[PATCH V2] configs: omap3x_logic: Enable LTO on more LogicPD OMAP3 boards
There are five omap3 based boards from LogicPD. Two of them have added LTO support. Add the remaining three to use LTO.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Rebase
diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 8b0c943024..5c1e19555c 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 2ab92551e4..deaabace4c 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index f2e9d20e8f..a1e4c95edf 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SPL=y +CONFIG_LTO=y CONFIG_DISTRO_DEFAULTS=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_USE_BOOTCOMMAND is not set
Adam Ford
