[U-Boot] [PATCH V3 0/4] pytest: add a simple test to check the command aes
This serie fix the command aes on sandbox and add a simple pytest for aes.
The first and second patch enable the command aes on sandbox and sandbox64. Thr third patch fix the command aes on sandbox (adding map_sysmem to avoid a segfault), the forth patch add a simple pytest for the command aes.
Philippe Reynes (4): sandbox: enable command aes sandbox64: enable command aes cmd: aes: use map_sysmem when accessing memory pytest: add a new test for aes
Changelog: v3: - add unmap_sysmem (thanks Simon) v2: - add binary file (key128.bin, iv128.bin and plaintext.bin)
cmd/aes.c | 14 ++++++++---- configs/sandbox64_defconfig | 1 + configs/sandbox_defconfig | 1 + test/py/tests/aes/iv128.bin | 1 + test/py/tests/aes/key128.bin | 1 + test/py/tests/aes/plaintext.bin | 1 + test/py/tests/test_aes.py | 48 +++++++++++++++++++++++++++++++++++++++++ 7 files changed, 63 insertions(+), 4 deletions(-) create mode 100644 test/py/tests/aes/iv128.bin create mode 100644 test/py/tests/aes/key128.bin create mode 100644 test/py/tests/aes/plaintext.bin create mode 100644 test/py/tests/test_aes.py
This commit enable the command aes on sandbox. Then, it may be used on pytest.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/sandbox_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f77b9e8..4b9cce5 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -67,6 +67,7 @@ CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_AES=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_BTRFS=y
On Tue, 24 Sep 2019 at 02:32, Philippe Reynes philippe.reynes@softathome.com wrote:
Applied to u-boot-dm/next, thanks!
This commit add the support of command aes. Then, it may be used on pytest.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/sandbox64_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 7aa2d38..1fea683 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -59,6 +59,7 @@ CONFIG_CMD_QFW=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y +CONFIG_CMD_AES=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_BTRFS=y
You could add this in sandbox's Kconfig BTW.
The aes command used to segfault when accessing memory in sandbox. The pointer accesses should be mapped.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- cmd/aes.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/cmd/aes.c b/cmd/aes.c index 7ff4a71..8c61cee 100644 --- a/cmd/aes.c +++ b/cmd/aes.c @@ -11,6 +11,7 @@ #include <malloc.h> #include <asm/byteorder.h> #include <linux/compiler.h> +#include <mapmem.h>
/** * do_aes() - Handle the "aes" command-line command @@ -46,10 +47,10 @@ static int do_aes(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) dst_addr = simple_strtoul(argv[5], NULL, 16); len = simple_strtoul(argv[6], NULL, 16);
- key_ptr = (uint8_t *)key_addr; - iv_ptr = (uint8_t *)iv_addr; - src_ptr = (uint8_t *)src_addr; - dst_ptr = (uint8_t *)dst_addr; + key_ptr = (uint8_t *)map_sysmem(key_addr, 128 / 8); + iv_ptr = (uint8_t *)map_sysmem(iv_addr, 128 / 8); + src_ptr = (uint8_t *)map_sysmem(src_addr, len); + dst_ptr = (uint8_t *)map_sysmem(dst_addr, len);
/* First we expand the key. */ aes_expand_key(key_ptr, key_exp); @@ -64,6 +65,11 @@ static int do_aes(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) aes_cbc_decrypt_blocks(key_exp, iv_ptr, src_ptr, dst_ptr, aes_blocks);
+ unmap_sysmem(key_ptr); + unmap_sysmem(iv_ptr); + unmap_sysmem(src_ptr); + unmap_sysmem(dst_ptr); + return 0; }
I don't see change logs on these patches. Do you use patman?
Regards, SImon
Regards, SImon
This commit add a simple test to check that a text may be ciphered and unciphered. Each step are checked with the known result.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- test/py/tests/aes/iv128.bin | 1 + test/py/tests/aes/key128.bin | 1 + test/py/tests/aes/plaintext.bin | 1 + test/py/tests/test_aes.py | 48 +++++++++++++++++++++++++++++++++++++++++ 4 files changed, 51 insertions(+) create mode 100644 test/py/tests/aes/iv128.bin create mode 100644 test/py/tests/aes/key128.bin create mode 100644 test/py/tests/aes/plaintext.bin create mode 100644 test/py/tests/test_aes.py
diff --git a/test/py/tests/aes/iv128.bin b/test/py/tests/aes/iv128.bin new file mode 100644 index 0000000..b7b5d5d --- /dev/null +++ b/test/py/tests/aes/iv128.bin @@ -0,0 +1 @@ +�!�/���a�P���r \ No newline at end of file diff --git a/test/py/tests/aes/key128.bin b/test/py/tests/aes/key128.bin new file mode 100644 index 0000000..9e3ce60 --- /dev/null +++ b/test/py/tests/aes/key128.bin @@ -0,0 +1 @@ +����Ć皳���6} \ No newline at end of file diff --git a/test/py/tests/aes/plaintext.bin b/test/py/tests/aes/plaintext.bin new file mode 100644 index 0000000..8598fd9 --- /dev/null +++ b/test/py/tests/aes/plaintext.bin @@ -0,0 +1 @@ +AES128 is working, amazing !!!!! \ No newline at end of file diff --git a/test/py/tests/test_aes.py b/test/py/tests/test_aes.py new file mode 100644 index 0000000..408bd77 --- /dev/null +++ b/test/py/tests/test_aes.py @@ -0,0 +1,48 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright (c) 2019, Softathome + +# Test U-Boot's "aes" command. + +import pytest + +def test_aes(u_boot_console): + """ + Test the aes command, and validate that it can + cipher and uncipher a simple text + """ + + cons = u_boot_console + tmpdir = cons.config.result_dir + '/' + datadir = cons.config.source_dir + '/test/py/tests/aes/' + + # Check that the option cmd_aes is enabled in the config + if cons.config.buildconfig.get('config_cmd_aes', 'n') != 'y': + pytest.skip('aes command not supported') + + # Send a command with no argument ... + output = cons.run_command('aes') + assert('AES 128 CBC encryption' in ''.join(output)) + + # Load file from host + output = cons.run_command('host load hostfs - 1000 %skey128.bin' % datadir) + assert('16 bytes read' in ''.join(output)) + output = cons.run_command('host load hostfs - 2000 %siv128.bin' % datadir) + assert('16 bytes read' in ''.join(output)) + output = cons.run_command('host load hostfs - 3000 %splaintext.bin' % datadir) + assert('32 bytes read' in ''.join(output)) + + output = cons.run_command('md.b 3000 0x20') + + output = cons.run_command('aes enc 1000 2000 3000 4000 0x20') + + output = cons.run_command('cmp.b 3000 4000 0x20') + assert('Total of 0 byte(s) were the same' in ''.join(output)) + + output = cons.run_command('md.b 4000 0x20') + + output = cons.run_command('aes dec 1000 2000 4000 5000 0x20') + + output = cons.run_command('md.b 5000 0x20') + + output = cons.run_command('cmp.b 3000 5000 0x20') + assert('Total of 32 byte(s) were the same' in ''.join(output))
Philippe Reynes
sjg@google.com
