[U-Boot] [patch v2] armv8/ls1043a: Add MTD partition scheme
Add and share the the MTD partition scheme with kernel by defualt bootargs. And add the "mtdparts" env.
Signed-off-by: Wenbin Song wenbin.song@nxp.com --- Changes for v2: rebase --- include/configs/ls1043a_common.h | 22 ++++++++++++++++++++-- 1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index a651130..0ad5261 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -241,6 +241,21 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
+#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define MTDPARTS_DEFAULT "mtdparts=spi0.0:1m(uboot)," \ + "5m(kernel),1m(dtb),9m(file_system)" +#else +#define MTDPARTS_DEFAULT "mtdparts=60000000.nor:1m(nor_bank0_rcw)," \ + "1m(nor_bank0_uboot),1m(nor_bank0_uboot_env)," \ + "1m(nor_bank0_fman_uconde),40m(nor_bank0_fit)," \ + "1m(nor_bank4_rcw),1m(nor_bank4_uboot)," \ + "1m(nor_bank4_uboot_env),1m(nor_bank4_fman_ucode)," \ + "40m(nor_bank4_fit);7e800000.flash:" \ + "1m(nand_uboot),1m(nand_uboot_env)," \ + "20m(nand_fit);spi0.0:1m(uboot)," \ + "5m(kernel),1m(dtb),9m(file_system)" +#endif + /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=auto\0" \ @@ -250,10 +265,13 @@ "kernel_start=0x61100000\0" \ "kernel_load=0xa0000000\0" \ "kernel_size=0x2800000\0" \ - "console=ttyS0,115200\0" + "console=ttyS0,115200\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0"
#define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ - "earlycon=uart8250,mmio,0x21c0500" + "earlycon=uart8250,mmio,0x21c0500 " \ + MTDPARTS_DEFAULT + #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_BOOTCOMMAND "sf probe && sf read $kernel_load " \ "e0000 f00000 && bootm $kernel_load"
Applied to fsl-qoriq master. Awaiting upstream. Thanks.
York
Wenbin song
york sun
