[U-Boot-Users] MPC860T POST
Hi all,
I'm working with an MPC860T on a custom designed board, using ppcboot-2.0.0. I've only recently tried to turn on the POSTs that is offered with ppcboot/uboot and have tried to #define CONFIG_POST (CFG_POST_RTC | \ CFG_POST_MEMORY | \ CFG_POST_CPU | \ CFG_POST_CACHE | \ CFG_POST_UART | \ CFG_POST_ETHER \ )
However, on compilation, I get the following:
{standard input}: Assembler messages: {standard input}:513: Error: Relocation cannot be done when using -mrelocatable {standard input}:519: Error: Relocation cannot be done when using -mrelocatable {standard input}:525: Error: Relocation cannot be done when using -mrelocatable make[1]: *** [post.o] Error 1 make[1]: Leaving directory `/vobs/wecc/ppcboot-2.0.0/post' make: *** [subdirs] Error 1 myhong@nemo /vobs/wecc/ppcboot-2.0.0 $powerpc-linux-gcc -dumpversion 3.0.4
Any ideas? should I be able to compile this with version 3.0.4? If so, how can I get this to work?
Thanks in advance, My Hong Vuong
------------------------------------------------------------------ Acoustic Mine Imaging Thales Underwater Systems 274 Victoria Road Rydalmere NSW 2116 +61 2 9848 3872 +61404 483 823 My-Hong.Vuong@au.thalesgroup.com ------------------------------------------------------------------
PPCBoot is dead. Please use U-Boot instead.
You have omitted the interesting part: the command line causing the error. It seems to me you are not using the correct command line switches.
Version 3.0.4 of what?
--- Wolfgang Denk wd@denx.de 的郵件內容:> In message <sef6ed4e.055@gw_tus_syd3.tus.au.thales>
board, using
done when using
done when using
done when using
-mrelocatable
version 3.0.4? If
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de Another Armenia, Belgium ... the weak innocents who always seem to be located on a natural invasion route. -- Kirk, "Errand of Mercy", stardate 3198.4
This SF.Net email is sponsored by: INetU Attention Web Developers & Consultants: Become An INetU Hosting Partner. Refer Dedicated Servers. We Manage Them. You Get 10% Monthly Commission! INetU Dedicated Managed Hosting http://www.inetu.net/partner/index.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/u-boot-users
_________________________________________________________ 最新鈴聲推介:十面埋伏,千金,七友... http://ringtone.yahoo.com.hk
In message 20030623101403.88463.qmail@web21103.mail.yahoo.com you wrote:
--- Wolfgang Denk wd@denx.de ªº¶l¥ó¤º®e¡G> In
Why do you quote my message without adding any text yourself?
I would like to boot the linux kernel from the floppy disk on Sandpoint system. I read the source code where it has an initialization code for Windbone 83C553F. I think I only need to load the floppy driver. I am not familar with this. Do anyone talk me how to do it ? Thanks
Wilson
Vuong My-Hong
Wilson Lo
