[PATCH] mtd: spi-nor-ids: Add is25lp512 and is25wp512 devices
Add is25lp512 and is25wp512 devices to spi-nor id table
Tested on Intel n5x hardware with QSPI carrier card
Signed-off-by: Kris Chaplin kris.chaplin@linux.intel.com Tested-by: Kris Chaplin kris.chaplin@linux.intel.com --- drivers/mtd/spi/spi-nor-ids.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 6ca669c591..5359d09489 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -133,6 +133,8 @@ const struct flash_info spi_nor_ids[] = { SECT_4K | SPI_NOR_DUAL_READ) }, { INFO("is25lp256", 0x9d6019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ) }, + { INFO("is25lp512", 0x9d601a, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp064", 0x9d7017, 0, 64 * 1024, 128, @@ -142,6 +144,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("is25wp256", 0x9d7019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("is25wp512", 0x9d701a, 0, 64 * 1024, 1024, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */
Same comment as before about the Tested-by trailer. Also adding SPI NOR maintainers in Cc, as mentioned in previous email.
I dunno much about these flashes so I am not commenting on the patch contents.
- { INFO("is25lp512", 0x9d601a, 0, 64 * 1024, 1024,
{ INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp064", 0x9d7017, 0, 64 * 1024, 128,SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { INFO("is25wp512", 0x9d701a, 0, 64 * 1024, 1024,
#endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */ -- 2.25.1
Kris Chaplin
Pratyush Yadav
