[U-Boot] [PATCH v2 1/5] rockchip: i2c: rk3328: support i2c for rk3328 SoC
Add compatible to support rk3328 i2c
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
Changes in v2: None
drivers/i2c/rk_i2c.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 68e6653..a051893 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -396,6 +396,7 @@ static const struct udevice_id rockchip_i2c_ids[] = { { .compatible = "rockchip,rk3066-i2c" }, { .compatible = "rockchip,rk3188-i2c" }, { .compatible = "rockchip,rk3288-i2c" }, + { .compatible = "rockchip,rk3328-i2c" }, { .compatible = "rockchip,rk3399-i2c" }, { } };
Add Rockchip pmic rk816 support.
RK816 have 4 DCDC, 6 LDO, RTC, CHARGER, FUEL GAUGE, GPIO, PWRKEY. The DCDC and LDO voltage output range and current loading are different from RK808 and RK818. RK816 add mask bit for enable/disable for read/write safety.
The RK816 most used with rk312x/rk322x/rk332x SoCs.
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - add introduce info for RK816 in commit message
drivers/power/pmic/rk8xx.c | 1 + drivers/power/regulator/rk8xx.c | 212 ++++++++++++++++++++++++++++++++-------- include/power/rk8xx_pmic.h | 9 +- 3 files changed, 182 insertions(+), 40 deletions(-)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index eb3ec0f..0fdea95 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -100,6 +100,7 @@ static struct dm_pmic_ops rk8xx_ops = {
static const struct udevice_id rk8xx_ids[] = { { .compatible = "rockchip,rk808" }, + { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, { } }; diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index 76fc2ef..cf3566e 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -48,6 +48,21 @@ static const struct rk8xx_reg_info rk808_buck[] = { { 1800000, 100000, REG_BUCK4_ON_VSEL, RK808_BUCK4_VSEL_MASK, }, };
+static const struct rk8xx_reg_info rk816_buck[] = { + /* buck 1 */ + { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 1800000, 200000, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 2300000, 0, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + /* buck 2 */ + { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 1800000, 200000, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + { 2300000, 0, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, + /* buck 3 */ + { 712500, 12500, -1, RK818_BUCK_VSEL_MASK, }, + /* buck 4 */ + { 800000, 100000, REG_BUCK4_ON_VSEL, RK818_BUCK4_VSEL_MASK, }, +}; + static const struct rk8xx_reg_info rk818_buck[] = { { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, }, { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, }, @@ -67,6 +82,15 @@ static const struct rk8xx_reg_info rk808_ldo[] = { { 1800000, 100000, REG_LDO8_ON_VSEL, RK808_LDO_VSEL_MASK, }, };
+static const struct rk8xx_reg_info rk816_ldo[] = { + { 800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO3_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO4_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO5_ON_VSEL, RK818_LDO_VSEL_MASK, }, + { 800000, 100000, REG_LDO6_ON_VSEL, RK818_LDO_VSEL_MASK, }, +}; + static const struct rk8xx_reg_info rk818_ldo[] = { { 1800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, }, { 1800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, }, @@ -88,10 +112,24 @@ static const uint rk818_chrg_shutdown_vsel_array[] = { };
static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic, - int num) + int num, int uvolt) { struct rk8xx_priv *priv = dev_get_priv(pmic); + switch (priv->variant) { + case RK816_ID: + switch (num) { + case 0: + case 1: + if (uvolt <= 1450000) + return &rk816_buck[num * 3 + 0]; + else if (uvolt <= 2200000) + return &rk816_buck[num * 3 + 1]; + else + return &rk816_buck[num * 3 + 2]; + default: + return &rk816_buck[num + 4]; + } case RK818_ID: return &rk818_buck[num]; default: @@ -101,7 +139,7 @@ static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic,
static int _buck_set_value(struct udevice *pmic, int buck, int uvolt) { - const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck - 1); + const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck, uvolt); int mask = info->vsel_mask; int val;
@@ -114,23 +152,76 @@ static int _buck_set_value(struct udevice *pmic, int buck, int uvolt) return pmic_clrsetbits(pmic, info->vsel_reg, mask, val); }
+static int _buck_get_enable(struct udevice *pmic, int buck) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask = 0; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (buck >= 4) { + mask = 1 << (buck - 4); + ret = pmic_reg_read(pmic, RK816_REG_DCDC_EN2); + } else { + mask = 1 << buck; + ret = pmic_reg_read(pmic, RK816_REG_DCDC_EN1); + } + break; + case RK808_ID: + case RK818_ID: + mask = 1 << buck; + ret = pmic_reg_read(pmic, REG_DCDC_EN); + if (ret < 0) + return ret; + break; + } + return ret & mask ? true : false; +} + + static int _buck_set_enable(struct udevice *pmic, int buck, bool enable) { - uint mask; + uint mask, value, en_reg; int ret; + struct rk8xx_priv *priv = dev_get_priv(pmic);
- buck--; - mask = 1 << buck; - if (enable) { - ret = pmic_clrsetbits(pmic, REG_DCDC_ILMAX, 0, 3 << (buck * 2)); - if (ret) - return ret; - ret = pmic_clrsetbits(pmic, REG_DCDC_UV_ACT, 1 << buck, 0); - if (ret) - return ret; + switch (priv->variant) { + case RK816_ID: + if (buck >= 4) { + buck -= 4; + en_reg = RK816_REG_DCDC_EN2; + } else { + en_reg = RK816_REG_DCDC_EN1; + } + if (enable) + value = ((1 << buck) | (1 << (buck + 4))); + else + value = ((0 << buck) | (1 << (buck + 4))); + ret = pmic_reg_write(pmic, en_reg, value); + break; + + case RK808_ID: + case RK818_ID: + mask = 1 << buck; + if (enable) { + ret = pmic_clrsetbits(pmic, REG_DCDC_ILMAX, + 0, 3 << (buck * 2)); + if (ret) + return ret; + ret = pmic_clrsetbits(pmic, REG_DCDC_UV_ACT, + 1 << buck, 0); + if (ret) + return ret; + } + ret = pmic_clrsetbits(pmic, REG_DCDC_EN, mask, + enable ? mask : 0); + break; + default: + ret = -EINVAL; }
- return pmic_clrsetbits(pmic, REG_DCDC_EN, mask, enable ? mask : 0); + return ret; }
#ifdef ENABLE_DRIVER @@ -138,7 +229,10 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, int num) { struct rk8xx_priv *priv = dev_get_priv(pmic); + switch (priv->variant) { + case RK816_ID: + return &rk816_ldo[num]; case RK818_ID: return &rk818_ldo[num]; default: @@ -146,10 +240,70 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, } }
+static int _ldo_get_enable(struct udevice *pmic, int ldo) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask = 0; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (ldo >= 4) { + mask = 1 << (ldo - 4); + ret = pmic_reg_read(pmic, RK816_REG_LDO_EN2); + } else { + mask = 1 << ldo; + ret = pmic_reg_read(pmic, RK816_REG_LDO_EN1); + } + break; + case RK808_ID: + case RK818_ID: + mask = 1 << ldo; + ret = pmic_reg_read(pmic, REG_LDO_EN); + if (ret < 0) + return ret; + break; + } + return ret & mask ? true : false; +} + + +static int _ldo_set_enable(struct udevice *pmic, int ldo, bool enable) +{ + struct rk8xx_priv *priv = dev_get_priv(pmic); + uint mask, value, en_reg; + int ret = 0; + + switch (priv->variant) { + case RK816_ID: + if (ldo >= 4) { + ldo -= 4; + en_reg = RK816_REG_LDO_EN2; + } else { + en_reg = RK816_REG_LDO_EN1; + } + if (enable) + value = ((1 << ldo) | (1 << (ldo + 4))); + else + value = ((0 << ldo) | (1 << (ldo + 4))); + + ret = pmic_reg_write(pmic, en_reg, value); + break; + case RK808_ID: + case RK818_ID: + mask = 1 << ldo; + ret = pmic_clrsetbits(pmic, REG_LDO_EN, mask, + enable ? mask : 0); + break; + } + + return ret; +} + static int buck_get_value(struct udevice *dev) { int buck = dev->driver_data - 1; - const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck); + const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck, 0); int mask = info->vsel_mask; int ret, val;
@@ -165,14 +319,14 @@ static int buck_get_value(struct udevice *dev)
static int buck_set_value(struct udevice *dev, int uvolt) { - int buck = dev->driver_data; + int buck = dev->driver_data - 1;
return _buck_set_value(dev->parent, buck, uvolt); }
static int buck_set_enable(struct udevice *dev, bool enable) { - int buck = dev->driver_data; + int buck = dev->driver_data - 1;
return _buck_set_enable(dev->parent, buck, enable); } @@ -180,16 +334,8 @@ static int buck_set_enable(struct udevice *dev, bool enable) static int buck_get_enable(struct udevice *dev) { int buck = dev->driver_data - 1; - int ret; - uint mask; - - mask = 1 << buck;
- ret = pmic_reg_read(dev->parent, REG_DCDC_EN); - if (ret < 0) - return ret; - - return ret & mask ? true : false; + return _buck_get_enable(dev->parent, buck); }
static int ldo_get_value(struct udevice *dev) @@ -228,27 +374,15 @@ static int ldo_set_value(struct udevice *dev, int uvolt) static int ldo_set_enable(struct udevice *dev, bool enable) { int ldo = dev->driver_data - 1; - uint mask; - - mask = 1 << ldo;
- return pmic_clrsetbits(dev->parent, REG_LDO_EN, mask, - enable ? mask : 0); + return _ldo_set_enable(dev->parent, ldo, enable); }
static int ldo_get_enable(struct udevice *dev) { int ldo = dev->driver_data - 1; - int ret; - uint mask; - - mask = 1 << ldo;
- ret = pmic_reg_read(dev->parent, REG_LDO_EN); - if (ret < 0) - return ret; - - return ret & mask ? true : false; + return _ldo_get_enable(dev->parent, ldo); }
static int switch_set_enable(struct udevice *dev, bool enable) diff --git a/include/power/rk8xx_pmic.h b/include/power/rk8xx_pmic.h index 47a6b36..8e821c3 100644 --- a/include/power/rk8xx_pmic.h +++ b/include/power/rk8xx_pmic.h @@ -171,8 +171,15 @@ enum { };
enum { - RK805_ID = 0x8050, + RK816_REG_DCDC_EN1 = 0x23, + RK816_REG_DCDC_EN2, + RK816_REG_LDO_EN1 = 0x27, + RK816_REG_LDO_EN2, +}; + +enum { RK808_ID = 0x0000, + RK816_ID = 0x8160, RK818_ID = 0x8180, };
The changes I requested (https://patchwork.ozlabs.org/patch/813297/) to to split this up (so we avoid having different logic in a switch/case for every function have not been addressed).
The RK816 apparently is different enough from the RK808 and RK816 to warrant a separate DM driver.
Our basic rule-of-thumb for deciding when to split a driver should be whether the new device can be added using driverdata containing parameters or whether we end up adding new conditional and exclusive code-paths (i.e. if there's a conditional statement in the middle that just adds/removes one step of processing, when this certainly won't justify splitting a driver) to the overwhelming number of the ops.
Please split this to introduce a new driver for the RK816 and keep the existing driver as simple as it is today.
Changes in v2:
- { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, { }
- /* buck 1 */
- { 712500, 12500, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 1800000, 200000, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 2300000, 0, REG_BUCK1_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- /* buck 2 */
- { 712500, 12500, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 1800000, 200000, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- { 2300000, 0, REG_BUCK2_ON_VSEL, RK818_BUCK_VSEL_MASK, },
- /* buck 3 */
- { 712500, 12500, -1, RK818_BUCK_VSEL_MASK, },
- /* buck 4 */
- { 800000, 100000, REG_BUCK4_ON_VSEL, RK818_BUCK4_VSEL_MASK, },
- { 800000, 100000, REG_LDO1_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO2_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO3_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO4_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO5_ON_VSEL, RK818_LDO_VSEL_MASK, },
- { 800000, 100000, REG_LDO6_ON_VSEL, RK818_LDO_VSEL_MASK, },
int num)
int num, int uvolt)
- switch (priv->variant) {
- case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
case RK818_ID: return &rk818_buck[num]; default:}
- const struct rk8xx_reg_info *info = get_buck_reg(pmic, buck, uvolt); int mask = info->vsel_mask; int val;
- struct rk8xx_priv *priv = dev_get_priv(pmic);
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (buck >= 4) {
} else {
mask = 1 << buck;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (ret < 0)
return ret;
break;
- uint mask;
- uint mask, value, en_reg; int ret;
- buck--;
- mask = 1 << buck;
- if (enable) {
if (ret)
return ret;
if (ret)
return ret;
- case RK816_ID:
if (buck >= 4) {
buck -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (enable) {
if (ret)
return ret;
1 << buck, 0);
if (ret)
return ret;
enable ? mask : 0);
break;
- default:
}ret = -EINVAL;
- return ret;
- case RK816_ID:
case RK818_ID: return &rk818_ldo[num]; default:return &rk816_ldo[num];
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
} else {
mask = 1 << ldo;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
if (ret < 0)
return ret;
break;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
ldo -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
enable ? mask : 0);
break;
- return ret;
- const struct rk8xx_reg_info *info = get_buck_reg(dev->parent, buck, 0); int mask = info->vsel_mask; int ret, val;
int ret;
uint mask;
mask = 1 << buck;
if (ret < 0)
return ret;
- return _buck_get_enable(dev->parent, buck);
uint mask;
mask = 1 << ldo;
enable ? mask : 0);
- return _ldo_set_enable(dev->parent, ldo, enable);
int ret;
uint mask;
mask = 1 << ldo;
if (ret < 0)
return ret;
- return _ldo_get_enable(dev->parent, ldo);
enum {
- RK816_REG_DCDC_EN1 = 0x23,
- RK816_REG_DCDC_EN2,
- RK816_REG_LDO_EN1 = 0x27,
- RK816_REG_LDO_EN2,
- RK816_ID = 0x8160, RK818_ID = 0x8180,
Hi Philipp,
I have reply your comment in patch set V1, and explain why we think it's reason-able to make then in one driver instead of two. What you are asking is not like to keep code clean and less duplicate code. I copy my comment here again, I prefer to improve the implementation instead of split them into different driver.
Will add detail difference between these chips, they are very similar as regulator and it's reasonable to make then in one driver instead of use different drivers for them: - different DCDC/LDO numbers; - different voltage output range and current loading; - RK816 and RK805 add mask bit for enable/disable to make read/write more safe.
The framework and the setting for all these chips are the same, except the BUCK/LDO numbers are different, and rk805/rk816 need extra mask bit for enable/disable.
Abstract the difference into array structure is a good way to share the code, I don't think split this into rk805.c rk808.c rk816.c and rk818.c will have a better shape.
BTW, these are all the PMICs we have since early 2013, so don't worry, it won't grow into large switch statement.
Thanks, - Kever
Changes in v2:
- /* buck 1 */
- /* buck 2 */
- /* buck 3 */
- /* buck 4 */
int num)
int num, int uvolt)
- case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (buck >= 4) {
} else {
mask = 1 << buck;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (ret < 0)
return ret;
break;
- uint mask;
- buck--;
- mask = 1 << buck;
- if (enable) {
2));
if (ret)
return ret;
if (ret)
return ret;
- case RK816_ID:
if (buck >= 4) {
buck -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (enable) {
if (ret)
return ret;
1 << buck, 0);
if (ret)
return ret;
enable ? mask : 0);
break;
- default:
}ret = -EINVAL;
- return ret;
- case RK816_ID:
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
} else {
mask = 1 << ldo;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
if (ret < 0)
return ret;
break;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
ldo -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
enable ? mask : 0);
break;
- return ret;
buck);
int ret;
uint mask;
mask = 1 << buck;
if (ret < 0)
return ret;
uint mask;
mask = 1 << ldo;
enable ? mask : 0);
int ret;
uint mask;
mask = 1 << ldo;
if (ret < 0)
return ret;
enum {
Kever,
On 28 Sep 2017, at 12:12, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
From: Elaine Zhang zhangqing@rock-chips.com mailto:zhangqing@rock-chips.com
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com mailto:zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com mailto:kever.yang@rock-chips.com
The changes I requested (https://patchwork.ozlabs.org/patch/813297/ https://patchwork.ozlabs.org/patch/813297/) to to split this up (so we avoid having different logic in a switch/case for every function have not been addressed).
I had seen the comment (patchworks picked it up and I keep checking there to make sure I didn’t miss emails). However, I disagree: see below.
more safe. The framework and the setting for all these chips are the same, except the BUCK/LDO numbers are different, and rk805/rk816 need extra mask bit for enable/disable.
In these cases, we should have a file containing the common code and then mini-drivers that use them. I had the same discussion with Simon, when I tried to get the rk3399 hdmi merged—and we finally decided there on using the model of having small DM-drivers that have the different logic and then using shared functions for the shared infrastructure
The array structure is great (and I very much like how it’s done), but the changed implementation concerns me. Let’s look at _buck_set_enable as an example…
Initially it had a very clean flow (pseudocode): { if (enable) /* set/clear a few bits */
return /* another op */; }
Now it has morphed into: { switch (id) { case ONE_CHIP: if (enable) /* set/clear some bits */ ret = /* another op */ break;
case ANOTHER_CHIP: if (enable) /* set/clear some bits */ ret = /* other ops */; break;
default: /* handle a bad id */ }
return ret; }
This is clearly a case where multiple different functions should be used… and normally another DM-driver will be called for.
Note that there is also a runtime penalty (the compiler can’t optimise the switch-statemenet away) and a size penalty (important, as regulator-drivers may be needed as early as TPL).
That’s good to hear ;-) However, this is yet another reason why this should be a separate mini-driver…
For the time being, I’ll pick up the remainder of the series for rc1 and we can then sort out how to deal with this specific driver after the upcoming golden week?
Thanks,
- Kever
Changes in v2:
- /* buck 1 */
- /* buck 2 */
- /* buck 3 */
- /* buck 4 */
int num)
int num, int uvolt)
- case RK816_ID:
switch (num) {
case 0:
case 1:
else
default:
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (buck >= 4) {
} else {
mask = 1 << buck;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (ret < 0)
return ret;
break;
- uint mask;
- buck--;
- mask = 1 << buck;
- if (enable) {
if (ret)
return ret;
if (ret)
return ret;
- case RK816_ID:
if (buck >= 4) {
buck -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << buck;
if (enable) {
if (ret)
return ret;
1 << buck, 0);
if (ret)
return ret;
enable ? mask : 0);
break;
- default:
}ret = -EINVAL;
- return ret;
- case RK816_ID:
- uint mask = 0;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
} else {
mask = 1 << ldo;
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
if (ret < 0)
return ret;
break;
- int ret = 0;
- case RK816_ID:
if (ldo >= 4) {
ldo -= 4;
} else {
if (enable)
else
break;
- case RK808_ID:
- case RK818_ID:
mask = 1 << ldo;
enable ? mask : 0);
break;
- return ret;
int ret;
uint mask;
mask = 1 << buck;
if (ret < 0)
return ret;
uint mask;
mask = 1 << ldo;
enable ? mask : 0);
int ret;
uint mask;
mask = 1 << ldo;
if (ret < 0)
return ret;
enum {
RK805 have 4 DCDC, 4 LDO, RTC. The configuration parameters are the same with RK816.
The RK805 most used with rk312x/rk322x/rk332x products which do not need charger and fuel guage.
drivers/power/pmic/rk8xx.c | 1 + drivers/power/regulator/rk8xx.c | 6 ++++++ include/power/rk8xx_pmic.h | 1 + 3 files changed, 8 insertions(+)
diff --git a/drivers/power/pmic/rk8xx.c b/drivers/power/pmic/rk8xx.c index 0fdea95..f2a2f07 100644 --- a/drivers/power/pmic/rk8xx.c +++ b/drivers/power/pmic/rk8xx.c @@ -99,6 +99,7 @@ static struct dm_pmic_ops rk8xx_ops = { };
static const struct udevice_id rk8xx_ids[] = { + { .compatible = "rockchip,rk805" }, { .compatible = "rockchip,rk808" }, { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" }, diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index cf3566e..6d4a243 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -117,6 +117,7 @@ static const struct rk8xx_reg_info *get_buck_reg(struct udevice *pmic, struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: switch (num) { case 0: @@ -159,6 +160,7 @@ static int _buck_get_enable(struct udevice *pmic, int buck) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (buck >= 4) { mask = 1 << (buck - 4); @@ -187,6 +189,7 @@ static int _buck_set_enable(struct udevice *pmic, int buck, bool enable) struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (buck >= 4) { buck -= 4; @@ -231,6 +234,7 @@ static const struct rk8xx_reg_info *get_ldo_reg(struct udevice *pmic, struct rk8xx_priv *priv = dev_get_priv(pmic);
switch (priv->variant) { + case RK805_ID: case RK816_ID: return &rk816_ldo[num]; case RK818_ID: @@ -247,6 +251,7 @@ static int _ldo_get_enable(struct udevice *pmic, int ldo) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (ldo >= 4) { mask = 1 << (ldo - 4); @@ -275,6 +280,7 @@ static int _ldo_set_enable(struct udevice *pmic, int ldo, bool enable) int ret = 0;
switch (priv->variant) { + case RK805_ID: case RK816_ID: if (ldo >= 4) { ldo -= 4; diff --git a/include/power/rk8xx_pmic.h b/include/power/rk8xx_pmic.h index 8e821c3..b1482b7 100644 --- a/include/power/rk8xx_pmic.h +++ b/include/power/rk8xx_pmic.h @@ -178,6 +178,7 @@ enum { };
enum { + RK805_ID = 0x8050, RK808_ID = 0x0000, RK816_ID = 0x8160, RK818_ID = 0x8180,
Changes in v2:
- { .compatible = "rockchip,rk805" }, { .compatible = "rockchip,rk808" }, { .compatible = "rockchip,rk816" }, { .compatible = "rockchip,rk818" },
- case RK805_ID: case RK816_ID: switch (num) { case 0:
- case RK805_ID: case RK816_ID: if (buck >= 4) { mask = 1 << (buck - 4);
- case RK805_ID: case RK816_ID: if (buck >= 4) { buck -= 4;
- case RK805_ID: case RK816_ID: return &rk816_ldo[num]; case RK818_ID:
- case RK805_ID: case RK816_ID: if (ldo >= 4) { mask = 1 << (ldo - 4);
- case RK805_ID: case RK816_ID: if (ldo >= 4) { ldo -= 4;
enum {
- RK805_ID = 0x8050, RK808_ID = 0x0000, RK816_ID = 0x8160, RK818_ID = 0x8180,
Changes in v2:
Changes in v2:
Add defconfig for rk8xx and regulator and i2c controller.
Changes in v2: None
configs/evb-rk3328_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 7bec001..6d0f3af 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -22,12 +22,18 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK3328=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_DM_REGULATOR=y CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_BASE=0xFF130000
Changes in v2: None
Applied to u-boot-rockchip, thanks!
add i2c1 and rk805 nodes to support rk805 init setting.
Changes in v2: None
arch/arm/dts/rk3328-evb.dts | 118 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 118 insertions(+)
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts index 8a14c65..f71690f 100644 --- a/arch/arm/dts/rk3328-evb.dts +++ b/arch/arm/dts/rk3328-evb.dts @@ -87,3 +87,121 @@ vbus-supply = <&vcc5v0_host_xhci>; status = "okay"; }; + +&i2c1 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk805: pmic@18 { + compatible = "rockchip,rk805"; + status = "okay"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + gpio-controller; + #gpio-cells = <2>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vdd_18: LDO_REG1 { + regulator-name = "vdd_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_18emmc: LDO_REG2 { + regulator-name = "vcc_18emmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; /* gpio2_a6 */ + }; + }; +}; +
Changes in v2: None
Hello Yang,
Am 27.09.2017 um 09:23 schrieb Kever Yang:
Changes in v2: None
Acked-by: Heiko Schocherhs@denx.de
bye, Heiko Schocher
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Acked-by: Heiko Schocherhs@denx.de
Changes in v2: None
Dr. Philipp Tomsich
Heiko Schocher
Kever Yang
Philipp Tomsich
