[U-Boot-Users] [PATCH 1/6] binary upload tool
# # Author: Robert Schwebel r.schwebel@pengutronix.de # # Description: Binary upload tool by Chris Hallinan # # State: 2003-12-09: submit #
# # Patch managed by http://www.mn-logistik.de/unsupported/pxa250/patcher #
--- /dev/null 1970-01-01 01:00:00.000000000 +0100 +++ u-boot-patches/tools/binupld.c 2003-12-09 18:59:59.000000000 +0100 @@ -0,0 +1,204 @@ +/* This utility downloads a binary file from Minicom to + * the serial port. It supports the Xon-Xoff software + * flow control protocol to use the highest possible speed + * + * (C) Copyright 2001, 2002 DS4.COM, Inc. + * Chris Hallinan clh@net1plus.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * To use this utility with Minicom, add the entry in Minicom's + * File Transfer Protocol as follows: + * Type Ctl-A, O (enter Configuration menu) + * Select File transfer protocols from menu + * Add the entry for binupld to look like the following (Item K) + * + * Name Program Name U/D FullScr IO-Red. Multi + * A zmodem /usr/bin/sz -vv -b Y U N Y Y + * B ymodem /usr/bin/sb -vv Y U N Y Y + * C xmodem /usr/bin/sx -vv Y U N Y N + * D zmodem /usr/bin/rz -vv -b -E N D N Y Y + * E ymodem /usr/bin/rb -vv N D N Y Y + * F xmodem /usr/bin/rx -vv Y D N Y N + * G kermit /usr/bin/kermit -i -l %l -s Y U Y N N + * H kermit /usr/bin/kermit -i -l %l -r N D Y N N + * I ascii /usr/bin/ascii-xfr -dsv Y U N Y N + * J srecdnld /usr/bin/srecdnl Y U N Y N + * K binupld /usr/bin/binupld Y U N Y N + */ + +#include <stdio.h> +#include <stdlib.h> +#include <sys/time.h> +#include <sys/types.h> +#include <sys/stat.h> +#include <fcntl.h> +#include <unistd.h> +#include <string.h> +#include <asm/errno.h> + +#define BUFSZ 1024 +#define TXBLK_SIZE 32 +#define XON 0x11 /* ASCII DC1 character */ +#define XOFF 0x13 /* ASCII DC3 character */ + +#define USE_STDERR +#undef USE_STDOUT + +#ifdef USE_STDERR +#define ERR_OUT stderr +#else +#define ERR_OUT err_fp +#define ERR_DEVICE "/dev/pts/0" +#endif + +#ifdef USE_STDOUT +#define LINE_OUT stdout +#else +#define LINE_OUT tty_fp +#endif + +int +main(int argc, char **argv) +{ + int bin_fd, i, fsize, nResult, count; + struct stat fst; + char lbuf; + int stepval, done, xoff, msgbidx = 0; + fd_set rfds; + struct timeval tv; + static char msgbuf[2048]; + static int got_xoff = 0; + +#ifndef USE_STDOUT + int LINE_OUT; +#endif + +#ifndef USE_STDERR + FILE *ERR_OUT; + + ERR_OUT = fopen(ERR_DEVICE, "w"); + if (ERR_OUT == NULL) { + perror("Error opening error output device"); + return -1; + } +#endif + +#ifndef USE_STDOUT + LINE_OUT = open("/dev/ttyS0", O_RDWR); + if (LINE_OUT == 1) { + perror("Error opening serial output device"); + return -1; + } +#endif + + if (argc != 2) { + fprintf(ERR_OUT, "Bad args\n"); + return -1; + } + + if (strlen(argv[1]) < 1) { + fprintf(ERR_OUT, "Bad file name\n"); + return -1; + } + + bin_fd = open(argv[1], O_RDONLY); + if (bin_fd == 1) { + perror("Open failed"); + return -1; + } + + /* Get file size */ + i = fstat(bin_fd, &fst); + if (i == -1) { + perror("stat failed"); + close(bin_fd); + return -1; + } + fsize = fst.st_size; + stepval = 100; + + /* Now ready for the file transfer! */ + fprintf(ERR_OUT, "\nUploading from %s --- xxxxxxx", argv[1]); + + i = 0; + done = 0; + xoff = 0; + while (!done) { + if (!xoff) { + count = read(bin_fd, &lbuf, TXBLK_SIZE); + if (count == 0) { + done = 1; + break; + } + + /* Write the output byte to tty port */ + if (write(LINE_OUT, &lbuf, count) != count) { + fprintf(ERR_OUT, + "Aw shit, binary write failed\n"); + return -1; + } + } + +#if 1 /* Delete if you don't need XON/XOFF spt */ + /* Setup for watching serial line input */ + FD_ZERO(&rfds); + FD_SET(LINE_OUT, &rfds); + /* Wait up to five hundred microseconds. */ + tv.tv_sec = 0; + tv.tv_usec = 500; + nResult = select(LINE_OUT + 1, &rfds, NULL, NULL, &tv); + if (nResult == -1) { + perror("Select failed"); + return -1; + } + + if (nResult && FD_ISSET(LINE_OUT, &rfds)) { + char c = getchar(); + /* Character received from serial port */ + switch (c) { + case XOFF: + xoff = 1; + got_xoff = 1; + break; + case XON: + xoff = 0; + break; + default: + msgbuf[msgbidx++] = c; + /* fprintf(ERR_OUT, " Data [%02x]\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b\b", c); */ + break; + } + } +#endif + + /* Display download progress */ + i += count; + fprintf(ERR_OUT, "\b\b\b\b\b\b\b%07d", i); + } + + fprintf(ERR_OUT, " - Done\n"); + msgbuf[msgbidx] = '\0'; + if (strlen(msgbuf)) + fprintf(ERR_OUT, "Msgbuf: %s\n", msgbuf); + + /* Report if we got an XOFF */ + if (got_xoff) + fprintf(ERR_OUT, "Got XOFF\n"); + + close(bin_fd); + return 0; +}
Robert Schwebel
