[U-Boot] [PATCH next 1/3] mx6: soc: Move mxs_dma_init() into the mxs nand driver
Currently the following build error is seen when a board using MMC SPL is built and the MXS nand driver is also selected:
arch/arm/cpu/armv7/built-in.o: In function `arch_cpu_init': arch/arm/cpu/armv7/mx6/soc.c:432: undefined reference to 'mxs_dma_init'
On mx6 the only user of mxs_dma_init() is the mxs nand driver, so move it there.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- arch/arm/cpu/armv7/mx6/soc.c | 5 ----- drivers/mtd/nand/mxs_nand.c | 1 + 2 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 2bedbdb..ecbc3b2 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -427,11 +427,6 @@ int arch_cpu_init(void)
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
-#ifdef CONFIG_APBH_DMA - /* Start APBH DMA */ - mxs_dma_init(); -#endif - init_src();
return 0; diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 9200544..5aa3608 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -1114,6 +1114,7 @@ int mxs_nand_init(struct mxs_nand_info *info) }
/* Init the DMA controller. */ + mxs_dma_init(); for (j = MXS_DMA_CHANNEL_AHB_APBH_GPMI0; j <= MXS_DMA_CHANNEL_AHB_APBH_GPMI7; j++) { ret = mxs_dma_init_channel(j);
Add support for mx6q, mx6dl and mx6qp sabreauto boards in SPL.
Retrieved the mx6q DCD table from: board/freescale/mx6qsabreauto/imximage.cfg
Retrieved the mx6dl DCD table from: board/freescale/mx6qsabreauto/mx6dl.cfg
Retrieved the mx6qp DCD table from: board/freescale/mx6qsabreauto/mx6qp.cfg
Flashed SPL and u-boot.img to an SD card and could successfully boot it on mx6q, mx6qp and mx6dl sabreauto boards.
Signed-off-by: Vanessa Maegima vanessa.maegima@nxp.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + board/freescale/mx6qsabreauto/mx6qsabreauto.c | 638 +++++++++++++++++++++----- configs/mx6qsabreauto_spl_defconfig | 53 +++ include/configs/mx6qsabreauto.h | 4 + 4 files changed, 581 insertions(+), 115 deletions(-) create mode 100644 configs/mx6qsabreauto_spl_defconfig
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 4fd60d4..0d500aa 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -205,6 +205,7 @@ config TARGET_MX6Q_ICORE_RQS config TARGET_MX6QSABREAUTO bool "mx6qsabreauto" select BOARD_LATE_INIT + select SUPPORT_SPL select DM select DM_THERMAL select BOARD_EARLY_INIT_F diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index 51bbbc4..927ebe4 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -70,38 +70,51 @@ int dram_init(void) }
static iomux_v3_cfg_t const uart4_pads[] = { - MX6_PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
static iomux_v3_cfg_t const enet_pads[] = { - MX6_PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + IOMUX_PADS(PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), };
/* I2C2 PMIC, iPod, Tuner, Codec, Touch, HDMI EDID, MIPI CSI2 card */ -static struct i2c_pads_info i2c_pad_info1 = { +static struct i2c_pads_info mx6q_i2c_pad_info1 = { .scl = { - .i2c_mode = MX6_PAD_EIM_EB2__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | PC, + .i2c_mode = MX6Q_PAD_EIM_EB2__I2C2_SCL | PC, + .gpio_mode = MX6Q_PAD_EIM_EB2__GPIO2_IO30 | PC, .gp = IMX_GPIO_NR(2, 30) }, .sda = { - .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, + .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +static struct i2c_pads_info mx6dl_i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6DL_PAD_EIM_EB2__I2C2_SCL | PC, + .gpio_mode = MX6DL_PAD_EIM_EB2__GPIO2_IO30 | PC, + .gp = IMX_GPIO_NR(2, 30) + }, + .sda = { + .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | PC, .gp = IMX_GPIO_NR(4, 13) } }; @@ -111,26 +124,39 @@ static struct i2c_pads_info i2c_pad_info1 = { * I2C3 MLB, Port Expanders (A, B, C), Video ADC, Light Sensor, * Compass Sensor, Accelerometer, Res Touch */ -static struct i2c_pads_info i2c_pad_info2 = { +static struct i2c_pads_info mx6q_i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6Q_PAD_GPIO_3__I2C3_SCL | PC, + .gpio_mode = MX6Q_PAD_GPIO_3__GPIO1_IO03 | PC, + .gp = IMX_GPIO_NR(1, 3) + }, + .sda = { + .i2c_mode = MX6Q_PAD_EIM_D18__I2C3_SDA | PC, + .gpio_mode = MX6Q_PAD_EIM_D18__GPIO3_IO18 | PC, + .gp = IMX_GPIO_NR(3, 18) + } +}; + +static struct i2c_pads_info mx6dl_i2c_pad_info2 = { .scl = { - .i2c_mode = MX6_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_GPIO_3__GPIO1_IO03 | PC, + .i2c_mode = MX6DL_PAD_GPIO_3__I2C3_SCL | PC, + .gpio_mode = MX6DL_PAD_GPIO_3__GPIO1_IO03 | PC, .gp = IMX_GPIO_NR(1, 3) }, .sda = { - .i2c_mode = MX6_PAD_EIM_D18__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D18__GPIO3_IO18 | PC, + .i2c_mode = MX6DL_PAD_EIM_D18__I2C3_SDA | PC, + .gpio_mode = MX6DL_PAD_EIM_D18__GPIO3_IO18 | PC, .gp = IMX_GPIO_NR(3, 18) } }; #endif
static iomux_v3_cfg_t const i2c3_pads[] = { - MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static iomux_v3_cfg_t const port_exp[] = { - MX6_PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
/*Define for building port exp gpio, pin starts from 0*/ @@ -172,49 +198,49 @@ static int port_exp_direction_output(unsigned gpio, int value) }
static iomux_v3_cfg_t const eimnor_pads[] = { - MX6_PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL) , - MX6_PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL), - MX6_PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static void eimnor_cs_setup(void) @@ -260,7 +286,7 @@ static void eim_clk_setup(void)
static void setup_iomux_eimnor(void) { - imx_iomux_v3_setup_multiple_pads(eimnor_pads, ARRAY_SIZE(eimnor_pads)); + SETUP_IOMUX_PADS(eimnor_pads);
gpio_direction_output(IMX_GPIO_NR(5, 4), 0);
@@ -269,27 +295,27 @@ static void setup_iomux_eimnor(void)
static void setup_iomux_enet(void) { - imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + SETUP_IOMUX_PADS(enet_pads); }
static iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_GPIO_18__SD3_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_GPIO_18__SD3_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static void setup_iomux_uart(void) { - imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); + SETUP_IOMUX_PADS(uart4_pads); }
#ifdef CONFIG_FSL_ESDHC @@ -305,7 +331,7 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { - imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + SETUP_IOMUX_PADS(usdhc3_pads);
usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); @@ -314,22 +340,22 @@ int board_mmc_init(bd_t *bis)
#ifdef CONFIG_NAND_MXS static iomux_v3_cfg_t gpmi_pads[] = { - MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL0), - MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2), - MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(GPMI_PAD_CTRL1), + IOMUX_PADS(PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL0)), + IOMUX_PADS(PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)), + IOMUX_PADS(PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(GPMI_PAD_CTRL1)), };
static void setup_gpmi_nand(void) @@ -337,7 +363,7 @@ static void setup_gpmi_nand(void) struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
/* config gpmi nand iomux */ - imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads)); + SETUP_IOMUX_PADS(gpmi_pads);
setup_gpmi_io_clk((MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | @@ -465,14 +491,13 @@ struct display_info_t const displays[] = {{ size_t display_count = ARRAY_SIZE(displays);
iomux_v3_cfg_t const backlight_pads[] = { - MX6_PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(ENET_PAD_CTRL), + IOMUX_PADS(PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(ENET_PAD_CTRL)), };
static void setup_iomux_backlight(void) { gpio_direction_output(IMX_GPIO_NR(2, 9), 1); - imx_iomux_v3_setup_multiple_pads(backlight_pads, - ARRAY_SIZE(backlight_pads)); + SETUP_IOMUX_PADS(backlight_pads); }
static void setup_display(void) @@ -557,15 +582,21 @@ int board_init(void) gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
/* I2C 2 and 3 setup - I2C 3 hw mux with EIM */ - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + if (is_mx6dq() || is_mx6dqp()) + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info1); + else + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1); /* I2C 3 Steer */ gpio_direction_output(IMX_GPIO_NR(5, 4), 1); - imx_iomux_v3_setup_multiple_pads(i2c3_pads, ARRAY_SIZE(i2c3_pads)); + SETUP_IOMUX_PADS(i2c3_pads); #ifndef CONFIG_SYS_FLASH_CFI - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + if (is_mx6dq() || is_mx6dqp()) + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c_pad_info2); + else + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info2); #endif gpio_direction_output(IMX_GPIO_NR(1, 15), 1); - imx_iomux_v3_setup_multiple_pads(port_exp, ARRAY_SIZE(port_exp)); + SETUP_IOMUX_PADS(port_exp);
#ifdef CONFIG_VIDEO_IPUV3 setup_display(); @@ -654,15 +685,14 @@ int checkboard(void) #define USB_OTG_PWR PORTEXP_IO_NR(0x34, 1)
iomux_v3_cfg_t const usb_otg_pads[] = { - MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL)), };
int board_ehci_hcd_init(int port) { switch (port) { case 0: - imx_iomux_v3_setup_multiple_pads(usb_otg_pads, - ARRAY_SIZE(usb_otg_pads)); + SETUP_IOMUX_PADS(usb_otg_pads);
/* * Set daisy chain for otg_pin_id on 6q. @@ -702,3 +732,381 @@ int board_ehci_power(int port, int on) return 0; } #endif + +#ifdef CONFIG_SPL_BUILD +#include <asm/arch/mx6-ddr.h> +#include <spl.h> +#include <libfdt.h> + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + if (is_mx6dqp()) { + /* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); + } else { + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); + } +} + +static int mx6q_dcd_table[] = { + 0x020e0798, 0x000C0000, + 0x020e0758, 0x00000000, + 0x020e0588, 0x00000030, + 0x020e0594, 0x00000030, + 0x020e056c, 0x00000030, + 0x020e0578, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e057c, 0x00000030, + 0x020e058c, 0x00000000, + 0x020e059c, 0x00000030, + 0x020e05a0, 0x00000030, + 0x020e078c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e05a8, 0x00000028, + 0x020e05b0, 0x00000028, + 0x020e0524, 0x00000028, + 0x020e051c, 0x00000028, + 0x020e0518, 0x00000028, + 0x020e050c, 0x00000028, + 0x020e05b8, 0x00000028, + 0x020e05c0, 0x00000028, + 0x020e0774, 0x00020000, + 0x020e0784, 0x00000028, + 0x020e0788, 0x00000028, + 0x020e0794, 0x00000028, + 0x020e079c, 0x00000028, + 0x020e07a0, 0x00000028, + 0x020e07a4, 0x00000028, + 0x020e07a8, 0x00000028, + 0x020e0748, 0x00000028, + 0x020e05ac, 0x00000028, + 0x020e05b4, 0x00000028, + 0x020e0528, 0x00000028, + 0x020e0520, 0x00000028, + 0x020e0514, 0x00000028, + 0x020e0510, 0x00000028, + 0x020e05bc, 0x00000028, + 0x020e05c4, 0x00000028, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001F001F, + 0x021b0810, 0x001F001F, + 0x021b480c, 0x001F001F, + 0x021b4810, 0x001F001F, + 0x021b083c, 0x43260335, + 0x021b0840, 0x031A030B, + 0x021b483c, 0x4323033B, + 0x021b4840, 0x0323026F, + 0x021b0848, 0x483D4545, + 0x021b4848, 0x44433E48, + 0x021b0850, 0x41444840, + 0x021b4850, 0x4835483E, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x00020036, + 0x021b0008, 0x09444040, + 0x021b000c, 0x8A8F7955, + 0x021b0010, 0xFF328F64, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x008F1023, + 0x021b0040, 0x00000047, + 0x021b0000, 0x841A0000, + 0x021b001c, 0x04088032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x09408030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x00025576, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + 0x020c4068, 0x00C03F3F, + 0x020c406c, 0x0030FC03, + 0x020c4070, 0x0FFFC000, + 0x020c4074, 0x3FF00000, + 0x020c4078, 0xFFFFF300, + 0x020c407c, 0x0F0000F3, + 0x020c4080, 0x00000FFF, + 0x020e0010, 0xF00000CF, + 0x020e0018, 0x007F007F, + 0x020e001c, 0x007F007F, +}; + +static int mx6qp_dcd_table[] = { + 0x020e0798, 0x000C0000, + 0x020e0758, 0x00000000, + 0x020e0588, 0x00000030, + 0x020e0594, 0x00000030, + 0x020e056c, 0x00000030, + 0x020e0578, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e057c, 0x00000030, + 0x020e058c, 0x00000000, + 0x020e059c, 0x00000030, + 0x020e05a0, 0x00000030, + 0x020e078c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e05a8, 0x00000030, + 0x020e05b0, 0x00000030, + 0x020e0524, 0x00000030, + 0x020e051c, 0x00000030, + 0x020e0518, 0x00000030, + 0x020e050c, 0x00000030, + 0x020e05b8, 0x00000030, + 0x020e05c0, 0x00000030, + 0x020e0774, 0x00020000, + 0x020e0784, 0x00000030, + 0x020e0788, 0x00000030, + 0x020e0794, 0x00000030, + 0x020e079c, 0x00000030, + 0x020e07a0, 0x00000030, + 0x020e07a4, 0x00000030, + 0x020e07a8, 0x00000030, + 0x020e0748, 0x00000030, + 0x020e05ac, 0x00000030, + 0x020e05b4, 0x00000030, + 0x020e0528, 0x00000030, + 0x020e0520, 0x00000030, + 0x020e0514, 0x00000030, + 0x020e0510, 0x00000030, + 0x020e05bc, 0x00000030, + 0x020e05c4, 0x00000030, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001b001e, + 0x021b0810, 0x002e0029, + 0x021b480c, 0x001b002a, + 0x021b4810, 0x0019002c, + 0x021b083c, 0x43240334, + 0x021b0840, 0x0324031a, + 0x021b483c, 0x43340344, + 0x021b4840, 0x03280276, + 0x021b0848, 0x44383A3E, + 0x021b4848, 0x3C3C3846, + 0x021b0850, 0x2e303230, + 0x021b4850, 0x38283E34, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08c0, 0x24912492, + 0x021b48c0, 0x24912492, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x00020036, + 0x021b0008, 0x09444040, + 0x021b000c, 0x898E7955, + 0x021b0010, 0xFF328F64, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x008E1023, + 0x021b0040, 0x00000047, + 0x021b0400, 0x14420000, + 0x021b0000, 0x841A0000, + 0x00bb0008, 0x00000004, + 0x00bb000c, 0x2891E41A, + 0x00bb0038, 0x00000564, + 0x00bb0014, 0x00000040, + 0x00bb0028, 0x00000020, + 0x00bb002c, 0x00000020, + 0x021b001c, 0x04088032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x09408030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x00025576, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + 0x020c4068, 0x00C03F3F, + 0x020c406c, 0x0030FC03, + 0x020c4070, 0x0FFFC000, + 0x020c4074, 0x3FF00000, + 0x020c4078, 0xFFFFF300, + 0x020c407c, 0x0F0000F3, + 0x020c4080, 0x00000FFF, + 0x020e0010, 0xF00000CF, + 0x020e0018, 0x77177717, + 0x020e001c, 0x77177717, +}; + +static int mx6dl_dcd_table[] = { + 0x020e0774, 0x000C0000, + 0x020e0754, 0x00000000, + 0x020e04ac, 0x00000030, + 0x020e04b0, 0x00000030, + 0x020e0464, 0x00000030, + 0x020e0490, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e0494, 0x00000030, + 0x020e04a0, 0x00000000, + 0x020e04b4, 0x00000030, + 0x020e04b8, 0x00000030, + 0x020e076c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e04bc, 0x00000028, + 0x020e04c0, 0x00000028, + 0x020e04c4, 0x00000028, + 0x020e04c8, 0x00000028, + 0x020e04cc, 0x00000028, + 0x020e04d0, 0x00000028, + 0x020e04d4, 0x00000028, + 0x020e04d8, 0x00000028, + 0x020e0760, 0x00020000, + 0x020e0764, 0x00000028, + 0x020e0770, 0x00000028, + 0x020e0778, 0x00000028, + 0x020e077c, 0x00000028, + 0x020e0780, 0x00000028, + 0x020e0784, 0x00000028, + 0x020e078c, 0x00000028, + 0x020e0748, 0x00000028, + 0x020e0470, 0x00000028, + 0x020e0474, 0x00000028, + 0x020e0478, 0x00000028, + 0x020e047c, 0x00000028, + 0x020e0480, 0x00000028, + 0x020e0484, 0x00000028, + 0x020e0488, 0x00000028, + 0x020e048c, 0x00000028, + 0x021b0800, 0xa1390003, + 0x021b080c, 0x001F001F, + 0x021b0810, 0x001F001F, + 0x021b480c, 0x001F001F, + 0x021b4810, 0x001F001F, + 0x021b083c, 0x42190217, + 0x021b0840, 0x017B017B, + 0x021b483c, 0x4176017B, + 0x021b4840, 0x015F016C, + 0x021b0848, 0x4C4C4D4C, + 0x021b4848, 0x4A4D4C48, + 0x021b0850, 0x3F3F3F40, + 0x021b4850, 0x3538382E, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b481c, 0x33333333, + 0x021b4820, 0x33333333, + 0x021b4824, 0x33333333, + 0x021b4828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b48b8, 0x00000800, + 0x021b0004, 0x00020025, + 0x021b0008, 0x00333030, + 0x021b000c, 0x676B5313, + 0x021b0010, 0xB66E8B63, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00001740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026d2, + 0x021b0030, 0x006B1023, + 0x021b0040, 0x00000047, + 0x021b0000, 0x841A0000, + 0x021b001c, 0x04008032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x05208030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00005800, + 0x021b0818, 0x00011117, + 0x021b4818, 0x00011117, + 0x021b0004, 0x00025565, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + 0x020c4068, 0x00C03F3F, + 0x020c406c, 0x0030FC03, + 0x020c4070, 0x0FFFC000, + 0x020c4074, 0x3FF00000, + 0x020c4078, 0xFFFFF300, + 0x020c407c, 0x0F0000C3, + 0x020c4080, 0x00000FFF, + 0x020e0010, 0xF00000CF, + 0x020e0018, 0x007F007F, + 0x020e001c, 0x007F007F, +}; + +static void ddr_init(int *table, int size) +{ + int i; + + for (i = 0; i < size / 2 ; i++) + writel(table[2 * i + 1], table[2 * i]); +} + +static void spl_dram_init(void) +{ + if (is_mx6dq()) + ddr_init(mx6q_dcd_table, ARRAY_SIZE(mx6q_dcd_table)); + else if (is_mx6dqp()) + ddr_init(mx6qp_dcd_table, ARRAY_SIZE(mx6qp_dcd_table)); + else if (is_mx6sdl()) + ddr_init(mx6dl_dcd_table, ARRAY_SIZE(mx6dl_dcd_table)); +} + +void board_init_f(ulong dummy) +{ + /* DDR initialization */ + spl_dram_init(); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* iomux and setup of i2c */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif diff --git a/configs/mx6qsabreauto_spl_defconfig b/configs/mx6qsabreauto_spl_defconfig new file mode 100644 index 0000000..ce2d1d2 --- /dev/null +++ b/configs/mx6qsabreauto_spl_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_BOOTDELAY=3 +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SPL=y +CONFIG_SPL_EXT_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_DFU_MMC=y +CONFIG_DFU_SF=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="FSL" +CONFIG_G_DNL_VENDOR_NUM=0x0525 +CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +# CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_OF_LIBFDT=y diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 635c04a..99b48ca 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -9,6 +9,10 @@ #ifndef __MX6QSABREAUTO_CONFIG_H #define __MX6QSABREAUTO_CONFIG_H
+#ifdef CONFIG_SPL +#include "imx6_spl.h" +#endif + #define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE #define CONSOLE_DEV "ttymxc3"
On Thu, Jun 29, 2017 at 9:33 AM, Vanessa Maegima vanessa.maegima@nxp.com wrote:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
- select SUPPORT_SPL select DM select DM_THERMAL select BOARD_EARLY_INIT_F
- IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_KEY_COL1__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_KEY_COL2__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)),
.gp = IMX_GPIO_NR(2, 30) }, .sda = {.gpio_mode = MX6Q_PAD_EIM_EB2__GPIO2_IO30 | PC,
- .scl = {
- .sda = {
.gp = IMX_GPIO_NR(4, 13) }.gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | PC,
- I2C3 MLB, Port Expanders (A, B, C), Video ADC, Light Sensor,
- Compass Sensor, Accelerometer, Res Touch
- .scl = {
- .sda = {
.gp = IMX_GPIO_NR(1, 3) }, .sda = {.gpio_mode = MX6DL_PAD_GPIO_3__GPIO1_IO03 | PC,
.gp = IMX_GPIO_NR(3, 18) }.gpio_mode = MX6DL_PAD_EIM_D18__GPIO3_IO18 | PC,
}; #endif
- IOMUX_PADS(PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_SD2_DAT0__GPIO1_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D18__EIM_DATA18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D19__EIM_DATA19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D20__EIM_DATA20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D21__EIM_DATA21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D22__EIM_DATA22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D23__EIM_DATA23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D24__EIM_DATA24 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D25__EIM_DATA25 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D26__EIM_DATA26 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D27__EIM_DATA27 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D28__EIM_DATA28 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D29__EIM_DATA29 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D30__EIM_DATA30 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D31__EIM_DATA31 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA0__EIM_AD00 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA1__EIM_AD01 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA2__EIM_AD02 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA3__EIM_AD03 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA4__EIM_AD04 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA5__EIM_AD05 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA6__EIM_AD06 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA7__EIM_AD07 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA8__EIM_AD08 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA9__EIM_AD09 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA10__EIM_AD10 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA11__EIM_AD11 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA12__EIM_AD12 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA13__EIM_AD13 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA14__EIM_AD14 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_DA15__EIM_AD15 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A16__EIM_ADDR16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A17__EIM_ADDR17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A18__EIM_ADDR18 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A19__EIM_ADDR19 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A20__EIM_ADDR20 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A21__EIM_ADDR21 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A22__EIM_ADDR22 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_A23__EIM_ADDR23 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_OE__EIM_OE_B | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_RW__EIM_RW | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_CS0__EIM_CS0_B | MUX_PAD_CTRL(NO_PAD_CTRL)),
- SETUP_IOMUX_PADS(enet_pads);
- IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_GPIO_18__SD3_VSELECT | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- SETUP_IOMUX_PADS(uart4_pads);
- IOMUX_PADS(PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(GPMI_PAD_CTRL0)),
- IOMUX_PADS(PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(GPMI_PAD_CTRL2)),
- IOMUX_PADS(PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(GPMI_PAD_CTRL1)),
- IOMUX_PADS(PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- SETUP_IOMUX_PADS(backlight_pads);
- if (is_mx6dq() || is_mx6dqp())
- else
/* I2C 3 Steer */ gpio_direction_output(IMX_GPIO_NR(5, 4), 1);setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c_pad_info1);
- SETUP_IOMUX_PADS(i2c3_pads);
- else
- SETUP_IOMUX_PADS(port_exp);
- IOMUX_PADS(PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL)),
- Set daisy chain for otg_pin_id on 6q.
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0x00C03F3F, &ccm->CCGR0);
- writel(0x0030FC03, &ccm->CCGR1);
- writel(0x0FFFC000, &ccm->CCGR2);
- writel(0x3FF00000, &ccm->CCGR3);
- writel(0x00FFF300, &ccm->CCGR4);
- writel(0x0F0000C3, &ccm->CCGR5);
- writel(0x000003FF, &ccm->CCGR6);
- struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR;
- /* enable AXI cache for VDOA/VPU/IPU */
- writel(0xF00000CF, &iomux->gpr[4]);
- if (is_mx6dqp()) {
- } else {
- 0x020e0798, 0x000C0000,
- 0x020e0758, 0x00000000,
- 0x020e0588, 0x00000030,
- 0x020e0594, 0x00000030,
- 0x020e056c, 0x00000030,
- 0x020e0578, 0x00000030,
- 0x020e074c, 0x00000030,
- 0x020e057c, 0x00000030,
- 0x020e058c, 0x00000000,
- 0x020e059c, 0x00000030,
- 0x020e05a0, 0x00000030,
- 0x020e078c, 0x00000030,
- 0x020e0750, 0x00020000,
- 0x020e05a8, 0x00000028,
- 0x020e05b0, 0x00000028,
- 0x020e0524, 0x00000028,
- 0x020e051c, 0x00000028,
- 0x020e0518, 0x00000028,
- 0x020e050c, 0x00000028,
- 0x020e05b8, 0x00000028,
- 0x020e05c0, 0x00000028,
- 0x020e0774, 0x00020000,
- 0x020e0784, 0x00000028,
- 0x020e0788, 0x00000028,
- 0x020e0794, 0x00000028,
- 0x020e079c, 0x00000028,
- 0x020e07a0, 0x00000028,
- 0x020e07a4, 0x00000028,
- 0x020e07a8, 0x00000028,
- 0x020e0748, 0x00000028,
- 0x020e05ac, 0x00000028,
- 0x020e05b4, 0x00000028,
- 0x020e0528, 0x00000028,
- 0x020e0520, 0x00000028,
- 0x020e0514, 0x00000028,
- 0x020e0510, 0x00000028,
- 0x020e05bc, 0x00000028,
- 0x020e05c4, 0x00000028,
- 0x021b0800, 0xa1390003,
- 0x021b080c, 0x001F001F,
- 0x021b0810, 0x001F001F,
- 0x021b480c, 0x001F001F,
- 0x021b4810, 0x001F001F,
- 0x021b083c, 0x43260335,
- 0x021b0840, 0x031A030B,
- 0x021b483c, 0x4323033B,
- 0x021b4840, 0x0323026F,
- 0x021b0848, 0x483D4545,
- 0x021b4848, 0x44433E48,
- 0x021b0850, 0x41444840,
- 0x021b4850, 0x4835483E,
- 0x021b081c, 0x33333333,
- 0x021b0820, 0x33333333,
- 0x021b0824, 0x33333333,
- 0x021b0828, 0x33333333,
- 0x021b481c, 0x33333333,
- 0x021b4820, 0x33333333,
- 0x021b4824, 0x33333333,
- 0x021b4828, 0x33333333,
- 0x021b08b8, 0x00000800,
- 0x021b48b8, 0x00000800,
- 0x021b0004, 0x00020036,
- 0x021b0008, 0x09444040,
- 0x021b000c, 0x8A8F7955,
- 0x021b0010, 0xFF328F64,
- 0x021b0014, 0x01FF00DB,
- 0x021b0018, 0x00001740,
- 0x021b001c, 0x00008000,
- 0x021b002c, 0x000026d2,
- 0x021b0030, 0x008F1023,
- 0x021b0040, 0x00000047,
- 0x021b0000, 0x841A0000,
- 0x021b001c, 0x04088032,
- 0x021b001c, 0x00008033,
- 0x021b001c, 0x00048031,
- 0x021b001c, 0x09408030,
- 0x021b001c, 0x04008040,
- 0x021b0020, 0x00005800,
- 0x021b0818, 0x00011117,
- 0x021b4818, 0x00011117,
- 0x021b0004, 0x00025576,
- 0x021b0404, 0x00011006,
- 0x021b001c, 0x00000000,
- 0x020c4068, 0x00C03F3F,
- 0x020c406c, 0x0030FC03,
- 0x020c4070, 0x0FFFC000,
- 0x020c4074, 0x3FF00000,
- 0x020c4078, 0xFFFFF300,
- 0x020c407c, 0x0F0000F3,
- 0x020c4080, 0x00000FFF,
- 0x020e0010, 0xF00000CF,
- 0x020e0018, 0x007F007F,
- 0x020e001c, 0x007F007F,
- 0x020e05a8, 0x00000030,
- 0x020e05b0, 0x00000030,
- 0x020e0524, 0x00000030,
- 0x020e051c, 0x00000030,
- 0x020e0518, 0x00000030,
- 0x020e050c, 0x00000030,
- 0x020e05b8, 0x00000030,
- 0x020e05c0, 0x00000030,
- 0x020e0784, 0x00000030,
- 0x020e0788, 0x00000030,
- 0x020e0794, 0x00000030,
- 0x020e079c, 0x00000030,
- 0x020e07a0, 0x00000030,
- 0x020e07a4, 0x00000030,
- 0x020e07a8, 0x00000030,
- 0x020e0748, 0x00000030,
- 0x020e05ac, 0x00000030,
- 0x020e05b4, 0x00000030,
- 0x020e0528, 0x00000030,
- 0x020e0520, 0x00000030,
- 0x020e0514, 0x00000030,
- 0x020e0510, 0x00000030,
- 0x020e05bc, 0x00000030,
- 0x020e05c4, 0x00000030,
- 0x021b080c, 0x001b001e,
- 0x021b0810, 0x002e0029,
- 0x021b480c, 0x001b002a,
- 0x021b4810, 0x0019002c,
- 0x021b083c, 0x43240334,
- 0x021b0840, 0x0324031a,
- 0x021b483c, 0x43340344,
- 0x021b4840, 0x03280276,
- 0x021b0848, 0x44383A3E,
- 0x021b4848, 0x3C3C3846,
- 0x021b0850, 0x2e303230,
- 0x021b4850, 0x38283E34,
- 0x021b08c0, 0x24912492,
- 0x021b48c0, 0x24912492,
- 0x021b000c, 0x898E7955,
- 0x021b0030, 0x008E1023,
- 0x021b0400, 0x14420000,
- 0x00bb0008, 0x00000004,
- 0x00bb000c, 0x2891E41A,
- 0x00bb0038, 0x00000564,
- 0x00bb0014, 0x00000040,
- 0x00bb0028, 0x00000020,
- 0x00bb002c, 0x00000020,
- 0x020e0018, 0x77177717,
- 0x020e001c, 0x77177717,
- 0x020e0774, 0x000C0000,
- 0x020e0754, 0x00000000,
- 0x020e04ac, 0x00000030,
- 0x020e04b0, 0x00000030,
- 0x020e0464, 0x00000030,
- 0x020e0490, 0x00000030,
- 0x020e0494, 0x00000030,
- 0x020e04a0, 0x00000000,
- 0x020e04b4, 0x00000030,
- 0x020e04b8, 0x00000030,
- 0x020e076c, 0x00000030,
- 0x020e04bc, 0x00000028,
- 0x020e04c0, 0x00000028,
- 0x020e04c4, 0x00000028,
- 0x020e04c8, 0x00000028,
- 0x020e04cc, 0x00000028,
- 0x020e04d0, 0x00000028,
- 0x020e04d4, 0x00000028,
- 0x020e04d8, 0x00000028,
- 0x020e0760, 0x00020000,
- 0x020e0764, 0x00000028,
- 0x020e0770, 0x00000028,
- 0x020e0778, 0x00000028,
- 0x020e077c, 0x00000028,
- 0x020e0780, 0x00000028,
- 0x020e078c, 0x00000028,
- 0x020e0470, 0x00000028,
- 0x020e0474, 0x00000028,
- 0x020e0478, 0x00000028,
- 0x020e047c, 0x00000028,
- 0x020e0480, 0x00000028,
- 0x020e0484, 0x00000028,
- 0x020e0488, 0x00000028,
- 0x020e048c, 0x00000028,
- 0x021b083c, 0x42190217,
- 0x021b0840, 0x017B017B,
- 0x021b483c, 0x4176017B,
- 0x021b4840, 0x015F016C,
- 0x021b0848, 0x4C4C4D4C,
- 0x021b4848, 0x4A4D4C48,
- 0x021b0850, 0x3F3F3F40,
- 0x021b4850, 0x3538382E,
- 0x021b0004, 0x00020025,
- 0x021b0008, 0x00333030,
- 0x021b000c, 0x676B5313,
- 0x021b0010, 0xB66E8B63,
- 0x021b0030, 0x006B1023,
- 0x021b001c, 0x04008032,
- 0x021b001c, 0x05208030,
- 0x021b0004, 0x00025565,
- 0x020c407c, 0x0F0000C3,
- int i;
- for (i = 0; i < size / 2 ; i++)
- if (is_mx6dq())
- else if (is_mx6dqp())
- else if (is_mx6sdl())
- /* DDR initialization */
- spl_dram_init();
- /* setup AIPS and disable watchdog */
- arch_cpu_init();
- ccgr_init();
- gpr_init();
- /* iomux and setup of i2c */
- board_early_init_f();
- /* setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- /* load/boot image from boot device */
- board_init_r(NULL, 0);
It looks ok to me.
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano
As mx6sabreauto supports SPL now, all variants can boot using the same defconfig.
This patch: - Removes non-SPL targets. - Renames target to mx6sabreauto_defconfig. - Renames folder and board files to mx6sabreauto. - Updates MAINTAINERS, Makefile and Kconfig accordingly. - Removes .cfg files. - Adds a README with instructions to build and flash SPL and u-boot.img.
Signed-off-by: Vanessa Maegima vanessa.maegima@nxp.com --- arch/arm/cpu/armv7/mx6/Kconfig | 6 +- board/freescale/mx6qsabreauto/MAINTAINERS | 9 -- board/freescale/mx6qsabreauto/imximage.cfg | 129 ------------------ board/freescale/mx6qsabreauto/mx6dl.cfg | 130 ------------------ board/freescale/mx6qsabreauto/mx6qp.cfg | 145 --------------------- .../{mx6qsabreauto => mx6sabreauto}/Kconfig | 6 +- board/freescale/mx6sabreauto/MAINTAINERS | 7 + .../{mx6qsabreauto => mx6sabreauto}/Makefile | 2 +- board/freescale/mx6sabreauto/README | 20 +++ .../mx6sabreauto.c} | 0 configs/mx6dlsabreauto_defconfig | 44 ------- configs/mx6qpsabreauto_defconfig | 43 ------ configs/mx6qsabreauto_defconfig | 44 ------- ...reauto_spl_defconfig => mx6sabreauto_defconfig} | 2 +- .../configs/{mx6qsabreauto.h => mx6sabreauto.h} | 6 +- 15 files changed, 38 insertions(+), 555 deletions(-) delete mode 100644 board/freescale/mx6qsabreauto/MAINTAINERS delete mode 100644 board/freescale/mx6qsabreauto/imximage.cfg delete mode 100644 board/freescale/mx6qsabreauto/mx6dl.cfg delete mode 100644 board/freescale/mx6qsabreauto/mx6qp.cfg rename board/freescale/{mx6qsabreauto => mx6sabreauto}/Kconfig (54%) create mode 100644 board/freescale/mx6sabreauto/MAINTAINERS rename board/freescale/{mx6qsabreauto => mx6sabreauto}/Makefile (85%) create mode 100644 board/freescale/mx6sabreauto/README rename board/freescale/{mx6qsabreauto/mx6qsabreauto.c => mx6sabreauto/mx6sabreauto.c} (100%) delete mode 100644 configs/mx6dlsabreauto_defconfig delete mode 100644 configs/mx6qpsabreauto_defconfig delete mode 100644 configs/mx6qsabreauto_defconfig rename configs/{mx6qsabreauto_spl_defconfig => mx6sabreauto_defconfig} (97%) rename include/configs/{mx6qsabreauto.h => mx6sabreauto.h} (94%)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 0d500aa..4a38dc2 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -202,8 +202,8 @@ config TARGET_MX6Q_ICORE_RQS select SUPPORT_SPL select SPL_LOAD_FIT
-config TARGET_MX6QSABREAUTO - bool "mx6qsabreauto" +config TARGET_MX6SABREAUTO + bool "mx6sabreauto" select BOARD_LATE_INIT select SUPPORT_SPL select DM @@ -413,7 +413,7 @@ source "board/engicam/icorem6/Kconfig" source "board/engicam/icorem6_rqs/Kconfig" source "board/engicam/isiotmx6ul/Kconfig" source "board/freescale/mx6qarm2/Kconfig" -source "board/freescale/mx6qsabreauto/Kconfig" +source "board/freescale/mx6sabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" source "board/freescale/mx6slevk/Kconfig" source "board/freescale/mx6sllevk/Kconfig" diff --git a/board/freescale/mx6qsabreauto/MAINTAINERS b/board/freescale/mx6qsabreauto/MAINTAINERS deleted file mode 100644 index f148dac..0000000 --- a/board/freescale/mx6qsabreauto/MAINTAINERS +++ /dev/null @@ -1,9 +0,0 @@ -MX6QSABREAUTO BOARD -M: Fabio Estevam fabio.estevam@nxp.com -M: Peng Fan peng.fan@nxp.com -S: Maintained -F: board/freescale/mx6qsabreauto/ -F: include/configs/mx6qsabreauto.h -F: configs/mx6dlsabreauto_defconfig -F: configs/mx6qsabreauto_defconfig -F: configs/mx6qpsabreauto_defconfig diff --git a/board/freescale/mx6qsabreauto/imximage.cfg b/board/freescale/mx6qsabreauto/imximage.cfg deleted file mode 100644 index 16bf473..0000000 --- a/board/freescale/mx6qsabreauto/imximage.cfg +++ /dev/null @@ -1,129 +0,0 @@ -/* - * Copyright (C) 2012 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ -/* image version */ - -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ -DATA 4 0x020e0798 0x000C0000 -DATA 4 0x020e0758 0x00000000 -DATA 4 0x020e0588 0x00000030 -DATA 4 0x020e0594 0x00000030 -DATA 4 0x020e056c 0x00000030 -DATA 4 0x020e0578 0x00000030 -DATA 4 0x020e074c 0x00000030 -DATA 4 0x020e057c 0x00000030 -DATA 4 0x020e058c 0x00000000 -DATA 4 0x020e059c 0x00000030 -DATA 4 0x020e05a0 0x00000030 -DATA 4 0x020e078c 0x00000030 -DATA 4 0x020e0750 0x00020000 -DATA 4 0x020e05a8 0x00000028 -DATA 4 0x020e05b0 0x00000028 -DATA 4 0x020e0524 0x00000028 -DATA 4 0x020e051c 0x00000028 -DATA 4 0x020e0518 0x00000028 -DATA 4 0x020e050c 0x00000028 -DATA 4 0x020e05b8 0x00000028 -DATA 4 0x020e05c0 0x00000028 -DATA 4 0x020e0774 0x00020000 -DATA 4 0x020e0784 0x00000028 -DATA 4 0x020e0788 0x00000028 -DATA 4 0x020e0794 0x00000028 -DATA 4 0x020e079c 0x00000028 -DATA 4 0x020e07a0 0x00000028 -DATA 4 0x020e07a4 0x00000028 -DATA 4 0x020e07a8 0x00000028 -DATA 4 0x020e0748 0x00000028 -DATA 4 0x020e05ac 0x00000028 -DATA 4 0x020e05b4 0x00000028 -DATA 4 0x020e0528 0x00000028 -DATA 4 0x020e0520 0x00000028 -DATA 4 0x020e0514 0x00000028 -DATA 4 0x020e0510 0x00000028 -DATA 4 0x020e05bc 0x00000028 -DATA 4 0x020e05c4 0x00000028 -DATA 4 0x021b0800 0xa1390003 -DATA 4 0x021b080c 0x001F001F -DATA 4 0x021b0810 0x001F001F -DATA 4 0x021b480c 0x001F001F -DATA 4 0x021b4810 0x001F001F -DATA 4 0x021b083c 0x43260335 -DATA 4 0x021b0840 0x031A030B -DATA 4 0x021b483c 0x4323033B -DATA 4 0x021b4840 0x0323026F -DATA 4 0x021b0848 0x483D4545 -DATA 4 0x021b4848 0x44433E48 -DATA 4 0x021b0850 0x41444840 -DATA 4 0x021b4850 0x4835483E -DATA 4 0x021b081c 0x33333333 -DATA 4 0x021b0820 0x33333333 -DATA 4 0x021b0824 0x33333333 -DATA 4 0x021b0828 0x33333333 -DATA 4 0x021b481c 0x33333333 -DATA 4 0x021b4820 0x33333333 -DATA 4 0x021b4824 0x33333333 -DATA 4 0x021b4828 0x33333333 -DATA 4 0x021b08b8 0x00000800 -DATA 4 0x021b48b8 0x00000800 -DATA 4 0x021b0004 0x00020036 -DATA 4 0x021b0008 0x09444040 -DATA 4 0x021b000c 0x8A8F7955 -DATA 4 0x021b0010 0xFF328F64 -DATA 4 0x021b0014 0x01FF00DB -DATA 4 0x021b0018 0x00001740 -DATA 4 0x021b001c 0x00008000 -DATA 4 0x021b002c 0x000026d2 -DATA 4 0x021b0030 0x008F1023 -DATA 4 0x021b0040 0x00000047 -DATA 4 0x021b0000 0x841A0000 -DATA 4 0x021b001c 0x04088032 -DATA 4 0x021b001c 0x00008033 -DATA 4 0x021b001c 0x00048031 -DATA 4 0x021b001c 0x09408030 -DATA 4 0x021b001c 0x04008040 -DATA 4 0x021b0020 0x00005800 -DATA 4 0x021b0818 0x00011117 -DATA 4 0x021b4818 0x00011117 -DATA 4 0x021b0004 0x00025576 -DATA 4 0x021b0404 0x00011006 -DATA 4 0x021b001c 0x00000000 - -/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0xFFFFF300 -DATA 4 0x020c407c 0x0F0000F3 -DATA 4 0x020c4080 0x00000FFF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F diff --git a/board/freescale/mx6qsabreauto/mx6dl.cfg b/board/freescale/mx6qsabreauto/mx6dl.cfg deleted file mode 100644 index 89078e5..0000000 --- a/board/freescale/mx6qsabreauto/mx6dl.cfg +++ /dev/null @@ -1,130 +0,0 @@ -/* - * Copyright (C) 2013 Freescale Semiconductor, Inc. - * Jason Liu r64343@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ -/* image version */ - -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ -DATA 4 0x020e0774 0x000C0000 -DATA 4 0x020e0754 0x00000000 -DATA 4 0x020e04ac 0x00000030 -DATA 4 0x020e04b0 0x00000030 -DATA 4 0x020e0464 0x00000030 -DATA 4 0x020e0490 0x00000030 -DATA 4 0x020e074c 0x00000030 -DATA 4 0x020e0494 0x00000030 -DATA 4 0x020e04a0 0x00000000 -DATA 4 0x020e04b4 0x00000030 -DATA 4 0x020e04b8 0x00000030 -DATA 4 0x020e076c 0x00000030 -DATA 4 0x020e0750 0x00020000 -DATA 4 0x020e04bc 0x00000028 -DATA 4 0x020e04c0 0x00000028 -DATA 4 0x020e04c4 0x00000028 -DATA 4 0x020e04c8 0x00000028 -DATA 4 0x020e04cc 0x00000028 -DATA 4 0x020e04d0 0x00000028 -DATA 4 0x020e04d4 0x00000028 -DATA 4 0x020e04d8 0x00000028 -DATA 4 0x020e0760 0x00020000 -DATA 4 0x020e0764 0x00000028 -DATA 4 0x020e0770 0x00000028 -DATA 4 0x020e0778 0x00000028 -DATA 4 0x020e077c 0x00000028 -DATA 4 0x020e0780 0x00000028 -DATA 4 0x020e0784 0x00000028 -DATA 4 0x020e078c 0x00000028 -DATA 4 0x020e0748 0x00000028 -DATA 4 0x020e0470 0x00000028 -DATA 4 0x020e0474 0x00000028 -DATA 4 0x020e0478 0x00000028 -DATA 4 0x020e047c 0x00000028 -DATA 4 0x020e0480 0x00000028 -DATA 4 0x020e0484 0x00000028 -DATA 4 0x020e0488 0x00000028 -DATA 4 0x020e048c 0x00000028 -DATA 4 0x021b0800 0xa1390003 -DATA 4 0x021b080c 0x001F001F -DATA 4 0x021b0810 0x001F001F -DATA 4 0x021b480c 0x001F001F -DATA 4 0x021b4810 0x001F001F -DATA 4 0x021b083c 0x42190217 -DATA 4 0x021b0840 0x017B017B -DATA 4 0x021b483c 0x4176017B -DATA 4 0x021b4840 0x015F016C -DATA 4 0x021b0848 0x4C4C4D4C -DATA 4 0x021b4848 0x4A4D4C48 -DATA 4 0x021b0850 0x3F3F3F40 -DATA 4 0x021b4850 0x3538382E -DATA 4 0x021b081c 0x33333333 -DATA 4 0x021b0820 0x33333333 -DATA 4 0x021b0824 0x33333333 -DATA 4 0x021b0828 0x33333333 -DATA 4 0x021b481c 0x33333333 -DATA 4 0x021b4820 0x33333333 -DATA 4 0x021b4824 0x33333333 -DATA 4 0x021b4828 0x33333333 -DATA 4 0x021b08b8 0x00000800 -DATA 4 0x021b48b8 0x00000800 -DATA 4 0x021b0004 0x00020025 -DATA 4 0x021b0008 0x00333030 -DATA 4 0x021b000c 0x676B5313 -DATA 4 0x021b0010 0xB66E8B63 -DATA 4 0x021b0014 0x01FF00DB -DATA 4 0x021b0018 0x00001740 -DATA 4 0x021b001c 0x00008000 -DATA 4 0x021b002c 0x000026d2 -DATA 4 0x021b0030 0x006B1023 -DATA 4 0x021b0040 0x00000047 -DATA 4 0x021b0000 0x841A0000 -DATA 4 0x021b001c 0x04008032 -DATA 4 0x021b001c 0x00008033 -DATA 4 0x021b001c 0x00048031 -DATA 4 0x021b001c 0x05208030 -DATA 4 0x021b001c 0x04008040 -DATA 4 0x021b0020 0x00005800 -DATA 4 0x021b0818 0x00011117 -DATA 4 0x021b4818 0x00011117 -DATA 4 0x021b0004 0x00025565 -DATA 4 0x021b0404 0x00011006 -DATA 4 0x021b001c 0x00000000 - -/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0xFFFFF300 -DATA 4 0x020c407c 0x0F0000C3 -DATA 4 0x020c4080 0x00000FFF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F diff --git a/board/freescale/mx6qsabreauto/mx6qp.cfg b/board/freescale/mx6qsabreauto/mx6qp.cfg deleted file mode 100644 index 2298c77..0000000 --- a/board/freescale/mx6qsabreauto/mx6qp.cfg +++ /dev/null @@ -1,145 +0,0 @@ -/* - * Copyright (C) 2015 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ -/* image version */ - -#define __ASSEMBLY__ -#include <config.h> - -IMAGE_VERSION 2 - -/* - * Boot Device : one of spi, sd, eimnor, nand, sata: - * spinor: flash_offset: 0x0400 - * nand: flash_offset: 0x0400 - * sata: flash_offset: 0x0400 - * sd/mmc: flash_offset: 0x0400 - * eimnor: flash_offset: 0x1000 - */ -BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ -DATA 4 0x020e0798 0x000C0000 -DATA 4 0x020e0758 0x00000000 -DATA 4 0x020e0588 0x00000030 -DATA 4 0x020e0594 0x00000030 -DATA 4 0x020e056c 0x00000030 -DATA 4 0x020e0578 0x00000030 -DATA 4 0x020e074c 0x00000030 -DATA 4 0x020e057c 0x00000030 -DATA 4 0x020e058c 0x00000000 -DATA 4 0x020e059c 0x00000030 -DATA 4 0x020e05a0 0x00000030 -DATA 4 0x020e078c 0x00000030 -DATA 4 0x020e0750 0x00020000 -DATA 4 0x020e05a8 0x00000030 -DATA 4 0x020e05b0 0x00000030 -DATA 4 0x020e0524 0x00000030 -DATA 4 0x020e051c 0x00000030 -DATA 4 0x020e0518 0x00000030 -DATA 4 0x020e050c 0x00000030 -DATA 4 0x020e05b8 0x00000030 -DATA 4 0x020e05c0 0x00000030 -DATA 4 0x020e0774 0x00020000 -DATA 4 0x020e0784 0x00000030 -DATA 4 0x020e0788 0x00000030 -DATA 4 0x020e0794 0x00000030 -DATA 4 0x020e079c 0x00000030 -DATA 4 0x020e07a0 0x00000030 -DATA 4 0x020e07a4 0x00000030 -DATA 4 0x020e07a8 0x00000030 -DATA 4 0x020e0748 0x00000030 -DATA 4 0x020e05ac 0x00000030 -DATA 4 0x020e05b4 0x00000030 -DATA 4 0x020e0528 0x00000030 -DATA 4 0x020e0520 0x00000030 -DATA 4 0x020e0514 0x00000030 -DATA 4 0x020e0510 0x00000030 -DATA 4 0x020e05bc 0x00000030 -DATA 4 0x020e05c4 0x00000030 -DATA 4 0x021b0800 0xa1390003 -DATA 4 0x021b080c 0x001b001e -DATA 4 0x021b0810 0x002e0029 -DATA 4 0x021b480c 0x001b002a -DATA 4 0x021b4810 0x0019002c -DATA 4 0x021b083c 0x43240334 -DATA 4 0x021b0840 0x0324031a -DATA 4 0x021b483c 0x43340344 -DATA 4 0x021b4840 0x03280276 -DATA 4 0x021b0848 0x44383A3E -DATA 4 0x021b4848 0x3C3C3846 -DATA 4 0x021b0850 0x2e303230 -DATA 4 0x021b4850 0x38283E34 -DATA 4 0x021b081c 0x33333333 -DATA 4 0x021b0820 0x33333333 -DATA 4 0x021b0824 0x33333333 -DATA 4 0x021b0828 0x33333333 -DATA 4 0x021b481c 0x33333333 -DATA 4 0x021b4820 0x33333333 -DATA 4 0x021b4824 0x33333333 -DATA 4 0x021b4828 0x33333333 -DATA 4 0x021b08c0 0x24912492 -DATA 4 0x021b48c0 0x24912492 -DATA 4 0x021b08b8 0x00000800 -DATA 4 0x021b48b8 0x00000800 -DATA 4 0x021b0004 0x00020036 -DATA 4 0x021b0008 0x09444040 -DATA 4 0x021b000c 0x898E7955 -DATA 4 0x021b0010 0xFF328F64 -DATA 4 0x021b0014 0x01FF00DB -DATA 4 0x021b0018 0x00001740 -DATA 4 0x021b001c 0x00008000 - -DATA 4 0x021b002c 0x000026d2 -DATA 4 0x021b0030 0x008E1023 -DATA 4 0x021b0040 0x00000047 -DATA 4 0x021b0400 0x14420000 -DATA 4 0x021b0000 0x841A0000 -DATA 4 0x00bb0008 0x00000004 -DATA 4 0x00bb000c 0x2891E41A -DATA 4 0x00bb0038 0x00000564 -DATA 4 0x00bb0014 0x00000040 -DATA 4 0x00bb0028 0x00000020 -DATA 4 0x00bb002c 0x00000020 -DATA 4 0x021b001c 0x04088032 -DATA 4 0x021b001c 0x00008033 -DATA 4 0x021b001c 0x00048031 -DATA 4 0x021b001c 0x09408030 -DATA 4 0x021b001c 0x04008040 -DATA 4 0x021b0020 0x00005800 -DATA 4 0x021b0818 0x00011117 -DATA 4 0x021b4818 0x00011117 -DATA 4 0x021b0004 0x00025576 -DATA 4 0x021b0404 0x00011006 -DATA 4 0x021b001c 0x00000000 -/* set the default clock gate to save power */ -DATA 4, 0x020c4068, 0x00C03F3F -DATA 4, 0x020c406c, 0x0030FC03 -DATA 4, 0x020c4070, 0x0FFFC000 -DATA 4, 0x020c4074, 0x3FF00000 -DATA 4, 0x020c4078, 0xFFFFF300 -DATA 4, 0x020c407c, 0x0F0000F3 -DATA 4, 0x020c4080, 0x00000FFF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4, 0x020e0010, 0xF00000CF -/* set IPU AXI-id1 Qos=0x1 AXI-id0/2/3 Qos=0x7 */ -DATA 4, 0x020e0018, 0x77177717 -DATA 4, 0x020e001c, 0x77177717 diff --git a/board/freescale/mx6qsabreauto/Kconfig b/board/freescale/mx6sabreauto/Kconfig similarity index 54% rename from board/freescale/mx6qsabreauto/Kconfig rename to board/freescale/mx6sabreauto/Kconfig index e579c0f..5b4faf6 100644 --- a/board/freescale/mx6qsabreauto/Kconfig +++ b/board/freescale/mx6sabreauto/Kconfig @@ -1,12 +1,12 @@ -if TARGET_MX6QSABREAUTO +if TARGET_MX6SABREAUTO
config SYS_BOARD - default "mx6qsabreauto" + default "mx6sabreauto"
config SYS_VENDOR default "freescale"
config SYS_CONFIG_NAME - default "mx6qsabreauto" + default "mx6sabreauto"
endif diff --git a/board/freescale/mx6sabreauto/MAINTAINERS b/board/freescale/mx6sabreauto/MAINTAINERS new file mode 100644 index 0000000..a89f05a --- /dev/null +++ b/board/freescale/mx6sabreauto/MAINTAINERS @@ -0,0 +1,7 @@ +MX6SABREAUTO BOARD +M: Fabio Estevam fabio.estevam@nxp.com +M: Peng Fan peng.fan@nxp.com +S: Maintained +F: board/freescale/mx6sabreauto/ +F: include/configs/mx6sabreauto.h +F: configs/mx6sabreauto_defconfig diff --git a/board/freescale/mx6qsabreauto/Makefile b/board/freescale/mx6sabreauto/Makefile similarity index 85% rename from board/freescale/mx6qsabreauto/Makefile rename to board/freescale/mx6sabreauto/Makefile index ac5bc81..87f4ec0 100644 --- a/board/freescale/mx6qsabreauto/Makefile +++ b/board/freescale/mx6sabreauto/Makefile @@ -6,4 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := mx6qsabreauto.o +obj-y := mx6sabreauto.o diff --git a/board/freescale/mx6sabreauto/README b/board/freescale/mx6sabreauto/README new file mode 100644 index 0000000..7e4596a --- /dev/null +++ b/board/freescale/mx6sabreauto/README @@ -0,0 +1,20 @@ +How to use and build U-Boot on mx6sabreauto +------------------------------------------- + +mx6sabreauto_defconfig target supports mx6q/mx6dl/mx6qp sabreauto variants. + +In order to build it: + +$ make mx6sabreauto_defconfig + +$ make + +This will generate the SPL and u-boot.img binaries. + +- Flash the SPL binary into the SD card: + +$ sudo dd if=SPL of=/dev/sdX bs=1K seek=1 && sync + +- Flash the u-boot.img binary into the SD card: + +$ sudo dd if=u-boot.img of=/dev/sdX bs=1K seek=69 && sync diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c similarity index 100% rename from board/freescale/mx6qsabreauto/mx6qsabreauto.c rename to board/freescale/mx6sabreauto/mx6sabreauto.c diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig deleted file mode 100644 index ba5ab8a..0000000 --- a/configs/mx6dlsabreauto_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TARGET_MX6QSABREAUTO=y -CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" -CONFIG_BOOTDELAY=3 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_SF=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -# CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig deleted file mode 100644 index 96a248e..0000000 --- a/configs/mx6qpsabreauto_defconfig +++ /dev/null @@ -1,43 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TARGET_MX6QSABREAUTO=y -CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" -CONFIG_BOOTDELAY=3 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_SF=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -# CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig deleted file mode 100644 index 015207d..0000000 --- a/configs/mx6qsabreauto_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TARGET_MX6QSABREAUTO=y -CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" -CONFIG_BOOTDELAY=3 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_SF=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -# CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabreauto_spl_defconfig b/configs/mx6sabreauto_defconfig similarity index 97% rename from configs/mx6qsabreauto_spl_defconfig rename to configs/mx6sabreauto_defconfig index ce2d1d2..c1b3bbf 100644 --- a/configs/mx6qsabreauto_spl_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_TARGET_MX6SABREAUTO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6sabreauto.h similarity index 94% rename from include/configs/mx6qsabreauto.h rename to include/configs/mx6sabreauto.h index 99b48ca..fd0d5ce 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -6,8 +6,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef __MX6QSABREAUTO_CONFIG_H -#define __MX6QSABREAUTO_CONFIG_H +#ifndef __MX6SABREAUTO_CONFIG_H +#define __MX6SABREAUTO_CONFIG_H
#ifdef CONFIG_SPL #include "imx6_spl.h" @@ -76,4 +76,4 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
-#endif /* __MX6QSABREAUTO_CONFIG_H */ +#endif /* __MX6SABREAUTO_CONFIG_H */
This patch:
This patch:
- bool "mx6sabreauto" select BOARD_LATE_INIT select SUPPORT_SPL select DM
- Copyright (C) 2012 Freescale Semiconductor, Inc.
- Refer doc/README.imximage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
-IMAGE_VERSION 2
- Boot Device : one of
- spi, sd (the board has no nand neither onenand)
-BOOT_FROM sd
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- Addr-type register length (1,2 or 4 bytes)
- Address absolute address of the register
- value value to be stored in the register
- Copyright (C) 2013 Freescale Semiconductor, Inc.
- Jason Liu r64343@freescale.com
-IMAGE_VERSION 2
-BOOT_FROM sd
- where:
- Copyright (C) 2015 Freescale Semiconductor, Inc.
-IMAGE_VERSION 2
- Boot Device : one of spi, sd, eimnor, nand, sata:
- spinor: flash_offset: 0x0400
- nand: flash_offset: 0x0400
- sata: flash_offset: 0x0400
- sd/mmc: flash_offset: 0x0400
- eimnor: flash_offset: 0x1000
-BOOT_FROM sd
- where:
config SYS_BOARD
- default "mx6sabreauto"
+$ make
Nice cleanup, thanks !
Best regards, Stefano Babic
This patch:
-IMAGE_VERSION 2
-BOOT_FROM sd
- where:
-IMAGE_VERSION 2
-BOOT_FROM sd
- where:
-IMAGE_VERSION 2
-BOOT_FROM sd
- where:
config SYS_BOARD
+$ make
Applied (whole series) to u-boot-imx, -next, thanks !
Hi Vanessa, hi Fabio,
Currently the following build error is seen when a board using MMC SPL is built and the MXS nand driver is also selected:
arch/arm/cpu/armv7/built-in.o: In function `arch_cpu_init': arch/arm/cpu/armv7/mx6/soc.c:432: undefined reference to 'mxs_dma_init'
On mx6 the only user of mxs_dma_init() is the mxs nand driver, so move it there.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com
arch/arm/cpu/armv7/mx6/soc.c | 5 ----- drivers/mtd/nand/mxs_nand.c | 1 + 2 files changed, 1 insertion(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 2bedbdb..ecbc3b2 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -427,11 +427,6 @@ int arch_cpu_init(void)
imx_set_wdog_powerdown(false); /* Disable PDE bit of WMCR register */
-#ifdef CONFIG_APBH_DMA
- /* Start APBH DMA */
- mxs_dma_init();
-#endif
init_src();
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 9200544..5aa3608 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -1114,6 +1114,7 @@ int mxs_nand_init(struct mxs_nand_info *info) }
/* Init the DMA controller. */
- mxs_dma_init();
But if this is the case, should we not also add a dependency in Kconfig for NAND_MXS, selecting automatically APBH_DMA ?
config NAND_MXS bool "MXS NAND support" depends on MX6 || MX7 + select APBH_DMA
for (j = MXS_DMA_CHANNEL_AHB_APBH_GPMI0; j <= MXS_DMA_CHANNEL_AHB_APBH_GPMI7; j++) { ret = mxs_dma_init_channel(j);
Hi Stefano,
select APBH_DMA
Doing like this still causes the build to fail:
arch/arm/cpu/armv7/built-in.o: In function `arch_cpu_init': /home/fabio/u-boot/arch/arm/cpu/armv7/mx6/soc.c:432: undefined reference to `mxs_dma_init' LD u-boot scripts/Makefile.spl:333: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 1 Makefile:1382: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2 make: *** Waiting for unfinished jobs....
SPL builds arch/arm/cpu/armv7/mx6/soc.c, but does not build the APBH_DMA driver, which provides mxs_dma_init().
That's why I thought in removing mxs_dma_init() from soc.c and put it inside the mxs_nand.c driver.
If there is some other alternative, please let me know.
Thanks
Hi Fabio,
On 30/06/2017 13:21, Fabio Estevam wrote:
Hi Stefano,
select APBH_DMA
Agree on this - my concern is if NAND_MXS is set, but APBH_DMA not. I see that APBH_DMA is not in Kconfig, and there are some other options that are really set by all MX6-MX7 boards:
#define CONFIG_APBH_DMA #define CONFIG_APBH_DMA_BURST #define CONFIG_APBH_DMA_BURST8
I understand now that we can do this with a follow-up patch. The best way will be if, activating NAND_MXS, all 3 above are set for i.MX6 and i.MX7 but just CONFIG_APBH_DMA for MX23-MX28, dropping them from include/configs/<board>
I agree with you, the rest requires more cleanup and should be done in separate patches.
Regards, Stefano
Hi Stefano,
Great, so I will submit the Kconfig cleanups separately as suggested.
Thanks
Fabio Estevam
Stefano Babic
Vanessa Maegima
