[U-Boot] sunxi: USB gadget does not work on H2+ after 92a30692b2b18f45aae6fdaae38d67ed03dd2d11
After this commit usb gadget does not work anymore for me on the Orange Pi Zero (H2+).
Thanks, Nuno
commit 92a30692b2b18f45aae6fdaae38d67ed03dd2d11 Author: Jagan Teki jagan@amarulasolutions.com Date: Fri Jul 20 12:34:20 2018 +0530
phy: sun4i-usb: Call phy_passby even for PHY#0
On newer Allwinner SoC, there is a pair of EHCI/OHCI USB hosts for OTG host mode. USB PHY passby must be configured for its corresponding PHY. so we can call for PHY#0. on the other hand in past usb-phy code the same thing can be restricted for Lower SoC's, other than H3/H5/A64.
Now there is no need to restrict usb passby since the phy driver is DT enabled, and the respective phy calls will trigger based DT information initiated by the drivers.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index 2b3cf48025..01f585a283 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -300,8 +300,7 @@ static int sun4i_usb_phy_init(struct phy *phy) data->cfg->disc_thresh, PHY_DISCON_TH_LEN); }
- if (usb_phy->id != 0) - sun4i_usb_phy_passby(phy, true); + sun4i_usb_phy_passby(phy, true);
sun4i_usb_phy0_reroute(data, true);
Please send log or full information?
Jagan.
This test is on 2018.09-rc2 with UMS enabled.
With your patch, I get this dmesg on the host:
[20121.718226] usb 1-4-port4: Cannot enable. Maybe the USB cable is bad? [20122.578151] usb 1-4-port4: Cannot enable. Maybe the USB cable is bad? [20122.578320] usb 1-4-port4: attempt power cycle [20123.750104] usb 1-4-port4: Cannot enable. Maybe the USB cable is bad? [20124.602034] usb 1-4-port4: Cannot enable. Maybe the USB cable is bad? [20124.602190] usb 1-4-port4: unable to enumerate USB device
u-boot console is the same, including loading the gadget:
Allwinner mUSB OTG (Peripheral)
If you tell me how you tested USB Gadget to work, I will reproduce your test locally to confirm the issue.
Thanks, Nuno
Pi
Zero (H2+).
Jagan.
This can be because UMS is not DM aware?
Thanks, Nuno
Pi
Zero (H2+).
Jagan.
Here is the steps with UMS on BPI-M2+ which is H3 board (USB is similar to H2+)
on target: => mmc list SUNXI SD/MMC: 0 SUNXI SD/MMC: 1 (eMMC) => mmc dev 1 switch to partitions #0, OK mmc1(part 0) is current device => ums 0 mmc 1 UMS: LUN 0, dev 1, hwpart 0, sector 0x0, count 0xe90000 \musb-hdrc: peripheral reset irq lost!
on host: $ sudo dmesg [25593.969620] usb 1-1: new high-speed USB device number 7 using xhci_hcd [25594.118084] usb 1-1: New USB device found, idVendor=1f3a, idProduct=1010 [25594.118092] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [25594.118097] usb 1-1: Product: USB download gadget [25594.118102] usb 1-1: Manufacturer: Allwinner Technology [25594.118107] usb 1-1: SerialNumber: 02c0008196cc4467 [25594.159273] usb-storage 1-1:1.0: USB Mass Storage device detected
fastboot also look fine.
Jagan.
What defconfig are you using for this test?
Thanks!
See the board I've mentioned, it's Sinovoip_BPI_M2_Plus_defconfig
That is the reason I asked, since that defconfig does not have CONFIG_CMD_USB_MASS_STORAGE. Your test is done with something else.
We, sunxi treated this CONFIG as user defined, not giving room to add it on defconfig. I enabled via menuconfig.
With the basic defconfig + CMD_USB_MASS_STORAGE, I don't get the driver to load:
Controller uninitialized g_dnl_register: failed!, error: -6 g_dnl_register failed
I just would like to confirm you have nothing else added...
Thanks! On Sat, Aug 18, 2018 at 7:42 PM Jagan Teki jagan@amarulasolutions.com wrote:
Are you using mainline? is your defconfig has MUSB? try to see existing H3 defconfigs for reference.
This error appears when CONFIG_USB_ETHER is not set. For some reason I can't enable UMS without USB_ETHER (probably because UMS is not DM aware).
Regarding the bug reported, it happens because after your commit USB_EHCI_HCD and USB_KEYBOARD are required to be set.
So, with USB_ETHER, USB_KEYBOARD and USB_EHCI_HCD, it works. Except for the last not sure if this is as expected.
Thanks, Nuno
Jagan Teki
Nuno Gonçalves
