[PATCH 0/3] binman: Add support for TI_DM entry
This series adds support for the TI_DM entry and moves all K3 platforms to using the same. With this feature introduced, if TI_DM argument is provided binman picks the pathname it provides; else, it defaults to picking up the ti-dm.bin file. This makes it flexible for users to build tispl.bin with custom DM binaries.
Boot logs: https://gist.github.com/nehamalcom/37ce8a32e37ddf3e1afcc4c8bd941159
Neha Malcom Francis (3): binman: etype: dm: Add entry type for TI DM arm: dts: k3-*-binman: Move to using ti-dm entry type doc: board: ti: k3: Mention TI_DM argument
Makefile | 1 + arch/arm/dts/k3-am625-sk-binman.dtsi | 4 ++-- .../dts/k3-am625-verdin-wifi-dev-binman.dtsi | 4 ++-- arch/arm/dts/k3-am62a-sk-binman.dtsi | 4 ++-- arch/arm/dts/k3-j7200-binman.dtsi | 4 ++-- arch/arm/dts/k3-j721e-binman.dtsi | 4 ++-- arch/arm/dts/k3-j721s2-binman.dtsi | 4 ++-- doc/board/ti/k3.rst | 7 ++++++ tools/binman/entries.rst | 14 ++++++++++++ tools/binman/etype/ti_dm.py | 22 +++++++++++++++++++ tools/binman/ftest.py | 7 ++++++ tools/binman/test/225_ti_dm.dts | 13 +++++++++++ 12 files changed, 76 insertions(+), 12 deletions(-) create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/test/225_ti_dm.dts
K3 devices introduces the concept of centralized power, resource and security management to System Firmware. This is to overcome challenges by the traditional approach that implements system control functions on each of the processing units.
The software interface for System Firmware is split into TIFS and DM. DM (Device Manager) is responsible for resource and power management from secure and non-secure hosts. This additional binary is necessary for specific platforms' ROM boot images and is to be packaged into tispl.bin
Add an entry for DM. The entry can be used for the packaging of tispl.bin by binman along with ATF and TEE.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- Makefile | 1 + tools/binman/entries.rst | 14 ++++++++++++++ tools/binman/etype/ti_dm.py | 22 ++++++++++++++++++++++ tools/binman/ftest.py | 7 +++++++ tools/binman/test/225_ti_dm.dts | 13 +++++++++++++ 5 files changed, 57 insertions(+) create mode 100644 tools/binman/etype/ti_dm.py create mode 100644 tools/binman/test/225_ti_dm.dts
diff --git a/Makefile b/Makefile index 1b347f4dfd..7b599ca130 100644 --- a/Makefile +++ b/Makefile @@ -1349,6 +1349,7 @@ cmd_binman = $(srctree)/tools/binman/binman $(if $(BINMAN_DEBUG),-D) \ $(foreach f,$(BINMAN_INDIRS),-I $(f)) \ -a atf-bl31-path=${BL31} \ -a tee-os-path=${TEE} \ + -a ti-dm-path=${TI_DM} \ -a opensbi-path=${OPENSBI} \ -a default-dt=$(default_dt) \ -a scp-path=$(SCP) \ diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 61de7f1f4a..254afe7607 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1906,6 +1906,20 @@ the included board config binaries. Example::
+.. _etype_ti_dm: + +Entry: ti-dm: TI Device Manager (DM) blob +----------------------------------------- + +Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically ti-dm.bin + +This entry holds the device manager responsible for resource and power management +in K3 devices. See https://software-dl.ti.com/tisci/esd/latest/ for more information +about TI DM. + + + .. _etype_ti_secure:
Entry: ti-secure: Entry containing a TI x509 certificate binary diff --git a/tools/binman/etype/ti_dm.py b/tools/binman/etype/ti_dm.py new file mode 100644 index 0000000000..0faa0bf0ca --- /dev/null +++ b/tools/binman/etype/ti_dm.py @@ -0,0 +1,22 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ +# Written by Neha Malcom Francis n-francis@ti.com +# +# Entry-type module for TI Device Manager (DM) +# + +from binman.etype.blob_named_by_arg import Entry_blob_named_by_arg + +class Entry_ti_dm(Entry_blob_named_by_arg): + """TI Device Manager (DM) blob + + Properties / Entry arguments: + - ti-dm-path: Filename of file to read into the entry, typically ti-dm.bin + + This entry holds the device manager responsible for resource and power management + in K3 devices. See https://software-dl.ti.com/tisci/esd/latest/ for more information + about TI DM. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node, 'ti-dm') + self.external = True diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 5ace2a825d..a273120d9f 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -88,6 +88,7 @@ FSP_S_DATA = b'fsp_s' FSP_T_DATA = b'fsp_t' ATF_BL31_DATA = b'bl31' TEE_OS_DATA = b'this is some tee OS data' +TI_DM_DATA = b'tidmtidm' ATF_BL2U_DATA = b'bl2u' OPENSBI_DATA = b'opensbi' SCP_DATA = b'scp' @@ -221,6 +222,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('compress_big', COMPRESS_DATA_BIG) TestFunctional._MakeInputFile('bl31.bin', ATF_BL31_DATA) TestFunctional._MakeInputFile('tee-pager.bin', TEE_OS_DATA) + TestFunctional._MakeInputFile('dm.bin', TI_DM_DATA) TestFunctional._MakeInputFile('bl2u.bin', ATF_BL2U_DATA) TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) @@ -5455,6 +5457,11 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('222_tee_os.dts') self.assertEqual(TEE_OS_DATA, data[:len(TEE_OS_DATA)])
+ def testPackTiDm(self): + """Test that an image with a TI DM binary can be created""" + data = self._DoReadFile('225_ti_dm.dts') + self.assertEqual(TI_DM_DATA, data[:len(TI_DM_DATA)]) + def testFitFdtOper(self): """Check handling of a specified FIT operation""" entry_args = { diff --git a/tools/binman/test/225_ti_dm.dts b/tools/binman/test/225_ti_dm.dts new file mode 100644 index 0000000000..3ab754131e --- /dev/null +++ b/tools/binman/test/225_ti_dm.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + binman { + ti-dm { + filename = "dm.bin"; + }; + }; +};
Move the DM entry in tispl.bin FIT image from default fetching an external blob entry to fetching using ti-dm entry type. This way, the DM entry will be populated by the TI_DM pathname if provided. Else it will resort to the ti-dm.bin file.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am625-sk-binman.dtsi | 4 ++-- arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi | 4 ++-- arch/arm/dts/k3-am62a-sk-binman.dtsi | 4 ++-- arch/arm/dts/k3-j7200-binman.dtsi | 4 ++-- arch/arm/dts/k3-j721e-binman.dtsi | 4 ++-- arch/arm/dts/k3-j721s2-binman.dtsi | 4 ++-- 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi index b7b5368886..5b058bd03a 100644 --- a/arch/arm/dts/k3-am625-sk-binman.dtsi +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -161,7 +161,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -248,7 +248,7 @@ images {
dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; }; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi index ed2c4482ef..78c371529a 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -227,7 +227,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -310,7 +310,7 @@ fit { images { dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; }; diff --git a/arch/arm/dts/k3-am62a-sk-binman.dtsi b/arch/arm/dts/k3-am62a-sk-binman.dtsi index c5e027d44d..ec3bf7ce91 100644 --- a/arch/arm/dts/k3-am62a-sk-binman.dtsi +++ b/arch/arm/dts/k3-am62a-sk-binman.dtsi @@ -164,7 +164,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -250,7 +250,7 @@ fit { images { dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; }; diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi index 10c9d6cba7..38cccabaa7 100644 --- a/arch/arm/dts/k3-j7200-binman.dtsi +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -200,7 +200,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -285,7 +285,7 @@ fit { images { dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; }; diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi index 5ddb474e3a..dbc385a852 100644 --- a/arch/arm/dts/k3-j721e-binman.dtsi +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -151,7 +151,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -282,7 +282,7 @@ fit { images { dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; }; diff --git a/arch/arm/dts/k3-j721s2-binman.dtsi b/arch/arm/dts/k3-j721s2-binman.dtsi index 3922007b3b..f17dd8e04c 100644 --- a/arch/arm/dts/k3-j721s2-binman.dtsi +++ b/arch/arm/dts/k3-j721s2-binman.dtsi @@ -164,7 +164,7 @@ content = <&dm>; keyfile = "custMpk.pem"; }; - dm: blob-ext { + dm: ti-dm { filename = "ti-dm.bin"; }; }; @@ -296,7 +296,7 @@ fit { images { dm { - blob-ext { + ti-dm { filename = "ti-dm.bin"; }; };
Mention TI_DM argument can be used to fetch a custom DM binary in the A72 build instructions for K3 devices.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- doc/board/ti/k3.rst | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index a127215ce5..15916b088f 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -320,6 +320,13 @@ use the `lite` option. make CROSS_COMPILE=$CC64 BINMAN_INDIRS=$LNX_FW_PATH \ BL31=$TFA_PATH/build/k3/$TFA_BOARD/release/bl31.bin \ TEE=$OPTEE_PATH/out/arm-plat-k3/core/tee-raw.bin + +.. note:: + It is also possible to pick up a custom DM binary by adding TI_DM argument + pointing to the file. If not provided, it defaults to picking up the DM + binary from ti-linux-firmware. This is only applicable to devices that + utilize split firmware. + .. k3_rst_include_end_build_steps_uboot
At this point you should have every binary needed initialize both the
+.. note::
- It is also possible to pick up a custom DM binary by adding TI_DM argument
- pointing to the file. If not provided, it defaults to picking up the DM
- binary from ti-linux-firmware. This is only applicable to devices that
It would only be "ti-linux-firmware" if that is what you had set as BINMAN_INDIRS.
s/ti-linux-firmware/BINMAN_INDIRS
Otherwise whole series LGTM,
Reviewed-by: Andrew Davis afd@ti.com
Hi Andrew
Thanks for catching that, will make the change.
.. k3_rst_include_end_build_steps_uboot At this point you should have every binary needed initialize both the
Andrew Davis
Neha Malcom Francis
