[U-Boot] [PATCH] include/env.h: Ensure ulong is defined
To fix these failures when building with musl: include/env.h:166:1: error: unknown type name 'ulong'; did you mean 'long'? ensure that ulong is defined.
Signed-off-by: Alistair Francis alistair.francis@wdc.com --- include/env.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/env.h b/include/env.h index b72239f6a5..5ca49a3456 100644 --- a/include/env.h +++ b/include/env.h @@ -13,6 +13,8 @@ #include <stdbool.h> #include <linux/types.h>
+typedef unsigned long ulong; + struct environment_s;
/* Value for environment validity */
On Wed, Nov 6, 2019 at 4:30 PM Alistair Francis alistair.francis@wdc.com wrote:
I think, this was fixed before 2019.10 release by this patchset:
https://patchwork.ozlabs.org/cover/1152432/
2.23.0
That didn't fix the problem for musl.
Alistair
2.23.0
What exactly is the case you're hitting this under? <linux/types.h> is where we have that typedef. I'd almost rather spell out unsigned long in a few more places than add a typedef here, if we can't solve this via correcting some include order or some other underlying problem.
That only applies if __KERNEL_STRICT_NAMES isn't defined (I'm guessing it somehow is for musl).
https://github.com/u-boot/u-boot/blob/master/include/linux/types.h#L8
Is there somehwere else you would prefer it?
Alistair
OK, so lets first understand for sure how we're getting in to this position.
If, once we know why the existing typedef's are used, and it's a feature not a bug then we should probably clean function prototypes to be more portably correct rather than adding a typedef for this case.
Alistair Francis
Alistair Francis
David Abdurachmanov
