[U-Boot] [u-Boot] USB EHCI for mpc512x crashes Uboot
Hi
I'm new to this list so I hope that this is the right place for my question.
I have a board with mpc5121e cpu on it and I'm been patching my Uboot (U-Boot v2009.11) with the patch given initially by Francesco Rendine:
http://lists.denx.de/pipermail/u-boot/2009-June/055022.html
It seems like that every time I run 'usb start' from the Uboot prompt it crashes the Uboot like:
------------ Hit any key to stop autoboot: 0 => usb start (Re)start USB... USB:
U-Boot 2009.11.1-svn813 (Aug 16 2010 - 15:07:33) MPC512X
CPU: MPC5121e rev. 3.0, Core e300c4 at 396 MHz, CSB at 198 MHz Board: V39 Revision B I2C: ready . . . -------------------
After some debugging it seems to be in the ehci_hcd_init(): - hcor = (struct ehci_hcor *)((uint32_t) hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
this line makes it crash.
Regards Einar
Hi Elinar,
I've cleaned up this patch and made it work better (there are some issues with it that needed fixing), but needs (mostly style) work before being submitted as a patch for mainline.
Please email me off-list if you want to test the patch for yourself. If it works for you, I should make the effort to clean it up and contribute it back...
-- Damien
Dear Damien Dusha,
In message AANLkTim0vHBH_a_v2ZnHwXX7-tF3e9maN56LReCasv+m@mail.gmail.com you wrote:
Please do this in any case. I would really like to add this feature.
Hi Damien
I'm very interested in testing this. Please send it to me to the address provided.
Regards Einar
________________________________________ From: u-boot-bounces@lists.denx.de [u-boot-bounces@lists.denx.de] on behalf of Wolfgang Denk [wd@denx.de] Sent: Tuesday, August 17, 2010 9:25 AM To: Damien Dusha Cc: u-boot@lists.denx.de; Einar Már Björgvinsson Subject: Re: [U-Boot] [u-Boot] USB EHCI for mpc512x crashes Uboot
Dear Damien Dusha,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "If the code and the comments disagree, then both are probably wrong." - Norm Schryer _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Damien Dusha
