[U-Boot] [PATCH 12/17] board_f: powerpc: Move prt_83xx_rsr() to private code
This function is called just before checkcpu() on MPX83xx. Move it to the code for that arch.
arch/powerpc/cpu/mpc83xx/cpu.c | 5 +++++ arch/powerpc/cpu/mpc83xx/cpu_init.c | 1 + arch/powerpc/include/asm/processor.h | 2 ++ common/board_f.c | 3 --- include/common.h | 2 -- 5 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu.c b/arch/powerpc/cpu/mpc83xx/cpu.c index c87f0fdd29..cb82621ec4 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu.c +++ b/arch/powerpc/cpu/mpc83xx/cpu.c @@ -33,6 +33,7 @@ int checkcpu(void) u32 pvr = get_pvr(); u32 spridr; char buf[32]; + int ret; int i;
const struct cpu_type { @@ -61,6 +62,10 @@ int checkcpu(void)
immr = (immap_t *)CONFIG_SYS_IMMR;
+ ret = prt_83xx_rsr(); + if (ret) + return ret; + puts("CPU: ");
switch (pvr & 0xffff0000) { diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 3a0916bdbf..2a9db0c51b 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -8,6 +8,7 @@ #include <mpc83xx.h> #include <ioports.h> #include <asm/io.h> +#include <asm/processor.h> #ifdef CONFIG_USB_EHCI_FSL #include <usb/ehci-ci.h> #endif diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 81bae6f008..c032726df1 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1354,6 +1354,8 @@ void ll_puts(const char *); /* In misc.c */ void _nmask_and_or_msr(unsigned long nmask, unsigned long or_val);
+int prt_83xx_rsr(void); + #endif /* ndef ASSEMBLY*/
#ifdef CONFIG_MACH_SPECIFIC diff --git a/common/board_f.c b/common/board_f.c index cbd9f67709..74cdef0ddb 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -864,9 +864,6 @@ static const init_fnc_t init_sequence_f[] = { prt_8260_rsr, prt_8260_clks, #endif /* CONFIG_MPC8260 */ -#if defined(CONFIG_MPC83xx) - prt_83xx_rsr, -#endif #if defined(CONFIG_PPC) || defined(CONFIG_M68K) || defined(CONFIG_SH) checkcpu, #endif diff --git a/include/common.h b/include/common.h index 684083510b..6f08110b74 100644 --- a/include/common.h +++ b/include/common.h @@ -715,8 +715,6 @@ ulong cpu_init_f(void); int cpu_init_r (void); #if defined(CONFIG_MPC8260) int prt_8260_rsr (void); -#elif defined(CONFIG_MPC83xx) -int prt_83xx_rsr (void); #endif
/* $(CPU)/interrupts.c */
