[PATCH 01/17] Convert CONFIG_FSL_FIXED_MMC_LOCATION et al to Kconfig
This converts the following to Kconfig: CONFIG_FSL_FIXED_MMC_LOCATION CONFIG_ESDHC_HC_BLK_ADDR
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/include/asm/config_mpc85xx.h | 3 --- boot/Kconfig | 13 +++++++++++++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + include/configs/P1010RDB.h | 4 +--- include/configs/P2041RDB.h | 5 ----- include/configs/corenet_ds.h | 5 ----- include/configs/p1_p2_rdb_pc.h | 4 +--- 24 files changed, 33 insertions(+), 19 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index e82adc6b4545..ce3a776c7e88 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_USB1_PHY_ENABLE -#define CONFIG_ESDHC_HC_BLK_ADDR
/* P1011 is single core version of P1020 */ #elif defined(CONFIG_ARCH_P1011) @@ -148,7 +147,6 @@ #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 -#define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_ARCH_BSC9132) #define CONFIG_FSL_SDHC_V2_3 @@ -160,7 +158,6 @@ #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" -#define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_ARCH_T4240) #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ diff --git a/boot/Kconfig b/boot/Kconfig index 63dacc0d14f4..ee0dc90e93cc 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -575,6 +575,19 @@ config SPIFLASH
endchoice
+config FSL_FIXED_MMC_LOCATION + bool "PBL MMC is at a fixed location" + depends on SDCARD && !RAMBOOT_PBL + +config ESDHC_HC_BLK_ADDR + def_bool y + depends on FSL_FIXED_MMC_LOCATION && (ARCH_BSC9131 || ARCH_BSC9132 || ARCH_P1010) + help + In High Capacity SD Cards (> 2 GBytes), the 32-bit source address and + code length of these soc specify the memory address in block address + format. Block length is fixed to 512 bytes as per the SD High + Capacity specification. + config SYS_FSL_PBL_PBI string "PBI(pre-boot instructions) commands for the PBL image" depends on RAMBOOT_PBL diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 81bfd7ae518c..481c69d2d33b 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 1ebfdec719e8..92bb8cdedf66 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 9240c38c164a..9c93d653748b 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index c0fa3b5e4eb3..736e52efdd9c 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -21,6 +21,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 0a3ba0573e01..eace5d0d2c29 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 3e5d313c405f..435c83c5f9b7 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index af65061a0c3e..abb98580532a 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 36892c9fc2e4..1b114b8c9791 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -21,6 +21,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 6c4575367be2..555f52f21a0c 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 0130ce6cb661..32c537a30c7a 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 6b6b12eae624..065845908aa3 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 643cee0b24ca..c5b5573c6025 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index c488aae69d5d..4547bdde55d7 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 40b6afa6cc0f..71a32289de0a 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 48f787ec91bf..7612b05fbae2 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 9b376595e7b8..996675f243d4 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index cd91e8903a67..fabca9b2a5c6 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 228f36af9a95..06c6f28b5961 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 19aebb810c7b..813516892c61 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -465,9 +465,7 @@ extern unsigned long get_sdram_size(void); /* * Environment */ -#if defined(CONFIG_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#elif defined(CONFIG_MTD_RAW_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #endif diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 4e96d2a06b79..4a1fccff598c 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -43,11 +43,6 @@ #define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_DPAA_RMAN /* RMan */
-#if defined(CONFIG_SPIFLASH) -#elif defined(CONFIG_SDCARD) - #define CONFIG_FSL_FIXED_MMC_LOCATION -#endif - #ifndef __ASSEMBLY__ #include <linux/stringify.h> #endif diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 6a4fd90ded9a..c0952e092858 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -39,11 +39,6 @@ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */
-#if defined(CONFIG_SPIFLASH) -#elif defined(CONFIG_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#endif - /* * These can be toggled for performance analysis, otherwise use default. */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 39552be32b3c..b719c7e923cf 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -424,9 +424,7 @@ /* * Environment */ -#if defined(CONFIG_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#elif defined(CONFIG_MTD_RAW_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #endif
No platforms set both CONFIG_LCD and CONFIG_FB_ADDR at this time, drop this legacy code.
Signed-off-by: Tom Rini trini@konsulko.com --- README | 14 -------------- common/board_f.c | 4 ---- include/configs/at91sam9rlek.h | 2 -- include/configs/trats.h | 1 - include/configs/trats2.h | 1 - 5 files changed, 22 deletions(-)
diff --git a/README b/README index a8d43f63b7e3..40069ed17993 100644 --- a/README +++ b/README @@ -1509,20 +1509,6 @@ The following options need to be configured: overwriting the architecture dependent default settings.
-- Frame Buffer Address: - CONFIG_FB_ADDR - - Define CONFIG_FB_ADDR if you want to use specific - address for frame buffer. This is typically the case - when using a graphics controller has separate video - memory. U-Boot will then place the frame buffer at - the given address instead of dynamically reserving it - in system RAM by calling lcd_setmem(), which grabs - the memory for the frame buffer depending on the - configured panel size. - - Please see board_init_f function. - - Automatic software updates via TFTP server CONFIG_UPDATE_TFTP CONFIG_UPDATE_TFTP_CNT_MAX diff --git a/common/board_f.c b/common/board_f.c index 51d2f3c365e9..cbfd42ce1235 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -400,13 +400,9 @@ static int reserve_video(void) ((unsigned long)gd->relocaddr - addr) >> 10, addr); gd->relocaddr = addr; #elif defined(CONFIG_LCD) -# ifdef CONFIG_FB_ADDR - gd->fb_base = CONFIG_FB_ADDR; -# else /* reserve memory for LCD display (always full pages) */ gd->relocaddr = lcd_setmem(gd->relocaddr); gd->fb_base = gd->relocaddr; -# endif /* CONFIG_FB_ADDR */ #endif
return 0; diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index e3350282bcf6..e418edddfbe5 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -22,8 +22,6 @@
/* LCD */ #define LCD_BPP LCD_COLOR8 -/* Let board_init_f handle the framebuffer allocation */ -#undef CONFIG_FB_ADDR
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 diff --git a/include/configs/trats.h b/include/configs/trats.h index bca239ae817e..53f5a6996bd7 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -149,7 +149,6 @@ #define LCD_BPP LCD_COLOR16
/* LCD */ -#define CONFIG_FB_ADDR 0x52504000 #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
#endif /* __CONFIG_H */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 20bd116c9e3d..b7449dab8bdb 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -139,7 +139,6 @@ #define LCD_BPP LCD_COLOR16
This converts the following to Kconfig: CONFIG_LAYERSCAPE_NS_ACCESS
Signed-off-by: Tom Rini trini@konsulko.com --- arch/Kconfig.nxp | 4 ++++ configs/ls1012a2g5rdb_qspi_defconfig | 1 + configs/ls1012a2g5rdb_tfa_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012afrdm_tfa_defconfig | 1 + configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_qspi_defconfig | 1 + configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atsn_qspi_defconfig | 1 + configs/ls1021atsn_sdcard_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_qspi_spl_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + configs/pg_wcom_expu1_defconfig | 1 + configs/pg_wcom_expu1_update_defconfig | 1 + configs/pg_wcom_seli8_defconfig | 1 + configs/pg_wcom_seli8_update_defconfig | 1 + include/configs/km/pg-wcom-ls102xa.h | 1 - include/configs/ls1012a_common.h | 3 --- include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atsn.h | 2 -- include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 2 -- include/configs/ls1043ardb.h | 2 -- include/configs/ls1046afrwy.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/ls1046ardb.h | 2 -- 87 files changed, 79 insertions(+), 19 deletions(-)
diff --git a/arch/Kconfig.nxp b/arch/Kconfig.nxp index 7a35560282fb..688f0fc9cd81 100644 --- a/arch/Kconfig.nxp +++ b/arch/Kconfig.nxp @@ -133,6 +133,10 @@ config DEEP_SLEEP Indicates this SoC supports deep sleep feature. If deep sleep is supported, core will start to execute uboot when wakes up.
+config LAYERSCAPE_NS_ACCESS + bool "Layerscape non-secure access support" + depends on ARCH_LS1021A || FSL_LSCH2 + config FSL_USE_PCA9547_MUX bool "Enable PCA9547 I2C Mux on Freescale boards" depends on PPC || ARCH_LS1021A || FSL_LSCH2 || FSL_LSCH3 diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index 0ab5c868af46..da72b39a494d 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-2g5rdb" CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index 4a65705a8ebd..8219d70e4204 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -14,6 +14,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 8c70bf095158..c679b2b9836b 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -11,6 +11,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frdm" CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index c425a7aae837..b580a59df424 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frdm" CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index 6a04d0bce82c..6337508e67de 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index bb30e27e00f8..35af5cde5285 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x401D0000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index f6fb8548b959..673359857401 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 129855f98408..926d6c377445 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-frwy" CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 87e6f1cca50e..fabe357e5819 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-qds" CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index de1518c01013..0acad021fea0 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index cc9f6f549f27..081d7a4275ec 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -14,6 +14,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 2ff9c5896f34..8c0184a92ef4 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 0a6c43f04a59..560dba486904 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -13,6 +13,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 689cbc63e956..051a4c567251 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 4224b48f9d8c..03b5a1369f0b 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -14,6 +14,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index e31728744d24..d8dd4c7ef192 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_QSPI_BOOT=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 52bc5bfb1df7..df6ce92d5a6b 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index f21129ebc2fb..86f847203756 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 498d795150af..d8d7aa14678b 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index df2395776d18..649e2f99fac0 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index b5b15a30d570..a800e663bbe5 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 8efaf414d2bc..21a5dae94915 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 0a449a67c538..fca79f65bb67 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index e9e0df93f444..75ec61fca361 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 03de83dc8cd8..db1a04f994e2 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index dd6c20c1450e..724c4106e07b 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -22,6 +22,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index cfa83b8c3b8a..fb89c2171023 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-tsn" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 5e93f730b32e..4d72c25f6556 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 67bde2ebcef9..03875bea8c90 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index e80b793a3828..659ea4ef5a11 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index a22d2a59210d..1399b09c83c0 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index aadc61b66cac..e186dfe7c4ce 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index ebd3eaed9167..0d4465edd531 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index c9a265d78198..5d9002a17f36 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index e4f2b8582353..714835cb4529 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 61e6a885fed4..3fa4440a7864 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 865ba21d3092..ae9b3449b835 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-lpuart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 7d898cbff28a..cbc58b2d98db 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 89cad11be73a..8b32b82fa5bb 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 1b8c7b46317d..2716898fb6ea 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 92f9fe4fe126..c95763ebe554 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index a988f5fa1697..15a1d158cce4 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 784af6bb8c99..b5d78e11c1d3 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index a0c9e4b88069..dff7fac4c8b5 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -18,6 +18,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 6e8db4962a74..c657a563ca4a 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FSL_LS_PPA=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 243a03030a98..7a7524954550 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -14,6 +14,7 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index a61781337d99..ce57a0a0d2f4 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 3c5e5ce0ae82..13a35e601c18 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -19,6 +19,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 70aae8569503..d577a4c9b891 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 0c348615fa38..2211547dcc32 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index c2fccda16492..c0c6310d116f 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index e065c7236656..ff703e57f17c 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index 92743034630e..f7aa843c663d 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index af074b616ed1..1c0a24a9a607 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -15,6 +15,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x40500000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 39c751d1c7a2..ea69dafe51f0 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index d1a462649259..59967d00f707 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index f1f5d104f9fd..0254c92075f2 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -15,6 +15,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-lpuart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 3e1f28187600..7ab5e4f79669 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 3307b00fee76..931e70a6c623 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index f850a4ef54a4..780c81959ba2 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index d721f61d550b..5a5e607e3ced 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index b3f9b249c51f..2430c8c6d794 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 185e9f5918cb..6f208b9d5896 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -18,6 +18,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 9cba997eb43e..81659aa9cc32 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 0c394c30f8b2..bc3123011a14 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 6f9a2e8ea29c..d958fb75321f 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -17,6 +17,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 799d460f2bd4..b1eda7b79a50 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 4263c64460ea..6daaba6c1925 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 50efffa442f7..c5653d72514c 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index b8daf03c5264..f8649c58c495 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -17,6 +17,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index c0685777eacc..2434ed379e15 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -19,6 +19,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x40500000 CONFIG_AHCI=y +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/pg_wcom_expu1_defconfig b/configs/pg_wcom_expu1_defconfig index fe864c75b7f0..4b205e13831c 100644 --- a/configs/pg_wcom_expu1_defconfig +++ b/configs/pg_wcom_expu1_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60060000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_KM_DEF_NETDEV="eth2" CONFIG_KM_COMMON_ETH_INIT=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/configs/pg_wcom_expu1_update_defconfig b/configs/pg_wcom_expu1_update_defconfig index 787fe554bad2..98f3dcc4545a 100644 --- a/configs/pg_wcom_expu1_update_defconfig +++ b/configs/pg_wcom_expu1_update_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60220000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_KM_DEF_NETDEV="eth2" CONFIG_KM_COMMON_ETH_INIT=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/configs/pg_wcom_seli8_defconfig b/configs/pg_wcom_seli8_defconfig index 51919dc6cbbb..ce3e7eb179b1 100644 --- a/configs/pg_wcom_seli8_defconfig +++ b/configs/pg_wcom_seli8_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60060000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_KM_DEF_NETDEV="eth2" CONFIG_KM_COMMON_ETH_INIT=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/configs/pg_wcom_seli8_update_defconfig b/configs/pg_wcom_seli8_update_defconfig index 0f22511dabc8..623afa33877e 100644 --- a/configs/pg_wcom_seli8_update_defconfig +++ b/configs/pg_wcom_seli8_update_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60220000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set +CONFIG_LAYERSCAPE_NS_ACCESS=y CONFIG_KM_DEF_NETDEV="eth2" CONFIG_KM_COMMON_ETH_INIT=y CONFIG_PIGGY_MAC_ADDRESS_OFFSET=3 diff --git a/include/configs/km/pg-wcom-ls102xa.h b/include/configs/km/pg-wcom-ls102xa.h index 3927558467af..a12923386a5f 100644 --- a/include/configs/km/pg-wcom-ls102xa.h +++ b/include/configs/km/pg-wcom-ls102xa.h @@ -173,7 +173,6 @@ {1, {I2C_NULL_HOP} }, \ }
-#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200
#define CONFIG_HWCONFIG diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 19201a735f0a..0c194ee575bf 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -15,9 +15,6 @@ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE #define CONFIG_SYS_DDR_BLOCK2_BASE 0x880000000ULL
-/* CSU */ -#define CONFIG_LAYERSCAPE_NS_ACCESS - /*SPI device */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000
diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 6a0ccbf836fa..f43ea2bd6ec9 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -108,7 +108,6 @@ #endif
#define CONFIG_PEN_ADDR_BIG_ENDIAN -#define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200
#define CONFIG_HWCONFIG diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 012b47116b98..1faa38b082bb 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -310,7 +310,6 @@ #endif
#define CONFIG_HWCONFIG diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index b06394c30039..3ff694f6b58f 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -87,8 +87,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
-#define CONFIG_LAYERSCAPE_NS_ACCESS - #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 256
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index d85a776daa17..eff919116ec1 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -180,7 +180,6 @@ #endif
#define CONFIG_HWCONFIG diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index e81384ab3f00..15c3ff53fe8e 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -8,8 +8,6 @@
#include "ls1043a_common.h"
-#define CONFIG_LAYERSCAPE_NS_ACCESS - /* Physical Memory Map */
#define SPD_EEPROM_ADDRESS 0x51 diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 411721c12545..6c33847b27b6 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -8,8 +8,6 @@
#ifndef CONFIG_SPL diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index e663fa0f6c7d..43717cdd4e63 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -8,8 +8,6 @@
#include "ls1046a_common.h"
-#define CONFIG_LAYERSCAPE_NS_ACCESS - #define CONFIG_SYS_UBOOT_BASE 0x40100000
/* diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 0e24209fbe9e..36c64db8f5d1 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -8,8 +8,6 @@
#define SPD_EEPROM_ADDRESS 0x51 diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index fdd251abcd1a..382d5c76461e 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -9,8 +9,6 @@
This converts the following to Kconfig: CONFIG_PCIE1 CONFIG_PCIE2 CONFIG_PCIE3 CONFIG_PCIE4 CONFIG_PCI1
Signed-off-by: Tom Rini trini@konsulko.com --- arch/Kconfig.nxp | 16 ++++++++++++++++ board/freescale/mpc8548cds/Kconfig | 3 +++ configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 2 ++ configs/P1010RDB-PA_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 2 ++ configs/P1010RDB-PB_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_defconfig | 2 ++ configs/P1020RDB-PC_NAND_defconfig | 2 ++ configs/P1020RDB-PC_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_defconfig | 2 ++ configs/P1020RDB-PD_NAND_defconfig | 2 ++ configs/P1020RDB-PD_SDCARD_defconfig | 2 ++ configs/P1020RDB-PD_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PD_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_defconfig | 2 ++ configs/P2020RDB-PC_NAND_defconfig | 2 ++ configs/P2020RDB-PC_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_defconfig | 2 ++ configs/P2041RDB_NAND_defconfig | 3 +++ configs/P2041RDB_SDCARD_defconfig | 3 +++ configs/P2041RDB_SPIFLASH_defconfig | 3 +++ configs/P2041RDB_defconfig | 3 +++ configs/P3041DS_NAND_defconfig | 4 ++++ configs/P3041DS_SDCARD_defconfig | 4 ++++ configs/P3041DS_SPIFLASH_defconfig | 4 ++++ configs/P3041DS_defconfig | 4 ++++ configs/P4080DS_SDCARD_defconfig | 3 +++ configs/P4080DS_SPIFLASH_defconfig | 3 +++ configs/P4080DS_defconfig | 3 +++ configs/P5040DS_NAND_defconfig | 3 +++ configs/P5040DS_SDCARD_defconfig | 3 +++ configs/P5040DS_SPIFLASH_defconfig | 3 +++ configs/P5040DS_defconfig | 3 +++ configs/T1024RDB_NAND_defconfig | 3 +++ configs/T1024RDB_SDCARD_defconfig | 3 +++ configs/T1024RDB_SPIFLASH_defconfig | 3 +++ configs/T1024RDB_defconfig | 3 +++ configs/T1042D4RDB_NAND_defconfig | 4 ++++ configs/T1042D4RDB_SDCARD_defconfig | 4 ++++ configs/T1042D4RDB_SPIFLASH_defconfig | 4 ++++ configs/T1042D4RDB_defconfig | 4 ++++ configs/T2080QDS_NAND_defconfig | 4 ++++ configs/T2080QDS_SDCARD_defconfig | 4 ++++ configs/T2080QDS_SECURE_BOOT_defconfig | 4 ++++ configs/T2080QDS_SPIFLASH_defconfig | 4 ++++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 4 ++++ configs/T2080QDS_defconfig | 4 ++++ configs/T2080RDB_NAND_defconfig | 4 ++++ configs/T2080RDB_SDCARD_defconfig | 4 ++++ configs/T2080RDB_SPIFLASH_defconfig | 4 ++++ configs/T2080RDB_defconfig | 4 ++++ configs/T2080RDB_revD_NAND_defconfig | 4 ++++ configs/T2080RDB_revD_SDCARD_defconfig | 4 ++++ configs/T2080RDB_revD_SPIFLASH_defconfig | 4 ++++ configs/T2080RDB_revD_defconfig | 4 ++++ configs/T4240RDB_SDCARD_defconfig | 4 ++++ configs/T4240RDB_defconfig | 4 ++++ configs/kmcent2_defconfig | 1 + configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_qspi_defconfig | 1 + configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 2 ++ configs/ls1021aiot_sdcard_defconfig | 2 ++ configs/ls1021aqds_ddr4_nor_defconfig | 2 ++ configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 2 ++ configs/ls1021aqds_nand_defconfig | 2 ++ configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 2 ++ configs/ls1021aqds_nor_defconfig | 2 ++ configs/ls1021aqds_nor_lpuart_defconfig | 2 ++ configs/ls1021aqds_qspi_defconfig | 2 ++ configs/ls1021aqds_sdcard_ifc_defconfig | 2 ++ configs/ls1021aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1021atsn_qspi_defconfig | 2 ++ configs/ls1021atsn_sdcard_defconfig | 2 ++ configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 ++ configs/ls1021atwr_nor_defconfig | 2 ++ configs/ls1021atwr_nor_lpuart_defconfig | 2 ++ configs/ls1021atwr_qspi_defconfig | 2 ++ .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 ++ configs/ls1021atwr_sdcard_ifc_defconfig | 2 ++ configs/ls1021atwr_sdcard_qspi_defconfig | 2 ++ configs/ls1043aqds_defconfig | 3 +++ configs/ls1043aqds_lpuart_defconfig | 3 +++ configs/ls1043aqds_nand_defconfig | 3 +++ configs/ls1043aqds_nor_ddr3_defconfig | 3 +++ configs/ls1043aqds_qspi_defconfig | 3 +++ configs/ls1043aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1043aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 3 +++ configs/ls1043aqds_tfa_defconfig | 3 +++ configs/ls1043ardb_SECURE_BOOT_defconfig | 3 +++ configs/ls1043ardb_defconfig | 3 +++ configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 3 +++ configs/ls1043ardb_nand_defconfig | 3 +++ configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 3 +++ configs/ls1043ardb_sdcard_defconfig | 3 +++ configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 3 +++ configs/ls1043ardb_tfa_defconfig | 3 +++ configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 3 +++ configs/ls1046afrwy_tfa_defconfig | 3 +++ configs/ls1046aqds_SECURE_BOOT_defconfig | 3 +++ configs/ls1046aqds_defconfig | 3 +++ configs/ls1046aqds_lpuart_defconfig | 3 +++ configs/ls1046aqds_nand_defconfig | 3 +++ configs/ls1046aqds_qspi_defconfig | 3 +++ configs/ls1046aqds_sdcard_ifc_defconfig | 3 +++ configs/ls1046aqds_sdcard_qspi_defconfig | 3 +++ configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 3 +++ configs/ls1046aqds_tfa_defconfig | 3 +++ configs/ls1046ardb_emmc_defconfig | 3 +++ configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 3 +++ configs/ls1046ardb_qspi_defconfig | 3 +++ configs/ls1046ardb_qspi_spl_defconfig | 3 +++ configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 3 +++ configs/ls1046ardb_sdcard_defconfig | 3 +++ configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 3 +++ configs/ls1046ardb_tfa_defconfig | 3 +++ include/configs/MPC8548CDS.h | 4 ---- include/configs/P1010RDB.h | 3 --- include/configs/P2041RDB.h | 3 --- include/configs/P3041DS.h | 2 -- include/configs/P4080DS.h | 2 -- include/configs/P5040DS.h | 1 - include/configs/T102xRDB.h | 3 --- include/configs/T104xRDB.h | 4 ---- include/configs/T208xQDS.h | 4 ---- include/configs/T208xRDB.h | 4 ---- include/configs/T4240RDB.h | 5 ----- include/configs/corenet_ds.h | 2 -- include/configs/kmcent2.h | 1 - include/configs/ls1012afrwy.h | 2 -- include/configs/ls1012aqds.h | 2 -- include/configs/ls1012ardb.h | 2 -- include/configs/ls1021aiot.h | 4 ---- include/configs/ls1021aqds.h | 4 ---- include/configs/ls1021atsn.h | 2 -- include/configs/ls1021atwr.h | 4 ---- include/configs/ls1043a_common.h | 4 ---- include/configs/ls1046a_common.h | 5 ----- include/configs/p1_p2_rdb_pc.h | 3 --- 171 files changed, 395 insertions(+), 70 deletions(-)
diff --git a/arch/Kconfig.nxp b/arch/Kconfig.nxp index 688f0fc9cd81..7d65b4443c2f 100644 --- a/arch/Kconfig.nxp +++ b/arch/Kconfig.nxp @@ -137,6 +137,22 @@ config LAYERSCAPE_NS_ACCESS bool "Layerscape non-secure access support" depends on ARCH_LS1021A || FSL_LSCH2
+config PCIE1 + bool "PCIe controller #1" + depends on LAYERSCAPE_NS_ACCESS || PPC + +config PCIE2 + bool "PCIe controller #2" + depends on LAYERSCAPE_NS_ACCESS || PPC + +config PCIE3 + bool "PCIe controller #3" + depends on LAYERSCAPE_NS_ACCESS || PPC + +config PCIE4 + bool "PCIe controller #4" + depends on LAYERSCAPE_NS_ACCESS || PPC + config FSL_USE_PCA9547_MUX bool "Enable PCA9547 I2C Mux on Freescale boards" depends on PPC || ARCH_LS1021A || FSL_LSCH2 || FSL_LSCH3 diff --git a/board/freescale/mpc8548cds/Kconfig b/board/freescale/mpc8548cds/Kconfig index 87f3374bf453..bd9153bc0d74 100644 --- a/board/freescale/mpc8548cds/Kconfig +++ b/board/freescale/mpc8548cds/Kconfig @@ -1,5 +1,8 @@ if TARGET_MPC8548CDS
+config PCI1 + def_bool y + config SYS_BOARD default "mpc8548cds"
diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 14eeef936ebf..6fa89aad36a7 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -11,6 +11,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y CONFIG_PHYS_64BIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 04f086e2d438..82776497a592 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -11,6 +11,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 874de6aeb2e3..c21ed57dc375 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_MPC8548CDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_TARGET_MPC8548CDS_LEGACY=y +CONFIG_PCIE1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DYNAMIC_SYS_CLK_FREQ=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 607278434c4c..1cc9f6a3e0e6 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 481c69d2d33b..f9352eaf4ca2 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 92bb8cdedf66..dfa9f40fcc72 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index f2bef4774ede..a5cba16b1aa4 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 373333dcc3c1..ff20c2db4b27 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 9c93d653748b..a03e4ad17f6a 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index 736e52efdd9c..3b2de516731c 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 4affbf52cc96..30c595136943 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1010RDB_PA=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 034bec111659..1f2117a7c5f5 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index eace5d0d2c29..4e7c70e6ad1d 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 435c83c5f9b7..7aaad099a85a 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index d28d037ff726..f2b92b2e8d3f 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index a1e8d54c8c0e..f7de085a9c47 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index abb98580532a..5847edb0f196 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -11,6 +11,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 1b114b8c9791..25a4d9e4eba3 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 381c1d3bb96a..1a49a0ce7369 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1010RDB_PB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 663c3bcdbc9d..733b1962bd8d 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 555f52f21a0c..bcb707d0b27f 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index b6d3dc95a692..dde232380011 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 32c537a30c7a..d22ed2ffc85d 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -12,6 +12,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index fc32e89cf2af..8655176da8ae 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 065845908aa3..5696f53d12bd 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 904658bd01b3..492699ae4531 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index c5b5573c6025..6abff4e595cd 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -12,6 +12,8 @@ CONFIG_TARGET_P1020RDB_PC=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 5cec7f7bfc1b..298eddb64f4a 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P1020RDB_PD=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 4547bdde55d7..a5042de2758b 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P1020RDB_PD=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 78f680644a78..43be0d972699 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P1020RDB_PD=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 71a32289de0a..529c73551e4c 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -12,6 +12,8 @@ CONFIG_TARGET_P1020RDB_PD=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index fb28554b733b..47782473a268 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 7612b05fbae2..9506270761e1 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 0f5af7c097d2..9db6e2dbe348 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 996675f243d4..e6456510b6f3 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -12,6 +12,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 6cb88863b9f4..d9025f4836f4 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index fabca9b2a5c6..0d451e05882d 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -17,6 +17,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 3f4fa81f75cd..06d7625652d9 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -19,6 +19,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 06c6f28b5961..8fd51386f638 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -12,6 +12,8 @@ CONFIG_TARGET_P2020RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 53d97d9316a0..5063470d8547 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -8,6 +8,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index a54f35a65923..a64f8924dd2d 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 76cabd3de02d..f295174da527 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index e6df3c8fa021..e3dd1e93e323 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P2041RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 9cf139f561c5..3e4cb5180ea5 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 223cd178111d..66eb6c3f3d91 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index ed0f7a1f295c..87c62be04f8d 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -9,6 +9,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 0a3937acca5e..d083c256b089 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -9,6 +9,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P3041DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index e87d506e1b55..ed6f3de96ec5 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 4b17f3614da0..e77085ae3e2d 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 5d6ffc5d1a31..91aa75d9e1ce 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P4080DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index dafb3ac2a0d5..3a48362c3b52 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -8,6 +8,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 083b2b39da66..9aa293dc2292 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 270c5545c05b..6f0d51a7abfe 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 6ae3f7b522d8..ae5f7b7ba348 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_P5040DS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 71cd09374201..30108b711f56 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -15,6 +15,9 @@ CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 2a5e232f487b..1ff5faec9772 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -15,6 +15,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 1bd06cc0656f..62f06dd9e23a 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -17,6 +17,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index adfad9839aa0..a0908ac83a78 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -9,6 +9,9 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index af88d5ab2aa9..0bfe868b3e65 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -14,6 +14,10 @@ CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 4c9edecd5b73..e205717c79c0 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -14,6 +14,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index ca44d8692fc8..f05e38f18775 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -16,6 +16,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 7160e052f37c..44458015c24f 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 7a7e1f21195c..f65304d1aefc 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -14,6 +14,10 @@ CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index ea9825e4b59a..f5caa46bd25c 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -14,6 +14,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index b081b728bbfc..fa3701eee994 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_NXP_ESBC=y CONFIG_BOOTSCRIPT_HDR_ADDR=0xee020000 +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 677883c6915f..08860ab5c402 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -16,6 +16,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index e8d68e6f7348..7a873c136013 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SRIO_PCIE_BOOT_SLAVE=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index e41f9d6eb70b..7a7a5c760a05 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xqds_vdd_mv" diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 7f343909c973..0321170553ca 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -14,6 +14,10 @@ CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index b500267bb530..b0b6515f1041 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -14,6 +14,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index da8531c706c7..e5a1d59cc337 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -16,6 +16,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index f4940fb2d795..b8768d5dd7fb 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 5c8e67ca027d..167069ae59a1 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -15,6 +15,10 @@ CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 40e8c5e98fac..bd126f9da9cd 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -15,6 +15,10 @@ CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index cffa7b552d0d..e7ed84b855bf 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -17,6 +17,10 @@ CONFIG_TARGET_T2080RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index 182bdee17f11..aca8704a8e93 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -9,6 +9,10 @@ CONFIG_TARGET_T2080RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_T2080RDB_REV_D=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t208xrdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 202e39853e83..514b41cd843a 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -14,6 +14,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y CONFIG_ENABLE_36BIT_PHYS=y CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t4240rdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 285b747f8290..20eb620afb63 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -8,6 +8,10 @@ CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y +CONFIG_PCIE4=y CONFIG_VID=y CONFIG_VID_FLS_ENV="t4240rdb_vdd_mv" CONFIG_VOL_MONITOR_IR36021_READ=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index 37529f21df39..cd6fb9675b00 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -12,6 +12,7 @@ CONFIG_TARGET_KMCENT2=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y CONFIG_ENABLE_36BIT_PHYS=y # CONFIG_DEEP_SLEEP is not set +CONFIG_PCIE1=y CONFIG_KM_DEF_NETDEV="eth2" CONFIG_KM_IVM_BUS=2 CONFIG_MP=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index 6337508e67de..1f12a3b95ac0 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 35af5cde5285..dfa525f31d9c 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -13,6 +13,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x401D0000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index 673359857401..50855d545628 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 926d6c377445..2bdebe2da49c 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -14,6 +14,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index fabe357e5819..0f6c2ac37dce 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -13,6 +13,7 @@ CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 0acad021fea0..fcc7914b5656 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -13,6 +13,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 081d7a4275ec..98e48f2fbaa2 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -15,6 +15,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 8c0184a92ef4..6147d4b0bcee 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 560dba486904..f9b0e6edacd9 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 051a4c567251..a603bd9acc5b 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 03b5a1369f0b..5a86992f0999 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -15,6 +15,7 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index d8dd4c7ef192..d731936d5299 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_QSPI_BOOT=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index df6ce92d5a6b..c71ab7818694 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -21,6 +21,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y # CONFIG_DEEP_SLEEP is not set CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_RAMBOOT_PBL=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 86f847203756..165e1a780fd2 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index d8d7aa14678b..13ded158e68e 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 649e2f99fac0..1423d732f8ae 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -22,6 +22,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index a800e663bbe5..1e6e650f47b3 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -15,6 +15,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 21a5dae94915..7cc61213e33b 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index fca79f65bb67..04cb087ad55c 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 75ec61fca361..2d560b2ea6d2 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -16,6 +16,8 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index db1a04f994e2..8e23ccc78895 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -23,6 +23,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y # CONFIG_QIXIS_I2C_ACCESS is not set diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 724c4106e07b..ff8fbeb71778 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -23,6 +23,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_QIXIS=y CONFIG_SYS_MEMTEST_START=0x80000000 diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index fb89c2171023..b368791280ac 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -15,6 +15,8 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-tsn" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 4d72c25f6556..64266afd013a 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -20,6 +20,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 03875bea8c90..831c20fc6d96 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -15,6 +15,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 659ea4ef5a11..c806309b0938 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 1399b09c83c0..de025930d85d 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -16,6 +16,8 @@ CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index e186dfe7c4ce..b5b2cf13f923 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -16,6 +16,8 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 0d4465edd531..2b76f0a2b960 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -22,6 +22,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 5d9002a17f36..161fa1eebd6d 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -22,6 +22,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 714835cb4529..2dc01e19bbc5 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -22,6 +22,8 @@ CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x82000000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 3fa4440a7864..364a34751fcf 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -16,6 +16,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index ae9b3449b835..7b083b32fba1 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -16,6 +16,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index cbc58b2d98db..7446f01272e0 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 8b32b82fa5bb..6dd797c652b9 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -16,6 +16,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 2716898fb6ea..30cc15a12f3d 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -17,6 +17,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index c95763ebe554..53f19a376ee8 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 15a1d158cce4..447a51513fe3 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index b5d78e11c1d3..1ebe893b43d4 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -17,6 +17,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index dff7fac4c8b5..d04d1d918b72 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -19,6 +19,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1043aqds_vdd_mv" diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index c657a563ca4a..787c8f96bd56 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -14,6 +14,9 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FSL_LS_PPA=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 7a7524954550..341fb0f92698 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -15,6 +15,9 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index ce57a0a0d2f4..305734d74822 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -16,6 +16,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 13a35e601c18..56cdef82216d 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -20,6 +20,9 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index d577a4c9b891..bf2805db9e94 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -17,6 +17,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 2211547dcc32..f1370b5104b6 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index c0c6310d116f..12ccb78b9210 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -16,6 +16,9 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index ff703e57f17c..db5229487216 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -18,6 +18,9 @@ CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index f7aa843c663d..1be7002a1859 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -14,6 +14,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 1c0a24a9a607..f41434c7419b 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -16,6 +16,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x40500000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index ea69dafe51f0..fdeedca47678 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -15,6 +15,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 59967d00f707..a66099c815dd 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -16,6 +16,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 0254c92075f2..835159deefbb 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -16,6 +16,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x60300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 7ab5e4f79669..2a70d660ed66 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 931e70a6c623..049cf1e56f98 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -17,6 +17,9 @@ CONFIG_FSL_LS_PPA=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 780c81959ba2..11554a831d5a 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 5a5e607e3ced..68aae882a807 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 2430c8c6d794..7fd24122f041 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -17,6 +17,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 6f208b9d5896..52d3d302d942 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -19,6 +19,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x60500000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_VID=y CONFIG_VID_FLS_ENV="ls1046aqds_vdd_mv" diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 81659aa9cc32..331419844669 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index bc3123011a14..2ea72cc2a8ad 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -16,6 +16,9 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index d958fb75321f..c6b537f3b8dd 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -18,6 +18,9 @@ CONFIG_QSPI_AHB_INIT=y CONFIG_ENV_ADDR=0x40300000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index b1eda7b79a50..57cebf5f8b43 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -24,6 +24,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 6daaba6c1925..6960aa9d3ffd 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -21,6 +21,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index c5653d72514c..9ca4315c83c7 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -22,6 +22,9 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1000fff0 diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index f8649c58c495..e192ef48b131 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -18,6 +18,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y CONFIG_NXP_ESBC=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 2434ed379e15..6e5f29a708dd 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -20,6 +20,9 @@ CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_ENV_ADDR=0x40500000 CONFIG_AHCI=y CONFIG_LAYERSCAPE_NS_ACCESS=y +CONFIG_PCIE1=y +CONFIG_PCIE2=y +CONFIG_PCIE3=y CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_MP=y diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index ce559e907c05..bec2ca0f81da 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -16,10 +16,6 @@ #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */
-#define CONFIG_PCI1 /* PCI controller 1 */ -#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ -#undef CONFIG_PCI2 - #define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */
#ifndef __ASSEMBLY__ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 813516892c61..5f64bd944b39 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -63,9 +63,6 @@ /* High Level Configuration Options */
#if defined(CONFIG_PCI) -#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ -#define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ - /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 4a1fccff598c..d7df5795cc22 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -33,9 +33,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */
#define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index 6063113634c7..bc8aa3ce0549 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -9,8 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_PCIE3 -#define CONFIG_PCIE4 #define CONFIG_SYS_DPAA_RMAN
#define CONFIG_SYS_SRIO diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 6615dd091e20..6375c65d483b 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -9,8 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_PCIE3 - #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ diff --git a/include/configs/P5040DS.h b/include/configs/P5040DS.h index 6e6e5bec66be..fb73f0b95390 100644 --- a/include/configs/P5040DS.h +++ b/include/configs/P5040DS.h @@ -9,7 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_PCIE3 #define CONFIG_SYS_FSL_RAID_ENGINE
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 2ccfd87bfb05..cdae8a88df94 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -352,9 +352,6 @@ * General PCIe * Memory space is mapped 1-1, but I/O space must start from 0. */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */
#ifdef CONFIG_PCI /* controller 1, direct to uli, tgtid 3, Base address 20000 */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 1c2052608ec5..8222c674706e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -61,10 +61,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_PCIE4 /* PCIE controller 4 */
/* * These can be toggled for performance analysis, otherwise use default. diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index eda03dad229a..53fc49fdcf2f 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -368,10 +368,6 @@ * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_PCIE4 /* PCIE controller 4 */ /* controller 1, direct to uli, tgtid 3, Base address 20000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 290fd7cf744e..b3648ae06fae 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -321,10 +321,6 @@ * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_PCIE4 /* PCIE controller 4 */ /* controller 1, direct to uli, tgtid 3, Base address 20000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 29447e4895ab..3edae6b01b7c 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -12,8 +12,6 @@
#include <linux/stringify.h>
-#define CONFIG_PCIE4 - #define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
#ifdef CONFIG_RAMBOOT_PBL @@ -44,9 +42,6 @@
/* * These can be toggled for performance analysis, otherwise use default. diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c0952e092858..59ec06415671 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -36,8 +36,6 @@
/* * These can be toggled for performance analysis, otherwise use default. diff --git a/include/configs/kmcent2.h b/include/configs/kmcent2.h index 3b4ddb0f94a5..ed24733abf57 100644 --- a/include/configs/kmcent2.h +++ b/include/configs/kmcent2.h @@ -140,7 +140,6 @@
/* Environment in parallel NOR-Flash */ #define CONFIG_ENV_TOTAL_SIZE 0x040000 diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index 7f083c597e30..ee67215a097a 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -25,8 +25,6 @@ func(USB, usb, 0) \ func(DHCP, dhcp, na)
-#define CONFIG_PCIE1 /* PCIE controller 1 */ - #define CONFIG_PCI_SCAN_SHOW
#undef CONFIG_EXTRA_ENV_SETTINGS diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index b5992366cf42..9dbf1a7ab3c8 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -82,8 +82,6 @@ DSPI_CTAR_CSSCK(2) | DSPI_CTAR_ASC(0) | \ DSPI_CTAR_DT(0))
#undef CONFIG_EXTRA_ENV_SETTINGS diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index c57b598d70de..f71ab2c80c8b 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -36,8 +36,6 @@ #define __PHY_ETH2_MASK 0xFB #define __PHY_ETH1_MASK 0xFD
#undef CONFIG_EXTRA_ENV_SETTINGS diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index f43ea2bd6ec9..6556f1aa65d6 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -97,10 +97,6 @@ #define TSEC2_PHYIDX 0 #endif
-/* PCIe */ -#define CONFIG_PCIE1 /* PCIE controler 1 */ -#define CONFIG_PCIE2 /* PCIE controler 2 */ - #define FSL_PCIE_COMPAT "fsl,ls1021a-pcie"
#ifdef CONFIG_PCI diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 1faa38b082bb..00825b373e67 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -301,10 +301,6 @@
#endif
-/* PCIe */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ - #ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW #endif diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index 3ff694f6b58f..791df844c147 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -80,8 +80,6 @@ #define FSL_QSPI_FLASH_NUM 2
/* PCIe */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ #define FSL_PCIE_COMPAT "fsl,ls1021a-pcie" #ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index eff919116ec1..921399e31de9 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -171,10 +171,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 1
-/* PCIe */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ - #ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW #endif diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 8363969d557c..db00a0a002ab 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -110,10 +110,6 @@
/* PCIe */ #ifndef SPL_NO_PCIE -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ - #ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW #endif diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index e139aa93e1fc..3a1106777f92 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -76,11 +76,6 @@
/* I2C */
-/* PCIe */ -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ - #ifdef CONFIG_PCI #define CONFIG_PCI_SCAN_SHOW #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index b719c7e923cf..c4854e60e4c6 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -102,9 +102,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc #endif
-#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ -#define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ - #define CONFIG_HWCONFIG /* * These can be toggled for performance analysis, otherwise use default.
This converts the following to Kconfig: CONFIG_PCIE_IMX
Signed-off-by: Tom Rini trini@konsulko.com --- configs/ge_bx50v3_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/novena_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/vining_2000_defconfig | 1 + drivers/pci/Kconfig | 4 ++++ include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 3 --- include/configs/mx6sabresd.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/tbs2910.h | 1 - include/configs/vining_2000.h | 1 - 18 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index c9e4ee8f93d1..114a361a1843 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -74,6 +74,7 @@ CONFIG_CMD_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 0044d893128e..ea9e7e2cbf0a 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -114,6 +114,7 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 08580255f79d..c0c7c0daf134 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -118,6 +118,7 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index e2eab2bb3815..7ce02fef8a2c 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -124,6 +124,7 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 15dbaf848cd7..f5ad3664db72 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -97,6 +97,7 @@ CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index c41b2d9264ea..9a9e0da5140b 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -60,6 +60,7 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 6b0f17628dcd..f156296adabb 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -75,6 +75,7 @@ CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 4b304f8c7f58..0401dc6142d3 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -83,6 +83,7 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y # CONFIG_PCI_PNP is not set +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_RTC=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index da782889a1bc..ad534ab58605 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -84,6 +84,7 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_POWER_LEGACY=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index fd2203420c3b..0c74f95f6041 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -254,6 +254,10 @@ config FSL_PCIE_EP_COMPAT This compatible is used to find pci controller ep node in Kernel DT to complete fixup.
+config PCIE_IMX + bool "i.MX PCIe support" + depends on ARCH_MX6 + config PCIE_INTEL_FPGA bool "Intel FPGA PCIe support" help diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index d813c6c22e78..b4638a2b9d82 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -110,6 +110,5 @@ #define CONFIG_IMX6_PWM_PER_CLK 66000000
#define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX
#endif /* __GE_BX50V3_CONFIG_H */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 47a72fc8fce5..4a0aaf4da583 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -31,9 +31,6 @@ /* * PCI express */ -#ifdef CONFIG_CMD_PCI -#define CONFIG_PCIE_IMX -#endif
/* * PMIC diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index ef255aa360e9..845154520e74 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -25,7 +25,6 @@
#ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) #endif diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 7bbc500ae126..fe3cb1e4dc5b 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -130,7 +130,6 @@
#ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(2, 0) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 72a9f4ec24fb..ff9cb12a59cd 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -102,7 +102,6 @@ */ #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 9f18db465e10..54afcf620df2 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -49,7 +49,6 @@ /* PCI express */ #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(3, 29) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(7, 12) #endif diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index b160f33dbfc6..2f6319936f75 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -30,7 +30,6 @@ /* PCI */ #ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #endif
diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 9cc8fc5ff533..beaff28aa2b7 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -46,7 +46,6 @@
#ifdef CONFIG_CMD_PCI #define CONFIG_PCI_SCAN_SHOW -#define CONFIG_PCIE_IMX #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(4, 6) #endif
This driver is not enabled anywhere, remove it. Also remove definitions of symbols only used in this driver, on platforms that did not enable it.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/pci/Makefile | 1 - drivers/pci/pci_sh4.c | 82 -------------------------------- include/configs/x86-chromebook.h | 12 ----- 3 files changed, 95 deletions(-) delete mode 100644 drivers/pci/pci_sh4.c
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 04f623652f09..cfcd6fd6c52f 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -20,7 +20,6 @@ obj-$(CONFIG_PCIE_IMX) += pcie_imx.o obj-$(CONFIG_PCI_MVEBU) += pci_mvebu.o obj-$(CONFIG_PCI_RCAR_GEN2) += pci-rcar-gen2.o obj-$(CONFIG_PCI_RCAR_GEN3) += pci-rcar-gen3.o -obj-$(CONFIG_SH4_PCI) += pci_sh4.o obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o obj-$(CONFIG_PCI_TEGRA) += pci_tegra.o diff --git a/drivers/pci/pci_sh4.c b/drivers/pci/pci_sh4.c deleted file mode 100644 index aac9be055e2c..000000000000 --- a/drivers/pci/pci_sh4.c +++ /dev/null @@ -1,82 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * SH4 PCI Controller (PCIC) for U-Boot. - * (C) Dustin McIntire (dustin@sensoria.com) - * (C) 2007,2008 Nobuhiro Iwamatsu iwamatsu@nigauri.org - * (C) 2008 Yusuke Goda goda.yusuke@renesas.com - * - * u-boot/arch/sh/cpu/sh4/pci-sh4.c - */ - -#include <common.h> -#include <linux/delay.h> - -#include <asm/processor.h> -#include <asm/io.h> -#include <asm/pci.h> -#include <pci.h> - -int pci_sh4_init(struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->region_count = 0; - hose->last_busno = 0xff; - - /* PCI memory space */ - pci_set_region(hose->regions + 0, - CONFIG_PCI_MEM_BUS, - CONFIG_PCI_MEM_PHYS, - CONFIG_PCI_MEM_SIZE, - PCI_REGION_MEM); - hose->region_count++; - - /* PCI IO space */ - pci_set_region(hose->regions + 1, - CONFIG_PCI_IO_BUS, - CONFIG_PCI_IO_PHYS, - CONFIG_PCI_IO_SIZE, - PCI_REGION_IO); - hose->region_count++; - -#if defined(CONFIG_PCI_SYS_BUS) - /* PCI System Memory space */ - pci_set_region(hose->regions + 2, - CONFIG_PCI_SYS_BUS, - CONFIG_PCI_SYS_PHYS, - CONFIG_PCI_SYS_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - hose->region_count++; -#endif - - udelay(1000); - - pci_set_ops(hose, - pci_hose_read_config_byte_via_dword, - pci_hose_read_config_word_via_dword, - pci_sh4_read_config_dword, - pci_hose_write_config_byte_via_dword, - pci_hose_write_config_word_via_dword, - pci_sh4_write_config_dword); - - pci_register_hose(hose); - - udelay(1000); - -#ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Bus Dev VenId DevId Class Int\n"); -#endif - hose->last_busno = pci_hose_scan(hose); - return 0; -} - -int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) -{ - return 0; -} - -#ifdef CONFIG_PCI_SCAN_SHOW -int pci_print_dev(struct pci_controller *hose, pci_dev_t dev) -{ - return 1; -} -#endif /* CONFIG_PCI_SCAN_SHOW */ diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index b45d2bbd6266..4109af7d8511 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -12,18 +12,6 @@ #define CONFIG_X86_REFCODE_ADDR 0xffea0000 #define CONFIG_X86_REFCODE_RUN_ADDR 0
-#define CONFIG_PCI_MEM_BUS 0xe0000000 -#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS -#define CONFIG_PCI_MEM_SIZE 0x10000000 - -#define CONFIG_PCI_PREF_BUS 0xd0000000 -#define CONFIG_PCI_PREF_PHYS CONFIG_PCI_PREF_BUS -#define CONFIG_PCI_PREF_SIZE 0x10000000 - -#define CONFIG_PCI_IO_BUS 0x1000 -#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS -#define CONFIG_PCI_IO_SIZE 0xefff - #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
This converts the following to Kconfig: CONFIG_PCI_SCAN_SHOW
Signed-off-by: Tom Rini trini@konsulko.com --- configs/ge_bx50v3_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/novena_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/vining_2000_defconfig | 1 + drivers/pci/Kconfig | 4 ++++ include/configs/MPC837XERDB.h | 4 ---- include/configs/MPC8548CDS.h | 4 ---- include/configs/P1010RDB.h | 2 -- include/configs/P2041RDB.h | 4 ---- include/configs/T102xRDB.h | 2 -- include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 4 ---- include/configs/T208xRDB.h | 4 ---- include/configs/T4240RDB.h | 4 ---- include/configs/apalis-tk1.h | 3 --- include/configs/clearfog.h | 3 --- include/configs/controlcenterdc.h | 3 --- include/configs/corenet_ds.h | 4 ---- include/configs/db-88f6820-amc.h | 3 --- include/configs/db-88f6820-gp.h | 3 --- include/configs/db-mv784mp-gp.h | 3 --- include/configs/ds414.h | 3 --- include/configs/durian.h | 3 --- include/configs/ge_bx50v3.h | 2 -- include/configs/helios4.h | 3 --- include/configs/ls1012afrwy.h | 2 -- include/configs/ls1012aqds.h | 2 -- include/configs/ls1012ardb.h | 2 -- include/configs/ls1021aiot.h | 4 ---- include/configs/ls1021aqds.h | 4 ---- include/configs/ls1021atsn.h | 3 --- include/configs/ls1021atwr.h | 4 ---- include/configs/ls1043a_common.h | 7 ------- include/configs/ls1046a_common.h | 4 ---- include/configs/ls2080aqds.h | 4 ---- include/configs/ls2080ardb.h | 4 ---- include/configs/lx2160a_common.h | 5 ----- include/configs/mx6sabresd.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/nitrogen6x.h | 7 ------- include/configs/novena.h | 1 - include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/tbs2910.h | 1 - include/configs/vining_2000.h | 1 - include/configs/x530.h | 3 --- 47 files changed, 10 insertions(+), 125 deletions(-)
diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 114a361a1843..c33287812663 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -74,6 +74,7 @@ CONFIG_CMD_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index f5ad3664db72..ea0c76467462 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -97,6 +97,7 @@ CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 9a9e0da5140b..1985ff96dec3 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -60,6 +60,7 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index f156296adabb..d4ab93850c4a 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -75,6 +75,7 @@ CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 0401dc6142d3..892d7c60d283 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -83,6 +83,7 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y # CONFIG_PCI_PNP is not set +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index ad534ab58605..8d87857ba0a4 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -84,6 +84,7 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y +CONFIG_PCI_SCAN_SHOW=y CONFIG_PCIE_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 0c74f95f6041..f4c4aece58d7 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -81,6 +81,10 @@ config PCI_ARID support on PCI devices. This helps to skip some devices in BDF scan that are not present.
+config PCI_SCAN_SHOW + bool "Show PCI devices during startup" + depends on PCIE_IMX + config PCIE_ECAM_GENERIC bool "Generic ECAM-based PCI host controller support" help diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 8e75d779c418..e8e0a1c66999 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -232,10 +232,6 @@ #define CONFIG_SYS_PCIE2_IO_PHYS 0xD8000000 #define CONFIG_SYS_PCIE2_IO_SIZE 0x00800000
-#ifdef CONFIG_PCI -#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - /* * TSEC */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index bec2ca0f81da..2eb33812f76a 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -312,10 +312,6 @@ #endif #define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */
-#if defined(CONFIG_PCI) -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - #if defined(CONFIG_TSEC_ENET)
#define CONFIG_TSEC1 1 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 5f64bd944b39..aea744c826cc 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -94,8 +94,6 @@ #else #define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 #endif - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif
#define CONFIG_HWCONFIG diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index d7df5795cc22..e019c168434a 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -321,10 +321,6 @@ #define CONFIG_SYS_DPAA_PME #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - #ifdef CONFIG_FMAN_ENET #define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x2 #define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x3 diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index cdae8a88df94..a519b5a9355e 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -377,8 +377,6 @@ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull #endif - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
/* diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 8222c674706e..3a7c643cfc94 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -362,8 +362,6 @@ #define CONFIG_SYS_PCIE4_IO_VIRT 0xf8030000 #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull #endif - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
/* diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 53fc49fdcf2f..eff22c18bb72 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -391,10 +391,6 @@ #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc40000000ull #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif - /* Qman/Bman */ #ifndef CONFIG_NOBQFMAN #define CONFIG_SYS_BMAN_NUM_PORTALS 18 diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index b3648ae06fae..ba9bfdd72f7e 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -344,10 +344,6 @@ #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc40000000ull #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif - /* Qman/Bman */ #ifndef CONFIG_NOBQFMAN #define CONFIG_SYS_BMAN_NUM_PORTALS 18 diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 3edae6b01b7c..12b479f9c773 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -138,10 +138,6 @@ #define CONFIG_SYS_PCIE4_MEM_PHYS 0xc60000000ull #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - /* * Environment */ diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index a362282a291e..6a4092a83e2e 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -19,9 +19,6 @@ #define FDT_MODULE "apalis-v1.2" #define FDT_MODULE_V1_0 "apalis"
-/* PCI host support */ -#undef CONFIG_PCI_SCAN_SHOW - /* * Custom Distro Boot configuration: * 1. 8bit SD port (MMC1) diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 9969269bf2ac..9c9e9506dc64 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -28,9 +28,6 @@
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* Keep device tree and initrd in lower memory so the kernel can access them */ #define RELOCATION_LIMITS_ENV_SETTINGS \ "fdt_high=0x10000000\0" \ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index bb1595f96111..5da2778b67be 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -17,9 +17,6 @@
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* * Environment Configuration */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 59ec06415671..2252bf89543d 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -314,10 +314,6 @@ #define CONFIG_SYS_DPAA_PME #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - #ifdef CONFIG_FMAN_ENET #define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x1c #define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x1d diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 6912f39d32d2..b9d03d253d99 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -14,9 +14,6 @@
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* NAND */
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 3b3a7abd281f..bba2b607aa86 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -17,9 +17,6 @@
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0x10000000\0" \ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 715a6d7a9e71..7b305955c962 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -21,9 +21,6 @@
/* diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 7e3f657e31cc..f8273a92f11a 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -19,9 +19,6 @@ /* I2C */ #define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/durian.h b/include/configs/durian.h index c224511832ff..7971df8c1d3b 100644 --- a/include/configs/durian.h +++ b/include/configs/durian.h @@ -13,9 +13,6 @@ #define PHYS_SDRAM_1_SIZE 0x7B000000 #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
-/* PCI CONFIG */ -#define CONFIG_PCI_SCAN_SHOW - /* BOOT */ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index b4638a2b9d82..ad00769bdeef 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -109,6 +109,4 @@
-#define CONFIG_PCI_SCAN_SHOW - #endif /* __GE_BX50V3_CONFIG_H */ diff --git a/include/configs/helios4.h b/include/configs/helios4.h index ff2c50644326..fc32487e1c7b 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -28,9 +28,6 @@
-/* PCIe support */ -#define CONFIG_PCI_SCAN_SHOW - /* Keep device tree and initrd in lower memory so the kernel can access them */ #define RELOCATION_LIMITS_ENV_SETTINGS \ "fdt_high=0x10000000\0" \ diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index ee67215a097a..a0ff3b897904 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -25,8 +25,6 @@ func(USB, usb, 0) \ func(DHCP, dhcp, na)
-#define CONFIG_PCI_SCAN_SHOW - #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "verify=no\0" \ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index 9dbf1a7ab3c8..b124ce52620c 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -82,8 +82,6 @@ DSPI_CTAR_CSSCK(2) | DSPI_CTAR_ASC(0) | \ DSPI_CTAR_DT(0))
-#define CONFIG_PCI_SCAN_SHOW - #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "verify=no\0" \ diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index f71ab2c80c8b..4f77acdaedec 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -36,8 +36,6 @@ #define __PHY_ETH2_MASK 0xFB #define __PHY_ETH1_MASK 0xFD
-#define CONFIG_PCI_SCAN_SHOW - #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ "verify=no\0" \ diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 6556f1aa65d6..ec688741a07e 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -99,10 +99,6 @@
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - #define CONFIG_PEN_ADDR_BIG_ENDIAN #define CONFIG_SMP_PEN_ADDR 0x01ee0200
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 00825b373e67..1a46f72a7357 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -301,10 +301,6 @@
#endif
diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h index 791df844c147..e5754c94e0fc 100644 --- a/include/configs/ls1021atsn.h +++ b/include/configs/ls1021atsn.h @@ -81,9 +81,6 @@
/* PCIe */ #define FSL_PCIE_COMPAT "fsl,ls1021a-pcie" -#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif
#define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 256 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 921399e31de9..09dce21aec5f 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -171,10 +171,6 @@ #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_SYS_EEPROM_BUS_NUM 1
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index db00a0a002ab..ed32e20dbf45 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -108,13 +108,6 @@
/* I2C */
-/* PCIe */ -#ifndef SPL_NO_PCIE -#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif -#endif - /* DSPI */
/* FMan ucode */ diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 3a1106777f92..94118c420e6a 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -76,10 +76,6 @@
/* I2C */
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - /* SATA */ #ifndef SPL_NO_SATA #define CONFIG_SYS_SATA AHCI_BASE_ADDR diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 9de602bc1640..9ba7258572fc 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -251,10 +251,6 @@
#define CONFIG_FSL_MEMAC
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - /* Initial environment variables */ #undef CONFIG_EXTRA_ENV_SETTINGS #ifdef CONFIG_NXP_ESBC diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 9c4d2feb7883..a504a0ea462a 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -238,10 +238,6 @@
-#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - #define BOOT_TARGET_DEVICES(func) \ func(USB, usb, 0) \ func(MMC, mmc, 0) \ diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index bc3a0046ac63..77e25822dcd6 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -89,11 +89,6 @@ /* Qixis */ #define CONFIG_SYS_I2C_FPGA_ADDR 0x66
-/* PCI */ -#ifdef CONFIG_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - /* USB */
#define COUNTER_FREQUENCY_REAL (get_board_sys_clk() / 4) diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 845154520e74..16f8858abb8f 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,7 +24,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 3
#ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) #endif diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index fe3cb1e4dc5b..58d550fee9ec 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -129,7 +129,6 @@ #endif
#ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(2, 0) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index ff9cb12a59cd..2007b48868f6 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -97,11 +97,4 @@
/* Environment organization */
-/* - * PCI express - */ -#ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 54afcf620df2..1696aa28520f 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -48,7 +48,6 @@
/* PCI express */ #ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(3, 29) #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(7, 12) #endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index c4854e60e4c6..93ae5c4d4033 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -393,8 +393,6 @@ #else #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 #endif - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET) diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 2f6319936f75..95bd45818703 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -29,7 +29,6 @@
/* PCI */ #ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #endif
diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index beaff28aa2b7..6eb022f26c5f 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -45,7 +45,6 @@ #define CONFIG_MXC_USB_FLAGS 0
#ifdef CONFIG_CMD_PCI -#define CONFIG_PCI_SCAN_SHOW #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(4, 6) #endif
diff --git a/include/configs/x530.h b/include/configs/x530.h index 1f1b4e1449eb..cb126837b9ca 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -47,9 +47,6 @@
#include <asm/arch/config.h>
This converts the following to Kconfig: CONFIG_PCI_GT64120
Signed-off-by: Tom Rini trini@konsulko.com --- configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + drivers/pci/Kconfig | 4 ++++ include/configs/malta.h | 1 - 6 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index cbea4fadff7e..a2d938c0dc74 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -38,5 +38,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y +CONFIG_PCI_GT64120=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index b268e33a379f..f7345b2484a4 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -40,5 +40,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y +CONFIG_PCI_GT64120=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 7b1b50547a4d..ae9cad857e2c 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -37,5 +37,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y +CONFIG_PCI_GT64120=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 540864b57327..963b9be59ea0 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -39,5 +39,6 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y +CONFIG_PCI_GT64120=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index f4c4aece58d7..0ef5c2923378 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -101,6 +101,10 @@ config PCIE_ECAM_SYNQUACER Note that this must be configured when boot because Linux driver expects the PCIe RC has been configured in the bootloader.
+config PCI_GT64120 + bool "GT64120 PCI support" + depends on MIPS + config PCI_PHYTIUM bool "Phytium PCIe support" help diff --git a/include/configs/malta.h b/include/configs/malta.h index 225ed7cd5cdc..75f38000f6ba 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -13,7 +13,6 @@
#define CONFIG_MEMSIZE_IN_BYTES
-#define CONFIG_PCI_GT64120 #define CONFIG_PCI_MSC01
#define CONFIG_SYS_ISA_IO_BASE_ADDRESS 0
This converts the following to Kconfig: CONFIG_PCI_CONFIG_HOST_BRIDGE
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/pci/Kconfig | 4 ++++ include/configs/x86-common.h | 5 ----- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 0ef5c2923378..53d0ebd745e7 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -48,6 +48,10 @@ config PCI_REGION_MULTI_ENTRY region type. This helps to add support for SoC's like OcteonTX/TX2 where every peripheral is on the PCI bus.
+config PCI_CONFIG_HOST_BRIDGE + bool "Configure PCI host bridges" + default y if X86 + config PCI_MAP_SYSTEM_MEMORY bool "Map local system memory from a virtual base address" depends on MIPS diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index f28fafe15c63..1366f623aa25 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -44,11 +44,6 @@ * Environment configuration */
-/*----------------------------------------------------------------------- - * PCI configuration - */ -#define CONFIG_PCI_CONFIG_HOST_BRIDGE - /*----------------------------------------------------------------------- * USB configuration */
The only mcf5445x platform does not enable PCI, drop this code.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/m68k/cpu/mcf5445x/Makefile | 2 +- arch/m68k/cpu/mcf5445x/pci.c | 151 -------------------------------- 2 files changed, 1 insertion(+), 152 deletions(-) delete mode 100644 arch/m68k/cpu/mcf5445x/pci.c
diff --git a/arch/m68k/cpu/mcf5445x/Makefile b/arch/m68k/cpu/mcf5445x/Makefile index ba90fc3c34a3..6a38c4838e99 100644 --- a/arch/m68k/cpu/mcf5445x/Makefile +++ b/arch/m68k/cpu/mcf5445x/Makefile @@ -6,4 +6,4 @@ # ccflags-y += -DET_DEBUG
extra-y = start.o -obj-y = cpu.o speed.o cpu_init.o interrupts.o pci.o dspi.o +obj-y = cpu.o speed.o cpu_init.o interrupts.o dspi.o diff --git a/arch/m68k/cpu/mcf5445x/pci.c b/arch/m68k/cpu/mcf5445x/pci.c deleted file mode 100644 index d487468d0bfa..000000000000 --- a/arch/m68k/cpu/mcf5445x/pci.c +++ /dev/null @@ -1,151 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2004-2007, 2012 Freescale Semiconductor, Inc. - * TsiChung Liew (Tsi-Chung.Liew@freescale.com) - */ - -/* - * PCI Configuration space access support - */ -#include <common.h> -#include <pci.h> -#include <asm/io.h> -#include <asm/immap.h> -#include <linux/delay.h> - -#if defined(CONFIG_PCI) -/* System RAM mapped over PCI */ -#define CONFIG_SYS_PCI_SYS_MEM_BUS CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_PCI_SYS_MEM_PHYS CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_PCI_SYS_MEM_SIZE (1024 * 1024 * 1024) - -#define cfg_read(val, addr, type, op) *val = op((type)(addr)); -#define cfg_write(val, addr, type, op) op((type *)(addr), (val)); - -#define PCI_OP(rw, size, type, op, mask) \ -int pci_##rw##_cfg_##size(struct pci_controller *hose, \ - pci_dev_t dev, int offset, type val) \ -{ \ - u32 addr = PCI_CONF1_ADDRESS(PCI_BUS(dev), PCI_DEV(dev), \ - PCI_FUNC(dev), offset); \ - out_be32(hose->cfg_addr, addr); \ - cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ - out_be32(hose->cfg_addr, addr & ~PCI_CONF1_ENABLE); \ - return 0; \ -} - -PCI_OP(read, byte, u8 *, in_8, 3) -PCI_OP(read, word, u16 *, in_le16, 2) -PCI_OP(read, dword, u32 *, in_le32, 0) -PCI_OP(write, byte, u8, out_8, 3) -PCI_OP(write, word, u16, out_le16, 2) -PCI_OP(write, dword, u32, out_le32, 0) - -void pci_mcf5445x_init(struct pci_controller *hose) -{ - pci_t *pci = (pci_t *)MMAP_PCI; - pciarb_t *pciarb = (pciarb_t *)MMAP_PCIARB; - gpio_t *gpio = (gpio_t *) MMAP_GPIO; - u32 barEn = 0; - - out_be32(&pciarb->acr, 0x001f001f); - - /* Set PCIGNT1, PCIREQ1, PCIREQ0/PCIGNTIN, PCIGNT0/PCIREQOUT, - PCIREQ2, PCIGNT2 */ - out_be16(&gpio->par_pci, - GPIO_PAR_PCI_GNT3_GNT3 | GPIO_PAR_PCI_GNT2 | - GPIO_PAR_PCI_GNT1 | GPIO_PAR_PCI_GNT0 | - GPIO_PAR_PCI_REQ3_REQ3 | GPIO_PAR_PCI_REQ2 | - GPIO_PAR_PCI_REQ1 | GPIO_PAR_PCI_REQ0); - - /* Assert reset bit */ - setbits_be32(&pci->gscr, PCI_GSCR_PR); - - setbits_be32(&pci->tcr1, PCI_TCR1_P); - - /* Initiator windows */ - out_be32(&pci->iw0btar, - CONFIG_SYS_PCI_MEM_PHYS | (CONFIG_SYS_PCI_MEM_PHYS >> 16)); - out_be32(&pci->iw1btar, - CONFIG_SYS_PCI_IO_PHYS | (CONFIG_SYS_PCI_IO_PHYS >> 16)); - out_be32(&pci->iw2btar, - CONFIG_SYS_PCI_CFG_PHYS | (CONFIG_SYS_PCI_CFG_PHYS >> 16)); - - out_be32(&pci->iwcr, - PCI_IWCR_W0C_EN | PCI_IWCR_W1C_EN | PCI_IWCR_W1C_IO | - PCI_IWCR_W2C_EN | PCI_IWCR_W2C_IO); - - out_be32(&pci->icr, 0); - - /* Enable bus master and mem access */ - out_be32(&pci->scr, PCI_SCR_B | PCI_SCR_M); - - /* Cache line size and master latency */ - out_be32(&pci->cr1, PCI_CR1_CLS(8) | PCI_CR1_LTMR(0xF8)); - out_be32(&pci->cr2, 0); - -#ifdef CONFIG_SYS_PCI_BAR0 - out_be32(&pci->bar0, PCI_BAR_BAR0(CONFIG_SYS_PCI_BAR0)); - out_be32(&pci->tbatr0, CONFIG_SYS_PCI_TBATR0 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B0E; -#endif -#ifdef CONFIG_SYS_PCI_BAR1 - out_be32(&pci->bar1, PCI_BAR_BAR1(CONFIG_SYS_PCI_BAR1)); - out_be32(&pci->tbatr1, CONFIG_SYS_PCI_TBATR1 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B1E; -#endif -#ifdef CONFIG_SYS_PCI_BAR2 - out_be32(&pci->bar2, PCI_BAR_BAR2(CONFIG_SYS_PCI_BAR2)); - out_be32(&pci->tbatr2, CONFIG_SYS_PCI_TBATR2 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B2E; -#endif -#ifdef CONFIG_SYS_PCI_BAR3 - out_be32(&pci->bar3, PCI_BAR_BAR3(CONFIG_SYS_PCI_BAR3)); - out_be32(&pci->tbatr3, CONFIG_SYS_PCI_TBATR3 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B3E; -#endif -#ifdef CONFIG_SYS_PCI_BAR4 - out_be32(&pci->bar4, PCI_BAR_BAR4(CONFIG_SYS_PCI_BAR4)); - out_be32(&pci->tbatr4, CONFIG_SYS_PCI_TBATR4 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B4E; -#endif -#ifdef CONFIG_SYS_PCI_BAR5 - out_be32(&pci->bar5, PCI_BAR_BAR5(CONFIG_SYS_PCI_BAR5)); - out_be32(&pci->tbatr5, CONFIG_SYS_PCI_TBATR5 | PCI_TBATR_EN); - barEn |= PCI_TCR2_B5E; -#endif - - out_be32(&pci->tcr2, barEn); - - /* Deassert reset bit */ - clrbits_be32(&pci->gscr, PCI_GSCR_PR); - udelay(1000); - - /* Enable PCI bus master support */ - hose->first_busno = 0; - hose->last_busno = 0xff; - - pci_set_region(hose->regions + 0, CONFIG_SYS_PCI_MEM_BUS, CONFIG_SYS_PCI_MEM_PHYS, - CONFIG_SYS_PCI_MEM_SIZE, PCI_REGION_MEM); - - pci_set_region(hose->regions + 1, CONFIG_SYS_PCI_IO_BUS, CONFIG_SYS_PCI_IO_PHYS, - CONFIG_SYS_PCI_IO_SIZE, PCI_REGION_IO); - - pci_set_region(hose->regions + 2, CONFIG_SYS_PCI_SYS_MEM_BUS, - CONFIG_SYS_PCI_SYS_MEM_PHYS, CONFIG_SYS_PCI_SYS_MEM_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - hose->region_count = 3; - - hose->cfg_addr = &(pci->car); - hose->cfg_data = (volatile unsigned char *)CONFIG_SYS_PCI_CFG_BUS; - - pci_set_ops(hose, pci_read_cfg_byte, pci_read_cfg_word, - pci_read_cfg_dword, pci_write_cfg_byte, pci_write_cfg_word, - pci_write_cfg_dword); - - /* Hose scan */ - pci_register_hose(hose); - hose->last_busno = pci_hose_scan(hose); -} -#endif /* CONFIG_PCI */
These defines aren't referenced in code today, remove them.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/MPC837XERDB.h | 24 ------------------------ 1 file changed, 24 deletions(-)
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index e8e0a1c66999..3e4d66874df4 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -198,39 +198,15 @@ * General PCI * Addresses are mapped 1-1. */ -#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE -#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI_MMIO_BASE 0x90000000 -#define CONFIG_SYS_PCI_MMIO_PHYS CONFIG_SYS_PCI_MMIO_BASE -#define CONFIG_SYS_PCI_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI_IO_PHYS 0xE0300000 -#define CONFIG_SYS_PCI_IO_SIZE 0x100000 /* 1M */ - -#define CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_SDRAM_BASE -#define CONFIG_SYS_PCI_SLV_MEM_BUS 0x00000000 -#define CONFIG_SYS_PCI_SLV_MEM_SIZE 0x80000000 - -#define CONFIG_SYS_PCIE1_BASE 0xA0000000 #define CONFIG_SYS_PCIE1_CFG_BASE 0xA0000000 #define CONFIG_SYS_PCIE1_CFG_SIZE 0x08000000 -#define CONFIG_SYS_PCIE1_MEM_BASE 0xA8000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xA8000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 -#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xB8000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000
-#define CONFIG_SYS_PCIE2_BASE 0xC0000000 #define CONFIG_SYS_PCIE2_CFG_BASE 0xC0000000 #define CONFIG_SYS_PCIE2_CFG_SIZE 0x08000000 -#define CONFIG_SYS_PCIE2_MEM_BASE 0xC8000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xC8000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 -#define CONFIG_SYS_PCIE2_IO_BASE 0x00000000 #define CONFIG_SYS_PCIE2_IO_PHYS 0xD8000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00800000
/* * TSEC
This converts the following to Kconfig: CONFIG_SH7751_PCI
Signed-off-by: Tom Rini trini@konsulko.com --- configs/r2dplus_defconfig | 1 + drivers/pci/Kconfig | 6 ++++++ include/configs/r2dplus.h | 5 ----- 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 5a38b070437d..2beda3a2fe0a 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -52,6 +52,7 @@ CONFIG_PCNET=y CONFIG_RTL8139=y CONFIG_TULIP=y CONFIG_PCI=y +CONFIG_SH7751_PCI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SERIAL_RX_BUFFER=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 53d0ebd745e7..680d5baa8029 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -171,6 +171,12 @@ config PCI_SANDBOX the device tree but the normal PCI scan technique is used to find then.
+config SH7751_PCI + bool "SH7751 PCI controller support" + depends on SH + help + SuperH PCI Bridge Configuration + config PCI_TEGRA bool "Tegra PCI support" depends on ARCH_TEGRA diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index ae712629df34..409d5af0241d 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -25,9 +25,4 @@ */ #define CONFIG_SYS_PLL_SETTLING_TIME 100/* in us */
-/* - * SuperH PCI Bridge Configration - */ -#define CONFIG_SH7751_PCI - #endif /* __CONFIG_H */
The symbol CONFIG_PCI_CLK_FREQ is local to this board. Provide equal clarity in the code by referencing the numeric value directly and move the explanatory comment to the code, just prior to use.
Signed-off-by: Tom Rini trini@konsulko.com --- board/socrates/socrates.c | 3 ++- include/configs/socrates.h | 2 -- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 3430a1ed0178..27aad4eaae3a 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -59,7 +59,8 @@ int checkboard (void) f = get_board_sys_clk(); } else { src = "PCI_CLK"; - f = CONFIG_PCI_CLK_FREQ; + /* PCI is clocked by the external source at 33 MHz */ + f = 33000000; } printf ("PCI1: 32 bit, %d MHz (%s)\n", f/1000000, src); #else diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 14f7bb9f7132..6a78cb1f2648 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -123,8 +123,6 @@ * Memory space is mapped 1-1. */
-/* PCI is clocked by the external source at 33 MHz */ -#define CONFIG_PCI_CLK_FREQ 33000000 #define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 #define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE #define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */
This converts the following to Kconfig: CONFIG_PCI_MSC01
Signed-off-by: Tom Rini trini@konsulko.com --- configs/malta64_defconfig | 1 + configs/malta64el_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + drivers/pci/Kconfig | 4 ++++ include/configs/malta.h | 2 -- 6 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index a2d938c0dc74..be8689071665 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -39,5 +39,6 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y CONFIG_PCI_GT64120=y +CONFIG_PCI_MSC01=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index f7345b2484a4..436bae8af87c 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -41,5 +41,6 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y CONFIG_PCI_GT64120=y +CONFIG_PCI_MSC01=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index ae9cad857e2c..88c0d5628dee 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -38,5 +38,6 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y CONFIG_PCI_GT64120=y +CONFIG_PCI_MSC01=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index 963b9be59ea0..58d31d6a4432 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -40,5 +40,6 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_PCNET=y CONFIG_PCI_GT64120=y +CONFIG_PCI_MSC01=y CONFIG_RTC_MC146818=y CONFIG_SYS_NS16550=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 680d5baa8029..e4c60561ee5d 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -146,6 +146,10 @@ config PCI_MPC85XX Say Y here if you want to enable PCI controller support on FSL PowerPC MPC85xx SoC.
+config PCI_MSC01 + bool "MSC01 PCI support" + depends on TARGET_MALTA + config PCI_RCAR_GEN2 bool "Renesas RCar Gen2 PCIe driver" depends on RCAR_32 diff --git a/include/configs/malta.h b/include/configs/malta.h index 75f38000f6ba..affee0069402 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -13,8 +13,6 @@
-#define CONFIG_PCI_MSC01 - #define CONFIG_SYS_ISA_IO_BASE_ADDRESS 0
This converts the following to Kconfig: CONFIG_SYS_FSL_PCI_VER_3_X
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/include/asm/config_mpc85xx.h | 2 -- drivers/pci/Kconfig | 4 ++++ 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index ce3a776c7e88..a43e6e5e538b 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -195,7 +195,6 @@ #define CONFIG_SYS_FSL_SRIO_LIODN #define CONFIG_SYS_FSL_USB_DUAL_PHY_ENABLE #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY -#define CONFIG_SYS_FSL_PCI_VER_3_X
#elif defined(CONFIG_ARCH_B4860) || defined(CONFIG_ARCH_B4420) #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ @@ -293,7 +292,6 @@ #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 4, 4, 4 } #define CONFIG_SYS_FSL_SRDS_1 -#define CONFIG_SYS_FSL_PCI_VER_3_X #if defined(CONFIG_ARCH_T2080) #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 4 diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index e4c60561ee5d..436acca898e4 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -133,8 +133,12 @@ config PCIE_DW_SIFIVE Say Y here if you want to enable PCIe controller support on FU740.
+config SYS_FSL_PCI_VER_3_X + bool + config PCIE_FSL bool "FSL PowerPC PCIe support" + select SYS_FSL_PCI_VER_3_X if ARCH_T2080 || ARCH_T4240 help Say Y here if you want to enable PCIe controller support on FSL PowerPC MPC85xx, MPC86xx, B series, P series and T series SoCs.
These CONFIG options are only used on this board, in the board file itself. Remove these from the CONFIG namespace and define in the board file.
Signed-off-by: Tom Rini trini@konsulko.com --- board/emulation/qemu-ppce500/qemu-ppce500.c | 8 ++++++-- include/configs/qemu-ppce500.h | 4 ---- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/emulation/qemu-ppce500/qemu-ppce500.c b/board/emulation/qemu-ppce500/qemu-ppce500.c index 348fcf3bb099..99edaa3b4215 100644 --- a/board/emulation/qemu-ppce500/qemu-ppce500.c +++ b/board/emulation/qemu-ppce500/qemu-ppce500.c @@ -32,6 +32,10 @@
DECLARE_GLOBAL_DATA_PTR;
+/* Virtual address range for PCI region maps */ +#define SYS_PCI_MAP_START 0x80000000 +#define SYS_PCI_MAP_END 0xe0000000 + static void *get_fdt_virt(void) { if (gd->flags & GD_FLG_RELOC) @@ -101,7 +105,7 @@ static int pci_map_region(phys_addr_t paddr, phys_size_t size, ulong *pmap_addr) map_addr += size - 1; map_addr &= ~(size - 1);
- if (map_addr + size >= CONFIG_SYS_PCI_MAP_END) + if (map_addr + size >= SYS_PCI_MAP_END) return -1;
/* Map virtual memory for range */ @@ -137,7 +141,7 @@ int misc_init_r(void) pci_get_regions(dev, &io, &mem, &pre);
/* Start MMIO and PIO range maps above RAM */ - map_addr = CONFIG_SYS_PCI_MAP_START; + map_addr = SYS_PCI_MAP_START;
/* Map MMIO range */ ret = pci_map_region(mem->phys_start, mem->size, &map_addr); diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 006593acfddd..451ae0e1e6df 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -25,10 +25,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR #endif
-/* Virtual address range for PCI region maps */ -#define CONFIG_SYS_PCI_MAP_START 0x80000000 -#define CONFIG_SYS_PCI_MAP_END 0xe0000000 - /* Virtual address to a temporary map if we need it (max 128MB) */ #define CONFIG_SYS_TMPVIRT 0xe8000000
This converts the following to Kconfig: CONFIG_KIRKWOOD_EGIGA_INIT CONFIG_KIRKWOOD_PCIE_INIT CONFIG_KIRKWOOD_RGMII_PAD_1V8 CONFIG_KM_DISABLE_PCIE
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-kirkwood/Kconfig | 12 ++++++++++++ arch/arm/mach-kirkwood/include/mach/config.h | 3 --- configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + include/configs/SBx81LIFKW.h | 4 ---- include/configs/SBx81LIFXCAT.h | 4 ---- include/configs/km_kirkwood.h | 7 ------- 8 files changed, 15 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-kirkwood/Kconfig b/arch/arm/mach-kirkwood/Kconfig index ca2da003b65b..98bb10c2dee3 100644 --- a/arch/arm/mach-kirkwood/Kconfig +++ b/arch/arm/mach-kirkwood/Kconfig @@ -121,6 +121,18 @@ endchoice config SYS_SOC default "kirkwood"
+config KIRKWOOD_RGMII_PAD_1V8 + bool "Configures the I/O voltage of the pads connected gigabit interface to 1.8V" + default y + +config KIRKWOOD_EGIGA_INIT + bool "Enable GbePort0/1 for kernel" + default y + +config KIRKWOOD_PCIE_INIT + bool "Enable PCIe Port0 for kernel" + default y + source "board/Marvell/openrd/Kconfig" source "board/Marvell/dreamplug/Kconfig" source "board/Synology/ds109/Kconfig" diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index ca341570544b..90e86ab99b41 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -23,9 +23,6 @@ #endif /* CONFIG_KW88F6281 */
#include <asm/arch/soc.h> -#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ -#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ -#define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 for kernel */
#define CONFIG_I2C_MVTWSI_BASE0 KW_TWSI_BASE #define MV_UART_CONSOLE_BASE KW_UART0_BASE diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 1d8ae5876b90..655759b09ce7 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_128M16_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_TARGET_KM_KIRKWOOD=y +# CONFIG_KIRKWOOD_PCIE_INIT is not set CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index d2f2ff4e23e7..65378d3cec16 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_TARGET_KM_KIRKWOOD=y +# CONFIG_KIRKWOOD_PCIE_INIT is not set CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 9654b8d8060c..8b54f9c7c842 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_KWD_CONFIG="board/keymile/km_arm/kwbimage_256M8_1.cfg" CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_TARGET_KM_KIRKWOOD=y +# CONFIG_KIRKWOOD_PCIE_INIT is not set CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xC0000 CONFIG_ENV_SECT_SIZE=0x10000 diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index 8114373655f3..e42e6d56532f 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -9,10 +9,6 @@ /* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000
-#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ -#define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ -#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ - /* * NS16550 Configuration */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index b70829c09d58..8926c26b0bdf 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -9,10 +9,6 @@ /* additions for new ARM relocation support */ #define CONFIG_SYS_SDRAM_BASE 0x00000000
-#define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ -#define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 */ -#define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ - /* * NS16550 Configuration */ diff --git a/include/configs/km_kirkwood.h b/include/configs/km_kirkwood.h index e58a69501b33..01482d531996 100644 --- a/include/configs/km_kirkwood.h +++ b/include/configs/km_kirkwood.h @@ -23,7 +23,6 @@ /* KM_KIRKWOOD */ #if defined(CONFIG_KM_KIRKWOOD) #define CONFIG_HOSTNAME "km_kirkwood" -#define CONFIG_KM_DISABLE_PCIE
/* KM_KIRKWOOD_PCI */ #elif defined(CONFIG_KM_KIRKWOOD_PCI) @@ -34,7 +33,6 @@ /* KM_KIRKWOOD_128M16 */ #elif defined(CONFIG_KM_KIRKWOOD_128M16) #define CONFIG_HOSTNAME "km_kirkwood_128m16" -#define CONFIG_KM_DISABLE_PCIE
/* KM_NUSA */ #elif defined(CONFIG_KM_NUSA) @@ -44,7 +42,6 @@ /* KMCOGE5UN */ #elif defined(CONFIG_KM_COGE5UN) #define CONFIG_HOSTNAME "kmcoge5un" -#define CONFIG_KM_DISABLE_PCIE
/* KM_SUSE2 */ #elif defined(CONFIG_KM_SUSE2) @@ -118,8 +115,4 @@ MVGBE_SET_MII_SPEED_TO_100) #endif
-#ifdef CONFIG_KM_DISABLE_PCIE -#undef CONFIG_KIRKWOOD_PCIE_INIT -#endif - #endif /* _CONFIG_KM_KIRKWOOD */
On Mon, Jun 20, 2022 at 08:07:42AM -0400, Tom Rini wrote:
This converts the following to Kconfig: CONFIG_FSL_FIXED_MMC_LOCATION CONFIG_ESDHC_HC_BLK_ADDR
For the series, applied to u-boot/next, thanks!
arch/powerpc/include/asm/config_mpc85xx.h | 3 --- boot/Kconfig | 13 +++++++++++++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + include/configs/P1010RDB.h | 4 +--- include/configs/P2041RDB.h | 5 ----- include/configs/corenet_ds.h | 5 ----- include/configs/p1_p2_rdb_pc.h | 4 +--- 24 files changed, 33 insertions(+), 19 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index e82adc6b4545..ce3a776c7e88 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_USB1_PHY_ENABLE -#define CONFIG_ESDHC_HC_BLK_ADDR
/* P1011 is single core version of P1020 */ #elif defined(CONFIG_ARCH_P1011) @@ -148,7 +147,6 @@ #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 -#define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_ARCH_BSC9132) #define CONFIG_FSL_SDHC_V2_3 @@ -160,7 +158,6 @@ #define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_FSL_ESDHC_P1010_BROKEN_SDCLK #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" -#define CONFIG_ESDHC_HC_BLK_ADDR
#elif defined(CONFIG_ARCH_T4240) #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ diff --git a/boot/Kconfig b/boot/Kconfig index 63dacc0d14f4..ee0dc90e93cc 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -575,6 +575,19 @@ config SPIFLASH
endchoice
+config FSL_FIXED_MMC_LOCATION
bool "PBL MMC is at a fixed location"
depends on SDCARD && !RAMBOOT_PBL
+config ESDHC_HC_BLK_ADDR
def_bool y
depends on FSL_FIXED_MMC_LOCATION && (ARCH_BSC9131 || ARCH_BSC9132 || ARCH_P1010)
help
In High Capacity SD Cards (> 2 GBytes), the 32-bit source address and
code length of these soc specify the memory address in block address
format. Block length is fixed to 512 bytes as per the SD High
Capacity specification.
config SYS_FSL_PBL_PBI string "PBI(pre-boot instructions) commands for the PBL image" depends on RAMBOOT_PBL diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 81bfd7ae518c..481c69d2d33b 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 1ebfdec719e8..92bb8cdedf66 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 9240c38c164a..9c93d653748b 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index c0fa3b5e4eb3..736e52efdd9c 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -21,6 +21,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 0a3ba0573e01..eace5d0d2c29 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 3e5d313c405f..435c83c5f9b7 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -22,6 +22,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index af65061a0c3e..abb98580532a 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -15,6 +15,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 36892c9fc2e4..1b114b8c9791 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -21,6 +21,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs ramdisk_size=$ramdisk_size;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr" diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 6c4575367be2..555f52f21a0c 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 0130ce6cb661..32c537a30c7a 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 6b6b12eae624..065845908aa3 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 643cee0b24ca..c5b5573c6025 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index c488aae69d5d..4547bdde55d7 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 40b6afa6cc0f..71a32289de0a 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 48f787ec91bf..7612b05fbae2 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 9b376595e7b8..996675f243d4 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -18,6 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index cd91e8903a67..fabca9b2a5c6 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SPL_SYS_MONITOR_BASE=0xF8F81000 +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 228f36af9a95..06c6f28b5961 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_FSL_FIXED_MMC_LOCATION=y CONFIG_BOOTDELAY=10 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="setenv bootargs root=/dev/$bdev rw rootdelay=30 console=$consoledev,$baudrate $othbootargs;usb start;ext2load usb 0:1 $loadaddr /boot/$bootfile;ext2load usb 0:1 $fdtaddr /boot/$fdtfile;bootm $loadaddr - $fdtaddr" diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 19aebb810c7b..813516892c61 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -465,9 +465,7 @@ extern unsigned long get_sdram_size(void); /*
- Environment
*/ -#if defined(CONFIG_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#elif defined(CONFIG_MTD_RAW_NAND) +#if defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD #define SPL_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) #endif diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 4e96d2a06b79..4a1fccff598c 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -43,11 +43,6 @@ #define CONFIG_SRIO_PCIE_BOOT_MASTER #define CONFIG_SYS_DPAA_RMAN /* RMan */
-#if defined(CONFIG_SPIFLASH) -#elif defined(CONFIG_SDCARD)
-#endif
#ifndef __ASSEMBLY__ #include <linux/stringify.h> #endif diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 6a4fd90ded9a..c0952e092858 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -39,11 +39,6 @@ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */
-#if defined(CONFIG_SPIFLASH) -#elif defined(CONFIG_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#endif
- These can be toggled for performance analysis, otherwise use default.
*/ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 39552be32b3c..b719c7e923cf 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -424,9 +424,7 @@ /*
- Environment
#endif
2.25.1
Tom,
I'm not sure this patch had the intended results. I just noticed that default bootcmd was changed due to this for the the imx8m*venice boards I maintain.
How did you go about generating this? In my case CONFIG_USE_BOOTCOMMAND is not set and prior to this patch was getting defaulted in include/config_distro_bootcmd.h but now that is removed and its getting set in tools/env/fw_env_private.h to something different.
To fix this, I'll have to submit a patch that does the following for configs/imx8m*_venice_defconfig +CONFIG_USE_BOOTCOMMAND=y +CONFIG_BOOTCOMMAND="run distro_bootcmd"
I figured it was worth mentioning and asking for others that run into this.
Best Regards,
Tim
[snip]
Tom,
It's this commit, specifically? Looking at u-boot-initial-env (and disabling LTO for the moment), I don't see bootcmd set before nor after. I could see this being a merge related problem or similar from 970bf8603b877e2b66170290f751f9c23c120838 where I finished moving everyone that was in-tree at the time that should have been setting CONFIG_USE_BOOTCOMMAND and then CONFIG_BOOTCOMMAND (if not using the default) leading to this kind of problem.
[snip]
Tom,
Tom,
I apologize... not sure how I ended up replying to the wrong patch.
Indeed it is commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig") that I was referring to.
It looks like any board that specifically did not define CONFIG_USE_BOOTCOMMAND was likely affected and if I simply remove '# CONFIG_USE_BOOTCOMMAND is not set' from my defconfigs it fixes it.
This is what I was going to submit but if the above assumption is correct there would be a lot of other boards affected.
imx8m*_venice_defconfig: fix default bootcmd
commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig") had an unintended side effect of resulting in a bootcmd env var change for boards like venice that did not have CONFIG_USE_BOOTCOMMAND defined and relied on it being defaulted in include/config_distro_bootcmd.h. Following that patch it instead got defaulted in tools/env/fw_env_private.h
Fix this by enabling CONFIG_USE_BOOTCOMMAND for venice.
Fixes: commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig ") Signed-off-by: Tim Harvey tharvey@gateworks.com
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 0165a4e5df08..c0fff026fbbc 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -27,7 +27,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index 63a654973710..4bbf9ded74ad 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 6758cd251e60..398875ae323a 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -28,7 +28,6 @@ CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="gsc wd-disable" CONFIG_BOARD_LATE_INIT=y
Best Regards,
Tim
[snip]
Tom,
Tom,
imx8m*_venice_defconfig: fix default bootcmd commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig") had an unintended side effect of resulting in a bootcmd env var change for boards like venice that did not have CONFIG_USE_BOOTCOMMAND defined and relied on it being defaulted in include/config_distro_bootcmd.h. Following that patch it instead got defaulted in tools/env/fw_env_private.h Fix this by enabling CONFIG_USE_BOOTCOMMAND for venice. Fixes: commit 970bf8603b87 ("Convert CONFIG_USE_BOOTCOMMAND et al to Kconfig
OK, yeah, makes more sense. I'm not quite sure how I missed this platform in the migration but apparently I did. A patch to fix up other platforms you can see were also broken would be appreciated, thanks!
Tim Harvey
