[PATCH] andes: rearrange defconfig and dts and memory layout for SPL.
Modify "CONFIG_AE350" to "CONFIG_ANDES_AE350" Unify the memory layout for u-boot SPL.
Signed-off-by: Randolph randolph@andestech.com --- arch/riscv/Kconfig | 4 +- arch/riscv/dts/Makefile | 2 +- arch/riscv/dts/ae350-u-boot.dtsi | 1 + arch/riscv/dts/ae350_32.dts | 61 ++++++++++++++-------------- arch/riscv/dts/ae350_64.dts | 1 - board/AndesTech/ae350/Kconfig | 28 ++++++++++++- configs/ae350_rv32_defconfig | 3 +- configs/ae350_rv32_spl_defconfig | 21 ++++------ configs/ae350_rv32_spl_xip_defconfig | 18 ++++---- configs/ae350_rv32_xip_defconfig | 3 +- configs/ae350_rv64_defconfig | 3 +- configs/ae350_rv64_spl_defconfig | 19 ++++----- configs/ae350_rv64_spl_xip_defconfig | 16 ++++---- configs/ae350_rv64_xip_defconfig | 3 +- 14 files changed, 101 insertions(+), 82 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 6771d8d919..aff1f33665 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -8,8 +8,8 @@ choice prompt "Target select" optional
-config TARGET_AE350 - bool "Support ae350" +config TARGET_ANDES_AE350 + bool "Support Andes ae350"
config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board" diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index f1525cb668..be6c8a4227 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-dtb-$(CONFIG_TARGET_AE350) += ae350_32.dtb ae350_64.dtb +dtb-$(CONFIG_TARGET_ANDES_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += mpfs-icicle-kit.dtb dtb-$(CONFIG_TARGET_QEMU_VIRT) += qemu-virt32.dtb qemu-virt64.dtb dtb-$(CONFIG_TARGET_OPENPITON_RISCV64) += openpiton-riscv64.dtb diff --git a/arch/riscv/dts/ae350-u-boot.dtsi b/arch/riscv/dts/ae350-u-boot.dtsi index aef9159b7a..ff5725501f 100644 --- a/arch/riscv/dts/ae350-u-boot.dtsi +++ b/arch/riscv/dts/ae350-u-boot.dtsi @@ -1,4 +1,5 @@ // SPDX-License-Identifier: (GPL-2.0 OR MIT) +#include CONFIG_SPL_LOAD_FIT_CONFIG
/ { cpus { diff --git a/arch/riscv/dts/ae350_32.dts b/arch/riscv/dts/ae350_32.dts index 61af6d5465..3dde0e1dfa 100644 --- a/arch/riscv/dts/ae350_32.dts +++ b/arch/riscv/dts/ae350_32.dts @@ -2,12 +2,11 @@
/dts-v1/;
-#include "binman.dtsi" #include "ae350-u-boot.dtsi"
/ { - #address-cells = <1>; - #size-cells = <1>; + #address-cells = <2>; + #size-cells = <2>; compatible = "andestech,a25"; model = "andestech,a25";
@@ -115,7 +114,7 @@ compatible = "cache"; cache-level = <2>; cache-size = <0x40000>; - reg = <0xe0500000 0x40000>; + reg = <0x0 0xe0500000 0x0 0x40000>; andes,inst-prefetch = <3>; andes,data-prefetch = <3>; /* The value format is <XRAMOCTL XRAMICTL> */ @@ -125,12 +124,12 @@
memory@0 { device_type = "memory"; - reg = <0x00000000 0x40000000>; + reg = <0x0 0x00000000 0x0 0x40000000>; };
soc { - #address-cells = <1>; - #size-cells = <1>; + #address-cells = <2>; + #size-cells = <2>; compatible = "simple-bus"; ranges;
@@ -138,7 +137,7 @@ compatible = "riscv,plic0"; #interrupt-cells = <2>; interrupt-controller; - reg = <0xe4000000 0x2000000>; + reg = <0x0 0xe4000000 0x0 0x2000000>; riscv,ndev=<71>; interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9 &CPU1_intc 11 &CPU1_intc 9 @@ -148,9 +147,9 @@
plicsw: interrupt-controller@e6400000 { compatible = "andestech,plicsw"; - #interrupt-cells = <1>; + #interrupt-cells = <2>; interrupt-controller; - reg = <0xe6400000 0x400000>; + reg = <0x0 0xe6400000 0x0 0x400000>; riscv,ndev=<2>; interrupts-extended = <&CPU0_intc 3 &CPU1_intc 3 @@ -164,7 +163,7 @@ &CPU1_intc 7 &CPU2_intc 7 &CPU3_intc 7>; - reg = <0xe6000000 0x100000>; + reg = <0x0 0xe6000000 0x0 0x100000>; }; };
@@ -176,7 +175,7 @@
timer0: timer@f0400000 { compatible = "andestech,atcpit100"; - reg = <0xf0400000 0x1000>; + reg = <0x0 0xf0400000 0x0 0x1000>; clock-frequency = <60000000>; interrupts = <3 4>; interrupt-parent = <&plic0>; @@ -184,7 +183,7 @@
serial0: serial@f0300000 { compatible = "andestech,uart16550", "ns16550a"; - reg = <0xf0300000 0x1000>; + reg = <0x0 0xf0300000 0x0 0x1000>; interrupts = <9 4>; clock-frequency = <19660800>; reg-shift = <2>; @@ -195,7 +194,7 @@
mac0: mac@e0100000 { compatible = "andestech,atmac100"; - reg = <0xe0100000 0x1000>; + reg = <0x0 0xe0100000 0x0 0x1000>; interrupts = <19 4>; interrupt-parent = <&plic0>; }; @@ -205,7 +204,7 @@ max-frequency = <100000000>; clock-freq-min-max = <400000 100000000>; fifo-depth = <0x10>; - reg = <0xf0e00000 0x1000>; + reg = <0x0 0xf0e00000 0x0 0x1000>; interrupts = <18 4>; cap-sd-highspeed; interrupt-parent = <&plic0>; @@ -213,7 +212,7 @@
dma0: dma@f0c00000 { compatible = "andestech,atcdmac300"; - reg = <0xf0c00000 0x1000>; + reg = <0x0 0xf0c00000 0x0 0x1000>; interrupts = <10 4 64 4 65 4 66 4 67 4 68 4 69 4 70 4 71 4>; dma-channels = <8>; interrupt-parent = <&plic0>; @@ -221,19 +220,19 @@
lcd0: lcd@e0200000 { compatible = "andestech,atflcdc100"; - reg = <0xe0200000 0x1000>; + reg = <0x0 0xe0200000 0x0 0x1000>; interrupts = <20 4>; interrupt-parent = <&plic0>; };
smc0: smc@e0400000 { compatible = "andestech,atfsmc020"; - reg = <0xe0400000 0x1000>; + reg = <0x0 0xe0400000 0x0 0x1000>; };
snd0: snd@f0d00000 { compatible = "andestech,atfac97"; - reg = <0xf0d00000 0x1000>; + reg = <0x0 0xf0d00000 0x0 0x1000>; interrupts = <17 4>; interrupt-parent = <&plic0>; }; @@ -245,71 +244,71 @@ virtio_mmio@fe007000 { interrupts = <0x17 0x4>; interrupt-parent = <0x2>; - reg = <0xfe007000 0x1000>; + reg = <0x0 0xfe007000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe006000 { interrupts = <0x16 0x4>; interrupt-parent = <0x2>; - reg = <0xfe006000 0x1000>; + reg = <0x0 0xfe006000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe005000 { interrupts = <0x15 0x4>; interrupt-parent = <0x2>; - reg = <0xfe005000 0x1000>; + reg = <0x0 0xfe005000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe004000 { interrupts = <0x14 0x4>; interrupt-parent = <0x2>; - reg = <0xfe004000 0x1000>; + reg = <0x0 0xfe004000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe003000 { interrupts = <0x13 0x4>; interrupt-parent = <0x2>; - reg = <0xfe003000 0x1000>; + reg = <0x0 0xfe003000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe002000 { interrupts = <0x12 0x4>; interrupt-parent = <0x2>; - reg = <0xfe002000 0x1000>; + reg = <0x0 0xfe002000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe001000 { interrupts = <0x11 0x4>; interrupt-parent = <0x2>; - reg = <0xfe001000 0x1000>; + reg = <0x0 0xfe001000 0x0 0x1000>; compatible = "virtio,mmio"; };
virtio_mmio@fe000000 { interrupts = <0x10 0x4>; interrupt-parent = <0x2>; - reg = <0xfe000000 0x1000>; + reg = <0x0 0xfe000000 0x0 0x1000>; compatible = "virtio,mmio"; };
nor@0,0 { - #address-cells = <1>; - #size-cells = <1>; + #address-cells = <2>; + #size-cells = <2>; compatible = "cfi-flash"; - reg = <0x88000000 0x4000000>; + reg = <0x0 0x88000000 0x0 0x4000000>; bank-width = <2>; device-width = <1>; };
spi: spi@f0b00000 { compatible = "andestech,atcspi200"; - reg = <0xf0b00000 0x1000>; + reg = <0x0 0xf0b00000 0x0 0x1000>; #address-cells = <1>; #size-cells = <0>; num-cs = <1>; diff --git a/arch/riscv/dts/ae350_64.dts b/arch/riscv/dts/ae350_64.dts index 8c7db29b4f..9d5f6c743c 100644 --- a/arch/riscv/dts/ae350_64.dts +++ b/arch/riscv/dts/ae350_64.dts @@ -2,7 +2,6 @@
/dts-v1/;
/ { diff --git a/board/AndesTech/ae350/Kconfig b/board/AndesTech/ae350/Kconfig index 75815bf99a..3b0d4c1733 100644 --- a/board/AndesTech/ae350/Kconfig +++ b/board/AndesTech/ae350/Kconfig @@ -1,4 +1,4 @@ -if TARGET_AE350 +if TARGET_ANDES_AE350
config SYS_CPU default "andesv5" @@ -41,4 +41,30 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SPL_RAM_DEVICE imply OF_HAS_PRIOR_STAGE
+choice + prompt "Fit type" + default SPL_LOAD_FIT_NORMAL + +config SPL_LOAD_FIT_NORMAL + bool "Enable SPL applying u-boot proper from FIT" + depends on SPL_LOAD_FIT + help + Use fw_dynamic from the FIT image. Normal mode means that CPU will execute + u-boot proper in next step. + +config SPL_LOAD_FIT_DYNAMIC + bool "Enable SPL (dynamic mode) applying linux from FIT" + depends on SPL_LOAD_FIT + help + Use fw_dynamic from the FIT image. Dynamic mode means that CPU will execute + linux in the next step. + +endchoice + +config SPL_LOAD_FIT_CONFIG + string "Default FIT configuration" + depends on SPL_LOAD_FIT + help + Specify corresponding FIT configuration for each modes. + endif diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 06a683d986..eea919249d 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -9,7 +9,8 @@ CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_MONITOR_LEN=786432 CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ae350_rv32_spl_defconfig b/configs/ae350_rv32_spl_defconfig index 75e55ba724..1479eb256e 100644 --- a/configs/ae350_rv32_spl_defconfig +++ b/configs/ae350_rv32_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_TEXT_BASE=0x01800000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_NR_DRAM_BANKS=2 @@ -7,25 +8,23 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x10000000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_SYS_MONITOR_LEN=786432 -CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y CONFIG_RISCV_SMODE=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" # CONFIG_AVAILABLE_HARTS is not set +CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 +CONFIG_PHYS_64BIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 CONFIG_SYS_MONITOR_BASE=0x88000000 -CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 -CONFIG_DISPLAY_CPUINFO=y -CONFIG_DISPLAY_BOARDINFO=y -CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 -CONFIG_SPL_BSS_START_ADDR=0x4000000 -CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BSS_START_ADDR=0x400000 CONFIG_SPL_CACHE=y +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x0 CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y @@ -36,7 +35,6 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y @@ -45,7 +43,6 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y -CONFIG_FLASH_SHOW_PROGRESS=0 CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv32_spl_xip_defconfig b/configs/ae350_rv32_spl_xip_defconfig index c2221b891e..142c5e29f2 100644 --- a/configs/ae350_rv32_spl_xip_defconfig +++ b/configs/ae350_rv32_spl_xip_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_TEXT_BASE=0x01800000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_NR_DRAM_BANKS=2 @@ -8,25 +9,24 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_SYS_MONITOR_LEN=786432 -CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y CONFIG_RISCV_SMODE=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_SPL_XIP=y +# CONFIG_AVAILABLE_HARTS is not set +CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 -CONFIG_DISPLAY_CPUINFO=y -CONFIG_DISPLAY_BOARDINFO=y -CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 -CONFIG_SPL_BSS_START_ADDR=0x4000000 -CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BSS_START_ADDR=0x400000 CONFIG_SPL_CACHE=y +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x0 CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y @@ -37,7 +37,6 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y @@ -46,7 +45,6 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y -CONFIG_FLASH_SHOW_PROGRESS=0 CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv32_xip_defconfig b/configs/ae350_rv32_xip_defconfig index 6d19400c2d..1b01b881ed 100644 --- a/configs/ae350_rv32_xip_defconfig +++ b/configs/ae350_rv32_xip_defconfig @@ -9,7 +9,8 @@ CONFIG_DEFAULT_DEVICE_TREE="ae350_32" CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_MONITOR_LEN=786432 CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_XIP=y CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index 0d7f0a552e..cd13fc58a5 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -8,7 +8,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_ARCH_RV64I=y CONFIG_FIT=y CONFIG_SYS_MONITOR_BASE=0x88000000 diff --git a/configs/ae350_rv64_spl_defconfig b/configs/ae350_rv64_spl_defconfig index 6a72b5a047..f48838ddf9 100644 --- a/configs/ae350_rv64_spl_defconfig +++ b/configs/ae350_rv64_spl_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_TEXT_BASE=0x01800000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_NR_DRAM_BANKS=2 @@ -7,25 +8,23 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x10000000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" # CONFIG_AVAILABLE_HARTS is not set CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT_ADDRESS=0x00200000 -CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_DISTRO_DEFAULTS=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x10000000 +CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_BOOTDELAY=3 -CONFIG_DISPLAY_CPUINFO=y -CONFIG_DISPLAY_BOARDINFO=y -CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 -CONFIG_SPL_BSS_START_ADDR=0x4000000 -CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BSS_START_ADDR=0x400000 CONFIG_SPL_CACHE=y +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x0 CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y @@ -36,7 +35,6 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y @@ -45,7 +43,6 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y -CONFIG_FLASH_SHOW_PROGRESS=0 CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv64_spl_xip_defconfig b/configs/ae350_rv64_spl_xip_defconfig index 43581c79b1..15de9d9ef6 100644 --- a/configs/ae350_rv64_spl_xip_defconfig +++ b/configs/ae350_rv64_spl_xip_defconfig @@ -1,4 +1,5 @@ CONFIG_RISCV=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_TEXT_BASE=0x01800000 CONFIG_SYS_MALLOC_LEN=0x80000 CONFIG_NR_DRAM_BANKS=2 @@ -8,25 +9,24 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SYS_PROMPT="RISC-V # " -CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x2000000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_SPL_XIP=y +# CONFIG_AVAILABLE_HARTS is not set CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x80010000 CONFIG_SYS_MONITOR_BASE=0x88000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 -CONFIG_DISPLAY_CPUINFO=y -CONFIG_DISPLAY_BOARDINFO=y -CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_MAX_SIZE=0x100000 -CONFIG_SPL_BSS_START_ADDR=0x4000000 -CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BSS_START_ADDR=0x400000 CONFIG_SPL_CACHE=y +CONFIG_SPL_OPENSBI_SCRATCH_OPTIONS=0x0 CONFIG_SYS_PBSIZE=1050 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_IMLS=y @@ -37,7 +37,6 @@ CONFIG_BOOTP_PREFER_SERVERIP=y CONFIG_CMD_CACHE=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RETRY_COUNT=50 CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC=y @@ -46,7 +45,6 @@ CONFIG_FTSDC010_SDIO=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI_WIDTH_16BIT=y -CONFIG_FLASH_SHOW_PROGRESS=0 CONFIG_SYS_CFI_FLASH_STATUS_POLL=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y diff --git a/configs/ae350_rv64_xip_defconfig b/configs/ae350_rv64_xip_defconfig index 02d7694489..88c3869f75 100644 --- a/configs/ae350_rv64_xip_defconfig +++ b/configs/ae350_rv64_xip_defconfig @@ -8,7 +8,8 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_DEFAULT_DEVICE_TREE="ae350_64" CONFIG_SYS_PROMPT="RISC-V # " CONFIG_SYS_LOAD_ADDR=0x100000 -CONFIG_TARGET_AE350=y +CONFIG_TARGET_ANDES_AE350=y +CONFIG_SPL_LOAD_FIT_CONFIG="binman.dtsi" CONFIG_ARCH_RV64I=y CONFIG_XIP=y CONFIG_FIT=y
This does 3 things and needs to be 3 patches. First, is renaming TARGET_AE350 to TARGET_ANDES_AE350 which is fine. The second is the memory map changes which also seem fine but are harder to review. The third is introducing what to me seems like a different way to implement SPL_OS_BOOT. But there's also not a full example of what that part looks like in this patch.
Randolph
