[PATCH v1 2/3] configs: pico-imx6ul: convert DM_VIDEO
Fix compile warning messages.
Signed-off-by: Wig Cheng wig.cheng@technexion.com --- configs/pico-imx6ul_defconfig | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index e8cbf3bc1e..f02d370b7d 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -75,4 +75,8 @@ CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_PCI_DEFAULT_FB_SIZE=0x0 +# CONFIG_CMD_VIDCONSOLE is not set +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set
Why is this one needed?
It shows warning messages after compiled:
===================== WARNING ====================== This board does not use CONFIG_DM_VIDEO Please update the board to use CONFIG_DM_VIDEO before the v2019.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Enable DM_VIDEO will be solved this warning although there's no difference no matter enable DM_VIDEO or not on runtime level, just for warning message.
I'll improve the commit log if you think it's okay, thanks a lot.
Yes, with the improved commit log and removing CONFIG_VIDEO_PCI_DEFAULT_FB_SIZE=0x0 the patch will be good.
Thanks
One more thing: you did a good job in writing the commit logs for the other patches, but this one needs to be improved.
Fabio Estevam
wig
