[U-Boot] [PATCH] arm: socfpga: fix issue with warm reset when CSEL is 0
When CSEL=0x0 the socfpga bootrom does not touch the clock configuration for the device. This can lead to a boot failure on warm resets. To address this, the bootrom is configured to run a bit of code in the last 4KB of onchip ram on a warm reset. This code puts the PLLs in bypass, disables the bootrom configuration to run the code snippet, and issues a warm reset to run the bootrom.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/include/mach/clock_manager.h | 22 ++++++- arch/arm/mach-socfpga/include/mach/reset_manager.h | 4 ++ .../arm/mach-socfpga/include/mach/system_manager.h | 7 ++- arch/arm/mach-socfpga/misc.c | 29 +++++++++ arch/arm/mach-socfpga/reset_clock_manager.S | 71 ++++++++++++++++++++++ 6 files changed, 132 insertions(+), 3 deletions(-) create mode 100644 arch/arm/mach-socfpga/reset_clock_manager.S
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 809cd47..6876ccf 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -8,7 +8,7 @@ #
obj-y += misc.o timer.o reset_manager.o system_manager.o clock_manager.o \ - fpga_manager.o board.o + fpga_manager.o board.o reset_clock_manager.o
obj-$(CONFIG_SPL_BUILD) += spl.o freeze_controller.o
diff --git a/arch/arm/mach-socfpga/include/mach/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h index 803c926..dd58c20 100644 --- a/arch/arm/mach-socfpga/include/mach/clock_manager.h +++ b/arch/arm/mach-socfpga/include/mach/clock_manager.h @@ -21,7 +21,6 @@ const unsigned int cm_get_f2s_sdr_ref_clk_hz(void);
/* Clock configuration accessors */ const struct cm_config * const cm_get_default_config(void); -#endif
struct cm_config { /* main group */ @@ -127,6 +126,19 @@ struct socfpga_clock_manager { struct socfpga_clock_manager_altera altera; u32 _pad_0xe8_0x200[70]; }; +#endif + +#define CLKMGR_CTRL_ADDRESS 0x0 +#define CLKMGR_BYPASS_ADDRESS 0x4 +#define CLKMGR_INTER_ADDRESS 0x8 +#define CLKMGR_INTREN_ADDRESS 0xc +#define CLKMGR_DBCTRL_ADDRESS 0x10 +#define CLKMGR_STAT_ADDRESS 0x14 +#define CLKMGR_MAINPLLGRP_MAINQSPICLK_ADDRESS 0x54 +#define CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_ADDRESS 0x58 +#define CLKMGR_PERPLLGRP_PERQSPICLK_ADDRESS 0x90 +#define CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_ADDRESS 0x94 +
#define CLKMGR_CTRL_SAFEMODE (1 << 0) #define CLKMGR_CTRL_SAFEMODE_OFFSET 0 @@ -314,4 +326,12 @@ struct socfpga_clock_manager { #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_OFFSET 9 #define CLKMGR_SDRPLLGRP_S2FUSER2CLK_PHASE_MASK 0x00000e00
+/* Bypass Main and Per PLL, bypass source per input mux */ +#define CLKMGR_BYPASS_MAIN_PER_PLL_MASK 0x19 + +#define CLKMGR_MAINQSPICLK_RESET_VALUE 0x3 +#define CLKMGR_MAINNANDSDMMCCLK_RESET_VALUE 0x3 +#define CLKMGR_PERQSPICLK_RESET_VALUE 0x1 +#define CLKMGR_PERNANDSDMMCCLK_RESET_VALUE 0x1 + #endif /* _CLOCK_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h index 2f070f2..58d77fb 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager.h @@ -7,6 +7,7 @@ #ifndef _RESET_MANAGER_H_ #define _RESET_MANAGER_H_
+#ifndef __ASSEMBLY__ void reset_cpu(ulong addr); void reset_deassert_peripherals_handoff(void);
@@ -28,6 +29,8 @@ struct socfpga_reset_manager { u32 padding2[12]; u32 tstscratch; }; +#endif +
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) #define RSTMGR_CTRL_SWWARMRSTREQ_LSB 2 @@ -40,6 +43,7 @@ struct socfpga_reset_manager { * and reset ID can be extracted using the subsequent macros * RSTMGR_RESET() and RSTMGR_BANK(). */ +#define RSTMGR_CTRL_OFFSET 4 #define RSTMGR_BANK_OFFSET 8 #define RSTMGR_BANK_MASK 0x7 #define RSTMGR_RESET_OFFSET 0 diff --git a/arch/arm/mach-socfpga/include/mach/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h index c45edea..d04fa2f 100644 --- a/arch/arm/mach-socfpga/include/mach/system_manager.h +++ b/arch/arm/mach-socfpga/include/mach/system_manager.h @@ -13,7 +13,6 @@ void sysmgr_pinmux_init(void); void sysmgr_config_warmrstcfgio(int enable);
void sysmgr_get_pinmux_table(const u8 **table, unsigned int *table_len); -#endif
struct socfpga_system_manager { /* System Manager Module */ @@ -115,6 +114,12 @@ struct socfpga_system_manager { u32 _pad_0x734; u32 spim0usefpga; /* 0x738 */ }; +#endif + +#define CONFIG_SYSMGR_WARMRAMGRP_ENABLE (SOCFPGA_SYSMGR_ADDRESS + 0xe0) + +#define SYSMGR_BOOTINFO_CSEL_MASK 0x18 +#define SYSMGR_BOOTINFO_CSEL_LSB 3
#define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGPINMUX (1 << 0) #define SYSMGR_ROMCODEGRP_CTRL_WARMRSTCFGIO (1 << 1) diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index dd6b53b..4d41420 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -22,6 +22,9 @@
#include <dt-bindings/reset/altr,rst-mgr.h>
+void reset_clock_manager(void); +extern unsigned reset_clock_manager_size; + DECLARE_GLOBAL_DATA_PTR;
static struct pl310_regs *const pl310 = @@ -356,6 +359,32 @@ static uint32_t iswgrp_handoff[8]; int arch_early_init_r(void) { int i; + unsigned csel, ramboot_addr; + + /* Check the CSEL value */ + csel = (readl(&sysmgr_regs->bootinfo) & SYSMGR_BOOTINFO_CSEL_MASK) >> + SYSMGR_BOOTINFO_CSEL_LSB; + + /* + * For CSEL = 0 the bootrom does not configure the clocks which can + * result in a boot failure on warm resets. To remedy this a small + * bit of code is placed at the end of the onchip ram and run on + * a warm reset. It puts the PLLs in bypass and issues another warm + * reset to get back to the bootrom. + */ + if(!csel) { + /* Put the code snippet in the last 4KB of the onchip ram */ + ramboot_addr = CONFIG_SYS_INIT_RAM_ADDR + + CONFIG_SYS_INIT_RAM_SIZE - 0x1000; + + /* Copy the code to the onchip ramlocation */ + memcpy((void *)ramboot_addr, reset_clock_manager, + reset_clock_manager_size); + + /* Set the bootrom to run the code snippet on reset */ + writel(ramboot_addr, + &sysmgr_regs->romcodegrp_warmramgrp_execution); + }
/* * Write magic value into magic register to unlock support for diff --git a/arch/arm/mach-socfpga/reset_clock_manager.S b/arch/arm/mach-socfpga/reset_clock_manager.S new file mode 100644 index 0000000..1818b2d --- /dev/null +++ b/arch/arm/mach-socfpga/reset_clock_manager.S @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2017, Intel Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/clock_manager.h> + +/* + */ +ENTRY(reset_clock_manager) + /* Put Main PLL and Peripheral PLL in bypass */ + ldr r0, SOCFPGA_CLKMGR + mov r1, #CLKMGR_BYPASS_ADDRESS + mov r2, #CLKMGR_BYPASS_MAIN_PER_PLL_MASK + add r3, r0, r1 + ldr r4, [r3] + orr r5, r4, r2 + str r5, [r3] + dsb + isb + mov r1, #CLKMGR_MAINPLLGRP_MAINQSPICLK_ADDRESS + mov r2, #CLKMGR_MAINQSPICLK_RESET_VALUE + add r3, r0, r1 + str r2, [r3] + mov r1, #CLKMGR_MAINPLLGRP_MAINNANDSDMMCCLK_ADDRESS + mov r2, #CLKMGR_MAINNANDSDMMCCLK_RESET_VALUE + add r3, r0, r1 + str r2, [r3] + mov r1, #CLKMGR_PERPLLGRP_PERQSPICLK_ADDRESS + mov r2, #CLKMGR_PERQSPICLK_RESET_VALUE + add r3, r0, r1 + str r2, [r3] + mov r1, #CLKMGR_PERPLLGRP_PERNANDSDMMCCLK_ADDRESS + mov r2, #CLKMGR_PERNANDSDMMCCLK_RESET_VALUE + add r3, r0, r1 + str r2, [r3] + + /* Disable the RAM boot */ + ldr r0, SOCFPGA_RSTMGR + ldr r1, SYSMGR_WARMRAMGRP_ENABLE + mov r2, #0 + str r2, [r1] + + /* Trigger warm reset to continue boot normally */ + mov r1, #RSTMGR_CTRL_OFFSET + add r2, r0, r1 + mov r3, #1 + mov r3, r3, LSL #RSTMGR_CTRL_SWWARMRSTREQ_LSB + ldr r4, [r2] + orr r4, r3, r4 + str r4, [r2] + +reset_clock_manager_loop: + dsb + isb + b reset_clock_manager_loop +ENDPROC(reset_clock_manager) + +SOCFPGA_CLKMGR: .word SOCFPGA_CLKMGR_ADDRESS +SOCFPGA_RSTMGR: .word SOCFPGA_RSTMGR_ADDRESS +SYSMGR_WARMRAMGRP_ENABLE: .word CONFIG_SYSMGR_WARMRAMGRP_ENABLE + +.globl reset_clock_manager_size +reset_clock_manager_size: + .word . - reset_clock_manager +
Please fix up these checkpatch errors: total: 17 errors, 4 warnings, 2 checks, 199 lines checked
Dinh
Dalon Westergreen
Dinh Nguyen
