[U-Boot] [PATCH] USB: g_dnl: Change device class
The USB Mass Storage (ums) works in Windows, Linux and OS X (EL Capitan). But, not in OS X (Yosemite). By applying the said patch, it extends the ums support.
Signed-off-by: John Tobias john.tobias.ph@gmail.com --- drivers/usb/gadget/g_dnl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index 2fa6da4..bd3aad9 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -58,8 +58,8 @@ static struct usb_device_descriptor device_desc = { .bDescriptorType = USB_DT_DEVICE,
.bcdUSB = __constant_cpu_to_le16(0x0200), - .bDeviceClass = USB_CLASS_COMM, - .bDeviceSubClass = 0x02, /*0x02:CDC-modem , 0x00:CDC-serial*/ + .bDeviceClass = USB_CLASS_PER_INTERFACE, + .bDeviceSubClass = 0, /*0x02:CDC-modem , 0x00:CDC-serial*/
.idVendor = __constant_cpu_to_le16(CONFIG_G_DNL_VENDOR_NUM), .idProduct = __constant_cpu_to_le16(CONFIG_G_DNL_PRODUCT_NUM),
Hi John,
- .bDeviceClass = USB_CLASS_PER_INTERFACE,
- .bDeviceSubClass = 0, /*0x02:CDC-modem , 0x00:CDC-serial*/
Have you tested if this patch is not introducing any regression on Linux and Windows?
Hi Lukas,
On Fri, Apr 8, 2016 at 2:19 AM, Lukasz Majewski l.majewski@samsung.com wrote:
Hi John,
The test what I did is like this:
Linux: - Run ums to expose all my eMMC partition - shows all correctly - Run ums to expose only 1 partition of my eMMC - show correctly
Windows: - Run ums to expose all my eMMC partition - it detects but it prompts, if I want to format it (due to a non windows partition) - Run ums to expose only the FAT32 partition - it show the partition correctly.
Note: I have a patch to expose only 1 partition: e.g: ums 0 mmc 1:8
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
Regards,
John
On Fri, 8 Apr 2016 08:41:14 -0700 John Tobias john.tobias.ph@gmail.com wrote:
Hi Lukas,
Hi John,
0x00:CDC-serial*/
Ok, I see. Thanks for your effort on testing. I do appreciate it.
Yes, I've just received it. I will provide feedback shortly.
-- Best regards,
Lukasz Majewski
Regards,
John _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi John,
Acked-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com
Test HW: Odroid XU3 with test/py for UMS, DFU
Applied to u-boot-dfu branch
John Tobias
Lukasz Majewski
Lukasz Majewski
