[U-Boot] [PATCH] AT91: reset.c: fix comments, add option
- The comment was wrong/misleading - One would assume that a u-boot "reset" command should also reset the external hardware outside the SoC. Since its unknown whether some boards rely on that NOT being so, asserting the external reset signal is optional
Signed-off-by: Reinhard Meyer u-boot@emk-elektronik.de --- arch/arm/cpu/arm926ejs/at91/reset.c | 17 ++++++++--------- 1 files changed, 8 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/reset.c b/arch/arm/cpu/arm926ejs/at91/reset.c index 1b67e77..22f3277 100644 --- a/arch/arm/cpu/arm926ejs/at91/reset.c +++ b/arch/arm/cpu/arm926ejs/at91/reset.c @@ -27,18 +27,17 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/io.h>
-/* - * Reset the cpu by setting up the watchdog timer and let him time out. - */ +/* Reset the cpu by telling the reset controller to do so */ void reset_cpu(ulong ignored) { at91_rstc_t *rstc = (at91_rstc_t *) AT91_RSTC_BASE;
- /* this is the way Linux does it */ - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_PROCRST | AT91_RSTC_CR_PERRST, - &rstc->cr); - + writel(AT91_RSTC_KEY + | AT91_RSTC_CR_PROCRST /* Processor Reset */ + | AT91_RSTC_CR_PERRST /* Peripheral Reset */ +#ifdef CONFIG_AT91RESET_EXTRST + | AT91_RSTC_CR_EXTRST /* External Reset (assert nRST pin) */ +#endif + , &rstc->cr); while (1); - /* Never reached */ }
Hi Reinhard,
- Reset the cpu by setting up the watchdog timer and let him time out.
&rstc->cr);
while (1);, &rstc->cr);
While you're at it, please put the semi-colon in the next line to clearly show the empty command.
Was this comment misleading? Why not leave it in?
Cheers Detlev
Detlev Zundel schrieb:
Hi Reinhard,
Applied (with requested changes) to u-boot-atmel/next Thanks, Reinhard
Detlev Zundel
Reinhard Meyer
