[PATCH] tqma6q_mba6: Convert to watchdog driver model
Commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") caused the 'reset' command in U-Boot to not cause a board reset.
Fix it by switching to the watchdog driver model via sysreset, which is the preferred method for implementing the watchdog reset.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx6dl-mba6b-u-boot.dtsi | 3 +++ arch/arm/dts/imx6q-mba6b-u-boot.dtsi | 3 +++ arch/arm/dts/imx6qdl-mba6-u-boot.dtsi | 15 +++++++++++++++ configs/tqma6dl_mba6_mmc_defconfig | 3 +++ configs/tqma6dl_mba6_spi_defconfig | 3 +++ configs/tqma6q_mba6_mmc_defconfig | 3 +++ configs/tqma6q_mba6_spi_defconfig | 3 +++ configs/tqma6s_mba6_mmc_defconfig | 3 +++ configs/tqma6s_mba6_spi_defconfig | 3 +++ 9 files changed, 39 insertions(+) create mode 100644 arch/arm/dts/imx6dl-mba6b-u-boot.dtsi create mode 100644 arch/arm/dts/imx6q-mba6b-u-boot.dtsi create mode 100644 arch/arm/dts/imx6qdl-mba6-u-boot.dtsi
diff --git a/arch/arm/dts/imx6dl-mba6b-u-boot.dtsi b/arch/arm/dts/imx6dl-mba6b-u-boot.dtsi new file mode 100644 index 000000000000..bb17ba9b4249 --- /dev/null +++ b/arch/arm/dts/imx6dl-mba6b-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include "imx6qdl-mba6-u-boot.dtsi" diff --git a/arch/arm/dts/imx6q-mba6b-u-boot.dtsi b/arch/arm/dts/imx6q-mba6b-u-boot.dtsi new file mode 100644 index 000000000000..bb17ba9b4249 --- /dev/null +++ b/arch/arm/dts/imx6q-mba6b-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include "imx6qdl-mba6-u-boot.dtsi" diff --git a/arch/arm/dts/imx6qdl-mba6-u-boot.dtsi b/arch/arm/dts/imx6qdl-mba6-u-boot.dtsi new file mode 100644 index 000000000000..78457ef68f4f --- /dev/null +++ b/arch/arm/dts/imx6qdl-mba6-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include "imx6qdl-u-boot.dtsi" + +/ { + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + bootph-pre-ram; + }; +}; + +&wdog1 { + bootph-pre-ram; +}; diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index 1a1d253c50ee..1534a2e9262a 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -65,5 +65,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index c6a1c7cf3d7d..5eaa9eb270ce 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -69,5 +69,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 27f949c6ef68..3fcc1f8d54e1 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -65,5 +65,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 5d3ce79c35d9..a7ffc9edb5b4 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -69,5 +69,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index a9ed0d3fc2c6..7839c4858478 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -65,5 +65,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index 9cd8c3dd20f4..c3bb44025b34 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -69,5 +69,8 @@ CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y +CONFIG_IMX_WATCHDOG=y
Applied, thanks.
Fabio Estevam
