[U-Boot] [PATCH] powerpc/mpc8xxx: Remove P1015 and P1016 from CPU list
P1015 is the same as P1011 and P1016 is the same as P1012 from software point of view. They have different packages but share SVRs.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/Makefile | 4 ---- arch/powerpc/cpu/mpc85xx/speed.c | 3 +-- arch/powerpc/cpu/mpc8xxx/cpu.c | 2 -- arch/powerpc/include/asm/config_mpc85xx.h | 27 --------------------------- arch/powerpc/include/asm/immap_85xx.h | 3 +-- arch/powerpc/include/asm/processor.h | 2 -- drivers/qe/uec.c | 15 +++++---------- 7 files changed, 7 insertions(+), 49 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 34f6c54..2f79a03 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -55,8 +55,6 @@ COBJS-$(CONFIG_P1011) += ddr-gen3.o COBJS-$(CONFIG_P1012) += ddr-gen3.o COBJS-$(CONFIG_P1013) += ddr-gen3.o COBJS-$(CONFIG_P1014) += ddr-gen3.o -COBJS-$(CONFIG_P1015) += ddr-gen3.o -COBJS-$(CONFIG_P1016) += ddr-gen3.o COBJS-$(CONFIG_P1020) += ddr-gen3.o COBJS-$(CONFIG_P1021) += ddr-gen3.o COBJS-$(CONFIG_P1022) += ddr-gen3.o @@ -103,8 +101,6 @@ COBJS-$(CONFIG_P1011) += p1021_serdes.o COBJS-$(CONFIG_P1012) += p1021_serdes.o COBJS-$(CONFIG_P1013) += p1022_serdes.o COBJS-$(CONFIG_P1014) += p1010_serdes.o -COBJS-$(CONFIG_P1015) += p1021_serdes.o -COBJS-$(CONFIG_P1016) += p1021_serdes.o COBJS-$(CONFIG_P1017) += p1023_serdes.o COBJS-$(CONFIG_P1020) += p1021_serdes.o COBJS-$(CONFIG_P1021) += p1021_serdes.o diff --git a/arch/powerpc/cpu/mpc85xx/speed.c b/arch/powerpc/cpu/mpc85xx/speed.c index ce47532..abfeb26 100644 --- a/arch/powerpc/cpu/mpc85xx/speed.c +++ b/arch/powerpc/cpu/mpc85xx/speed.c @@ -186,8 +186,7 @@ void get_sys_info (sys_info_t * sysInfo) #endif
#ifdef CONFIG_QE -#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) sysInfo->freqQE = sysInfo->freqSystemBus; #else qe_ratio = ((gur->porpllsr) & MPC85xx_PORPLLSR_QE_RATIO) diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index cbc6742..1c615d0 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -57,8 +57,6 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P1012, P1012, 1), CPU_TYPE_ENTRY(P1013, P1013, 1), CPU_TYPE_ENTRY(P1014, P1014, 1), - CPU_TYPE_ENTRY(P1015, P1015, 1), - CPU_TYPE_ENTRY(P1016, P1016, 1), CPU_TYPE_ENTRY(P1017, P1017, 1), CPU_TYPE_ENTRY(P1020, P1020, 2), CPU_TYPE_ENTRY(P1021, P1021, 2), diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 7e61f71..0a780d7 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -191,33 +191,6 @@ #define CONFIG_SYS_FSL_ERRATUM_P1010_A003549 #define CONFIG_SYS_FSL_ERRATUM_IFC_A003399
-/* P1015 is single core version of P1024 */ -#elif defined(CONFIG_P1015) -#define CONFIG_MAX_CPUS 1 -#define CONFIG_SYS_FSL_NUM_LAWS 12 -#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 -#define CONFIG_TSECV2 -#define CONFIG_FSL_PCIE_DISABLE_ASPM -#define CONFIG_SYS_FSL_SEC_COMPAT 2 -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 -#define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 -#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 - -/* P1016 is single core version of P1025 */ -#elif defined(CONFIG_P1016) -#define CONFIG_MAX_CPUS 1 -#define CONFIG_SYS_FSL_NUM_LAWS 12 -#define CONFIG_SYS_PPC_E500_DEBUG_TLB 2 -#define CONFIG_TSECV2 -#define CONFIG_FSL_PCIE_DISABLE_ASPM -#define CONFIG_SYS_FSL_SEC_COMPAT 2 -#define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 -#define CONFIG_SYS_FSL_ERRATUM_ESDHC111 -#define QE_MURAM_SIZE 0x6000UL -#define MAX_QE_RISC 1 -#define QE_NUM_OF_SNUM 28 -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 - /* P1017 is single core version of P1023 */ #elif defined(CONFIG_P1017) #define CONFIG_MAX_CPUS 1 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 53d563e..1050d61 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2259,8 +2259,7 @@ typedef struct ccsr_gur { u8 res11a[76]; par_io_t qe_par_io[7]; u8 res11b[1600]; -#elif defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#elif defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) u8 res11a[12]; u32 iovselsr; u8 res11b[60]; diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 4eb88e9..ee57af1 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1075,8 +1075,6 @@ #define SVR_P1012 0x80E501 #define SVR_P1013 0x80E700 #define SVR_P1014 0x80F101 -#define SVR_P1015 0x80E502 -#define SVR_P1016 0x80E503 #define SVR_P1017 0x80F700 #define SVR_P1020 0x80E400 #define SVR_P1021 0x80E401 diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 216c898..e6ae709 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -580,8 +580,7 @@ static void phy_change(struct eth_device *dev) { uec_private_t *uec = (uec_private_t *)dev->priv;
-#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
/* QE9 and QE12 need to be set for enabling QE MII managment signals */ @@ -592,8 +591,7 @@ static void phy_change(struct eth_device *dev) /* Update the link, speed, duplex */ uec->mii_info->phyinfo->read_status(uec->mii_info);
-#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) /* * QE12 is muxed with LBCTL, it needs to be released for enabling * LBCTL signal for LBC usage. @@ -1208,16 +1206,14 @@ static int uec_init(struct eth_device* dev, bd_t *bd) uec_private_t *uec; int err, i; struct phy_info *curphy; -#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif
if (uec->the_first_run == 0) { -#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) /* QE9 and QE12 need to be set for enabling QE MII managment signals */ setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE9); setbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE12); @@ -1249,8 +1245,7 @@ static int uec_init(struct eth_device* dev, bd_t *bd) udelay(100000); } while (1);
-#if defined(CONFIG_P1012) || defined(CONFIG_P1016) || \ - defined(CONFIG_P1021) || defined(CONFIG_P1025) +#if defined(CONFIG_P1012) || defined(CONFIG_P1021) || defined(CONFIG_P1025) /* QE12 needs to be released for enabling LBCTL signal*/ clrbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_QE12); #endif
York Sun
