[U-Boot-Users] [PATCH: cmdcfg: 01/19] Introduce initial versions of new Command Config files.
Derive three new files from cmd_confdefs.h: config_bootp.h - Has BOOTP related config options, not commands config_cmd_all.h - Has a CONFIG_CMD_* definition for every command config_cmd_default.h - Has a CONFIG_CMD_* definition for default cmds.
For now, include "config_bootp.h" for compatability until all users of it directly include it properly.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/cmd_confdefs.h | 30 ++-------------- include/config_bootp.h | 41 +++++++++++++++++++++ include/config_cmd_all.h | 80 ++++++++++++++++++++++++++++++++++++++++++ include/config_cmd_default.h | 41 +++++++++++++++++++++ 4 files changed, 165 insertions(+), 27 deletions(-) create mode 100644 include/config_bootp.h create mode 100644 include/config_cmd_all.h create mode 100644 include/config_cmd_default.h
diff --git a/include/cmd_confdefs.h b/include/cmd_confdefs.h index b3ccdce..9b4545f 100644 --- a/include/cmd_confdefs.h +++ b/include/cmd_confdefs.h @@ -155,33 +155,9 @@
/* - * optional BOOTP fields + * Temporary placeholder until all users directly + * include the proper include file, "config_bootp.h". */ - -#define CONFIG_BOOTP_SUBNETMASK 0x00000001 -#define CONFIG_BOOTP_GATEWAY 0x00000002 -#define CONFIG_BOOTP_HOSTNAME 0x00000004 -#define CONFIG_BOOTP_NISDOMAIN 0x00000008 -#define CONFIG_BOOTP_BOOTPATH 0x00000010 -#define CONFIG_BOOTP_BOOTFILESIZE 0x00000020 -#define CONFIG_BOOTP_DNS 0x00000040 -#define CONFIG_BOOTP_DNS2 0x00000080 -#define CONFIG_BOOTP_SEND_HOSTNAME 0x00000100 -#define CONFIG_BOOTP_NTPSERVER 0x00000200 -#define CONFIG_BOOTP_TIMEOFFSET 0x00000400 - -#define CONFIG_BOOTP_VENDOREX 0x80000000 - -#define CONFIG_BOOTP_ALL (~CONFIG_BOOTP_VENDOREX) - - -#define CONFIG_BOOTP_DEFAULT (CONFIG_BOOTP_SUBNETMASK | \ - CONFIG_BOOTP_GATEWAY | \ - CONFIG_BOOTP_HOSTNAME | \ - CONFIG_BOOTP_BOOTPATH) - -#ifndef CONFIG_BOOTP_MASK -#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT -#endif +#include "config_bootp.h"
#endif /* _CMD_CONFIG_H */ diff --git a/include/config_bootp.h b/include/config_bootp.h new file mode 100644 index 0000000..f0c9360 --- /dev/null +++ b/include/config_bootp.h @@ -0,0 +1,41 @@ +/* + * Copyright 2007 Freescale Semiconductor, Inc. + * + * This file is licensed under the terms of the GNU General Public + * License Version 2. This file is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#ifndef _CONFIG_BOOTP_H +#define _CONFIG_BOOTP_H + +/* + * Optional BOOTP fields + */ + +#define CONFIG_BOOTP_SUBNETMASK 0x00000001 +#define CONFIG_BOOTP_GATEWAY 0x00000002 +#define CONFIG_BOOTP_HOSTNAME 0x00000004 +#define CONFIG_BOOTP_NISDOMAIN 0x00000008 +#define CONFIG_BOOTP_BOOTPATH 0x00000010 +#define CONFIG_BOOTP_BOOTFILESIZE 0x00000020 +#define CONFIG_BOOTP_DNS 0x00000040 +#define CONFIG_BOOTP_DNS2 0x00000080 +#define CONFIG_BOOTP_SEND_HOSTNAME 0x00000100 +#define CONFIG_BOOTP_NTPSERVER 0x00000200 +#define CONFIG_BOOTP_TIMEOFFSET 0x00000400 + +#define CONFIG_BOOTP_VENDOREX 0x80000000 + +#define CONFIG_BOOTP_ALL (~CONFIG_BOOTP_VENDOREX) + +#define CONFIG_BOOTP_DEFAULT (CONFIG_BOOTP_SUBNETMASK | \ + CONFIG_BOOTP_GATEWAY | \ + CONFIG_BOOTP_HOSTNAME | \ + CONFIG_BOOTP_BOOTPATH) + +#ifndef CONFIG_BOOTP_MASK +#define CONFIG_BOOTP_MASK CONFIG_BOOTP_DEFAULT +#endif + +#endif /* _CONFIG_BOOTP_H */ diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h new file mode 100644 index 0000000..14801b5 --- /dev/null +++ b/include/config_cmd_all.h @@ -0,0 +1,80 @@ +/* + * Copyright 2007 Freescale Semiconductor, Inc. + * + * This file is licensed under the terms of the GNU General Public + * License Version 2. This file is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#ifndef _CONFIG_CMD_ALL_H +#define _CONFIG_CMD_ALL_H + +/* + * Alphabetical list of all possible commands. + */ + +#define CONFIG_CMD_ASKENV /* ask for env variable */ +#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BEDBUG /* Include BedBug Debugger */ +#define CONFIG_CMD_BMP /* BMP support */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_BSP /* Board Specific functions */ +#define CONFIG_CMD_CACHE /* icache, dcache */ +#define CONFIG_CMD_CDP /* Cisco Discovery Protocol */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_DATE /* support for RTC, date/time...*/ +#define CONFIG_CMD_DHCP /* DHCP Support */ +#define CONFIG_CMD_DIAG /* Diagnostics */ +#define CONFIG_CMD_DISPLAY /* Display support */ +#define CONFIG_CMD_DOC /* Disk-On-Chip Support */ +#define CONFIG_CMD_DTT /* Digital Therm and Thermostat */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_EEPROM /* EEPROM read/write support */ +#define CONFIG_CMD_ELF /* ELF (VxWorks) load/boot cmd */ +#define CONFIG_CMD_ENV /* saveenv */ +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_FDC /* Floppy Disk Support */ +#define CONFIG_CMD_FDOS /* Floppy DOS support */ +#define CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_HWFLOW /* RTS/CTS hw flow control */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_IDE /* IDE harddisk support */ +#define CONFIG_CMD_IMI /* iminfo */ +#define CONFIG_CMD_IMLS /* List all found images */ +#define CONFIG_CMD_IMMAP /* IMMR dump support */ +#define CONFIG_CMD_IRQ /* irqinfo */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_KGDB /* kgdb */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MFSL /* FSL support for Microblaze */ +#define CONFIG_CMD_MII /* MII support */ +#define CONFIG_CMD_MISC /* Misc functions like sleep etc*/ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_PCI /* pciinfo */ +#define CONFIG_CMD_PCMCIA /* PCMCIA support */ +#define CONFIG_CMD_PING /* ping support */ +#define CONFIG_CMD_PORTIO /* Port I/O */ +#define CONFIG_CMD_REGINFO /* Register dump */ +#define CONFIG_CMD_REISER /* Reiserfs support */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SAVES /* save S record dump */ +#define CONFIG_CMD_SCSI /* SCSI Support */ +#define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SNTP /* SNTP support */ +#define CONFIG_CMD_SPI /* SPI utility */ +#define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ +#define CONFIG_CMD_USB /* USB Support */ +#define CONFIG_CMD_VFD /* VFD support (TRAB) */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */ + +#endif /* _CONFIG_CMD_ALL_H */ diff --git a/include/config_cmd_default.h b/include/config_cmd_default.h new file mode 100644 index 0000000..81eba01 --- /dev/null +++ b/include/config_cmd_default.h @@ -0,0 +1,41 @@ +/* + * Copyright 2007 Freescale Semiconductor, Inc. + * + * This file is licensed under the terms of the GNU General Public + * License Version 2. This file is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#ifndef _CONFIG_CMD_DEFAULT_H +#define _CONFIG_CMD_DEFAULT_H + +/* + * Alphabetical list of all commands that are configured by default. + * This is essentially all commands minus those that are considered + * "non-standard" for some reason (memory hogs, requires special + * hardware, not fully tested, etc.). + */ + +#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_ENV /* saveenv */ +#define CONFIG_CMD_FLASH /* flinfo, erase, protect */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_IMI /* iminfo */ +#define CONFIG_CMD_IMLS /* List all found images */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MISC /* Misc functions like sleep etc*/ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_NFS /* NFS support */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */ + +#endif /* _CONFIG_CMD_DEFAULT_H */ +#endif /* _CONFIG_CMD_DEFAULT_H */
Jon Loeliger
