[U-Boot] [PATCH 1/2] microblaze: bootm: Fix coding style issues
Prepare place for new patch.
Signed-off-by: Michal Simek michal.simek@xilinx.com --- arch/microblaze/lib/bootm.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index 66d21f4..b992a4d 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -32,11 +32,12 @@
DECLARE_GLOBAL_DATA_PTR;
-int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *images) +int do_bootm_linux(int flag, int argc, char * const argv[], + bootm_headers_t *images) { /* First parameter is mapped to $r5 for kernel boot args */ - void (*theKernel) (char *, ulong, ulong); - char *commandline = getenv ("bootargs"); + void (*thekernel) (char *, ulong, ulong); + char *commandline = getenv("bootargs"); ulong rd_data_start, rd_data_end;
if ((flag != 0) && (flag != BOOTM_STATE_OS_GO)) @@ -51,10 +52,10 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima of_flat_tree = images->ft_addr; #endif
- theKernel = (void (*)(char *, ulong, ulong))images->ep; + thekernel = (void (*)(char *, ulong, ulong))images->ep;
/* find ramdisk */ - ret = boot_get_ramdisk (argc, argv, images, IH_ARCH_MICROBLAZE, + ret = boot_get_ramdisk(argc, argv, images, IH_ARCH_MICROBLAZE, &rd_data_start, &rd_data_end); if (ret) return 1; @@ -64,9 +65,10 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima if (!of_flat_tree && argc > 3) of_flat_tree = (char *)simple_strtoul(argv[3], NULL, 16); #ifdef DEBUG - printf ("## Transferring control to Linux (at address 0x%08lx) " \ - "ramdisk 0x%08lx, FDT 0x%08lx...\n", - (ulong) theKernel, rd_data_start, (ulong) of_flat_tree); + printf("## Transferring control to Linux (at address 0x%08lx) ", + (ulong)thekernel); + printf("ramdisk 0x%08lx, FDT 0x%08lx...\n", + rd_data_start, (ulong) of_flat_tree); #endif
#ifdef XILINX_USE_DCACHE @@ -78,7 +80,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima * r6: pointer to ramdisk * r7: pointer to the fdt, followed by the board info data */ - theKernel (commandline, rd_data_start, (ulong) of_flat_tree); + thekernel(commandline, rd_data_start, (ulong)of_flat_tree); /* does not return */
return 1; -- 1.8.2.1
fdt_initrd add additional information to DTB about initrd addresses which are later used by kernel.
Signed-off-by: Michal Simek michal.simek@xilinx.com --- arch/microblaze/lib/bootm.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index b992a4d..bb01a71 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -64,6 +64,11 @@ int do_bootm_linux(int flag, int argc, char * const argv[],
if (!of_flat_tree && argc > 3) of_flat_tree = (char *)simple_strtoul(argv[3], NULL, 16); + + /* fixup the initrd now that we know where it should be */ + if (images->rd_start && images->rd_end && of_flat_tree) + fdt_initrd(of_flat_tree, images->rd_start, images->rd_end, 1); + #ifdef DEBUG printf("## Transferring control to Linux (at address 0x%08lx) ", (ulong)thekernel); -- 1.8.2.1
- /* fixup the initrd now that we know where it should be */
- if (images->rd_start && images->rd_end && of_flat_tree)
Michal: You should also check return value.
BTW: it should be also checked for arm and ppc.
will send v2.
Thanks, Michal
Michal Simek
Michal Simek
