[U-Boot] [PATCH 1/2] bfin: enlarge the monitor size for ip04 board to avoid oversize link error
Signed-off-by: Sonic Zhang sonic.zhang@analog.com ---
include/configs/ip04.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ip04.h b/include/configs/ip04.h index ec510bd..2ee215f 100644 --- a/include/configs/ip04.h +++ b/include/configs/ip04.h @@ -61,7 +61,7 @@ #define CONFIG_EBIU_AMBCTL0_VAL 0xffc2ffc2 #define CONFIG_EBIU_AMBCTL1_VAL 0xffc2ffc2
-#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
include/configs/bct-brettl2.h | 2 +- include/configs/ibf-dsp561.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 39982ef..2e0e922 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -97,7 +97,7 @@ #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x12000
#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_BYPASS) #define ENV_IS_EMBEDDED diff --git a/include/configs/ibf-dsp561.h b/include/configs/ibf-dsp561.h index ac5ca9a..2a937c6 100644 --- a/include/configs/ibf-dsp561.h +++ b/include/configs/ibf-dsp561.h @@ -82,7 +82,7 @@ #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x10000 /* Total Size of Environment Sector */ +#define CONFIG_ENV_SECT_SIZE 0x12000 /* Total Size of Environment Sector */ #if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_BYPASS) #define ENV_IS_EMBEDDED #else
sonic.adi@gmail.com
