[U-Boot] [PATCH] powerpc/mpc85xx: Fix SPL_BUILD compilation by adding CONFIG_USB_EHCI_FSL flag
Commit 9262367 moved USB errata workaround to a C file but didn't build it for SPL targets. The EHCI errata should be applied/checked only when EHCI is defined.
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com --- arch/powerpc/include/asm/config_mpc85xx.h | 32 +++++++++++++++++++++++++++++-- include/configs/km/kmp204x-common.h | 1 + 2 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 505d355..c5fe3cf 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -161,9 +161,11 @@ #define CONFIG_SYS_FSL_ERRATUM_A005125 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_ERRATUM_A004508 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A007075 #define CONFIG_SYS_FSL_ERRATUM_A006261 #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_A004447_SVR_REV 0x10 #define CONFIG_ESDHC_HC_BLK_ADDR
@@ -295,7 +297,9 @@ #define CONFIG_FSL_SATA_ERRATUM_A001 #define CONFIG_SYS_FSL_ERRATUM_A004508 #define CONFIG_SYS_FSL_ERRATUM_A005125 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */
#elif defined(CONFIG_P1023) #define CONFIG_MAX_CPUS 2 @@ -376,7 +380,9 @@ #define CONFIG_SYS_FSL_SRIO_MSG_UNIT_NUM 2 #define CONFIG_SYS_FSL_ERRATUM_A004508 #define CONFIG_SYS_FSL_ERRATUM_A005125 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
#elif defined(CONFIG_PPC_P2041) /* also supports P2040 */ @@ -414,7 +420,9 @@ #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_A004849 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_A004447_SVR_REV 0x11
#elif defined(CONFIG_PPC_P3041) @@ -454,7 +462,9 @@ #define CONFIG_SYS_FSL_ERRATUM_A004849 #define CONFIG_SYS_FSL_ERRATUM_A005812 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ @@ -505,7 +515,9 @@ #define CONFIG_SYS_P4080_ERRATUM_PCIE_A003 #define CONFIG_SYS_FSL_ERRATUM_A005812 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A007075 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20
#elif defined(CONFIG_PPC_P5020) /* also supports P5010 */ @@ -541,7 +553,9 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xc0000000 #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_A004447_SVR_REV 0x20
#elif defined(CONFIG_PPC_P5040) @@ -574,7 +588,9 @@ #define CONFIG_SYS_FSL_ERRATUM_A004699 #define CONFIG_SYS_FSL_ERRATUM_A004510 #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 #define CONFIG_SYS_FSL_ERRATUM_A005812
@@ -594,7 +610,9 @@ #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_A005125 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_BSC9132) @@ -619,7 +637,9 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_ERRATUM_A005125 #define CONFIG_SYS_FSL_ERRATUM_A005434 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_ERRATUM_I2C_A004447 #define CONFIG_SYS_FSL_A004447_SVR_REV 0x11 #define CONFIG_ESDHC_HC_BLK_ADDR @@ -681,11 +701,13 @@ #define CONFIG_SYS_FSL_ERRATUM_A004468 #define CONFIG_SYS_FSL_ERRATUM_A_004934 #define CONFIG_SYS_FSL_ERRATUM_A005871 -#define CONFIG_SYS_FSL_ERRATUM_A006261 #define CONFIG_SYS_FSL_ERRATUM_A006379 #define CONFIG_SYS_FSL_ERRATUM_A007186 #define CONFIG_SYS_FSL_ERRATUM_A006593 +#ifdef CONFIG_USB_EHCI_FSL +#define CONFIG_SYS_FSL_ERRATUM_A006261 #define CONFIG_SYS_FSL_ERRATUM_A007798 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_SFP_VER_3_0 #define CONFIG_SYS_FSL_PCI_VER_3_X @@ -724,11 +746,13 @@ #define CONFIG_SYS_FSL_ERRATUM_A006379 #define CONFIG_SYS_FSL_ERRATUM_A007186 #define CONFIG_SYS_FSL_ERRATUM_A006593 -#define CONFIG_SYS_FSL_ERRATUM_A007075 #define CONFIG_SYS_FSL_ERRATUM_A006475 #define CONFIG_SYS_FSL_ERRATUM_A006384 #define CONFIG_SYS_FSL_ERRATUM_A007212 +#ifdef CONFIG_USB_EHCI_FSL +#define CONFIG_SYS_FSL_ERRATUM_A007075 #define CONFIG_SYS_FSL_ERRATUM_A004477 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_SFP_VER_3_0
@@ -799,7 +823,9 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.4" #define CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE @@ -907,7 +933,9 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define CONFIG_SYS_FSL_SFP_VER_3_0 #define CONFIG_SYS_FSL_ISBC_VER 2 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 +#ifdef CONFIG_USB_EHCI_FSL #define CONFIG_SYS_FSL_ERRATUM_A006261 +#endif /* CONFIG_USB_EHCI_FSL */ #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_FSL_ERRATUM_A007186 #define CONFIG_SYS_FSL_ERRATUM_A006379 diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 028623d..5bdda22 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -406,6 +406,7 @@ int get_scl(void); #endif
#define __USB_PHY_TYPE utmi +#define CONFIG_USB_EHCI_FSL
/* * Environment Configuration
So why don't you fix arch/powerpc/cpu/mpc85xx/cmd_errata.c instead of adding zillion ifdefs into the config_mpc85xx.h ?
- Environment Configuration
From: Marek Vasut [mailto:marex@denx.de] On 07/04/2016 01:11 PM, Sriram Dash wrote:
Hello Marek,
The phy errata is applied at cpu init time for some boards. Due to this, the code has been added in the file arch/powerpc/cpu/mpc85xx/cpu_init.c also. Now, this file is also required for SPL build. Hence, rather than fixing in every file currently and the future implementations, I am thinking of fixing this at a common place.
0xc0000000
#define
-- Best regards, Marek Vasut
Regards, Sriram
Hello Marek,
Which files are those exactly ? I suspect most of the erratas are used in cmd_errata.c only and maybe in ehci-fsl.c
0xc0000000
#define
Regards, Sriram
Hello Marek,
Let's think from another angle. What causes this issue? Some functions are called for SPL build. Do we need those functions? Earlier I thought we need some USB workaround for SPL. But that is not the case. The normal version of U-Boot can implement those workaround so we don't have to have them for SPL. So is the cmd_errata. Now I think Ed's simple fix makes more sense. It's getting close to 2016.07 release. Let's test more with the new fix proposed by Ed. Please don't hesitate to send a new patch if you have other ideas.
York
Sriram Dash
york sun
