Re: [U-Boot-Users] MIPS question
From: Vlad Lungu vlad@comsys.ro Shinya Kuribayashi wrote:
Vlad Lungu wrote:
in include/asm-mips/addrspace.h line 52, there is a
#define UNCACHED_SDRAM(a) PHYSADDR(a)
The question is: shouldn't we use KSEG1ADDR() instead of
PHYSADDR()?
I think we should. At least my target boards need that change.
The RAM might be mapped at 0 too on some boards, that's why it works with PHYSADDR(). ...
My code base is unchanged from U-Boot 1.1.1 :
#if defined(CONFIG_AU1X00) || defined(CONFIG_TB0229) /* We use a 36 bit physical address map here and cannot access physical memory directly from core */ #define UNCACHED_SDRAM(a) (((unsigned long)(a)) | 0x20000000) #else /* !CONFIG_AU1X00 */ #define UNCACHED_SDRAM(a) PHYSADDR(a) #endif /* CONFIG_AU1X00 */
Since the name is uncached, you want an uncached address, so I think we want
#define UNCACHED_SDRAM(a) KSEG1ADDR(a)
In the Au1x00 based systems (like ours), the SDRAM is generally mapped to physical address 0x80000000, so it works out as valid KSEG0 / KSEG1 addresses.
Tim Braun, Sr. Des. Eng. LibreStream Technologies 200-55 Rothwell Rd, Winnipeg, R3P 2M5 http://www.librestream.com
Tim Braun
