[PATCH] pinctrl: renesas: Convert to IS_ENABLED() macro
Use the IS_ENABLED() macro to reduce amount of #ifdef use in the driver and improve code coverage. With IS_ENABLED() macro, the code is compiled and then optimized out, which prevents bitrot.
In case no PFC table matches the SoC in use, do not probe the driver and instead exit with -ENODEV. This should never happen under normal conditions, because this would mean the driver DT compatible string match happened, but the list in probe() cannot match the model listed in match data associated with the compatible string on which the match did happen.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Hai Pham hai.pham.ud@renesas.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Tom Rini trini@konsulko.com Cc: u-boot@lists.denx.de --- drivers/pinctrl/renesas/pfc.c | 128 ++++++++++++---------------------- 1 file changed, 44 insertions(+), 84 deletions(-)
diff --git a/drivers/pinctrl/renesas/pfc.c b/drivers/pinctrl/renesas/pfc.c index 2f6c3b3d1c7..db6be39a528 100644 --- a/drivers/pinctrl/renesas/pfc.c +++ b/drivers/pinctrl/renesas/pfc.c @@ -961,90 +961,50 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) if (!priv->pfc.regs) return -ENOMEM;
-#ifdef CONFIG_PINCTRL_PFC_R8A7790 - if (model == SH_PFC_R8A7790) + if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7790) && model == SH_PFC_R8A7790) priv->pfc.info = &r8a7790_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A7791 - if (model == SH_PFC_R8A7791) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7791) && model == SH_PFC_R8A7791) priv->pfc.info = &r8a7791_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A7792 - if (model == SH_PFC_R8A7792) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7792) && model == SH_PFC_R8A7792) priv->pfc.info = &r8a7792_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A7793 - if (model == SH_PFC_R8A7793) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7793) && model == SH_PFC_R8A7793) priv->pfc.info = &r8a7793_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A7794 - if (model == SH_PFC_R8A7794) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7794) && model == SH_PFC_R8A7794) priv->pfc.info = &r8a7794_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77951 - if (model == SH_PFC_R8A7795) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77951) && model == SH_PFC_R8A7795) priv->pfc.info = &r8a77951_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77960 - if (model == SH_PFC_R8A77960) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77960) && model == SH_PFC_R8A77960) priv->pfc.info = &r8a77960_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77961 - if (model == SH_PFC_R8A77961) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77961) && model == SH_PFC_R8A77961) priv->pfc.info = &r8a77961_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A774A1 - if (model == SH_PFC_R8A774A1) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774A1) && model == SH_PFC_R8A774A1) priv->pfc.info = &r8a774a1_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A774B1 - if (model == SH_PFC_R8A774B1) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774B1) && model == SH_PFC_R8A774B1) priv->pfc.info = &r8a774b1_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A774C0 - if (model == SH_PFC_R8A774C0) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774C0) && model == SH_PFC_R8A774C0) priv->pfc.info = &r8a774c0_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A774E1 - if (model == SH_PFC_R8A774E1) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774E1) && model == SH_PFC_R8A774E1) priv->pfc.info = &r8a774e1_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77965 - if (model == SH_PFC_R8A77965) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77965) && model == SH_PFC_R8A77965) priv->pfc.info = &r8a77965_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77970 - if (model == SH_PFC_R8A77970) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77970) && model == SH_PFC_R8A77970) priv->pfc.info = &r8a77970_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77980 - if (model == SH_PFC_R8A77980) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77980) && model == SH_PFC_R8A77980) priv->pfc.info = &r8a77980_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77990 - if (model == SH_PFC_R8A77990) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77990) && model == SH_PFC_R8A77990) priv->pfc.info = &r8a77990_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A77995 - if (model == SH_PFC_R8A77995) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77995) && model == SH_PFC_R8A77995) priv->pfc.info = &r8a77995_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A779A0 - if (model == SH_PFC_R8A779A0) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779A0) && model == SH_PFC_R8A779A0) priv->pfc.info = &r8a779a0_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A779F0 - if (model == SH_PFC_R8A779F0) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779F0) && model == SH_PFC_R8A779F0) priv->pfc.info = &r8a779f0_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A779G0 - if (model == SH_PFC_R8A779G0) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779G0) && model == SH_PFC_R8A779G0) priv->pfc.info = &r8a779g0_pinmux_info; -#endif -#ifdef CONFIG_PINCTRL_PFC_R8A779H0 - if (model == SH_PFC_R8A779H0) + else if (IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779H0) && model == SH_PFC_R8A779H0) priv->pfc.info = &r8a779h0_pinmux_info; -#endif + else + return -ENODEV;
priv->pmx.pfc = &priv->pfc; sh_pfc_init_ranges(&priv->pfc); @@ -1054,127 +1014,127 @@ static int sh_pfc_pinctrl_probe(struct udevice *dev) }
static const struct udevice_id sh_pfc_pinctrl_ids[] = { -#ifdef CONFIG_PINCTRL_PFC_R8A7790 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7790) { .compatible = "renesas,pfc-r8a7790", .data = SH_PFC_R8A7790, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A7791 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7791) { .compatible = "renesas,pfc-r8a7791", .data = SH_PFC_R8A7791, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A7792 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7792) { .compatible = "renesas,pfc-r8a7792", .data = SH_PFC_R8A7792, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A7793 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7793) { .compatible = "renesas,pfc-r8a7793", .data = SH_PFC_R8A7793, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A7794 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A7794) { .compatible = "renesas,pfc-r8a7794", .data = SH_PFC_R8A7794, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77951 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77951) { .compatible = "renesas,pfc-r8a7795", .data = SH_PFC_R8A7795, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77960 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77960) { .compatible = "renesas,pfc-r8a7796", .data = SH_PFC_R8A77960, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77961 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77961) { .compatible = "renesas,pfc-r8a77961", .data = SH_PFC_R8A77961, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A774A1 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774A1) { .compatible = "renesas,pfc-r8a774a1", .data = SH_PFC_R8A774A1, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A774B1 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774B1) { .compatible = "renesas,pfc-r8a774b1", .data = SH_PFC_R8A774B1, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A774C0 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774C0) { .compatible = "renesas,pfc-r8a774c0", .data = SH_PFC_R8A774C0, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A774E1 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A774E1) { .compatible = "renesas,pfc-r8a774e1", .data = SH_PFC_R8A774E1, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77965 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77965) { .compatible = "renesas,pfc-r8a77965", .data = SH_PFC_R8A77965, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77970 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77970) { .compatible = "renesas,pfc-r8a77970", .data = SH_PFC_R8A77970, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77980 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77980) { .compatible = "renesas,pfc-r8a77980", .data = SH_PFC_R8A77980, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77990 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77990) { .compatible = "renesas,pfc-r8a77990", .data = SH_PFC_R8A77990, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A77995 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A77995) { .compatible = "renesas,pfc-r8a77995", .data = SH_PFC_R8A77995, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A779A0 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779A0) { .compatible = "renesas,pfc-r8a779a0", .data = SH_PFC_R8A779A0, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A779F0 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779F0) { .compatible = "renesas,pfc-r8a779f0", .data = SH_PFC_R8A779F0, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A779G0 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779G0) { .compatible = "renesas,pfc-r8a779g0", .data = SH_PFC_R8A779G0, }, #endif -#ifdef CONFIG_PINCTRL_PFC_R8A779H0 +#if IS_ENABLED(CONFIG_PINCTRL_PFC_R8A779H0) { .compatible = "renesas,pfc-r8a779h0", .data = SH_PFC_R8A779H0,
