[U-Boot] [PATCH] common/cli_hush.c: remove unnecessary double braces
Clang interpretes an if condition like "if ((a = b) == NULL) as it tries to assign a value in a statement. Hence if you do "if ((something)) it warns you that you might be confused. Hence drop the double braces for plane if statements.
Simon Glass sjg@chromium.org Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- common/cli_hush.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cli_hush.c b/common/cli_hush.c index e0c436f..38da5a0 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -1840,7 +1840,7 @@ static int run_list_real(struct pipe *pi) if (rmode == RES_DO) { if (!flag_rep) continue; } - if ((rmode == RES_DONE)) { + if (rmode == RES_DONE) { if (flag_rep) { flag_restore = 1; } else { @@ -3569,7 +3569,7 @@ static char **make_list_in(char **inp, char *name) p3 = insert_var_value(inp[i]); p1 = p3; while (*p1) { - if ((*p1 == ' ')) { + if (*p1 == ' ') { p1++; continue; }
Jeroen Hofstee
