[PATCH] video: ipuv3: fix framebuffer base address init with multiple IPUs
Since commit 7812bbdc3732 ("video: Correctly handle multiple framebuffers") the vidconsole output is missing on the primary display on boards with two IPU units (all i.MX6Q/D based boards). The base address of the allocated framebuffer is not correctly programmed in the display controller. Fix it.
Reported-by: Soeren Moch smoch@web.de Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/video/imx/mxc_ipuv3_fb.c | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index 587d62f2d8..4c20ec5e66 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -66,6 +66,7 @@ static void fb_videomode_to_var(struct fb_var_screeninfo *var, * Structure containing the MXC specific framebuffer information. */ struct mxcfb_info { + struct udevice *udev; int blank; ipu_channel_t ipu_ch; int ipu_di; @@ -381,13 +382,16 @@ static int mxcfb_check_var(struct fb_var_screeninfo *var, struct fb_info *info)
static int mxcfb_map_video_memory(struct fb_info *fbi) { + struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par; + struct video_uc_platdata *plat = dev_get_uclass_platdata(mxc_fbi->udev); + if (fbi->fix.smem_len < fbi->var.yres_virtual * fbi->fix.line_length) { fbi->fix.smem_len = fbi->var.yres_virtual * fbi->fix.line_length; } fbi->fix.smem_len = roundup(fbi->fix.smem_len, ARCH_DMA_MINALIGN);
- fbi->screen_base = (char *)gd->video_bottom; + fbi->screen_base = (char *)plat->base;
fbi->fix.smem_start = (unsigned long)fbi->screen_base; if (fbi->screen_base == 0) { @@ -477,8 +481,8 @@ extern struct clk *g_ipu_clk; * * @return Appropriate error code to the kernel common code */ -static int mxcfb_probe(u32 interface_pix_fmt, uint8_t disp, - struct fb_videomode const *mode) +static int mxcfb_probe(struct udevice *dev, u32 interface_pix_fmt, + uint8_t disp, struct fb_videomode const *mode) { struct fb_info *fbi; struct mxcfb_info *mxcfbi; @@ -501,6 +505,7 @@ static int mxcfb_probe(u32 interface_pix_fmt, uint8_t disp, }
mxcfbi->ipu_di = disp; + mxcfbi->udev = dev;
if (!ipu_clk_enabled()) clk_enable(g_ipu_clk); @@ -600,7 +605,7 @@ static int ipuv3_video_probe(struct udevice *dev) if (ret < 0) return ret;
- ret = mxcfb_probe(gpixfmt, gdisp, gmode); + ret = mxcfb_probe(dev, gpixfmt, gdisp, gmode); if (ret < 0) return ret;
Successfully tested on a tbs2910 board (i.MX6Q based).
Tested-by: Soeren Moch smoch@web.de
Thanks, Soeren
- Structure containing the MXC specific framebuffer information.
- struct udevice *udev; int blank; ipu_channel_t ipu_ch; int ipu_di;
- struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par;
- struct video_uc_platdata *plat = dev_get_uclass_platdata(mxc_fbi->udev);
- if (fbi->fix.smem_len < fbi->var.yres_virtual * fbi->fix.line_length) { fbi->fix.smem_len = fbi->var.yres_virtual * fbi->fix.line_length; } fbi->fix.smem_len = roundup(fbi->fix.smem_len, ARCH_DMA_MINALIGN);
- @return Appropriate error code to the kernel common code
mxcfbi->udev = dev;
- ret = mxcfb_probe(dev, gpixfmt, gdisp, gmode); if (ret < 0) return ret;
Applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Soeren Moch
