Hi Tom,
I notice that the runners are not utilised much by the QEMU jobs, since we only run one at a time.
I wonder if we could improve this, perhaps by using a different tag for the QEMU ones and then having a machine that only runs those (and runs 40 in parallel)?
In general our use of the runners seems a bit primitive, since the main use of parallelism is in the world builds.
On Sat, Aug 12, 2023 at 09:14:45PM -0600, Simon Glass wrote:
Hi Tom,
I'm honestly not sure. I think there's a few tweaks that we should do, like putting the opensbi and coreboot files in to the Dockerfile logic instead. And maybe seeing if just like we can have a docker registry cache, if we can setup local pypi cache too? I'm not otherwise sure what's taking 23 seconds or so of https://source.denx.de/u-boot/u-boot/-/jobs/673565#L34 since the build and run parts aren't much.
My first big worry about running 2 or 3 qemu jobs at the same time on a host is that any wins get from a shorter queue will be lost to buildman doing "make -j$(nproc)" 2 or 3 times at once and so we build slower.
My second big worry is that getting the right tags on runners will be a little tricky.
My third big worry (but this is something you can test easy enough at least) is that running the big sandbox tests, 2 or 3 times at once on the same host will get much slower. I think, but profiling would be helpful, that those get slow due to I/O and not CPU.
Hi Tom,
Hi Tom,
Yes, perhaps.
Yes, and error-prone. Also it makes it harder to deal with broken machines.
I suspect it would be fast enough.
But actually the other problem is that I am not sure whether the jobs would have their own filesystem?
On Tue, Aug 15, 2023 at 08:44:20AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Yes, perhaps.
Yes, they should be properly sandboxed. If you want to test some of these ideas, I think the best path is to just un-register temproarily (comment out the token in config.toml) some of your runners and then register them with just the DM tree and experiment.
Hi Tom,
Hi Tom,
Hi Tom,
Yes, perhaps.
OK thanks for the idea. I tried this on tui
I used a 'concurrent = 10' and it got up to a load of 70 or so every now and then, but mostly it was much less.
The whole run (of just the test.py stage) took 8 minutes, with 'sandbox with clang test' taking the longest.
I'm not too sure what that tells us...
Hi Tom,
On Thu, 17 Aug 2023 at 07:41, Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
Hi Tom,
Yes, perhaps.
After a bit more thought, perhaps we should:
- Give everything except the world builds a special tag like 'single', meaning it is somewhat single-threaded - Adjust some runners to have a second registration which only accepts 'single' jobs, with a concurrency of 10, say - Consider running everything in a single stage
That might be easy to maintain?
On Thu, Aug 17, 2023 at 07:41:50AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
Yes, perhaps.
Well, looking at https://source.denx.de/u-boot/u-boot/-/pipelines/17391/builds the whole run took 56 minutes, of which 46 minutes was on 32bit ARM world build. And the longest test.py stage was sandbox without LTO at just under 8 minutes. So I think trying to get more concurrency in this stage is likely to be a wash in terms of overall CI run time.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
Yes, perhaps.
There is quite a lot of variability. Two of the machines take about 15mins to 32-bit ARM and another two take under 20mins, e.g.:
https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/676055
Perhaps we should reserve the big jobs for the fastest machines? But then what if they all go offline at once?
On Thu, Aug 17, 2023 at 10:58:15AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
> Hi Tom, > > I notice that the runners are not utilised much by the QEMU jobs, > since we only run one at a time. > > I wonder if we could improve this, perhaps by using a different tag > for the QEMU ones and then having a machine that only runs those (and > runs 40 in parallel)? > > In general our use of the runners seems a bit primitive, since the > main use of parallelism is in the world builds.
Yes, perhaps.
Barring some significant donation of resources, we probably are just going to have to live with enough variation in build time "about an hour" is what we'll end up with. I see that overall the pipeline the above example is from took 50 minutes.
Hi Tom,
Hi Tom,
Hi Tom,
Hi Tom,
wrote:
> > On Sat, Aug 12, 2023 at 09:14:45PM -0600, Simon Glass wrote: > > > Hi Tom, > > > > I notice that the runners are not utilised much by the QEMU
jobs,
> > since we only run one at a time. > > > > I wonder if we could improve this, perhaps by using a
different tag
those (and
> > runs 40 in parallel)? > > > > In general our use of the runners seems a bit primitive,
since the
> > main use of parallelism is in the world builds. > > I'm honestly not sure. I think there's a few tweaks that we
should do,
Dockerfile logic
registry
otherwise sure
> what's taking 23 seconds or so of > https://source.denx.de/u-boot/u-boot/-/jobs/673565#L34 since
the build
> and run parts aren't much. > > My first big worry about running 2 or 3 qemu jobs at the same
time on a
to buildman
slower.
Yes, perhaps.
will be a
> little tricky.
broken machines.
enough at
once on
would be
the jobs
of
temproarily
then
whole
Yes I think so.
