[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
The following changes since commit 5cf618ee60a752d058a767372ca1ecb8d9c09b16:
Merge git://git.denx.de/u-boot-arc (2017-03-24 08:19:30 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to db40c1aa1c100d8a9e33206575efd8b3678f31db:
drivers/net/phy: add fixed-phy / fixed-link support (2017-03-26 09:58:26 -0500)
---------------------------------------------------------------- Alexandre Messier (1): net: link_local: Fix netmask endianness bug
Hannes Schmelzer (1): drivers/net/phy: add fixed-phy / fixed-link support
Suji Velupillai (1): net: fix cache misaligned issue in Broadcom SF2 driver
Tuomas Tynkkynen (1): fdt_support: Fixup 'ethernet' aliases not ending in digits
Yung-Ching LIN (2): board: ge: bx50v3: fix AR8033 reset timing issue board: ge: bx50v3: apply the proper register setting to fix the voltage peak issue
oliver@schinagl.nl (2): net: sunxi-emac: Write HW address via function net: sunxi: Enable eeprom on OLinuXino Lime boards
board/ge/bx50v3/bx50v3.c | 6 +- common/fdt_support.c | 10 ++- configs/A10-OLinuXino-Lime_defconfig | 4 + configs/A20-OLinuXino-Lime2_defconfig | 4 + configs/A20-OLinuXino-Lime_defconfig | 4 + configs/A20-OLinuXino_MICRO_defconfig | 4 + doc/device-tree-bindings/net/fixed-link.txt | 30 ++++++++ drivers/net/bcm-sf2-eth-gmac.c | 113 +++++++++++++++------------- drivers/net/bcm-sf2-eth.h | 4 +- drivers/net/phy/Kconfig | 10 +++ drivers/net/phy/Makefile | 1 + drivers/net/phy/fixed.c | 82 ++++++++++++++++++++ drivers/net/phy/phy.c | 23 +++++- drivers/net/sunxi_emac.c | 19 ++++- include/phy.h | 3 + net/link_local.c | 2 +- 16 files changed, 249 insertions(+), 70 deletions(-) create mode 100644 doc/device-tree-bindings/net/fixed-link.txt create mode 100644 drivers/net/phy/fixed.c
Thanks! -Joe
On Mon, Mar 27, 2017 at 11:50:12AM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
