[PATCH] tlv_eeprom: Add missing CRC32 dependency
tlv_eeprom uses crc32() function, so add dependency into Kconfig.
Signed-off-by: Pali Rohár pali@kernel.org --- cmd/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 69c1814d24af..d513d808aa3d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -167,6 +167,7 @@ config CMD_REGINFO config CMD_TLV_EEPROM bool "tlv_eeprom" depends on I2C_EEPROM + select CRC32 help Display and program the system EEPROM data block in ONIE Tlvinfo format. TLV stands for Type-Length-Value. @@ -175,6 +176,7 @@ config SPL_CMD_TLV_EEPROM bool "tlv_eeprom for SPL" depends on SPL_I2C_EEPROM select SPL_DRIVERS_MISC + select SPL_CRC32 help Read system EEPROM data block in ONIE Tlvinfo format from SPL.
Hi Pali,
Reviewed-by: Baruch Siach baruch@tkos.co.il
Thanks, baruch
- select CRC32 help Display and program the system EEPROM data block in ONIE Tlvinfo format. TLV stands for Type-Length-Value.
- select SPL_CRC32 help Read system EEPROM data block in ONIE Tlvinfo format from SPL.
Thanks, Stefan
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Baruch Siach
Pali Rohár
Stefan Roese
