[U-Boot] [UBOOT][PATCHv6 0/6] Add TI qspi controller with memory mapped support.
This patch series add support for TI qspi controller and in the process also add support for quad read and memory mapped read in mtd spi framework.
Testing details: Did a boot from qspi mode on DRA7xx. Testing details present in the last patch of the series.
Currently, TI qpsi controller supports only 16MB access. Access for higher MB area will be added later.
Patches are available at: git://gitorious.org/u-boot-shared/u-boot-qspi.git qspi_v7
Matt Porter (3): omap5: add qspi support spi: add TI QSPI driver dra7xx_evm: add SPL API, QSPI, and serial flash support
Sourav Poddar (3): armv7: hw_data: change clock divider setting. sf: Add memory mapped read support README: qspi usecase and testing documentation.
arch/arm/cpu/armv7/omap5/hw_data.c | 10 +- arch/arm/cpu/armv7/omap5/prcm-regs.c | 1 + arch/arm/include/asm/arch-omap5/omap.h | 3 + arch/arm/include/asm/arch-omap5/spl.h | 1 + arch/arm/include/asm/omap_common.h | 1 + board/ti/dra7xx/mux_data.h | 10 + doc/SPI/README.ti_qspi_dra_test | 48 +++++ doc/SPI/README.ti_qspi_flash | 47 +++++ drivers/mtd/spi/sf_ops.c | 2 + drivers/mtd/spi/sf_probe.c | 1 + drivers/spi/Makefile | 1 + drivers/spi/ti_qspi.c | 311 ++++++++++++++++++++++++++++++++ include/configs/dra7xx_evm.h | 19 ++ include/spi.h | 3 + 14 files changed, 457 insertions(+), 1 deletions(-) create mode 100644 doc/SPI/README.ti_qspi_dra_test create mode 100644 doc/SPI/README.ti_qspi_flash create mode 100644 drivers/spi/ti_qspi.c
Add QSPI definitions and clock configuration support.
Signed-off-by: Matt Porter matt.porter@linaro.org Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- arch/arm/cpu/armv7/omap5/hw_data.c | 8 ++++++++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 1 + arch/arm/include/asm/arch-omap5/omap.h | 3 +++ arch/arm/include/asm/arch-omap5/spl.h | 1 + arch/arm/include/asm/omap_common.h | 1 + 5 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index fbbc486..c00bfb8 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -426,6 +426,10 @@ void enable_basic_clocks(void) #ifdef CONFIG_DRIVER_TI_CPSW (*prcm)->cm_gmac_gmac_clkctrl, #endif + +#ifdef CONFIG_TI_QSPI + (*prcm)->cm_l4per_qspi_clkctrl, +#endif 0 };
@@ -454,6 +458,10 @@ void enable_basic_clocks(void) clk_modules_explicit_en_essential, 1);
+#ifdef CONFIG_TI_QSPI + setbits_le32((*prcm)->cm_l4per_qspi_clkctrl, (1<<24)); +#endif + /* Enable SCRM OPT clocks for PER and CORE dpll */ setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_PER_MASK); diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index 579818d..0b1bb46 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -933,6 +933,7 @@ struct prcm_regs const dra7xx_prcm = { .cm_l4per_gpio8_clkctrl = 0x4a009818, .cm_l4per_mmcsd3_clkctrl = 0x4a009820, .cm_l4per_mmcsd4_clkctrl = 0x4a009828, + .cm_l4per_qspi_clkctrl = 0x4a009838, .cm_l4per_uart1_clkctrl = 0x4a009840, .cm_l4per_uart2_clkctrl = 0x4a009848, .cm_l4per_uart3_clkctrl = 0x4a009850, diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index e9a51d3..414d37a 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -61,6 +61,9 @@ /* GPMC */ #define OMAP54XX_GPMC_BASE 0x50000000
+/* QSPI */ +#define QSPI_BASE 0x4B300000 + /* * Hardware Register Details */ diff --git a/arch/arm/include/asm/arch-omap5/spl.h b/arch/arm/include/asm/arch-omap5/spl.h index fe8b0c0..57f0de5 100644 --- a/arch/arm/include/asm/arch-omap5/spl.h +++ b/arch/arm/include/asm/arch-omap5/spl.h @@ -15,6 +15,7 @@ #define BOOT_DEVICE_MMC1 5 #define BOOT_DEVICE_MMC2 6 #define BOOT_DEVICE_MMC2_2 7 +#define BOOT_DEVICE_SPI 10
#define MMC_BOOT_DEVICES_START BOOT_DEVICE_MMC1 #define MMC_BOOT_DEVICES_END BOOT_DEVICE_MMC2_2 diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 5e2f027..f865c14 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -266,6 +266,7 @@ struct prcm_regs { u32 cm_l4per_mmcsd4_clkctrl; u32 cm_l4per_msprohg_clkctrl; u32 cm_l4per_slimbus2_clkctrl; + u32 cm_l4per_qspi_clkctrl; u32 cm_l4per_uart1_clkctrl; u32 cm_l4per_uart2_clkctrl; u32 cm_l4per_uart3_clkctrl;
Clock requirement for qspi clk is 192 Mhz. According to the below formulae,
f dpll = f ref * 2 * m /(n + 1) clockoutx2_Hmn = f dpll / (hmn+ 1)
fref = 20 Mhz, m = 96, n = 4 gives f dpll = 768 Mhz For clockoutx2_Hmn to be 768, hmn + 1 should be 4.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- arch/arm/cpu/armv7/omap5/hw_data.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index c00bfb8..a1b249e 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -170,7 +170,7 @@ static const struct dpll_params per_dpll_params_768mhz_es2[NUM_SYS_CLKS] = {
static const struct dpll_params per_dpll_params_768mhz_dra7xx[NUM_SYS_CLKS] = { {32, 0, 4, 1, 3, 4, 10, 2, -1, -1, -1, -1}, /* 12 MHz */ - {96, 4, 4, 1, 3, 4, 10, 2, -1, -1, -1, -1}, /* 20 MHz */ + {96, 4, 4, 1, 3, 4, 4, 2, -1, -1, -1, -1}, /* 20 MHz */ {160, 6, 4, 1, 3, 4, 10, 2, -1, -1, -1, -1}, /* 16.8 MHz */ {20, 0, 4, 1, 3, 4, 10, 2, -1, -1, -1, -1}, /* 19.2 MHz */ {192, 12, 4, 1, 3, 4, 10, 2, -1, -1, -1, -1}, /* 26 MHz */
Qspi controller can have a memory mapped port which can be used for data read. Added support to enable memory mapped port read.
This patch enables the following: - It enables exchange of memory map address between mtd and qspi through the introduction of "memory_map" flag. - Add support to communicate to the driver that memory mapped transfer is to be started through introduction of new flags like "SPI_XFER_MEM_MAP" and "SPI_XFER_MEM_MAP_END".
This will enable the spi controller to do memory mapped configurations if required.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- v5->v6: Add proper tab space drivers/mtd/spi/sf_ops.c | 2 ++ drivers/mtd/spi/sf_probe.c | 1 + include/spi.h | 3 +++ 3 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index c009af5..2396e22 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -269,7 +269,9 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset,
/* Handle memory-mapped SPI */ if (flash->memory_map) { + spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP); memcpy(data, flash->memory_map + offset, len); + spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP_END); return 0; }
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 1525636..6aa7086 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -203,6 +203,7 @@ struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, u8 *idcode) flash->page_size = (ext_jedec == 0x4d00) ? 512 : 256; flash->sector_size = params->sector_size; flash->size = flash->sector_size * params->nr_sectors; + flash->memory_map = spi->memory_map;
/* Compute erase sector and command */ if (params->flags & SECT_4K) { diff --git a/include/spi.h b/include/spi.h index c44ebe8..c2086fc 100644 --- a/include/spi.h +++ b/include/spi.h @@ -27,6 +27,8 @@ /* SPI transfer flags */ #define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ #define SPI_XFER_END 0x02 /* Deassert CS after transfer */ +#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ +#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */
/* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec @@ -46,6 +48,7 @@ struct spi_slave { unsigned int bus; unsigned int cs; unsigned int max_write_size; + void *memory_map; };
Adds a SPI master driver for the TI QSPI peripheral. - Added quad read support. - Added memory mapped support.
Signed-off-by: Matt Porter matt.porter@linaro.org Signed-off-by: Sourav Poddar sourav.poddar@ti.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- v5->v6: - Added ti related comments - Created ti spec func for ti code - Fixed few checkpatch.pl errors - Rearranged the code.
drivers/spi/Makefile | 1 + drivers/spi/ti_qspi.c | 311 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 312 insertions(+), 0 deletions(-) create mode 100644 drivers/spi/ti_qspi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 91d24ce..e5941b0 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_FDT_SPI) += fdt_spi.o COBJS-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o COBJS-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o COBJS-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o +COBJS-$(CONFIG_TI_QSPI) += ti_qspi.o COBJS-$(CONFIG_XILINX_SPI) += xilinx_spi.o COBJS-$(CONFIG_ZYNQ_SPI) += zynq_spi.o
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c new file mode 100644 index 0000000..5a5b482 --- /dev/null +++ b/drivers/spi/ti_qspi.c @@ -0,0 +1,311 @@ +/* + * TI QSPI driver + * + * Copyright (C) 2013, Texas Instruments, Incorporated + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/omap.h> +#include <malloc.h> +#include <spi.h> + +/* ti qpsi register bit masks */ +#define QSPI_TIMEOUT 2000000 +#define QSPI_FCLK 192000000 +/* clock control */ +#define QSPI_CLK_EN (1 << 31) +#define QSPI_CLK_DIV_MAX 0xffff +/* command */ +#define QSPI_EN_CS(n) (n << 28) +#define QSPI_WLEN(n) ((n-1) << 19) +#define QSPI_3_PIN (1 << 18) +#define QSPI_RD_SNGL (1 << 16) +#define QSPI_WR_SNGL (2 << 16) +#define QSPI_INVAL (4 << 16) +#define QSPI_RD_QUAD (7 << 16) +/* device control */ +#define QSPI_DD(m, n) (m << (3 + n*8)) +#define QSPI_CKPHA(n) (1 << (2 + n*8)) +#define QSPI_CSPOL(n) (1 << (1 + n*8)) +#define QSPI_CKPOL(n) (1 << (n*8)) +/* status */ +#define QSPI_WC (1 << 1) +#define QSPI_BUSY (1 << 0) +#define QSPI_WC_BUSY (QSPI_WC | QSPI_BUSY) +#define QSPI_XFER_DONE QSPI_WC +#define MM_SWITCH 0x01 +#define MEM_CS 0x100 +#define MEM_CS_UNSELECT 0xfffff0ff +#define MMAP_START_ADDR 0x5c000000 +#define CORE_CTRL_IO 0x4a002558 + +#define QSPI_CMD_READ (0x3 << 0) +#define QSPI_CMD_READ_QUAD (0x6b << 0) +#define QSPI_CMD_READ_FAST (0x0b << 0) +#define QSPI_SETUP0_NUM_A_BYTES (0x2 << 8) +#define QSPI_SETUP0_NUM_D_BYTES_NO_BITS (0x0 << 10) +#define QSPI_SETUP0_NUM_D_BYTES_8_BITS (0x1 << 10) +#define QSPI_SETUP0_READ_NORMAL (0x0 << 12) +#define QSPI_SETUP0_READ_QUAD (0x3 << 12) +#define QSPI_CMD_WRITE (0x2 << 16) +#define QSPI_NUM_DUMMY_BITS (0x0 << 24) + +/* ti qspi register set */ +struct ti_qspi_regs { + u32 pid; + u32 pad0[3]; + u32 sysconfig; + u32 pad1[3]; + u32 int_stat_raw; + u32 int_stat_en; + u32 int_en_set; + u32 int_en_ctlr; + u32 intc_eoi; + u32 pad2[3]; + u32 clk_ctrl; + u32 dc; + u32 cmd; + u32 status; + u32 data; + u32 setup0; + u32 setup1; + u32 setup2; + u32 setup3; + u32 memswitch; + u32 data1; + u32 data2; + u32 data3; +}; + +/* ti qspi slave */ +struct ti_qspi_slave { + struct spi_slave slave; + struct ti_qspi_regs *base; + unsigned int mode; + u32 cmd; + u32 dc; +}; + +static inline struct ti_qspi_slave *to_ti_qspi_slave(struct spi_slave *slave) +{ + return container_of(slave, struct ti_qspi_slave, slave); +} + +static void ti_spi_setup_spi_register(struct ti_qspi_slave *qslave) +{ + struct spi_slave *slave = &qslave->slave; + u32 memval = 0; + + slave->memory_map = (void *)MMAP_START_ADDR; + + memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | + QSPI_SETUP0_NUM_D_BYTES_NO_BITS | + QSPI_SETUP0_READ_NORMAL | QSPI_CMD_WRITE | + QSPI_NUM_DUMMY_BITS; + + writel(memval, &qslave->base->setup0); +} + +static void ti_spi_set_speed(struct spi_slave *slave, uint hz) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + uint clk_div; + + debug("ti_spi_set_speed: hz: %d, clock divider %d\n", hz, clk_div); + + if (!hz) + clk_div = 0; + else + clk_div = (QSPI_FCLK / hz) - 1; + + /* disable SCLK */ + writel(readl(&qslave->base->clk_ctrl) & ~QSPI_CLK_EN, + &qslave->base->clk_ctrl); + + /* assign clk_div values */ + if (clk_div < 0) + clk_div = 0; + else if (clk_div > QSPI_CLK_DIV_MAX) + clk_div = QSPI_CLK_DIV_MAX; + + /* enable SCLK */ + writel(QSPI_CLK_EN | clk_div, &qslave->base->clk_ctrl); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + /* CS handled in xfer */ + return; +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + + debug("spi_cs_deactivate: 0x%08x\n", (u32)slave); + + writel(qslave->cmd | QSPI_INVAL, &qslave->base->cmd); +} + +void spi_init(void) +{ + /* nothing to do */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct ti_qspi_slave *qslave; + + qslave = spi_alloc_slave(struct ti_qspi_slave, bus, cs); + if (!qslave) { + printf("SPI_error: Fail to allocate ti_qspi_slave\n"); + return NULL; + } + + qslave->base = (struct ti_qspi_regs *)QSPI_BASE; + qslave->mode = mode; + + ti_spi_set_speed(&qslave->slave, max_hz); + +#ifdef CONFIG_TI_SPI_MMAP + ti_spi_setup_spi_register(qslave); +#endif + + return &qslave->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + free(qslave); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + + debug("spi_claim_bus: bus:%i cs:%i\n", slave->bus, slave->cs); + + qslave->dc = 0; + if (qslave->mode & SPI_CPHA) + qslave->dc |= QSPI_CKPHA(slave->cs); + if (qslave->mode & SPI_CPOL) + qslave->dc |= QSPI_CKPOL(slave->cs); + if (qslave->mode & SPI_CS_HIGH) + qslave->dc |= QSPI_CSPOL(slave->cs); + + writel(qslave->dc, &qslave->base->dc); + writel(0, &qslave->base->cmd); + writel(0, &qslave->base->data); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + + debug("spi_release_bus: bus:%i cs:%i\n", slave->bus, slave->cs); + + writel(0, &qslave->base->dc); + writel(0, &qslave->base->cmd); + writel(0, &qslave->base->data); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct ti_qspi_slave *qslave = to_ti_qspi_slave(slave); + uint words = bitlen >> 3; /* fixed 8-bit word length */ + const uchar *txp = dout; + uchar *rxp = din; + uint status; + int timeout, val; + + debug("spi_xfer: bus:%i cs:%i bitlen:%i words:%i flags:%lx\n", + slave->bus, slave->cs, bitlen, words, flags); + + /* Setup mmap flags */ + if (flags & SPI_XFER_MMAP) { + writel(MM_SWITCH, &qslave->base->memswitch); + val = readl(CORE_CTRL_IO); + val |= MEM_CS; + writel(val, CORE_CTRL_IO); + return 0; + } else if (flags & SPI_XFER_MMAP_END) { + writel(~MM_SWITCH, &qslave->base->memswitch); + val = readl(CORE_CTRL_IO); + val &= MEM_CS_UNSELECT; + writel(val, CORE_CTRL_IO); + return 0; + } + + if (bitlen == 0) + return -1; + + if (bitlen % 8) { + debug("spi_xfer: Non byte aligned SPI transfer\n"); + return -1; + } + + /* Setup command reg */ + qslave->cmd = 0; + qslave->cmd |= QSPI_WLEN(8); + qslave->cmd |= QSPI_EN_CS(slave->cs); + if (flags & SPI_3WIRE) + qslave->cmd |= QSPI_3_PIN; + qslave->cmd |= 0xfff; + + while (words--) { + if (txp) { + debug("tx cmd %08x dc %08x data %02x\n", + qslave->cmd | QSPI_WR_SNGL, qslave->dc, *txp); + writel(*txp++, &qslave->base->data); + writel(qslave->cmd | QSPI_WR_SNGL, + &qslave->base->cmd); + status = readl(&qslave->base->status); + timeout = QSPI_TIMEOUT; + while ((status & QSPI_WC_BUSY) != QSPI_XFER_DONE) { + if (--timeout < 0) { + printf("spi_xfer: TX timeout!\n"); + return -1; + } + status = readl(&qslave->base->status); + } + debug("tx done, status %08x\n", status); + } + if (rxp) { + qslave->cmd |= QSPI_RD_SNGL; + debug("rx cmd %08x dc %08x\n", + qslave->cmd, qslave->dc); + writel(qslave->cmd, &qslave->base->cmd); + status = readl(&qslave->base->status); + timeout = QSPI_TIMEOUT; + while ((status & QSPI_WC_BUSY) != QSPI_XFER_DONE) { + if (--timeout < 0) { + printf("spi_xfer: RX timeout!\n"); + return -1; + } + status = readl(&qslave->base->status); + } + *rxp++ = readl(&qslave->base->data); + debug("rx done, status %08x, read %02x\n", + status, *(rxp-1)); + } + } + + /* Terminate frame */ + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return 0; +}
Enables support for SPI SPL, QSPI and Spansion serial flash device on the EVM. Configures pin muxes for QSPI mode.
Signed-off-by: Matt Porter matt.porter@linaro.org Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- v5->v6: change MMAP name to amore readable name. board/ti/dra7xx/mux_data.h | 10 ++++++++++ include/configs/dra7xx_evm.h | 19 +++++++++++++++++++ 2 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/board/ti/dra7xx/mux_data.h b/board/ti/dra7xx/mux_data.h index 0a86594..6965cc5 100644 --- a/board/ti/dra7xx/mux_data.h +++ b/board/ti/dra7xx/mux_data.h @@ -51,5 +51,15 @@ const struct pad_conf_entry core_padconf_array_essential[] = { {RGMII0_RXD2, (IEN | M0) }, {RGMII0_RXD1, (IEN | M0) }, {RGMII0_RXD0, (IEN | M0) }, + {GPMC_A13, (IEN | PDIS | M1)}, /* QSPI1_RTCLK */ + {GPMC_A14, (IEN | PDIS | M1)}, /* QSPI1_D[3] */ + {GPMC_A15, (IEN | PDIS | M1)}, /* QSPI1_D[2] */ + {GPMC_A16, (IEN | PDIS | M1)}, /* QSPI1_D[1] */ + {GPMC_A17, (IEN | PDIS | M1)}, /* QSPI1_D[0] */ + {GPMC_A18, (M1)}, /* QSPI1_SCLK */ + {GPMC_A3, (IEN | PDIS | M1)}, /* QSPI1_CS2 */ + {GPMC_A4, (IEN | PDIS | M1)}, /* QSPI1_CS3 */ + {GPMC_CS2, (IEN | PTU | PDIS | M1)}, /* QSPI1_CS0 */ + {GPMC_CS3, (IEN | PTU | PDIS | M1)}, /* QSPI1_CS1*/ }; #endif /* _MUX_DATA_DRA7XX_H_ */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 4fbe768..f9cfd18 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -42,4 +42,23 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ADDR 2
+/* SPI */ +#undef CONFIG_OMAP3_SPI +#define CONFIG_TI_QSPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#define CONFIG_TI_SPI_MMAP +#define CONFIG_SF_DEFAULT_SPEED 48000000 +#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3 + +/* SPI SPL */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_BUS 0 +#define CONFIG_SPL_SPI_CS 0 +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 + #endif /* __CONFIG_DRA7XX_EVM_H */
Contains documentation and testing details for qspi flash interface.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- doc/SPI/README.ti_qspi_dra_test | 48 +++++++++++++++++++++++++++++++++++++++ doc/SPI/README.ti_qspi_flash | 47 ++++++++++++++++++++++++++++++++++++++ 2 files changed, 95 insertions(+), 0 deletions(-) create mode 100644 doc/SPI/README.ti_qspi_dra_test create mode 100644 doc/SPI/README.ti_qspi_flash
diff --git a/doc/SPI/README.ti_qspi_dra_test b/doc/SPI/README.ti_qspi_dra_test new file mode 100644 index 0000000..fe37857 --- /dev/null +++ b/doc/SPI/README.ti_qspi_dra_test @@ -0,0 +1,48 @@ +------------------------------------------------- + Simple steps used to test the QSPI at U-Boot +------------------------------------------------- + +For #1, build the patched U-Boot and load MLO/u-boot.img + +---------------------------------- +Boot from another medium like MMC +---------------------------------- + +U-Boot# mmc dev 0 +mmc0 is current device +U-Boot# fatload mmc 0 0x82000000 MLO +reading MLO +55872 bytes read in 8 ms (6.7 MiB/s) +U-Boot# fatload mmc 0 0x83000000 u-boot.img +reading u-boot.img +248600 bytes read in 19 ms (12.5 MiB/s) + +-------------------------------------------------- +Commands to erase/write u-boot/mlo to flash device +-------------------------------------------------- +U-Boot# sf probe 0 +SF: Detected S25FL256S_64K with page size 256 Bytes, erase size 64 KiB, total 32 MiB, mapped at 5c000000 +SF: Warning - Only lower 16MiB accessible, Full access #define CONFIG_SPI_FLASH_BAR +U-Boot# sf erase 0 0x10000 +SF: 65536 bytes @ 0x0 Erased: OK +U-Boot# sf erase 0x20000 0x10000 +SF: 65536 bytes @ 0x20000 Erased: OK +U-Boot# sf erase 0x30000 0x10000 +SF: 65536 bytes @ 0x30000 Erased: OK +U-Boot# sf erase 0x40000 0x10000 +SF: 65536 bytes @ 0x40000 Erased: OK +U-Boot# sf erase 0x50000 0x10000 +SF: 65536 bytes @ 0x50000 Erased: OK +U-Boot# sf erase 0x60000 0x10000 +SF: 65536 bytes @ 0x60000 Erased: OK +U-Boot# sf write 82000000 0 0x10000 +SF: 65536 bytes @ 0x0 Written: OK +U-Boot# sf write 83000000 0x20000 0x60000 +SF: 393216 bytes @ 0x20000 Written: OK + +For #2, set sysboot to QSPI-1 boot mode(SYSBOOT[5:0] = 100110) and power +on. ROM should find the GP header at offset 0 and load/execute SPL. SPL +then detects that ROM was in QSPI-1 mode (boot code 10) and attempts to +find a U-Boot image header at offset 0x20000 (set in the config file) +and proceeds to load that image using the U-Boot image payload offset/size +from the header. It will then start U-Boot. diff --git a/doc/SPI/README.ti_qspi_flash b/doc/SPI/README.ti_qspi_flash new file mode 100644 index 0000000..1b86d01 --- /dev/null +++ b/doc/SPI/README.ti_qspi_flash @@ -0,0 +1,47 @@ +QSPI U-boot support +------------------ + +Host processor is connected to serial flash device via qpsi +interface. QSPI is a kind of spi module that allows single, +dual and quad read access to external spi devices. The module +has a memory mapped interface which provide direct interface +for accessing data form external spi devices. + +The one QSPI in the device is primarily intended for fast booting +from Quad SPI flash devices. + +Usecase +------- + +MLO/u-boot.img will be flashed from SD/MMC to the flash device +using serial flash erase and write commands. Then, switch settings +will be changed to qspi boot. Then, the ROM code will read MLO +from the predefined location in the flash, where it was flashed and +execute it after storing it in SDRAM. Then, the MLO will read +u-boot.img from flash and execute it from SDRAM. + +SPI mode +------- +SPI mode uses mtd spi framework for transfer and reception of data. +Can be used in: +1. Normal mode: use single pin for transfers +2. Dual Mode: use two pins for transfers. +3. Quad mode: use four pin for transfer + +Memory mapped read mode +----------------------- +In this, SPI controller is configured using configuration port and then +controler is switched to memory mapped port for data read. + +Driver +------ +drivers/qspi/ti_qspi.c + - Newly created file which is responsible for configuring the + qspi controller and also for providing the low level api which + is responsible for transferring the datas from host controller + to flash device and vice versa. + +Testing +------- +A seperated file named README.dra_qspi_test has been created which gives all the +details about the commands required to test qspi at u-boot level.
Applied to u-boot-spi/master
Thanks!
Jagan Teki
Sourav Poddar
