[U-Boot] [PATCH 1/1] sunxi: board: Add i2c initialization for sun50i
To use TWI0/1/2 the user can select CONFIG_I2C#_ENABLE. However even the controller is enabled, the mux for the pins are not set.
This patch follows the existing mux method. Since the pads are different, separate check is added for each i2c.
Tested with A64-SOM204 board.
Signed-off-by: Stefan Mavrodiev stefan@olimex.com --- arch/arm/include/asm/arch-sunxi/gpio.h | 3 +++ board/sunxi/board.c | 12 ++++++++++++ 2 files changed, 15 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 2daf23f6f5..40a3f845d0 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -176,6 +176,7 @@ enum sunxi_gpio_number {
#define SUN5I_GPE_SDC2 3 #define SUN8I_GPE_TWI2 3 +#define SUN50I_GPE_TWI2 3
#define SUNXI_GPF_SDC0 2 #define SUNXI_GPF_UART0 4 @@ -193,8 +194,10 @@ enum sunxi_gpio_number { #define SUN4I_GPH_SDC1 5 #define SUN6I_GPH_TWI0 2 #define SUN8I_GPH_TWI0 2 +#define SUN50I_GPH_TWI0 2 #define SUN6I_GPH_TWI1 2 #define SUN8I_GPH_TWI1 2 +#define SUN50I_GPH_TWI1 2 #define SUN6I_GPH_TWI2 2 #define SUN6I_GPH_UART0 2 #define SUN9I_GPH_UART0 2 diff --git a/board/sunxi/board.c b/board/sunxi/board.c index f022f365e9..ad14837291 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -98,6 +98,10 @@ void i2c_init_board(void) sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN8I_GPH_TWI0); sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN8I_GPH_TWI0); clock_twi_onoff(0, 1); +#elif defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(0), SUN50I_GPH_TWI0); + sunxi_gpio_set_cfgpin(SUNXI_GPH(1), SUN50I_GPH_TWI0); + clock_twi_onoff(0, 1); #endif #endif
@@ -120,6 +124,10 @@ void i2c_init_board(void) sunxi_gpio_set_cfgpin(SUNXI_GPH(4), SUN8I_GPH_TWI1); sunxi_gpio_set_cfgpin(SUNXI_GPH(5), SUN8I_GPH_TWI1); clock_twi_onoff(1, 1); +#elif defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPH(2), SUN50I_GPH_TWI1); + sunxi_gpio_set_cfgpin(SUNXI_GPH(3), SUN50I_GPH_TWI1); + clock_twi_onoff(1, 1); #endif #endif
@@ -142,6 +150,10 @@ void i2c_init_board(void) sunxi_gpio_set_cfgpin(SUNXI_GPE(12), SUN8I_GPE_TWI2); sunxi_gpio_set_cfgpin(SUNXI_GPE(13), SUN8I_GPE_TWI2); clock_twi_onoff(2, 1); +#elif defined(CONFIG_MACH_SUN50I) + sunxi_gpio_set_cfgpin(SUNXI_GPE(14), SUN50I_GPE_TWI2); + sunxi_gpio_set_cfgpin(SUNXI_GPE(15), SUN50I_GPE_TWI2); + clock_twi_onoff(2, 1); #endif #endif
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Thanks! Maxime
On Tue, Jan 8, 2019 at 3:47 PM Maxime Ripard maxime.ripard@bootlin.com wrote:
Applied to u-boot-sunxi/master
Jagan Teki
Maxime Ripard
Stefan Mavrodiev
