[U-Boot] [PATCH] rpi: Set the default mmc max device to 2
When running with special configuration (OF_BOARD and mmc overlay) RPI have the SD card as id 1. This make device enumeration fails when using the API.
Signed-off-by: Emmanuel Vadot manu@freebsd.org --- include/configs/rpi.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/rpi.h b/include/configs/rpi.h index a97550b732..26fc9b9d95 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -69,6 +69,8 @@ #define CONFIG_MISC_INIT_R #endif
+#define CONFIG_SYS_MMC_MAX_DEVICE 2 + /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024
Could you please elaborate a bit? From the commit message I don't fully understand which problem you're trying to solve.
Thanks,
Alex
- /* Console configuration */ #define CONFIG_SYS_CBSIZE 1024
Thanks,
Alex
Sure,
When using the dtb from the rpi fundation and the mmc overlay (which switch back the sd card to use the SDHCI controller and not the SDHOST one) and using OF_BOARD so u-boot uses it/pass it to the OS the device id for the sd is 1 : U-Boot> mmc list mmc@7e300000: 1
This cause the API (see api/api_storage.c) code to never expose this device to the consumer as the default value for CONFIG_SYS_MMC_MAX_DEVICE is 1.
If it's more clear I'll send a v2 with those words.
Cheers,
Thanks,
Alex
Sure,
Ouch, that whole file assumes that you know the number of devices present in your system. That's terrible.
I think the real fix would be to convert api_storage.c to instead use dm native routines to loop through all available devices and not explicitly depend on any maximum number of possible devices.
Simon, do you potentially have a patch lying around for that in a branch already?
Alex
Hi Alex,
Thanks,
Alex
Sure,
No sorry I don't.
The API could use another look for DM.
Thanks,
Alex
Sure,
Please send a v2 with reworked wording or - if you have the time - rework the storage api to no require this change at all with DM :).
Alex
Alexander Graf
Emmanuel Vadot
Emmanuel Vadot
