[U-Boot] Altering cpu/mpc85xx/start.S to set GPIO
I am testing on an e500 core P2020 QorIQ (mpc85xx). As part of this testing, I would like to set a GPIO pin high (aka "turn on an led") during extremely early U-boot code.
I have modified cpu/mpc85xx/start.S to (1) set GPIMR for one gpio pin, (2) set GPDIR for the same gpio pin, and (3) set GPDAT for the same gpio pin. The writes I have introduced(to GPDAT etc) occur directly after the PPC exception vectors are set. The relevant portion of my modified start.S is attached below.
The problem I'm having is that the first "stw" instruction (specifically, "stw 1,0(9)") sends the core into the e00 exception vector. This exception is set in start.S as STD_EXCEPTION(0x0e00, InstructionTLBError, UnknownException). After the exception occurs, the processor halts at 0xfff80e00.
As per the P2020 QoriQ manual's section 4.5.3 (p. 4-48, "QorIQ P2020 Integrated Processor Reference Manual"), I ought to be able to access CCSRBAR without mapping it through a TLB; the board in question is configured to boot from eSPI. As the memory mapped gpio pins are in ccsr space, I am left quite confused as to why such accesses are causing a TLB exception.
Can anyone offer any pointers on what I'm doing wrong?
Thank you, -Rick
Modified start.s follows: -------------------------------------------------------
start_e500: /* L1 */ li r0,2 mtspr L1CSR0,r0 /* invalidate d-cache */ mtspr L1CSR1,r0 /* invalidate i-cache */ mfspr r1,DBSR mtspr DBSR,r1 /* Clear all valid bits */
/* Enable L1 Caches early */ lis r2,L1CSR0_CPE@H /* enable parity */ ori r2,r2,L1CSR0_DCE mtspr L1CSR0,r2 /* enable L1 Dcache */ isync mtspr L1CSR1,r2 /* enable L1 Icache */ isync msync /* Setup interrupt vectors */ lis r1,TEXT_BASE@h mtspr IVPR,r1
li r1,0x0100 mtspr IVOR0,r1 /* 0: Critical input */ li r1,0x0200 mtspr IVOR1,r1 /* 1: Machine check */ li r1,0x0300 mtspr IVOR2,r1 /* 2: Data storage */ li r1,0x0400 mtspr IVOR3,r1 /* 3: Instruction storage */ li r1,0x0500 mtspr IVOR4,r1 /* 4: External interrupt */ li r1,0x0600 mtspr IVOR5,r1 /* 5: Alignment */ li r1,0x0700 mtspr IVOR6,r1 /* 6: Program check */ li r1,0x0800 mtspr IVOR7,r1 /* 7: floating point unavailable */ li r1,0x0900 mtspr IVOR8,r1 /* 8: System call */ /* 9: Auxiliary processor unavailable(unsupported) */ li r1,0x0a00 mtspr IVOR10,r1 /* 10: Decrementer */ li r1,0x0b00 mtspr IVOR11,r1 /* 11: Interval timer */ li r1,0x0c00 mtspr IVOR12,r1 /* 12: Watchdog timer */ li r1,0x0d00 mtspr IVOR13,r1 /* 13: Data TLB error */ li r1,0x0e00 mtspr IVOR14,r1 /* 14: Instruction TLB error */ li r1,0x0f00 mtspr IVOR15,r1 /* 15: Debug */
/* Clear and set up some registers. */ li r0,0x0000 lis r1,0xffff mtspr DEC,r0 /* prevent dec exceptions */ mttbl r0 /* prevent fit & wdt exceptions */ mttbu r0 mtspr TSR,r1 /* clear all timer exception status */ mtspr TCR,r0 /* disable all */ mtspr ESR,r0 /* clear exception syndrome register */ mtspr MCSR,r0 /* machine check syndrome register */ mtxer r0 /* clear integer exception register */
/* BEGIN MODIFICATIONS */ /* TURN ON THE LED */ s 9,0xff70 lis 11,0xff70 lis 10,0xff70 lis 1,0x1
/* set low 16 bits of r9,r10,r11 */ ori 9,9,64512 /* 0xfc00 */ ori 10,10,64520 /* 0xfc08 */ ori 11,11,64528 /* 0xfc10 */
/* push contents of r1 to r9,r10,r11 */ stw 1,0(9) stw 1,0(11) stw 1,0(10)
/* for purposes of this message, you can assume the following loop exists (or not) */ b .
Thank you, -Rick
is this a typo?
lis 11,0xff70 lis 10,0xff70 lis 1,0x1 /* set low 16 bits of r9,r10,r11 */ ori 9,9,64512 /* 0xfc00 */ ori 10,10,64520 /* 0xfc08 */ ori 11,11,64528 /* 0xfc10 */ /* push contents of r1 to r9,r10,r11 */ stw 1,0(9) stw 1,0(11) stw 1,0(10)
/* for purposes of this message, you can assume the following loop exists (or not) */ b . _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Thu, Feb 10, 2011 at 12:24 AM, Kumar Gala galak@kernel.crashing.org wrote:
is this a typo?
Yes. "s" --> "lis" -Rick
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Kumar Gala Sent: Thursday, February 10, 2011 1:54 PM To: Rick Ramstetter Cc: u-boot@lists.denx.de; Thomas Taranowski Subject: Re: [U-Boot] Altering cpu/mpc85xx/start.S to set GPIO
gpio pin.
TLB is required to access CCSRBAR space.
Thank you, -Rick
is this a typo?
On Wed, 9 Feb 2011 23:20:03 -0800 Rick Ramstetter rick.ramstetter@gmail.com wrote:
4.5.3 says you don't need a LAW, it doesn't say anything about not needing a TLB entry.
-Scott
-Scott
In think in the boot from SPI case there is a 4G TLB that maps 1:1
- k
Aggrwal Poonam-B10812
Kumar Gala
Rick Ramstetter
Scott Wood
