[PATCH v2 1/2] configs: j721s2: merge HS and non-HS defconfigs
K3 devices have runtime type board detection. Make the default defconfig include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection. If TI_SECURE_DEV_PKG is not set the build will emit warnings, for non-HS devices these can be ignored.
Signed-off-by: Manorit Chawdhry m-chawdhry@ti.com Acked-by: Andrew Davis afd@ti.com --- v1->v2: update MAINTAINERS
MAINTAINERS | 2 - configs/j721s2_evm_a72_defconfig | 3 +- configs/j721s2_evm_r5_defconfig | 1 + configs/j721s2_hs_evm_a72_defconfig | 213 ---------------------------- configs/j721s2_hs_evm_r5_defconfig | 176 ----------------------- 5 files changed, 3 insertions(+), 392 deletions(-) delete mode 100644 configs/j721s2_hs_evm_a72_defconfig delete mode 100644 configs/j721s2_hs_evm_r5_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index b9c505d5faa7..bdea0704adc0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1457,8 +1457,6 @@ F: configs/j7200_hs_evm_a72_defconfig F: configs/j7200_hs_evm_r5_defconfig F: configs/j721e_hs_evm_a72_defconfig F: configs/j721e_hs_evm_r5_defconfig -F: configs/j721s2_hs_evm_a72_defconfig -F: configs/j721s2_hs_evm_r5_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 84b4fb083191..c880a8d37158 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -32,7 +33,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 1f2102a9f91f..51f2da66c9d1 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_SPL_GPIO=y diff --git a/configs/j721s2_hs_evm_a72_defconfig b/configs/j721s2_hs_evm_a72_defconfig deleted file mode 100644 index 9fc90737da80..000000000000 --- a/configs/j721s2_hs_evm_a72_defconfig +++ /dev/null @@ -1,213 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721S2=y -CONFIG_TARGET_J721S2_A72_EVM=y -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -CONFIG_DISTRO_DEFAULTS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set -CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_TI_DP83867=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_DSP=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_DM_RESET=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/j721s2_hs_evm_r5_defconfig b/configs/j721s2_hs_evm_r5_defconfig deleted file mode 100644 index d9988fc17fc7..000000000000 --- a/configs/j721s2_hs_evm_r5_defconfig +++ /dev/null @@ -1,176 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x10000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721S2=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J721S2_R5_EVM=y -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j721s2-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_SIZE_LIMIT=0x80000 -CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x4000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c76000 -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y -CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41c76000 -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_THERMAL=y -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_SOFT_RESET=y -CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y -CONFIG_SPI_FLASH_SPANSION=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_SPI_FLASH_MT35XU=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_DM_RESET=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_DM_THERMAL=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6168 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_PANIC_HANG=y -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
MAINTAINERS | 2 - configs/j7200_evm_a72_defconfig | 3 +- configs/j7200_evm_r5_defconfig | 1 + configs/j7200_hs_evm_a72_defconfig | 205 ----------------------------- configs/j7200_hs_evm_r5_defconfig | 171 ------------------------ 5 files changed, 3 insertions(+), 379 deletions(-) delete mode 100644 configs/j7200_hs_evm_a72_defconfig delete mode 100644 configs/j7200_hs_evm_r5_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index bdea0704adc0..0516b36f5c16 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1453,8 +1453,6 @@ F: configs/k2g_hs_evm_defconfig F: configs/k2l_hs_evm_defconfig F: configs/am65x_hs_evm_r5_defconfig F: configs/am65x_hs_evm_a53_defconfig -F: configs/j7200_hs_evm_a72_defconfig -F: configs/j7200_hs_evm_r5_defconfig F: configs/j721e_hs_evm_a72_defconfig F: configs/j721e_hs_evm_r5_defconfig
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index 053f29b11f54..e588c4ada5cc 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y @@ -32,7 +33,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_SPL_MAX_SIZE=0xc0000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index dc6c1b6935df..6fbc2e96321d 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SPL_GPIO=y diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig deleted file mode 100644 index 782a42b74657..000000000000 --- a/configs/j7200_hs_evm_a72_defconfig +++ /dev/null @@ -1,205 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_J721E=y -CONFIG_TARGET_J7200_A72_EVM=y -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -CONFIG_DISTRO_DEFAULTS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set -CONFIG_OF_BOARD_SETUP=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run boot_rprocs; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_MTD=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_UFS=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0,nor0=47034000.hyperbus" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_CCF=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_DM_I2C_GPIO=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_MMC_IO_VOLTAGE=y -CONFIG_MMC_UHS_SUPPORT=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_MULTIPLEXER=y -CONFIG_MUX_MMIO=y -CONFIG_PHY_FIXED=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PHY=y -CONFIG_SPL_PHY=y -CONFIG_PHY_CADENCE_TORRENT=y -CONFIG_PHY_J721E_WIZ=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_DM_RESET=y -CONFIG_RESET_TI_SCI=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_USB_CDNS3_HOST=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_UFS=y -CONFIG_CADENCE_UFS=y -CONFIG_TI_J721E_UFS=y -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig deleted file mode 100644 index 73979f4cc32c..000000000000 --- a/configs/j7200_hs_evm_r5_defconfig +++ /dev/null @@ -1,171 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x70000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SOC_K3_J721E=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_J7200_R5_EVM=y -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-j7200-r5-common-proc-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41cf5bfc -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 -# CONFIG_USE_SPL_FIT_GENERATOR is not set -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_MAX_SIZE=0xc0000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41cf5bfc -CONFIG_SPL_BSS_MAX_SIZE=0xa000 -CONFIG_SPL_BOARD_INIT=y -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_FS_EXT4=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_NOR_SUPPORT=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_USB_GADGET=y -CONFIG_SPL_DFU=y -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SYSCON=y -CONFIG_SPL_SYSCON=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_SPL_CLK_CCF=y -CONFIG_SPL_CLK_K3_PLL=y -CONFIG_SPL_CLK_K3=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x40000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_FS_LOADER=y -CONFIG_SPL_FS_LOADER=y -CONFIG_K3_AVS0=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_SPL_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_SHOW_PROGRESS=0 -CONFIG_CFI_FLASH=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_FLASH_CFI_MTD=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_HBMC_AM654=y -CONFIG_SYS_MAX_FLASH_BANKS_DETECT=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_TPS65941=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_TPS65941=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_DM_RESET=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_HAS_CQSPI_REF_CLK=y -CONFIG_CQSPI_REF_CLK=133333333 -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_SPL_DM_USB_GADGET=y -CONFIG_USB_CDNS3=y -CONFIG_USB_CDNS3_GADGET=y -CONFIG_SPL_USB_CDNS3_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6164 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_FS_EXT4=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 -CONFIG_LIB_RATIONAL=y -CONFIG_SPL_LIB_RATIONAL=y
Hi Tom,
Please revert this series, they need some other fixes also along with them, i had dropped them during spinning of the seperate series, forgot to comment here.
Regards, Manorit
-- Tom
Hi Tom,
Done, thanks.
Manorit Chawdhry
