Hi
After searching internet for a good example of using U-boot PPC405 in xilinx FPGAs with only a SPI Flash, and finding nothing, I began writing my own driver. I used a couple of standalone examples besides the linux driver as the base point, and could finally use it. As much as I have tested the system, it is working fine with a m25p64 spi flash. Now I would be happy to share the driver, but haven't done such a thing previously. I am not even much familiar with patch! Is there any document telling the procedure? Besides I have developed board support for suaku V sz410 board, and a simplistic driver for xilinx frame buffer core too (which is not as much tested as the spi driver). Should I submit them too?
Regards S. M. Sajjadi
Hi
Adding this driver to mainline depends on style of your driver. You should look at http://www.denx.de/wiki/U-Boot/CodingStyle and http://www.denx.de/wiki/U-Boot/Patches
Both drivers will be useful. I can test them on Microblaze cpu.
Please write there any information about configuration - which IP you use and how to test it.
If you want you can send your patches directly to me and I take a look before you send them to mailing list.
Regards, Michal
Michal Simek
Seyyed Mohammad Sajjadi
