[PATCH 0/3] RFC: add fdt_add_pubkey tool
In order to reduce the coupling between building the kernel and U-Boot, I'd like a tool that can add a public key to U-Boot's dtb without simultaneously signing a FIT image. That tool doesn't seem to exist, so I stole the necessary pieces from mkimage et al and put it in a single .c file.
I'm still working on the details of my proposed "require just k out these n required keys" and how it should be implemented, but it will probably involve teaching this tool a bunch of new options. These patches are not necessarily ready for inclusion (unless someone else finds fdt_add_pubkey useful as is), but I thought I might as well send it out for early comments.
Rasmus Villemoes (3): test_vboot.py: remove extraneous -k option to fit_check_sign tools: add fdt_add_pubkey test_vboot.py: include test of fdt_add_pubkey tool
test/py/tests/test_vboot.py | 11 ++++- tools/.gitignore | 1 + tools/Makefile | 3 ++ tools/fdt_add_pubkey.c | 96 +++++++++++++++++++++++++++++++++++++ 4 files changed, 109 insertions(+), 2 deletions(-) create mode 100644 tools/fdt_add_pubkey.c
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- test/py/tests/test_vboot.py | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/test/py/tests/test_vboot.py b/test/py/tests/test_vboot.py index 9c41ee56b1..3dd8e3cb66 100644 --- a/test/py/tests/test_vboot.py +++ b/test/py/tests/test_vboot.py @@ -180,8 +180,7 @@ def test_vboot(u_boot_console):
cons.log.action('%s: Check signed config on the host' % sha_algo)
- util.run_and_log(cons, [fit_check_sign, '-f', fit, '-k', tmpdir, - '-k', dtb]) + util.run_and_log(cons, [fit_check_sign, '-f', fit, '-k', dtb])
# Replace header bytes bcfg = u_boot_console.config.buildconfig
Hi Rasmus,
On Tue, 11 Feb 2020 at 02:49, Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Please add a commit message with motivation and effect.
Having to use the -K option to mkimage to populate U-Boot's .dtb with the public key while signing the kernel FIT image is often a little awkward. In particular, when using a meta-build system such as bitbake/Yocto, having the tasks of the kernel and U-Boot recipes intertwined, modifying deployed artifacts and rebuilding U-Boot with an updated .dtb is quite cumbersome. Also, in some scenarios one may wish to build U-Boot complete with the public key(s) embedded in the .dtb without the corresponding private keys being present on the same build host.
So this adds a simple tool that allows one to disentangle the kernel and U-Boot builds, by simply copy-pasting just enough of the mkimage code to allow one to add a public key to a .dtb. When using mkimage, some of the information is taken from the .its used to build the kernel (algorithm and key name), so that of course needs to be supplied on the command line.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- tools/.gitignore | 1 + tools/Makefile | 3 ++ tools/fdt_add_pubkey.c | 96 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 100 insertions(+) create mode 100644 tools/fdt_add_pubkey.c
diff --git a/tools/.gitignore b/tools/.gitignore index 82bdce2782..a9894db853 100644 --- a/tools/.gitignore +++ b/tools/.gitignore @@ -6,6 +6,7 @@ /dumpimage /easylogo/easylogo /envcrc +/fdt_add_pubkey /fdtgrep /file2include /fit_check_sign diff --git a/tools/Makefile b/tools/Makefile index 345bc84e48..d91edeaddc 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -54,6 +54,7 @@ mkenvimage-objs := mkenvimage.o os_support.o lib/crc32.o
hostprogs-y += dumpimage mkimage hostprogs-$(CONFIG_FIT_SIGNATURE) += fit_info fit_check_sign +hostprogs-$(CONFIG_FIT_SIGNATURE) += fdt_add_pubkey
hostprogs-$(CONFIG_CMD_BOOTEFI_SELFTEST) += file2include
@@ -122,6 +123,7 @@ dumpimage-objs := $(dumpimage-mkimage-objs) dumpimage.o mkimage-objs := $(dumpimage-mkimage-objs) mkimage.o fit_info-objs := $(dumpimage-mkimage-objs) fit_info.o fit_check_sign-objs := $(dumpimage-mkimage-objs) fit_check_sign.o +fdt_add_pubkey-objs := $(dumpimage-mkimage-objs) fdt_add_pubkey.o file2include-objs := file2include.o
ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_FIT_SIGNATURE),) @@ -166,6 +168,7 @@ HOSTCFLAGS_fit_image.o += -DMKIMAGE_DTC="$(CONFIG_MKIMAGE_DTC_PATH)" HOSTLOADLIBES_dumpimage := $(HOSTLOADLIBES_mkimage) HOSTLOADLIBES_fit_info := $(HOSTLOADLIBES_mkimage) HOSTLOADLIBES_fit_check_sign := $(HOSTLOADLIBES_mkimage) +HOSTLOADLIBES_fdt_add_pubkey := $(HOSTLOADLIBES_mkimage)
hostprogs-$(CONFIG_EXYNOS5250) += mkexynosspl hostprogs-$(CONFIG_EXYNOS5420) += mkexynosspl diff --git a/tools/fdt_add_pubkey.c b/tools/fdt_add_pubkey.c new file mode 100644 index 0000000000..45a2ce9ad2 --- /dev/null +++ b/tools/fdt_add_pubkey.c @@ -0,0 +1,96 @@ +#include <image.h> +#include "fit_common.h" + +static const char *cmdname; + +static const char *algo_name = "sha1,rsa2048"; /* -a <algo> */ +static const char *keydir = "."; /* -k <keydir> */ +static const char *keyname = "key"; /* -n <keyname> */ +static const char *require_keys; /* -r <conf|image> */ +static const char *keydest; /* argv[n] */ + +static void usage(const char *msg) +{ + fprintf(stderr, "Error: %s\n", msg); + fprintf(stderr, "Usage: %s [-a <algo>] [-k <keydir>] [-n <keyname>] [-r <conf|image>] <fdt blob>\n", + cmdname); + exit(EXIT_FAILURE); +} + +static void process_args(int argc, char *argv[]) +{ + int opt; + + while((opt = getopt(argc, argv, "a:k:n:r:")) != -1) { + switch (opt) { + case 'k': + keydir = optarg; + break; + case 'a': + algo_name = optarg; + break; + case 'n': + keyname = optarg; + break; + case 'r': + require_keys = optarg; + break; + default: + usage("Invalid option"); + } + } + /* The last parameter is expected to be the .dtb to add the public key to */ + if (optind < argc) + keydest = argv[optind]; + + if (!keydest) + usage("Missing dtb file to update"); +} + +int main(int argc, char *argv[]) +{ + struct image_sign_info info; + int destfd, ret; + void *dest_blob = NULL; + struct stat dest_sbuf; + size_t size_inc = 0; + + cmdname = argv[0]; + + process_args(argc, argv); + + memset(&info, 0, sizeof(info)); + + info.keydir = keydir; + info.keyname = keyname; + info.name = algo_name; + info.require_keys = require_keys; + info.crypto = image_get_crypto_algo(algo_name); + if (!info.crypto) { + fprintf(stderr, "Unsupported signature algorithm '%s'\n", algo_name); + exit(EXIT_FAILURE); + } + + while (1) { + destfd = mmap_fdt(cmdname, keydest, size_inc, &dest_blob, &dest_sbuf, false, false); + if (destfd < 0) + exit(EXIT_FAILURE); + + ret = info.crypto->add_verify_data(&info, dest_blob); + + munmap(dest_blob, dest_sbuf.st_size); + close(destfd); + if (!ret || ret != -ENOSPC) + break; + fprintf(stderr, ".dtb too small, increasing size by 1024 bytes\n"); + size_inc = 1024; + } + + if (ret) { + fprintf(stderr, "%s: Cannot add public key to FIT blob: %s\n", + cmdname, strerror(-ret)); + exit(EXIT_FAILURE); + } + + exit(EXIT_SUCCESS); +}
On Tue, Feb 11, 2020 at 9:49 AM Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
Have you started looking at the required bitbake pieces? You're definitely dealing with a piece of pain that I'd like resolved!
cmdname);
exit(EXIT_FAILURE);
int opt;
switch (opt) {
case 'k':
keydir = optarg;
break;
case 'a':
algo_name = optarg;
break;
case 'n':
keyname = optarg;
break;
case 'r':
break;
default:
if (optind < argc)
if (!keydest)
int destfd, ret;
cmdname = argv[0];
if (!info.crypto) {
exit(EXIT_FAILURE);
while (1) {
if (destfd < 0)
exit(EXIT_FAILURE);
close(destfd);
break;
size_inc = 1024;
if (ret) {
exit(EXIT_FAILURE);
exit(EXIT_SUCCESS);
2.23.0
Not really, but I know that something like this is a necessary first part - and I'm glad to know I'm not the only one struggling with this.
For now I've come to the conclusion that kernel-fitimage.bbclass is not worth the trouble (for example, I need to create two different fit images with different initramfs, but a fit image without initramfs is pointless in my case, and there's no way to use kernel-fitimage.bbclass for that), so I just set KERNEL_IMAGETYPE to vmlinux, then have my own extra tasks doing the objcopy -O binary, gzip, and mkimage the different fit images I need.
[I'm also thinking that adding a companion tool for doing the signing part might make sense at some point - it's somewhat counter-intuituve that the .its contains some of the information (base name of key and algorithm - mkimage currently just segfaults if key-name-hint is accidentally omitted from the .its), while mkimage needs to be fed with another part (directory holding the keys).]
Rasmus
On Tue, Feb 11, 2020 at 10:22 AM Rasmus Villemoes rasmus.villemoes@prevas.dk wrote:
kernel-fitimage is a nightmare... every time someone touches it the risk of it breaking for someone else is pretty high. FWIW my flow through it is just kernel (no initramfs), DTBs and configurations, with keys pre-embedded in U-Boot, so avoiding the loop back through that otherwise happens. But I could do with the ability to compose configurations in it, which isn't easy with it today.
I suspect leaving kernel-fitimage to one side and starting again (with tests) has a lot of merit!
Rasmus
-- Alex Kiernan
Hi Rasmus,
Would it be possible to modify mkimage instead, with another flag?
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- test/py/tests/test_vboot.py | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/test/py/tests/test_vboot.py b/test/py/tests/test_vboot.py index 3dd8e3cb66..799c28cc2c 100644 --- a/test/py/tests/test_vboot.py +++ b/test/py/tests/test_vboot.py @@ -182,6 +182,13 @@ def test_vboot(u_boot_console):
+ # Create a fresh .dtb without the public keys + dtc('sandbox-u-boot.dts') + # Then add the dev key via the fdt_add_pubkey tool + util.run_and_log(cons, [fdt_add_pubkey, '-a', '%s,rsa2048' % sha_algo, + '-k', tmpdir, '-n', 'dev', '-r', 'conf', dtb]) + util.run_and_log(cons, [fit_check_sign, '-f', fit, '-k', dtb]) + # Replace header bytes bcfg = u_boot_console.config.buildconfig max_size = int(bcfg.get('config_fit_signature_max_size', 0x10000000), 0) @@ -246,6 +253,7 @@ def test_vboot(u_boot_console): fit = '%stest.fit' % tmpdir mkimage = cons.config.build_dir + '/tools/mkimage' fit_check_sign = cons.config.build_dir + '/tools/fit_check_sign' + fdt_add_pubkey = cons.config.build_dir + '/tools/fdt_add_pubkey' dtc_args = '-I dts -O dtb -i %s' % tmpdir dtb = '%ssandbox-u-boot.dtb' % tmpdir sig_node = '/configurations/conf-1/signature'
Alex Kiernan
Rasmus Villemoes
