[U-Boot] [RESEND PATCH v2 0/2] ti_qspi: Move to spi-mem framework
Now that SPI NOR Supports MMIO SPI controllers via spi-mem framework, move TI QSPI to SPI MEM framework for better performance and avoid repeating SPI NOR generic code in the driver.
While at that get rid of non DM code, as all boards are expected to support DM and DT by now.
Tested on AM43xx, dra7xx EVMs. Build tested for all TI platforms using buildman
v2 * Rebase on top of latest master and Uri's patch [1] removing cl-som-am57x_defconfig * Remove more un-needed CONFIGs related to TI QSPI that have not been * Collect Reviewed-bys
[1] http://patchwork.ozlabs.org/patch/1085281/
Vignesh Raghavendra (2): spi: ti_qspi: Drop non DM code spi: ti_qspi: Convert to spi-mem ops
drivers/spi/Kconfig | 13 +- drivers/spi/Makefile | 2 +- drivers/spi/ti_qspi.c | 351 ++++++++++------------------------- include/configs/am43xx_evm.h | 6 - include/configs/am57xx_evm.h | 5 - include/configs/cm_t43.h | 3 - include/configs/dra7xx_evm.h | 5 - scripts/config_whitelist.txt | 3 - 8 files changed, 108 insertions(+), 280 deletions(-)
Now that all boards using TI QSPI have moved to DM and DT, drop non DM code completely.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 13 +- drivers/spi/Makefile | 2 +- drivers/spi/ti_qspi.c | 231 ++++++----------------------------- include/configs/am43xx_evm.h | 6 - include/configs/am57xx_evm.h | 5 - include/configs/cm_t43.h | 3 - include/configs/dra7xx_evm.h | 5 - scripts/config_whitelist.txt | 3 - 8 files changed, 46 insertions(+), 222 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 098372e09324..2bf244f94169 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -260,6 +260,13 @@ config TEGRA210_QSPI be used to access SPI chips on platforms embedding this NVIDIA Tegra210 IP core.
+config TI_QSPI + bool "TI QSPI driver" + imply TI_EDMA3 + help + Enable the TI Quad-SPI (QSPI) driver for DRA7xx and AM43xx evms. + This driver support spi flash single, quad and memory reads. + config XILINX_SPI bool "Xilinx SPI driver" help @@ -347,12 +354,6 @@ config SH_QSPI Enable the Renesas Quad SPI controller driver. This driver can be used on Renesas SoCs.
-config TI_QSPI - bool "TI QSPI driver" - help - Enable the TI Quad-SPI (QSPI) driver for DRA7xx and AM43xx evms. - This driver support spi flash single, quad and memory reads. - config KIRKWOOD_SPI bool "Marvell Kirkwood SPI Driver" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 01907bef7950..8be9a4baa244 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -9,6 +9,7 @@ obj-y += spi-uclass.o obj-$(CONFIG_SANDBOX) += spi-emul-uclass.o obj-$(CONFIG_SOFT_SPI) += soft_spi.o obj-$(CONFIG_SPI_MEM) += spi-mem.o +obj-$(CONFIG_TI_QSPI) += ti_qspi.o else obj-y += spi.o obj-$(CONFIG_SPI_MEM) += spi-mem-nodm.o @@ -56,7 +57,6 @@ obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o obj-$(CONFIG_TEGRA210_QSPI) += tegra210_qspi.o -obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o obj-$(CONFIG_ZYNQ_QSPI) += zynq_qspi.o diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 2dcce66de048..731fb23022d2 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -52,9 +52,6 @@ DECLARE_GLOBAL_DATA_PTR; #define MM_SWITCH 0x01 #define MEM_CS(cs) ((cs + 1) << 8) #define MEM_CS_UNSELECT 0xfffff8ff -#define MMAP_START_ADDR_DRA 0x5c000000 -#define MMAP_START_ADDR_AM43x 0x30000000 -#define CORE_CTRL_IO 0x4a002558
#define QSPI_CMD_READ (0x3 << 0) #define QSPI_CMD_READ_DUAL (0x6b << 0) @@ -98,13 +95,9 @@ struct ti_qspi_regs {
/* ti qspi priv */ struct ti_qspi_priv { -#ifndef CONFIG_DM_SPI - struct spi_slave slave; -#else void *memory_map; uint max_hz; u32 num_cs; -#endif struct ti_qspi_regs *base; void *ctrl_mod_mmap; ulong fclk; @@ -113,8 +106,9 @@ struct ti_qspi_priv { u32 dc; };
-static void ti_spi_set_speed(struct ti_qspi_priv *priv, uint hz) +static int ti_qspi_set_speed(struct udevice *bus, uint hz) { + struct ti_qspi_priv *priv = dev_get_priv(bus); uint clk_div;
if (!hz) @@ -133,6 +127,8 @@ static void ti_spi_set_speed(struct ti_qspi_priv *priv, uint hz) &priv->base->clk_ctrl); /* enable SCLK and program the clk divider */ writel(QSPI_CLK_EN | clk_div, &priv->base->clk_ctrl); + + return 0; }
static void ti_qspi_cs_deactivate(struct ti_qspi_priv *priv) @@ -142,38 +138,6 @@ static void ti_qspi_cs_deactivate(struct ti_qspi_priv *priv) readl(&priv->base->cmd); }
-static int __ti_qspi_set_mode(struct ti_qspi_priv *priv, unsigned int mode) -{ - priv->dc = 0; - if (mode & SPI_CPHA) - priv->dc |= QSPI_CKPHA(0); - if (mode & SPI_CPOL) - priv->dc |= QSPI_CKPOL(0); - if (mode & SPI_CS_HIGH) - priv->dc |= QSPI_CSPOL(0); - - return 0; -} - -static int __ti_qspi_claim_bus(struct ti_qspi_priv *priv, int cs) -{ - writel(priv->dc, &priv->base->dc); - writel(0, &priv->base->cmd); - writel(0, &priv->base->data); - - priv->dc <<= cs * 8; - writel(priv->dc, &priv->base->dc); - - return 0; -} - -static void __ti_qspi_release_bus(struct ti_qspi_priv *priv) -{ - writel(0, &priv->base->dc); - writel(0, &priv->base->cmd); - writel(0, &priv->base->data); -} - static void ti_qspi_ctrl_mode_mmap(void *ctrl_mod_mmap, int cs, bool enable) { u32 val; @@ -186,15 +150,26 @@ static void ti_qspi_ctrl_mode_mmap(void *ctrl_mod_mmap, int cs, bool enable) writel(val, ctrl_mod_mmap); }
-static int __ti_qspi_xfer(struct ti_qspi_priv *priv, unsigned int bitlen, - const void *dout, void *din, unsigned long flags, - u32 cs) +static int ti_qspi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) { + struct dm_spi_slave_platdata *slave = dev_get_parent_platdata(dev); + struct ti_qspi_priv *priv; + struct udevice *bus; uint words = bitlen >> 3; /* fixed 8-bit word length */ const uchar *txp = dout; uchar *rxp = din; uint status; int timeout; + unsigned int cs = slave->cs; + + bus = dev->parent; + priv = dev_get_priv(bus); + + if (cs > priv->num_cs) { + debug("invalid qspi chip select\n"); + return -EINVAL; + }
/* Setup mmap flags */ if (flags & SPI_XFER_MMAP) { @@ -316,126 +291,6 @@ void spi_flash_copy_mmap(void *data, void *offset, size_t len) } #endif
-#ifndef CONFIG_DM_SPI - -static inline struct ti_qspi_priv *to_ti_qspi_priv(struct spi_slave *slave) -{ - return container_of(slave, struct ti_qspi_priv, slave); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return 1; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* CS handled in xfer */ - return; -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - struct ti_qspi_priv *priv = to_ti_qspi_priv(slave); - ti_qspi_cs_deactivate(priv); -} - -void spi_init(void) -{ - /* nothing to do */ -} - -static void ti_spi_setup_spi_register(struct ti_qspi_priv *priv) -{ - u32 memval = 0; - -#ifdef CONFIG_QSPI_QUAD_SUPPORT - struct spi_slave *slave = &priv->slave; - memval |= (QSPI_CMD_READ_QUAD | QSPI_SETUP0_NUM_A_BYTES | - QSPI_SETUP0_NUM_D_BYTES_8_BITS | - QSPI_SETUP0_READ_QUAD | QSPI_CMD_WRITE | - QSPI_NUM_DUMMY_BITS); - slave->mode |= SPI_RX_QUAD; -#else - memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | - QSPI_SETUP0_NUM_D_BYTES_NO_BITS | - QSPI_SETUP0_READ_NORMAL | QSPI_CMD_WRITE | - QSPI_NUM_DUMMY_BITS; -#endif - - writel(memval, &priv->base->setup0); -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct ti_qspi_priv *priv; - -#ifdef CONFIG_AM43XX - gpio_request(CONFIG_QSPI_SEL_GPIO, "qspi_gpio"); - gpio_direction_output(CONFIG_QSPI_SEL_GPIO, 1); -#endif - - priv = spi_alloc_slave(struct ti_qspi_priv, bus, cs); - if (!priv) { - printf("SPI_error: Fail to allocate ti_qspi_priv\n"); - return NULL; - } - - priv->base = (struct ti_qspi_regs *)QSPI_BASE; - priv->mode = mode; -#if defined(CONFIG_DRA7XX) - priv->ctrl_mod_mmap = (void *)CORE_CTRL_IO; - priv->slave.memory_map = (void *)MMAP_START_ADDR_DRA; - priv->fclk = QSPI_DRA7XX_FCLK; -#else - priv->slave.memory_map = (void *)MMAP_START_ADDR_AM43x; - priv->fclk = QSPI_FCLK; -#endif - - ti_spi_set_speed(priv, max_hz); - -#ifdef CONFIG_TI_SPI_MMAP - ti_spi_setup_spi_register(priv); -#endif - - return &priv->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct ti_qspi_priv *priv = to_ti_qspi_priv(slave); - free(priv); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct ti_qspi_priv *priv = to_ti_qspi_priv(slave); - - debug("%s: bus:%i cs:%i\n", __func__, priv->slave.bus, priv->slave.cs); - __ti_qspi_set_mode(priv, priv->mode); - return __ti_qspi_claim_bus(priv, priv->slave.cs); -} -void spi_release_bus(struct spi_slave *slave) -{ - struct ti_qspi_priv *priv = to_ti_qspi_priv(slave); - - debug("%s: bus:%i cs:%i\n", __func__, priv->slave.bus, priv->slave.cs); - __ti_qspi_release_bus(priv); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, - void *din, unsigned long flags) -{ - struct ti_qspi_priv *priv = to_ti_qspi_priv(slave); - - debug("spi_xfer: bus:%i cs:%i bitlen:%i flags:%lx\n", - priv->slave.bus, priv->slave.cs, bitlen, flags); - return __ti_qspi_xfer(priv, bitlen, dout, din, flags, priv->slave.cs); -} - -#else /* CONFIG_DM_SPI */ - static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, struct spi_slave *slave, bool enable) @@ -472,22 +327,21 @@ static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, writel(memval, &priv->base->setup0); }
- -static int ti_qspi_set_speed(struct udevice *bus, uint max_hz) +static int ti_qspi_set_mode(struct udevice *bus, uint mode) { struct ti_qspi_priv *priv = dev_get_priv(bus);
- ti_spi_set_speed(priv, max_hz); + priv->dc = 0; + if (mode & SPI_CPHA) + priv->dc |= QSPI_CKPHA(0); + if (mode & SPI_CPOL) + priv->dc |= QSPI_CKPOL(0); + if (mode & SPI_CS_HIGH) + priv->dc |= QSPI_CSPOL(0);
return 0; }
-static int ti_qspi_set_mode(struct udevice *bus, uint mode) -{ - struct ti_qspi_priv *priv = dev_get_priv(bus); - return __ti_qspi_set_mode(priv, mode); -} - static int ti_qspi_claim_bus(struct udevice *dev) { struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); @@ -505,7 +359,14 @@ static int ti_qspi_claim_bus(struct udevice *dev)
__ti_qspi_setup_memorymap(priv, slave, true);
- return __ti_qspi_claim_bus(priv, slave_plat->cs); + writel(priv->dc, &priv->base->dc); + writel(0, &priv->base->cmd); + writel(0, &priv->base->data); + + priv->dc <<= slave_plat->cs * 8; + writel(priv->dc, &priv->base->dc); + + return 0; }
static int ti_qspi_release_bus(struct udevice *dev) @@ -518,27 +379,12 @@ static int ti_qspi_release_bus(struct udevice *dev) priv = dev_get_priv(bus);
__ti_qspi_setup_memorymap(priv, slave, false); - __ti_qspi_release_bus(priv); - - return 0; -}
-static int ti_qspi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct dm_spi_slave_platdata *slave = dev_get_parent_platdata(dev); - struct ti_qspi_priv *priv; - struct udevice *bus; - - bus = dev->parent; - priv = dev_get_priv(bus); - - if (slave->cs > priv->num_cs) { - debug("invalid qspi chip select\n"); - return -EINVAL; - } + writel(0, &priv->base->dc); + writel(0, &priv->base->cmd); + writel(0, &priv->base->data);
- return __ti_qspi_xfer(priv, bitlen, dout, din, flags, slave->cs); + return 0; }
static int ti_qspi_probe(struct udevice *bus) @@ -648,4 +494,3 @@ U_BOOT_DRIVER(ti_qspi) = { .probe = ti_qspi_probe, .child_pre_probe = ti_qspi_child_pre_probe, }; -#endif /* CONFIG_DM_SPI */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 5a6080645a85..37d058ebbc20 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -120,12 +120,6 @@ #define CONFIG_ENV_OFFSET_REDUND 0x120000 #endif
-/* SPI */ -#define CONFIG_TI_SPI_MMAP -#define CONFIG_QSPI_SEL_GPIO 48 -#define CONFIG_QSPI_QUAD_SUPPORT -#define CONFIG_TI_EDMA3 - #ifndef CONFIG_SPL_BUILD #include <environment/ti/dfu.h> #include <environment/ti/mmc.h> diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 48999847ee91..c14b010550fe 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -92,11 +92,6 @@ #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000
/* SPI SPL */ -#define CONFIG_TI_EDMA3 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000
-/* SPI */ -#define CONFIG_TI_SPI_MMAP -#define CONFIG_QSPI_QUAD_SUPPORT - #endif /* __CONFIG_AM57XX_EVM_H */ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index ffe4a44c869a..e4e37e5bbbf3 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -53,9 +53,6 @@ #define CONFIG_USB_XHCI_OMAP #define CONFIG_AM437X_USB2PHY2_HOST
-/* SPI Flash support */ -#define CONFIG_TI_SPI_MMAP - /* Power */ #define CONFIG_POWER #define CONFIG_POWER_I2C diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 10eac20aa0c8..d4e584533656 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -72,10 +72,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #define CONFIG_PHY_TI
-/* SPI */ -#define CONFIG_TI_SPI_MMAP -#define CONFIG_QSPI_QUAD_SUPPORT - /* * Default to using SPI for environment, etc. * 0x000000 - 0x040000 : QSPI.SPL (256KiB) @@ -98,7 +94,6 @@ #endif
#define CONFIG_SUPPORT_EMMC_BOOT diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8c7c1592a562..c5699ddffe1b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1555,8 +1555,6 @@ CONFIG_QE CONFIG_QEMU_MIPS CONFIG_QIXIS_I2C_ACCESS CONFIG_QSPI -CONFIG_QSPI_QUAD_SUPPORT -CONFIG_QSPI_SEL_GPIO CONFIG_QUOTA CONFIG_R7780MP CONFIG_R8A66597_BASE_ADDR @@ -4401,7 +4399,6 @@ CONFIG_TIMESTAMP CONFIG_TIZEN CONFIG_TI_KEYSTONE_SERDES CONFIG_TI_KSNAV -CONFIG_TI_SPI_MMAP CONFIG_TMU_TIMER CONFIG_TPL_PAD_TO CONFIG_TPM_TIS_BASE_ADDRESS
Fixed config_whitelist.txt rebase and updated MIGRATION.txt.
Applied to u-boot-spi/master
Convert driver to use spi-mem ops in order to support accelerated MMIO flash interface in generic way and for better performance.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- drivers/spi/ti_qspi.c | 132 ++++++++++++++++++++++-------------------- 1 file changed, 68 insertions(+), 64 deletions(-)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 731fb23022d2..77fa17ee8ab1 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -10,6 +10,7 @@ #include <asm/arch/omap.h> #include <malloc.h> #include <spi.h> +#include <spi-mem.h> #include <dm.h> #include <asm/gpio.h> #include <asm/omap_gpio.h> @@ -40,7 +41,6 @@ DECLARE_GLOBAL_DATA_PTR; #define QSPI_INVAL (4 << 16) #define QSPI_RD_QUAD (7 << 16) /* device control */ -#define QSPI_DD(m, n) (m << (3 + n*8)) #define QSPI_CKPHA(n) (1 << (2 + n*8)) #define QSPI_CSPOL(n) (1 << (1 + n*8)) #define QSPI_CKPOL(n) (1 << (n*8)) @@ -53,18 +53,11 @@ DECLARE_GLOBAL_DATA_PTR; #define MEM_CS(cs) ((cs + 1) << 8) #define MEM_CS_UNSELECT 0xfffff8ff
-#define QSPI_CMD_READ (0x3 << 0) -#define QSPI_CMD_READ_DUAL (0x6b << 0) -#define QSPI_CMD_READ_QUAD (0x6c << 0) -#define QSPI_CMD_READ_FAST (0x0b << 0) -#define QSPI_SETUP0_NUM_A_BYTES (0x3 << 8) -#define QSPI_SETUP0_NUM_D_BYTES_NO_BITS (0x0 << 10) -#define QSPI_SETUP0_NUM_D_BYTES_8_BITS (0x1 << 10) #define QSPI_SETUP0_READ_NORMAL (0x0 << 12) #define QSPI_SETUP0_READ_DUAL (0x1 << 12) #define QSPI_SETUP0_READ_QUAD (0x3 << 12) -#define QSPI_CMD_WRITE (0x12 << 16) -#define QSPI_NUM_DUMMY_BITS (0x0 << 24) +#define QSPI_SETUP0_ADDR_SHIFT (8) +#define QSPI_SETUP0_DBITS_SHIFT (10)
/* ti qspi register set */ struct ti_qspi_regs { @@ -96,6 +89,7 @@ struct ti_qspi_regs { /* ti qspi priv */ struct ti_qspi_priv { void *memory_map; + size_t mmap_size; uint max_hz; u32 num_cs; struct ti_qspi_regs *base; @@ -171,19 +165,6 @@ static int ti_qspi_xfer(struct udevice *dev, unsigned int bitlen, return -EINVAL; }
- /* Setup mmap flags */ - if (flags & SPI_XFER_MMAP) { - writel(MM_SWITCH, &priv->base->memswitch); - if (priv->ctrl_mod_mmap) - ti_qspi_ctrl_mode_mmap(priv->ctrl_mod_mmap, cs, true); - return 0; - } else if (flags & SPI_XFER_MMAP_END) { - writel(~MM_SWITCH, &priv->base->memswitch); - if (priv->ctrl_mod_mmap) - ti_qspi_ctrl_mode_mmap(priv->ctrl_mod_mmap, cs, false); - return 0; - } - if (bitlen == 0) return -1;
@@ -269,9 +250,9 @@ static int ti_qspi_xfer(struct udevice *dev, unsigned int bitlen, }
/* TODO: control from sf layer to here through dm-spi */ -#if defined(CONFIG_TI_EDMA3) && !defined(CONFIG_DMA) -void spi_flash_copy_mmap(void *data, void *offset, size_t len) +static void ti_qspi_copy_mmap(void *data, void *offset, size_t len) { +#if defined(CONFIG_TI_EDMA3) && !defined(CONFIG_DMA) unsigned int addr = (unsigned int) (data); unsigned int edma_slot_num = 1;
@@ -286,44 +267,34 @@ void spi_flash_copy_mmap(void *data, void *offset, size_t len)
/* disable edma3 clocks */ disable_edma3_clocks(); +#else + memcpy_fromio(data, offset, len); +#endif
*((unsigned int *)offset) += len; } -#endif
-static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, - struct spi_slave *slave, - bool enable) +static void ti_qspi_setup_mmap_read(struct ti_qspi_priv *priv, u8 opcode, + u8 data_nbits, u8 addr_width, + u8 dummy_bytes) { - u32 memval; - u32 mode = slave->mode & (SPI_RX_QUAD | SPI_RX_DUAL); + u32 memval = opcode;
- if (!enable) { - writel(0, &priv->base->setup0); - return; - } - - memval = QSPI_SETUP0_NUM_A_BYTES | QSPI_CMD_WRITE | QSPI_NUM_DUMMY_BITS; - - switch (mode) { - case SPI_RX_QUAD: - memval |= QSPI_CMD_READ_QUAD; - memval |= QSPI_SETUP0_NUM_D_BYTES_8_BITS; + switch (data_nbits) { + case 4: memval |= QSPI_SETUP0_READ_QUAD; - slave->mode |= SPI_RX_QUAD; break; - case SPI_RX_DUAL: - memval |= QSPI_CMD_READ_DUAL; - memval |= QSPI_SETUP0_NUM_D_BYTES_8_BITS; + case 2: memval |= QSPI_SETUP0_READ_DUAL; break; default: - memval |= QSPI_CMD_READ; - memval |= QSPI_SETUP0_NUM_D_BYTES_NO_BITS; memval |= QSPI_SETUP0_READ_NORMAL; break; }
+ memval |= ((addr_width - 1) << QSPI_SETUP0_ADDR_SHIFT | + dummy_bytes << QSPI_SETUP0_DBITS_SHIFT); + writel(memval, &priv->base->setup0); }
@@ -342,10 +313,39 @@ static int ti_qspi_set_mode(struct udevice *bus, uint mode) return 0; }
+static int ti_qspi_exec_mem_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + struct ti_qspi_priv *priv; + struct udevice *bus; + + bus = slave->dev->parent; + priv = dev_get_priv(bus); + u32 from = 0; + int ret = 0; + + /* Only optimize read path. */ + if (!op->data.nbytes || op->data.dir != SPI_MEM_DATA_IN || + !op->addr.nbytes || op->addr.nbytes > 4) + return -ENOTSUPP; + + /* Address exceeds MMIO window size, fall back to regular mode. */ + from = op->addr.val; + if (from + op->data.nbytes > priv->mmap_size) + return -ENOTSUPP; + + ti_qspi_setup_mmap_read(priv, op->cmd.opcode, op->data.buswidth, + op->addr.nbytes, op->dummy.nbytes); + + ti_qspi_copy_mmap((void *)op->data.buf.in, + (void *)priv->memory_map + from, op->data.nbytes); + + return ret; +} + static int ti_qspi_claim_bus(struct udevice *dev) { struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); - struct spi_slave *slave = dev_get_parent_priv(dev); struct ti_qspi_priv *priv; struct udevice *bus;
@@ -357,7 +357,10 @@ static int ti_qspi_claim_bus(struct udevice *dev) return -EINVAL; }
- __ti_qspi_setup_memorymap(priv, slave, true); + writel(MM_SWITCH, &priv->base->memswitch); + if (priv->ctrl_mod_mmap) + ti_qspi_ctrl_mode_mmap(priv->ctrl_mod_mmap, + slave_plat->cs, true);
writel(priv->dc, &priv->base->dc); writel(0, &priv->base->cmd); @@ -371,18 +374,22 @@ static int ti_qspi_claim_bus(struct udevice *dev)
static int ti_qspi_release_bus(struct udevice *dev) { - struct spi_slave *slave = dev_get_parent_priv(dev); + struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); struct ti_qspi_priv *priv; struct udevice *bus;
bus = dev->parent; priv = dev_get_priv(bus);
- __ti_qspi_setup_memorymap(priv, slave, false); + writel(~MM_SWITCH, &priv->base->memswitch); + if (priv->ctrl_mod_mmap) + ti_qspi_ctrl_mode_mmap(priv->ctrl_mod_mmap, + slave_plat->cs, false);
writel(0, &priv->base->dc); writel(0, &priv->base->cmd); writel(0, &priv->base->data); + writel(0, &priv->base->setup0);
return 0; } @@ -440,12 +447,15 @@ static int ti_qspi_ofdata_to_platdata(struct udevice *bus) struct ti_qspi_priv *priv = dev_get_priv(bus); const void *blob = gd->fdt_blob; int node = dev_of_offset(bus); + fdt_addr_t mmap_addr; + fdt_addr_t mmap_size;
priv->ctrl_mod_mmap = map_syscon_chipselects(bus); priv->base = map_physmem(devfdt_get_addr(bus), sizeof(struct ti_qspi_regs), MAP_NOCACHE); - priv->memory_map = map_physmem(devfdt_get_addr_index(bus, 1), 0, - MAP_NOCACHE); + mmap_addr = devfdt_get_addr_size_index(bus, 1, &mmap_size); + priv->memory_map = map_physmem(mmap_addr, mmap_size, MAP_NOCACHE); + priv->mmap_size = mmap_size;
priv->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", -1); if (priv->max_hz < 0) { @@ -460,15 +470,9 @@ static int ti_qspi_ofdata_to_platdata(struct udevice *bus) return 0; }
-static int ti_qspi_child_pre_probe(struct udevice *dev) -{ - struct spi_slave *slave = dev_get_parent_priv(dev); - struct udevice *bus = dev_get_parent(dev); - struct ti_qspi_priv *priv = dev_get_priv(bus); - - slave->memory_map = priv->memory_map; - return 0; -} +static const struct spi_controller_mem_ops ti_qspi_mem_ops = { + .exec_op = ti_qspi_exec_mem_op, +};
static const struct dm_spi_ops ti_qspi_ops = { .claim_bus = ti_qspi_claim_bus, @@ -476,6 +480,7 @@ static const struct dm_spi_ops ti_qspi_ops = { .xfer = ti_qspi_xfer, .set_speed = ti_qspi_set_speed, .set_mode = ti_qspi_set_mode, + .mem_ops = &ti_qspi_mem_ops, };
static const struct udevice_id ti_qspi_ids[] = { @@ -492,5 +497,4 @@ U_BOOT_DRIVER(ti_qspi) = { .ofdata_to_platdata = ti_qspi_ofdata_to_platdata, .priv_auto_alloc_size = sizeof(struct ti_qspi_priv), .probe = ti_qspi_probe, - .child_pre_probe = ti_qspi_child_pre_probe, };
Tom, Jagan
v2
- Rebase on top of latest master and Uri's patch [1] removing cl-som-am57x_defconfig
- Remove more un-needed CONFIGs related to TI QSPI that have not been
- Collect Reviewed-bys
I am not sure how this dependency can be handled. But since [1] would go through Tom's TI related pull, one solution would be to take this series also via the same tree with Jagan's Ack/Review to avoid build issues. Does that sound good?
Jagan Teki
Vignesh Raghavendra
