[PATCH] ARM: imx: Add support for the primary/secondary bmode to MX53
Implement the 'getprisec' subcommand of 'bmode' command for i.MX53 and also the primary/secondary bootmode switching.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx5/soc.c | 21 ++++++++++++++++++++- 1 file changed, 20 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/mx5/soc.c b/arch/arm/mach-imx/mx5/soc.c index c61fcce3eb..47f531dc85 100644 --- a/arch/arm/mach-imx/mx5/soc.c +++ b/arch/arm/mach-imx/mx5/soc.c @@ -87,10 +87,27 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) #endif
#ifdef CONFIG_MX53 +#define IMX53_SRTC_LPGR_PERSIST_SECONDARY_BOOT BIT(30) + void boot_mode_apply(unsigned cfg_val) { - writel(cfg_val, &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr); + void *lpgr = &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr; + + if (cfg_val == MAKE_CFGVAL_PRIMARY_BOOT) + clrbits_le32(lpgr, IMX53_SRTC_LPGR_PERSIST_SECONDARY_BOOT); + else if (cfg_val == MAKE_CFGVAL_SECONDARY_BOOT) + setbits_le32(lpgr, IMX53_SRTC_LPGR_PERSIST_SECONDARY_BOOT); + else + writel(cfg_val, lpgr); +} + +int boot_mode_getprisec(void) +{ + void *lpgr = &((struct srtc_regs *)SRTC_BASE_ADDR)->lpgr; + + return !!(readl(lpgr) & IMX53_SRTC_LPGR_PERSIST_SECONDARY_BOOT); } + /* * cfg_val will be used for * Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] @@ -112,6 +129,8 @@ const struct boot_mode soc_boot_modes[] = { {"esdhc2", MAKE_CFGVAL(0x40, 0x20, 0x08, 0x12)}, {"esdhc3", MAKE_CFGVAL(0x40, 0x20, 0x10, 0x12)}, {"esdhc4", MAKE_CFGVAL(0x40, 0x20, 0x18, 0x12)}, + {"primary", MAKE_CFGVAL_PRIMARY_BOOT}, + {"secondary", MAKE_CFGVAL_SECONDARY_BOOT}, {NULL, 0}, }; #endif
Implement the 'getprisec' subcommand of 'bmode' command for i.MX53 and also the primary/secondary bootmode switching. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
