[U-Boot] [PATCH] am33xx: Finish migration of CONFIG_AM33XX/AM43XX
Almost all users of CONFIG_AM33XX/AM43XX have been migrated. Finish moving the last few over to Kconfig, and put all of the boards under the appropriate Kconfig chocie now. This board choice is non-optional, so remove that keyword on am33xx.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-omap2/Kconfig | 55 +------------------------------ arch/arm/mach-omap2/am33xx/Kconfig | 60 +++++++++++++++++++++++++++++++++- configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 3 ++ configs/cm_t43_defconfig | 1 + configs/draco_defconfig | 3 +- configs/etamin_defconfig | 3 +- configs/pxm2_defconfig | 3 +- configs/rastaban_defconfig | 3 +- configs/rut_defconfig | 4 ++- configs/thuban_defconfig | 3 +- include/configs/bur_am335x_common.h | 1 - include/configs/cm_t43.h | 3 +- include/configs/siemens-am33x-common.h | 2 -- 16 files changed, 81 insertions(+), 66 deletions(-)
diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index d161b5194640..683cdb92963d 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -2,57 +2,7 @@ if ARCH_OMAP2PLUS
choice prompt "OMAP2+ platform select" - default TARGET_BRXRE1 - -config TARGET_BRXRE1 - bool "Support BRXRE1" - select BOARD_LATE_INIT - -config TARGET_BRPPT1 - bool "Support BRPPT1" - select BOARD_LATE_INIT - -config TARGET_DRACO - bool "Support draco" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO - -config TARGET_THUBAN - bool "Support thuban" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO - -config TARGET_RASTABAN - bool "Support rastaban" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO - -config TARGET_ETAMIN - bool "Support etamin" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO - -config TARGET_PXM2 - bool "Support pxm2" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO - -config TARGET_RUT - bool "Support rut" - select BOARD_LATE_INIT - select DM - select DM_SERIAL - select DM_GPIO + default OMAP34XX
config OMAP34XX bool "OMAP34XX SoC" @@ -151,9 +101,6 @@ config AM33XX protocols, optional 3D graphics and an optional customer programmable secure boot.
-config TARGET_CM_T43 - bool "Support cm_t43" - endchoice
config SYS_MPUCLK diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 36ec13414098..d8abba992acb 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -26,7 +26,6 @@ config AM33XX_CHILISOM
choice prompt "AM33xx board select" - optional
config TARGET_AM335X_EVM bool "Support am335x_evm" @@ -104,6 +103,14 @@ config TARGET_BAV335X
For more information, visit: http://birdland.com/oem
+config TARGET_BRXRE1 + bool "Support BRXRE1" + select BOARD_LATE_INIT + +config TARGET_BRPPT1 + bool "Support BRPPT1" + select BOARD_LATE_INIT + config TARGET_CHILIBOARD bool "Grinn chiliBoard" select AM33XX_CHILISOM @@ -117,6 +124,20 @@ config TARGET_CM_T335 select DM_SERIAL select DM_GPIO
+config TARGET_DRACO + bool "Support draco" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + +config TARGET_ETAMIN + bool "Support etamin" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + config TARGET_PCM051 bool "Support pcm051" select DM @@ -135,12 +156,43 @@ config TARGET_PEPPER select DM_SERIAL select DM_GPIO
+config TARGET_PXM2 + bool "Support pxm2" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + +config TARGET_RASTABAN + bool "Support rastaban" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + +config TARGET_RUT + bool "Support rut" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + +config TARGET_THUBAN + bool "Support thuban" + select BOARD_LATE_INIT + select DM + select DM_SERIAL + select DM_GPIO + endchoice
endif
if AM43XX
+choice + prompt "AM43xx board select" + config TARGET_AM43XX_EVM bool "Support am43xx_evm" select BOARD_LATE_INIT @@ -171,6 +223,12 @@ config TARGET_AM43XX_EVM evaluation module system that enables developers to write software and develop hardware around an AM43xx processor subsystem. + +config TARGET_CM_T43 + bool "Support cm_t43" + +endchoice + endif
if AM43XX || AM33XX diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 356622319071..f975eca9f406 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM33XX=y CONFIG_TARGET_BRPPT1=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index f07a46b78ff8..ff3b0f8107b6 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM33XX=y CONFIG_TARGET_BRPPT1=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 333e2043107f..27a412498084 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM33XX=y CONFIG_TARGET_BRPPT1=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index f558886067e5..7353b2afa8e2 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM33XX=y +CONFIG_TARGET_BRXRE1=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y @@ -57,6 +59,7 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_LCD=y +# CONFIG_OMAP_WATCHDOG is not set CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index d813cc54fb3e..5c5b11446788 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_AM43XX=y CONFIG_TARGET_CM_T43=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 0e50b3109ea2..28fe82ade1c9 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_DRACO=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=300 +CONFIG_TARGET_DRACO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index b6911fd71743..aac8bfac1a0d 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_ETAMIN=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=300 +CONFIG_TARGET_ETAMIN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 67bdfd63f259..4d6e2613a7c2 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_PXM2=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=720 +CONFIG_TARGET_PXM2=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index f77d4d408793..a3adce5776cc 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_RASTABAN=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=300 +CONFIG_TARGET_RASTABAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index f09a67e62c73..8acc7cc0ecf0 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_RUT=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=600 +CONFIG_TARGET_RUT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -73,3 +74,4 @@ CONFIG_G_DNL_PRODUCT_NUM=0x02d2 # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_SYS_CONSOLE_BG_COL=0xff CONFIG_SYS_CONSOLE_FG_COL=0x00 +# CONFIG_OMAP_WATCHDOG is not set diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 914f70fd6a01..4c07de7879de 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -4,8 +4,9 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_TARGET_THUBAN=y +CONFIG_AM33XX=y CONFIG_SYS_MPUCLK=300 +CONFIG_TARGET_THUBAN=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 7907310084e2..8d0e0ea793ca 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -12,7 +12,6 @@ #ifndef __BUR_AM335X_COMMON_H__ #define __BUR_AM335X_COMMON_H__ /* ------------------------------------------------------------------------- */ -#define CONFIG_AM33XX #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
/* Timer information */ diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 1e63098d5f17..7b5ca0db0fe7 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -9,7 +9,6 @@ #ifndef __CONFIG_CM_T43_H #define __CONFIG_CM_T43_H
-#define CONFIG_AM43XX #define CONFIG_CM_T43 #define CONFIG_ARCH_CPU_INIT #define CONFIG_MAX_RAM_BANK_SIZE (2048 << 20) /* 2GB */ @@ -21,7 +20,7 @@ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_CLK 48000000 #define CONFIG_SYS_NS16550_COM1 0x44e09000 -#ifdef CONFIG_SPL_BUILD +#if !defined(CONFIG_SPL_DM) || !defined(CONFIG_DM_SERIAL) #define CONFIG_SYS_NS16550_REG_SIZE (-4) #endif
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index b5705b71693c..21029d10ae99 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -14,8 +14,6 @@ #ifndef __CONFIG_SIEMENS_AM33X_COMMON_H #define __CONFIG_SIEMENS_AM33X_COMMON_H
-#define CONFIG_AM33XX - #include <asm/arch/omap.h>
#define CONFIG_DMA_COHERENT
