[U-Boot] [PATCH-V2 4/4] AM35x: Add support for EMIF4
This patch adds support for the EMIF4 interface available in the AM35x processors.
Signed-off-by: Vaibhav Hiremath hvaibhav@ti.com Signed-off-by: Sanjeev Premi premi@ti.com --- arch/arm/cpu/arm_cortexa8/omap3/Makefile | 3 + arch/arm/cpu/arm_cortexa8/omap3/emif4.c | 168 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap3/cpu.h | 24 ++++ arch/arm/include/asm/arch-omap3/emif4.h | 79 +++++++++++++ arch/arm/include/asm/arch-omap3/sys_proto.h | 3 + 5 files changed, 277 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm_cortexa8/omap3/emif4.c create mode 100644 arch/arm/include/asm/arch-omap3/emif4.h
diff --git a/arch/arm/cpu/arm_cortexa8/omap3/Makefile b/arch/arm/cpu/arm_cortexa8/omap3/Makefile index 8cc7802..0a23fa5 100644 --- a/arch/arm/cpu/arm_cortexa8/omap3/Makefile +++ b/arch/arm/cpu/arm_cortexa8/omap3/Makefile @@ -36,6 +36,9 @@ COBJS += mem.o ifdef CONFIG_SDRC COBJS += sdrc.o endif +ifdef CONFIG_EMIF4 +COBJS += emif4.o +endif COBJS += syslib.o COBJS += sys_info.o COBJS += timer.o diff --git a/arch/arm/cpu/arm_cortexa8/omap3/emif4.c b/arch/arm/cpu/arm_cortexa8/omap3/emif4.c new file mode 100644 index 0000000..749a394 --- /dev/null +++ b/arch/arm/cpu/arm_cortexa8/omap3/emif4.c @@ -0,0 +1,168 @@ +/* + * Author : + * Vaibhav Hiremath hvaibhav@ti.com + * + * Based on mem.c and sdrc.c + * + * Copyright (C) 2010 + * Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mem.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/emif4.h> + +extern omap3_sysinfo sysinfo; + +static emif4_t *emif4_base = (emif4_t *)OMAP34XX_SDRC_BASE; + +/* + * is_mem_sdr - + * - Return 1 if mem type in use is SDR + */ +u32 is_mem_sdr(void) +{ + return 0; +} + +/* + * get_sdr_cs_size - + * - Get size of chip select 0/1 + */ +u32 get_sdr_cs_size(u32 cs) +{ + u32 size; + + /* TODO: Calculate the size based on EMIF4 configuration */ + size = CONFIG_SYS_CS0_SIZE; + + return size; +} + +/* + * get_sdr_cs_offset - + * - Get offset of cs from cs0 start + */ +u32 get_sdr_cs_offset(u32 cs) +{ + u32 offset = 0; + + return offset; +} + +/* + * do_emif4_init - + * - Init the emif4 module for DDR access + * - Early init routines, called from flash or SRAM. + */ +void do_emif4_init(void) +{ + unsigned int regval; + /* Set the DDR PHY parameters in PHY ctrl registers */ + regval = (EMIF4_DDR1_READ_LAT | EMIF4_DDR1_PWRDN_DIS | + EMIF4_DDR1_EXT_STRB_DIS); + writel(regval, &emif4_base->ddr_phyctrl1); + writel(regval, &emif4_base->ddr_phyctrl1_shdw); + writel(0, &emif4_base->ddr_phyctrl2); + + /* Reset the DDR PHY and wait till completed */ + regval = readl(&emif4_base->sdram_iodft_tlgc); + regval |= (1<<10); + writel(regval, &emif4_base->sdram_iodft_tlgc); + /*Wait till that bit clears*/ + while ((readl(&emif4_base->sdram_iodft_tlgc) & (1<<10)) == 0x1); + /*Re-verify the DDR PHY status*/ + while ((readl(&emif4_base->sdram_sts) & (1<<2)) == 0x0); + + regval |= (1<<0); + writel(regval, &emif4_base->sdram_iodft_tlgc); + /* Set SDR timing registers */ + regval = (EMIF4_TIM1_T_WTR | EMIF4_TIM1_T_RRD | + EMIF4_TIM1_T_RC | EMIF4_TIM1_T_RAS | + EMIF4_TIM1_T_WR | EMIF4_TIM1_T_RCD | + EMIF4_TIM1_T_RP); + writel(regval, &emif4_base->sdram_time1); + writel(regval, &emif4_base->sdram_time1_shdw); + + regval = (EMIF4_TIM2_T_CKE | EMIF4_TIM2_T_RTP | + EMIF4_TIM2_T_XSRD | EMIF4_TIM2_T_XSNR | + EMIF4_TIM2_T_ODT | EMIF4_TIM2_T_XP); + writel(regval, &emif4_base->sdram_time2); + writel(regval, &emif4_base->sdram_time2_shdw); + + regval = (EMIF4_TIM3_T_RAS_MAX | EMIF4_TIM3_T_RFC); + writel(regval, &emif4_base->sdram_time3); + writel(regval, &emif4_base->sdram_time3_shdw); + + /* Set the PWR control register */ + regval = (EMIF4_PWR_PM_TIM | EMIF4_PWR_LP_MODE | + EMIF4_PWR_DPD_DIS | EMIF4_PWR_IDLE_MODE); + writel(regval, &emif4_base->sdram_pwr_mgmt); + writel(regval, &emif4_base->sdram_pwr_mgmt_shdw); + + /* Set the DDR refresh rate control register */ + regval = (EMIF4_REFRESH_RATE | EMIF4_INITREF_DIS); + writel(regval, &emif4_base->sdram_refresh_ctrl); + writel(regval, &emif4_base->sdram_refresh_ctrl_shdw); + + /* set the SDRAM configuration register */ + regval = (EMIF4_CFG_PGSIZE | EMIF4_CFG_EBANK | + EMIF4_CFG_IBANK | EMIF4_CFG_ROWSIZE | + EMIF4_CFG_CL | EMIF4_CFG_NARROW_MD | + EMIF4_CFG_SDR_DRV | EMIF4_CFG_DDR_DIS_DLL | + EMIF4_CFG_DDR2_DDQS | EMIF4_CFG_DDR_TERM | + EMIF4_CFG_IBANK_POS | EMIF4_CFG_SDRAM_TYP); + writel(regval, &emif4_base->sdram_config); +} + +/* + * dram_init - + * - Sets uboots idea of sdram size + */ +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned int size0 = 0, size1 = 0; + + size0 = get_sdr_cs_size(CS0); + /* + * If a second bank of DDR is attached to CS1 this is + * where it can be started. Early init code will init + * memory on CS0. + */ + if ((sysinfo.mtype == DDR_COMBO) || (sysinfo.mtype == DDR_STACKED)) + size1 = get_sdr_cs_size(CS1); + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = size0; + gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + get_sdr_cs_offset(CS1); + gd->bd->bi_dram[1].size = size1; + + return 0; +} + +/* + * mem_init() - + * - Initialize memory subsystem + */ +void mem_init(void) +{ + do_emif4_init(); +} diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index a49af10..25668bd 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -217,6 +217,30 @@ struct sdrc { struct sdrc_cs cs[2]; /* 0x80 || 0xB0 */ };
+#elif defined(CONFIG_EMIF4) +/* EMIF4 */ +typedef struct emif4 { + unsigned int sdram_sts; + unsigned int sdram_config; + unsigned int res1; + unsigned int sdram_refresh_ctrl; + unsigned int sdram_refresh_ctrl_shdw; + unsigned int sdram_time1; + unsigned int sdram_time1_shdw; + unsigned int sdram_time2; + unsigned int sdram_time2_shdw; + unsigned int sdram_time3; + unsigned int sdram_time3_shdw; + unsigned char res2[8]; + unsigned int sdram_pwr_mgmt; + unsigned int sdram_pwr_mgmt_shdw; + unsigned char res3[32]; + unsigned int sdram_iodft_tlgc; + unsigned char res4[128]; + unsigned int ddr_phyctrl1; + unsigned int ddr_phyctrl1_shdw; + unsigned int ddr_phyctrl2; +} emif4_t; #endif /* CONFIG_SDRC */ #endif /* __ASSEMBLY__ */ #endif /* __KERNEL_STRICT_NAMES */ diff --git a/arch/arm/include/asm/arch-omap3/emif4.h b/arch/arm/include/asm/arch-omap3/emif4.h new file mode 100644 index 0000000..579da0c --- /dev/null +++ b/arch/arm/include/asm/arch-omap3/emif4.h @@ -0,0 +1,79 @@ +/* + * Auther: + * Vaibhav Hiremath hvaibhav@ti.com + * + * Copyright (C) 2010 + * Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ + +/* + * Configuration values + */ +#define EMIF4_TIM1_T_RP (0x3 << 25) +#define EMIF4_TIM1_T_RCD (0x3 << 21) +#define EMIF4_TIM1_T_WR (0x3 << 17) +#define EMIF4_TIM1_T_RAS (0x8 << 12) +#define EMIF4_TIM1_T_RC (0xA << 6) +#define EMIF4_TIM1_T_RRD (0x2 << 3) +#define EMIF4_TIM1_T_WTR (0x2) + +#define EMIF4_TIM2_T_XP (0x2 << 28) +#define EMIF4_TIM2_T_ODT (0x0 << 25) +#define EMIF4_TIM2_T_XSNR (0x1C << 16) +#define EMIF4_TIM2_T_XSRD (0xC8 << 6) +#define EMIF4_TIM2_T_RTP (0x1 << 3) +#define EMIF4_TIM2_T_CKE (0x2) + +#define EMIF4_TIM3_T_RFC (0x25 << 4) +#define EMIF4_TIM3_T_RAS_MAX (0x7) + +#define EMIF4_PWR_IDLE_MODE (0x2 << 30) +#define EMIF4_PWR_DPD_DIS (0x0 << 10) +#define EMIF4_PWR_DPD_EN (0x1 << 10) +#define EMIF4_PWR_LP_MODE (0x0 << 8) +#define EMIF4_PWR_PM_TIM (0x0) + +#define EMIF4_INITREF_DIS (0x0 << 31) +#define EMIF4_REFRESH_RATE (0x50F) + +#define EMIF4_CFG_SDRAM_TYP (0x2 << 29) +#define EMIF4_CFG_IBANK_POS (0x0 << 27) +#define EMIF4_CFG_DDR_TERM (0x0 << 24) +#define EMIF4_CFG_DDR2_DDQS (0x1 << 23) +#define EMIF4_CFG_DDR_DIS_DLL (0x0 << 20) +#define EMIF4_CFG_SDR_DRV (0x0 << 18) +#define EMIF4_CFG_NARROW_MD (0x0 << 14) +#define EMIF4_CFG_CL (0x5 << 10) +#define EMIF4_CFG_ROWSIZE (0x0 << 7) +#define EMIF4_CFG_IBANK (0x3 << 4) +#define EMIF4_CFG_EBANK (0x0 << 3) +#define EMIF4_CFG_PGSIZE (0x2) + +/* + * EMIF4 PHY Control 1 register configuration + */ +#define EMIF4_DDR1_EXT_STRB_EN (0x1 << 7) +#define EMIF4_DDR1_EXT_STRB_DIS (0x0 << 7) +#define EMIF4_DDR1_PWRDN_DIS (0x0 << 6) +#define EMIF4_DDR1_PWRDN_EN (0x1 << 6) +#define EMIF4_DDR1_READ_LAT (0x6 << 0) + +#endif /* endif _EMIF_H_ */ diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 34e4e0d..7b425be 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -35,6 +35,9 @@ void memif_init(void); void sdrc_init(void); void do_sdrc_init(u32, u32); #endif +#if defined(CONFIG_EMIF4) +void emif4_init(void); +#endif void gpmc_init(void); void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, u32 size); -- 1.6.2.4
Dear hvaibhav@ti.com,
Don't use ifdef, use COBJS-$(CONFIG_EMIF4) instead.
I guess you can omit the #ifdef here, right?
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Thursday, May 06, 2010 1:44 AM To: Hiremath, Vaibhav Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH-V2 4/4] AM35x: Add support for EMIF4
[Hiremath, Vaibhav] Denk,
We have OMAP families supporting both SDRC and EMIF4 (obviously mutually exclusive), so we need to add this #ifdef.
Thanks, Vaibhav
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A failure will not appear until a unit has passed final inspection.
Dear "Hiremath, Vaibhav",
In message 19F8576C6E063C45BE387C64729E7394044E351BE7@dbde02.ent.ti.com you wrote:
We have OMAP families supporting both SDRC and EMIF4 (obviously mutually ex clusive), so we need to add this #ifdef.
What makes you think you need it? Did you try what happens when you just remove the #if/#endif ?
Hiremath, Vaibhav
hvaibhav@ti.com
