[U-Boot] [PATCH 1/5] x86: coreboot: Drop sysinfo.c
sysinfo.c only contains the lib_sysinfo data structure which is used/filled by tables.c. This split was introduced by importing code from libpayload originally, but to keep the code simple, add the single line of actual code to tables.c
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- arch/x86/cpu/coreboot/Makefile | 1 - arch/x86/cpu/coreboot/sysinfo.c | 39 --------------------------------------- arch/x86/cpu/coreboot/tables.c | 8 ++++++++ 3 files changed, 8 insertions(+), 40 deletions(-) delete mode 100644 arch/x86/cpu/coreboot/sysinfo.c
diff --git a/arch/x86/cpu/coreboot/Makefile b/arch/x86/cpu/coreboot/Makefile index fbf5a00..2afd30c 100644 --- a/arch/x86/cpu/coreboot/Makefile +++ b/arch/x86/cpu/coreboot/Makefile @@ -37,7 +37,6 @@ COBJS-$(CONFIG_SYS_COREBOOT) += coreboot.o COBJS-$(CONFIG_SYS_COREBOOT) += tables.o COBJS-$(CONFIG_SYS_COREBOOT) += ipchecksum.o COBJS-$(CONFIG_SYS_COREBOOT) += sdram.o -COBJS-$(CONFIG_SYS_COREBOOT) += sysinfo.o COBJS-$(CONFIG_PCI) += pci.o
SOBJS-$(CONFIG_SYS_COREBOOT) += coreboot_car.o diff --git a/arch/x86/cpu/coreboot/sysinfo.c b/arch/x86/cpu/coreboot/sysinfo.c deleted file mode 100644 index 9b3e660..0000000 --- a/arch/x86/cpu/coreboot/sysinfo.c +++ /dev/null @@ -1,39 +0,0 @@ -/* - * This file is part of the libpayload project. - * - * Copyright (C) 2008 Advanced Micro Devices, Inc. - * Copyright (C) 2009 coresystems GmbH - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * 3. The name of the author may not be used to endorse or promote products - * derived from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE - * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL - * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS - * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT - * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY - * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - */ - -#include <asm/arch-coreboot/sysinfo.h> - -/* - * This needs to be in the .data section so that it's copied over during - * relocation. By default it's put in the .bss section which is simply filled - * with zeroes when transitioning from "ROM", which is really RAM, to other - * RAM. - */ -struct sysinfo_t lib_sysinfo __attribute__((section(".data"))); diff --git a/arch/x86/cpu/coreboot/tables.c b/arch/x86/cpu/coreboot/tables.c index 0e3451b..25ca50d 100644 --- a/arch/x86/cpu/coreboot/tables.c +++ b/arch/x86/cpu/coreboot/tables.c @@ -33,6 +33,14 @@ #include <asm/arch-coreboot/tables.h>
/* + * This needs to be in the .data section so that it's copied over during + * relocation. By default it's put in the .bss section which is simply filled + * with zeroes when transitioning from "ROM", which is really RAM, to other + * RAM. + */ +struct sysinfo_t lib_sysinfo __attribute__((section(".data"))); + +/* * Some of this is x86 specific, and the rest of it is generic. Right now, * since we only support x86, we'll avoid trying to make lots of infrastructure * we don't need. If in the future, we want to use coreboot on some other
Add support for decoding tags for GPIOs, compile/build info, cbmem and other features.
Signed-off-by: Stefan Reinauer reinauer@chromium.org Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Gabe Black gabeblack@chromium.org
Signed-off-by: Simon Glass sjg@chromium.org --- arch/x86/cpu/coreboot/tables.c | 109 ++++++++++++++++++++----- arch/x86/include/asm/arch-coreboot/sysinfo.h | 34 +++++++-- arch/x86/include/asm/arch-coreboot/tables.h | 74 +++++++++++++++++ 3 files changed, 188 insertions(+), 29 deletions(-)
diff --git a/arch/x86/cpu/coreboot/tables.c b/arch/x86/cpu/coreboot/tables.c index 25ca50d..b116d59 100644 --- a/arch/x86/cpu/coreboot/tables.c +++ b/arch/x86/cpu/coreboot/tables.c @@ -28,6 +28,7 @@ * SUCH DAMAGE. */
+#include <common.h> #include <asm/arch-coreboot/ipchecksum.h> #include <asm/arch-coreboot/sysinfo.h> #include <asm/arch-coreboot/tables.h> @@ -80,22 +81,45 @@ static void cb_parse_memory(unsigned char *ptr, struct sysinfo_t *info) static void cb_parse_serial(unsigned char *ptr, struct sysinfo_t *info) { struct cb_serial *ser = (struct cb_serial *)ptr; - if (ser->type != CB_SERIAL_TYPE_IO_MAPPED) - return; - info->ser_ioport = ser->baseaddr; + info->serial = ser; }
-static void cb_parse_optiontable(unsigned char *ptr, struct sysinfo_t *info) +static void cb_parse_vbnv(unsigned char *ptr, struct sysinfo_t *info) { - info->option_table = (struct cb_cmos_option_table *)ptr; + struct cb_vbnv *vbnv = (struct cb_vbnv *)ptr; + + info->vbnv_start = vbnv->vbnv_start; + info->vbnv_size = vbnv->vbnv_size; }
-static void cb_parse_checksum(unsigned char *ptr, struct sysinfo_t *info) +static void cb_parse_gpios(unsigned char *ptr, struct sysinfo_t *info) { - struct cb_cmos_checksum *cmos_cksum = (struct cb_cmos_checksum *)ptr; - info->cmos_range_start = cmos_cksum->range_start; - info->cmos_range_end = cmos_cksum->range_end; - info->cmos_checksum_location = cmos_cksum->location; + int i; + struct cb_gpios *gpios = (struct cb_gpios *)ptr; + + info->num_gpios = (gpios->count < SYSINFO_MAX_GPIOS) ? + (gpios->count) : SYSINFO_MAX_GPIOS; + + for (i = 0; i < info->num_gpios; i++) + info->gpios[i] = gpios->gpios[i]; +} + +static void cb_parse_vdat(unsigned char *ptr, struct sysinfo_t *info) +{ + struct cb_vdat *vdat = (struct cb_vdat *) ptr; + + info->vdat_addr = vdat->vdat_addr; + info->vdat_size = vdat->vdat_size; +} + +static void cb_parse_tstamp(unsigned char *ptr, struct sysinfo_t *info) +{ + info->tstamp_table = ((struct cb_cbmem_tab *)ptr)->cbmem_tab; +} + +static void cb_parse_cbmem_cons(unsigned char *ptr, struct sysinfo_t *info) +{ + info->cbmem_cons = ((struct cb_cbmem_tab *)ptr)->cbmem_tab; }
static void cb_parse_framebuffer(unsigned char *ptr, struct sysinfo_t *info) @@ -103,6 +127,11 @@ static void cb_parse_framebuffer(unsigned char *ptr, struct sysinfo_t *info) info->framebuffer = (struct cb_framebuffer *)ptr; }
+static void cb_parse_string(unsigned char *ptr, char **info) +{ + *info = (char *)((struct cb_string *)ptr)->string; +} + static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) { struct cb_header *header; @@ -133,6 +162,9 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) /* Now, walk the tables. */ ptr += header->header_bytes;
+ /* Inintialize some fields to sentinel values. */ + info->vbnv_start = info->vbnv_size = (uint32_t)(-1); + for (i = 0; i < header->table_entries; i++) { struct cb_record *rec = (struct cb_record *)ptr;
@@ -150,11 +182,35 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) case CB_TAG_SERIAL: cb_parse_serial(ptr, info); break; - case CB_TAG_CMOS_OPTION_TABLE: - cb_parse_optiontable(ptr, info); + case CB_TAG_VERSION: + cb_parse_string(ptr, &info->version); + break; + case CB_TAG_EXTRA_VERSION: + cb_parse_string(ptr, &info->extra_version); + break; + case CB_TAG_BUILD: + cb_parse_string(ptr, &info->build); + break; + case CB_TAG_COMPILE_TIME: + cb_parse_string(ptr, &info->compile_time); + break; + case CB_TAG_COMPILE_BY: + cb_parse_string(ptr, &info->compile_by); + break; + case CB_TAG_COMPILE_HOST: + cb_parse_string(ptr, &info->compile_host); + break; + case CB_TAG_COMPILE_DOMAIN: + cb_parse_string(ptr, &info->compile_domain); + break; + case CB_TAG_COMPILER: + cb_parse_string(ptr, &info->compiler); + break; + case CB_TAG_LINKER: + cb_parse_string(ptr, &info->linker); break; - case CB_TAG_OPTION_CHECKSUM: - cb_parse_checksum(ptr, info); + case CB_TAG_ASSEMBLER: + cb_parse_string(ptr, &info->assembler); break; /* * FIXME we should warn on serial if coreboot set up a @@ -163,6 +219,21 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) case CB_TAG_FRAMEBUFFER: cb_parse_framebuffer(ptr, info); break; + case CB_TAG_GPIO: + cb_parse_gpios(ptr, info); + break; + case CB_TAG_VDAT: + cb_parse_vdat(ptr, info); + break; + case CB_TAG_TIMESTAMPS: + cb_parse_tstamp(ptr, info); + break; + case CB_TAG_CBMEM_CONSOLE: + cb_parse_cbmem_cons(ptr, info); + break; + case CB_TAG_VBNV: + cb_parse_vbnv(ptr, info); + break; }
ptr += rec->size; @@ -174,18 +245,12 @@ static int cb_parse_header(void *addr, int len, struct sysinfo_t *info) /* == Architecture specific == */ /* This is the x86 specific stuff. */
-/* Assume no translation or that memory is identity mapped. */ -static void *phys_to_virt(unsigned long virt) -{ - return (void *)(uintptr_t)virt; -} - int get_coreboot_info(struct sysinfo_t *info) { - int ret = cb_parse_header(phys_to_virt(0x00000000), 0x1000, info); + int ret = cb_parse_header((void *)0x00000000, 0x1000, info);
if (ret != 1) - ret = cb_parse_header(phys_to_virt(0x000f0000), 0x1000, info); + ret = cb_parse_header((void *)0x000f0000, 0x1000, info);
return (ret == 1) ? 0 : -1; } diff --git a/arch/x86/include/asm/arch-coreboot/sysinfo.h b/arch/x86/include/asm/arch-coreboot/sysinfo.h index 5c44e1a..77ae304 100644 --- a/arch/x86/include/asm/arch-coreboot/sysinfo.h +++ b/arch/x86/include/asm/arch-coreboot/sysinfo.h @@ -30,32 +30,52 @@ #ifndef _COREBOOT_SYSINFO_H #define _COREBOOT_SYSINFO_H
+#include <common.h> #include <compiler.h> +#include <fdt.h> +#include <asm/arch/tables.h>
/* Allow a maximum of 16 memory range definitions. */ #define SYSINFO_MAX_MEM_RANGES 16 +/* Allow a maximum of 8 GPIOs */ +#define SYSINFO_MAX_GPIOS 8
struct sysinfo_t { - unsigned int cpu_khz; - unsigned short ser_ioport; - unsigned long ser_base; /* for mmapped serial */ - int n_memranges; - struct memrange { unsigned long long base; unsigned long long size; unsigned int type; } memrange[SYSINFO_MAX_MEM_RANGES];
- struct cb_cmos_option_table *option_table; u32 cmos_range_start; u32 cmos_range_end; u32 cmos_checksum_location; + u32 vbnv_start; + u32 vbnv_size; + + char *version; + char *extra_version; + char *build; + char *compile_time; + char *compile_by; + char *compile_host; + char *compile_domain; + char *compiler; + char *linker; + char *assembler;
struct cb_framebuffer *framebuffer;
- unsigned long *mbtable; /** Pointer to the multiboot table */ + int num_gpios; + struct cb_gpio gpios[SYSINFO_MAX_GPIOS]; + + void *vdat_addr; + u32 vdat_size; + void *tstamp_table; + void *cbmem_cons; + + struct cb_serial *serial; };
extern struct sysinfo_t lib_sysinfo; diff --git a/arch/x86/include/asm/arch-coreboot/tables.h b/arch/x86/include/asm/arch-coreboot/tables.h index c286973..ad34a8b 100644 --- a/arch/x86/include/asm/arch-coreboot/tables.h +++ b/arch/x86/include/asm/arch-coreboot/tables.h @@ -164,6 +164,55 @@ struct cb_framebuffer { u8 reserved_mask_size; };
+#define CB_TAG_GPIO 0x0013 +#define GPIO_MAX_NAME_LENGTH 16 +struct cb_gpio { + u32 port; + u32 polarity; + u32 value; + u8 name[GPIO_MAX_NAME_LENGTH]; +}; + +struct cb_gpios { + u32 tag; + u32 size; + + u32 count; + struct cb_gpio gpios[0]; +}; + +#define CB_TAG_FDT 0x0014 +struct cb_fdt { + uint32_t tag; + uint32_t size; /* size of the entire entry */ + /* the actual FDT gets placed here */ +}; + +#define CB_TAG_VDAT 0x0015 +struct cb_vdat { + uint32_t tag; + uint32_t size; /* size of the entire entry */ + void *vdat_addr; + uint32_t vdat_size; +}; + +#define CB_TAG_TIMESTAMPS 0x0016 +#define CB_TAG_CBMEM_CONSOLE 0x0017 +#define CB_TAG_MRC_CACHE 0x0018 +struct cb_cbmem_tab { + uint32_t tag; + uint32_t size; + void *cbmem_tab; +}; + +#define CB_TAG_VBNV 0x0019 +struct cb_vbnv { + uint32_t tag; + uint32_t size; + uint32_t vbnv_start; + uint32_t vbnv_size; +}; + #define CB_TAG_CMOS_OPTION_TABLE 0x00c8 struct cb_cmos_option_table { u32 tag; @@ -238,4 +287,29 @@ struct sysinfo_t;
int get_coreboot_info(struct sysinfo_t *info);
+#define CBMEM_TOC_RESERVED 512 +#define MAX_CBMEM_ENTRIES 16 +#define CBMEM_MAGIC 0x434f5245 + +struct cbmem_entry { + u32 magic; + u32 id; + u64 base; + u64 size; +} __packed; + +#define CBMEM_ID_FREESPACE 0x46524545 +#define CBMEM_ID_GDT 0x4c474454 +#define CBMEM_ID_ACPI 0x41435049 +#define CBMEM_ID_CBTABLE 0x43425442 +#define CBMEM_ID_PIRQ 0x49525154 +#define CBMEM_ID_MPTABLE 0x534d5054 +#define CBMEM_ID_RESUME 0x5245534d +#define CBMEM_ID_RESUME_SCRATCH 0x52455343 +#define CBMEM_ID_SMBIOS 0x534d4254 +#define CBMEM_ID_TIMESTAMP 0x54494d45 +#define CBMEM_ID_MRCDATA 0x4d524344 +#define CBMEM_ID_CONSOLE 0x434f4e53 +#define CBMEM_ID_NONE 0x00000000 + #endif
This patch builds upon the recently introduced CBMEM console feature of coreboot.
CBMEM console uses a memry area allocated by coreboot to store the console output. The memory area has a certain structure, which allows to determine where the buffer is, the buffer size and the location of the pointer in the buffer. This allows different phases of the firmware (rom based coreboot, ram based coreboot, u-boot after relocation with this change) to keep adding text to the same buffer.
Note that this patch introduces a new console driver and adds the driver to the list of drivers to be used for console output, i.e. it engages only after u-boot relocates. Usiong CBMEM console for capturing the pre-relocation console output will be done under a separate change.
From Linux, run the cbmem.py utility (which is a part of the coreboot
package) to see the output, e.g.:
vvvvvvvvvvvvvvvvv SCSI: AHCI 0001.0300 32 slots 6 ports ? Gbps 0xf impl SATA mode flags: 64bit ilck stag led pmp pio ... Magic signature found Kernel command line: "cros_secure quiet loglevel=1 console=tty2... ^^^^^^^^^^^^^^^^^
Note that the entire u-boot output fits into the buffer only if the coreboot log level is reduced from the most verbose. Ether the buffer size will have to be increased, or the coreboot verbosity permanently reduced.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- common/stdio.c | 4 ++- drivers/misc/Makefile | 1 + drivers/misc/cbmem_console.c | 67 ++++++++++++++++++++++++++++++++++++++++++ include/stdio_dev.h | 3 ++ 4 files changed, 74 insertions(+), 1 deletions(-) create mode 100644 drivers/misc/cbmem_console.c
diff --git a/common/stdio.c b/common/stdio.c index 605ff3f..9f48e5f 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -237,6 +237,8 @@ int stdio_init (void) #ifdef CONFIG_JTAG_CONSOLE drv_jtag_console_init (); #endif - +#ifdef CONFIG_CBMEM_CONSOLE + cbmemc_init(); +#endif return (0); } diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 271463c..a77db3d 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libmisc.o
COBJS-$(CONFIG_ALI152X) += ali512x.o COBJS-$(CONFIG_DS4510) += ds4510.o +COBJS-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o COBJS-$(CONFIG_FSL_LAW) += fsl_law.o COBJS-$(CONFIG_GPIO_LED) += gpio_led.o COBJS-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o diff --git a/drivers/misc/cbmem_console.c b/drivers/misc/cbmem_console.c new file mode 100644 index 0000000..80a84fd --- /dev/null +++ b/drivers/misc/cbmem_console.c @@ -0,0 +1,67 @@ +/* + * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA, 02110-1301 USA + */ + +#include <common.h> + +#ifndef CONFIG_SYS_COREBOOT +#error This driver requires coreboot +#endif + +#include <asm/arch/sysinfo.h> + +struct cbmem_console { + u32 buffer_size; + u32 buffer_cursor; + u8 buffer_body[0]; +} __attribute__ ((__packed__)); + +static struct cbmem_console *cbmem_console_p; + +void cbmemc_putc(char data) +{ + int cursor; + + cursor = cbmem_console_p->buffer_cursor++; + if (cursor < cbmem_console_p->buffer_size) + cbmem_console_p->buffer_body[cursor] = data; +} + +void cbmemc_puts(const char *str) +{ + char c; + + while ((c = *str++) != 0) + cbmemc_putc(c); +} + +int cbmemc_init(void) +{ + int rc; + struct stdio_dev cons_dev; + cbmem_console_p = lib_sysinfo.cbmem_cons; + + memset(&cons_dev, 0, sizeof(cons_dev)); + + strcpy(cons_dev.name, "cbmem"); + cons_dev.flags = DEV_FLAGS_OUTPUT; /* Output only */ + cons_dev.putc = cbmemc_putc; + cons_dev.puts = cbmemc_puts; + + rc = stdio_register(&cons_dev); + + return (rc == 0) ? 1 : rc; +} diff --git a/include/stdio_dev.h b/include/stdio_dev.h index 23e0ee1..932d093 100644 --- a/include/stdio_dev.h +++ b/include/stdio_dev.h @@ -120,5 +120,8 @@ int drv_nc_init (void); #ifdef CONFIG_JTAG_CONSOLE int drv_jtag_console_init (void); #endif +#ifdef CONFIG_CBMEM_CONSOLE +int cbmemc_init(void); +#endif
#endif
This command is useful to allow to observe messages generated by coreboot and u-boot until present. In particular it is handy when u-boot is instrumented to fall through into console mode on startup errors.
Signed-off-by: Vadim Bendebury vbendeb@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- drivers/misc/cbmem_console.c | 26 ++++++++++++++++++++++++++ 1 files changed, 26 insertions(+), 0 deletions(-)
diff --git a/drivers/misc/cbmem_console.c b/drivers/misc/cbmem_console.c index 80a84fd..35c3cb1 100644 --- a/drivers/misc/cbmem_console.c +++ b/drivers/misc/cbmem_console.c @@ -31,10 +31,19 @@ struct cbmem_console {
+/* + * Need to be able to avoid adding charactes to cbmem console buffer while its + * contents are being dumped. + */ +static int suppress_cbmem_console; + void cbmemc_putc(char data) { int cursor;
+ if (suppress_cbmem_console) + return; + cursor = cbmem_console_p->buffer_cursor++; if (cursor < cbmem_console_p->buffer_size) cbmem_console_p->buffer_body[cursor] = data; @@ -65,3 +74,20 @@ int cbmemc_init(void)
return (rc == 0) ? 1 : rc; } + +static int +do_cbc_dump(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int cursor = 0; + + suppress_cbmem_console = 1; + + while (cursor < cbmem_console_p->buffer_cursor) + putc(cbmem_console_p->buffer_body[cursor++]); + + suppress_cbmem_console = 0; + return 0; +} + +U_BOOT_CMD(cbc_dump, 1, 1, do_cbc_dump, + "dump CBMEM console buffer to serial port", NULL);
We want to support VGA, serial, USB keyboard and the Coreboot memory console buffer.
Signed-off-by: Simon Glass sjg@chromium.org --- include/configs/coreboot.h | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/include/configs/coreboot.h b/include/configs/coreboot.h index 2649b82..fe589f3 100644 --- a/include/configs/coreboot.h +++ b/include/configs/coreboot.h @@ -39,6 +39,10 @@ #define CONFIG_LAST_STAGE_INIT #define CONFIG_NO_RESET_CODE
+#define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,vga,serial\0" \ + "stdout=vga,serial,cbmem\0" \ + "stderr=vga,serial,cbmem\0" + /*----------------------------------------------------------------------- * Watchdog Configuration */ @@ -70,6 +74,9 @@ #define CONFIG_SYS_NS16550_COM2 UART1_BASE #define CONFIG_SYS_NS16550_PORT_MAPPED
+#define CONFIG_CONSOLE_MUX +#define CONFIG_CBMEM_CONSOLE + /* max. 1 IDE bus */ #define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 drive per IDE bus */
