[U-Boot] [PATCH 1/6] net: macb: sync header definitions as taken from Linux
Few registers and bits were added by Cadence and they were not updated in the headers. Take the latest definitions as defined in Linux header (5.1) that also includes some comments about existing registers.
One register was improperly named (UR), fix that.
Signed-off-by: Ramon Fried rfried.dev@gmail.com ---
drivers/net/macb.c | 4 +- drivers/net/macb.h | 868 ++++++++++++++++++++++++++++++++++----------- 2 files changed, 660 insertions(+), 212 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index c5560a7111..5858004858 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -772,9 +772,9 @@ static int _macb_init(struct macb_device *macb, const char *name) #ifdef CONFIG_DM_ETH if ((macb->phy_interface == PHY_INTERFACE_MODE_RMII) || (macb->phy_interface == PHY_INTERFACE_MODE_RGMII)) - gem_writel(macb, UR, GEM_BIT(RGMII)); + gem_writel(macb, USRIO, GEM_BIT(RGMII)); else - gem_writel(macb, UR, 0); + gem_writel(macb, USRIO, 0); #else #if defined(CONFIG_RGMII) || defined(CONFIG_RMII) gem_writel(macb, UR, GEM_BIT(RGMII)); diff --git a/drivers/net/macb.h b/drivers/net/macb.h index 3cc27f8560..8966c793a7 100644 --- a/drivers/net/macb.h +++ b/drivers/net/macb.h @@ -5,221 +5,410 @@ #ifndef __DRIVERS_MACB_H__ #define __DRIVERS_MACB_H__
+#define MACB_GREGS_NBR 16 +#define MACB_GREGS_VERSION 2 +#define MACB_MAX_QUEUES 8 + /* MACB register offsets */ -#define MACB_NCR 0x0000 -#define MACB_NCFGR 0x0004 -#define MACB_NSR 0x0008 -#define GEM_UR 0x000c -#define MACB_DMACFG 0x0010 -#define MACB_TSR 0x0014 -#define MACB_RBQP 0x0018 -#define MACB_TBQP 0x001c -#define MACB_RSR 0x0020 -#define MACB_ISR 0x0024 -#define MACB_IER 0x0028 -#define MACB_IDR 0x002c -#define MACB_IMR 0x0030 -#define MACB_MAN 0x0034 -#define MACB_PTR 0x0038 -#define MACB_PFR 0x003c -#define MACB_FTO 0x0040 -#define MACB_SCF 0x0044 -#define MACB_MCF 0x0048 -#define MACB_FRO 0x004c -#define MACB_FCSE 0x0050 -#define MACB_ALE 0x0054 -#define MACB_DTF 0x0058 -#define MACB_LCOL 0x005c -#define MACB_EXCOL 0x0060 -#define MACB_TUND 0x0064 -#define MACB_CSE 0x0068 -#define MACB_RRE 0x006c -#define MACB_ROVR 0x0070 -#define MACB_RSE 0x0074 -#define MACB_ELE 0x0078 -#define MACB_RJA 0x007c -#define MACB_USF 0x0080 -#define MACB_STE 0x0084 -#define MACB_RLE 0x0088 -#define MACB_TPF 0x008c -#define MACB_HRB 0x0090 -#define MACB_HRT 0x0094 -#define MACB_SA1B 0x0098 -#define MACB_SA1T 0x009c -#define MACB_SA2B 0x00a0 -#define MACB_SA2T 0x00a4 -#define MACB_SA3B 0x00a8 -#define MACB_SA3T 0x00ac -#define MACB_SA4B 0x00b0 -#define MACB_SA4T 0x00b4 -#define MACB_TID 0x00b8 -#define MACB_TPQ 0x00bc -#define MACB_USRIO 0x00c0 -#define MACB_WOL 0x00c4 -#define MACB_MID 0x00fc - -/* GEM specific register offsets */ -#define GEM_DCFG1 0x0280 -#define GEM_DCFG6 0x0294 - -#define MACB_MAX_QUEUES 8 - -/* GEM specific multi queues register offset */ -/* hw_q can be 0~7 */ -#define GEM_TBQP(hw_q) (0x0440 + ((hw_q) << 2)) +#define MACB_NCR 0x0000 /* Network Control */ +#define MACB_NCFGR 0x0004 /* Network Config */ +#define MACB_NSR 0x0008 /* Network Status */ +#define MACB_TAR 0x000c /* AT91RM9200 only */ +#define MACB_TCR 0x0010 /* AT91RM9200 only */ +#define MACB_TSR 0x0014 /* Transmit Status */ +#define MACB_RBQP 0x0018 /* RX Q Base Address */ +#define MACB_TBQP 0x001c /* TX Q Base Address */ +#define MACB_RSR 0x0020 /* Receive Status */ +#define MACB_ISR 0x0024 /* Interrupt Status */ +#define MACB_IER 0x0028 /* Interrupt Enable */ +#define MACB_IDR 0x002c /* Interrupt Disable */ +#define MACB_IMR 0x0030 /* Interrupt Mask */ +#define MACB_MAN 0x0034 /* PHY Maintenance */ +#define MACB_PTR 0x0038 +#define MACB_PFR 0x003c +#define MACB_FTO 0x0040 +#define MACB_SCF 0x0044 +#define MACB_MCF 0x0048 +#define MACB_FRO 0x004c +#define MACB_FCSE 0x0050 +#define MACB_ALE 0x0054 +#define MACB_DTF 0x0058 +#define MACB_LCOL 0x005c +#define MACB_EXCOL 0x0060 +#define MACB_TUND 0x0064 +#define MACB_CSE 0x0068 +#define MACB_RRE 0x006c +#define MACB_ROVR 0x0070 +#define MACB_RSE 0x0074 +#define MACB_ELE 0x0078 +#define MACB_RJA 0x007c +#define MACB_USF 0x0080 +#define MACB_STE 0x0084 +#define MACB_RLE 0x0088 +#define MACB_TPF 0x008c +#define MACB_HRB 0x0090 +#define MACB_HRT 0x0094 +#define MACB_SA1B 0x0098 +#define MACB_SA1T 0x009c +#define MACB_SA2B 0x00a0 +#define MACB_SA2T 0x00a4 +#define MACB_SA3B 0x00a8 +#define MACB_SA3T 0x00ac +#define MACB_SA4B 0x00b0 +#define MACB_SA4T 0x00b4 +#define MACB_TID 0x00b8 +#define MACB_TPQ 0x00bc +#define MACB_USRIO 0x00c0 +#define MACB_WOL 0x00c4 +#define MACB_MID 0x00fc +#define MACB_TBQPH 0x04C8 +#define MACB_RBQPH 0x04D4 + +/* GEM register offsets. */ +#define GEM_NCFGR 0x0004 /* Network Config */ +#define GEM_USRIO 0x000c /* User IO */ +#define GEM_DMACFG 0x0010 /* DMA Configuration */ +#define GEM_JML 0x0048 /* Jumbo Max Length */ +#define GEM_HRB 0x0080 /* Hash Bottom */ +#define GEM_HRT 0x0084 /* Hash Top */ +#define GEM_SA1B 0x0088 /* Specific1 Bottom */ +#define GEM_SA1T 0x008C /* Specific1 Top */ +#define GEM_SA2B 0x0090 /* Specific2 Bottom */ +#define GEM_SA2T 0x0094 /* Specific2 Top */ +#define GEM_SA3B 0x0098 /* Specific3 Bottom */ +#define GEM_SA3T 0x009C /* Specific3 Top */ +#define GEM_SA4B 0x00A0 /* Specific4 Bottom */ +#define GEM_SA4T 0x00A4 /* Specific4 Top */ +#define GEM_EFTSH 0x00e8 /* PTP Event Frame Transmitted Seconds Register 47:32 */ +#define GEM_EFRSH 0x00ec /* PTP Event Frame Received Seconds Register 47:32 */ +#define GEM_PEFTSH 0x00f0 /* PTP Peer Event Frame Transmitted Seconds Register 47:32 */ +#define GEM_PEFRSH 0x00f4 /* PTP Peer Event Frame Received Seconds Register 47:32 */ +#define GEM_OTX 0x0100 /* Octets transmitted */ +#define GEM_OCTTXL 0x0100 /* Octets transmitted [31:0] */ +#define GEM_OCTTXH 0x0104 /* Octets transmitted [47:32] */ +#define GEM_TXCNT 0x0108 /* Frames Transmitted counter */ +#define GEM_TXBCCNT 0x010c /* Broadcast Frames counter */ +#define GEM_TXMCCNT 0x0110 /* Multicast Frames counter */ +#define GEM_TXPAUSECNT 0x0114 /* Pause Frames Transmitted Counter */ +#define GEM_TX64CNT 0x0118 /* 64 byte Frames TX counter */ +#define GEM_TX65CNT 0x011c /* 65-127 byte Frames TX counter */ +#define GEM_TX128CNT 0x0120 /* 128-255 byte Frames TX counter */ +#define GEM_TX256CNT 0x0124 /* 256-511 byte Frames TX counter */ +#define GEM_TX512CNT 0x0128 /* 512-1023 byte Frames TX counter */ +#define GEM_TX1024CNT 0x012c /* 1024-1518 byte Frames TX counter */ +#define GEM_TX1519CNT 0x0130 /* 1519+ byte Frames TX counter */ +#define GEM_TXURUNCNT 0x0134 /* TX under run error counter */ +#define GEM_SNGLCOLLCNT 0x0138 /* Single Collision Frame Counter */ +#define GEM_MULTICOLLCNT 0x013c /* Multiple Collision Frame Counter */ +#define GEM_EXCESSCOLLCNT 0x0140 /* Excessive Collision Frame Counter */ +#define GEM_LATECOLLCNT 0x0144 /* Late Collision Frame Counter */ +#define GEM_TXDEFERCNT 0x0148 /* Deferred Transmission Frame Counter */ +#define GEM_TXCSENSECNT 0x014c /* Carrier Sense Error Counter */ +#define GEM_ORX 0x0150 /* Octets received */ +#define GEM_OCTRXL 0x0150 /* Octets received [31:0] */ +#define GEM_OCTRXH 0x0154 /* Octets received [47:32] */ +#define GEM_RXCNT 0x0158 /* Frames Received Counter */ +#define GEM_RXBROADCNT 0x015c /* Broadcast Frames Received Counter */ +#define GEM_RXMULTICNT 0x0160 /* Multicast Frames Received Counter */ +#define GEM_RXPAUSECNT 0x0164 /* Pause Frames Received Counter */ +#define GEM_RX64CNT 0x0168 /* 64 byte Frames RX Counter */ +#define GEM_RX65CNT 0x016c /* 65-127 byte Frames RX Counter */ +#define GEM_RX128CNT 0x0170 /* 128-255 byte Frames RX Counter */ +#define GEM_RX256CNT 0x0174 /* 256-511 byte Frames RX Counter */ +#define GEM_RX512CNT 0x0178 /* 512-1023 byte Frames RX Counter */ +#define GEM_RX1024CNT 0x017c /* 1024-1518 byte Frames RX Counter */ +#define GEM_RX1519CNT 0x0180 /* 1519+ byte Frames RX Counter */ +#define GEM_RXUNDRCNT 0x0184 /* Undersize Frames Received Counter */ +#define GEM_RXOVRCNT 0x0188 /* Oversize Frames Received Counter */ +#define GEM_RXJABCNT 0x018c /* Jabbers Received Counter */ +#define GEM_RXFCSCNT 0x0190 /* Frame Check Sequence Error Counter */ +#define GEM_RXLENGTHCNT 0x0194 /* Length Field Error Counter */ +#define GEM_RXSYMBCNT 0x0198 /* Symbol Error Counter */ +#define GEM_RXALIGNCNT 0x019c /* Alignment Error Counter */ +#define GEM_RXRESERRCNT 0x01a0 /* Receive Resource Error Counter */ +#define GEM_RXORCNT 0x01a4 /* Receive Overrun Counter */ +#define GEM_RXIPCCNT 0x01a8 /* IP header Checksum Error Counter */ +#define GEM_RXTCPCCNT 0x01ac /* TCP Checksum Error Counter */ +#define GEM_RXUDPCCNT 0x01b0 /* UDP Checksum Error Counter */ +#define GEM_TISUBN 0x01bc /* 1588 Timer Increment Sub-ns */ +#define GEM_TSH 0x01c0 /* 1588 Timer Seconds High */ +#define GEM_TSL 0x01d0 /* 1588 Timer Seconds Low */ +#define GEM_TN 0x01d4 /* 1588 Timer Nanoseconds */ +#define GEM_TA 0x01d8 /* 1588 Timer Adjust */ +#define GEM_TI 0x01dc /* 1588 Timer Increment */ +#define GEM_EFTSL 0x01e0 /* PTP Event Frame Tx Seconds Low */ +#define GEM_EFTN 0x01e4 /* PTP Event Frame Tx Nanoseconds */ +#define GEM_EFRSL 0x01e8 /* PTP Event Frame Rx Seconds Low */ +#define GEM_EFRN 0x01ec /* PTP Event Frame Rx Nanoseconds */ +#define GEM_PEFTSL 0x01f0 /* PTP Peer Event Frame Tx Secs Low */ +#define GEM_PEFTN 0x01f4 /* PTP Peer Event Frame Tx Ns */ +#define GEM_PEFRSL 0x01f8 /* PTP Peer Event Frame Rx Sec Low */ +#define GEM_PEFRN 0x01fc /* PTP Peer Event Frame Rx Ns */ +#define GEM_DCFG1 0x0280 /* Design Config 1 */ +#define GEM_DCFG2 0x0284 /* Design Config 2 */ +#define GEM_DCFG3 0x0288 /* Design Config 3 */ +#define GEM_DCFG4 0x028c /* Design Config 4 */ +#define GEM_DCFG5 0x0290 /* Design Config 5 */ +#define GEM_DCFG6 0x0294 /* Design Config 6 */ +#define GEM_DCFG7 0x0298 /* Design Config 7 */ +#define GEM_DCFG8 0x029C /* Design Config 8 */ +#define GEM_DCFG10 0x02A4 /* Design Config 10 */ + +#define GEM_TXBDCTRL 0x04cc /* TX Buffer Descriptor control register */ +#define GEM_RXBDCTRL 0x04d0 /* RX Buffer Descriptor control register */ + +/* Screener Type 2 match registers */ +#define GEM_SCRT2 0x540 + +/* EtherType registers */ +#define GEM_ETHT 0x06E0 + +/* Type 2 compare registers */ +#define GEM_T2CMPW0 0x0700 +#define GEM_T2CMPW1 0x0704 +#define T2CMP_OFST(t2idx) (t2idx * 2) + +/* type 2 compare registers + * each location requires 3 compare regs + */ +#define GEM_IP4SRC_CMP(idx) (idx * 3) +#define GEM_IP4DST_CMP(idx) (idx * 3 + 1) +#define GEM_PORT_CMP(idx) (idx * 3 + 2) + +/* Which screening type 2 EtherType register will be used (0 - 7) */ +#define SCRT2_ETHT 0 + +#define GEM_ISR(hw_q) (0x0400 + ((hw_q) << 2)) +#define GEM_TBQP(hw_q) (0x0440 + ((hw_q) << 2)) +#define GEM_TBQPH(hw_q) (0x04C8) +#define GEM_RBQP(hw_q) (0x0480 + ((hw_q) << 2)) +#define GEM_RBQS(hw_q) (0x04A0 + ((hw_q) << 2)) +#define GEM_RBQPH(hw_q) (0x04D4) +#define GEM_IER(hw_q) (0x0600 + ((hw_q) << 2)) +#define GEM_IDR(hw_q) (0x0620 + ((hw_q) << 2)) +#define GEM_IMR(hw_q) (0x0640 + ((hw_q) << 2))
/* Bitfields in NCR */ -#define MACB_LB_OFFSET 0 -#define MACB_LB_SIZE 1 -#define MACB_LLB_OFFSET 1 -#define MACB_LLB_SIZE 1 -#define MACB_RE_OFFSET 2 -#define MACB_RE_SIZE 1 -#define MACB_TE_OFFSET 3 -#define MACB_TE_SIZE 1 -#define MACB_MPE_OFFSET 4 -#define MACB_MPE_SIZE 1 -#define MACB_CLRSTAT_OFFSET 5 -#define MACB_CLRSTAT_SIZE 1 -#define MACB_INCSTAT_OFFSET 6 -#define MACB_INCSTAT_SIZE 1 -#define MACB_WESTAT_OFFSET 7 -#define MACB_WESTAT_SIZE 1 -#define MACB_BP_OFFSET 8 -#define MACB_BP_SIZE 1 -#define MACB_TSTART_OFFSET 9 -#define MACB_TSTART_SIZE 1 -#define MACB_THALT_OFFSET 10 -#define MACB_THALT_SIZE 1 -#define MACB_NCR_TPF_OFFSET 11 -#define MACB_NCR_TPF_SIZE 1 -#define MACB_TZQ_OFFSET 12 -#define MACB_TZQ_SIZE 1 +#define MACB_LB_OFFSET 0 /* reserved */ +#define MACB_LB_SIZE 1 +#define MACB_LLB_OFFSET 1 /* Loop back local */ +#define MACB_LLB_SIZE 1 +#define MACB_RE_OFFSET 2 /* Receive enable */ +#define MACB_RE_SIZE 1 +#define MACB_TE_OFFSET 3 /* Transmit enable */ +#define MACB_TE_SIZE 1 +#define MACB_MPE_OFFSET 4 /* Management port enable */ +#define MACB_MPE_SIZE 1 +#define MACB_CLRSTAT_OFFSET 5 /* Clear stats regs */ +#define MACB_CLRSTAT_SIZE 1 +#define MACB_INCSTAT_OFFSET 6 /* Incremental stats regs */ +#define MACB_INCSTAT_SIZE 1 +#define MACB_WESTAT_OFFSET 7 /* Write enable stats regs */ +#define MACB_WESTAT_SIZE 1 +#define MACB_BP_OFFSET 8 /* Back pressure */ +#define MACB_BP_SIZE 1 +#define MACB_TSTART_OFFSET 9 /* Start transmission */ +#define MACB_TSTART_SIZE 1 +#define MACB_THALT_OFFSET 10 /* Transmit halt */ +#define MACB_THALT_SIZE 1 +#define MACB_NCR_TPF_OFFSET 11 /* Transmit pause frame */ +#define MACB_NCR_TPF_SIZE 1 +#define MACB_TZQ_OFFSET 12 /* Transmit zero quantum pause frame */ +#define MACB_TZQ_SIZE 1 +#define MACB_SRTSM_OFFSET 15 +#define MACB_OSSMODE_OFFSET 24 /* Enable One Step Synchro Mode */ +#define MACB_OSSMODE_SIZE 1
/* Bitfields in NCFGR */ -#define MACB_SPD_OFFSET 0 -#define MACB_SPD_SIZE 1 -#define MACB_FD_OFFSET 1 -#define MACB_FD_SIZE 1 -#define MACB_BIT_RATE_OFFSET 2 -#define MACB_BIT_RATE_SIZE 1 -#define MACB_JFRAME_OFFSET 3 -#define MACB_JFRAME_SIZE 1 -#define MACB_CAF_OFFSET 4 -#define MACB_CAF_SIZE 1 -#define MACB_NBC_OFFSET 5 -#define MACB_NBC_SIZE 1 -#define MACB_NCFGR_MTI_OFFSET 6 -#define MACB_NCFGR_MTI_SIZE 1 -#define MACB_UNI_OFFSET 7 -#define MACB_UNI_SIZE 1 -#define MACB_BIG_OFFSET 8 -#define MACB_BIG_SIZE 1 -#define MACB_EAE_OFFSET 9 -#define MACB_EAE_SIZE 1 -#define MACB_CLK_OFFSET 10 -#define MACB_CLK_SIZE 2 -#define MACB_RTY_OFFSET 12 -#define MACB_RTY_SIZE 1 -#define MACB_PAE_OFFSET 13 -#define MACB_PAE_SIZE 1 -#define MACB_RBOF_OFFSET 14 -#define MACB_RBOF_SIZE 2 -#define MACB_RLCE_OFFSET 16 -#define MACB_RLCE_SIZE 1 -#define MACB_DRFCS_OFFSET 17 -#define MACB_DRFCS_SIZE 1 -#define MACB_EFRHD_OFFSET 18 -#define MACB_EFRHD_SIZE 1 -#define MACB_IRXFCS_OFFSET 19 -#define MACB_IRXFCS_SIZE 1 - -#define GEM_GBE_OFFSET 10 -#define GEM_GBE_SIZE 1 -#define GEM_CLK_OFFSET 18 -#define GEM_CLK_SIZE 3 -#define GEM_DBW_OFFSET 21 -#define GEM_DBW_SIZE 2 +#define MACB_SPD_OFFSET 0 /* Speed */ +#define MACB_SPD_SIZE 1 +#define MACB_FD_OFFSET 1 /* Full duplex */ +#define MACB_FD_SIZE 1 +#define MACB_BIT_RATE_OFFSET 2 /* Discard non-VLAN frames */ +#define MACB_BIT_RATE_SIZE 1 +#define MACB_JFRAME_OFFSET 3 /* reserved */ +#define MACB_JFRAME_SIZE 1 +#define MACB_CAF_OFFSET 4 /* Copy all frames */ +#define MACB_CAF_SIZE 1 +#define MACB_NBC_OFFSET 5 /* No broadcast */ +#define MACB_NBC_SIZE 1 +#define MACB_NCFGR_MTI_OFFSET 6 /* Multicast hash enable */ +#define MACB_NCFGR_MTI_SIZE 1 +#define MACB_UNI_OFFSET 7 /* Unicast hash enable */ +#define MACB_UNI_SIZE 1 +#define MACB_BIG_OFFSET 8 /* Receive 1536 byte frames */ +#define MACB_BIG_SIZE 1 +#define MACB_EAE_OFFSET 9 /* External address match enable */ +#define MACB_EAE_SIZE 1 +#define MACB_CLK_OFFSET 10 +#define MACB_CLK_SIZE 2 +#define MACB_RTY_OFFSET 12 /* Retry test */ +#define MACB_RTY_SIZE 1 +#define MACB_PAE_OFFSET 13 /* Pause enable */ +#define MACB_PAE_SIZE 1 +#define MACB_RM9200_RMII_OFFSET 13 /* AT91RM9200 only */ +#define MACB_RM9200_RMII_SIZE 1 /* AT91RM9200 only */ +#define MACB_RBOF_OFFSET 14 /* Receive buffer offset */ +#define MACB_RBOF_SIZE 2 +#define MACB_RLCE_OFFSET 16 /* Length field error frame discard */ +#define MACB_RLCE_SIZE 1 +#define MACB_DRFCS_OFFSET 17 /* FCS remove */ +#define MACB_DRFCS_SIZE 1 +#define MACB_EFRHD_OFFSET 18 +#define MACB_EFRHD_SIZE 1 +#define MACB_IRXFCS_OFFSET 19 +#define MACB_IRXFCS_SIZE 1 + +/* GEM specific NCFGR bitfields. */ +#define GEM_GBE_OFFSET 10 /* Gigabit mode enable */ +#define GEM_GBE_SIZE 1 +#define GEM_PCSSEL_OFFSET 11 +#define GEM_PCSSEL_SIZE 1 +#define GEM_CLK_OFFSET 18 /* MDC clock division */ +#define GEM_CLK_SIZE 3 +#define GEM_DBW_OFFSET 21 /* Data bus width */ +#define GEM_DBW_SIZE 2 +#define GEM_RXCOEN_OFFSET 24 +#define GEM_RXCOEN_SIZE 1 +#define GEM_SGMIIEN_OFFSET 27 +#define GEM_SGMIIEN_SIZE 1 + + +/* Constants for data bus width. */ +#define GEM_DBW32 0 /* 32 bit AMBA AHB data bus width */ +#define GEM_DBW64 1 /* 64 bit AMBA AHB data bus width */ +#define GEM_DBW128 2 /* 128 bit AMBA AHB data bus width */ + +/* Bitfields in DMACFG. */ +#define GEM_FBLDO_OFFSET 0 /* fixed burst length for DMA */ +#define GEM_FBLDO_SIZE 5 +#define GEM_ENDIA_DESC_OFFSET 6 /* endian swap mode for management descriptor access */ +#define GEM_ENDIA_DESC_SIZE 1 +#define GEM_ENDIA_PKT_OFFSET 7 /* endian swap mode for packet data access */ +#define GEM_ENDIA_PKT_SIZE 1 +#define GEM_RXBMS_OFFSET 8 /* RX packet buffer memory size select */ +#define GEM_RXBMS_SIZE 2 +#define GEM_TXPBMS_OFFSET 10 /* TX packet buffer memory size select */ +#define GEM_TXPBMS_SIZE 1 +#define GEM_TXCOEN_OFFSET 11 /* TX IP/TCP/UDP checksum gen offload */ +#define GEM_TXCOEN_SIZE 1 +#define GEM_RXBS_OFFSET 16 /* DMA receive buffer size */ +#define GEM_RXBS_SIZE 8 +#define GEM_DDRP_OFFSET 24 /* disc_when_no_ahb */ +#define GEM_DDRP_SIZE 1 +#define GEM_RXEXT_OFFSET 28 /* RX extended Buffer Descriptor mode */ +#define GEM_RXEXT_SIZE 1 +#define GEM_TXEXT_OFFSET 29 /* TX extended Buffer Descriptor mode */ +#define GEM_TXEXT_SIZE 1 +#define GEM_ADDR64_OFFSET 30 /* Address bus width - 64b or 32b */ +#define GEM_ADDR64_SIZE 1 +
/* Bitfields in NSR */ -#define MACB_NSR_LINK_OFFSET 0 -#define MACB_NSR_LINK_SIZE 1 -#define MACB_MDIO_OFFSET 1 -#define MACB_MDIO_SIZE 1 -#define MACB_IDLE_OFFSET 2 -#define MACB_IDLE_SIZE 1 - -/* Bitfields in UR */ -#define GEM_RGMII_OFFSET 0 -#define GEM_RGMII_SIZE 1 +#define MACB_NSR_LINK_OFFSET 0 /* pcs_link_state */ +#define MACB_NSR_LINK_SIZE 1 +#define MACB_MDIO_OFFSET 1 /* status of the mdio_in pin */ +#define MACB_MDIO_SIZE 1 +#define MACB_IDLE_OFFSET 2 /* The PHY management logic is idle */ +#define MACB_IDLE_SIZE 1
/* Bitfields in TSR */ -#define MACB_UBR_OFFSET 0 -#define MACB_UBR_SIZE 1 -#define MACB_COL_OFFSET 1 -#define MACB_COL_SIZE 1 -#define MACB_TSR_RLE_OFFSET 2 -#define MACB_TSR_RLE_SIZE 1 -#define MACB_TGO_OFFSET 3 -#define MACB_TGO_SIZE 1 -#define MACB_BEX_OFFSET 4 -#define MACB_BEX_SIZE 1 -#define MACB_COMP_OFFSET 5 -#define MACB_COMP_SIZE 1 -#define MACB_UND_OFFSET 6 -#define MACB_UND_SIZE 1 +#define MACB_UBR_OFFSET 0 /* Used bit read */ +#define MACB_UBR_SIZE 1 +#define MACB_COL_OFFSET 1 /* Collision occurred */ +#define MACB_COL_SIZE 1 +#define MACB_TSR_RLE_OFFSET 2 /* Retry limit exceeded */ +#define MACB_TSR_RLE_SIZE 1 +#define MACB_TGO_OFFSET 3 /* Transmit go */ +#define MACB_TGO_SIZE 1 +#define MACB_BEX_OFFSET 4 /* TX frame corruption due to AHB error */ +#define MACB_BEX_SIZE 1 +#define MACB_RM9200_BNQ_OFFSET 4 /* AT91RM9200 only */ +#define MACB_RM9200_BNQ_SIZE 1 /* AT91RM9200 only */ +#define MACB_COMP_OFFSET 5 /* Trnasmit complete */ +#define MACB_COMP_SIZE 1 +#define MACB_UND_OFFSET 6 /* Trnasmit under run */ +#define MACB_UND_SIZE 1
/* Bitfields in RSR */ -#define MACB_BNA_OFFSET 0 -#define MACB_BNA_SIZE 1 -#define MACB_REC_OFFSET 1 -#define MACB_REC_SIZE 1 -#define MACB_OVR_OFFSET 2 -#define MACB_OVR_SIZE 1 +#define MACB_BNA_OFFSET 0 /* Buffer not available */ +#define MACB_BNA_SIZE 1 +#define MACB_REC_OFFSET 1 /* Frame received */ +#define MACB_REC_SIZE 1 +#define MACB_OVR_OFFSET 2 /* Receive overrun */ +#define MACB_OVR_SIZE 1
/* Bitfields in ISR/IER/IDR/IMR */ -#define MACB_MFD_OFFSET 0 -#define MACB_MFD_SIZE 1 -#define MACB_RCOMP_OFFSET 1 -#define MACB_RCOMP_SIZE 1 -#define MACB_RXUBR_OFFSET 2 -#define MACB_RXUBR_SIZE 1 -#define MACB_TXUBR_OFFSET 3 -#define MACB_TXUBR_SIZE 1 -#define MACB_ISR_TUND_OFFSET 4 -#define MACB_ISR_TUND_SIZE 1 -#define MACB_ISR_RLE_OFFSET 5 -#define MACB_ISR_RLE_SIZE 1 -#define MACB_TXERR_OFFSET 6 -#define MACB_TXERR_SIZE 1 -#define MACB_TCOMP_OFFSET 7 -#define MACB_TCOMP_SIZE 1 -#define MACB_ISR_LINK_OFFSET 9 -#define MACB_ISR_LINK_SIZE 1 -#define MACB_ISR_ROVR_OFFSET 10 -#define MACB_ISR_ROVR_SIZE 1 -#define MACB_HRESP_OFFSET 11 -#define MACB_HRESP_SIZE 1 -#define MACB_PFR_OFFSET 12 -#define MACB_PFR_SIZE 1 -#define MACB_PTZ_OFFSET 13 -#define MACB_PTZ_SIZE 1 +#define MACB_MFD_OFFSET 0 /* Management frame sent */ +#define MACB_MFD_SIZE 1 +#define MACB_RCOMP_OFFSET 1 /* Receive complete */ +#define MACB_RCOMP_SIZE 1 +#define MACB_RXUBR_OFFSET 2 /* RX used bit read */ +#define MACB_RXUBR_SIZE 1 +#define MACB_TXUBR_OFFSET 3 /* TX used bit read */ +#define MACB_TXUBR_SIZE 1 +#define MACB_ISR_TUND_OFFSET 4 /* Enable TX buffer under run interrupt */ +#define MACB_ISR_TUND_SIZE 1 +#define MACB_ISR_RLE_OFFSET 5 /* EN retry exceeded/late coll interrupt */ +#define MACB_ISR_RLE_SIZE 1 +#define MACB_TXERR_OFFSET 6 /* EN TX frame corrupt from error interrupt */ +#define MACB_TXERR_SIZE 1 +#define MACB_TCOMP_OFFSET 7 /* Enable transmit complete interrupt */ +#define MACB_TCOMP_SIZE 1 +#define MACB_ISR_LINK_OFFSET 9 /* Enable link change interrupt */ +#define MACB_ISR_LINK_SIZE 1 +#define MACB_ISR_ROVR_OFFSET 10 /* Enable receive overrun interrupt */ +#define MACB_ISR_ROVR_SIZE 1 +#define MACB_HRESP_OFFSET 11 /* Enable hrsep not OK interrupt */ +#define MACB_HRESP_SIZE 1 +#define MACB_PFR_OFFSET 12 /* Enable pause frame w/ quantum interrupt */ +#define MACB_PFR_SIZE 1 +#define MACB_PTZ_OFFSET 13 /* Enable pause time zero interrupt */ +#define MACB_PTZ_SIZE 1 +#define MACB_WOL_OFFSET 14 /* Enable wake-on-lan interrupt */ +#define MACB_WOL_SIZE 1 +#define MACB_DRQFR_OFFSET 18 /* PTP Delay Request Frame Received */ +#define MACB_DRQFR_SIZE 1 +#define MACB_SFR_OFFSET 19 /* PTP Sync Frame Received */ +#define MACB_SFR_SIZE 1 +#define MACB_DRQFT_OFFSET 20 /* PTP Delay Request Frame Transmitted */ +#define MACB_DRQFT_SIZE 1 +#define MACB_SFT_OFFSET 21 /* PTP Sync Frame Transmitted */ +#define MACB_SFT_SIZE 1 +#define MACB_PDRQFR_OFFSET 22 /* PDelay Request Frame Received */ +#define MACB_PDRQFR_SIZE 1 +#define MACB_PDRSFR_OFFSET 23 /* PDelay Response Frame Received */ +#define MACB_PDRSFR_SIZE 1 +#define MACB_PDRQFT_OFFSET 24 /* PDelay Request Frame Transmitted */ +#define MACB_PDRQFT_SIZE 1 +#define MACB_PDRSFT_OFFSET 25 /* PDelay Response Frame Transmitted */ +#define MACB_PDRSFT_SIZE 1 +#define MACB_SRI_OFFSET 26 /* TSU Seconds Register Increment */ +#define MACB_SRI_SIZE 1 + +/* Timer increment fields */ +#define MACB_TI_CNS_OFFSET 0 +#define MACB_TI_CNS_SIZE 8 +#define MACB_TI_ACNS_OFFSET 8 +#define MACB_TI_ACNS_SIZE 8 +#define MACB_TI_NIT_OFFSET 16 +#define MACB_TI_NIT_SIZE 8
/* Bitfields in MAN */ -#define MACB_DATA_OFFSET 0 -#define MACB_DATA_SIZE 16 -#define MACB_CODE_OFFSET 16 -#define MACB_CODE_SIZE 2 -#define MACB_REGA_OFFSET 18 -#define MACB_REGA_SIZE 5 -#define MACB_PHYA_OFFSET 23 -#define MACB_PHYA_SIZE 5 -#define MACB_RW_OFFSET 28 -#define MACB_RW_SIZE 2 -#define MACB_SOF_OFFSET 30 -#define MACB_SOF_SIZE 2 - -/* Bitfields in USRIO */ +#define MACB_DATA_OFFSET 0 /* data */ +#define MACB_DATA_SIZE 16 +#define MACB_CODE_OFFSET 16 /* Must be written to 10 */ +#define MACB_CODE_SIZE 2 +#define MACB_REGA_OFFSET 18 /* Register address */ +#define MACB_REGA_SIZE 5 +#define MACB_PHYA_OFFSET 23 /* PHY address */ +#define MACB_PHYA_SIZE 5 +#define MACB_RW_OFFSET 28 /* Operation. 10 is read. 01 is write. */ +#define MACB_RW_SIZE 2 +#define MACB_SOF_OFFSET 30 /* Must be written to 1 for Clause 22 */ +#define MACB_SOF_SIZE 2 + +/* Bitfields in USRIO (AVR32) */ #define MACB_MII_OFFSET 0 #define MACB_MII_SIZE 1 #define MACB_EAM_OFFSET 1 @@ -232,6 +421,8 @@ /* Bitfields in USRIO (AT91) */ #define MACB_RMII_OFFSET 0 #define MACB_RMII_SIZE 1 +#define GEM_RGMII_OFFSET 0 /* GEM gigabit mode */ +#define GEM_RGMII_SIZE 1 #define MACB_CLKEN_OFFSET 1 #define MACB_CLKEN_SIZE 1
@@ -249,17 +440,166 @@
/* Bitfields in MID */ #define MACB_IDNUM_OFFSET 16 -#define MACB_IDNUM_SIZE 16 +#define MACB_IDNUM_SIZE 12 +#define MACB_REV_OFFSET 0 +#define MACB_REV_SIZE 16
-/* Bitfields in DCFG1 */ +/* Bitfields in DCFG1. */ +#define GEM_IRQCOR_OFFSET 23 +#define GEM_IRQCOR_SIZE 1 #define GEM_DBWDEF_OFFSET 25 #define GEM_DBWDEF_SIZE 3
-/* constants for data bus width */ -#define GEM_DBW32 0 -#define GEM_DBW64 1 -#define GEM_DBW128 2 +/* Bitfields in DCFG2. */ +#define GEM_RX_PKT_BUFF_OFFSET 20 +#define GEM_RX_PKT_BUFF_SIZE 1 +#define GEM_TX_PKT_BUFF_OFFSET 21 +#define GEM_TX_PKT_BUFF_SIZE 1 + + +/* Bitfields in DCFG5. */ +#define GEM_TSU_OFFSET 8 +#define GEM_TSU_SIZE 1 + +/* Bitfields in DCFG6. */ +#define GEM_PBUF_LSO_OFFSET 27 +#define GEM_PBUF_LSO_SIZE 1 +#define GEM_DAW64_OFFSET 23 +#define GEM_DAW64_SIZE 1 + +/* Bitfields in DCFG8. */ +#define GEM_T1SCR_OFFSET 24 +#define GEM_T1SCR_SIZE 8 +#define GEM_T2SCR_OFFSET 16 +#define GEM_T2SCR_SIZE 8 +#define GEM_SCR2ETH_OFFSET 8 +#define GEM_SCR2ETH_SIZE 8 +#define GEM_SCR2CMP_OFFSET 0 +#define GEM_SCR2CMP_SIZE 8 + +/* Bitfields in DCFG10 */ +#define GEM_TXBD_RDBUFF_OFFSET 12 +#define GEM_TXBD_RDBUFF_SIZE 4 +#define GEM_RXBD_RDBUFF_OFFSET 8 +#define GEM_RXBD_RDBUFF_SIZE 4 + +/* Bitfields in TISUBN */ +#define GEM_SUBNSINCR_OFFSET 0 +#define GEM_SUBNSINCR_SIZE 16 + +/* Bitfields in TI */ +#define GEM_NSINCR_OFFSET 0 +#define GEM_NSINCR_SIZE 8 + +/* Bitfields in TSH */ +#define GEM_TSH_OFFSET 0 /* TSU timer value (s). MSB [47:32] of seconds timer count */ +#define GEM_TSH_SIZE 16 + +/* Bitfields in TSL */ +#define GEM_TSL_OFFSET 0 /* TSU timer value (s). LSB [31:0] of seconds timer count */ +#define GEM_TSL_SIZE 32
+/* Bitfields in TN */ +#define GEM_TN_OFFSET 0 /* TSU timer value (ns) */ +#define GEM_TN_SIZE 30 + +/* Bitfields in TXBDCTRL */ +#define GEM_TXTSMODE_OFFSET 4 /* TX Descriptor Timestamp Insertion mode */ +#define GEM_TXTSMODE_SIZE 2 + +/* Bitfields in RXBDCTRL */ +#define GEM_RXTSMODE_OFFSET 4 /* RX Descriptor Timestamp Insertion mode */ +#define GEM_RXTSMODE_SIZE 2 + +/* Bitfields in SCRT2 */ +#define GEM_QUEUE_OFFSET 0 /* Queue Number */ +#define GEM_QUEUE_SIZE 4 +#define GEM_VLANPR_OFFSET 4 /* VLAN Priority */ +#define GEM_VLANPR_SIZE 3 +#define GEM_VLANEN_OFFSET 8 /* VLAN Enable */ +#define GEM_VLANEN_SIZE 1 +#define GEM_ETHT2IDX_OFFSET 9 /* Index to screener type 2 EtherType register */ +#define GEM_ETHT2IDX_SIZE 3 +#define GEM_ETHTEN_OFFSET 12 /* EtherType Enable */ +#define GEM_ETHTEN_SIZE 1 +#define GEM_CMPA_OFFSET 13 /* Compare A - Index to screener type 2 Compare register */ +#define GEM_CMPA_SIZE 5 +#define GEM_CMPAEN_OFFSET 18 /* Compare A Enable */ +#define GEM_CMPAEN_SIZE 1 +#define GEM_CMPB_OFFSET 19 /* Compare B - Index to screener type 2 Compare register */ +#define GEM_CMPB_SIZE 5 +#define GEM_CMPBEN_OFFSET 24 /* Compare B Enable */ +#define GEM_CMPBEN_SIZE 1 +#define GEM_CMPC_OFFSET 25 /* Compare C - Index to screener type 2 Compare register */ +#define GEM_CMPC_SIZE 5 +#define GEM_CMPCEN_OFFSET 30 /* Compare C Enable */ +#define GEM_CMPCEN_SIZE 1 + +/* Bitfields in ETHT */ +#define GEM_ETHTCMP_OFFSET 0 /* EtherType compare value */ +#define GEM_ETHTCMP_SIZE 16 + +/* Bitfields in T2CMPW0 */ +#define GEM_T2CMP_OFFSET 16 /* 0xFFFF0000 compare value */ +#define GEM_T2CMP_SIZE 16 +#define GEM_T2MASK_OFFSET 0 /* 0x0000FFFF compare value or mask */ +#define GEM_T2MASK_SIZE 16 + +/* Bitfields in T2CMPW1 */ +#define GEM_T2DISMSK_OFFSET 9 /* disable mask */ +#define GEM_T2DISMSK_SIZE 1 +#define GEM_T2CMPOFST_OFFSET 7 /* compare offset */ +#define GEM_T2CMPOFST_SIZE 2 +#define GEM_T2OFST_OFFSET 0 /* offset value */ +#define GEM_T2OFST_SIZE 7 + +/* Offset for screener type 2 compare values (T2CMPOFST). + * Note the offset is applied after the specified point, + * e.g. GEM_T2COMPOFST_ETYPE denotes the EtherType field, so an offset + * of 12 bytes from this would be the source IP address in an IP header + */ +#define GEM_T2COMPOFST_SOF 0 +#define GEM_T2COMPOFST_ETYPE 1 +#define GEM_T2COMPOFST_IPHDR 2 +#define GEM_T2COMPOFST_TCPUDP 3 + +/* offset from EtherType to IP address */ +#define ETYPE_SRCIP_OFFSET 12 +#define ETYPE_DSTIP_OFFSET 16 + +/* offset from IP header to port */ +#define IPHDR_SRCPORT_OFFSET 0 +#define IPHDR_DSTPORT_OFFSET 2 + +/* Transmit DMA buffer descriptor Word 1 */ +#define GEM_DMA_TXVALID_OFFSET 23 /* timestamp has been captured in the Buffer Descriptor */ +#define GEM_DMA_TXVALID_SIZE 1 + +/* Receive DMA buffer descriptor Word 0 */ +#define GEM_DMA_RXVALID_OFFSET 2 /* indicates a valid timestamp in the Buffer Descriptor */ +#define GEM_DMA_RXVALID_SIZE 1 + +/* DMA buffer descriptor Word 2 (32 bit addressing) or Word 4 (64 bit addressing) */ +#define GEM_DMA_SECL_OFFSET 30 /* Timestamp seconds[1:0] */ +#define GEM_DMA_SECL_SIZE 2 +#define GEM_DMA_NSEC_OFFSET 0 /* Timestamp nanosecs [29:0] */ +#define GEM_DMA_NSEC_SIZE 30 + +/* DMA buffer descriptor Word 3 (32 bit addressing) or Word 5 (64 bit addressing) */ + +/* New hardware supports 12 bit precision of timestamp in DMA buffer descriptor. + * Old hardware supports only 6 bit precision but it is enough for PTP. + * Less accuracy is used always instead of checking hardware version. + */ +#define GEM_DMA_SECH_OFFSET 0 /* Timestamp seconds[5:2] */ +#define GEM_DMA_SECH_SIZE 4 +#define GEM_DMA_SEC_WIDTH (GEM_DMA_SECH_SIZE + GEM_DMA_SECL_SIZE) +#define GEM_DMA_SEC_TOP (1 << GEM_DMA_SEC_WIDTH) +#define GEM_DMA_SEC_MASK (GEM_DMA_SEC_TOP - 1) + +/* Bitfields in ADJ */ +#define GEM_ADDSUB_OFFSET 31 +#define GEM_ADDSUB_SIZE 1 /* Constants for CLK */ #define MACB_CLK_DIV8 0 #define MACB_CLK_DIV16 1 @@ -280,19 +620,38 @@ #define MACB_MAN_READ 2 #define MACB_MAN_CODE 2
+/* Capability mask bits */ +#define MACB_CAPS_ISR_CLEAR_ON_WRITE 0x00000001 +#define MACB_CAPS_USRIO_HAS_CLKEN 0x00000002 +#define MACB_CAPS_USRIO_DEFAULT_IS_MII_GMII 0x00000004 +#define MACB_CAPS_NO_GIGABIT_HALF 0x00000008 +#define MACB_CAPS_USRIO_DISABLED 0x00000010 +#define MACB_CAPS_JUMBO 0x00000020 +#define MACB_CAPS_GEM_HAS_PTP 0x00000040 +#define MACB_CAPS_BD_RD_PREFETCH 0x00000080 +#define MACB_CAPS_NEEDS_RSTONUBR 0x00000100 +#define MACB_CAPS_FIFO_MODE 0x10000000 +#define MACB_CAPS_GIGABIT_MODE_AVAILABLE 0x20000000 +#define MACB_CAPS_SG_DISABLED 0x40000000 +#define MACB_CAPS_MACB_IS_GEM 0x80000000 + +/* LSO settings */ +#define MACB_LSO_UFO_ENABLE 0x01 +#define MACB_LSO_TSO_ENABLE 0x02 + /* Bit manipulation macros */ #define MACB_BIT(name) \ (1 << MACB_##name##_OFFSET) -#define MACB_BF(name, value) \ +#define MACB_BF(name,value) \ (((value) & ((1 << MACB_##name##_SIZE) - 1)) \ << MACB_##name##_OFFSET) -#define MACB_BFEXT(name, value)\ +#define MACB_BFEXT(name,value)\ (((value) >> MACB_##name##_OFFSET) \ & ((1 << MACB_##name##_SIZE) - 1)) -#define MACB_BFINS(name, value, old) \ +#define MACB_BFINS(name,value,old) \ (((old) & ~(((1 << MACB_##name##_SIZE) - 1) \ << MACB_##name##_OFFSET)) \ - | MACB_BF(name, value)) + | MACB_BF(name,value))
#define GEM_BIT(name) \ (1 << GEM_##name##_OFFSET) @@ -316,6 +675,95 @@ readl((port)->regs + GEM_##reg) #define gem_writel(port, reg, value) \ writel((value), (port)->regs + GEM_##reg) + +/* DMA descriptor bitfields */ +#define MACB_RX_USED_OFFSET 0 +#define MACB_RX_USED_SIZE 1 +#define MACB_RX_WRAP_OFFSET 1 +#define MACB_RX_WRAP_SIZE 1 +#define MACB_RX_WADDR_OFFSET 2 +#define MACB_RX_WADDR_SIZE 30 + +#define MACB_RX_FRMLEN_OFFSET 0 +#define MACB_RX_FRMLEN_SIZE 12 +#define MACB_RX_OFFSET_OFFSET 12 +#define MACB_RX_OFFSET_SIZE 2 +#define MACB_RX_SOF_OFFSET 14 +#define MACB_RX_SOF_SIZE 1 +#define MACB_RX_EOF_OFFSET 15 +#define MACB_RX_EOF_SIZE 1 +#define MACB_RX_CFI_OFFSET 16 +#define MACB_RX_CFI_SIZE 1 +#define MACB_RX_VLAN_PRI_OFFSET 17 +#define MACB_RX_VLAN_PRI_SIZE 3 +#define MACB_RX_PRI_TAG_OFFSET 20 +#define MACB_RX_PRI_TAG_SIZE 1 +#define MACB_RX_VLAN_TAG_OFFSET 21 +#define MACB_RX_VLAN_TAG_SIZE 1 +#define MACB_RX_TYPEID_MATCH_OFFSET 22 +#define MACB_RX_TYPEID_MATCH_SIZE 1 +#define MACB_RX_SA4_MATCH_OFFSET 23 +#define MACB_RX_SA4_MATCH_SIZE 1 +#define MACB_RX_SA3_MATCH_OFFSET 24 +#define MACB_RX_SA3_MATCH_SIZE 1 +#define MACB_RX_SA2_MATCH_OFFSET 25 +#define MACB_RX_SA2_MATCH_SIZE 1 +#define MACB_RX_SA1_MATCH_OFFSET 26 +#define MACB_RX_SA1_MATCH_SIZE 1 +#define MACB_RX_EXT_MATCH_OFFSET 28 +#define MACB_RX_EXT_MATCH_SIZE 1 +#define MACB_RX_UHASH_MATCH_OFFSET 29 +#define MACB_RX_UHASH_MATCH_SIZE 1 +#define MACB_RX_MHASH_MATCH_OFFSET 30 +#define MACB_RX_MHASH_MATCH_SIZE 1 +#define MACB_RX_BROADCAST_OFFSET 31 +#define MACB_RX_BROADCAST_SIZE 1 + +#define MACB_RX_FRMLEN_MASK 0xFFF +#define MACB_RX_JFRMLEN_MASK 0x3FFF + +/* RX checksum offload disabled: bit 24 clear in NCFGR */ +#define GEM_RX_TYPEID_MATCH_OFFSET 22 +#define GEM_RX_TYPEID_MATCH_SIZE 2 + +/* RX checksum offload enabled: bit 24 set in NCFGR */ +#define GEM_RX_CSUM_OFFSET 22 +#define GEM_RX_CSUM_SIZE 2 + +#define MACB_TX_FRMLEN_OFFSET 0 +#define MACB_TX_FRMLEN_SIZE 11 +#define MACB_TX_LAST_OFFSET 15 +#define MACB_TX_LAST_SIZE 1 +#define MACB_TX_NOCRC_OFFSET 16 +#define MACB_TX_NOCRC_SIZE 1 +#define MACB_MSS_MFS_OFFSET 16 +#define MACB_MSS_MFS_SIZE 14 +#define MACB_TX_LSO_OFFSET 17 +#define MACB_TX_LSO_SIZE 2 +#define MACB_TX_TCP_SEQ_SRC_OFFSET 19 +#define MACB_TX_TCP_SEQ_SRC_SIZE 1 +#define MACB_TX_BUF_EXHAUSTED_OFFSET 27 +#define MACB_TX_BUF_EXHAUSTED_SIZE 1 +#define MACB_TX_UNDERRUN_OFFSET 28 +#define MACB_TX_UNDERRUN_SIZE 1 +#define MACB_TX_ERROR_OFFSET 29 +#define MACB_TX_ERROR_SIZE 1 +#define MACB_TX_WRAP_OFFSET 30 +#define MACB_TX_WRAP_SIZE 1 +#define MACB_TX_USED_OFFSET 31 +#define MACB_TX_USED_SIZE 1 + +#define GEM_TX_FRMLEN_OFFSET 0 +#define GEM_TX_FRMLEN_SIZE 14 + +/* Buffer descriptor constants */ +#define GEM_RX_CSUM_NONE 0 +#define GEM_RX_CSUM_IP_ONLY 1 +#define GEM_RX_CSUM_IP_TCP 2 +#define GEM_RX_CSUM_IP_UDP 3 + +/* limit RX checksum offload to TCP and UDP packets */ +#define GEM_RX_CSUM_CHECKED_MASK 2 #define gem_writel_queue_TBQP(port, value, queue_num) \ writel((value), (port)->regs + GEM_TBQP(queue_num))
add support for clock rates higher than 2.4Mhz
drivers/net/macb.c | 6 +++++- drivers/net/macb.h | 2 ++ 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 5858004858..6885da9c38 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -901,8 +901,12 @@ static u32 gem_mdc_clk_div(int id, struct macb_device *macb) config = GEM_BF(CLK, GEM_CLK_DIV48); else if (macb_hz < 160000000) config = GEM_BF(CLK, GEM_CLK_DIV64); - else + else if (macb_hz < 240000000) config = GEM_BF(CLK, GEM_CLK_DIV96); + else if (macb_hz < 320000000) + config = GEM_BF(CLK, GEM_CLK_DIV128); + else + config = GEM_BF(CLK, GEM_CLK_DIV224);
return config; } diff --git a/drivers/net/macb.h b/drivers/net/macb.h index 8966c793a7..9b16383eba 100644 --- a/drivers/net/macb.h +++ b/drivers/net/macb.h @@ -613,6 +613,8 @@ #define GEM_CLK_DIV48 3 #define GEM_CLK_DIV64 4 #define GEM_CLK_DIV96 5 +#define GEM_CLK_DIV128 6 +#define GEM_CLK_DIV224 7
/* Constants for MAN register */ #define MACB_MAN_SOF 1
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:49 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 2/6] net: macb: add support for faster clk rates
- else
else
return config;
2.21.0
Reviewed-by: Anup Patel anup.patel@wdc.com Tested-by: Anup Patel anup.patel@wdc.com
Regards, Anup
macb.h provides macros for reading/setting bitfields, in macb registers and descriptors. use that instead of redefining them in the source file.
drivers/net/macb.c | 48 +++++++++++++++------------------------------- 1 file changed, 15 insertions(+), 33 deletions(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 6885da9c38..d957afe21a 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -77,27 +77,8 @@ struct macb_dma_desc { #define MACB_RX_DMA_DESC_SIZE (DMA_DESC_BYTES(MACB_RX_RING_SIZE)) #define MACB_TX_DUMMY_DMA_DESC_SIZE (DMA_DESC_BYTES(1))
-#define RXADDR_USED 0x00000001 -#define RXADDR_WRAP 0x00000002 - #define RXBUF_FRMLEN_MASK 0x00000fff -#define RXBUF_FRAME_START 0x00004000 -#define RXBUF_FRAME_END 0x00008000 -#define RXBUF_TYPEID_MATCH 0x00400000 -#define RXBUF_ADDR4_MATCH 0x00800000 -#define RXBUF_ADDR3_MATCH 0x01000000 -#define RXBUF_ADDR2_MATCH 0x02000000 -#define RXBUF_ADDR1_MATCH 0x04000000 -#define RXBUF_BROADCAST 0x80000000 - #define TXBUF_FRMLEN_MASK 0x000007ff -#define TXBUF_FRAME_END 0x00008000 -#define TXBUF_NOCRC 0x00010000 -#define TXBUF_EXHAUSTED 0x08000000 -#define TXBUF_UNDERRUN 0x10000000 -#define TXBUF_MAXRETRY 0x20000000 -#define TXBUF_WRAP 0x40000000 -#define TXBUF_USED 0x80000000
struct macb_device { void *regs; @@ -316,9 +297,9 @@ static int _macb_send(struct macb_device *macb, const char *name, void *packet, paddr = dma_map_single(packet, length, DMA_TO_DEVICE);
ctrl = length & TXBUF_FRMLEN_MASK; - ctrl |= TXBUF_FRAME_END; + ctrl |= MACB_BIT(TX_LAST); if (tx_head == (MACB_TX_RING_SIZE - 1)) { - ctrl |= TXBUF_WRAP; + ctrl |= MACB_BIT(TX_WRAP); macb->tx_head = 0; } else { macb->tx_head++; @@ -340,7 +321,7 @@ static int _macb_send(struct macb_device *macb, const char *name, void *packet, barrier(); macb_invalidate_ring_desc(macb, TX); ctrl = macb->tx_ring[tx_head].ctrl; - if (ctrl & TXBUF_USED) + if (ctrl & MACB_BIT(TX_USED)) break; udelay(1); } @@ -348,9 +329,9 @@ static int _macb_send(struct macb_device *macb, const char *name, void *packet, dma_unmap_single(packet, length, paddr);
if (i <= MACB_TX_TIMEOUT) { - if (ctrl & TXBUF_UNDERRUN) + if (ctrl & MACB_BIT(TX_UNDERRUN)) printf("%s: TX underrun\n", name); - if (ctrl & TXBUF_EXHAUSTED) + if (ctrl & MACB_BIT(TX_BUF_EXHAUSTED)) printf("%s: TX buffers exhausted in mid frame\n", name); } else { printf("%s: TX timeout\n", name); @@ -369,14 +350,14 @@ static void reclaim_rx_buffers(struct macb_device *macb,
macb_invalidate_ring_desc(macb, RX); while (i > new_tail) { - macb->rx_ring[i].addr &= ~RXADDR_USED; + macb->rx_ring[i].addr &= ~MACB_BIT(RX_USED); i++; if (i > MACB_RX_RING_SIZE) i = 0; }
while (i < new_tail) { - macb->rx_ring[i].addr &= ~RXADDR_USED; + macb->rx_ring[i].addr &= ~MACB_BIT(RX_USED); i++; }
@@ -396,17 +377,17 @@ static int _macb_recv(struct macb_device *macb, uchar **packetp) for (;;) { macb_invalidate_ring_desc(macb, RX);
- if (!(macb->rx_ring[next_rx_tail].addr & RXADDR_USED)) + if (!(macb->rx_ring[next_rx_tail].addr & MACB_BIT(RX_USED))) return -EAGAIN;
status = macb->rx_ring[next_rx_tail].ctrl; - if (status & RXBUF_FRAME_START) { + if (status & MACB_BIT(RX_SOF)) { if (next_rx_tail != macb->rx_tail) reclaim_rx_buffers(macb, next_rx_tail); macb->wrapped = false; }
- if (status & RXBUF_FRAME_END) { + if (status & MACB_BIT(RX_EOF)) { buffer = macb->rx_buffer + 128 * macb->rx_tail; length = status & RXBUF_FRMLEN_MASK;
@@ -697,7 +678,7 @@ static int gmac_init_multi_queues(struct macb_device *macb) if (queue_mask & (1 << i)) num_queues++;
- macb->dummy_desc->ctrl = TXBUF_USED; + macb->dummy_desc->ctrl = MACB_BIT(TX_USED); macb->dummy_desc->addr = 0; flush_dcache_range(macb->dummy_desc_dma, macb->dummy_desc_dma + ALIGN(MACB_TX_DUMMY_DMA_DESC_SIZE, PKTALIGN)); @@ -730,7 +711,7 @@ static int _macb_init(struct macb_device *macb, const char *name) paddr = macb->rx_buffer_dma; for (i = 0; i < MACB_RX_RING_SIZE; i++) { if (i == (MACB_RX_RING_SIZE - 1)) - paddr |= RXADDR_WRAP; + paddr |= MACB_BIT(RX_WRAP); macb->rx_ring[i].addr = paddr; macb->rx_ring[i].ctrl = 0; paddr += 128; @@ -741,9 +722,10 @@ static int _macb_init(struct macb_device *macb, const char *name) for (i = 0; i < MACB_TX_RING_SIZE; i++) { macb->tx_ring[i].addr = 0; if (i == (MACB_TX_RING_SIZE - 1)) - macb->tx_ring[i].ctrl = TXBUF_USED | TXBUF_WRAP; + macb->tx_ring[i].ctrl = MACB_BIT(TX_USED) | + MACB_BIT(TX_WRAP); else - macb->tx_ring[i].ctrl = TXBUF_USED; + macb->tx_ring[i].ctrl = MACB_BIT(TX_USED); } macb_flush_ring_desc(macb, TX);
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:49 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 3/6] net: macb: use bit access macro from header file
- ctrl |= MACB_BIT(TX_LAST); if (tx_head == (MACB_TX_RING_SIZE - 1)) {
ctrl |= TXBUF_WRAP;
macb->tx_head = 0; } else { macb->tx_head++;ctrl |= MACB_BIT(TX_WRAP);
udelay(1); }if (ctrl & MACB_BIT(TX_USED)) break;
i++; }macb->rx_ring[i].addr &= ~MACB_BIT(RX_USED);
}if (status & MACB_BIT(RX_SOF)) { if (next_rx_tail != macb->rx_tail) reclaim_rx_buffers(macb, next_rx_tail); macb->wrapped = false;
- macb->dummy_desc->ctrl = MACB_BIT(TX_USED); macb->dummy_desc->addr = 0; flush_dcache_range(macb->dummy_desc_dma, macb-
dummy_desc_dma +
macb->rx_ring[i].addr = paddr; macb->rx_ring[i].ctrl = 0; paddr += 128;paddr |= MACB_BIT(RX_WRAP);
elseMACB_BIT(TX_WRAP);
} macb_flush_ring_desc(macb, TX);macb->tx_ring[i].ctrl = MACB_BIT(TX_USED);
-- 2.21.0
Regards, Anup
This patch adds support for the sgmii phy interface, available only to DM users, dictated by current driver design.
drivers/net/macb.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index d957afe21a..ae8937bbb1 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -757,6 +757,13 @@ static int _macb_init(struct macb_device *macb, const char *name) gem_writel(macb, USRIO, GEM_BIT(RGMII)); else gem_writel(macb, USRIO, 0); + + if (macb->phy_interface == PHY_INTERFACE_MODE_SGMII) { + unsigned int ncfgr = macb_readl(macb, NCFGR); + + ncfgr |= GEM_BIT(SGMIIEN) | GEM_BIT(PCSSEL); + macb_writel(macb, NCFGR, ncfgr); + } #else #if defined(CONFIG_RGMII) || defined(CONFIG_RMII) gem_writel(macb, UR, GEM_BIT(RGMII));
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:49 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 4/6] net: macb: add support for SGMII phy interface
#else #if defined(CONFIG_RGMII) || defined(CONFIG_RMII) gem_writel(macb, UR, GEM_BIT(RGMII)); -- 2.21.0
Regards, Anup
GEM support higher DMA burst writes/reads than the default (4). add configuration structure with dma burst length so it could be applied later to DMA configuration.
drivers/net/macb.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index ae8937bbb1..fb42172520 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -82,6 +82,7 @@ struct macb_dma_desc {
struct macb_device { void *regs; + unsigned int dma_burst_length;
unsigned int rx_tail; unsigned int tx_head; @@ -118,6 +119,11 @@ struct macb_device { phy_interface_t phy_interface; #endif }; + +struct macb_config { + unsigned int dma_burst_length; +}; + #ifndef CONFIG_DM_ETH #define to_macb(_nd) container_of(_nd, struct macb_device, netdev) #endif @@ -1133,8 +1139,13 @@ static int macb_enable_clk(struct udevice *dev) } #endif
+static const struct macb_config default_gem_config = { + .dma_burst_length = 16, +}; + static int macb_eth_probe(struct udevice *dev) { + const struct macb_config *macb_config; struct eth_pdata *pdata = dev_get_platdata(dev); struct macb_device *macb = dev_get_priv(dev); const char *phy_mode; @@ -1151,6 +1162,11 @@ static int macb_eth_probe(struct udevice *dev)
macb->regs = (void *)pdata->iobase;
+ macb_config = (struct macb_config *)dev_get_driver_data(dev); + if (!macb_config) + macb_config = &default_gem_config; + + macb->dma_burst_length = macb_config->dma_burst_length; #ifdef CONFIG_CLK ret = macb_enable_clk(dev); if (ret) @@ -1211,12 +1227,16 @@ static int macb_eth_ofdata_to_platdata(struct udevice *dev) return macb_late_eth_ofdata_to_platdata(dev); }
+static const struct macb_config sama5d4_config = { + .dma_burst_length = 4, +}; + static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,macb" }, { .compatible = "cdns,at91sam9260-macb" }, { .compatible = "atmel,sama5d2-gem" }, { .compatible = "atmel,sama5d3-gem" }, - { .compatible = "atmel,sama5d4-gem" }, + { .compatible = "atmel,sama5d4-gem", .data = (ulong)&sama5d4_config }, { .compatible = "cdns,zynq-gem" }, { } };
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:49 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 5/6] net: macb: add dma_burst_length config
- unsigned int dma_burst_length;
- .dma_burst_length = 16,
- const struct macb_config *macb_config; struct eth_pdata *pdata = dev_get_platdata(dev); struct macb_device *macb = dev_get_priv(dev); const char *phy_mode;
- macb_config = (struct macb_config *)dev_get_driver_data(dev);
- if (!macb_config)
- macb->dma_burst_length = macb_config->dma_burst_length;
- .dma_burst_length = 4,
- { .compatible = "atmel,sama5d4-gem", .data =
(ulong)&sama5d4_config }, { .compatible = "cdns,zynq-gem" }, { } }; -- 2.21.0
Regards, Anup
DMA configuration was heavily dependent on the HW defaults, add function to properly set the required fields, including the new dma_burst_length.
drivers/net/macb.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index fb42172520..c072f99d8f 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -47,6 +47,7 @@ DECLARE_GLOBAL_DATA_PTR;
#define MACB_RX_BUFFER_SIZE 4096 #define MACB_RX_RING_SIZE (MACB_RX_BUFFER_SIZE / 128) +#define RX_BUFFER_MULTIPLE 64 #define MACB_TX_RING_SIZE 16 #define MACB_TX_TIMEOUT 1000 #define MACB_AUTONEG_TIMEOUT 5000000 @@ -695,6 +696,31 @@ static int gmac_init_multi_queues(struct macb_device *macb) return 0; }
+static void gmac_configure_dma(struct macb_device *macb) +{ + u32 buffer_size; + u32 dmacfg; + + buffer_size = 128 / RX_BUFFER_MULTIPLE; + dmacfg = gem_readl(macb, DMACFG) & ~GEM_BF(RXBS, -1L); + dmacfg |= GEM_BF(RXBS, buffer_size); + + if (macb->dma_burst_length) + dmacfg = GEM_BFINS(FBLDO, macb->dma_burst_length, dmacfg); + + dmacfg |= GEM_BIT(TXPBMS) | GEM_BF(RXBMS, -1L); + dmacfg &= ~GEM_BIT(ENDIA_PKT); + +#ifdef CONFIG_SYS_LITTLE_ENDIAN + dmacfg &= ~GEM_BIT(ENDIA_DESC); +#else + dmacfg |= GEM_BIT(ENDIA_DESC); /* CPU in big endian */ +#endif + + dmacfg &= ~GEM_BIT(ADDR64); + gem_writel(macb, DMACFG, dmacfg); +} + #ifdef CONFIG_DM_ETH static int _macb_init(struct udevice *dev, const char *name) #else @@ -748,6 +774,8 @@ static int _macb_init(struct macb_device *macb, const char *name) macb_writel(macb, TBQP, macb->tx_ring_dma);
if (macb_is_gem(macb)) { + /* Initialize DMA properties */ + gmac_configure_dma(macb); /* Check the multi queue and initialize the queue for tx */ gmac_init_multi_queues(macb);
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:50 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 6/6] net: macb: apply sane DMA configuration
+static void gmac_configure_dma(struct macb_device *macb) {
- u32 buffer_size;
- u32 dmacfg;
- buffer_size = 128 / RX_BUFFER_MULTIPLE;
- dmacfg = gem_readl(macb, DMACFG) & ~GEM_BF(RXBS, -1L);
- dmacfg |= GEM_BF(RXBS, buffer_size);
- if (macb->dma_burst_length)
dmacfg);
- dmacfg |= GEM_BIT(TXPBMS) | GEM_BF(RXBMS, -1L);
- dmacfg &= ~GEM_BIT(ENDIA_PKT);
+#else
#endif
- dmacfg &= ~GEM_BIT(ADDR64);
- gem_writel(macb, DMACFG, dmacfg);
#ifdef CONFIG_DM_ETH static int _macb_init(struct udevice *dev, const char *name) #else @@ - 748,6 +774,8 @@ static int _macb_init(struct macb_device *macb, const char *name) macb_writel(macb, TBQP, macb->tx_ring_dma);
/* Check the multi queue and initialize the queue for tx */ gmac_init_multi_queues(macb);gmac_configure_dma(macb);
-- 2.21.0
Regards, Anup
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Ramon Fried Sent: Tuesday, June 11, 2019 8:49 PM To: u-boot@lists.denx.de Cc: Joe Hershberger joe.hershberger@ni.com Subject: [U-Boot] [PATCH 1/6] net: macb: sync header definitions as taken from Linux
elsegem_writel(macb, USRIO, GEM_BIT(RGMII));
+/* GEM register offsets. */ +#define GEM_NCFGR 0x0004 /* Network Config */ +#define GEM_USRIO 0x000c /* User IO */ +#define GEM_DMACFG 0x0010 /* DMA Configuration */ +#define GEM_JML 0x0048 /* Jumbo Max Length */ +#define GEM_HRB 0x0080 /* Hash Bottom */ +#define GEM_HRT 0x0084 /* Hash Top */ +#define GEM_SA1B 0x0088 /* Specific1 Bottom */ +#define GEM_SA1T 0x008C /* Specific1 Top */ +#define GEM_SA2B 0x0090 /* Specific2 Bottom */ +#define GEM_SA2T 0x0094 /* Specific2 Top */ +#define GEM_SA3B 0x0098 /* Specific3 Bottom */ +#define GEM_SA3T 0x009C /* Specific3 Top */ +#define GEM_SA4B 0x00A0 /* Specific4 Bottom */ +#define GEM_SA4T 0x00A4 /* Specific4 Top */ +#define GEM_EFTSH 0x00e8 /* PTP Event Frame Transmitted Seconds Register 47:32 */ +#define GEM_EFRSH 0x00ec /* PTP Event Frame Received Seconds Register 47:32 */ +#define GEM_PEFTSH 0x00f0 /* PTP Peer Event Frame Transmitted Seconds Register 47:32 */ +#define GEM_PEFRSH 0x00f4 /* PTP Peer Event Frame Received Seconds Register 47:32 */ +#define GEM_OTX 0x0100 /* Octets transmitted */ +#define GEM_OCTTXL 0x0100 /* Octets transmitted [31:0] */ +#define GEM_OCTTXH 0x0104 /* Octets transmitted [47:32] */ +#define GEM_TXCNT 0x0108 /* Frames Transmitted counter */ +#define GEM_TXBCCNT 0x010c /* Broadcast Frames counter */ +#define GEM_TXMCCNT 0x0110 /* Multicast Frames counter */ +#define GEM_TXPAUSECNT 0x0114 /* Pause Frames Transmitted Counter */ +#define GEM_TX64CNT 0x0118 /* 64 byte Frames TX counter */ +#define GEM_TX65CNT 0x011c /* 65-127 byte Frames TX counter */ +#define GEM_TX128CNT 0x0120 /* 128-255 byte Frames TX counter */ +#define GEM_TX256CNT 0x0124 /* 256-511 byte Frames TX counter */ +#define GEM_TX512CNT 0x0128 /* 512-1023 byte Frames TX counter */ +#define GEM_TX1024CNT 0x012c /* 1024-1518 byte Frames TX counter */ +#define GEM_TX1519CNT 0x0130 /* 1519+ byte Frames TX counter */ +#define GEM_TXURUNCNT 0x0134 /* TX under run error counter */ +#define GEM_SNGLCOLLCNT 0x0138 /* Single Collision Frame Counter */ +#define GEM_MULTICOLLCNT 0x013c /* Multiple Collision Frame Counter */ +#define GEM_EXCESSCOLLCNT 0x0140 /* Excessive Collision Frame Counter */ +#define GEM_LATECOLLCNT 0x0144 /* Late Collision Frame Counter */ +#define GEM_TXDEFERCNT 0x0148 /* Deferred Transmission Frame Counter */ +#define GEM_TXCSENSECNT 0x014c /* Carrier Sense Error Counter */ +#define GEM_ORX 0x0150 /* Octets received */ +#define GEM_OCTRXL 0x0150 /* Octets received [31:0] */ +#define GEM_OCTRXH 0x0154 /* Octets received [47:32] */ +#define GEM_RXCNT 0x0158 /* Frames Received Counter */ +#define GEM_RXBROADCNT 0x015c /* Broadcast Frames Received Counter */ +#define GEM_RXMULTICNT 0x0160 /* Multicast Frames Received Counter */ +#define GEM_RXPAUSECNT 0x0164 /* Pause Frames Received Counter */ +#define GEM_RX64CNT 0x0168 /* 64 byte Frames RX Counter */ +#define GEM_RX65CNT 0x016c /* 65-127 byte Frames RX Counter */ +#define GEM_RX128CNT 0x0170 /* 128-255 byte Frames RX Counter */ +#define GEM_RX256CNT 0x0174 /* 256-511 byte Frames RX Counter */ +#define GEM_RX512CNT 0x0178 /* 512-1023 byte Frames RX Counter */ +#define GEM_RX1024CNT 0x017c /* 1024-1518 byte Frames RX Counter */ +#define GEM_RX1519CNT 0x0180 /* 1519+ byte Frames RX Counter */ +#define GEM_RXUNDRCNT 0x0184 /* Undersize Frames Received Counter */ +#define GEM_RXOVRCNT 0x0188 /* Oversize Frames Received Counter */ +#define GEM_RXJABCNT 0x018c /* Jabbers Received Counter */ +#define GEM_RXFCSCNT 0x0190 /* Frame Check Sequence Error Counter */ +#define GEM_RXLENGTHCNT 0x0194 /* Length Field Error Counter */ +#define GEM_RXSYMBCNT 0x0198 /* Symbol Error Counter */ +#define GEM_RXALIGNCNT 0x019c /* Alignment Error Counter */ +#define GEM_RXRESERRCNT 0x01a0 /* Receive Resource Error Counter */ +#define GEM_RXORCNT 0x01a4 /* Receive Overrun Counter */ +#define GEM_RXIPCCNT 0x01a8 /* IP header Checksum Error Counter */ +#define GEM_RXTCPCCNT 0x01ac /* TCP Checksum Error Counter */ +#define GEM_RXUDPCCNT 0x01b0 /* UDP Checksum Error Counter */ +#define GEM_TISUBN 0x01bc /* 1588 Timer Increment Sub- ns */ +#define GEM_TSH 0x01c0 /* 1588 Timer Seconds High */ +#define GEM_TSL 0x01d0 /* 1588 Timer Seconds Low */ +#define GEM_TN 0x01d4 /* 1588 Timer Nanoseconds */ +#define GEM_TA 0x01d8 /* 1588 Timer Adjust */ +#define GEM_TI 0x01dc /* 1588 Timer Increment */ +#define GEM_EFTSL 0x01e0 /* PTP Event Frame Tx Seconds Low */ +#define GEM_EFTN 0x01e4 /* PTP Event Frame Tx Nanoseconds */ +#define GEM_EFRSL 0x01e8 /* PTP Event Frame Rx Seconds Low */ +#define GEM_EFRN 0x01ec /* PTP Event Frame Rx Nanoseconds */ +#define GEM_PEFTSL 0x01f0 /* PTP Peer Event Frame Tx Secs Low */ +#define GEM_PEFTN 0x01f4 /* PTP Peer Event Frame Tx Ns */ +#define GEM_PEFRSL 0x01f8 /* PTP Peer Event Frame Rx Sec Low */ +#define GEM_PEFRN 0x01fc /* PTP Peer Event Frame Rx Ns */ +#define GEM_DCFG1 0x0280 /* Design Config 1 */ +#define GEM_DCFG2 0x0284 /* Design Config 2 */ +#define GEM_DCFG3 0x0288 /* Design Config 3 */ +#define GEM_DCFG4 0x028c /* Design Config 4 */ +#define GEM_DCFG5 0x0290 /* Design Config 5 */ +#define GEM_DCFG6 0x0294 /* Design Config 6 */ +#define GEM_DCFG7 0x0298 /* Design Config 7 */ +#define GEM_DCFG8 0x029C /* Design Config 8 */ +#define GEM_DCFG10 0x02A4 /* Design Config 10 */
- each location requires 3 compare regs */
- Note the offset is applied after the specified point,
- e.g. GEM_T2COMPOFST_ETYPE denotes the EtherType field, so an offset
- of 12 bytes from this would be the source IP address in an IP header
+*/ +#define GEM_T2COMPOFST_SOF 0 +#define GEM_T2COMPOFST_ETYPE 1 +#define GEM_T2COMPOFST_IPHDR 2 +#define GEM_T2COMPOFST_TCPUDP 3
+/* DMA buffer descriptor Word 3 (32 bit addressing) or Word 5 (64 bit +addressing) */
- Old hardware supports only 6 bit precision but it is enough for PTP.
- Less accuracy is used always instead of checking hardware version.
-- 2.21.0
Regards, Anup
This is breaking the build. "UR" is still referred to in drivers/net/macb.c line 805.
Did you build test this?
On Mon, Jul 15, 2019 at 9:31 PM Joe Hershberger joe.hershberger@ni.com wrote:
Well of course, but apparently I screwed this one in rebasing, prior to submit. Didn't run buildman afterwards. sorry. Will issue a revised patchset. Sorry. Ramon.
Actually, now that I look at this. it looks fine. the patch replaces the line you mentioned: https://patchwork.ozlabs.org/patch/1114041/ Can take a look ?
It addresses some of them, but not the ones a few lines below.
On Mon, Jul 15, 2019 at 11:48 PM Joe Hershberger joe.hershberger@ni.com wrote:
Just cherry-picked to a brand new master branch. there are no UR left on the file and it compiles correctly. Did you apply something else beforehand ?
One of them is even in the context of this patch...
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ This right here, and another a few lines later.
On Tue, Jul 16, 2019 at 9:42 PM Joe Hershberger joe.hershberger@ni.com wrote:
On Tue, Jun 11, 2019 at 10:51 AM Ramon Fried rfried.dev@gmail.com wrote: > > Few registers and bits were added by Cadence and > they were not updated in the headers. > Take the latest definitions as defined in Linux > header (5.1) that also includes some comments > about existing registers. > > One register was improperly named (UR), fix that.
- gem_writel(macb, USRIO, 0);
Face palm I tested with SGMII, that's why it worked on my setup. I'll fix it shortly, sorry for the trouble :) Thanks, Ramon.
Anup Patel
Joe Hershberger
Ramon Fried
