 0x0000, 0, 0), + MX6_PAD_I2C2_SDA__I2C2_SDA = IOMUX_PAD(0x0458, 0x0168, 16, 0x0728, 1, 0), + MX6_PAD_I2C2_SDA__AUDMUX_AUD4_RXC = IOMUX_PAD(0x0458, 0x0168, 1, 0x05EC, 0, 0), + MX6_PAD_I2C2_SDA__SPDIF_OUT1 = IOMUX_PAD(0x0458, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_I2C2_SDA__FEC_REF_OUT = IOMUX_PAD(0x0458, 0x0168, 3, 0x0000, 0, 0), + MX6_PAD_I2C2_SDA__USDHC3_CD = IOMUX_PAD(0x0458, 0x0168, 4, 0x0838, 2, 0), + MX6_PAD_I2C2_SDA__GPIO_3_15 = IOMUX_PAD(0x0458, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_I2C2_SDA__ANATOP_ANATOP_TESTO_0 = IOMUX_PAD(0x0458, 0x0168, 6, 0x0000, 0, 0), + MX6_PAD_I2C2_SDA__PL301_SIM_MX6_PER1_HWRITE = IOMUX_PAD(0x0458, 0x0168, 7, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x045C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0460, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x0464, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x0468, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x046C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TRSTB__SJC_TRSTB = IOMUX_PAD(0x0470, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x0474, 0x016C, 0, 0x0734, 0, 0), + MX6_PAD_KEY_COL0__I2C2_SCL = IOMUX_PAD(0x0474, 0x016C, 17, 0x0724, 2, 0), + MX6_PAD_KEY_COL0__LCDIF_DAT_0 = IOMUX_PAD(0x0474, 0x016C, 2, 0x0778, 0, 0), + MX6_PAD_KEY_COL0__WEIM_WEIM_DA_A_0 = IOMUX_PAD(0x0474, 0x016C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__USDHC1_CD = IOMUX_PAD(0x0474, 0x016C, 4, 0x0828, 2, 0), + MX6_PAD_KEY_COL0__GPIO_3_24 = IOMUX_PAD(0x0474, 0x016C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__MSHC_SCLK = IOMUX_PAD(0x0474, 0x016C, 6, 0x07E8, 0, 0), + MX6_PAD_KEY_COL0__TPSMP_HDATA_0 = IOMUX_PAD(0x0474, 0x016C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x0478, 0x0170, 0, 0x0738, 0, 0), + MX6_PAD_KEY_COL1__ECSPI4_MOSI = IOMUX_PAD(0x0478, 0x0170, 1, 0x06D8, 2, 0), + MX6_PAD_KEY_COL1__LCDIF_DAT_2 = IOMUX_PAD(0x0478, 0x0170, 2, 0x0780, 0, 0), + MX6_PAD_KEY_COL1__WEIM_WEIM_DA_A_2 = IOMUX_PAD(0x0478, 0x0170, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__USDHC3_DAT4 = IOMUX_PAD(0x0478, 0x0170, 4, 0x083C, 0, 0), + MX6_PAD_KEY_COL1__GPIO_3_26 = IOMUX_PAD(0x0478, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__MSHC_DATA_0 = IOMUX_PAD(0x0478, 0x0170, 6, 0x07D8, 0, 0), + MX6_PAD_KEY_COL1__TPSMP_HDATA_2 = IOMUX_PAD(0x0478, 0x0170, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x047C, 0x0174, 0, 0x073C, 0, 0), + MX6_PAD_KEY_COL2__ECSPI4_SS0 = IOMUX_PAD(0x047C, 0x0174, 1, 0x06DC, 2, 0), + MX6_PAD_KEY_COL2__LCDIF_DAT_4 = IOMUX_PAD(0x047C, 0x0174, 2, 0x0788, 0, 0), + MX6_PAD_KEY_COL2__WEIM_WEIM_DA_A_4 = IOMUX_PAD(0x047C, 0x0174, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USDHC3_DAT6 = IOMUX_PAD(0x047C, 0x0174, 4, 0x0844, 0, 0), + MX6_PAD_KEY_COL2__GPIO_3_28 = IOMUX_PAD(0x047C, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__MSHC_DATA_2 = IOMUX_PAD(0x047C, 0x0174, 6, 0x07E0, 0, 0), + MX6_PAD_KEY_COL2__TPSMP_HDATA_4 = IOMUX_PAD(0x047C, 0x0174, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x0480, 0x0178, 0, 0x0740, 0, 0), + MX6_PAD_KEY_COL3__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0480, 0x0178, 1, 0x0620, 1, 0), + MX6_PAD_KEY_COL3__LCDIF_DAT_6 = IOMUX_PAD(0x0480, 0x0178, 2, 0x0790, 0, 0), + MX6_PAD_KEY_COL3__WEIM_WEIM_DA_A_6 = IOMUX_PAD(0x0480, 0x0178, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__USDHC4_DAT6 = IOMUX_PAD(0x0480, 0x0178, 4, 0x0874, 1, 0), + MX6_PAD_KEY_COL3__GPIO_3_30 = IOMUX_PAD(0x0480, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__USDHC1_RST = IOMUX_PAD(0x0480, 0x0178, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__TPSMP_HDATA_6 = IOMUX_PAD(0x0480, 0x0178, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x0484, 0x017C, 0, 0x0744, 0, 0), + MX6_PAD_KEY_COL4__AUDMUX_AUD6_RXD = IOMUX_PAD(0x0484, 0x017C, 1, 0x0614, 1, 0), + MX6_PAD_KEY_COL4__LCDIF_DAT_8 = IOMUX_PAD(0x0484, 0x017C, 2, 0x0798, 0, 0), + MX6_PAD_KEY_COL4__WEIM_WEIM_DA_A_8 = IOMUX_PAD(0x0484, 0x017C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__USDHC4_CLK = IOMUX_PAD(0x0484, 0x017C, 4, 0x0850, 2, 0), + MX6_PAD_KEY_COL4__GPIO_4_0 = IOMUX_PAD(0x0484, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__USB_USBOTG1_PWR = IOMUX_PAD(0x0484, 0x017C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__TPSMP_HDATA_8 = IOMUX_PAD(0x0484, 0x017C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL5__KPP_COL_5 = IOMUX_PAD(0x0488, 0x0180, 0, 0x0748, 0, 0), + MX6_PAD_KEY_COL5__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x0488, 0x0180, 1, 0x0628, 1, 0), + MX6_PAD_KEY_COL5__LCDIF_DAT_10 = IOMUX_PAD(0x0488, 0x0180, 2, 0x07A0, 0, 0), + MX6_PAD_KEY_COL5__WEIM_WEIM_DA_A_10 = IOMUX_PAD(0x0488, 0x0180, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL5__USDHC4_DAT0 = IOMUX_PAD(0x0488, 0x0180, 4, 0x085C, 2, 0), + MX6_PAD_KEY_COL5__GPIO_4_2 = IOMUX_PAD(0x0488, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL5__USB_USBOTG2_PWR = IOMUX_PAD(0x0488, 0x0180, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL5__TPSMP_HDATA_10 = IOMUX_PAD(0x0488, 0x0180, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL6__KPP_COL_6 = IOMUX_PAD(0x048C, 0x0184, 0, 0x074C, 0, 0), + MX6_PAD_KEY_COL6__UART4_TXD = IOMUX_PAD(0x048C, 0x0184, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL6__UART4_RXD = IOMUX_PAD(0x048C, 0x0184, 1, 0x0814, 2, 0), + MX6_PAD_KEY_COL6__LCDIF_DAT_12 = IOMUX_PAD(0x048C, 0x0184, 2, 0x07A8, 0, 0), + MX6_PAD_KEY_COL6__WEIM_WEIM_DA_A_12 = IOMUX_PAD(0x048C, 0x0184, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL6__USDHC4_DAT2 = IOMUX_PAD(0x048C, 0x0184, 4, 0x0864, 2, 0), + MX6_PAD_KEY_COL6__GPIO_4_4 = IOMUX_PAD(0x048C, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL6__USDHC3_RST = IOMUX_PAD(0x048C, 0x0184, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL6__TPSMP_HDATA_12 = IOMUX_PAD(0x048C, 0x0184, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL7__KPP_COL_7 = IOMUX_PAD(0x0490, 0x0188, 0, 0x0750, 0, 0), + MX6_PAD_KEY_COL7__UART4_CTS = IOMUX_PAD(0x0490, 0x0188, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL7__UART4_RTS = IOMUX_PAD(0x0490, 0x0188, 1, 0x0810, 2, 0), + MX6_PAD_KEY_COL7__LCDIF_DAT_14 = IOMUX_PAD(0x0490, 0x0188, 2, 0x07B0, 0, 0), + MX6_PAD_KEY_COL7__WEIM_WEIM_DA_A_14 = IOMUX_PAD(0x0490, 0x0188, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL7__USDHC4_DAT4 = IOMUX_PAD(0x0490, 0x0188, 4, 0x086C, 1, 0), + MX6_PAD_KEY_COL7__GPIO_4_6 = IOMUX_PAD(0x0490, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL7__USDHC1_WP = IOMUX_PAD(0x0490, 0x0188, 6, 0x082C, 2, 0), + MX6_PAD_KEY_COL7__TPSMP_HDATA_14 = IOMUX_PAD(0x0490, 0x0188, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x0494, 0x018C, 0, 0x0754, 0, 0), + MX6_PAD_KEY_ROW0__I2C2_SDA = IOMUX_PAD(0x0494, 0x018C, 17, 0x0728, 2, 0), + MX6_PAD_KEY_ROW0__LCDIF_DAT_1 = IOMUX_PAD(0x0494, 0x018C, 2, 0x077C, 0, 0), + MX6_PAD_KEY_ROW0__WEIM_WEIM_DA_A_1 = IOMUX_PAD(0x0494, 0x018C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__USDHC1_WP = IOMUX_PAD(0x0494, 0x018C, 4, 0x082C, 3, 0), + MX6_PAD_KEY_ROW0__GPIO_3_25 = IOMUX_PAD(0x0494, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__MSHC_BS = IOMUX_PAD(0x0494, 0x018C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__TPSMP_HDATA_1 = IOMUX_PAD(0x0494, 0x018C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x0498, 0x0190, 0, 0x0758, 0, 0), + MX6_PAD_KEY_ROW1__ECSPI4_MISO = IOMUX_PAD(0x0498, 0x0190, 1, 0x06D4, 2, 0), + MX6_PAD_KEY_ROW1__LCDIF_DAT_3 = IOMUX_PAD(0x0498, 0x0190, 2, 0x0784, 0, 0), + MX6_PAD_KEY_ROW1__WEIM_WEIM_DA_A_3 = IOMUX_PAD(0x0498, 0x0190, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__USDHC3_DAT5 = IOMUX_PAD(0x0498, 0x0190, 4, 0x0840, 0, 0), + MX6_PAD_KEY_ROW1__GPIO_3_27 = IOMUX_PAD(0x0498, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__MSHC_DATA_1 = IOMUX_PAD(0x0498, 0x0190, 6, 0x07DC, 0, 0), + MX6_PAD_KEY_ROW1__TPSMP_HDATA_3 = IOMUX_PAD(0x0498, 0x0190, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x049C, 0x0194, 0, 0x075C, 0, 0), + MX6_PAD_KEY_ROW2__ECSPI4_SCLK = IOMUX_PAD(0x049C, 0x0194, 1, 0x06D0, 2, 0), + MX6_PAD_KEY_ROW2__LCDIF_DAT_5 = IOMUX_PAD(0x049C, 0x0194, 2, 0x078C, 0, 0), + MX6_PAD_KEY_ROW2__WEIM_WEIM_DA_A_5 = IOMUX_PAD(0x049C, 0x0194, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__USDHC3_DAT7 = IOMUX_PAD(0x049C, 0x0194, 4, 0x0848, 0, 0), + MX6_PAD_KEY_ROW2__GPIO_3_29 = IOMUX_PAD(0x049C, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__MSHC_DATA_3 = IOMUX_PAD(0x049C, 0x0194, 6, 0x07E4, 0, 0), + MX6_PAD_KEY_ROW2__TPSMP_HDATA_5 = IOMUX_PAD(0x049C, 0x0194, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x04A0, 0x0198, 0, 0x0760, 0, 0), + MX6_PAD_KEY_ROW3__AUDMUX_AUD6_RXC = IOMUX_PAD(0x04A0, 0x0198, 1, 0x061C, 1, 0), + MX6_PAD_KEY_ROW3__LCDIF_DAT_7 = IOMUX_PAD(0x04A0, 0x0198, 2, 0x0794, 0, 0), + MX6_PAD_KEY_ROW3__WEIM_WEIM_DA_A_7 = IOMUX_PAD(0x04A0, 0x0198, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__USDHC4_DAT7 = IOMUX_PAD(0x04A0, 0x0198, 4, 0x0878, 1, 0), + MX6_PAD_KEY_ROW3__GPIO_3_31 = IOMUX_PAD(0x04A0, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__USDHC1_VSELECT = IOMUX_PAD(0x04A0, 0x0198, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__TPSMP_HDATA_7 = IOMUX_PAD(0x04A0, 0x0198, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x04A4, 0x019C, 0, 0x0764, 0, 0), + MX6_PAD_KEY_ROW4__AUDMUX_AUD6_TXC = IOMUX_PAD(0x04A4, 0x019C, 1, 0x0624, 1, 0), + MX6_PAD_KEY_ROW4__LCDIF_DAT_9 = IOMUX_PAD(0x04A4, 0x019C, 2, 0x079C, 0, 0), + MX6_PAD_KEY_ROW4__WEIM_WEIM_DA_A_9 = IOMUX_PAD(0x04A4, 0x019C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USDHC4_CMD = IOMUX_PAD(0x04A4, 0x019C, 4, 0x0858, 2, 0), + MX6_PAD_KEY_ROW4__GPIO_4_1 = IOMUX_PAD(0x04A4, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USB_USBOTG1_OC = IOMUX_PAD(0x04A4, 0x019C, 6, 0x0824, 1, 0), + MX6_PAD_KEY_ROW4__TPSMP_HDATA_9 = IOMUX_PAD(0x04A4, 0x019C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW5__KPP_ROW_5 = IOMUX_PAD(0x04A8, 0x01A0, 0, 0x0768, 0, 0), + MX6_PAD_KEY_ROW5__AUDMUX_AUD6_TXD = IOMUX_PAD(0x04A8, 0x01A0, 1, 0x0618, 1, 0), + MX6_PAD_KEY_ROW5__LCDIF_DAT_11 = IOMUX_PAD(0x04A8, 0x01A0, 2, 0x07A4, 0, 0), + MX6_PAD_KEY_ROW5__WEIM_WEIM_DA_A_11 = IOMUX_PAD(0x04A8, 0x01A0, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW5__USDHC4_DAT1 = IOMUX_PAD(0x04A8, 0x01A0, 4, 0x0860, 2, 0), + MX6_PAD_KEY_ROW5__GPIO_4_3 = IOMUX_PAD(0x04A8, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW5__USB_USBOTG2_OC = IOMUX_PAD(0x04A8, 0x01A0, 6, 0x0820, 2, 0), + MX6_PAD_KEY_ROW5__TPSMP_HDATA_11 = IOMUX_PAD(0x04A8, 0x01A0, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW6__KPP_ROW_6 = IOMUX_PAD(0x04AC, 0x01A4, 0, 0x076C, 0, 0), + MX6_PAD_KEY_ROW6__UART4_TXD = IOMUX_PAD(0x04AC, 0x01A4, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW6__UART4_RXD = IOMUX_PAD(0x04AC, 0x01A4, 1, 0x0814, 3, 0), + MX6_PAD_KEY_ROW6__LCDIF_DAT_13 = IOMUX_PAD(0x04AC, 0x01A4, 2, 0x07AC, 0, 0), + MX6_PAD_KEY_ROW6__WEIM_WEIM_DA_A_13 = IOMUX_PAD(0x04AC, 0x01A4, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW6__USDHC4_DAT3 = IOMUX_PAD(0x04AC, 0x01A4, 4, 0x0868, 2, 0), + MX6_PAD_KEY_ROW6__GPIO_4_5 = IOMUX_PAD(0x04AC, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW6__USDHC3_VSELECT = IOMUX_PAD(0x04AC, 0x01A4, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW6__TPSMP_HDATA_13 = IOMUX_PAD(0x04AC, 0x01A4, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW7__KPP_ROW_7 = IOMUX_PAD(0x04B0, 0x01A8, 0, 0x0770, 0, 0), + MX6_PAD_KEY_ROW7__UART4_CTS = IOMUX_PAD(0x04B0, 0x01A8, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW7__UART4_RTS = IOMUX_PAD(0x04B0, 0x01A8, 1, 0x0810, 3, 0), + MX6_PAD_KEY_ROW7__LCDIF_DAT_15 = IOMUX_PAD(0x04B0, 0x01A8, 2, 0x07B4, 0, 0), + MX6_PAD_KEY_ROW7__WEIM_WEIM_DA_A_15 = IOMUX_PAD(0x04B0, 0x01A8, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW7__USDHC4_DAT5 = IOMUX_PAD(0x04B0, 0x01A8, 4, 0x0870, 1, 0), + MX6_PAD_KEY_ROW7__GPIO_4_7 = IOMUX_PAD(0x04B0, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW7__USDHC1_CD = IOMUX_PAD(0x04B0, 0x01A8, 6, 0x0828, 3, 0), + MX6_PAD_KEY_ROW7__TPSMP_HDATA_15 = IOMUX_PAD(0x04B0, 0x01A8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__LCDIF_CLK = IOMUX_PAD(0x04B4, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__USDHC4_DAT4 = IOMUX_PAD(0x04B4, 0x01AC, 1, 0x086C, 2, 0), + MX6_PAD_LCD_CLK__LCDIF_WR_RWN = IOMUX_PAD(0x04B4, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__WEIM_WEIM_RW = IOMUX_PAD(0x04B4, 0x01AC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__PWM4_PWMO = IOMUX_PAD(0x04B4, 0x01AC, 4, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__GPIO_2_15 = IOMUX_PAD(0x04B4, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__SRC_EARLY_RST = IOMUX_PAD(0x04B4, 0x01AC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_CLK__TPSMP_HTRANS_0 = IOMUX_PAD(0x04B4, 0x01AC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT0__LCDIF_DAT_0 = IOMUX_PAD(0x04B8, 0x01B0, 0, 0x0778, 1, 0), + MX6_PAD_LCD_DAT0__ECSPI1_MOSI = IOMUX_PAD(0x04B8, 0x01B0, 1, 0x0688, 1, 0), + MX6_PAD_LCD_DAT0__ANATOP_USBOTG2_ID = IOMUX_PAD(0x04B8, 0x01B0, 2, 0x05E0, 1, 0), + MX6_PAD_LCD_DAT0__PWM1_PWMO = IOMUX_PAD(0x04B8, 0x01B0, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT0__UART5_DTR = IOMUX_PAD(0x04B8, 0x01B0, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT0__GPIO_2_20 = IOMUX_PAD(0x04B8, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT0__KITTEN_TRACE_0 = IOMUX_PAD(0x04B8, 0x01B0, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT0__SRC_BT_CFG_0 = IOMUX_PAD(0x04B8, 0x01B0, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT1__LCDIF_DAT_1 = IOMUX_PAD(0x04BC, 0x01B4, 0, 0x077C, 1, 0), + MX6_PAD_LCD_DAT1__ECSPI1_MISO = IOMUX_PAD(0x04BC, 0x01B4, 1, 0x0684, 1, 0), + MX6_PAD_LCD_DAT1__ANATOP_USBOTG1_ID = IOMUX_PAD(0x04BC, 0x01B4, 2, 0x05DC, 2, 0), + MX6_PAD_LCD_DAT1__PWM2_PWMO = IOMUX_PAD(0x04BC, 0x01B4, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT1__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x04BC, 0x01B4, 4, 0x05F0, 1, 0), + MX6_PAD_LCD_DAT1__GPIO_2_21 = IOMUX_PAD(0x04BC, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT1__KITTEN_TRACE_1 = IOMUX_PAD(0x04BC, 0x01B4, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT1__SRC_BT_CFG_1 = IOMUX_PAD(0x04BC, 0x01B4, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT10__LCDIF_DAT_10 = IOMUX_PAD(0x04C0, 0x01B8, 0, 0x07A0, 1, 0), + MX6_PAD_LCD_DAT10__KPP_COL_1 = IOMUX_PAD(0x04C0, 0x01B8, 1, 0x0738, 1, 0), + MX6_PAD_LCD_DAT10__CSI_D_7 = IOMUX_PAD(0x04C0, 0x01B8, 2, 0x064C, 1, 0), + MX6_PAD_LCD_DAT10__WEIM_WEIM_D_4 = IOMUX_PAD(0x04C0, 0x01B8, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT10__ECSPI2_MISO = IOMUX_PAD(0x04C0, 0x01B8, 4, 0x06A0, 2, 0), + MX6_PAD_LCD_DAT10__GPIO_2_30 = IOMUX_PAD(0x04C0, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT10__KITTEN_TRACE_10 = IOMUX_PAD(0x04C0, 0x01B8, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT10__SRC_BT_CFG_10 = IOMUX_PAD(0x04C0, 0x01B8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT11__LCDIF_DAT_11 = IOMUX_PAD(0x04C4, 0x01BC, 0, 0x07A4, 1, 0), + MX6_PAD_LCD_DAT11__KPP_ROW_1 = IOMUX_PAD(0x04C4, 0x01BC, 1, 0x0758, 1, 0), + MX6_PAD_LCD_DAT11__CSI_D_6 = IOMUX_PAD(0x04C4, 0x01BC, 2, 0x0648, 1, 0), + MX6_PAD_LCD_DAT11__WEIM_WEIM_D_5 = IOMUX_PAD(0x04C4, 0x01BC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT11__ECSPI2_SS1 = IOMUX_PAD(0x04C4, 0x01BC, 4, 0x06AC, 1, 0), + MX6_PAD_LCD_DAT11__GPIO_2_31 = IOMUX_PAD(0x04C4, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT11__KITTEN_TRACE_11 = IOMUX_PAD(0x04C4, 0x01BC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT11__SRC_BT_CFG_11 = IOMUX_PAD(0x04C4, 0x01BC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT12__LCDIF_DAT_12 = IOMUX_PAD(0x04C8, 0x01C0, 0, 0x07A8, 1, 0), + MX6_PAD_LCD_DAT12__KPP_COL_2 = IOMUX_PAD(0x04C8, 0x01C0, 1, 0x073C, 1, 0), + MX6_PAD_LCD_DAT12__CSI_D_5 = IOMUX_PAD(0x04C8, 0x01C0, 2, 0x0644, 1, 0), + MX6_PAD_LCD_DAT12__WEIM_WEIM_D_6 = IOMUX_PAD(0x04C8, 0x01C0, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT12__UART5_CTS = IOMUX_PAD(0x04C8, 0x01C0, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT12__UART5_RTS = IOMUX_PAD(0x04C8, 0x01C0, 4, 0x0818, 2, 0), + MX6_PAD_LCD_DAT12__GPIO_3_0 = IOMUX_PAD(0x04C8, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT12__KITTEN_TRACE_12 = IOMUX_PAD(0x04C8, 0x01C0, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT12__SRC_BT_CFG_12 = IOMUX_PAD(0x04C8, 0x01C0, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT13__LCDIF_DAT_13 = IOMUX_PAD(0x04CC, 0x01C4, 0, 0x07AC, 1, 0), + MX6_PAD_LCD_DAT13__KPP_ROW_2 = IOMUX_PAD(0x04CC, 0x01C4, 1, 0x075C, 1, 0), + MX6_PAD_LCD_DAT13__CSI_D_4 = IOMUX_PAD(0x04CC, 0x01C4, 2, 0x0640, 1, 0), + MX6_PAD_LCD_DAT13__WEIM_WEIM_D_7 = IOMUX_PAD(0x04CC, 0x01C4, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT13__UART5_CTS = IOMUX_PAD(0x04CC, 0x01C4, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT13__UART5_RTS = IOMUX_PAD(0x04CC, 0x01C4, 4, 0x0818, 3, 0), + MX6_PAD_LCD_DAT13__GPIO_3_1 = IOMUX_PAD(0x04CC, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT13__KITTEN_TRACE_13 = IOMUX_PAD(0x04CC, 0x01C4, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT13__SRC_BT_CFG_13 = IOMUX_PAD(0x04CC, 0x01C4, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT14__LCDIF_DAT_14 = IOMUX_PAD(0x04D0, 0x01C8, 0, 0x07B0, 1, 0), + MX6_PAD_LCD_DAT14__KPP_COL_3 = IOMUX_PAD(0x04D0, 0x01C8, 1, 0x0740, 1, 0), + MX6_PAD_LCD_DAT14__CSI_D_3 = IOMUX_PAD(0x04D0, 0x01C8, 2, 0x063C, 1, 0), + MX6_PAD_LCD_DAT14__WEIM_WEIM_D_8 = IOMUX_PAD(0x04D0, 0x01C8, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT14__UART5_TXD = IOMUX_PAD(0x04D0, 0x01C8, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT14__UART5_RXD = IOMUX_PAD(0x04D0, 0x01C8, 4, 0x081C, 2, 0), + MX6_PAD_LCD_DAT14__GPIO_3_2 = IOMUX_PAD(0x04D0, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT14__KITTEN_TRACE_14 = IOMUX_PAD(0x04D0, 0x01C8, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT14__SRC_BT_CFG_14 = IOMUX_PAD(0x04D0, 0x01C8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT15__LCDIF_DAT_15 = IOMUX_PAD(0x04D4, 0x01CC, 0, 0x07B4, 1, 0), + MX6_PAD_LCD_DAT15__KPP_ROW_3 = IOMUX_PAD(0x04D4, 0x01CC, 1, 0x0760, 1, 0), + MX6_PAD_LCD_DAT15__CSI_D_2 = IOMUX_PAD(0x04D4, 0x01CC, 2, 0x0638, 1, 0), + MX6_PAD_LCD_DAT15__WEIM_WEIM_D_9 = IOMUX_PAD(0x04D4, 0x01CC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT15__UART5_TXD = IOMUX_PAD(0x04D4, 0x01CC, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT15__UART5_RXD = IOMUX_PAD(0x04D4, 0x01CC, 4, 0x081C, 3, 0), + MX6_PAD_LCD_DAT15__GPIO_3_3 = IOMUX_PAD(0x04D4, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT15__KITTEN_TRACE_15 = IOMUX_PAD(0x04D4, 0x01CC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT15__SRC_BT_CFG_15 = IOMUX_PAD(0x04D4, 0x01CC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT16__LCDIF_DAT_16 = IOMUX_PAD(0x04D8, 0x01D0, 0, 0x07B8, 1, 0), + MX6_PAD_LCD_DAT16__KPP_COL_4 = IOMUX_PAD(0x04D8, 0x01D0, 1, 0x0744, 1, 0), + MX6_PAD_LCD_DAT16__CSI_D_1 = IOMUX_PAD(0x04D8, 0x01D0, 2, 0x0634, 1, 0), + MX6_PAD_LCD_DAT16__WEIM_WEIM_D_10 = IOMUX_PAD(0x04D8, 0x01D0, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT16__I2C2_SCL = IOMUX_PAD(0x04D8, 0x01D0, 20, 0x0724, 3, 0), + MX6_PAD_LCD_DAT16__GPIO_3_4 = IOMUX_PAD(0x04D8, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT16__KITTEN_TRACE_16 = IOMUX_PAD(0x04D8, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT16__SRC_BT_CFG_24 = IOMUX_PAD(0x04D8, 0x01D0, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT17__LCDIF_DAT_17 = IOMUX_PAD(0x04DC, 0x01D4, 0, 0x07BC, 1, 0), + MX6_PAD_LCD_DAT17__KPP_ROW_4 = IOMUX_PAD(0x04DC, 0x01D4, 1, 0x0764, 1, 0), + MX6_PAD_LCD_DAT17__CSI_D_0 = IOMUX_PAD(0x04DC, 0x01D4, 2, 0x0630, 1, 0), + MX6_PAD_LCD_DAT17__WEIM_WEIM_D_11 = IOMUX_PAD(0x04DC, 0x01D4, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT17__I2C2_SDA = IOMUX_PAD(0x04DC, 0x01D4, 20, 0x0728, 3, 0), + MX6_PAD_LCD_DAT17__GPIO_3_5 = IOMUX_PAD(0x04DC, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT17__KITTEN_TRACE_17 = IOMUX_PAD(0x04DC, 0x01D4, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT17__SRC_BT_CFG_25 = IOMUX_PAD(0x04DC, 0x01D4, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT18__LCDIF_DAT_18 = IOMUX_PAD(0x04E0, 0x01D8, 0, 0x07C0, 1, 0), + MX6_PAD_LCD_DAT18__KPP_COL_5 = IOMUX_PAD(0x04E0, 0x01D8, 1, 0x0748, 1, 0), + MX6_PAD_LCD_DAT18__CSI_D_15 = IOMUX_PAD(0x04E0, 0x01D8, 2, 0x066C, 0, 0), + MX6_PAD_LCD_DAT18__WEIM_WEIM_D_12 = IOMUX_PAD(0x04E0, 0x01D8, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT18__GPT_CAPIN1 = IOMUX_PAD(0x04E0, 0x01D8, 4, 0x0710, 1, 0), + MX6_PAD_LCD_DAT18__GPIO_3_6 = IOMUX_PAD(0x04E0, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT18__KITTEN_TRACE_18 = IOMUX_PAD(0x04E0, 0x01D8, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT18__SRC_BT_CFG_26 = IOMUX_PAD(0x04E0, 0x01D8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT19__LCDIF_DAT_19 = IOMUX_PAD(0x04E4, 0x01DC, 0, 0x07C4, 1, 0), + MX6_PAD_LCD_DAT19__KPP_ROW_5 = IOMUX_PAD(0x04E4, 0x01DC, 1, 0x0768, 1, 0), + MX6_PAD_LCD_DAT19__CSI_D_14 = IOMUX_PAD(0x04E4, 0x01DC, 2, 0x0668, 0, 0), + MX6_PAD_LCD_DAT19__WEIM_WEIM_D_13 = IOMUX_PAD(0x04E4, 0x01DC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT19__GPT_CAPIN2 = IOMUX_PAD(0x04E4, 0x01DC, 4, 0x0714, 1, 0), + MX6_PAD_LCD_DAT19__GPIO_3_7 = IOMUX_PAD(0x04E4, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT19__KITTEN_TRACE_19 = IOMUX_PAD(0x04E4, 0x01DC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT19__SRC_BT_CFG_27 = IOMUX_PAD(0x04E4, 0x01DC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT2__LCDIF_DAT_2 = IOMUX_PAD(0x04E8, 0x01E0, 0, 0x0780, 1, 0), + MX6_PAD_LCD_DAT2__ECSPI1_SS0 = IOMUX_PAD(0x04E8, 0x01E0, 1, 0x068C, 1, 0), + MX6_PAD_LCD_DAT2__EPIT2_EPITO = IOMUX_PAD(0x04E8, 0x01E0, 2, 0x0000, 0, 0), + MX6_PAD_LCD_DAT2__PWM3_PWMO = IOMUX_PAD(0x04E8, 0x01E0, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT2__AUDMUX_AUD4_RXC = IOMUX_PAD(0x04E8, 0x01E0, 4, 0x05EC, 1, 0), + MX6_PAD_LCD_DAT2__GPIO_2_22 = IOMUX_PAD(0x04E8, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT2__KITTEN_TRACE_2 = IOMUX_PAD(0x04E8, 0x01E0, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT2__SRC_BT_CFG_2 = IOMUX_PAD(0x04E8, 0x01E0, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT20__LCDIF_DAT_20 = IOMUX_PAD(0x04EC, 0x01E4, 0, 0x07C8, 1, 0), + MX6_PAD_LCD_DAT20__KPP_COL_6 = IOMUX_PAD(0x04EC, 0x01E4, 1, 0x074C, 1, 0), + MX6_PAD_LCD_DAT20__CSI_D_13 = IOMUX_PAD(0x04EC, 0x01E4, 2, 0x0664, 0, 0), + MX6_PAD_LCD_DAT20__WEIM_WEIM_D_14 = IOMUX_PAD(0x04EC, 0x01E4, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT20__GPT_CMPOUT1 = IOMUX_PAD(0x04EC, 0x01E4, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT20__GPIO_3_8 = IOMUX_PAD(0x04EC, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT20__KITTEN_TRACE_20 = IOMUX_PAD(0x04EC, 0x01E4, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT20__SRC_BT_CFG_28 = IOMUX_PAD(0x04EC, 0x01E4, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT21__LCDIF_DAT_21 = IOMUX_PAD(0x04F0, 0x01E8, 0, 0x07CC, 1, 0), + MX6_PAD_LCD_DAT21__KPP_ROW_6 = IOMUX_PAD(0x04F0, 0x01E8, 1, 0x076C, 1, 0), + MX6_PAD_LCD_DAT21__CSI_D_12 = IOMUX_PAD(0x04F0, 0x01E8, 2, 0x0660, 0, 0), + MX6_PAD_LCD_DAT21__WEIM_WEIM_D_15 = IOMUX_PAD(0x04F0, 0x01E8, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT21__GPT_CMPOUT2 = IOMUX_PAD(0x04F0, 0x01E8, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT21__GPIO_3_9 = IOMUX_PAD(0x04F0, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT21__KITTEN_TRACE_21 = IOMUX_PAD(0x04F0, 0x01E8, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT21__SRC_BT_CFG_29 = IOMUX_PAD(0x04F0, 0x01E8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT22__LCDIF_DAT_22 = IOMUX_PAD(0x04F4, 0x01EC, 0, 0x07D0, 1, 0), + MX6_PAD_LCD_DAT22__KPP_COL_7 = IOMUX_PAD(0x04F4, 0x01EC, 1, 0x0750, 1, 0), + MX6_PAD_LCD_DAT22__CSI_D_11 = IOMUX_PAD(0x04F4, 0x01EC, 2, 0x065C, 1, 0), + MX6_PAD_LCD_DAT22__WEIM_WEIM_EB_3 = IOMUX_PAD(0x04F4, 0x01EC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT22__GPT_CMPOUT3 = IOMUX_PAD(0x04F4, 0x01EC, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT22__GPIO_3_10 = IOMUX_PAD(0x04F4, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT22__KITTEN_TRACE_22 = IOMUX_PAD(0x04F4, 0x01EC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT22__SRC_BT_CFG_30 = IOMUX_PAD(0x04F4, 0x01EC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT23__LCDIF_DAT_23 = IOMUX_PAD(0x04F8, 0x01F0, 0, 0x07D4, 1, 0), + MX6_PAD_LCD_DAT23__KPP_ROW_7 = IOMUX_PAD(0x04F8, 0x01F0, 1, 0x0770, 1, 0), + MX6_PAD_LCD_DAT23__CSI_D_10 = IOMUX_PAD(0x04F8, 0x01F0, 2, 0x0658, 1, 0), + MX6_PAD_LCD_DAT23__WEIM_WEIM_EB_2 = IOMUX_PAD(0x04F8, 0x01F0, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT23__GPT_CLKIN = IOMUX_PAD(0x04F8, 0x01F0, 4, 0x0718, 1, 0), + MX6_PAD_LCD_DAT23__GPIO_3_11 = IOMUX_PAD(0x04F8, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT23__KITTEN_TRACE_23 = IOMUX_PAD(0x04F8, 0x01F0, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT23__SRC_BT_CFG_31 = IOMUX_PAD(0x04F8, 0x01F0, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT3__LCDIF_DAT_3 = IOMUX_PAD(0x04FC, 0x01F4, 0, 0x0784, 1, 0), + MX6_PAD_LCD_DAT3__ECSPI1_SCLK = IOMUX_PAD(0x04FC, 0x01F4, 1, 0x067C, 1, 0), + MX6_PAD_LCD_DAT3__UART5_DSR = IOMUX_PAD(0x04FC, 0x01F4, 2, 0x0000, 0, 0), + MX6_PAD_LCD_DAT3__PWM4_PWMO = IOMUX_PAD(0x04FC, 0x01F4, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT3__AUDMUX_AUD4_RXD = IOMUX_PAD(0x04FC, 0x01F4, 4, 0x05E4, 1, 0), + MX6_PAD_LCD_DAT3__GPIO_2_23 = IOMUX_PAD(0x04FC, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT3__KITTEN_TRACE_3 = IOMUX_PAD(0x04FC, 0x01F4, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT3__SRC_BT_CFG_3 = IOMUX_PAD(0x04FC, 0x01F4, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT4__LCDIF_DAT_4 = IOMUX_PAD(0x0500, 0x01F8, 0, 0x0788, 1, 0), + MX6_PAD_LCD_DAT4__ECSPI1_SS1 = IOMUX_PAD(0x0500, 0x01F8, 1, 0x0690, 1, 0), + MX6_PAD_LCD_DAT4__CSI_VSYNC = IOMUX_PAD(0x0500, 0x01F8, 2, 0x0678, 2, 0), + MX6_PAD_LCD_DAT4__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x0500, 0x01F8, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT4__AUDMUX_AUD4_TXC = IOMUX_PAD(0x0500, 0x01F8, 4, 0x05F4, 1, 0), + MX6_PAD_LCD_DAT4__GPIO_2_24 = IOMUX_PAD(0x0500, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT4__KITTEN_TRACE_4 = IOMUX_PAD(0x0500, 0x01F8, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT4__SRC_BT_CFG_4 = IOMUX_PAD(0x0500, 0x01F8, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT5__LCDIF_DAT_5 = IOMUX_PAD(0x0504, 0x01FC, 0, 0x078C, 1, 0), + MX6_PAD_LCD_DAT5__ECSPI1_SS2 = IOMUX_PAD(0x0504, 0x01FC, 1, 0x0694, 1, 0), + MX6_PAD_LCD_DAT5__CSI_HSYNC = IOMUX_PAD(0x0504, 0x01FC, 2, 0x0670, 2, 0), + MX6_PAD_LCD_DAT5__WEIM_WEIM_CS_3 = IOMUX_PAD(0x0504, 0x01FC, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT5__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x0504, 0x01FC, 4, 0x05F8, 1, 0), + MX6_PAD_LCD_DAT5__GPIO_2_25 = IOMUX_PAD(0x0504, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT5__KITTEN_TRACE_5 = IOMUX_PAD(0x0504, 0x01FC, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT5__SRC_BT_CFG_5 = IOMUX_PAD(0x0504, 0x01FC, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT6__LCDIF_DAT_6 = IOMUX_PAD(0x0508, 0x0200, 0, 0x0790, 1, 0), + MX6_PAD_LCD_DAT6__ECSPI1_SS3 = IOMUX_PAD(0x0508, 0x0200, 1, 0x0698, 1, 0), + MX6_PAD_LCD_DAT6__CSI_PIXCLK = IOMUX_PAD(0x0508, 0x0200, 2, 0x0674, 2, 0), + MX6_PAD_LCD_DAT6__WEIM_WEIM_D_0 = IOMUX_PAD(0x0508, 0x0200, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT6__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0508, 0x0200, 4, 0x05E8, 1, 0), + MX6_PAD_LCD_DAT6__GPIO_2_26 = IOMUX_PAD(0x0508, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT6__KITTEN_TRACE_6 = IOMUX_PAD(0x0508, 0x0200, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT6__SRC_BT_CFG_6 = IOMUX_PAD(0x0508, 0x0200, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__LCDIF_DAT_7 = IOMUX_PAD(0x050C, 0x0204, 0, 0x0794, 1, 0), + MX6_PAD_LCD_DAT7__ECSPI1_RDY = IOMUX_PAD(0x050C, 0x0204, 1, 0x0680, 1, 0), + MX6_PAD_LCD_DAT7__CSI_MCLK = IOMUX_PAD(0x050C, 0x0204, 2, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__WEIM_WEIM_D_1 = IOMUX_PAD(0x050C, 0x0204, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__AUDMUX_AUDIO_CLK_OUT = IOMUX_PAD(0x050C, 0x0204, 4, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__GPIO_2_27 = IOMUX_PAD(0x050C, 0x0204, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__KITTEN_TRACE_7 = IOMUX_PAD(0x050C, 0x0204, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT7__SRC_BT_CFG_7 = IOMUX_PAD(0x050C, 0x0204, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT8__LCDIF_DAT_8 = IOMUX_PAD(0x0510, 0x0208, 0, 0x0798, 1, 0), + MX6_PAD_LCD_DAT8__KPP_COL_0 = IOMUX_PAD(0x0510, 0x0208, 1, 0x0734, 1, 0), + MX6_PAD_LCD_DAT8__CSI_D_9 = IOMUX_PAD(0x0510, 0x0208, 2, 0x0654, 1, 0), + MX6_PAD_LCD_DAT8__WEIM_WEIM_D_2 = IOMUX_PAD(0x0510, 0x0208, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0510, 0x0208, 4, 0x069C, 2, 0), + MX6_PAD_LCD_DAT8__GPIO_2_28 = IOMUX_PAD(0x0510, 0x0208, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT8__KITTEN_TRACE_8 = IOMUX_PAD(0x0510, 0x0208, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT8__SRC_BT_CFG_8 = IOMUX_PAD(0x0510, 0x0208, 7, 0x0000, 0, 0), + MX6_PAD_LCD_DAT9__LCDIF_DAT_9 = IOMUX_PAD(0x0514, 0x020C, 0, 0x079C, 1, 0), + MX6_PAD_LCD_DAT9__KPP_ROW_0 = IOMUX_PAD(0x0514, 0x020C, 1, 0x0754, 1, 0), + MX6_PAD_LCD_DAT9__CSI_D_8 = IOMUX_PAD(0x0514, 0x020C, 2, 0x0650, 1, 0), + MX6_PAD_LCD_DAT9__WEIM_WEIM_D_3 = IOMUX_PAD(0x0514, 0x020C, 3, 0x0000, 0, 0), + MX6_PAD_LCD_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x0514, 0x020C, 4, 0x06A4, 2, 0), + MX6_PAD_LCD_DAT9__GPIO_2_29 = IOMUX_PAD(0x0514, 0x020C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_DAT9__KITTEN_TRACE_9 = IOMUX_PAD(0x0514, 0x020C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_DAT9__SRC_BT_CFG_9 = IOMUX_PAD(0x0514, 0x020C, 7, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__LCDIF_ENABLE = IOMUX_PAD(0x0518, 0x0210, 0, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__USDHC4_DAT5 = IOMUX_PAD(0x0518, 0x0210, 1, 0x0870, 2, 0), + MX6_PAD_LCD_ENABLE__LCDIF_RD_E = IOMUX_PAD(0x0518, 0x0210, 2, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__WEIM_WEIM_OE = IOMUX_PAD(0x0518, 0x0210, 3, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__UART2_TXD = IOMUX_PAD(0x0518, 0x0210, 4, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__UART2_RXD = IOMUX_PAD(0x0518, 0x0210, 4, 0x0804, 2, 0), + MX6_PAD_LCD_ENABLE__GPIO_2_16 = IOMUX_PAD(0x0518, 0x0210, 5, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x0518, 0x0210, 6, 0x0000, 0, 0), + MX6_PAD_LCD_ENABLE__TPSMP_HTRANS_1 = IOMUX_PAD(0x0518, 0x0210, 7, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__LCDIF_HSYNC = IOMUX_PAD(0x051C, 0x0214, 0, 0x0774, 0, 0), + MX6_PAD_LCD_HSYNC__USDHC4_DAT6 = IOMUX_PAD(0x051C, 0x0214, 1, 0x0874, 2, 0), + MX6_PAD_LCD_HSYNC__LCDIF_CS = IOMUX_PAD(0x051C, 0x0214, 2, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__WEIM_WEIM_CS_0 = IOMUX_PAD(0x051C, 0x0214, 3, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__UART2_TXD = IOMUX_PAD(0x051C, 0x0214, 4, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__UART2_RXD = IOMUX_PAD(0x051C, 0x0214, 4, 0x0804, 3, 0), + MX6_PAD_LCD_HSYNC__GPIO_2_17 = IOMUX_PAD(0x051C, 0x0214, 5, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__KITTEN_TRCLK = IOMUX_PAD(0x051C, 0x0214, 6, 0x0000, 0, 0), + MX6_PAD_LCD_HSYNC__TPSMP_HDATA_16 = IOMUX_PAD(0x051C, 0x0214, 7, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__LCDIF_RESET = IOMUX_PAD(0x0520, 0x0218, 0, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__WEIM_WEIM_DTACK_B = IOMUX_PAD(0x0520, 0x0218, 1, 0x0880, 1, 0), + MX6_PAD_LCD_RESET__LCDIF_BUSY = IOMUX_PAD(0x0520, 0x0218, 2, 0x0774, 1, 0), + MX6_PAD_LCD_RESET__WEIM_WEIM_WAIT = IOMUX_PAD(0x0520, 0x0218, 3, 0x0884, 1, 0), + MX6_PAD_LCD_RESET__UART2_CTS = IOMUX_PAD(0x0520, 0x0218, 4, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__UART2_RTS = IOMUX_PAD(0x0520, 0x0218, 4, 0x0800, 2, 0), + MX6_PAD_LCD_RESET__GPIO_2_19 = IOMUX_PAD(0x0520, 0x0218, 5, 0x0000, 0, 0), + MX6_PAD_LCD_RESET__CCM_PMIC_RDY = IOMUX_PAD(0x0520, 0x0218, 6, 0x062C, 1, 0), + MX6_PAD_LCD_RESET__TPSMP_HDATA_DIR = IOMUX_PAD(0x0520, 0x0218, 7, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__LCDIF_VSYNC = IOMUX_PAD(0x0524, 0x021C, 0, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__USDHC4_DAT7 = IOMUX_PAD(0x0524, 0x021C, 1, 0x0878, 2, 0), + MX6_PAD_LCD_VSYNC__LCDIF_RS = IOMUX_PAD(0x0524, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__WEIM_WEIM_CS_1 = IOMUX_PAD(0x0524, 0x021C, 3, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__UART2_CTS = IOMUX_PAD(0x0524, 0x021C, 4, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__UART2_RTS = IOMUX_PAD(0x0524, 0x021C, 4, 0x0800, 3, 0), + MX6_PAD_LCD_VSYNC__GPIO_2_18 = IOMUX_PAD(0x0524, 0x021C, 5, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__KITTEN_TRCTL = IOMUX_PAD(0x0524, 0x021C, 6, 0x0000, 0, 0), + MX6_PAD_LCD_VSYNC__TPSMP_HDATA_17 = IOMUX_PAD(0x0524, 0x021C, 7, 0x0000, 0, 0), + MX6_PAD_PMIC_ON_REQ__SNVS_LP_WRAPPER_SNVS_WAKEUP_ALARM = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_PMIC_STBY_REQ__CCM_PMIC_VSTBY_REQ = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_POR_B__SRC_POR_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_PWM1__PWM1_PWMO = IOMUX_PAD(0x0528, 0x0220, 0, 0x0000, 0, 0), + MX6_PAD_PWM1__CCM_CLKO = IOMUX_PAD(0x0528, 0x0220, 1, 0x0000, 0, 0), + MX6_PAD_PWM1__AUDMUX_AUDIO_CLK_OUT = IOMUX_PAD(0x0528, 0x0220, 2, 0x0000, 0, 0), + MX6_PAD_PWM1__FEC_REF_OUT = IOMUX_PAD(0x0528, 0x0220, 3, 0x0000, 0, 0), + MX6_PAD_PWM1__CSI_MCLK = IOMUX_PAD(0x0528, 0x0220, 4, 0x0000, 0, 0), + MX6_PAD_PWM1__GPIO_3_23 = IOMUX_PAD(0x0528, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_PWM1__EPIT1_EPITO = IOMUX_PAD(0x0528, 0x0220, 6, 0x0000, 0, 0), + MX6_PAD_PWM1__OBSERVE_MUX_OUT_4 = IOMUX_PAD(0x0528, 0x0220, 7, 0x0000, 0, 0), + MX6_PAD_REF_CLK_24M__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x052C, 0x0224, 0, 0x0000, 0, 0), + MX6_PAD_REF_CLK_24M__I2C3_SCL = IOMUX_PAD(0x052C, 0x0224, 17, 0x072C, 2, 0), + MX6_PAD_REF_CLK_24M__PWM3_PWMO = IOMUX_PAD(0x052C, 0x0224, 2, 0x0000, 0, 0), + MX6_PAD_REF_CLK_24M__ANATOP_USBOTG2_ID = IOMUX_PAD(0x052C, 0x0224, 3, 0x05E0, 2, 0), + MX6_PAD_REF_CLK_24M__CCM_PMIC_RDY = IOMUX_PAD(0x052C, 0x0224, 4, 0x062C, 2, 0), + MX6_PAD_REF_CLK_24M__GPIO_3_21 = IOMUX_PAD(0x052C, 0x0224, 5, 0x0000, 0, 0), + MX6_PAD_REF_CLK_24M__USDHC3_WP = IOMUX_PAD(0x052C, 0x0224, 6, 0x084C, 3, 0), + MX6_PAD_REF_CLK_24M__TPSMP_HDATA_19 = IOMUX_PAD(0x052C, 0x0224, 7, 0x0000, 0, 0), + MX6_PAD_REF_CLK_32K__ANATOP_ANATOP_32K_OUT = IOMUX_PAD(0x0530, 0x0228, 0, 0x0000, 0, 0), + MX6_PAD_REF_CLK_32K__I2C3_SDA = IOMUX_PAD(0x0530, 0x0228, 17, 0x0730, 2, 0), + MX6_PAD_REF_CLK_32K__PWM4_PWMO = IOMUX_PAD(0x0530, 0x0228, 2, 0x0000, 0, 0), + MX6_PAD_REF_CLK_32K__ANATOP_USBOTG1_ID = IOMUX_PAD(0x0530, 0x0228, 3, 0x05DC, 3, 0), + MX6_PAD_REF_CLK_32K__USDHC1_LCTL = IOMUX_PAD(0x0530, 0x0228, 4, 0x0000, 0, 0), + MX6_PAD_REF_CLK_32K__GPIO_3_22 = IOMUX_PAD(0x0530, 0x0228, 5, 0x0000, 0, 0), + MX6_PAD_REF_CLK_32K__USDHC3_CD = IOMUX_PAD(0x0530, 0x0228, 6, 0x0838, 3, 0), + MX6_PAD_REF_CLK_32K__OBSERVE_MUX_OUT_3 = IOMUX_PAD(0x0530, 0x0228, 7, 0x0000, 0, 0), + MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x0534, 0x022C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__FEC_MDIO = IOMUX_PAD(0x0534, 0x022C, 1, 0x06F4, 2, 0), + MX6_PAD_SD1_CLK__KPP_COL_0 = IOMUX_PAD(0x0534, 0x022C, 2, 0x0734, 2, 0), + MX6_PAD_SD1_CLK__EPDC_SDCE_4 = IOMUX_PAD(0x0534, 0x022C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__MSHC_SCLK = IOMUX_PAD(0x0534, 0x022C, 4, 0x07E8, 1, 0), + MX6_PAD_SD1_CLK__GPIO_5_15 = IOMUX_PAD(0x0534, 0x022C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__ANATOP_ANATOP_TESTO_2 = IOMUX_PAD(0x0534, 0x022C, 6, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__PL301_SIM_MX6_PER1_HADDR_25 = IOMUX_PAD(0x0534, 0x022C, 7, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x0538, 0x0230, 0, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__FEC_TX_CLK = IOMUX_PAD(0x0538, 0x0230, 1, 0x070C, 2, 0), + MX6_PAD_SD1_CMD__KPP_ROW_0 = IOMUX_PAD(0x0538, 0x0230, 2, 0x0754, 2, 0), + MX6_PAD_SD1_CMD__EPDC_SDCE_5 = IOMUX_PAD(0x0538, 0x0230, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__MSHC_BS = IOMUX_PAD(0x0538, 0x0230, 4, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPIO_5_14 = IOMUX_PAD(0x0538, 0x0230, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__ANATOP_ANATOP_TESTO_3 = IOMUX_PAD(0x0538, 0x0230, 6, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__PL301_SIM_MX6_PER1_HADDR_26 = IOMUX_PAD(0x0538, 0x0230, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__USDHC1_DAT0 = IOMUX_PAD(0x053C, 0x0234, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__FEC_RX_ER = IOMUX_PAD(0x053C, 0x0234, 1, 0x0708, 2, 0), + MX6_PAD_SD1_DAT0__KPP_COL_1 = IOMUX_PAD(0x053C, 0x0234, 2, 0x0738, 2, 0), + MX6_PAD_SD1_DAT0__EPDC_SDCE_6 = IOMUX_PAD(0x053C, 0x0234, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__MSHC_DATA_0 = IOMUX_PAD(0x053C, 0x0234, 4, 0x07D8, 1, 0), + MX6_PAD_SD1_DAT0__GPIO_5_11 = IOMUX_PAD(0x053C, 0x0234, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__ANATOP_ANATOP_TESTO_4 = IOMUX_PAD(0x053C, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__PL301_SIM_MX6_PER1_HADDR_27 = IOMUX_PAD(0x053C, 0x0234, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__USDHC1_DAT1 = IOMUX_PAD(0x0540, 0x0238, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__FEC_RX_DV = IOMUX_PAD(0x0540, 0x0238, 1, 0x0704, 2, 0), + MX6_PAD_SD1_DAT1__KPP_ROW_1 = IOMUX_PAD(0x0540, 0x0238, 2, 0x0758, 2, 0), + MX6_PAD_SD1_DAT1__EPDC_SDCE_7 = IOMUX_PAD(0x0540, 0x0238, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__MSHC_DATA_1 = IOMUX_PAD(0x0540, 0x0238, 4, 0x07DC, 1, 0), + MX6_PAD_SD1_DAT1__GPIO_5_8 = IOMUX_PAD(0x0540, 0x0238, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__ANATOP_ANATOP_TESTO_5 = IOMUX_PAD(0x0540, 0x0238, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__PL301_SIM_MX6_PER1_HADDR_28 = IOMUX_PAD(0x0540, 0x0238, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__USDHC1_DAT2 = IOMUX_PAD(0x0544, 0x023C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__FEC_RDATA_1 = IOMUX_PAD(0x0544, 0x023C, 1, 0x06FC, 2, 0), + MX6_PAD_SD1_DAT2__KPP_COL_2 = IOMUX_PAD(0x0544, 0x023C, 2, 0x073C, 2, 0), + MX6_PAD_SD1_DAT2__EPDC_SDCE_8 = IOMUX_PAD(0x0544, 0x023C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__MSHC_DATA_2 = IOMUX_PAD(0x0544, 0x023C, 4, 0x07E0, 1, 0), + MX6_PAD_SD1_DAT2__GPIO_5_13 = IOMUX_PAD(0x0544, 0x023C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__ANATOP_ANATOP_TESTO_6 = IOMUX_PAD(0x0544, 0x023C, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__PL301_SIM_MX6_PER1_HADDR_29 = IOMUX_PAD(0x0544, 0x023C, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__USDHC1_DAT3 = IOMUX_PAD(0x0548, 0x0240, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__FEC_TDATA_0 = IOMUX_PAD(0x0548, 0x0240, 1, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__KPP_ROW_2 = IOMUX_PAD(0x0548, 0x0240, 2, 0x075C, 2, 0), + MX6_PAD_SD1_DAT3__EPDC_SDCE_9 = IOMUX_PAD(0x0548, 0x0240, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__MSHC_DATA_3 = IOMUX_PAD(0x0548, 0x0240, 4, 0x07E4, 1, 0), + MX6_PAD_SD1_DAT3__GPIO_5_6 = IOMUX_PAD(0x0548, 0x0240, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__ANATOP_ANATOP_TESTO_7 = IOMUX_PAD(0x0548, 0x0240, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__PL301_SIM_MX6_PER1_HADDR_30 = IOMUX_PAD(0x0548, 0x0240, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__USDHC1_DAT4 = IOMUX_PAD(0x054C, 0x0244, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__FEC_MDC = IOMUX_PAD(0x054C, 0x0244, 1, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__KPP_COL_3 = IOMUX_PAD(0x054C, 0x0244, 2, 0x0740, 2, 0), + MX6_PAD_SD1_DAT4__EPDC_SDCLKN = IOMUX_PAD(0x054C, 0x0244, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__UART4_TXD = IOMUX_PAD(0x054C, 0x0244, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__UART4_RXD = IOMUX_PAD(0x054C, 0x0244, 4, 0x0814, 4, 0), + MX6_PAD_SD1_DAT4__GPIO_5_12 = IOMUX_PAD(0x054C, 0x0244, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__ANATOP_ANATOP_TESTO_8 = IOMUX_PAD(0x054C, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT4__PL301_SIM_MX6_PER1_HADDR_31 = IOMUX_PAD(0x054C, 0x0244, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__USDHC1_DAT5 = IOMUX_PAD(0x0550, 0x0248, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__FEC_RDATA_0 = IOMUX_PAD(0x0550, 0x0248, 1, 0x06F8, 2, 0), + MX6_PAD_SD1_DAT5__KPP_ROW_3 = IOMUX_PAD(0x0550, 0x0248, 2, 0x0760, 2, 0), + MX6_PAD_SD1_DAT5__EPDC_SDOED = IOMUX_PAD(0x0550, 0x0248, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__UART4_TXD = IOMUX_PAD(0x0550, 0x0248, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__UART4_RXD = IOMUX_PAD(0x0550, 0x0248, 4, 0x0814, 5, 0), + MX6_PAD_SD1_DAT5__GPIO_5_9 = IOMUX_PAD(0x0550, 0x0248, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__ANATOP_ANATOP_TESTO_9 = IOMUX_PAD(0x0550, 0x0248, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT5__PL301_SIM_MX6_PER1_HPROT_3 = IOMUX_PAD(0x0550, 0x0248, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__USDHC1_DAT6 = IOMUX_PAD(0x0554, 0x024C, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__FEC_TX_EN = IOMUX_PAD(0x0554, 0x024C, 1, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__KPP_COL_4 = IOMUX_PAD(0x0554, 0x024C, 2, 0x0744, 2, 0), + MX6_PAD_SD1_DAT6__EPDC_SDOEZ = IOMUX_PAD(0x0554, 0x024C, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__UART4_CTS = IOMUX_PAD(0x0554, 0x024C, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__UART4_RTS = IOMUX_PAD(0x0554, 0x024C, 4, 0x0810, 4, 0), + MX6_PAD_SD1_DAT6__GPIO_5_7 = IOMUX_PAD(0x0554, 0x024C, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__ANATOP_ANATOP_TESTO_10 = IOMUX_PAD(0x0554, 0x024C, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT6__PL301_SIM_MX6_PER1_HPROT_2 = IOMUX_PAD(0x0554, 0x024C, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__USDHC1_DAT7 = IOMUX_PAD(0x0558, 0x0250, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__FEC_TDATA_1 = IOMUX_PAD(0x0558, 0x0250, 1, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__KPP_ROW_4 = IOMUX_PAD(0x0558, 0x0250, 2, 0x0764, 2, 0), + MX6_PAD_SD1_DAT7__CCM_PMIC_RDY = IOMUX_PAD(0x0558, 0x0250, 3, 0x062C, 3, 0), + MX6_PAD_SD1_DAT7__UART4_CTS = IOMUX_PAD(0x0558, 0x0250, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__UART4_RTS = IOMUX_PAD(0x0558, 0x0250, 4, 0x0810, 5, 0), + MX6_PAD_SD1_DAT7__GPIO_5_10 = IOMUX_PAD(0x0558, 0x0250, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__ANATOP_ANATOP_TESTO_11 = IOMUX_PAD(0x0558, 0x0250, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT7__PL301_SIM_MX6_PER1_HMASTLOCK = IOMUX_PAD(0x0558, 0x0250, 7, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x055C, 0x0254, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x055C, 0x0254, 1, 0x05F0, 2, 0), + MX6_PAD_SD2_CLK__ECSPI3_SCLK = IOMUX_PAD(0x055C, 0x0254, 2, 0x06B0, 2, 0), + MX6_PAD_SD2_CLK__CSI_D_0 = IOMUX_PAD(0x055C, 0x0254, 3, 0x0630, 2, 0), + MX6_PAD_SD2_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x055C, 0x0254, 4, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__GPIO_5_5 = IOMUX_PAD(0x055C, 0x0254, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__ANATOP_ANATOP_TESTO_13 = IOMUX_PAD(0x055C, 0x0254, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__PL301_SIM_MX6_PER1_HPROT_1 = IOMUX_PAD(0x055C, 0x0254, 7, 0x07EC, 1, 0), + MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0560, 0x0258, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__AUDMUX_AUD4_RXC = IOMUX_PAD(0x0560, 0x0258, 1, 0x05EC, 2, 0), + MX6_PAD_SD2_CMD__ECSPI3_SS0 = IOMUX_PAD(0x0560, 0x0258, 2, 0x06C0, 2, 0), + MX6_PAD_SD2_CMD__CSI_D_1 = IOMUX_PAD(0x0560, 0x0258, 3, 0x0634, 2, 0), + MX6_PAD_SD2_CMD__EPIT1_EPITO = IOMUX_PAD(0x0560, 0x0258, 4, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__GPIO_5_4 = IOMUX_PAD(0x0560, 0x0258, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__ANATOP_ANATOP_TESTO_14 = IOMUX_PAD(0x0560, 0x0258, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__PL301_SIM_MX6_PER1_HADDR_21 = IOMUX_PAD(0x0560, 0x0258, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 = IOMUX_PAD(0x0564, 0x025C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__AUDMUX_AUD4_RXD = IOMUX_PAD(0x0564, 0x025C, 1, 0x05E4, 2, 0), + MX6_PAD_SD2_DAT0__ECSPI3_MOSI = IOMUX_PAD(0x0564, 0x025C, 2, 0x06BC, 2, 0), + MX6_PAD_SD2_DAT0__CSI_D_2 = IOMUX_PAD(0x0564, 0x025C, 3, 0x0638, 2, 0), + MX6_PAD_SD2_DAT0__UART5_CTS = IOMUX_PAD(0x0564, 0x025C, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__UART5_RTS = IOMUX_PAD(0x0564, 0x025C, 4, 0x0818, 4, 0), + MX6_PAD_SD2_DAT0__GPIO_5_1 = IOMUX_PAD(0x0564, 0x025C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__ANATOP_ANATOP_TESTO_15 = IOMUX_PAD(0x0564, 0x025C, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__PL301_SIM_MX6_PER1_HPROT_0 = IOMUX_PAD(0x0564, 0x025C, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x0568, 0x0260, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUDMUX_AUD4_TXC = IOMUX_PAD(0x0568, 0x0260, 1, 0x05F4, 2, 0), + MX6_PAD_SD2_DAT1__ECSPI3_MISO = IOMUX_PAD(0x0568, 0x0260, 2, 0x06B8, 2, 0), + MX6_PAD_SD2_DAT1__CSI_D_3 = IOMUX_PAD(0x0568, 0x0260, 3, 0x063C, 2, 0), + MX6_PAD_SD2_DAT1__UART5_CTS = IOMUX_PAD(0x0568, 0x0260, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__UART5_RTS = IOMUX_PAD(0x0568, 0x0260, 4, 0x0818, 5, 0), + MX6_PAD_SD2_DAT1__GPIO_4_30 = IOMUX_PAD(0x0568, 0x0260, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0568, 0x0260, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__PL301_SIM_MX6_PER1_HBURST_1 = IOMUX_PAD(0x0568, 0x0260, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 = IOMUX_PAD(0x056C, 0x0264, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x056C, 0x0264, 1, 0x05F8, 2, 0), + MX6_PAD_SD2_DAT2__FEC_COL = IOMUX_PAD(0x056C, 0x0264, 2, 0x06F0, 1, 0), + MX6_PAD_SD2_DAT2__CSI_D_4 = IOMUX_PAD(0x056C, 0x0264, 3, 0x0640, 2, 0), + MX6_PAD_SD2_DAT2__UART5_TXD = IOMUX_PAD(0x056C, 0x0264, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__UART5_RXD = IOMUX_PAD(0x056C, 0x0264, 4, 0x081C, 4, 0), + MX6_PAD_SD2_DAT2__GPIO_5_3 = IOMUX_PAD(0x056C, 0x0264, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x056C, 0x0264, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__PL301_SIM_MX6_PER1_HADDR_22 = IOMUX_PAD(0x056C, 0x0264, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 = IOMUX_PAD(0x0570, 0x0268, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__AUDMUX_AUD4_TXD = IOMUX_PAD(0x0570, 0x0268, 1, 0x05E8, 2, 0), + MX6_PAD_SD2_DAT3__FEC_RX_CLK = IOMUX_PAD(0x0570, 0x0268, 2, 0x0700, 1, 0), + MX6_PAD_SD2_DAT3__CSI_D_5 = IOMUX_PAD(0x0570, 0x0268, 3, 0x0644, 2, 0), + MX6_PAD_SD2_DAT3__UART5_TXD = IOMUX_PAD(0x0570, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__UART5_RXD = IOMUX_PAD(0x0570, 0x0268, 4, 0x081C, 5, 0), + MX6_PAD_SD2_DAT3__GPIO_4_28 = IOMUX_PAD(0x0570, 0x0268, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0570, 0x0268, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__PL301_SIM_MX6_PER1_HBURST_0 = IOMUX_PAD(0x0570, 0x0268, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__USDHC2_DAT4 = IOMUX_PAD(0x0574, 0x026C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__USDHC3_DAT4 = IOMUX_PAD(0x0574, 0x026C, 1, 0x083C, 1, 0), + MX6_PAD_SD2_DAT4__UART2_TXD = IOMUX_PAD(0x0574, 0x026C, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__UART2_RXD = IOMUX_PAD(0x0574, 0x026C, 2, 0x0804, 4, 0), + MX6_PAD_SD2_DAT4__CSI_D_6 = IOMUX_PAD(0x0574, 0x026C, 3, 0x0648, 2, 0), + MX6_PAD_SD2_DAT4__SPDIF_OUT1 = IOMUX_PAD(0x0574, 0x026C, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__GPIO_5_2 = IOMUX_PAD(0x0574, 0x026C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x0574, 0x026C, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT4__PL301_SIM_MX6_PER1_HADDR_10 = IOMUX_PAD(0x0574, 0x026C, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT5__USDHC2_DAT5 = IOMUX_PAD(0x0578, 0x0270, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT5__USDHC3_DAT5 = IOMUX_PAD(0x0578, 0x0270, 1, 0x0840, 1, 0), + MX6_PAD_SD2_DAT5__UART2_TXD = IOMUX_PAD(0x0578, 0x0270, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT5__UART2_RXD = IOMUX_PAD(0x0578, 0x0270, 2, 0x0804, 5, 0), + MX6_PAD_SD2_DAT5__CSI_D_7 = IOMUX_PAD(0x0578, 0x0270, 3, 0x064C, 2, 0), + MX6_PAD_SD2_DAT5__SPDIF_IN1 = IOMUX_PAD(0x0578, 0x0270, 4, 0x07F0, 2, 0), + MX6_PAD_SD2_DAT5__GPIO_4_31 = IOMUX_PAD(0x0578, 0x0270, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT5__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0578, 0x0270, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT5__PL301_SIM_MX6_PER1_HADDR_20 = IOMUX_PAD(0x0578, 0x0270, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT6__USDHC2_DAT6 = IOMUX_PAD(0x057C, 0x0274, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT6__USDHC3_DAT6 = IOMUX_PAD(0x057C, 0x0274, 1, 0x0844, 1, 0), + MX6_PAD_SD2_DAT6__UART2_CTS = IOMUX_PAD(0x057C, 0x0274, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT6__UART2_RTS = IOMUX_PAD(0x057C, 0x0274, 2, 0x0800, 4, 0), + MX6_PAD_SD2_DAT6__CSI_D_8 = IOMUX_PAD(0x057C, 0x0274, 3, 0x0650, 2, 0), + MX6_PAD_SD2_DAT6__USDHC2_WP = IOMUX_PAD(0x057C, 0x0274, 4, 0x0834, 2, 0), + MX6_PAD_SD2_DAT6__GPIO_4_29 = IOMUX_PAD(0x057C, 0x0274, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT6__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x057C, 0x0274, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT6__PL301_SIM_MX6_PER1_HADDR_19 = IOMUX_PAD(0x057C, 0x0274, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT7__USDHC2_DAT7 = IOMUX_PAD(0x0580, 0x0278, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT7__USDHC3_DAT7 = IOMUX_PAD(0x0580, 0x0278, 1, 0x0848, 1, 0), + MX6_PAD_SD2_DAT7__UART2_CTS = IOMUX_PAD(0x0580, 0x0278, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT7__UART2_RTS = IOMUX_PAD(0x0580, 0x0278, 2, 0x0800, 5, 0), + MX6_PAD_SD2_DAT7__CSI_D_9 = IOMUX_PAD(0x0580, 0x0278, 3, 0x0654, 2, 0), + MX6_PAD_SD2_DAT7__USDHC2_CD = IOMUX_PAD(0x0580, 0x0278, 4, 0x0830, 2, 0), + MX6_PAD_SD2_DAT7__GPIO_5_0 = IOMUX_PAD(0x0580, 0x0278, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT7__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0580, 0x0278, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT7__PL301_SIM_MX6_PER1_HADDR_16 = IOMUX_PAD(0x0580, 0x0278, 7, 0x0000, 0, 0), + MX6_PAD_SD2_RST__USDHC2_RST = IOMUX_PAD(0x0584, 0x027C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_RST__FEC_REF_OUT = IOMUX_PAD(0x0584, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_SD2_RST__WDOG2_WDOG_B = IOMUX_PAD(0x0584, 0x027C, 2, 0x0000, 0, 0), + MX6_PAD_SD2_RST__SPDIF_OUT1 = IOMUX_PAD(0x0584, 0x027C, 3, 0x0000, 0, 0), + MX6_PAD_SD2_RST__CSI_MCLK = IOMUX_PAD(0x0584, 0x027C, 4, 0x0000, 0, 0), + MX6_PAD_SD2_RST__GPIO_4_27 = IOMUX_PAD(0x0584, 0x027C, 5, 0x0000, 0, 0), + MX6_PAD_SD2_RST__ANATOP_ANATOP_TESTO_12 = IOMUX_PAD(0x0584, 0x027C, 6, 0x0000, 0, 0), + MX6_PAD_SD2_RST__PL301_SIM_MX6_PER1_HBURST_2 = IOMUX_PAD(0x0584, 0x027C, 7, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x0588, 0x0280, 0, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0588, 0x0280, 1, 0x0608, 1, 0), + MX6_PAD_SD3_CLK__KPP_COL_5 = IOMUX_PAD(0x0588, 0x0280, 2, 0x0748, 2, 0), + MX6_PAD_SD3_CLK__CSI_D_10 = IOMUX_PAD(0x0588, 0x0280, 3, 0x0658, 2, 0), + MX6_PAD_SD3_CLK__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x0588, 0x0280, 4, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__GPIO_5_18 = IOMUX_PAD(0x0588, 0x0280, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__USB_USBOTG1_PWR = IOMUX_PAD(0x0588, 0x0280, 6, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__PL301_SIM_MX6_PER1_HADDR_13 = IOMUX_PAD(0x0588, 0x0280, 7, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x058C, 0x0284, 0, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__AUDMUX_AUD5_RXC = IOMUX_PAD(0x058C, 0x0284, 1, 0x0604, 1, 0), + MX6_PAD_SD3_CMD__KPP_ROW_5 = IOMUX_PAD(0x058C, 0x0284, 2, 0x0768, 2, 0), + MX6_PAD_SD3_CMD__CSI_D_11 = IOMUX_PAD(0x058C, 0x0284, 3, 0x065C, 2, 0), + MX6_PAD_SD3_CMD__ANATOP_USBOTG2_ID = IOMUX_PAD(0x058C, 0x0284, 4, 0x05E0, 3, 0), + MX6_PAD_SD3_CMD__GPIO_5_21 = IOMUX_PAD(0x058C, 0x0284, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__USB_USBOTG2_PWR = IOMUX_PAD(0x058C, 0x0284, 6, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__PL301_SIM_MX6_PER1_HADDR_18 = IOMUX_PAD(0x058C, 0x0284, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__USDHC3_DAT0 = IOMUX_PAD(0x0590, 0x0288, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0590, 0x0288, 1, 0x05FC, 1, 0), + MX6_PAD_SD3_DAT0__KPP_COL_6 = IOMUX_PAD(0x0590, 0x0288, 2, 0x074C, 2, 0), + MX6_PAD_SD3_DAT0__CSI_D_12 = IOMUX_PAD(0x0590, 0x0288, 3, 0x0660, 1, 0), + MX6_PAD_SD3_DAT0__ANATOP_USBOTG1_ID = IOMUX_PAD(0x0590, 0x0288, 4, 0x05DC, 4, 0), + MX6_PAD_SD3_DAT0__GPIO_5_19 = IOMUX_PAD(0x0590, 0x0288, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__SJC_JTAG_ACT = IOMUX_PAD(0x0590, 0x0288, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__PL301_SIM_MX6_PER1_HADDR_11 = IOMUX_PAD(0x0590, 0x0288, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__USDHC3_DAT1 = IOMUX_PAD(0x0594, 0x028C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__AUDMUX_AUD5_TXC = IOMUX_PAD(0x0594, 0x028C, 1, 0x060C, 1, 0), + MX6_PAD_SD3_DAT1__KPP_ROW_6 = IOMUX_PAD(0x0594, 0x028C, 2, 0x076C, 2, 0), + MX6_PAD_SD3_DAT1__CSI_D_13 = IOMUX_PAD(0x0594, 0x028C, 3, 0x0664, 1, 0), + MX6_PAD_SD3_DAT1__USDHC1_VSELECT = IOMUX_PAD(0x0594, 0x028C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__GPIO_5_20 = IOMUX_PAD(0x0594, 0x028C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__SJC_DE_B = IOMUX_PAD(0x0594, 0x028C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__PL301_SIM_MX6_PER1_HADDR_17 = IOMUX_PAD(0x0594, 0x028C, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__USDHC3_DAT2 = IOMUX_PAD(0x0598, 0x0290, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x0598, 0x0290, 1, 0x0610, 1, 0), + MX6_PAD_SD3_DAT2__KPP_COL_7 = IOMUX_PAD(0x0598, 0x0290, 2, 0x0750, 2, 0), + MX6_PAD_SD3_DAT2__CSI_D_14 = IOMUX_PAD(0x0598, 0x0290, 3, 0x0668, 1, 0), + MX6_PAD_SD3_DAT2__EPIT1_EPITO = IOMUX_PAD(0x0598, 0x0290, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__GPIO_5_16 = IOMUX_PAD(0x0598, 0x0290, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__USB_USBOTG2_OC = IOMUX_PAD(0x0598, 0x0290, 6, 0x0820, 3, 0), + MX6_PAD_SD3_DAT2__PL301_SIM_MX6_PER1_HADDR_14 = IOMUX_PAD(0x0598, 0x0290, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__USDHC3_DAT3 = IOMUX_PAD(0x059C, 0x0294, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__AUDMUX_AUD5_TXD = IOMUX_PAD(0x059C, 0x0294, 1, 0x0600, 1, 0), + MX6_PAD_SD3_DAT3__KPP_ROW_7 = IOMUX_PAD(0x059C, 0x0294, 2, 0x0770, 2, 0), + MX6_PAD_SD3_DAT3__CSI_D_15 = IOMUX_PAD(0x059C, 0x0294, 3, 0x066C, 1, 0), + MX6_PAD_SD3_DAT3__EPIT2_EPITO = IOMUX_PAD(0x059C, 0x0294, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__GPIO_5_17 = IOMUX_PAD(0x059C, 0x0294, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__USB_USBOTG1_OC = IOMUX_PAD(0x059C, 0x0294, 6, 0x0824, 2, 0), + MX6_PAD_SD3_DAT3__PL301_SIM_MX6_PER1_HADDR_12 = IOMUX_PAD(0x059C, 0x0294, 7, 0x0000, 0, 0), + MX6_PAD_TAMPER__SNVS_LP_WRAPPER_SNVS_TD1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_TEST_MODE__TCU_TEST_MODE = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART1_TXD = IOMUX_PAD(0x05A0, 0x0298, 0, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x05A0, 0x0298, 0, 0x07FC, 0, 0), + MX6_PAD_UART1_RXD__PWM1_PWMO = IOMUX_PAD(0x05A0, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART4_TXD = IOMUX_PAD(0x05A0, 0x0298, 2, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART4_RXD = IOMUX_PAD(0x05A0, 0x0298, 2, 0x0814, 6, 0), + MX6_PAD_UART1_RXD__FEC_COL = IOMUX_PAD(0x05A0, 0x0298, 3, 0x06F0, 2, 0), + MX6_PAD_UART1_RXD__UART5_TXD = IOMUX_PAD(0x05A0, 0x0298, 4, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART5_RXD = IOMUX_PAD(0x05A0, 0x0298, 4, 0x081C, 6, 0), + MX6_PAD_UART1_RXD__GPIO_3_16 = IOMUX_PAD(0x05A0, 0x0298, 5, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__ANATOP_ANATOP_TESTI_2 = IOMUX_PAD(0x05A0, 0x0298, 6, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__TPSMP_CLK = IOMUX_PAD(0x05A0, 0x0298, 7, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x05A4, 0x029C, 0, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART1_RXD = IOMUX_PAD(0x05A4, 0x029C, 0, 0x07FC, 1, 0), + MX6_PAD_UART1_TXD__PWM2_PWMO = IOMUX_PAD(0x05A4, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART4_TXD = IOMUX_PAD(0x05A4, 0x029C, 2, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART4_RXD = IOMUX_PAD(0x05A4, 0x029C, 2, 0x0814, 7, 0), + MX6_PAD_UART1_TXD__FEC_RX_CLK = IOMUX_PAD(0x05A4, 0x029C, 3, 0x0700, 2, 0), + MX6_PAD_UART1_TXD__UART5_TXD = IOMUX_PAD(0x05A4, 0x029C, 4, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART5_RXD = IOMUX_PAD(0x05A4, 0x029C, 4, 0x081C, 7, 0), + MX6_PAD_UART1_TXD__GPIO_3_17 = IOMUX_PAD(0x05A4, 0x029C, 5, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x05A4, 0x029C, 6, 0x0000, 0, 0), + MX6_PAD_UART1_TXD__UART5_DCD = IOMUX_PAD(0x05A4, 0x029C, 7, 0x0000, 0, 0), + MX6_PAD_WDOG_B__WDOG1_WDOG_B = IOMUX_PAD(0x05A8, 0x02A0, 0, 0x0000, 0, 0), + MX6_PAD_WDOG_B__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x05A8, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_WDOG_B__UART5_RI = IOMUX_PAD(0x05A8, 0x02A0, 2, 0x0000, 0, 0), + MX6_PAD_WDOG_B__GPIO_3_18 = IOMUX_PAD(0x05A8, 0x02A0, 5, 0x0000, 0, 0), + MX6_PAD_WDOG_B__OBSERVE_MUX_OUT_2 = IOMUX_PAD(0x05A8, 0x02A0, 7, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_MX6_MX6SL_PINS_H__ */ diff --git a/board/freescale/mx6slevk/Makefile b/board/freescale/mx6slevk/Makefile new file mode 100644 index 0000000..43af351 --- /dev/null +++ b/board/freescale/mx6slevk/Makefile @@ -0,0 +1,28 @@ +# (C) Copyright 2013 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := mx6slevk.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx6slevk/imximage.cfg b/board/freescale/mx6slevk/imximage.cfg new file mode 100644 index 0000000..df39a16 --- /dev/null +++ b/board/freescale/mx6slevk/imximage.cfg @@ -0,0 +1,118 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ +DATA 4 0x020c4018 0x00260324 + +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff + +DATA 4 0x020e0344 0x00003030 +DATA 4 0x020e0348 0x00003030 +DATA 4 0x020e034c 0x00003030 +DATA 4 0x020e0350 0x00003030 +DATA 4 0x020e030c 0x00000030 +DATA 4 0x020e0310 0x00000030 +DATA 4 0x020e0314 0x00000030 +DATA 4 0x020e0318 0x00000030 +DATA 4 0x020e0300 0x00000030 +DATA 4 0x020e031c 0x00000030 +DATA 4 0x020e0338 0x00000028 +DATA 4 0x020e0320 0x00000030 +DATA 4 0x020e032c 0x00000000 +DATA 4 0x020e033c 0x00000008 +DATA 4 0x020e0340 0x00000008 +DATA 4 0x020e05c4 0x00000030 +DATA 4 0x020e05cc 0x00000030 +DATA 4 0x020e05d4 0x00000030 +DATA 4 0x020e05d8 0x00000030 +DATA 4 0x020e05ac 0x00000030 +DATA 4 0x020e05c8 0x00000030 +DATA 4 0x020e05b0 0x00020000 +DATA 4 0x020e05b4 0x00000000 +DATA 4 0x020e05c0 0x00020000 +DATA 4 0x020e05d0 0x00080000 + +DATA 4 0x021b001c 0x00008000 +DATA 4 0x021b085c 0x1b4700c7 +DATA 4 0x021b0800 0xa1390003 +DATA 4 0x021b0890 0x00300000 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b081c 0x33333333 +DATA 4 0x021b0820 0x33333333 +DATA 4 0x021b0824 0x33333333 +DATA 4 0x021b0828 0x33333333 +DATA 4 0x021b082c 0xf3333333 +DATA 4 0x021b0830 0xf3333333 +DATA 4 0x021b0834 0xf3333333 +DATA 4 0x021b0838 0xf3333333 +DATA 4 0x021b0848 0x4241444a +DATA 4 0x021b0850 0x3030312b +DATA 4 0x021b083c 0x20000000 +DATA 4 0x021b0840 0x00000000 +DATA 4 0x021b08c0 0x24911492 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b000c 0x33374133 +DATA 4 0x021b0004 0x00020024 +DATA 4 0x021b0010 0x00100A82 +DATA 4 0x021b0014 0x00000093 +DATA 4 0x021b0018 0x00001688 +DATA 4 0x021b002c 0x0f9f26d2 +DATA 4 0x021b0030 0x0000020e +DATA 4 0x021b0038 0x00190778 +DATA 4 0x021b0008 0x00000000 +DATA 4 0x021b0040 0x0000004f +DATA 4 0x021b0000 0xc3110000 +DATA 4 0x021b001c 0x003f8030 +DATA 4 0x021b001c 0xff0a8030 +DATA 4 0x021b001c 0x82018030 +DATA 4 0x021b001c 0x04028030 +DATA 4 0x021b001c 0x02038030 +DATA 4 0x021b001c 0xff0a8038 +DATA 4 0x021b001c 0x82018038 +DATA 4 0x021b001c 0x04028038 +DATA 4 0x021b001c 0x02038038 +DATA 4 0x021b0800 0xa1310003 +DATA 4 0x021b0020 0x00001800 +DATA 4 0x021b0818 0x00000000 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b0004 0x00025564 +DATA 4 0x021b0404 0x00011006 +DATA 4 0x021b001c 0x00000000 diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c new file mode 100644 index 0000000..fc6353e --- /dev/null +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -0,0 +1,102 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <asm/sizes.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TXD__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* Assume boot SD always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int checkboard(void) +{ + puts("Board: MX6SLEVK\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 199fcfa..2844712 100644 --- a/boards.cfg +++ b/boards.cfg @@ -256,6 +256,7 @@ mx6qarm2 arm armv7 mx6qarm2 freesca mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +mx6slevk arm armv7 mx6slevk freescale mx6 mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL eco5pk arm armv7 eco5pk 8dtech omap3 nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h new file mode 100644 index 0000000..67b63f4 --- /dev/null +++ b/include/configs/mx6slevk.h @@ -0,0 +1,189 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6SL EVK board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <asm/sizes.h> + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define MACH_TYPE_MX6SLEVK 4307 +#define CONFIG_MACH_TYPE MACH_TYPE_MX6SLEVK + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x80800000 +#define CONFIG_SYS_TEXT_BASE 0x87800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6sl-evk.dtb\0" \ + "fdt_addr=0x81000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 256 * SZ_1M) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE SZ_512M + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * SZ_64K) +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H */
Hi Fabio,
Am 30.03.2013 22:08, schrieb Fabio Estevam:
mx6slevk board is a development board from Freescale based on the mx6 solo lite processor.
For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&...
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com
MAINTAINERS | 1 + arch/arm/cpu/armv7/mx6/clock.c | 38 +- arch/arm/include/asm/arch-mx6/crm_regs.h | 1 + arch/arm/include/asm/arch-mx6/imx-regs.h | 63 +- arch/arm/include/asm/arch-mx6/mx6-pins.h | 4 + arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 1374 ++++++++++++++++++++++++++++
Would it make sense to split this patch into two parts? One general "add i.MX6 SoloLite support" and then the "add mx6slevk board board support"?
board/freescale/mx6slevk/Makefile | 28 + board/freescale/mx6slevk/imximage.cfg | 118 +++ board/freescale/mx6slevk/mx6slevk.c | 102 +++ boards.cfg | 1 + include/configs/mx6slevk.h | 189 ++++ 11 files changed, 1916 insertions(+), 3 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sl_pins.h create mode 100644 board/freescale/mx6slevk/Makefile create mode 100644 board/freescale/mx6slevk/imximage.cfg create mode 100644 board/freescale/mx6slevk/mx6slevk.c create mode 100644 include/configs/mx6slevk.h
- Copyright (C) 2013 Freescale Semiconductor, Inc.
- the License or (at your option) any later version.
- Refer docs/README.imxmage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
+IMAGE_VERSION 2
- Boot Device : one of
- spi, sd (the board has no nand neither onenand)
+BOOT_FROM sd
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- Addr-type register length (1,2 or 4 bytes)
- Address absolute address of the register
- value value to be stored in the register
I haven't looked into the manual, but are these the clock registers? If so, is it necessary to set them to 0xffffffff? Or are these already the default reset values?
- Copyright 2013 Freescale Semiconductor, Inc.
- Configuration settings for the Freescale i.MX6SL EVK board.
Below, you seem to boot with device tree. Is this necessary, then?
- "script=boot.scr\0" \
- "uimage=uImage\0" \
- "console=ttymxc0\0" \
- "fdt_high=0xffffffff\0" \
- "initrd_high=0xffffffff\0" \
- "fdt_file=imx6sl-evk.dtb\0" \
Is a kernel patch for this already available anywhere?
Best regards
Dirk
Hi Dirk,
Yes, I can split as suggested.
Yes, these are the default values, so I can remove them indeed;
Yes, we need to be able to boot a 3.0.35 kernel from Freescale, which is the only one available for solo-lite currently.
"uimage=uImage\0" \
Not yet. Only kernel 3.0.35 is available currently.
Regards,
Fabio Estevam
On 3/31/2013 2:38 AM, Fabio Estevam wrote:
<snip>
diff --git a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h new file mode 100644 index 0000000..cd974d8 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h @@ -0,0 +1,1374 @@ +/*
- Copyright (C) 2013 Freescale Semiconductor, Inc. All Rights Reserved.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
+#ifndef __ASM_ARCH_MX6_MX6SL_PINS_H__ +#define __ASM_ARCH_MX6_MX6SL_PINS_H__
+/* Use to set PAD control */ +#define PAD_CTL_HYS (1 << 16) +#define PAD_CTL_PUS_100K_DOWN (0 << 14) +#define PAD_CTL_PUS_47K_UP (1 << 14) +#define PAD_CTL_PUS_100K_UP (2 << 14) +#define PAD_CTL_PUS_22K_UP (3 << 14)
+#define PAD_CTL_PUE (1 << 13) +#define PAD_CTL_PKE (1 << 12) +#define PAD_CTL_ODE (1 << 11) +#define PAD_CTL_SPEED_LOW (1 << 6) +#define PAD_CTL_SPEED_MED (2 << 6) +#define PAD_CTL_SPEED_HIGH (3 << 6) +#define PAD_CTL_DSE_DISABLE (0 << 3) +#define PAD_CTL_DSE_240ohm (1 << 3) +#define PAD_CTL_DSE_120ohm (2 << 3) +#define PAD_CTL_DSE_80ohm (3 << 3) +#define PAD_CTL_DSE_60ohm (4 << 3) +#define PAD_CTL_DSE_48ohm (5 << 3) +#define PAD_CTL_DSE_40ohm (6 << 3) +#define PAD_CTL_DSE_34ohm (7 << 3) +#define PAD_CTL_SRE_FAST (1 << 0) +#define PAD_CTL_SRE_SLOW (0 << 0)
Is the above same for all the variants of i.Mx? Can we put this into a common header file?
+#define IOMUX_CONFIG_SION 0x10 +#define NO_MUX_I 0 +#define NO_PAD_I 0 +enum {
- MX6_PAD_AUD_MCLK__AUDMUX_AUDIO_CLK_OUT = IOMUX_PAD(0x02A4, 0x004C, 0, 0x0000, 0, 0),
- MX6_PAD_AUD_MCLK__PWM4_PWMO = IOMUX_PAD(0x02A4, 0x004C, 1, 0x0000, 0, 0),
- MX6_PAD_AUD_MCLK__ECSPI3_RDY = IOMUX_PAD(0x02A4, 0x004C, 2, 0x06B4, 0, 0),
- MX6_PAD_AUD_MCLK__FEC_MDC = IOMUX_PAD(0x02A4, 0x004C, 3, 0x0000, 0, 0),
Is the mx6slevk using all the pins defined here? If not please take off the unused IOMUX pins so that we don't add dead code.
Regards, Vikram
Ok, I can try to put this into a common location.
No, I put all pins for completion.
I thought it was common practice to provide the complete IOMUX pin file.
Stefano, please advise.
Regards,
Fabio Estevam
I meant completeness, here.
Looking at mx6q_pins.h I see that the IOMUX table is complete, but mx6dl_pins.h is not, so just want to get a confirmation first before doing v2.
Regards,
Fabio Estevam
Please refer the mx6dl discussion here. http://www.mail-archive.com/u-boot@lists.denx.de/msg94194.html
It was Troy's idea, to include only the necessary pins.
Regards, Vikram
Dirk Behme
Fabio Estevam
Vikram Narayanan
