[U-Boot] [RFC PATCH v1 0/1] net: Support for Broadcom Tigon 3 NICs
I should probably explain the people involved here. Joshua did most of the porting work. I (Chris) picked it up to finish things off and to do some more testing. I'll also be the one trying to get this accepted upstream.
Because my employer paid for us to do the work I've signed with my work email address. But because I'm already subscribed I'll send the patches using my gmail account.
Joshua Scott (1): net: Add support for Tigon3 based Ethernet NICs
drivers/net/Makefile | 1 + drivers/net/tg3.c | 6119 ++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/tg3.h | 3217 ++++++++++++++++++++++++++ include/netdev.h | 4 + 4 files changed, 9341 insertions(+) create mode 100644 drivers/net/tg3.c create mode 100644 drivers/net/tg3.h
From: Joshua Scott joshua.scott@alliedtelesis.co.nz
This patch contains a port of the Linux Tigon3 driver to U-Boot. Many non-bootloader type things (TSO, firmware, jumbo-frames, etc) have been removed to keep the driver small and simple.
Signed-off-by: Joshua Scott joshua.scott@alliedtelesis.co.nz Signed-off-by: Chris Packham chris.packham@alliedtelesis.co.nz --- This code is functional. It's been tested using a P2041RDB with the PCI-e NIC installed.
We've been a bit inconsistent with the porting. Some code we've removed. Other code we've #if 0'd out. What is preferred? How well should this compare to the equivalent Linux driver?
Also because of u-boot/linux differences (and because because the original linux source is not clean) this isn't checkpatch.pl clean. We could put effort into cleaning this up but that would make the driver even less comparable to it's linux peer.
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fb0cf8c..86ffefe 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -59,6 +59,7 @@ obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_TSI108_ETH) += tsi108_eth.o obj-$(CONFIG_ULI526X) += uli526x.o +obj-$(CONFIG_TIGON3) += tg3.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o obj-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o obj-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o diff --git a/drivers/net/tg3.c b/drivers/net/tg3.c new file mode 100644 index 0000000..b37481b --- /dev/null +++ b/drivers/net/tg3.c @@ -0,0 +1,6119 @@ +/* + * tg3.c: Broadcom Tigon3 ethernet driver. + * + * This is a port of the Tigon3 driver from Linux to U-Boot. + * + * Support for the following has been removed to simplify the code: + * - Jumbo frames, TSO, TSS, RSS, ASF, EEE, Flow control, VPD, APE, NVRAM + * -> These features are not very useful for a bootloader. + * - Interrupts, Timers + * -> These do not fit in with how things are done in U-Boot + * - Firmware + * -> May effect CHIPREV_ID_5701_A0 / ASIC_REV_57766. + * - USE_PHYLIB + * -> Used by ASIC_REV_5785 / ASIC_REV_57780 + * - Subsys vendors + * - Setting the 10_100_ONLY flag + * -> In some cases, this value came from the driver_data value + * (Linux PCI). + * -> Will need to be re-implemented if your card needs this. + * - PCIe-only / PCI-X-only code. + * - Checking of pci_channel_offline. + * -> On Linux does this: (pdev->error_state != pci_channel_io_normal); + * + * Development and testing was done using the following card: + * [partno(BCM95718) rev 5717100] (PCI Express) + * vendor=14e4, device=1656 + * PHY is 5718C (10/100/1000Base-T Ethernet) + * + * Other Notes: + * + * - The DMA alloc function I'm using in here is borrowed from ARM code, + * as it was not defined for PPC. + */ + +/* + * tg3.c: Broadcom Tigon3 ethernet driver. (Linux) + * + * Copyright (C) 2001, 2002, 2003, 2004 David S. Miller (davem@redhat.com) + * Copyright (C) 2001, 2002, 2003 Jeff Garzik (jgarzik@pobox.com) + * Copyright (C) 2004 Sun Microsystems Inc. + * Copyright (C) 2005-2014 Broadcom Corporation. + */ + +#include <asm/byteorder.h> +#include <common.h> +#include <errno.h> +#include <malloc.h> +#include <net.h> +#include <netdev.h> +#include <asm/io.h> +#include <pci.h> +#include <linux/mii.h> +#include <phy.h> + +/* TODO: Investigate the producur ring size. Will a smaller size work + * on this card? Do other cards require a larger size? */ + +#define TG3_TX_RING_SIZE 32 +#define TG3_RX_PRODUCER_RING_SIZE 512 +#define TG3_RX_RETURN_RING_SIZE 32 +#define TG3_TX_BUFFER_COUNT 1 +#define TG3_RX_BUFFER_COUNT 32 +#define TG3_RX_FRAME_SIZE 1536 + +#define TG3_INIT_STATE_NONE 0 +#define TG3_INIT_STATE_PRE 1 +#define TG3_INIT_STATE_DONE 2 + +#include "tg3.h" + +/* compatibility definition */ +#define smp_mb() mb() + +/* TODO: Find out why these aren't being pulled in from mii.h */ +#define CTL1000_AS_MASTER 0x0800 +#define CTL1000_ENABLE_MASTER 0x1000 + +/* TODO: Borrowing this from ARM... */ +static void *dma_alloc_coherent(size_t len, dma_addr_t *handle) +{ + *handle = (dma_addr_t)memalign(ARCH_DMA_MINALIGN, len); + return (void *)*handle; +} + +static struct pci_device_id tg3_supported[] = { + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5752 }, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5752M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5700}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5701}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5702}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5703}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5704}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5704S_2}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5702FE}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5705}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5705_2}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5719}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5721}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5722}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5723}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5705M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5705M_2}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5714}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5714S}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5780}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5780S}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5705F}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5754M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5755M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5756}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5750}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5751}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5715}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5715S}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5754}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5755}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5751M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5751F}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5787F}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5761E}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5761}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5764}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5787M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5782}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5784}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5786}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5787}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5788}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5789}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5702X}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5703X}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5704S}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5702A3}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5703A3}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5781}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5753}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5753M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5753F}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5901}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5901_2}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5906}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5906M}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5785_G}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5785_F}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57780}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57760}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57790}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57788}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5717}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5717_C}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5718}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57781}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57785}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57761}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57765}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57791}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57795}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5719}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5720}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57762}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57766}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5762}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5725}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_5727}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57764}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57767}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57787}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57782}, + {TG3PCI_VENDOR_BROADCOM, TG3PCI_DEVICE_TIGON3_57786}, + {PCI_VENDOR_ID_SYSKONNECT, PCI_DEVICE_ID_SYSKONNECT_9DXX}, + {PCI_VENDOR_ID_SYSKONNECT, PCI_DEVICE_ID_SYSKONNECT_9MXX}, + {PCI_VENDOR_ID_ALTIMA, PCI_DEVICE_ID_ALTIMA_AC1000}, + {PCI_VENDOR_ID_ALTIMA, PCI_DEVICE_ID_ALTIMA_AC1001}, + {PCI_VENDOR_ID_ALTIMA, PCI_DEVICE_ID_ALTIMA_AC1003}, + {PCI_VENDOR_ID_ALTIMA, PCI_DEVICE_ID_ALTIMA_AC9100}, + {PCI_VENDOR_ID_APPLE, PCI_DEVICE_ID_APPLE_TIGON3}, + {0x10cf, 0x11a2}, /* Fujitsu 1000base-SX with BCM5703SKHB */ + {} +}; + +/* Functions & macros to verify TG3_FLAGS types */ + +static inline int _tg3_flag(enum TG3_FLAGS flag, unsigned long *bits) +{ + return test_bit(flag, bits); +} + +static inline void _tg3_flag_set(enum TG3_FLAGS flag, unsigned long *bits) +{ + set_bit(flag, bits); +} + +static inline void _tg3_flag_clear(enum TG3_FLAGS flag, unsigned long *bits) +{ + clear_bit(flag, bits); +} + +#define tg3_flag(tp, flag) \ + _tg3_flag(TG3_FLAG_##flag, (tp)->tg3_flags) +#define tg3_flag_set(tp, flag) \ + _tg3_flag_set(TG3_FLAG_##flag, (tp)->tg3_flags) +#define tg3_flag_clear(tp, flag) \ + _tg3_flag_clear(TG3_FLAG_##flag, (tp)->tg3_flags) + +#define RESET_KIND_SHUTDOWN 0 +#define RESET_KIND_INIT 1 +#define RESET_KIND_SUSPEND 2 + +#define TG3_DEF_RX_MODE 0 +#define TG3_DEF_TX_MODE 0 + +#define TG3_GRC_LCLCTL_PWRSW_DELAY 100 + +/* hardware minimum and maximum for a single frame's data payload */ +#define TG3_MAX_MTU(tp) 1500 + +/* Do not place this n-ring entries value into the tp struct itself, + * we really want to expose these constants to GCC so that modulo et + * al. operations are done with shifts and masks instead of with + * hw multiply/modulo instructions. Another solution would be to + * replace things like '% foo' with '& (foo - 1)'. + */ + +#define TG3_RX_STD_RING_BYTES \ + (sizeof(struct tg3_rx_buffer_desc) * TG3_RX_PRODUCER_RING_SIZE) +#define TG3_RX_RCB_RING_BYTES \ + (sizeof(struct tg3_rx_buffer_desc) * TG3_RX_RETURN_RING_SIZE) +#define TG3_TX_RING_BYTES \ + (sizeof(struct tg3_tx_buffer_desc) * TG3_TX_RING_SIZE) + +#define TG3_TX_BD_DMA_MAX_2K 2048 +#define TG3_TX_BD_DMA_MAX_4K 4096 + +static void tg3_write32(struct tg3_priv *tp, u32 off, u32 val) +{ + writel(val, tp->regs + off); +} + +static u32 tg3_read32(struct tg3_priv *tp, u32 off) +{ + return readl(tp->regs + off); +} + +static void tg3_write_indirect_reg32(struct tg3_priv *tp, u32 off, u32 val) +{ + pci_write_config_dword(tp->devno, TG3PCI_REG_BASE_ADDR, off); + pci_write_config_dword(tp->devno, TG3PCI_REG_DATA, val); +} + +static void tg3_write_flush_reg32(struct tg3_priv *tp, u32 off, u32 val) +{ + writel(val, tp->regs + off); + readl(tp->regs + off); +} + +static u32 tg3_read_indirect_reg32(struct tg3_priv *tp, u32 off) +{ + u32 val; + pci_write_config_dword(tp->devno, TG3PCI_REG_BASE_ADDR, off); + pci_read_config_dword(tp->devno, TG3PCI_REG_DATA, &val); + return val; +} + +static void tg3_write_indirect_mbox(struct tg3_priv *tp, u32 off, u32 val) +{ + if (off == (MAILBOX_RCVRET_CON_IDX_0 + TG3_64BIT_REG_LOW)) { + pci_write_config_dword(tp->devno, TG3PCI_RCV_RET_RING_CON_IDX + + TG3_64BIT_REG_LOW, val); + return; + } + if (off == TG3_RX_STD_PROD_IDX_REG) { + pci_write_config_dword(tp->devno, TG3PCI_STD_RING_PROD_IDX + + TG3_64BIT_REG_LOW, val); + return; + } + + pci_write_config_dword(tp->devno, TG3PCI_REG_BASE_ADDR, off + 0x5600); + pci_write_config_dword(tp->devno, TG3PCI_REG_DATA, val); + + /* In indirect mode when disabling interrupts, we also need + * to clear the interrupt bit in the GRC local ctrl register. + */ + if ((off == (MAILBOX_INTERRUPT_0 + TG3_64BIT_REG_LOW)) && + (val == 0x1)) { + pci_write_config_dword(tp->devno, TG3PCI_MISC_LOCAL_CTRL, + tp->grc_local_ctrl|GRC_LCLCTRL_CLEARINT); + } +} + +static u32 tg3_read_indirect_mbox(struct tg3_priv *tp, u32 off) +{ + u32 val; + pci_write_config_dword(tp->devno, TG3PCI_REG_BASE_ADDR, off + 0x5600); + pci_read_config_dword(tp->devno, TG3PCI_REG_DATA, &val); + return val; +} + +/* usec_wait specifies the wait time in usec when writing to certain registers + * where it is unsafe to read back the register without some delay. + * GRC_LOCAL_CTRL is one example if the GPIOs are toggled to switch power. + * TG3PCI_CLOCK_CTRL is another example if the clock frequencies are changed. + */ +static void _tw32_flush(struct tg3_priv *tp, u32 off, u32 val, u32 usec_wait) +{ + if (tg3_flag(tp, PCIX_TARGET_HWBUG) || tg3_flag(tp, ICH_WORKAROUND)) + /* Non-posted methods */ + tp->write32(tp, off, val); + else { + /* Posted method */ + tg3_write32(tp, off, val); + if (usec_wait) + udelay(usec_wait); + tp->read32(tp, off); + } + /* Wait again after the read for the posted method to guarantee that + * the wait time is met. + */ + if (usec_wait) + udelay(usec_wait); +} + +static inline void tw32_mailbox_flush(struct tg3_priv *tp, u32 off, u32 val) +{ + tp->write32_mbox(tp, off, val); + if (tg3_flag(tp, FLUSH_POSTED_WRITES) || + (!tg3_flag(tp, MBOX_WRITE_REORDER) && + !tg3_flag(tp, ICH_WORKAROUND))) + tp->read32_mbox(tp, off); +} + +static void tg3_write32_tx_mbox(struct tg3_priv *tp, u32 off, u32 val) +{ + void __iomem *mbox = tp->regs + off; + writel(val, mbox); + if (tg3_flag(tp, TXD_MBOX_HWBUG)) + writel(val, mbox); + if (tg3_flag(tp, MBOX_WRITE_REORDER) || + tg3_flag(tp, FLUSH_POSTED_WRITES)) + readl(mbox); +} + +static u32 tg3_read32_mbox_5906(struct tg3_priv *tp, u32 off) +{ + return readl(tp->regs + off + GRCMBOX_BASE); +} + +static void tg3_write32_mbox_5906(struct tg3_priv *tp, u32 off, u32 val) +{ + writel(val, tp->regs + off + GRCMBOX_BASE); +} + +#define tw32_mailbox(reg, val) tp->write32_mbox(tp, reg, val) +#define tw32_mailbox_f(reg, val) tw32_mailbox_flush(tp, (reg), (val)) +#define tw32_rx_mbox(reg, val) tp->write32_rx_mbox(tp, reg, val) +#define tw32_tx_mbox(reg, val) tp->write32_tx_mbox(tp, reg, val) +#define tr32_mailbox(reg) tp->read32_mbox(tp, reg) + +#define tw32(reg, val) tp->write32(tp, reg, val) +#define tw32_f(reg, val) _tw32_flush(tp, (reg), (val), 0) +#define tw32_wait_f(reg, val, us) _tw32_flush(tp, (reg), (val), (us)) +#define tr32(reg) tp->read32(tp, reg) + +static void tg3_write_mem(struct tg3_priv *tp, u32 off, u32 val) +{ + if (tg3_asic_rev(tp) == ASIC_REV_5906 && (off >= NIC_SRAM_STATS_BLK) && + (off < NIC_SRAM_TX_BUFFER_DESC)) + return; + + if (tg3_flag(tp, SRAM_USE_CONFIG)) { + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, + off); + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_DATA, val); + + /* Always leave this as zero. */ + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, 0); + } else { + tw32_f(TG3PCI_MEM_WIN_BASE_ADDR, off); + tw32_f(TG3PCI_MEM_WIN_DATA, val); + + /* Always leave this as zero. */ + tw32_f(TG3PCI_MEM_WIN_BASE_ADDR, 0); + } +} + +static void tg3_read_mem(struct tg3_priv *tp, u32 off, u32 *val) +{ + if (tg3_asic_rev(tp) == ASIC_REV_5906 && + (off >= NIC_SRAM_STATS_BLK) && (off < NIC_SRAM_TX_BUFFER_DESC)) { + *val = 0; + return; + } + + if (tg3_flag(tp, SRAM_USE_CONFIG)) { + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, off); + pci_read_config_dword(tp->devno, TG3PCI_MEM_WIN_DATA, val); + + /* Always leave this as zero. */ + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, 0); + } else { + tw32_f(TG3PCI_MEM_WIN_BASE_ADDR, off); + *val = tr32(TG3PCI_MEM_WIN_DATA); + + /* Always leave this as zero. */ + tw32_f(TG3PCI_MEM_WIN_BASE_ADDR, 0); + } +} + +static void tg3_disable_ints(struct tg3_priv *tp) +{ + tw32(TG3PCI_MISC_HOST_CTRL, (tp->misc_host_ctrl | MISC_HOST_CTRL_MASK_PCI_INT)); + tw32_mailbox_f(tp->napi[0].int_mbox, 0x00000001); +} + +static void tg3_switch_clocks(struct tg3_priv *tp) +{ + u32 clock_ctrl; u32 + orig_clock_ctrl; + + if (tg3_flag(tp, CPMU_PRESENT) || tg3_flag(tp, 5780_CLASS)) + return; + + clock_ctrl = tr32(TG3PCI_CLOCK_CTRL); + + orig_clock_ctrl = clock_ctrl; + clock_ctrl &= (CLOCK_CTRL_FORCE_CLKRUN | + CLOCK_CTRL_CLKRUN_OENABLE | + 0x1f); + tp->pci_clock_ctrl = clock_ctrl; + + if (tg3_flag(tp, 5705_PLUS)) { + if (orig_clock_ctrl & CLOCK_CTRL_625_CORE) { + tw32_wait_f(TG3PCI_CLOCK_CTRL, + clock_ctrl | CLOCK_CTRL_625_CORE, 40); + } + } else if ((orig_clock_ctrl & CLOCK_CTRL_44MHZ_CORE) != 0) { + tw32_wait_f(TG3PCI_CLOCK_CTRL, + clock_ctrl | + (CLOCK_CTRL_44MHZ_CORE | CLOCK_CTRL_ALTCLK), + 40); + tw32_wait_f(TG3PCI_CLOCK_CTRL, + clock_ctrl | (CLOCK_CTRL_ALTCLK), + 40); + } + tw32_wait_f(TG3PCI_CLOCK_CTRL, clock_ctrl, 40); +} + +#define PHY_BUSY_LOOPS 5000 + +static int __tg3_readphy(struct tg3_priv *tp, unsigned int phy_addr, int reg, + u32 *val) +{ + u32 frame_val; + unsigned int loops; + int ret; + + if ((tp->mi_mode & MAC_MI_MODE_AUTO_POLL) != 0) { + tw32_f(MAC_MI_MODE, + (tp->mi_mode & ~MAC_MI_MODE_AUTO_POLL)); + udelay(80); + } + + *val = 0x0; + + frame_val = ((phy_addr << MI_COM_PHY_ADDR_SHIFT) & + MI_COM_PHY_ADDR_MASK); + frame_val |= ((reg << MI_COM_REG_ADDR_SHIFT) & + MI_COM_REG_ADDR_MASK); + frame_val |= (MI_COM_CMD_READ | MI_COM_START); + + tw32_f(MAC_MI_COM, frame_val); + + loops = PHY_BUSY_LOOPS; + while (loops != 0) { + udelay(10); + frame_val = tr32(MAC_MI_COM); + + if ((frame_val & MI_COM_BUSY) == 0) { + udelay(5); + frame_val = tr32(MAC_MI_COM); + break; + } + loops -= 1; + } + + ret = -EBUSY; + if (loops != 0) { + *val = frame_val & MI_COM_DATA_MASK; + ret = 0; + } + + if ((tp->mi_mode & MAC_MI_MODE_AUTO_POLL) != 0) { + tw32_f(MAC_MI_MODE, tp->mi_mode); + udelay(80); + } + + return ret; +} + +static int tg3_readphy(struct tg3_priv *tp, int reg, u32 *val) +{ + return __tg3_readphy(tp, tp->phy_addr, reg, val); +} + +static int __tg3_writephy(struct tg3_priv *tp, unsigned int phy_addr, int reg, + u32 val) +{ + u32 frame_val; + unsigned int loops; + int ret; + + if ((tp->phy_flags & TG3_PHYFLG_IS_FET) && + (reg == MII_CTRL1000 || reg == MII_TG3_AUX_CTRL)) + return 0; + + if ((tp->mi_mode & MAC_MI_MODE_AUTO_POLL) != 0) { + tw32_f(MAC_MI_MODE, + (tp->mi_mode & ~MAC_MI_MODE_AUTO_POLL)); + udelay(80); + } + + frame_val = ((phy_addr << MI_COM_PHY_ADDR_SHIFT) & + MI_COM_PHY_ADDR_MASK); + frame_val |= ((reg << MI_COM_REG_ADDR_SHIFT) & + MI_COM_REG_ADDR_MASK); + frame_val |= (val & MI_COM_DATA_MASK); + frame_val |= (MI_COM_CMD_WRITE | MI_COM_START); + + tw32_f(MAC_MI_COM, frame_val); + + loops = PHY_BUSY_LOOPS; + while (loops != 0) { + udelay(10); + frame_val = tr32(MAC_MI_COM); + if ((frame_val & MI_COM_BUSY) == 0) { + udelay(5); + frame_val = tr32(MAC_MI_COM); + break; + } + loops -= 1; + } + + ret = -EBUSY; + if (loops != 0) + ret = 0; + + if ((tp->mi_mode & MAC_MI_MODE_AUTO_POLL) != 0) { + tw32_f(MAC_MI_MODE, tp->mi_mode); + udelay(80); + } + + return ret; +} + +static int tg3_writephy(struct tg3_priv *tp, int reg, u32 val) +{ + return __tg3_writephy(tp, tp->phy_addr, reg, val); +} + +static int tg3_phydsp_write(struct tg3_priv *tp, u32 reg, u32 val) +{ + int err; + + err = tg3_writephy(tp, MII_TG3_DSP_ADDRESS, reg); + if (!err) + err = tg3_writephy(tp, MII_TG3_DSP_RW_PORT, val); + + return err; +} + +static int tg3_phy_auxctl_read(struct tg3_priv *tp, int reg, u32 *val) +{ + int err; + + err = tg3_writephy(tp, MII_TG3_AUX_CTRL, + (reg << MII_TG3_AUXCTL_MISC_RDSEL_SHIFT) | + MII_TG3_AUXCTL_SHDWSEL_MISC); + if (!err) + err = tg3_readphy(tp, MII_TG3_AUX_CTRL, val); + + return err; +} + +static int tg3_phy_auxctl_write(struct tg3_priv *tp, int reg, u32 set) +{ + if (reg == MII_TG3_AUXCTL_SHDWSEL_MISC) + set |= MII_TG3_AUXCTL_MISC_WREN; + + return tg3_writephy(tp, MII_TG3_AUX_CTRL, set | reg); +} + +static int tg3_phy_toggle_auxctl_smdsp(struct tg3_priv *tp, bool enable) +{ + u32 val; + int err; + + err = tg3_phy_auxctl_read(tp, MII_TG3_AUXCTL_SHDWSEL_AUXCTL, &val); + + if (err) + return err; + + if (enable) + val |= MII_TG3_AUXCTL_ACTL_SMDSP_ENA; + else + val &= ~MII_TG3_AUXCTL_ACTL_SMDSP_ENA; + + err = tg3_phy_auxctl_write((tp), MII_TG3_AUXCTL_SHDWSEL_AUXCTL, + val | MII_TG3_AUXCTL_ACTL_TX_6DB); + + return err; +} + +static int tg3_phy_shdw_write(struct tg3_priv *tp, int reg, u32 val) +{ + return tg3_writephy(tp, MII_TG3_MISC_SHDW, + reg | val | MII_TG3_MISC_SHDW_WREN); +} + +static int tg3_bmcr_reset(struct tg3_priv *tp) +{ + u32 phy_control; + int limit, err; + + /* OK, reset it, and poll the BMCR_RESET bit until it + * clears or we time out. + */ + phy_control = BMCR_RESET; + err = tg3_writephy(tp, MII_BMCR, phy_control); + if (err != 0) + return -EBUSY; + + limit = 5000; + while (limit--) { + err = tg3_readphy(tp, MII_BMCR, &phy_control); + if (err != 0) + return -EBUSY; + + if ((phy_control & BMCR_RESET) == 0) { + udelay(40); + break; + } + udelay(10); + } + if (limit < 0) + return -EBUSY; + + return 0; +} + +static void tg3_mdio_start(struct tg3_priv *tp) +{ + tp->mi_mode &= ~MAC_MI_MODE_AUTO_POLL; + tw32_f(MAC_MI_MODE, tp->mi_mode); + udelay(80); +} + +static int tg3_mdio_init(struct tg3_priv *tp) +{ + if (tg3_flag(tp, 5717_PLUS)) { + u32 is_serdes; + + tp->phy_addr = tp->pci_fn + 1; + + if (tg3_chip_rev_id(tp) != CHIPREV_ID_5717_A0) + is_serdes = tr32(SG_DIG_STATUS) & SG_DIG_IS_SERDES; + else + is_serdes = tr32(TG3_CPMU_PHY_STRAP) & + TG3_CPMU_PHY_STRAP_IS_SERDES; + if (is_serdes) + tp->phy_addr += 7; + } else { + tp->phy_addr = TG3_PHY_MII_ADDR; + } + + tg3_mdio_start(tp); + + return 0; +} + +static void tg3_write_sig_pre_reset(struct tg3_priv *tp, int kind) +{ + tg3_write_mem(tp, NIC_SRAM_FIRMWARE_MBOX, NIC_SRAM_FIRMWARE_MBOX_MAGIC1); +} + +static int tg3_poll_fw(struct tg3_priv *tp) +{ + int i; + u32 val; + + if (tg3_flag(tp, NO_FWARE_REPORTED)) + return 0; + + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + /* Wait up to 20ms for init done. */ + for (i = 0; i < 200; i++) { + if (tr32(VCPU_STATUS) & VCPU_STATUS_INIT_DONE) + return 0; + + udelay(100); + } + return -ENODEV; + } + + /* Wait for firmware initialization to complete. */ + for (i = 0; i < 100000; i++) { + tg3_read_mem(tp, NIC_SRAM_FIRMWARE_MBOX, &val); + if (val == ~NIC_SRAM_FIRMWARE_MBOX_MAGIC1) + break; + udelay(10); + } + + /* Chip might not be fitted with firmware. Some Sun onboard + * parts are configured like that. So don't signal the timeout + * of the above loop as an error, but do report the lack of + * running firmware once. + */ + if (i >= 100000 && !tg3_flag(tp, NO_FWARE_REPORTED)) { + tg3_flag_set(tp, NO_FWARE_REPORTED); + + printf("# No firmware running\n"); + } + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_57765_A0) { + /* The 57765 A0 needs a little more + * time to do some important work. + */ + mdelay(10); + } + + return 0; +} + +static void tg3_phy_fet_toggle_apd(struct tg3_priv *tp, bool enable) +{ + u32 phytest; + + if (!tg3_readphy(tp, MII_TG3_FET_TEST, &phytest)) { + u32 phy; + + tg3_writephy(tp, MII_TG3_FET_TEST, + phytest | MII_TG3_FET_SHADOW_EN); + if (!tg3_readphy(tp, MII_TG3_FET_SHDW_AUXSTAT2, &phy)) { + if (enable) + phy |= MII_TG3_FET_SHDW_AUXSTAT2_APD; + else + phy &= ~MII_TG3_FET_SHDW_AUXSTAT2_APD; + tg3_writephy(tp, MII_TG3_FET_SHDW_AUXSTAT2, phy); + } + tg3_writephy(tp, MII_TG3_FET_TEST, phytest); + } +} + +static void tg3_phy_toggle_apd(struct tg3_priv *tp, bool enable) +{ + u32 reg; + + if (!tg3_flag(tp, 5705_PLUS) || + (tg3_flag(tp, 5717_PLUS) && + (tp->phy_flags & TG3_PHYFLG_MII_SERDES))) + return; + + if (tp->phy_flags & TG3_PHYFLG_IS_FET) { + tg3_phy_fet_toggle_apd(tp, enable); + return; + } + + reg = MII_TG3_MISC_SHDW_SCR5_LPED | + MII_TG3_MISC_SHDW_SCR5_DLPTLM | + MII_TG3_MISC_SHDW_SCR5_SDTL | + MII_TG3_MISC_SHDW_SCR5_C125OE; + if (tg3_asic_rev(tp) != ASIC_REV_5784 || !enable) + reg |= MII_TG3_MISC_SHDW_SCR5_DLLAPD; + + tg3_phy_shdw_write(tp, MII_TG3_MISC_SHDW_SCR5_SEL, reg); + + + reg = MII_TG3_MISC_SHDW_APD_WKTM_84MS; + if (enable) + reg |= MII_TG3_MISC_SHDW_APD_ENABLE; + + tg3_phy_shdw_write(tp, MII_TG3_MISC_SHDW_APD_SEL, reg); +} + +static void tg3_phy_toggle_automdix(struct tg3_priv *tp, bool enable) +{ + u32 phy; + + if (!tg3_flag(tp, 5705_PLUS) || + (tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) + return; + + if (tp->phy_flags & TG3_PHYFLG_IS_FET) { + u32 ephy; + + if (!tg3_readphy(tp, MII_TG3_FET_TEST, &ephy)) { + u32 reg = MII_TG3_FET_SHDW_MISCCTRL; + + tg3_writephy(tp, MII_TG3_FET_TEST, + ephy | MII_TG3_FET_SHADOW_EN); + if (!tg3_readphy(tp, reg, &phy)) { + if (enable) + phy |= MII_TG3_FET_SHDW_MISCCTRL_MDIX; + else + phy &= ~MII_TG3_FET_SHDW_MISCCTRL_MDIX; + tg3_writephy(tp, reg, phy); + } + tg3_writephy(tp, MII_TG3_FET_TEST, ephy); + } + } else { + int ret; + + ret = tg3_phy_auxctl_read(tp, + MII_TG3_AUXCTL_SHDWSEL_MISC, &phy); + if (!ret) { + if (enable) + phy |= MII_TG3_AUXCTL_MISC_FORCE_AMDIX; + else + phy &= ~MII_TG3_AUXCTL_MISC_FORCE_AMDIX; + tg3_phy_auxctl_write(tp, + MII_TG3_AUXCTL_SHDWSEL_MISC, phy); + } + } +} + +static void tg3_phy_set_wirespeed(struct tg3_priv *tp) +{ + int ret; + u32 val; + + if (tp->phy_flags & TG3_PHYFLG_NO_ETH_WIRE_SPEED) + return; + + ret = tg3_phy_auxctl_read(tp, MII_TG3_AUXCTL_SHDWSEL_MISC, &val); + if (!ret) + tg3_phy_auxctl_write(tp, MII_TG3_AUXCTL_SHDWSEL_MISC, + val | MII_TG3_AUXCTL_MISC_WIRESPD_EN); +} + +static void tg3_phy_apply_otp(struct tg3_priv *tp) +{ + u32 otp, phy; + + if (!tp->phy_otp) + return; + + otp = tp->phy_otp; + + if (tg3_phy_toggle_auxctl_smdsp(tp, true)) + return; + + phy = ((otp & TG3_OTP_AGCTGT_MASK) >> TG3_OTP_AGCTGT_SHIFT); + phy |= MII_TG3_DSP_TAP1_AGCTGT_DFLT; + tg3_phydsp_write(tp, MII_TG3_DSP_TAP1, phy); + + phy = ((otp & TG3_OTP_HPFFLTR_MASK) >> TG3_OTP_HPFFLTR_SHIFT) | + ((otp & TG3_OTP_HPFOVER_MASK) >> TG3_OTP_HPFOVER_SHIFT); + tg3_phydsp_write(tp, MII_TG3_DSP_AADJ1CH0, phy); + + phy = ((otp & TG3_OTP_LPFDIS_MASK) >> TG3_OTP_LPFDIS_SHIFT); + phy |= MII_TG3_DSP_AADJ1CH3_ADCCKADJ; + tg3_phydsp_write(tp, MII_TG3_DSP_AADJ1CH3, phy); + + phy = ((otp & TG3_OTP_VDAC_MASK) >> TG3_OTP_VDAC_SHIFT); + tg3_phydsp_write(tp, MII_TG3_DSP_EXP75, phy); + + phy = ((otp & TG3_OTP_10BTAMP_MASK) >> TG3_OTP_10BTAMP_SHIFT); + tg3_phydsp_write(tp, MII_TG3_DSP_EXP96, phy); + + phy = ((otp & TG3_OTP_ROFF_MASK) >> TG3_OTP_ROFF_SHIFT) | + ((otp & TG3_OTP_RCOFF_MASK) >> TG3_OTP_RCOFF_SHIFT); + tg3_phydsp_write(tp, MII_TG3_DSP_EXP97, phy); + + tg3_phy_toggle_auxctl_smdsp(tp, false); +} + +static int tg3_wait_macro_done(struct tg3_priv *tp) +{ + int limit = 100; + + while (limit--) { + u32 tmp32; + + if (!tg3_readphy(tp, MII_TG3_DSP_CONTROL, &tmp32)) { + if ((tmp32 & 0x1000) == 0) + break; + } + } + if (limit < 0) + return -EBUSY; + + return 0; +} + +static int tg3_phy_write_and_check_testpat(struct tg3_priv *tp, int *resetp) +{ + static const u32 test_pat[4][6] = { + { 0x00005555, 0x00000005, 0x00002aaa, 0x0000000a, 0x00003456, 0x00000003 }, + { 0x00002aaa, 0x0000000a, 0x00003333, 0x00000003, 0x0000789a, 0x00000005 }, + { 0x00005a5a, 0x00000005, 0x00002a6a, 0x0000000a, 0x00001bcd, 0x00000003 }, + { 0x00002a5a, 0x0000000a, 0x000033c3, 0x00000003, 0x00002ef1, 0x00000005 } + }; + int chan; + + for (chan = 0; chan < 4; chan++) { + int i; + + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, + (chan * 0x2000) | 0x0200); + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0002); + + for (i = 0; i < 6; i++) + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, + test_pat[chan][i]); + + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0202); + if (tg3_wait_macro_done(tp)) { + *resetp = 1; + return -EBUSY; + } + + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, + (chan * 0x2000) | 0x0200); + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0082); + if (tg3_wait_macro_done(tp)) { + *resetp = 1; + return -EBUSY; + } + + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0802); + if (tg3_wait_macro_done(tp)) { + *resetp = 1; + return -EBUSY; + } + + for (i = 0; i < 6; i += 2) { + u32 low, high; + + if (tg3_readphy(tp, MII_TG3_DSP_RW_PORT, &low) || + tg3_readphy(tp, MII_TG3_DSP_RW_PORT, &high) || + tg3_wait_macro_done(tp)) { + *resetp = 1; + return -EBUSY; + } + low &= 0x7fff; + high &= 0x000f; + if (low != test_pat[chan][i] || + high != test_pat[chan][i+1]) { + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, 0x000b); + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, 0x4001); + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, 0x4005); + + return -EBUSY; + } + } + } + + return 0; +} + +static int tg3_phy_reset_chanpat(struct tg3_priv *tp) +{ + int chan; + + for (chan = 0; chan < 4; chan++) { + int i; + + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, + (chan * 0x2000) | 0x0200); + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0002); + for (i = 0; i < 6; i++) + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, 0x000); + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0202); + if (tg3_wait_macro_done(tp)) + return -EBUSY; + } + + return 0; +} + +static int tg3_phy_reset_5703_4_5(struct tg3_priv *tp) +{ + u32 reg32, phy9_orig; + int retries, do_phy_reset, err; + + retries = 10; + do_phy_reset = 1; + do { + if (do_phy_reset) { + err = tg3_bmcr_reset(tp); + if (err) + return err; + do_phy_reset = 0; + } + + /* Disable transmitter and interrupt. */ + if (tg3_readphy(tp, MII_TG3_EXT_CTRL, ®32)) + continue; + + reg32 |= 0x3000; + tg3_writephy(tp, MII_TG3_EXT_CTRL, reg32); + + /* Set full-duplex, 1000 mbps. */ + tg3_writephy(tp, MII_BMCR, + BMCR_FULLDPLX | BMCR_SPEED1000); + + /* Set to master mode. */ + if (tg3_readphy(tp, MII_CTRL1000, &phy9_orig)) + continue; + + tg3_writephy(tp, MII_CTRL1000, + CTL1000_AS_MASTER | CTL1000_ENABLE_MASTER); + + err = tg3_phy_toggle_auxctl_smdsp(tp, true); + if (err) + return err; + + /* Block the PHY control access. */ + tg3_phydsp_write(tp, 0x8005, 0x0800); + + err = tg3_phy_write_and_check_testpat(tp, &do_phy_reset); + if (!err) + break; + } while (--retries); + + err = tg3_phy_reset_chanpat(tp); + if (err) + return err; + + tg3_phydsp_write(tp, 0x8005, 0x0000); + + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, 0x8200); + tg3_writephy(tp, MII_TG3_DSP_CONTROL, 0x0000); + + tg3_phy_toggle_auxctl_smdsp(tp, false); + + tg3_writephy(tp, MII_CTRL1000, phy9_orig); + + err = tg3_readphy(tp, MII_TG3_EXT_CTRL, ®32); + if (err) + return err; + + reg32 &= ~0x3000; + tg3_writephy(tp, MII_TG3_EXT_CTRL, reg32); + + return 0; +} + +/* This will reset the tigon3 PHY if there is no valid + * link unless the FORCE argument is non-zero. + */ +static int tg3_phy_reset(struct tg3_priv *tp) +{ + u32 val, cpmuctrl; + int err; + + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + val = tr32(GRC_MISC_CFG); + tw32_f(GRC_MISC_CFG, val & ~GRC_MISC_CFG_EPHY_IDDQ); + udelay(40); + } + err = tg3_readphy(tp, MII_BMSR, &val); + err |= tg3_readphy(tp, MII_BMSR, &val); + if (err != 0) + return -EBUSY; + + if (tg3_asic_rev(tp) == ASIC_REV_5703 || + tg3_asic_rev(tp) == ASIC_REV_5704 || + tg3_asic_rev(tp) == ASIC_REV_5705) { + err = tg3_phy_reset_5703_4_5(tp); + if (err) + return err; + goto out; + } + + cpmuctrl = 0; + if (tg3_asic_rev(tp) == ASIC_REV_5784 && + tg3_chip_rev(tp) != CHIPREV_5784_AX) { + cpmuctrl = tr32(TG3_CPMU_CTRL); + if (cpmuctrl & CPMU_CTRL_GPHY_10MB_RXONLY) + tw32(TG3_CPMU_CTRL, + cpmuctrl & ~CPMU_CTRL_GPHY_10MB_RXONLY); + } + + err = tg3_bmcr_reset(tp); + if (err) + return err; + + if (cpmuctrl & CPMU_CTRL_GPHY_10MB_RXONLY) { + val = MII_TG3_DSP_EXP8_AEDW | MII_TG3_DSP_EXP8_REJ2MHz; + tg3_phydsp_write(tp, MII_TG3_DSP_EXP8, val); + + tw32(TG3_CPMU_CTRL, cpmuctrl); + } + + if (tg3_chip_rev(tp) == CHIPREV_5784_AX || + tg3_chip_rev(tp) == CHIPREV_5761_AX) { + val = tr32(TG3_CPMU_LSPD_1000MB_CLK); + if ((val & CPMU_LSPD_1000MB_MACCLK_MASK) == + CPMU_LSPD_1000MB_MACCLK_12_5) { + val &= ~CPMU_LSPD_1000MB_MACCLK_MASK; + udelay(40); + tw32_f(TG3_CPMU_LSPD_1000MB_CLK, val); + } + } + + if (tg3_flag(tp, 5717_PLUS) && + (tp->phy_flags & TG3_PHYFLG_MII_SERDES)) + return 0; + + tg3_phy_apply_otp(tp); + + if (tp->phy_flags & TG3_PHYFLG_ENABLE_APD) + tg3_phy_toggle_apd(tp, true); + else + tg3_phy_toggle_apd(tp, false); + +out: + if ((tp->phy_flags & TG3_PHYFLG_ADC_BUG) && + !tg3_phy_toggle_auxctl_smdsp(tp, true)) { + tg3_phydsp_write(tp, 0x201f, 0x2aaa); + tg3_phydsp_write(tp, 0x000a, 0x0323); + tg3_phy_toggle_auxctl_smdsp(tp, false); + } + + if (tp->phy_flags & TG3_PHYFLG_5704_A0_BUG) { + tg3_writephy(tp, MII_TG3_MISC_SHDW, 0x8d68); + tg3_writephy(tp, MII_TG3_MISC_SHDW, 0x8d68); + } + + if (tp->phy_flags & TG3_PHYFLG_BER_BUG) { + if (!tg3_phy_toggle_auxctl_smdsp(tp, true)) { + tg3_phydsp_write(tp, 0x000a, 0x310b); + tg3_phydsp_write(tp, 0x201f, 0x9506); + tg3_phydsp_write(tp, 0x401f, 0x14e2); + tg3_phy_toggle_auxctl_smdsp(tp, false); + } + } else if (tp->phy_flags & TG3_PHYFLG_JITTER_BUG) { + if (!tg3_phy_toggle_auxctl_smdsp(tp, true)) { + tg3_writephy(tp, MII_TG3_DSP_ADDRESS, 0x000a); + if (tp->phy_flags & TG3_PHYFLG_ADJUST_TRIM) { + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, 0x110b); + tg3_writephy(tp, MII_TG3_TEST1, + MII_TG3_TEST1_TRIM_EN | 0x4); + } else { + tg3_writephy(tp, MII_TG3_DSP_RW_PORT, 0x010b); + } + + tg3_phy_toggle_auxctl_smdsp(tp, false); + } + } + + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + /* adjust output voltage */ + tg3_writephy(tp, MII_TG3_FET_PTEST, 0x12); + } + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5762_A0) + tg3_phydsp_write(tp, 0xffb, 0x4000); + + tg3_phy_toggle_automdix(tp, true); + tg3_phy_set_wirespeed(tp); + return 0; +} + +#define TG3_GPIO_MSG_DRVR_PRES 0x00000001 +#define TG3_GPIO_MSG_NEED_VAUX 0x00000002 +#define TG3_GPIO_MSG_MASK (TG3_GPIO_MSG_DRVR_PRES | \ + TG3_GPIO_MSG_NEED_VAUX) +#define TG3_GPIO_MSG_ALL_DRVR_PRES_MASK \ + ((TG3_GPIO_MSG_DRVR_PRES << 0) | \ + (TG3_GPIO_MSG_DRVR_PRES << 4) | \ + (TG3_GPIO_MSG_DRVR_PRES << 8) | \ + (TG3_GPIO_MSG_DRVR_PRES << 12)) + +#define TG3_GPIO_MSG_ALL_NEED_VAUX_MASK \ + ((TG3_GPIO_MSG_NEED_VAUX << 0) | \ + (TG3_GPIO_MSG_NEED_VAUX << 4) | \ + (TG3_GPIO_MSG_NEED_VAUX << 8) | \ + (TG3_GPIO_MSG_NEED_VAUX << 12)) + +static inline u32 tg3_set_function_status(struct tg3_priv *tp, u32 newstat) +{ + u32 status, shift; + + status = tr32(TG3_CPMU_DRV_STATUS); + + shift = TG3_APE_GPIO_MSG_SHIFT + 4 * tp->pci_fn; + status &= ~(TG3_GPIO_MSG_MASK << shift); + status |= (newstat << shift); + + tw32(TG3_CPMU_DRV_STATUS, status); + + return status >> TG3_APE_GPIO_MSG_SHIFT; +} + +static inline int tg3_pwrsrc_switch_to_vmain(struct tg3_priv *tp) +{ + if (!tg3_flag(tp, IS_NIC)) + return 0; + + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) { + tg3_set_function_status(tp, TG3_GPIO_MSG_DRVR_PRES); + + tw32_wait_f(GRC_LOCAL_CTRL, tp->grc_local_ctrl, + TG3_GRC_LCLCTL_PWRSW_DELAY); + + } else { + tw32_wait_f(GRC_LOCAL_CTRL, tp->grc_local_ctrl, + TG3_GRC_LCLCTL_PWRSW_DELAY); + } + + return 0; +} + +static int tg3_5700_link_polarity(struct tg3_priv *tp, u32 speed) +{ + if (tp->led_ctrl == LED_CTRL_MODE_PHY_2) { + return 1; + } else if ((tp->phy_id & TG3_PHY_ID_MASK) == TG3_PHY_ID_BCM5411) { + if (speed != SPEED_10) + return 1; + } else if (speed == SPEED_10) { + return 1; + } + + return 0; +} + +static void __tg3_set_one_mac_addr(struct tg3_priv *tp, u8 *mac_addr, int index) +{ + u32 addr_high, addr_low; + + addr_high = ((mac_addr[0] << 8) | mac_addr[1]); + addr_low = ((mac_addr[2] << 24) | (mac_addr[3] << 16) | + (mac_addr[4] << 8) | mac_addr[5]); + + if (index < 4) { + tw32(MAC_ADDR_0_HIGH + (index * 8), addr_high); + tw32(MAC_ADDR_0_LOW + (index * 8), addr_low); + } else { + index -= 4; + tw32(MAC_EXTADDR_0_HIGH + (index * 8), addr_high); + tw32(MAC_EXTADDR_0_LOW + (index * 8), addr_low); + } +} + +static void __tg3_set_mac_addr(struct tg3_priv *tp, bool skip_mac_1) +{ + u32 addr_high; + int i; + + for (i = 0; i < 4; i++) { + if (i == 1 && skip_mac_1) + continue; + __tg3_set_one_mac_addr(tp, tp->mac_address, i); + } + + if (tg3_asic_rev(tp) == ASIC_REV_5703 || + tg3_asic_rev(tp) == ASIC_REV_5704) { + for (i = 4; i < 16; i++) + __tg3_set_one_mac_addr(tp, tp->mac_address, i); + } + addr_high = (tp->mac_address[0] + tp->mac_address[1] + + tp->mac_address[2] + tp->mac_address[3] + + tp->mac_address[4] + tp->mac_address[5]) & + TX_BACKOFF_SEED_MASK; + tw32(MAC_TX_BACKOFF_SEED, addr_high); +} + +static void tg3_enable_register_access(struct tg3_priv *tp) +{ + /* + * Make sure register accesses (indirect or otherwise) will function + * correctly. + */ + pci_write_config_dword(tp->devno, + TG3PCI_MISC_HOST_CTRL, tp->misc_host_ctrl); +} + +static int tg3_power_up(struct tg3_priv *tp) +{ + tg3_enable_register_access(tp); + + /* Switch out of Vaux if it is a NIC */ + tg3_pwrsrc_switch_to_vmain(tp); + + return 0; +} + +static int tg3_setup_phy(struct tg3_priv*, bool); + +static void tg3_aux_stat_to_speed_duplex(struct tg3_priv *tp, u32 val, u16 *speed, + u8 *duplex) +{ + switch (val & MII_TG3_AUX_STAT_SPDMASK) { + case MII_TG3_AUX_STAT_10HALF: + *speed = SPEED_10; + *duplex = DUPLEX_HALF; + break; + + case MII_TG3_AUX_STAT_10FULL: + *speed = SPEED_10; + *duplex = DUPLEX_FULL; + break; + + case MII_TG3_AUX_STAT_100HALF: + *speed = SPEED_100; + *duplex = DUPLEX_HALF; + break; + + case MII_TG3_AUX_STAT_100FULL: + *speed = SPEED_100; + *duplex = DUPLEX_FULL; + break; + + case MII_TG3_AUX_STAT_1000HALF: + *speed = SPEED_1000; + *duplex = DUPLEX_HALF; + break; + + case MII_TG3_AUX_STAT_1000FULL: + *speed = SPEED_1000; + *duplex = DUPLEX_FULL; + break; + + default: + if (tp->phy_flags & TG3_PHYFLG_IS_FET) { + *speed = (val & MII_TG3_AUX_STAT_100) ? SPEED_100 : + SPEED_10; + *duplex = (val & MII_TG3_AUX_STAT_FULL) ? DUPLEX_FULL : + DUPLEX_HALF; + break; + } + *speed = SPEED_UNKNOWN; + *duplex = DUPLEX_UNKNOWN; + break; + } +} + +static int tg3_phy_autoneg_cfg(struct tg3_priv *tp, u32 advertise) +{ + int err = 0; + u32 new_adv; + + new_adv = ADVERTISE_CSMA | ADVERTISE_ALL; + + err = tg3_writephy(tp, MII_ADVERTISE, new_adv); + if (err) + goto done; + + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + new_adv = ADVERTISE_CSMA | ADVERTISE_ALL | ADVERTISE_1000FULL; + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5701_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B0) + new_adv |= CTL1000_AS_MASTER | CTL1000_ENABLE_MASTER; + + err = tg3_writephy(tp, MII_CTRL1000, new_adv); + if (err) + goto done; + } + +done: + return err; +} + +static void tg3_phy_copper_begin(struct tg3_priv *tp) +{ + if (tp->link_config.autoneg == AUTONEG_ENABLE || + (tp->phy_flags & TG3_PHYFLG_IS_LOW_POWER)) { + u32 adv; + + if ((tp->phy_flags & TG3_PHYFLG_IS_LOW_POWER) && + !(tp->phy_flags & TG3_PHYFLG_KEEP_LINK_ON_PWRDN)) { + adv = ADVERTISED_10baseT_Half | + ADVERTISED_10baseT_Full; + if (tg3_flag(tp, WOL_SPEED_100MB)) + adv |= ADVERTISED_100baseT_Half | + ADVERTISED_100baseT_Full; + if (tp->phy_flags & TG3_PHYFLG_1G_ON_VAUX_OK) { + if (!(tp->phy_flags & + TG3_PHYFLG_DISABLE_1G_HD_ADV)) + adv |= ADVERTISED_1000baseT_Half; + adv |= ADVERTISED_1000baseT_Full; + } + } else { + adv = tp->link_config.advertising; + if (tp->phy_flags & TG3_PHYFLG_10_100_ONLY) + adv &= ~(ADVERTISED_1000baseT_Half | + ADVERTISED_1000baseT_Full); + } + + tg3_phy_autoneg_cfg(tp, adv); + + if ((tp->phy_flags & TG3_PHYFLG_IS_LOW_POWER) && + (tp->phy_flags & TG3_PHYFLG_KEEP_LINK_ON_PWRDN)) { + /* Normally during power down we want to autonegotiate + * the lowest possible speed for WOL. However, to avoid + * link flap, we leave it untouched. + */ + return; + } + + tg3_writephy(tp, MII_BMCR, + BMCR_ANENABLE | BMCR_ANRESTART); + } else { + int i; + u32 bmcr, orig_bmcr; + + tp->link_config.active_speed = tp->link_config.speed; + tp->link_config.active_duplex = tp->link_config.duplex; + + if (tg3_asic_rev(tp) == ASIC_REV_5714) { + /* With autoneg disabled, 5715 only links up when the + * advertisement register has the configured speed + * enabled. + */ + tg3_writephy(tp, MII_ADVERTISE, ADVERTISE_ALL); + } + + bmcr = 0; + switch (tp->link_config.speed) { + default: + case SPEED_10: + break; + + case SPEED_100: + bmcr |= BMCR_SPEED100; + break; + + case SPEED_1000: + bmcr |= BMCR_SPEED1000; + break; + } + + if (tp->link_config.duplex == DUPLEX_FULL) + bmcr |= BMCR_FULLDPLX; + + if (!tg3_readphy(tp, MII_BMCR, &orig_bmcr) && + (bmcr != orig_bmcr)) { + tg3_writephy(tp, MII_BMCR, BMCR_LOOPBACK); + for (i = 0; i < 1500; i++) { + u32 tmp; + + udelay(10); + if (tg3_readphy(tp, MII_BMSR, &tmp) || + tg3_readphy(tp, MII_BMSR, &tmp)) + continue; + if (!(tmp & BMSR_LSTATUS)) { + udelay(40); + break; + } + } + tg3_writephy(tp, MII_BMCR, bmcr); + udelay(40); + } + } +} + +/* TODO */ +/* BEGIN: Borrowed from Linux */ + +/** + * ethtool_adv_to_mii_adv_x + * @ethadv: the ethtool advertisement settings + * + * A small helper function that translates ethtool advertisement + * settings to phy autonegotiation advertisements for the + * MII_CTRL1000 register when in 1000Base-X mode. + */ +static inline u32 ethtool_adv_to_mii_adv_x(u32 ethadv) +{ + u32 result = 0; + + if (ethadv & ADVERTISED_1000baseT_Half) + result |= ADVERTISE_1000XHALF; + if (ethadv & ADVERTISED_1000baseT_Full) + result |= ADVERTISE_1000XFULL; + + return result; +} + +/** + * mii_adv_to_ethtool_adv_t + * @adv: value of the MII_ADVERTISE register + * + * A small helper function that translates MII_ADVERTISE bits + * to ethtool advertisement settings. + */ +static inline u32 mii_adv_to_ethtool_adv_t(u32 adv) +{ + u32 result = 0; + + if (adv & ADVERTISE_10HALF) + result |= ADVERTISED_10baseT_Half; + if (adv & ADVERTISE_10FULL) + result |= ADVERTISED_10baseT_Full; + if (adv & ADVERTISE_100HALF) + result |= ADVERTISED_100baseT_Half; + if (adv & ADVERTISE_100FULL) + result |= ADVERTISED_100baseT_Full; + + return result; +} + +/** + * mii_ctrl1000_to_ethtool_adv_t + * @adv: value of the MII_CTRL1000 register + * + * A small helper function that translates MII_CTRL1000 + * bits, when in 1000Base-T mode, to ethtool + * advertisement settings. + */ +static inline u32 mii_ctrl1000_to_ethtool_adv_t(u32 adv) +{ + u32 result = 0; + + if (adv & ADVERTISE_1000HALF) + result |= ADVERTISED_1000baseT_Half; + if (adv & ADVERTISE_1000FULL) + result |= ADVERTISED_1000baseT_Full; + + return result; +} +/** + * mii_adv_to_ethtool_adv_x + * @adv: value of the MII_CTRL1000 register + * + * A small helper function that translates MII_CTRL1000 + * bits, when in 1000Base-X mode, to ethtool + * advertisement settings. + */ +static inline u32 mii_adv_to_ethtool_adv_x(u32 adv) +{ + u32 result = 0; + + if (adv & ADVERTISE_1000XHALF) + result |= ADVERTISED_1000baseT_Half; + if (adv & ADVERTISE_1000XFULL) + result |= ADVERTISED_1000baseT_Full; + return result; +} +/* END: Borrowed from Linux */ + +static int tg3_phy_pull_config(struct tg3_priv *tp) +{ + int err; + u32 val; + + err = tg3_readphy(tp, MII_BMCR, &val); + if (err) + goto done; + + if (!(val & BMCR_ANENABLE)) { + tp->link_config.autoneg = AUTONEG_DISABLE; + tp->link_config.advertising = 0; + tg3_flag_clear(tp, PAUSE_AUTONEG); + + err = -EIO; + + switch (val & (BMCR_SPEED1000 | BMCR_SPEED100)) { + case 0: + if (tp->phy_flags & TG3_PHYFLG_ANY_SERDES) + goto done; + + tp->link_config.speed = SPEED_10; + break; + case BMCR_SPEED100: + if (tp->phy_flags & TG3_PHYFLG_ANY_SERDES) + goto done; + + tp->link_config.speed = SPEED_100; + break; + case BMCR_SPEED1000: + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + tp->link_config.speed = SPEED_1000; + break; + } + /* Fall through */ + default: + goto done; + } + + if (val & BMCR_FULLDPLX) + tp->link_config.duplex = DUPLEX_FULL; + else + tp->link_config.duplex = DUPLEX_HALF; + + err = 0; + goto done; + } + + tp->link_config.autoneg = AUTONEG_ENABLE; + tp->link_config.advertising = ADVERTISED_Autoneg; + + if (!(tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) { + u32 adv; + + err = tg3_readphy(tp, MII_ADVERTISE, &val); + if (err) + goto done; + + adv = mii_adv_to_ethtool_adv_t(val & ADVERTISE_ALL); + tp->link_config.advertising |= adv | ADVERTISED_TP; + + } else { + tp->link_config.advertising |= ADVERTISED_FIBRE; + } + + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + u32 adv; + + if (!(tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) { + err = tg3_readphy(tp, MII_CTRL1000, &val); + if (err) + goto done; + + adv = mii_ctrl1000_to_ethtool_adv_t(val); + } else { + err = tg3_readphy(tp, MII_ADVERTISE, &val); + if (err) + goto done; + + adv = 0; + + val &= (ADVERTISE_1000XHALF | ADVERTISE_1000XFULL); + adv = mii_adv_to_ethtool_adv_x(val); + } + + tp->link_config.advertising |= adv; + } + +done: + return err; +} + +static int tg3_init_5401phy_dsp(struct tg3_priv *tp) +{ + int err; + + /* Turn off tap power management. */ + /* Set Extended packet length bit */ + err = tg3_phy_auxctl_write(tp, MII_TG3_AUXCTL_SHDWSEL_AUXCTL, 0x4c20); + + err |= tg3_phydsp_write(tp, 0x0012, 0x1804); + err |= tg3_phydsp_write(tp, 0x0013, 0x1204); + err |= tg3_phydsp_write(tp, 0x8006, 0x0132); + err |= tg3_phydsp_write(tp, 0x8006, 0x0232); + err |= tg3_phydsp_write(tp, 0x201f, 0x0a20); + + udelay(40); + + return err; +} + +static bool tg3_phy_copper_an_config_ok(struct tg3_priv *tp, u32 *lcladv) +{ + u32 advmsk, tgtadv; + + /* TODO NOTE: Assuming we always want 10/100/1000 */ + + tgtadv = ADVERTISE_ALL; + advmsk = ADVERTISE_ALL; + + if (tg3_readphy(tp, MII_ADVERTISE, lcladv)) + return false; + + if ((*lcladv & advmsk) != tgtadv) + return false; + + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + u32 tg3_ctrl; + + tgtadv = ADVERTISE_ALL | ADVERTISE_1000FULL; + + if (tg3_readphy(tp, MII_CTRL1000, &tg3_ctrl)) + return false; + + if (tgtadv && + (tg3_chip_rev_id(tp) == CHIPREV_ID_5701_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B0)) { + tgtadv |= CTL1000_AS_MASTER | CTL1000_ENABLE_MASTER; + tg3_ctrl &= (ADVERTISE_1000HALF | ADVERTISE_1000FULL | + CTL1000_AS_MASTER | CTL1000_ENABLE_MASTER); + } else { + tg3_ctrl &= (ADVERTISE_1000HALF | ADVERTISE_1000FULL); + } + + if (tg3_ctrl != tgtadv) + return false; + } + + return true; +} + +static bool tg3_phy_copper_fetch_rmtadv(struct tg3_priv *tp, u32 *rmtadv) +{ + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + u32 val; + + if (tg3_readphy(tp, MII_STAT1000, &val)) + return false; + } + + if (tg3_readphy(tp, MII_LPA, rmtadv)) + return false; + + return true; +} + +static void tg3_clear_mac_status(struct tg3_priv *tp) +{ + tw32(MAC_EVENT, 0); + + tw32_f(MAC_STATUS, + MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED | + MAC_STATUS_MI_COMPLETION | + MAC_STATUS_LNKSTATE_CHANGED); + udelay(40); +} + +static int tg3_setup_copper_phy(struct tg3_priv *tp, bool force_reset) +{ + bool current_link_up; + u32 bmsr, val; + u32 lcl_adv, rmt_adv; + u16 current_speed; + u8 current_duplex; + int i, err; + + tg3_clear_mac_status(tp); + + if ((tp->mi_mode & MAC_MI_MODE_AUTO_POLL) != 0) { + tw32_f(MAC_MI_MODE, + (tp->mi_mode & ~MAC_MI_MODE_AUTO_POLL)); + udelay(80); + } + + tg3_phy_auxctl_write(tp, MII_TG3_AUXCTL_SHDWSEL_PWRCTL, 0); + + /* Some third-party PHYs need to be reset on link going + * down. + */ + if (force_reset) + tg3_phy_reset(tp); + + if ((tp->phy_id & TG3_PHY_ID_MASK) == TG3_PHY_ID_BCM5401) { + tg3_readphy(tp, MII_BMSR, &bmsr); + if (tg3_readphy(tp, MII_BMSR, &bmsr) || + !tg3_flag(tp, INIT_COMPLETE)) + bmsr = 0; + + if (!(bmsr & BMSR_LSTATUS)) { + err = tg3_init_5401phy_dsp(tp); + if (err) + return err; + + tg3_readphy(tp, MII_BMSR, &bmsr); + for (i = 0; i < 1000; i++) { + udelay(10); + if (!tg3_readphy(tp, MII_BMSR, &bmsr) && + (bmsr & BMSR_LSTATUS)) { + udelay(40); + break; + } + } + + if ((tp->phy_id & TG3_PHY_ID_REV_MASK) == + TG3_PHY_REV_BCM5401_B0 && + !(bmsr & BMSR_LSTATUS) && + tp->link_config.active_speed == SPEED_1000) { + err = tg3_phy_reset(tp); + if (!err) + err = tg3_init_5401phy_dsp(tp); + if (err) + return err; + } + } + } else if (tg3_chip_rev_id(tp) == CHIPREV_ID_5701_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B0) { + /* 5701 {A0,B0} CRC bug workaround */ + tg3_writephy(tp, 0x15, 0x0a75); + tg3_writephy(tp, MII_TG3_MISC_SHDW, 0x8c68); + tg3_writephy(tp, MII_TG3_MISC_SHDW, 0x8d68); + tg3_writephy(tp, MII_TG3_MISC_SHDW, 0x8c68); + } + + /* Clear pending interrupts... */ + tg3_readphy(tp, MII_TG3_ISTAT, &val); + tg3_readphy(tp, MII_TG3_ISTAT, &val); + + if (tp->phy_flags & TG3_PHYFLG_USE_MI_INTERRUPT) + tg3_writephy(tp, MII_TG3_IMASK, ~MII_TG3_INT_LINKCHG); + else if (!(tp->phy_flags & TG3_PHYFLG_IS_FET)) + tg3_writephy(tp, MII_TG3_IMASK, ~0); + + if (tg3_asic_rev(tp) == ASIC_REV_5700 || + tg3_asic_rev(tp) == ASIC_REV_5701) { + if (tp->led_ctrl == LED_CTRL_MODE_PHY_1) + tg3_writephy(tp, MII_TG3_EXT_CTRL, + MII_TG3_EXT_CTRL_LNK3_LED_MODE); + else + tg3_writephy(tp, MII_TG3_EXT_CTRL, 0); + } + + current_link_up = false; + current_speed = SPEED_UNKNOWN; + current_duplex = DUPLEX_UNKNOWN; + tp->phy_flags &= ~TG3_PHYFLG_MDIX_STATE; + + if (tp->phy_flags & TG3_PHYFLG_CAPACITIVE_COUPLING) { + err = tg3_phy_auxctl_read(tp, + MII_TG3_AUXCTL_SHDWSEL_MISCTEST, + &val); + if (!err && !(val & (1 << 10))) { + tg3_phy_auxctl_write(tp, + MII_TG3_AUXCTL_SHDWSEL_MISCTEST, + val | (1 << 10)); + goto relink; + } + } + + bmsr = 0; + for (i = 0; i < 100; i++) { + tg3_readphy(tp, MII_BMSR, &bmsr); + if (!tg3_readphy(tp, MII_BMSR, &bmsr) && + (bmsr & BMSR_LSTATUS)) + break; + udelay(40); + } + + if (bmsr & BMSR_LSTATUS) { + u32 aux_stat, bmcr; + + tg3_readphy(tp, MII_TG3_AUX_STAT, &aux_stat); + for (i = 0; i < 2000; i++) { + udelay(10); + if (!tg3_readphy(tp, MII_TG3_AUX_STAT, &aux_stat) && + aux_stat) + break; + } + + tg3_aux_stat_to_speed_duplex(tp, aux_stat, + ¤t_speed, + ¤t_duplex); + + bmcr = 0; + for (i = 0; i < 200; i++) { + tg3_readphy(tp, MII_BMCR, &bmcr); + if (tg3_readphy(tp, MII_BMCR, &bmcr)) + continue; + if (bmcr && bmcr != 0x7fff) + break; + udelay(10); + } + + lcl_adv = 0; + rmt_adv = 0; + + tp->link_config.active_speed = current_speed; + tp->link_config.active_duplex = current_duplex; + + if (tp->link_config.autoneg == AUTONEG_ENABLE) { + if ((bmcr & BMCR_ANENABLE) && + tg3_phy_copper_an_config_ok(tp, &lcl_adv) && + tg3_phy_copper_fetch_rmtadv(tp, &rmt_adv)) + current_link_up = true; + + } else { + if (!(bmcr & BMCR_ANENABLE) && + tp->link_config.speed == current_speed && + tp->link_config.duplex == current_duplex) { + current_link_up = true; + } + } + + if (current_link_up && + tp->link_config.active_duplex == DUPLEX_FULL) { + u32 reg, bit; + + if (tp->phy_flags & TG3_PHYFLG_IS_FET) { + reg = MII_TG3_FET_GEN_STAT; + bit = MII_TG3_FET_GEN_STAT_MDIXSTAT; + } else { + reg = MII_TG3_EXT_STAT; + bit = MII_TG3_EXT_STAT_MDIX; + } + + if (!tg3_readphy(tp, reg, &val) && (val & bit)) + tp->phy_flags |= TG3_PHYFLG_MDIX_STATE; + } + } + +relink: + if (!current_link_up || (tp->phy_flags & TG3_PHYFLG_IS_LOW_POWER)) { + tg3_phy_copper_begin(tp); + + if (tg3_flag(tp, ROBOSWITCH)) { + current_link_up = true; + /* FIXME: when BCM5325 switch is used use 100 MBit/s */ + current_speed = SPEED_1000; + current_duplex = DUPLEX_FULL; + tp->link_config.active_speed = current_speed; + tp->link_config.active_duplex = current_duplex; + } + + tg3_readphy(tp, MII_BMSR, &bmsr); + if ((!tg3_readphy(tp, MII_BMSR, &bmsr) && (bmsr & BMSR_LSTATUS)) || + (tp->mac_mode & MAC_MODE_PORT_INT_LPBACK)) + current_link_up = true; + } + + tp->mac_mode &= ~MAC_MODE_PORT_MODE_MASK; + if (current_link_up) { + if (tp->link_config.active_speed == SPEED_100 || + tp->link_config.active_speed == SPEED_10) + tp->mac_mode |= MAC_MODE_PORT_MODE_MII; + else + tp->mac_mode |= MAC_MODE_PORT_MODE_GMII; + } else if (tp->phy_flags & TG3_PHYFLG_IS_FET) { + tp->mac_mode |= MAC_MODE_PORT_MODE_MII; + } else { + tp->mac_mode |= MAC_MODE_PORT_MODE_GMII; + } + + /* In order for the 5750 core in BCM4785 chip to work properly + * in RGMII mode, the Led Control Register must be set up. + */ + if (tg3_flag(tp, RGMII_MODE)) { + u32 led_ctrl = tr32(MAC_LED_CTRL); + led_ctrl &= ~(LED_CTRL_1000MBPS_ON | LED_CTRL_100MBPS_ON); + + if (tp->link_config.active_speed == SPEED_10) + led_ctrl |= LED_CTRL_LNKLED_OVERRIDE; + else if (tp->link_config.active_speed == SPEED_100) + led_ctrl |= (LED_CTRL_LNKLED_OVERRIDE | + LED_CTRL_100MBPS_ON); + else if (tp->link_config.active_speed == SPEED_1000) + led_ctrl |= (LED_CTRL_LNKLED_OVERRIDE | + LED_CTRL_1000MBPS_ON); + + tw32(MAC_LED_CTRL, led_ctrl); + udelay(40); + } + + tp->mac_mode &= ~MAC_MODE_HALF_DUPLEX; + if (tp->link_config.active_duplex == DUPLEX_HALF) + tp->mac_mode |= MAC_MODE_HALF_DUPLEX; + + if (tg3_asic_rev(tp) == ASIC_REV_5700) { + if (current_link_up && + tg3_5700_link_polarity(tp, tp->link_config.active_speed)) + tp->mac_mode |= MAC_MODE_LINK_POLARITY; + else + tp->mac_mode &= ~MAC_MODE_LINK_POLARITY; + } + + /* ??? Without this setting Netgear GA302T PHY does not + * ??? send/receive packets... + */ + if ((tp->phy_id & TG3_PHY_ID_MASK) == TG3_PHY_ID_BCM5411 && + tg3_chip_rev_id(tp) == CHIPREV_ID_5700_ALTIMA) { + tp->mi_mode |= MAC_MI_MODE_AUTO_POLL; + tw32_f(MAC_MI_MODE, tp->mi_mode); + udelay(80); + } + + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + if (tg3_flag(tp, USE_LINKCHG_REG)) { + /* Polled via timer. */ + tw32_f(MAC_EVENT, 0); + } else { + tw32_f(MAC_EVENT, MAC_EVENT_LNKSTATE_CHANGED); + } + udelay(40); + + if (tg3_asic_rev(tp) == ASIC_REV_5700 && + current_link_up && + tp->link_config.active_speed == SPEED_1000 && + (tg3_flag(tp, PCI_HIGH_SPEED))) { + udelay(120); + tw32_f(MAC_STATUS, + (MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED)); + udelay(40); + tg3_write_mem(tp, + NIC_SRAM_FIRMWARE_MBOX, + NIC_SRAM_FIRMWARE_MBOX_MAGIC2); + } + + return 0; +} + +struct tg3_fiber_aneginfo { + int state; +#define ANEG_STATE_UNKNOWN 0 +#define ANEG_STATE_AN_ENABLE 1 +#define ANEG_STATE_RESTART_INIT 2 +#define ANEG_STATE_RESTART 3 +#define ANEG_STATE_DISABLE_LINK_OK 4 +#define ANEG_STATE_ABILITY_DETECT_INIT 5 +#define ANEG_STATE_ABILITY_DETECT 6 +#define ANEG_STATE_ACK_DETECT_INIT 7 +#define ANEG_STATE_ACK_DETECT 8 +#define ANEG_STATE_COMPLETE_ACK_INIT 9 +#define ANEG_STATE_COMPLETE_ACK 10 +#define ANEG_STATE_IDLE_DETECT_INIT 11 +#define ANEG_STATE_IDLE_DETECT 12 +#define ANEG_STATE_LINK_OK 13 +#define ANEG_STATE_NEXT_PAGE_WAIT_INIT 14 +#define ANEG_STATE_NEXT_PAGE_WAIT 15 + + u32 flags; +#define MR_AN_ENABLE 0x00000001 +#define MR_RESTART_AN 0x00000002 +#define MR_AN_COMPLETE 0x00000004 +#define MR_PAGE_RX 0x00000008 +#define MR_NP_LOADED 0x00000010 +#define MR_TOGGLE_TX 0x00000020 +#define MR_LP_ADV_FULL_DUPLEX 0x00000040 +#define MR_LP_ADV_HALF_DUPLEX 0x00000080 +#define MR_LP_ADV_REMOTE_FAULT1 0x00000400 +#define MR_LP_ADV_REMOTE_FAULT2 0x00000800 +#define MR_LP_ADV_NEXT_PAGE 0x00001000 +#define MR_TOGGLE_RX 0x00002000 +#define MR_NP_RX 0x00004000 + +#define MR_LINK_OK 0x80000000 + + unsigned long link_time, cur_time; + + u32 ability_match_cfg; + int ability_match_count; + + char ability_match, idle_match, ack_match; + + u32 txconfig, rxconfig; +#define ANEG_CFG_NP 0x00000080 +#define ANEG_CFG_ACK 0x00000040 +#define ANEG_CFG_RF2 0x00000020 +#define ANEG_CFG_RF1 0x00000010 +#define ANEG_CFG_PS2 0x00000001 +#define ANEG_CFG_PS1 0x00008000 +#define ANEG_CFG_HD 0x00004000 +#define ANEG_CFG_FD 0x00002000 +#define ANEG_CFG_INVAL 0x00001f06 + +}; +#define ANEG_OK 0 +#define ANEG_DONE 1 +#define ANEG_TIMER_ENAB 2 +#define ANEG_FAILED -1 + +#define ANEG_STATE_SETTLE_TIME 10000 + +static int tg3_fiber_aneg_smachine(struct tg3_priv *tp, + struct tg3_fiber_aneginfo *ap) +{ + unsigned long delta; + u32 rx_cfg_reg; + int ret; + + if (ap->state == ANEG_STATE_UNKNOWN) { + ap->rxconfig = 0; + ap->link_time = 0; + ap->cur_time = 0; + ap->ability_match_cfg = 0; + ap->ability_match_count = 0; + ap->ability_match = 0; + ap->idle_match = 0; + ap->ack_match = 0; + } + ap->cur_time++; + + if (tr32(MAC_STATUS) & MAC_STATUS_RCVD_CFG) { + rx_cfg_reg = tr32(MAC_RX_AUTO_NEG); + + if (rx_cfg_reg != ap->ability_match_cfg) { + ap->ability_match_cfg = rx_cfg_reg; + ap->ability_match = 0; + ap->ability_match_count = 0; + } else { + if (++ap->ability_match_count > 1) { + ap->ability_match = 1; + ap->ability_match_cfg = rx_cfg_reg; + } + } + if (rx_cfg_reg & ANEG_CFG_ACK) + ap->ack_match = 1; + else + ap->ack_match = 0; + + ap->idle_match = 0; + } else { + ap->idle_match = 1; + ap->ability_match_cfg = 0; + ap->ability_match_count = 0; + ap->ability_match = 0; + ap->ack_match = 0; + + rx_cfg_reg = 0; + } + + ap->rxconfig = rx_cfg_reg; + ret = ANEG_OK; + + switch (ap->state) { + case ANEG_STATE_UNKNOWN: + if (ap->flags & (MR_AN_ENABLE | MR_RESTART_AN)) + ap->state = ANEG_STATE_AN_ENABLE; + + /* fallthru */ + case ANEG_STATE_AN_ENABLE: + ap->flags &= ~(MR_AN_COMPLETE | MR_PAGE_RX); + if (ap->flags & MR_AN_ENABLE) { + ap->link_time = 0; + ap->cur_time = 0; + ap->ability_match_cfg = 0; + ap->ability_match_count = 0; + ap->ability_match = 0; + ap->idle_match = 0; + ap->ack_match = 0; + + ap->state = ANEG_STATE_RESTART_INIT; + } else { + ap->state = ANEG_STATE_DISABLE_LINK_OK; + } + break; + + case ANEG_STATE_RESTART_INIT: + ap->link_time = ap->cur_time; + ap->flags &= ~(MR_NP_LOADED); + ap->txconfig = 0; + tw32(MAC_TX_AUTO_NEG, 0); + tp->mac_mode |= MAC_MODE_SEND_CONFIGS; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + ret = ANEG_TIMER_ENAB; + ap->state = ANEG_STATE_RESTART; + + /* fallthru */ + case ANEG_STATE_RESTART: + delta = ap->cur_time - ap->link_time; + if (delta > ANEG_STATE_SETTLE_TIME) + ap->state = ANEG_STATE_ABILITY_DETECT_INIT; + else + ret = ANEG_TIMER_ENAB; + break; + + case ANEG_STATE_DISABLE_LINK_OK: + ret = ANEG_DONE; + break; + + case ANEG_STATE_ABILITY_DETECT_INIT: + ap->flags &= ~(MR_TOGGLE_TX); + ap->txconfig = ANEG_CFG_FD; + tw32(MAC_TX_AUTO_NEG, ap->txconfig); + tp->mac_mode |= MAC_MODE_SEND_CONFIGS; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + ap->state = ANEG_STATE_ABILITY_DETECT; + break; + + case ANEG_STATE_ABILITY_DETECT: + if (ap->ability_match != 0 && ap->rxconfig != 0) + ap->state = ANEG_STATE_ACK_DETECT_INIT; + break; + + case ANEG_STATE_ACK_DETECT_INIT: + ap->txconfig |= ANEG_CFG_ACK; + tw32(MAC_TX_AUTO_NEG, ap->txconfig); + tp->mac_mode |= MAC_MODE_SEND_CONFIGS; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + ap->state = ANEG_STATE_ACK_DETECT; + + /* fallthru */ + case ANEG_STATE_ACK_DETECT: + if (ap->ack_match != 0) { + if ((ap->rxconfig & ~ANEG_CFG_ACK) == + (ap->ability_match_cfg & ~ANEG_CFG_ACK)) { + ap->state = ANEG_STATE_COMPLETE_ACK_INIT; + } else { + ap->state = ANEG_STATE_AN_ENABLE; + } + } else if (ap->ability_match != 0 && + ap->rxconfig == 0) { + ap->state = ANEG_STATE_AN_ENABLE; + } + break; + + case ANEG_STATE_COMPLETE_ACK_INIT: + if (ap->rxconfig & ANEG_CFG_INVAL) { + ret = ANEG_FAILED; + break; + } + ap->flags &= ~(MR_LP_ADV_FULL_DUPLEX | + MR_LP_ADV_HALF_DUPLEX | + MR_LP_ADV_REMOTE_FAULT1 | + MR_LP_ADV_REMOTE_FAULT2 | + MR_LP_ADV_NEXT_PAGE | + MR_TOGGLE_RX | + MR_NP_RX); + if (ap->rxconfig & ANEG_CFG_FD) + ap->flags |= MR_LP_ADV_FULL_DUPLEX; + if (ap->rxconfig & ANEG_CFG_HD) + ap->flags |= MR_LP_ADV_HALF_DUPLEX; + if (ap->rxconfig & ANEG_CFG_RF1) + ap->flags |= MR_LP_ADV_REMOTE_FAULT1; + if (ap->rxconfig & ANEG_CFG_RF2) + ap->flags |= MR_LP_ADV_REMOTE_FAULT2; + if (ap->rxconfig & ANEG_CFG_NP) + ap->flags |= MR_LP_ADV_NEXT_PAGE; + + ap->link_time = ap->cur_time; + + ap->flags ^= (MR_TOGGLE_TX); + if (ap->rxconfig & 0x0008) + ap->flags |= MR_TOGGLE_RX; + if (ap->rxconfig & ANEG_CFG_NP) + ap->flags |= MR_NP_RX; + ap->flags |= MR_PAGE_RX; + + ap->state = ANEG_STATE_COMPLETE_ACK; + ret = ANEG_TIMER_ENAB; + break; + + case ANEG_STATE_COMPLETE_ACK: + if (ap->ability_match != 0 && + ap->rxconfig == 0) { + ap->state = ANEG_STATE_AN_ENABLE; + break; + } + delta = ap->cur_time - ap->link_time; + if (delta > ANEG_STATE_SETTLE_TIME) { + if (!(ap->flags & (MR_LP_ADV_NEXT_PAGE))) { + ap->state = ANEG_STATE_IDLE_DETECT_INIT; + } else { + if ((ap->txconfig & ANEG_CFG_NP) == 0 && + !(ap->flags & MR_NP_RX)) { + ap->state = ANEG_STATE_IDLE_DETECT_INIT; + } else { + ret = ANEG_FAILED; + } + } + } + break; + + case ANEG_STATE_IDLE_DETECT_INIT: + ap->link_time = ap->cur_time; + tp->mac_mode &= ~MAC_MODE_SEND_CONFIGS; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + ap->state = ANEG_STATE_IDLE_DETECT; + ret = ANEG_TIMER_ENAB; + break; + + case ANEG_STATE_IDLE_DETECT: + if (ap->ability_match != 0 && + ap->rxconfig == 0) { + ap->state = ANEG_STATE_AN_ENABLE; + break; + } + delta = ap->cur_time - ap->link_time; + if (delta > ANEG_STATE_SETTLE_TIME) { + /* XXX another gem from the Broadcom driver :( */ + ap->state = ANEG_STATE_LINK_OK; + } + break; + + case ANEG_STATE_LINK_OK: + ap->flags |= (MR_AN_COMPLETE | MR_LINK_OK); + ret = ANEG_DONE; + break; + + case ANEG_STATE_NEXT_PAGE_WAIT_INIT: + /* ??? unimplemented */ + break; + + case ANEG_STATE_NEXT_PAGE_WAIT: + /* ??? unimplemented */ + break; + + default: + ret = ANEG_FAILED; + break; + } + + return ret; +} + +static int fiber_autoneg(struct tg3_priv *tp, u32 *txflags, u32 *rxflags) +{ + int res = 0; + struct tg3_fiber_aneginfo aninfo; + int status = ANEG_FAILED; + unsigned int tick; + u32 tmp; + + tw32_f(MAC_TX_AUTO_NEG, 0); + + tmp = tp->mac_mode & ~MAC_MODE_PORT_MODE_MASK; + tw32_f(MAC_MODE, tmp | MAC_MODE_PORT_MODE_GMII); + udelay(40); + + tw32_f(MAC_MODE, tp->mac_mode | MAC_MODE_SEND_CONFIGS); + udelay(40); + + memset(&aninfo, 0, sizeof(aninfo)); + aninfo.flags |= MR_AN_ENABLE; + aninfo.state = ANEG_STATE_UNKNOWN; + aninfo.cur_time = 0; + tick = 0; + while (++tick < 195000) { + status = tg3_fiber_aneg_smachine(tp, &aninfo); + if (status == ANEG_DONE || status == ANEG_FAILED) + break; + + udelay(1); + } + + tp->mac_mode &= ~MAC_MODE_SEND_CONFIGS; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + *txflags = aninfo.txconfig; + *rxflags = aninfo.flags; + + if (status == ANEG_DONE && + (aninfo.flags & (MR_AN_COMPLETE | MR_LINK_OK | + MR_LP_ADV_FULL_DUPLEX))) + res = 1; + + return res; +} + +static void tg3_init_bcm8002(struct tg3_priv *tp) +{ + u32 mac_status = tr32(MAC_STATUS); + int i; + + /* Reset when initting first time or we have a link. */ + if (tg3_flag(tp, INIT_COMPLETE) && + !(mac_status & MAC_STATUS_PCS_SYNCED)) + return; + + /* Set PLL lock range. */ + tg3_writephy(tp, 0x16, 0x8007); + + /* SW reset */ + tg3_writephy(tp, MII_BMCR, BMCR_RESET); + + /* Wait for reset to complete. */ + /* XXX schedule_timeout() ... */ + for (i = 0; i < 500; i++) + udelay(10); + + /* Config mode; select PMA/Ch 1 regs. */ + tg3_writephy(tp, 0x10, 0x8411); + + /* Enable auto-lock and comdet, select txclk for tx. */ + tg3_writephy(tp, 0x11, 0x0a10); + + tg3_writephy(tp, 0x18, 0x00a0); + tg3_writephy(tp, 0x16, 0x41ff); + + /* Assert and deassert POR. */ + tg3_writephy(tp, 0x13, 0x0400); + udelay(40); + tg3_writephy(tp, 0x13, 0x0000); + + tg3_writephy(tp, 0x11, 0x0a50); + udelay(40); + tg3_writephy(tp, 0x11, 0x0a10); + + /* Wait for signal to stabilize */ + /* XXX schedule_timeout() ... */ + for (i = 0; i < 15000; i++) + udelay(10); + + /* Deselect the channel register so we can read the PHYID + * later. + */ + tg3_writephy(tp, 0x10, 0x8011); +} + +static bool tg3_setup_fiber_hw_autoneg(struct tg3_priv *tp, u32 mac_status) +{ + bool current_link_up; + u32 sg_dig_ctrl, sg_dig_status; + u32 serdes_cfg, expected_sg_dig_ctrl; + int workaround, port_a; + + serdes_cfg = 0; + expected_sg_dig_ctrl = 0; + workaround = 0; + port_a = 1; + current_link_up = false; + + if (tg3_chip_rev_id(tp) != CHIPREV_ID_5704_A0 && + tg3_chip_rev_id(tp) != CHIPREV_ID_5704_A1) { + workaround = 1; + if (tr32(TG3PCI_DUAL_MAC_CTRL) & DUAL_MAC_CTRL_ID) + port_a = 0; + + /* preserve bits 0-11,13,14 for signal pre-emphasis */ + /* preserve bits 20-23 for voltage regulator */ + serdes_cfg = tr32(MAC_SERDES_CFG) & 0x00f06fff; + } + + sg_dig_ctrl = tr32(SG_DIG_CTRL); + + if (tp->link_config.autoneg != AUTONEG_ENABLE) { + if (sg_dig_ctrl & SG_DIG_USING_HW_AUTONEG) { + if (workaround) { + u32 val = serdes_cfg; + + if (port_a) + val |= 0xc010000; + else + val |= 0x4010000; + tw32_f(MAC_SERDES_CFG, val); + } + + tw32_f(SG_DIG_CTRL, SG_DIG_COMMON_SETUP); + } + if (mac_status & MAC_STATUS_PCS_SYNCED) { + current_link_up = true; + } + goto out; + } + + /* Want auto-negotiation. */ + expected_sg_dig_ctrl = SG_DIG_USING_HW_AUTONEG | SG_DIG_COMMON_SETUP; + + if (sg_dig_ctrl != expected_sg_dig_ctrl) { + if ((tp->phy_flags & TG3_PHYFLG_PARALLEL_DETECT) && + tp->serdes_counter && + ((mac_status & (MAC_STATUS_PCS_SYNCED | + MAC_STATUS_RCVD_CFG)) == + MAC_STATUS_PCS_SYNCED)) { + tp->serdes_counter--; + current_link_up = true; + goto out; + } +restart_autoneg: + if (workaround) + tw32_f(MAC_SERDES_CFG, serdes_cfg | 0xc011000); + tw32_f(SG_DIG_CTRL, expected_sg_dig_ctrl | SG_DIG_SOFT_RESET); + udelay(5); + tw32_f(SG_DIG_CTRL, expected_sg_dig_ctrl); + + tp->serdes_counter = SERDES_AN_TIMEOUT_5704S; + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + } else if (mac_status & (MAC_STATUS_PCS_SYNCED | + MAC_STATUS_SIGNAL_DET)) { + sg_dig_status = tr32(SG_DIG_STATUS); + mac_status = tr32(MAC_STATUS); + + if ((sg_dig_status & SG_DIG_AUTONEG_COMPLETE) && + (mac_status & MAC_STATUS_PCS_SYNCED)) { + + current_link_up = true; + tp->serdes_counter = 0; + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + } else if (!(sg_dig_status & SG_DIG_AUTONEG_COMPLETE)) { + if (tp->serdes_counter) + tp->serdes_counter--; + else { + if (workaround) { + u32 val = serdes_cfg; + + if (port_a) + val |= 0xc010000; + else + val |= 0x4010000; + + tw32_f(MAC_SERDES_CFG, val); + } + + tw32_f(SG_DIG_CTRL, SG_DIG_COMMON_SETUP); + udelay(40); + + /* Link parallel detection - link is up */ + /* only if we have PCS_SYNC and not */ + /* receiving config code words */ + mac_status = tr32(MAC_STATUS); + if ((mac_status & MAC_STATUS_PCS_SYNCED) && + !(mac_status & MAC_STATUS_RCVD_CFG)) { + current_link_up = true; + tp->phy_flags |= + TG3_PHYFLG_PARALLEL_DETECT; + tp->serdes_counter = + SERDES_PARALLEL_DET_TIMEOUT; + } else + goto restart_autoneg; + } + } + } else { + tp->serdes_counter = SERDES_AN_TIMEOUT_5704S; + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + } + +out: + return current_link_up; +} + +static bool tg3_setup_fiber_by_hand(struct tg3_priv *tp, u32 mac_status) +{ + bool current_link_up = false; + + if (!(mac_status & MAC_STATUS_PCS_SYNCED)) + goto out; + + if (tp->link_config.autoneg == AUTONEG_ENABLE) { + u32 txflags, rxflags; + int i; + + if (fiber_autoneg(tp, &txflags, &rxflags)) { + + current_link_up = true; + } + for (i = 0; i < 30; i++) { + udelay(20); + tw32_f(MAC_STATUS, + (MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED)); + udelay(40); + if ((tr32(MAC_STATUS) & + (MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED)) == 0) + break; + } + + mac_status = tr32(MAC_STATUS); + if (!current_link_up && + (mac_status & MAC_STATUS_PCS_SYNCED) && + !(mac_status & MAC_STATUS_RCVD_CFG)) + current_link_up = true; + } else { + /* Forcing 1000FD link up. */ + current_link_up = true; + + tw32_f(MAC_MODE, (tp->mac_mode | MAC_MODE_SEND_CONFIGS)); + udelay(40); + + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + } + +out: + return current_link_up; +} + +static int tg3_setup_fiber_phy(struct tg3_priv *tp, bool force_reset) +{ + u32 mac_status; + bool current_link_up; + int i; + + tw32_f(MAC_TX_AUTO_NEG, 0); + + tp->mac_mode &= ~(MAC_MODE_PORT_MODE_MASK | MAC_MODE_HALF_DUPLEX); + tp->mac_mode |= MAC_MODE_PORT_MODE_TBI; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + if (tp->phy_id == TG3_PHY_ID_BCM8002) + tg3_init_bcm8002(tp); + + /* Enable link change event even when serdes polling. */ + tw32_f(MAC_EVENT, MAC_EVENT_LNKSTATE_CHANGED); + udelay(40); + + current_link_up = false; + mac_status = tr32(MAC_STATUS); + + if (tg3_flag(tp, HW_AUTONEG)) + current_link_up = tg3_setup_fiber_hw_autoneg(tp, mac_status); + else + current_link_up = tg3_setup_fiber_by_hand(tp, mac_status); + + tp->napi[0].hw_status->status = + (SD_STATUS_UPDATED | + (tp->napi[0].hw_status->status & ~SD_STATUS_LINK_CHG)); + + for (i = 0; i < 100; i++) { + tw32_f(MAC_STATUS, (MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED)); + udelay(5); + if ((tr32(MAC_STATUS) & (MAC_STATUS_SYNC_CHANGED | + MAC_STATUS_CFG_CHANGED | + MAC_STATUS_LNKSTATE_CHANGED)) == 0) + break; + } + + mac_status = tr32(MAC_STATUS); + if ((mac_status & MAC_STATUS_PCS_SYNCED) == 0) { + current_link_up = false; + if (tp->link_config.autoneg == AUTONEG_ENABLE && + tp->serdes_counter == 0) { + tw32_f(MAC_MODE, (tp->mac_mode | + MAC_MODE_SEND_CONFIGS)); + udelay(1); + tw32_f(MAC_MODE, tp->mac_mode); + } + } + + if (current_link_up) { + tp->link_config.active_speed = SPEED_1000; + tp->link_config.active_duplex = DUPLEX_FULL; + tw32(MAC_LED_CTRL, (tp->led_ctrl | + LED_CTRL_LNKLED_OVERRIDE | + LED_CTRL_1000MBPS_ON)); + } else { + tp->link_config.active_speed = SPEED_UNKNOWN; + tp->link_config.active_duplex = DUPLEX_UNKNOWN; + tw32(MAC_LED_CTRL, (tp->led_ctrl | + LED_CTRL_LNKLED_OVERRIDE | + LED_CTRL_TRAFFIC_OVERRIDE)); + } + + return 0; +} + +static int tg3_setup_fiber_mii_phy(struct tg3_priv *tp, bool force_reset) +{ + int err = 0; + u32 bmsr, bmcr; + u16 current_speed = SPEED_UNKNOWN; + u8 current_duplex = DUPLEX_UNKNOWN; + __maybe_unused bool current_link_up = false; + u32 local_adv, remote_adv, sgsr; + + if ((tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) && + !tg3_readphy(tp, SERDES_TG3_1000X_STATUS, &sgsr) && + (sgsr & SERDES_TG3_SGMII_MODE)) { + + if (force_reset) + tg3_phy_reset(tp); + + tp->mac_mode &= ~MAC_MODE_PORT_MODE_MASK; + + if (!(sgsr & SERDES_TG3_LINK_UP)) { + tp->mac_mode |= MAC_MODE_PORT_MODE_GMII; + } else { + current_link_up = true; + if (sgsr & SERDES_TG3_SPEED_1000) { + current_speed = SPEED_1000; + tp->mac_mode |= MAC_MODE_PORT_MODE_GMII; + } else if (sgsr & SERDES_TG3_SPEED_100) { + current_speed = SPEED_100; + tp->mac_mode |= MAC_MODE_PORT_MODE_MII; + } else { + current_speed = SPEED_10; + tp->mac_mode |= MAC_MODE_PORT_MODE_MII; + } + + if (sgsr & SERDES_TG3_FULL_DUPLEX) + current_duplex = DUPLEX_FULL; + else + current_duplex = DUPLEX_HALF; + } + + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + tg3_clear_mac_status(tp); + + goto fiber_setup_done; + } + + tp->mac_mode |= MAC_MODE_PORT_MODE_GMII; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + tg3_clear_mac_status(tp); + + if (force_reset) + tg3_phy_reset(tp); + + err |= tg3_readphy(tp, MII_BMSR, &bmsr); + err |= tg3_readphy(tp, MII_BMSR, &bmsr); + if (tg3_asic_rev(tp) == ASIC_REV_5714) { + if (tr32(MAC_TX_STATUS) & TX_STATUS_LINK_UP) + bmsr |= BMSR_LSTATUS; + else + bmsr &= ~BMSR_LSTATUS; + } + + err |= tg3_readphy(tp, MII_BMCR, &bmcr); + + if ((tp->link_config.autoneg == AUTONEG_ENABLE) && !force_reset && + (tp->phy_flags & TG3_PHYFLG_PARALLEL_DETECT)) { + /* do nothing, just check for link up at the end */ + } else if (tp->link_config.autoneg == AUTONEG_ENABLE) { + u32 adv, newadv; + + err |= tg3_readphy(tp, MII_ADVERTISE, &adv); + newadv = adv & ~(ADVERTISE_1000XFULL | ADVERTISE_1000XHALF | + ADVERTISE_1000XPAUSE | + ADVERTISE_1000XPSE_ASYM | + ADVERTISE_SLCT); + + newadv |= ethtool_adv_to_mii_adv_x(tp->link_config.advertising); + + if ((newadv != adv) || !(bmcr & BMCR_ANENABLE)) { + tg3_writephy(tp, MII_ADVERTISE, newadv); + bmcr |= BMCR_ANENABLE | BMCR_ANRESTART; + tg3_writephy(tp, MII_BMCR, bmcr); + + tw32_f(MAC_EVENT, MAC_EVENT_LNKSTATE_CHANGED); + tp->serdes_counter = SERDES_AN_TIMEOUT_5714S; + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + + return err; + } + } else { + u32 new_bmcr; + + bmcr &= ~BMCR_SPEED1000; + new_bmcr = bmcr & ~(BMCR_ANENABLE | BMCR_FULLDPLX); + + if (tp->link_config.duplex == DUPLEX_FULL) + new_bmcr |= BMCR_FULLDPLX; + + if (new_bmcr != bmcr) { + /* BMCR_SPEED1000 is a reserved bit that needs + * to be set on write. + */ + new_bmcr |= BMCR_SPEED1000; + + tg3_writephy(tp, MII_BMCR, new_bmcr); + bmcr = new_bmcr; + err |= tg3_readphy(tp, MII_BMSR, &bmsr); + err |= tg3_readphy(tp, MII_BMSR, &bmsr); + if (tg3_asic_rev(tp) == ASIC_REV_5714) { + if (tr32(MAC_TX_STATUS) & TX_STATUS_LINK_UP) + bmsr |= BMSR_LSTATUS; + else + bmsr &= ~BMSR_LSTATUS; + } + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + } + } + + if (bmsr & BMSR_LSTATUS) { + current_speed = SPEED_1000; + current_link_up = true; + if (bmcr & BMCR_FULLDPLX) + current_duplex = DUPLEX_FULL; + else + current_duplex = DUPLEX_HALF; + + local_adv = 0; + remote_adv = 0; + + if (bmcr & BMCR_ANENABLE) { + u32 common; + + err |= tg3_readphy(tp, MII_ADVERTISE, &local_adv); + err |= tg3_readphy(tp, MII_LPA, &remote_adv); + common = local_adv & remote_adv; + if (common & (ADVERTISE_1000XHALF | + ADVERTISE_1000XFULL)) { + if (common & ADVERTISE_1000XFULL) + current_duplex = DUPLEX_FULL; + else + current_duplex = DUPLEX_HALF; + + } else if (!tg3_flag(tp, 5780_CLASS)) { + /* Link is up via parallel detect */ + } else { + current_link_up = false; + } + } + } + +fiber_setup_done: + tp->mac_mode &= ~MAC_MODE_HALF_DUPLEX; + if (tp->link_config.active_duplex == DUPLEX_HALF) + tp->mac_mode |= MAC_MODE_HALF_DUPLEX; + + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + tw32_f(MAC_EVENT, MAC_EVENT_LNKSTATE_CHANGED); + + tp->link_config.active_speed = current_speed; + tp->link_config.active_duplex = current_duplex; + + return err; +} + +static int tg3_setup_phy(struct tg3_priv *tp, bool force_reset) +{ + u32 val; + int err; + + if (tp->phy_flags & TG3_PHYFLG_PHY_SERDES) + err = tg3_setup_fiber_phy(tp, force_reset); + else if (tp->phy_flags & TG3_PHYFLG_MII_SERDES) + err = tg3_setup_fiber_mii_phy(tp, force_reset); + else + err = tg3_setup_copper_phy(tp, force_reset); + + if (tg3_chip_rev(tp) == CHIPREV_5784_AX) { + u32 scale; + + val = tr32(TG3_CPMU_CLCK_STAT) & CPMU_CLCK_STAT_MAC_CLCK_MASK; + if (val == CPMU_CLCK_STAT_MAC_CLCK_62_5) + scale = 65; + else if (val == CPMU_CLCK_STAT_MAC_CLCK_6_25) + scale = 6; + else + scale = 12; + + val = tr32(GRC_MISC_CFG) & ~GRC_MISC_CFG_PRESCALAR_MASK; + val |= (scale << GRC_MISC_CFG_PRESCALAR_SHIFT); + tw32(GRC_MISC_CFG, val); + } + + val = (2 << TX_LENGTHS_IPG_CRS_SHIFT) | + (6 << TX_LENGTHS_IPG_SHIFT); + if (tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) + val |= tr32(MAC_TX_LENGTHS) & + (TX_LENGTHS_JMB_FRM_LEN_MSK | + TX_LENGTHS_CNT_DWN_VAL_MSK); + + if (tp->link_config.active_speed == SPEED_1000 && + tp->link_config.active_duplex == DUPLEX_HALF) + tw32(MAC_TX_LENGTHS, val | + (0xff << TX_LENGTHS_SLOT_TIME_SHIFT)); + else + tw32(MAC_TX_LENGTHS, val | + (32 << TX_LENGTHS_SLOT_TIME_SHIFT)); + + if (tg3_flag(tp, ASPM_WORKAROUND)) { + val = tr32(PCIE_PWR_MGMT_THRESH); + val = (val & ~PCIE_PWR_MGMT_L1_THRESH_MSK) | tp->pwrmgmt_thresh; + tw32(PCIE_PWR_MGMT_THRESH, val); + } + + return err; +} + +/* The RX ring scheme is composed of multiple rings which post fresh buffers to + * the chip, and one special ring the chip uses to report status back to the + * host. + * + * The special ring reports the status of received packets to the host. The + * chip does not write into the original descriptor the RX buffer was obtained + * from. The chip simply takes the original descriptor as provided by the + * host, updates the status and length field, then writes this into the next + * status ring entry. + * + * Each ring the host uses to post buffers to the chip is described by a + * TG3_BDINFO entry in the chips SRAM area. When a packet arrives, it is first + * placed into the on-chip ram. When the packet's length is known, it walks + * down the TG3_BDINFO entries to select the ring. Each TG3_BDINFO specifies a + * MAXLEN field and the first TG3_BDINFO which is within the range of the new + * packet's length is chosen. + * + * The "separate ring for rx status" scheme may sound queer, but it makes sense + * from a cache coherency perspective. If only the host writes to the buffer + * post rings, and only the chip writes to the rx status rings, then cache + * lines never move beyond shared-modified state. If both the host and chip + * were to write into the same ring, cache line eviction could occur since both + * entities want it in an exclusive state. + */ +int tg3_recv(struct eth_device *dev) +{ + struct tg3_priv *tp = dev->priv; + struct tg3_napi *tnapi = &tp->napi[0]; + + int rx_producer = tp->rx_producer; + int rx_consumer = tp->rx_consumer; + + /* Loop the Return ring until there are no more packets */ + while (rx_consumer != tnapi->hw_status->idx[0].rx_producer) { + void *packet_address = (void *) (uintptr_t) (((uint64_t) tnapi->rx_rcb[rx_consumer].addr_hi << 32) + + (uint64_t) tnapi->rx_rcb[rx_consumer].addr_lo); + u32 packet_length = tnapi->rx_rcb[rx_consumer].idx_len; + + if (packet_length > TG3_RX_FRAME_SIZE) { + printf("Error: Invalid packet length.\n"); + return -EIO; + } + /* Process the packet */ + NetReceive(packet_address , packet_length); + + /* Update Producer Ring producer */ + tnapi->prodring.rx_std[rx_producer].addr_hi = tnapi->rx_rcb[rx_consumer].addr_hi; + tnapi->prodring.rx_std[rx_producer].addr_lo = tnapi->rx_rcb[rx_consumer].addr_lo; + rx_producer = (rx_producer + 1) % TG3_RX_PRODUCER_RING_SIZE; + tw32_rx_mbox(TG3_RX_STD_PROD_IDX_REG, rx_producer); + + /* Update Return Ring consumer */ + rx_consumer = (rx_consumer + 1) % TG3_RX_RETURN_RING_SIZE; + tw32_rx_mbox(tnapi->consmbox, rx_consumer); + } + + tp->rx_producer = rx_producer; + tp->rx_consumer = rx_consumer; + + return 0; +} + +static inline void tg3_tx_set_bd(struct tg3_tx_buffer_desc *txbd, + dma_addr_t mapping, u32 len, u32 flags, + u32 mss, u32 vlan) +{ + txbd->addr_hi = ((u64) mapping >> 32); + txbd->addr_lo = ((u64) mapping & 0xffffffff); + txbd->len_flags = (len << TXD_LEN_SHIFT) | (flags & 0x0000ffff); + txbd->vlan_tag = (mss << TXD_MSS_SHIFT) | (vlan << TXD_VLAN_TAG_SHIFT); +} + +static void tg3_rx_prodring_free(struct tg3_priv *tp, struct tg3_rx_prodring_set *tpr) +{ + int i; + for (i = 0; i < TG3_RX_BUFFER_COUNT; i++) + free(tp->rx_buffer[i]); +} + +/* Initialize rx rings for packet processing. + * + * The chip has been shut down and the driver detached from the networking, so + * no interrupts or new tx packets will end up in the driver. tp->{tx,}lock + * are held and thus we may not sleep. + */ +static int tg3_rx_prodring_alloc(struct tg3_priv *tp, struct tg3_rx_prodring_set *tpr) +{ + int i; + + /* Initialize invariants of the rings, we only set this stuff once. + * This works because the card does not write into the rx buffer + * posting rings. + */ + for (i = 0; i < TG3_RX_PRODUCER_RING_SIZE; i++) { + struct tg3_rx_buffer_desc *rxd; + + rxd = &tpr->rx_std[i]; + rxd->idx_len = TG3_RX_FRAME_SIZE << RXD_LEN_SHIFT; + rxd->type_flags = (RXD_FLAG_END << RXD_FLAGS_SHIFT); + rxd->opaque = (RXD_OPAQUE_RING_STD | (i << RXD_OPAQUE_INDEX_SHIFT)); + } + + /* Allocate memory for packets that we receive */ + for (i = 0; i < TG3_RX_BUFFER_COUNT; i++) { + dma_addr_t temp_buffer_mapping; + void *temp_buffer = dma_alloc_coherent(TG3_RX_FRAME_SIZE, &temp_buffer_mapping); + + if (temp_buffer == NULL) { + printf("We've run out of memory D: (Rx buffer %d)\n", i); + } + tp->rx_buffer[i] = temp_buffer; + tpr->rx_std[i].addr_hi = ((u64)temp_buffer_mapping >> 32); + tpr->rx_std[i].addr_lo = ((u64)temp_buffer_mapping & 0xffffffff); + tp->rx_producer = i; + } + + return 0; +} + +/* Free up pending packets in all rx/tx rings. + * + * The chip has been shut down and the driver detached from + * the networking, so no interrupts or new tx packets will + * end up in the driver. tp->{tx,}lock is not held and we are not + * in an interrupt context and thus may sleep. + */ +static void tg3_free_rings(struct tg3_priv *tp) +{ + struct tg3_napi *tnapi = &tp->napi[0]; + tg3_rx_prodring_free(tp, &tnapi->prodring); +} + +/* Initialize tx/rx rings for packet processing. + * + * The chip has been shut down and the driver detached from + * the networking, so no interrupts or new tx packets will + * end up in the driver. tp->{tx,}lock are held and thus + * we may not sleep. + */ +static int tg3_init_rings(struct tg3_priv *tp) +{ + struct tg3_napi *tnapi = &tp->napi[0]; + + tnapi->hw_status->status = 0; + tnapi->hw_status->status_tag = 0; + memset(tnapi->hw_status, 0, TG3_HW_STATUS_SIZE); + + tp->tx_producer = 0; + tp->rx_producer = 0; + tp->rx_consumer = 0; + + if (tg3_rx_prodring_alloc(tp, &tnapi->prodring)) { + tg3_free_rings(tp); + return -ENOMEM; + } + + return 0; +} + +static int tg3_mem_ring_acquire(struct tg3_priv *tp) +{ + struct tg3_napi *tnapi = tp->napi; + + /* Allocate Rx Producer Ring */ + tnapi->prodring.rx_std = dma_alloc_coherent(TG3_RX_STD_RING_BYTES, &tnapi->prodring.rx_std_mapping); + memset(tnapi->prodring.rx_std, 0, TG3_RX_STD_RING_BYTES); + + /* Allocate Rx Return Ring */ + tnapi->rx_rcb = dma_alloc_coherent(TG3_RX_RCB_RING_BYTES, &tnapi->rx_rcb_mapping); + memset(tnapi->rx_rcb, 0, TG3_RX_RCB_RING_BYTES); + + /* Allocate Tx Ring */ + tnapi->tx_ring = dma_alloc_coherent(TG3_TX_RING_BYTES, &tnapi->tx_desc_mapping); + memset(tnapi->tx_ring, 0, TG3_TX_RING_BYTES); + + if (tnapi->tx_ring && tnapi->rx_rcb && tnapi->prodring.rx_std) + return 0; + + return -ENOMEM; +} + +static void tg3_free_consistent(struct tg3_priv *tp) +{ + struct tg3_napi *tnapi = &tp->napi[0]; + + if (tnapi->hw_status) { + free(tnapi->hw_status); + tnapi->hw_status = NULL; + } + + /* Descriptor rings */ + if (tnapi->prodring.rx_std) { + free(tnapi->prodring.rx_std); + tnapi->prodring.rx_std = NULL; + } + if (tnapi->rx_rcb) { + free(tnapi->rx_rcb); + tnapi->rx_rcb = NULL; + } + if (tnapi->tx_ring) { + free(tnapi->tx_ring); + tnapi->tx_ring = NULL; + } + + if (tp->hw_stats) { + free(tp->hw_stats); + tp->hw_stats = NULL; + } +} + +/* TODO: Consider this comment.. Interrupts don't exist for us. + * Must not be invoked with interrupt sources disabled and + * the hardware shutdown down. Can sleep. + */ +static int tg3_alloc_consistent(struct tg3_priv *tp) +{ + struct tg3_napi *tnapi = &tp->napi[0]; + + tp->hw_stats = dma_alloc_coherent(sizeof(struct tg3_hw_stats), &tp->stats_mapping); + if (!tp->hw_stats) + goto err_out; + + tnapi->hw_status = dma_alloc_coherent(TG3_HW_STATUS_SIZE, + &tnapi->status_mapping); + if (!tnapi->hw_status) + goto err_out; + + if (tg3_mem_ring_acquire(tp)) + goto err_out; + + return 0; + +err_out: + tg3_free_consistent(tp); + return -ENOMEM; +} + +#define MAX_WAIT_CNT 1000 + +/* To stop a block, clear the enable bit and poll till it clears. + */ +static int tg3_stop_block(struct tg3_priv *tp, unsigned long ofs, u32 enable_bit, bool silent) +{ + unsigned int i; + u32 val; + + if (tg3_flag(tp, 5705_PLUS)) { + switch (ofs) { + case RCVLSC_MODE: + case DMAC_MODE: + case MBFREE_MODE: + case BUFMGR_MODE: + case MEMARB_MODE: + /* We can't enable/disable these bits of the + * 5705/5750, just say success. + */ + return 0; + + default: + break; + } + } + + val = tr32(ofs); + val &= ~enable_bit; + tw32_f(ofs, val); + + for (i = 0; i < MAX_WAIT_CNT; i++) { + udelay(100); + val = tr32(ofs); + if ((val & enable_bit) == 0) + break; + } + + if (i == MAX_WAIT_CNT && !silent) { + printf("# tg3_stop_block timed out, ofs=%lx enable_bit=%x\n", + ofs, enable_bit); + return -ENODEV; + } + + return 0; +} + +static int tg3_abort_hw(struct tg3_priv *tp, bool silent) +{ + int i, err; + + tg3_disable_ints(tp); + + tp->rx_mode &= ~RX_MODE_ENABLE; + tw32_f(MAC_RX_MODE, tp->rx_mode); + udelay(10); + + err = tg3_stop_block(tp, RCVBDI_MODE, RCVBDI_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RCVLPC_MODE, RCVLPC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RCVLSC_MODE, RCVLSC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RCVDBDI_MODE, RCVDBDI_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RCVDCC_MODE, RCVDCC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RCVCC_MODE, RCVCC_MODE_ENABLE, silent); + + err |= tg3_stop_block(tp, SNDBDS_MODE, SNDBDS_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, SNDBDI_MODE, SNDBDI_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, SNDDATAI_MODE, SNDDATAI_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, RDMAC_MODE, RDMAC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, SNDDATAC_MODE, SNDDATAC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, DMAC_MODE, DMAC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, SNDBDC_MODE, SNDBDC_MODE_ENABLE, silent); + + tp->mac_mode &= ~MAC_MODE_TDE_ENABLE; + tw32_f(MAC_MODE, tp->mac_mode); + udelay(40); + + tp->tx_mode &= ~TX_MODE_ENABLE; + tw32_f(MAC_TX_MODE, tp->tx_mode); + + for (i = 0; i < MAX_WAIT_CNT; i++) { + udelay(100); + if (!(tr32(MAC_TX_MODE) & TX_MODE_ENABLE)) + break; + } + if (i >= MAX_WAIT_CNT) { + printf("# %s timed out, TX_MODE_ENABLE will not clear MAC_TX_MODE=%08x\n", + __func__, tr32(MAC_TX_MODE)); + err |= -ENODEV; + } + + err |= tg3_stop_block(tp, HOSTCC_MODE, HOSTCC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, WDMAC_MODE, WDMAC_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, MBFREE_MODE, MBFREE_MODE_ENABLE, silent); + + tw32(FTQ_RESET, 0xffffffff); + tw32(FTQ_RESET, 0x00000000); + + err |= tg3_stop_block(tp, BUFMGR_MODE, BUFMGR_MODE_ENABLE, silent); + err |= tg3_stop_block(tp, MEMARB_MODE, MEMARB_MODE_ENABLE, silent); + + for (i = 0; i < 1/*tp->irq_cnt*/; i++) { + struct tg3_napi *tnapi = &tp->napi[i]; + if (tnapi->hw_status) + memset(tnapi->hw_status, 0, TG3_HW_STATUS_SIZE); + } + + return err; +} + +/* Save PCI command register before chip reset */ +static void tg3_save_pci_state(struct tg3_priv *tp) +{ + pci_read_config_word(tp->devno, PCI_COMMAND, &tp->pci_cmd); +} + +/* Restore PCI state after chip reset */ +static void tg3_restore_pci_state(struct tg3_priv *tp) +{ + u32 val; + + /* Re-enable indirect register accesses. */ + pci_write_config_dword(tp->devno, TG3PCI_MISC_HOST_CTRL, + tp->misc_host_ctrl); + + /* Set MAX PCI retry to zero. */ + val = (PCISTATE_ROM_ENABLE | PCISTATE_ROM_RETRY_ENABLE); + + pci_write_config_dword(tp->devno, TG3PCI_PCISTATE, val); + + pci_write_config_word(tp->devno, PCI_COMMAND, tp->pci_cmd); + + pci_write_config_byte(tp->devno, PCI_CACHE_LINE_SIZE, tp->pci_cacheline_sz); + pci_write_config_byte(tp->devno, PCI_LATENCY_TIMER, tp->pci_lat_timer); + +} + +static void tg3_override_clk(struct tg3_priv *tp) +{ + u32 val; + + switch (tg3_asic_rev(tp)) { + case ASIC_REV_5717: + val = tr32(TG3_CPMU_CLCK_ORIDE_ENABLE); + tw32(TG3_CPMU_CLCK_ORIDE_ENABLE, val | + TG3_CPMU_MAC_ORIDE_ENABLE); + break; + + case ASIC_REV_5719: + case ASIC_REV_5720: + tw32(TG3_CPMU_CLCK_ORIDE, CPMU_CLCK_ORIDE_MAC_ORIDE_EN); + break; + + default: + return; + } +} + +static void tg3_restore_clk(struct tg3_priv *tp) +{ + u32 val; + + switch (tg3_asic_rev(tp)) { + case ASIC_REV_5717: + val = tr32(TG3_CPMU_CLCK_ORIDE_ENABLE); + tw32(TG3_CPMU_CLCK_ORIDE_ENABLE, + val & ~TG3_CPMU_MAC_ORIDE_ENABLE); + break; + + case ASIC_REV_5719: + case ASIC_REV_5720: + val = tr32(TG3_CPMU_CLCK_ORIDE); + tw32(TG3_CPMU_CLCK_ORIDE, val & ~CPMU_CLCK_ORIDE_MAC_ORIDE_EN); + break; + + default: + return; + } +} + +static int tg3_chip_reset(struct tg3_priv *tp) +{ + u32 val; + void (*write_op)(struct tg3_priv *, u32, u32); + int err; + + /* GRC_MISC_CFG core clock reset will clear the memory + * enable bit in PCI register 4 and the MSI enable bit + * on some chips, so we save relevant registers here. + */ + tg3_save_pci_state(tp); + + if (tg3_asic_rev(tp) == ASIC_REV_5752 || + tg3_flag(tp, 5755_PLUS)) + tw32(GRC_FASTBOOT_PC, 0); + + /* + * We must avoid the readl() that normally takes place. + * It locks machines, causes machine checks, and other + * fun things. So, temporarily disable the 5701 + * hardware workaround, while we do the reset. + */ + write_op = tp->write32; + if (write_op == tg3_write_flush_reg32) + tp->write32 = tg3_write32; + + tg3_flag_set(tp, CHIP_RESETTING); + struct tg3_napi *tnapi = &tp->napi[0]; + if (tnapi->hw_status) { + tnapi->hw_status->status = 0; + tnapi->hw_status->status_tag = 0; + } + + smp_mb(); + + if (tg3_asic_rev(tp) == ASIC_REV_57780) { + val = tr32(TG3_PCIE_LNKCTL) & ~TG3_PCIE_LNKCTL_L1_PLL_PD_EN; + tw32(TG3_PCIE_LNKCTL, val | TG3_PCIE_LNKCTL_L1_PLL_PD_DIS); + } + + /* do the reset */ + val = GRC_MISC_CFG_CORECLK_RESET; + + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + tw32(VCPU_STATUS, tr32(VCPU_STATUS) | VCPU_STATUS_DRV_RESET); + tw32(GRC_VCPU_EXT_CTRL, + tr32(GRC_VCPU_EXT_CTRL) & ~GRC_VCPU_EXT_CTRL_HALT_CPU); + } + + /* Set the clock to the highest frequency to avoid timeouts. With link + * aware mode, the clock speed could be slow and bootcode does not + * complete within the expected time. Override the clock to allow the + * bootcode to finish sooner and then restore it. + */ + tg3_override_clk(tp); + + /* Manage gphy power for all CPMU absent PCIe devices. */ + if (tg3_flag(tp, 5705_PLUS) && !tg3_flag(tp, CPMU_PRESENT)) + val |= GRC_MISC_CFG_KEEP_GPHY_POWER; + + tw32(GRC_MISC_CFG, val); + + /* restore 5701 hardware bug workaround write method */ + tp->write32 = write_op; + + /* Unfortunately, we have to delay before the PCI read back. + * Some 575X chips even will not respond to a PCI cfg access + * when the reset command is given to the chip. + * + * How do these hardware designers expect things to work + * properly if the PCI write is posted for a long period + * of time? It is always necessary to have some method by + * which a register read back can occur to push the write + * out which does the reset. + * + * For most tg3 variants the trick below was working. + * Ho hum... + */ + udelay(120); + + /* Flush PCI posted writes. The normal MMIO registers + * are inaccessible at this time so this is the only + * way to make this reliably (actually, this is no longer + * the case, see above). I tried to use indirect + * register read/write but this upset some 5701 variants. + */ + pci_read_config_dword(tp->devno, PCI_COMMAND, &val); + + udelay(120); + + tg3_restore_pci_state(tp); + + tg3_flag_clear(tp, CHIP_RESETTING); + tg3_flag_clear(tp, ERROR_PROCESSED); + + val = 0; + if (tg3_flag(tp, 5780_CLASS)) + val = tr32(MEMARB_MODE); + tw32(MEMARB_MODE, val | MEMARB_MODE_ENABLE); + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5750_A3) { + tw32(0x5000, 0x400); + } + + err = tg3_poll_fw(tp); + if (err) + return err; + + tw32(GRC_MODE, tp->grc_mode); + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5705_A0) { + val = tr32(0xc4); + + tw32(0xc4, val | (1 << 15)); + } + + if ((tp->nic_sram_data_cfg & NIC_SRAM_DATA_CFG_MINI_PCI) != 0 && + tg3_asic_rev(tp) == ASIC_REV_5705) { + tp->pci_clock_ctrl |= CLOCK_CTRL_CLKRUN_OENABLE; + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5705_A0) + tp->pci_clock_ctrl |= CLOCK_CTRL_FORCE_CLKRUN; + tw32(TG3PCI_CLOCK_CTRL, tp->pci_clock_ctrl); + } + + if (tp->phy_flags & TG3_PHYFLG_PHY_SERDES) { + tp->mac_mode = MAC_MODE_PORT_MODE_TBI; + val = tp->mac_mode; + } else if (tp->phy_flags & TG3_PHYFLG_MII_SERDES) { + tp->mac_mode = MAC_MODE_PORT_MODE_GMII; + val = tp->mac_mode; + } else + val = 0; + + tw32_f(MAC_MODE, val); + udelay(40); + + tg3_mdio_start(tp); + + tg3_restore_clk(tp); + + return 0; +} + +static int tg3_halt__(struct tg3_priv *tp, int kind, bool silent) +{ + int err; + + tg3_write_sig_pre_reset(tp, kind); + + tg3_abort_hw(tp, silent); + err = tg3_chip_reset(tp); + + __tg3_set_mac_addr(tp, false); + + return err; +} + +static void tg3_set_bdinfo(struct tg3_priv *tp, u32 bdinfo_addr, dma_addr_t mapping, + u32 maxlen_flags, u32 nic_addr) +{ + tg3_write_mem(tp, (bdinfo_addr + TG3_BDINFO_HOST_ADDR + TG3_64BIT_REG_HIGH), + ((u64) mapping >> 32)); + tg3_write_mem(tp, (bdinfo_addr + TG3_BDINFO_HOST_ADDR + TG3_64BIT_REG_LOW), + ((u64) mapping & 0xffffffff)); + tg3_write_mem(tp, (bdinfo_addr + TG3_BDINFO_MAXLEN_FLAGS), maxlen_flags); + + if (!tg3_flag(tp, 5705_PLUS)) + tg3_write_mem(tp, (bdinfo_addr + TG3_BDINFO_NIC_ADDR), nic_addr); +} + +static void tg3_coal_tx_init(struct tg3_priv *tp) +{ + tw32(HOSTCC_TXCOL_TICKS, 1000); + tw32(HOSTCC_TXMAX_FRAMES, 1); + tw32(HOSTCC_TXCOAL_MAXF_INT, 1); +} + +static void tg3_coal_rx_init(struct tg3_priv *tp) +{ + tw32(HOSTCC_RXCOL_TICKS, 1000); + tw32(HOSTCC_RXMAX_FRAMES, 1); + tw32(HOSTCC_RXCOAL_MAXF_INT, 1); +} + +static void __tg3_set_coalesce(struct tg3_priv *tp) +{ + tg3_coal_tx_init(tp); + tg3_coal_rx_init(tp); +} + +static void tg3_tx_rcbs_disable(struct tg3_priv *tp) +{ + u32 txrcb, limit; + + /* Disable all transmit rings but the first. */ + if (!tg3_flag(tp, 5705_PLUS)) + limit = NIC_SRAM_SEND_RCB + TG3_BDINFO_SIZE * 16; + else if (tg3_flag(tp, 5717_PLUS)) + limit = NIC_SRAM_SEND_RCB + TG3_BDINFO_SIZE * 4; + else if (tg3_flag(tp, 57765_CLASS) || + tg3_asic_rev(tp) == ASIC_REV_5762) + limit = NIC_SRAM_SEND_RCB + TG3_BDINFO_SIZE * 2; + else + limit = NIC_SRAM_SEND_RCB + TG3_BDINFO_SIZE; + + for (txrcb = NIC_SRAM_SEND_RCB + TG3_BDINFO_SIZE; + txrcb < limit; txrcb += TG3_BDINFO_SIZE) + tg3_write_mem(tp, txrcb + TG3_BDINFO_MAXLEN_FLAGS, + BDINFO_FLAGS_DISABLED); +} + +static void tg3_tx_rcbs_init(struct tg3_priv *tp) +{ + u32 txrcb = NIC_SRAM_SEND_RCB; + + struct tg3_napi *tnapi = &tp->napi[0]; + + if (!tnapi->tx_ring) + return; + + tg3_set_bdinfo(tp, txrcb, tnapi->tx_desc_mapping, + (TG3_TX_RING_SIZE << BDINFO_FLAGS_MAXLEN_SHIFT), + NIC_SRAM_TX_BUFFER_DESC); +} + +static void tg3_rx_ret_rcbs_disable(struct tg3_priv *tp) +{ + u32 rxrcb, limit; + + /* Disable all receive return rings but the first. */ + if (tg3_flag(tp, 5717_PLUS)) + limit = NIC_SRAM_RCV_RET_RCB + TG3_BDINFO_SIZE * 17; + else if (!tg3_flag(tp, 5705_PLUS)) + limit = NIC_SRAM_RCV_RET_RCB + TG3_BDINFO_SIZE * 16; + else if (tg3_asic_rev(tp) == ASIC_REV_5755 || + tg3_asic_rev(tp) == ASIC_REV_5762 || + tg3_flag(tp, 57765_CLASS)) + limit = NIC_SRAM_RCV_RET_RCB + TG3_BDINFO_SIZE * 4; + else + limit = NIC_SRAM_RCV_RET_RCB + TG3_BDINFO_SIZE; + + for (rxrcb = NIC_SRAM_RCV_RET_RCB + TG3_BDINFO_SIZE; + rxrcb < limit; rxrcb += TG3_BDINFO_SIZE) + tg3_write_mem(tp, rxrcb + TG3_BDINFO_MAXLEN_FLAGS, + BDINFO_FLAGS_DISABLED); +} + +static void tg3_rx_ret_rcbs_init(struct tg3_priv *tp) +{ + u32 rxrcb = NIC_SRAM_RCV_RET_RCB; + + struct tg3_napi *tnapi = &tp->napi[0]; + + if (!tnapi->rx_rcb) { + printf("# WARNING: Skipping the only one we have! %d\n", __LINE__); + return; + } + + tg3_set_bdinfo(tp, rxrcb, tnapi->rx_rcb_mapping, + TG3_RX_RETURN_RING_SIZE << + BDINFO_FLAGS_MAXLEN_SHIFT, 0); +} + +static void tg3_rings_reset(struct tg3_priv *tp) +{ + int i; + u32 stblk; + struct tg3_napi *tnapi = &tp->napi[0]; + + tg3_tx_rcbs_disable(tp); + + tg3_rx_ret_rcbs_disable(tp); + + /* Disable interrupts */ + tw32_mailbox_f(tp->napi[0].int_mbox, 1); + + tw32_mailbox(tp->napi[0].prodmbox, 0); + tw32_rx_mbox(tp->napi[0].consmbox, 0); + + /* Make sure the NIC-based send BD rings are disabled. */ + if (!tg3_flag(tp, 5705_PLUS)) { + u32 mbox = MAILBOX_SNDNIC_PROD_IDX_0 + TG3_64BIT_REG_LOW; + for (i = 0; i < 16; i++) + tw32_tx_mbox(mbox + i * 8, 0); + } + + /* Clear status block in ram. */ + memset(tnapi->hw_status, 0, TG3_HW_STATUS_SIZE); + + /* Set status block DMA address */ + tw32(HOSTCC_STATUS_BLK_HOST_ADDR + TG3_64BIT_REG_HIGH, + ((u64) tnapi->status_mapping >> 32)); + tw32(HOSTCC_STATUS_BLK_HOST_ADDR + TG3_64BIT_REG_LOW, + ((u64) tnapi->status_mapping & 0xffffffff)); + + stblk = HOSTCC_STATBLCK_RING1; + + for (i = 1, tnapi++; i < 1/*tp->irq_cnt*/; i++, tnapi++) { + u64 mapping = (u64)tnapi->status_mapping; + tw32(stblk + TG3_64BIT_REG_HIGH, mapping >> 32); + tw32(stblk + TG3_64BIT_REG_LOW, mapping & 0xffffffff); + stblk += 8; + + /* Clear status block in ram. */ + memset(tnapi->hw_status, 0, TG3_HW_STATUS_SIZE); + } + + tg3_tx_rcbs_init(tp); + tg3_rx_ret_rcbs_init(tp); +} + +static void tg3_setup_rxbd_thresholds(struct tg3_priv *tp) +{ + u32 val, bdcache_maxcnt, host_rep_thresh, nic_rep_thresh; + + if (!tg3_flag(tp, 5750_PLUS) || + tg3_flag(tp, 5780_CLASS) || + tg3_asic_rev(tp) == ASIC_REV_5750 || + tg3_asic_rev(tp) == ASIC_REV_5752 || + tg3_flag(tp, 57765_PLUS)) + bdcache_maxcnt = TG3_SRAM_RX_STD_BDCACHE_SIZE_5700; + else if (tg3_asic_rev(tp) == ASIC_REV_5755 || + tg3_asic_rev(tp) == ASIC_REV_5787) + bdcache_maxcnt = TG3_SRAM_RX_STD_BDCACHE_SIZE_5755; + else + bdcache_maxcnt = TG3_SRAM_RX_STD_BDCACHE_SIZE_5906; + + nic_rep_thresh = min(bdcache_maxcnt / 2, tp->rx_std_max_post); + host_rep_thresh = max_t(u32, TG3_RX_BUFFER_COUNT / 8, 1); + + val = min(nic_rep_thresh, host_rep_thresh); + tw32(RCVBDI_STD_THRESH, val); + + if (tg3_flag(tp, 57765_PLUS)) + tw32(STD_REPLENISH_LWM, bdcache_maxcnt); + +} + +static void tg3_set_multi(struct tg3_priv *tp, unsigned int accept_all) +{ + /* accept or reject all multicast frames */ + tw32(MAC_HASH_REG_0, accept_all ? 0xffffffff : 0); + tw32(MAC_HASH_REG_1, accept_all ? 0xffffffff : 0); + tw32(MAC_HASH_REG_2, accept_all ? 0xffffffff : 0); + tw32(MAC_HASH_REG_3, accept_all ? 0xffffffff : 0); +} + +static void __tg3_set_rx_mode(struct tg3_priv *tp) +{ + u32 rx_mode; + + rx_mode = tp->rx_mode & ~(RX_MODE_PROMISC | RX_MODE_KEEP_VLAN_TAG); + +#if !defined(CONFIG_VLAN_8021Q) && !defined(CONFIG_VLAN_8021Q_MODULE) + rx_mode |= RX_MODE_KEEP_VLAN_TAG; +#endif + + tg3_set_multi(tp, 1); + + if (rx_mode != tp->rx_mode) { + tp->rx_mode = rx_mode; + tw32_f(MAC_RX_MODE, rx_mode); + udelay(10); + } +} + +static inline u32 tg3_lso_rd_dma_workaround_bit(struct tg3_priv *tp) +{ + if (tg3_asic_rev(tp) == ASIC_REV_5719) + return TG3_LSO_RD_DMA_TX_LENGTH_WA_5719; + else + return TG3_LSO_RD_DMA_TX_LENGTH_WA_5720; +} + +static int tg3_reset_hw(struct tg3_priv *tp, bool reset_phy) +{ + u32 val, rdmac_mode; + int i, err, limit; + struct tg3_rx_prodring_set *tpr = &tp->napi[0].prodring; + + tg3_disable_ints(tp); + + tg3_write_sig_pre_reset(tp, RESET_KIND_INIT); + + if (tg3_flag(tp, INIT_COMPLETE)) + tg3_abort_hw(tp, 1); + + if ((tp->phy_flags & TG3_PHYFLG_KEEP_LINK_ON_PWRDN) && + !(tp->phy_flags & TG3_PHYFLG_USER_CONFIGURED)) { + tg3_phy_pull_config(tp); + tp->phy_flags |= TG3_PHYFLG_USER_CONFIGURED; + } + + if (reset_phy) + tg3_phy_reset(tp); + + err = tg3_chip_reset(tp); + if (err) + return err; + + if (tg3_chip_rev(tp) == CHIPREV_5784_AX) { + val = tr32(TG3_CPMU_CTRL); + val &= ~(CPMU_CTRL_LINK_AWARE_MODE | CPMU_CTRL_LINK_IDLE_MODE); + tw32(TG3_CPMU_CTRL, val); + + val = tr32(TG3_CPMU_LSPD_10MB_CLK); + val &= ~CPMU_LSPD_10MB_MACCLK_MASK; + val |= CPMU_LSPD_10MB_MACCLK_6_25; + tw32(TG3_CPMU_LSPD_10MB_CLK, val); + + val = tr32(TG3_CPMU_LNK_AWARE_PWRMD); + val &= ~CPMU_LNK_AWARE_MACCLK_MASK; + val |= CPMU_LNK_AWARE_MACCLK_6_25; + tw32(TG3_CPMU_LNK_AWARE_PWRMD, val); + + val = tr32(TG3_CPMU_HST_ACC); + val &= ~CPMU_HST_ACC_MACCLK_MASK; + val |= CPMU_HST_ACC_MACCLK_6_25; + tw32(TG3_CPMU_HST_ACC, val); + } + + if (tg3_asic_rev(tp) == ASIC_REV_57780) { + val = tr32(PCIE_PWR_MGMT_THRESH) & ~PCIE_PWR_MGMT_L1_THRESH_MSK; + val |= PCIE_PWR_MGMT_EXT_ASPM_TMR_EN | + PCIE_PWR_MGMT_L1_THRESH_4MS; + tw32(PCIE_PWR_MGMT_THRESH, val); + + val = tr32(TG3_PCIE_EIDLE_DELAY) & ~TG3_PCIE_EIDLE_DELAY_MASK; + tw32(TG3_PCIE_EIDLE_DELAY, val | TG3_PCIE_EIDLE_DELAY_13_CLKS); + + tw32(TG3_CORR_ERR_STAT, TG3_CORR_ERR_STAT_CLEAR); + + val = tr32(TG3_PCIE_LNKCTL) & ~TG3_PCIE_LNKCTL_L1_PLL_PD_EN; + tw32(TG3_PCIE_LNKCTL, val | TG3_PCIE_LNKCTL_L1_PLL_PD_DIS); + } + + if (tg3_flag(tp, L1PLLPD_EN)) { + u32 grc_mode = tr32(GRC_MODE); + + /* Access the lower 1K of PL PCIE block registers. */ + val = grc_mode & ~GRC_MODE_PCIE_PORT_MASK; + tw32(GRC_MODE, val | GRC_MODE_PCIE_PL_SEL); + + val = tr32(TG3_PCIE_TLDLPL_PORT + TG3_PCIE_PL_LO_PHYCTL1); + tw32(TG3_PCIE_TLDLPL_PORT + TG3_PCIE_PL_LO_PHYCTL1, + val | TG3_PCIE_PL_LO_PHYCTL1_L1PLLPD_EN); + + tw32(GRC_MODE, grc_mode); + } + + if (tg3_flag(tp, 57765_CLASS)) { + if (tg3_chip_rev_id(tp) == CHIPREV_ID_57765_A0) { + u32 grc_mode = tr32(GRC_MODE); + + /* Access the lower 1K of PL PCIE block registers. */ + val = grc_mode & ~GRC_MODE_PCIE_PORT_MASK; + tw32(GRC_MODE, val | GRC_MODE_PCIE_PL_SEL); + + val = tr32(TG3_PCIE_TLDLPL_PORT + + TG3_PCIE_PL_LO_PHYCTL5); + tw32(TG3_PCIE_TLDLPL_PORT + TG3_PCIE_PL_LO_PHYCTL5, + val | TG3_PCIE_PL_LO_PHYCTL5_DIS_L2CLKREQ); + + tw32(GRC_MODE, grc_mode); + } + + if (tg3_chip_rev(tp) != CHIPREV_57765_AX) { + u32 grc_mode; + + /* Fix transmit hangs */ + val = tr32(TG3_CPMU_PADRNG_CTL); + val |= TG3_CPMU_PADRNG_CTL_RDIV2; + tw32(TG3_CPMU_PADRNG_CTL, val); + + grc_mode = tr32(GRC_MODE); + + /* Access the lower 1K of DL PCIE block registers. */ + val = grc_mode & ~GRC_MODE_PCIE_PORT_MASK; + tw32(GRC_MODE, val | GRC_MODE_PCIE_DL_SEL); + + val = tr32(TG3_PCIE_TLDLPL_PORT + + TG3_PCIE_DL_LO_FTSMAX); + val &= ~TG3_PCIE_DL_LO_FTSMAX_MSK; + tw32(TG3_PCIE_TLDLPL_PORT + TG3_PCIE_DL_LO_FTSMAX, + val | TG3_PCIE_DL_LO_FTSMAX_VAL); + + tw32(GRC_MODE, grc_mode); + } + + val = tr32(TG3_CPMU_LSPD_10MB_CLK); + val &= ~CPMU_LSPD_10MB_MACCLK_MASK; + val |= CPMU_LSPD_10MB_MACCLK_6_25; + tw32(TG3_CPMU_LSPD_10MB_CLK, val); + } + + /* This works around an issue with Athlon chipsets on + * B3 tigon3 silicon. This bit has no effect on any + * other revision. But do not set this on PCI Express + * chips and don't even touch the clocks if the CPMU is present. + */ + if (!tg3_flag(tp, CPMU_PRESENT)) { + tp->pci_clock_ctrl |= CLOCK_CTRL_DELAY_PCI_GRANT; + tw32_f(TG3PCI_CLOCK_CTRL, tp->pci_clock_ctrl); + } + + if (tg3_chip_rev(tp) == CHIPREV_5704_BX) { + /* Enable some hw fixes. */ + val = tr32(TG3PCI_MSI_DATA); + val |= (1 << 26) | (1 << 28) | (1 << 29); + tw32(TG3PCI_MSI_DATA, val); + } + + /* Descriptor ring init may make accesses to the + * NIC SRAM area to setup the TX descriptors, so we + * can only do this after the hardware has been + * successfully reset. + */ + err = tg3_init_rings(tp); + if (err) + return err; + + if (tg3_flag(tp, 57765_PLUS)) { + val = tr32(TG3PCI_DMA_RW_CTRL) & + ~DMA_RWCTRL_DIS_CACHE_ALIGNMENT; + if (tg3_chip_rev_id(tp) == CHIPREV_ID_57765_A0) + val &= ~DMA_RWCTRL_CRDRDR_RDMA_MRRS_MSK; + if (!tg3_flag(tp, 57765_CLASS) && + tg3_asic_rev(tp) != ASIC_REV_5717 && + tg3_asic_rev(tp) != ASIC_REV_5762) + val |= DMA_RWCTRL_TAGGED_STAT_WA; + tw32(TG3PCI_DMA_RW_CTRL, val | tp->dma_rwctrl); + } else if (tg3_asic_rev(tp) != ASIC_REV_5784 && + tg3_asic_rev(tp) != ASIC_REV_5761) { + /* This value is determined during the probe time DMA + * engine test, tg3_test_dma. + */ + tw32(TG3PCI_DMA_RW_CTRL, tp->dma_rwctrl); + } + + tp->grc_mode &= ~(GRC_MODE_HOST_SENDBDS | + GRC_MODE_4X_NIC_SEND_RINGS | + GRC_MODE_NO_TX_PHDR_CSUM | + GRC_MODE_NO_RX_PHDR_CSUM); + tp->grc_mode |= GRC_MODE_HOST_SENDBDS; + + /* Pseudo-header checksum is done by hardware logic and not + * the offload processers, so make the chip do the pseudo- + * header checksums on receive. For transmit it is more + * convenient to do the pseudo-header checksum in software + * as Linux does that on transmit for us in all cases. + */ + tp->grc_mode |= GRC_MODE_NO_TX_PHDR_CSUM; + + val = GRC_MODE_IRQ_ON_MAC_ATTN | GRC_MODE_HOST_STACKUP; + + tw32(GRC_MODE, tp->grc_mode | val); + + /* Setup the timer prescalar register. Clock is always 66Mhz. */ + val = tr32(GRC_MISC_CFG); + val &= ~0xff; + val |= (65 << GRC_MISC_CFG_PRESCALAR_SHIFT); + tw32(GRC_MISC_CFG, val); + + /* Initialize MBUF/DESC pool. */ + if (tg3_flag(tp, 5750_PLUS)) { + /* Do nothing. */ + } else if (tg3_asic_rev(tp) != ASIC_REV_5705) { + tw32(BUFMGR_MB_POOL_ADDR, NIC_SRAM_MBUF_POOL_BASE); + if (tg3_asic_rev(tp) == ASIC_REV_5704) + tw32(BUFMGR_MB_POOL_SIZE, NIC_SRAM_MBUF_POOL_SIZE64); + else + tw32(BUFMGR_MB_POOL_SIZE, NIC_SRAM_MBUF_POOL_SIZE96); + tw32(BUFMGR_DMA_DESC_POOL_ADDR, NIC_SRAM_DMA_DESC_POOL_BASE); + tw32(BUFMGR_DMA_DESC_POOL_SIZE, NIC_SRAM_DMA_DESC_POOL_SIZE); + } + + tw32(BUFMGR_MB_RDMA_LOW_WATER, tp->bufmgr_config.mbuf_read_dma_low_water); + tw32(BUFMGR_MB_MACRX_LOW_WATER, tp->bufmgr_config.mbuf_mac_rx_low_water); + tw32(BUFMGR_MB_HIGH_WATER, tp->bufmgr_config.mbuf_high_water); + + tw32(BUFMGR_DMA_LOW_WATER, tp->bufmgr_config.dma_low_water); + tw32(BUFMGR_DMA_HIGH_WATER, tp->bufmgr_config.dma_high_water); + + val = BUFMGR_MODE_ENABLE | BUFMGR_MODE_ATTN_ENABLE; + if (tg3_asic_rev(tp) == ASIC_REV_5719) + val |= BUFMGR_MODE_NO_TX_UNDERRUN; + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5762 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5719_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5720_A0) + val |= BUFMGR_MODE_MBLOW_ATTN_ENAB; + tw32(BUFMGR_MODE, val); + for (i = 0; i < 2000; i++) { + if (tr32(BUFMGR_MODE) & BUFMGR_MODE_ENABLE) + break; + udelay(10); + } + if (i >= 2000) { + printf("# %s cannot enable BUFMGR\n", __func__); + return -ENODEV; + } + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5906_A1) + tw32(ISO_PKT_TX, (tr32(ISO_PKT_TX) & ~0x3) | 0x2); + + tg3_setup_rxbd_thresholds(tp); + + /* Initialize TG3_BDINFO's at: + * RCVDBDI_STD_BD: standard eth size rx ring + * RCVDBDI_JUMBO_BD: jumbo frame rx ring + * RCVDBDI_MINI_BD: small frame rx ring (??? does not work) + * + * like so: + * TG3_BDINFO_HOST_ADDR: high/low parts of DMA address of ring + * TG3_BDINFO_MAXLEN_FLAGS: (rx max buffer size << 16) | + * ring attribute flags + * TG3_BDINFO_NIC_ADDR: location of descriptors in nic SRAM + * + * Standard receive ring @ NIC_SRAM_RX_BUFFER_DESC, 512 entries. + * Jumbo receive ring @ NIC_SRAM_RX_JUMBO_BUFFER_DESC, 256 entries. + * + * The size of each ring is fixed in the firmware, but the location is + * configurable. + */ + tw32(RCVDBDI_STD_BD + TG3_BDINFO_HOST_ADDR + TG3_64BIT_REG_HIGH, + ((u64) tpr->rx_std_mapping >> 32)); + tw32(RCVDBDI_STD_BD + TG3_BDINFO_HOST_ADDR + TG3_64BIT_REG_LOW, + ((u64) tpr->rx_std_mapping & 0xffffffff)); + if (!tg3_flag(tp, 5717_PLUS)) + tw32(RCVDBDI_STD_BD + TG3_BDINFO_NIC_ADDR, + NIC_SRAM_RX_BUFFER_DESC); + + /* Disable the mini ring */ + if (!tg3_flag(tp, 5705_PLUS)) + tw32(RCVDBDI_MINI_BD + TG3_BDINFO_MAXLEN_FLAGS, + BDINFO_FLAGS_DISABLED); + + /* Program the jumbo buffer descriptor ring control + * blocks on those devices that have them. + */ + /* Disable jumbo */ + tw32(RCVDBDI_JUMBO_BD + TG3_BDINFO_MAXLEN_FLAGS, BDINFO_FLAGS_DISABLED); + + val = TG3_RX_PRODUCER_RING_SIZE << BDINFO_FLAGS_MAXLEN_SHIFT; + val |= TG3_RX_FRAME_SIZE << 2; /* Packet size */ + + tw32(RCVDBDI_STD_BD + TG3_BDINFO_MAXLEN_FLAGS, val); + + tw32_rx_mbox(TG3_RX_STD_PROD_IDX_REG, 0); + + tg3_rings_reset(tp); + + /* Initialize MAC address and backoff seed. */ + __tg3_set_mac_addr(tp, false); + + /* MTU + ethernet header + FCS + optional VLAN tag */ + tw32(MAC_RX_MTU_SIZE, TG3_RX_FRAME_SIZE); + + /* The slot time is changed by tg3_setup_phy if we + * run at gigabit with half duplex. + */ + val = (2 << TX_LENGTHS_IPG_CRS_SHIFT) | + (6 << TX_LENGTHS_IPG_SHIFT) | + (32 << TX_LENGTHS_SLOT_TIME_SHIFT); + + if (tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) + val |= tr32(MAC_TX_LENGTHS) & + (TX_LENGTHS_JMB_FRM_LEN_MSK | + TX_LENGTHS_CNT_DWN_VAL_MSK); + + tw32(MAC_TX_LENGTHS, val); + + /* Receive rules. */ + tw32(MAC_RCV_RULE_CFG, RCV_RULE_CFG_DEFAULT_CLASS); + tw32(RCVLPC_CONFIG, 0x0181); + + /* Calculate RDMAC_MODE setting early, we need it to determine + * the RCVLPC_STATE_ENABLE mask. + */ + rdmac_mode = (RDMAC_MODE_ENABLE | RDMAC_MODE_TGTABORT_ENAB | + RDMAC_MODE_MSTABORT_ENAB | RDMAC_MODE_PARITYERR_ENAB | + RDMAC_MODE_ADDROFLOW_ENAB | RDMAC_MODE_FIFOOFLOW_ENAB | + RDMAC_MODE_FIFOURUN_ENAB | RDMAC_MODE_FIFOOREAD_ENAB | + RDMAC_MODE_LNGREAD_ENAB); + + if (tg3_asic_rev(tp) == ASIC_REV_5717) + rdmac_mode |= RDMAC_MODE_MULT_DMA_RD_DIS; + + if (tg3_asic_rev(tp) == ASIC_REV_5784 || + tg3_asic_rev(tp) == ASIC_REV_5785 || + tg3_asic_rev(tp) == ASIC_REV_57780) + rdmac_mode |= RDMAC_MODE_BD_SBD_CRPT_ENAB | + RDMAC_MODE_MBUF_RBD_CRPT_ENAB | + RDMAC_MODE_MBUF_SBD_CRPT_ENAB; + + if (tg3_asic_rev(tp) == ASIC_REV_5705 && + tg3_chip_rev_id(tp) != CHIPREV_ID_5705_A0) { + if (!(tr32(TG3PCI_PCISTATE) & PCISTATE_BUS_SPEED_HIGH) && + !tg3_flag(tp, IS_5788)) { + rdmac_mode |= RDMAC_MODE_FIFO_LONG_BURST; + } + } + + if (tg3_flag(tp, 57765_PLUS) || + tg3_asic_rev(tp) == ASIC_REV_5785 || + tg3_asic_rev(tp) == ASIC_REV_57780) + rdmac_mode |= RDMAC_MODE_IPV6_LSO_EN; + + if (tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) + rdmac_mode |= tr32(RDMAC_MODE) & RDMAC_MODE_H2BNC_VLAN_DET; + + if (tg3_asic_rev(tp) == ASIC_REV_5761 || + tg3_asic_rev(tp) == ASIC_REV_5784 || + tg3_asic_rev(tp) == ASIC_REV_5785 || + tg3_asic_rev(tp) == ASIC_REV_57780 || + tg3_flag(tp, 57765_PLUS)) { + u32 tgtreg; + + if (tg3_asic_rev(tp) == ASIC_REV_5762) + tgtreg = TG3_RDMA_RSRVCTRL_REG2; + else + tgtreg = TG3_RDMA_RSRVCTRL_REG; + + val = tr32(tgtreg); + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5719_A0 || + tg3_asic_rev(tp) == ASIC_REV_5762) { + val &= ~(TG3_RDMA_RSRVCTRL_TXMRGN_MASK | + TG3_RDMA_RSRVCTRL_FIFO_LWM_MASK | + TG3_RDMA_RSRVCTRL_FIFO_HWM_MASK); + val |= TG3_RDMA_RSRVCTRL_TXMRGN_320B | + TG3_RDMA_RSRVCTRL_FIFO_LWM_1_5K | + TG3_RDMA_RSRVCTRL_FIFO_HWM_1_5K; + } + tw32(tgtreg, val | TG3_RDMA_RSRVCTRL_FIFO_OFLW_FIX); + } + + if (tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) { + u32 tgtreg; + + if (tg3_asic_rev(tp) == ASIC_REV_5762) + tgtreg = TG3_LSO_RD_DMA_CRPTEN_CTRL2; + else + tgtreg = TG3_LSO_RD_DMA_CRPTEN_CTRL; + + val = tr32(tgtreg); + tw32(tgtreg, val | + TG3_LSO_RD_DMA_CRPTEN_CTRL_BLEN_BD_4K | + TG3_LSO_RD_DMA_CRPTEN_CTRL_BLEN_LSO_4K); + } + + /* Receive/send statistics. */ + if (tg3_flag(tp, 5750_PLUS)) { + val = tr32(RCVLPC_STATS_ENABLE); + val &= ~RCVLPC_STATSENAB_DACK_FIX; + tw32(RCVLPC_STATS_ENABLE, val); + } else { + tw32(RCVLPC_STATS_ENABLE, 0xffffff); + } + tw32(RCVLPC_STATSCTRL, RCVLPC_STATSCTRL_ENABLE); + tw32(SNDDATAI_STATSENAB, 0xffffff); + tw32(SNDDATAI_STATSCTRL, + (SNDDATAI_SCTRL_ENABLE | + SNDDATAI_SCTRL_FASTUPD)); + + /* Setup host coalescing engine. */ + tw32(HOSTCC_MODE, 0); + for (i = 0; i < 2000; i++) { + if (!(tr32(HOSTCC_MODE) & HOSTCC_MODE_ENABLE)) + break; + udelay(10); + } + + __tg3_set_coalesce(tp); + + if (!tg3_flag(tp, 5705_PLUS)) { + /* Status/statistics block address. See tg3_timer, + * the tg3_periodic_fetch_stats call there, and + * tg3_get_stats to see how this works for 5705/5750 chips. + */ + tw32(HOSTCC_STATS_BLK_HOST_ADDR + TG3_64BIT_REG_HIGH, + ((u64) tp->stats_mapping >> 32)); + tw32(HOSTCC_STATS_BLK_HOST_ADDR + TG3_64BIT_REG_LOW, + ((u64) tp->stats_mapping & 0xffffffff)); + tw32(HOSTCC_STATS_BLK_NIC_ADDR, NIC_SRAM_STATS_BLK); + + tw32(HOSTCC_STATUS_BLK_NIC_ADDR, NIC_SRAM_STATUS_BLK); + + /* Clear statistics and status block memory areas */ + for (i = NIC_SRAM_STATS_BLK; + i < NIC_SRAM_STATUS_BLK + TG3_HW_STATUS_SIZE; + i += sizeof(u32)) { + tg3_write_mem(tp, i, 0); + udelay(40); + } + } + + tw32(HOSTCC_MODE, HOSTCC_MODE_ENABLE | tp->coalesce_mode); + + tw32(RCVCC_MODE, RCVCC_MODE_ENABLE | RCVCC_MODE_ATTN_ENABLE); + tw32(RCVLPC_MODE, RCVLPC_MODE_ENABLE); + if (!tg3_flag(tp, 5705_PLUS)) + tw32(RCVLSC_MODE, RCVLSC_MODE_ENABLE | RCVLSC_MODE_ATTN_ENABLE); + + if (tp->phy_flags & TG3_PHYFLG_MII_SERDES) { + tp->phy_flags &= ~TG3_PHYFLG_PARALLEL_DETECT; + /* reset to prevent losing 1st rx packet intermittently */ + tw32_f(MAC_RX_MODE, RX_MODE_RESET); + udelay(10); + } + + tp->mac_mode |= MAC_MODE_TXSTAT_ENABLE | MAC_MODE_RXSTAT_ENABLE | + MAC_MODE_TDE_ENABLE | MAC_MODE_RDE_ENABLE | + MAC_MODE_FHDE_ENABLE; + + if (!tg3_flag(tp, 5705_PLUS) && + !(tp->phy_flags & TG3_PHYFLG_PHY_SERDES) && + tg3_asic_rev(tp) != ASIC_REV_5700) + tp->mac_mode |= MAC_MODE_LINK_POLARITY; + tw32_f(MAC_MODE, tp->mac_mode | MAC_MODE_RXSTAT_CLEAR | MAC_MODE_TXSTAT_CLEAR); + udelay(40); + + /* tp->grc_local_ctrl is partially set up during tg3_get_invariants(). + * If TG3_FLAG_IS_NIC is zero, we should read the + * register to preserve the GPIO settings for LOMs. The GPIOs, + * whether used as inputs or outputs, are set by boot code after + * reset. + */ + if (!tg3_flag(tp, IS_NIC)) { + u32 gpio_mask; + + gpio_mask = GRC_LCLCTRL_GPIO_OE0 | GRC_LCLCTRL_GPIO_OE1 | + GRC_LCLCTRL_GPIO_OE2 | GRC_LCLCTRL_GPIO_OUTPUT0 | + GRC_LCLCTRL_GPIO_OUTPUT1 | GRC_LCLCTRL_GPIO_OUTPUT2; + + if (tg3_asic_rev(tp) == ASIC_REV_5752) + gpio_mask |= GRC_LCLCTRL_GPIO_OE3 | + GRC_LCLCTRL_GPIO_OUTPUT3; + + if (tg3_asic_rev(tp) == ASIC_REV_5755) + gpio_mask |= GRC_LCLCTRL_GPIO_UART_SEL; + + tp->grc_local_ctrl &= ~gpio_mask; + tp->grc_local_ctrl |= tr32(GRC_LOCAL_CTRL) & gpio_mask; + + /* GPIO1 must be driven high for eeprom write protect */ + if (tg3_flag(tp, EEPROM_WRITE_PROT)) + tp->grc_local_ctrl |= (GRC_LCLCTRL_GPIO_OE1 | + GRC_LCLCTRL_GPIO_OUTPUT1); + } + tw32_f(GRC_LOCAL_CTRL, tp->grc_local_ctrl); + udelay(100); + + if (!tg3_flag(tp, 5705_PLUS)) { + tw32_f(DMAC_MODE, DMAC_MODE_ENABLE); + udelay(40); + } + + val = (WDMAC_MODE_ENABLE | WDMAC_MODE_TGTABORT_ENAB | + WDMAC_MODE_MSTABORT_ENAB | WDMAC_MODE_PARITYERR_ENAB | + WDMAC_MODE_ADDROFLOW_ENAB | WDMAC_MODE_FIFOOFLOW_ENAB | + WDMAC_MODE_FIFOURUN_ENAB | WDMAC_MODE_FIFOOREAD_ENAB | + WDMAC_MODE_LNGREAD_ENAB); + + if (tg3_asic_rev(tp) == ASIC_REV_5705 && + tg3_chip_rev_id(tp) != CHIPREV_ID_5705_A0) { + if (!(tr32(TG3PCI_PCISTATE) & PCISTATE_BUS_SPEED_HIGH) + && !tg3_flag(tp, IS_5788)) { + val |= WDMAC_MODE_RX_ACCEL; + } + } + + /* Enable host coalescing bug fix */ + if (tg3_flag(tp, 5755_PLUS)) + val |= WDMAC_MODE_STATUS_TAG_FIX; + + if (tg3_asic_rev(tp) == ASIC_REV_5785) + val |= WDMAC_MODE_BURST_ALL_DATA; + + tw32_f(WDMAC_MODE, val); + udelay(40); + + tw32_f(RDMAC_MODE, rdmac_mode); + udelay(40); + + if (tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) { + for (i = 0; i < TG3_NUM_RDMA_CHANNELS; i++) { + if (tr32(TG3_RDMA_LENGTH + (i << 2)) > TG3_MAX_MTU(tp)) + break; + } + if (i < TG3_NUM_RDMA_CHANNELS) { + val = tr32(TG3_LSO_RD_DMA_CRPTEN_CTRL); + val |= tg3_lso_rd_dma_workaround_bit(tp); + tw32(TG3_LSO_RD_DMA_CRPTEN_CTRL, val); + tg3_flag_set(tp, 5719_5720_RDMA_BUG); + } + } + + tw32(RCVDCC_MODE, RCVDCC_MODE_ENABLE | RCVDCC_MODE_ATTN_ENABLE); + if (!tg3_flag(tp, 5705_PLUS)) + tw32(MBFREE_MODE, MBFREE_MODE_ENABLE); + + if (tg3_asic_rev(tp) == ASIC_REV_5761) + tw32(SNDDATAC_MODE, + SNDDATAC_MODE_ENABLE | SNDDATAC_MODE_CDELAY); + else + tw32(SNDDATAC_MODE, SNDDATAC_MODE_ENABLE); + + tw32(SNDBDC_MODE, SNDBDC_MODE_ENABLE | SNDBDC_MODE_ATTN_ENABLE); + tw32(RCVBDI_MODE, RCVBDI_MODE_ENABLE | RCVBDI_MODE_RCB_ATTN_ENAB); + val = RCVDBDI_MODE_ENABLE | RCVDBDI_MODE_INV_RING_SZ; + if (tg3_flag(tp, LRG_PROD_RING_CAP)) + val |= RCVDBDI_MODE_LRG_RING_SZ; + tw32(RCVDBDI_MODE, val); + tw32(SNDDATAI_MODE, SNDDATAI_MODE_ENABLE); + + val = SNDBDI_MODE_ENABLE | SNDBDI_MODE_ATTN_ENABLE; + tw32(SNDBDI_MODE, val); + tw32(SNDBDS_MODE, SNDBDS_MODE_ENABLE | SNDBDS_MODE_ATTN_ENABLE); + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5701_A0) { + printf("# Note: Not loading firmware fix.\n"); + } + + tp->tx_mode = TX_MODE_ENABLE; + + if (tg3_flag(tp, 5755_PLUS) || + tg3_asic_rev(tp) == ASIC_REV_5906) + tp->tx_mode |= TX_MODE_MBUF_LOCKUP_FIX; + + if (tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) { + val = TX_MODE_JMB_FRM_LEN | TX_MODE_CNT_DN_MODE; + tp->tx_mode &= ~val; + tp->tx_mode |= tr32(MAC_TX_MODE) & val; + } + + tw32_f(MAC_TX_MODE, tp->tx_mode); + udelay(100); + + tp->rx_mode = RX_MODE_ENABLE; + if (tg3_flag(tp, 5755_PLUS)) + tp->rx_mode |= RX_MODE_IPV6_CSUM_ENABLE; + + if (tg3_asic_rev(tp) == ASIC_REV_5762) + tp->rx_mode |= RX_MODE_IPV4_FRAG_FIX; + + tw32_f(MAC_RX_MODE, tp->rx_mode); + udelay(10); + + tw32(MAC_LED_CTRL, tp->led_ctrl); + + tw32(MAC_MI_STAT, MAC_MI_STAT_LNKSTAT_ATTN_ENAB); + if (tp->phy_flags & TG3_PHYFLG_PHY_SERDES) { + tw32_f(MAC_RX_MODE, RX_MODE_RESET); + udelay(10); + } + tw32_f(MAC_RX_MODE, tp->rx_mode); + udelay(10); + + if (tp->phy_flags & TG3_PHYFLG_PHY_SERDES) { + if ((tg3_asic_rev(tp) == ASIC_REV_5704) && + !(tp->phy_flags & TG3_PHYFLG_SERDES_PREEMPHASIS)) { + /* Set drive transmission level to 1.2V */ + /* only if the signal pre-emphasis bit is not set */ + val = tr32(MAC_SERDES_CFG); + val &= 0xfffff000; + val |= 0x880; + tw32(MAC_SERDES_CFG, val); + } + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5703_A1) + tw32(MAC_SERDES_CFG, 0x616000); + } + + /* Prevent chip from dropping frames when flow control + * is enabled. + */ + if (tg3_flag(tp, 57765_CLASS)) + val = 1; + else + val = 2; + tw32_f(MAC_LOW_WMARK_MAX_RX_FRAME, val); + + if (tg3_asic_rev(tp) == ASIC_REV_5704 && + (tp->phy_flags & TG3_PHYFLG_PHY_SERDES)) { + /* Use hardware link auto-negotiation */ + tg3_flag_set(tp, HW_AUTONEG); + } + + if ((tp->phy_flags & TG3_PHYFLG_MII_SERDES) && + tg3_asic_rev(tp) == ASIC_REV_5714) { + u32 tmp; + + tmp = tr32(SERDES_RX_CTRL); + tw32(SERDES_RX_CTRL, tmp | SERDES_RX_SIG_DETECT); + tp->grc_local_ctrl &= ~GRC_LCLCTRL_USE_EXT_SIG_DETECT; + tp->grc_local_ctrl |= GRC_LCLCTRL_USE_SIG_DETECT; + tw32(GRC_LOCAL_CTRL, tp->grc_local_ctrl); + } + + + if (tp->phy_flags & TG3_PHYFLG_IS_LOW_POWER) + tp->phy_flags &= ~TG3_PHYFLG_IS_LOW_POWER; + + err = tg3_setup_phy(tp, false); + if (err) + return err; + + if (!(tp->phy_flags & TG3_PHYFLG_PHY_SERDES) && + !(tp->phy_flags & TG3_PHYFLG_IS_FET)) { + u32 tmp; + + /* Clear CRC stats. */ + if (!tg3_readphy(tp, MII_TG3_TEST1, &tmp)) { + tg3_writephy(tp, MII_TG3_TEST1, tmp | MII_TG3_TEST1_CRC_EN); + tg3_readphy(tp, MII_TG3_RXR_COUNTERS, &tmp); + } + } + + __tg3_set_rx_mode(tp); + + /* Initialize receive rules. */ + tw32(MAC_RCV_RULE_0, 0xc2000000 & RCV_RULE_DISABLE_MASK); + tw32(MAC_RCV_VALUE_0, 0xffffffff & RCV_RULE_DISABLE_MASK); + tw32(MAC_RCV_RULE_1, 0x86000004 & RCV_RULE_DISABLE_MASK); + tw32(MAC_RCV_VALUE_1, 0xffffffff & RCV_RULE_DISABLE_MASK); + + if (tg3_flag(tp, 5705_PLUS) && !tg3_flag(tp, 5780_CLASS)) + limit = 8; + else + limit = 16; + switch (limit) { + case 16: + tw32(MAC_RCV_RULE_15, 0); tw32(MAC_RCV_VALUE_15, 0); + case 15: + tw32(MAC_RCV_RULE_14, 0); tw32(MAC_RCV_VALUE_14, 0); + case 14: + tw32(MAC_RCV_RULE_13, 0); tw32(MAC_RCV_VALUE_13, 0); + case 13: + tw32(MAC_RCV_RULE_12, 0); tw32(MAC_RCV_VALUE_12, 0); + case 12: + tw32(MAC_RCV_RULE_11, 0); tw32(MAC_RCV_VALUE_11, 0); + case 11: + tw32(MAC_RCV_RULE_10, 0); tw32(MAC_RCV_VALUE_10, 0); + case 10: + tw32(MAC_RCV_RULE_9, 0); tw32(MAC_RCV_VALUE_9, 0); + case 9: + tw32(MAC_RCV_RULE_8, 0); tw32(MAC_RCV_VALUE_8, 0); + case 8: + tw32(MAC_RCV_RULE_7, 0); tw32(MAC_RCV_VALUE_7, 0); + case 7: + tw32(MAC_RCV_RULE_6, 0); tw32(MAC_RCV_VALUE_6, 0); + case 6: + tw32(MAC_RCV_RULE_5, 0); tw32(MAC_RCV_VALUE_5, 0); + case 5: + tw32(MAC_RCV_RULE_4, 0); tw32(MAC_RCV_VALUE_4, 0); + default: + break; + } + + return 0; +} + +/* Called at device open time to get the chip ready for + * packet processing. Invoked with tp->lock held. + */ +static int tg3_init_hw(struct tg3_priv *tp, bool reset_phy) +{ + /* Chip may have been just powered on. If so, the boot code may still + * be running initialization. Wait for it to finish to avoid races in + * accessing the hardware. + */ + tg3_enable_register_access(tp); + tg3_poll_fw(tp); + + tg3_switch_clocks(tp); + + tw32(TG3PCI_MEM_WIN_BASE_ADDR, 0); + + return tg3_reset_hw(tp, reset_phy); +} + +static int tg3_start(struct tg3_priv *tp, bool reset_phy, bool init) +{ + int err; + + /* The placement of this call is tied to the setup and use of Host TX + * descriptors. + */ + err = tg3_alloc_consistent(tp); + if (err) + goto out_ints_fini; + + err = tg3_init_hw(tp, reset_phy); + if (err) { + printf("# Error: line %d.\n", __LINE__); + tg3_halt__(tp, RESET_KIND_SHUTDOWN, 1); + tg3_free_rings(tp); + } + + tg3_flag_set(tp, INIT_COMPLETE); + + return 0; + +out_ints_fini: + + return err; +} + +void tg3_halt(struct eth_device *dev) +{ + /* Once the card is initialized, + * we will leave it initialized. */ + return; +} + +static void tg3_get_eeprom_hw_cfg(struct tg3_priv *tp) +{ + u32 val; + + tp->phy_id = TG3_PHY_ID_INVALID; + tp->led_ctrl = LED_CTRL_MODE_PHY_1; + + /* Assume an onboard device and WOL capable by default. */ + tg3_flag_set(tp, EEPROM_WRITE_PROT); + + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + if (!(tr32(PCIE_TRANSACTION_CFG) & PCIE_TRANS_CFG_LOM)) { + tg3_flag_clear(tp, EEPROM_WRITE_PROT); + tg3_flag_set(tp, IS_NIC); + } + val = tr32(VCPU_CFGSHDW); + if (val & VCPU_CFGSHDW_ASPM_DBNC) + tg3_flag_set(tp, ASPM_WORKAROUND); + goto done; + } + + tg3_read_mem(tp, NIC_SRAM_DATA_SIG, &val); + if (val == NIC_SRAM_DATA_SIG_MAGIC) { + u32 nic_cfg, led_cfg; + u32 cfg2 = 0, cfg4 = 0, cfg5 = 0; + u32 nic_phy_id, ver, eeprom_phy_id; + int eeprom_phy_serdes = 0; + + tg3_read_mem(tp, NIC_SRAM_DATA_CFG, &nic_cfg); + tp->nic_sram_data_cfg = nic_cfg; + + tg3_read_mem(tp, NIC_SRAM_DATA_VER, &ver); + ver >>= NIC_SRAM_DATA_VER_SHIFT; + if (tg3_asic_rev(tp) != ASIC_REV_5700 && + tg3_asic_rev(tp) != ASIC_REV_5701 && + tg3_asic_rev(tp) != ASIC_REV_5703 && + (ver > 0) && (ver < 0x100)) + tg3_read_mem(tp, NIC_SRAM_DATA_CFG_2, &cfg2); + + if (tg3_asic_rev(tp) == ASIC_REV_5785) + tg3_read_mem(tp, NIC_SRAM_DATA_CFG_4, &cfg4); + + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) + tg3_read_mem(tp, NIC_SRAM_DATA_CFG_5, &cfg5); + + if ((nic_cfg & NIC_SRAM_DATA_CFG_PHY_TYPE_MASK) == + NIC_SRAM_DATA_CFG_PHY_TYPE_FIBER) + eeprom_phy_serdes = 1; + + tg3_read_mem(tp, NIC_SRAM_DATA_PHY_ID, &nic_phy_id); + if (nic_phy_id != 0) { + u32 id1 = nic_phy_id & NIC_SRAM_DATA_PHY_ID1_MASK; + u32 id2 = nic_phy_id & NIC_SRAM_DATA_PHY_ID2_MASK; + + eeprom_phy_id = (id1 >> 16) << 10; + eeprom_phy_id |= (id2 & 0xfc00) << 16; + eeprom_phy_id |= (id2 & 0x03ff) << 0; + } else { + eeprom_phy_id = 0; + } + + tp->phy_id = eeprom_phy_id; + if (eeprom_phy_serdes) { + if (!tg3_flag(tp, 5705_PLUS)) + tp->phy_flags |= TG3_PHYFLG_PHY_SERDES; + else + tp->phy_flags |= TG3_PHYFLG_MII_SERDES; + } + + if (tg3_flag(tp, 5750_PLUS)) + led_cfg = cfg2 & (NIC_SRAM_DATA_CFG_LED_MODE_MASK | + SHASTA_EXT_LED_MODE_MASK); + else + led_cfg = nic_cfg & NIC_SRAM_DATA_CFG_LED_MODE_MASK; + + switch (led_cfg) { + default: + case NIC_SRAM_DATA_CFG_LED_MODE_PHY_1: + tp->led_ctrl = LED_CTRL_MODE_PHY_1; + break; + + case NIC_SRAM_DATA_CFG_LED_MODE_PHY_2: + tp->led_ctrl = LED_CTRL_MODE_PHY_2; + break; + + case NIC_SRAM_DATA_CFG_LED_MODE_MAC: + tp->led_ctrl = LED_CTRL_MODE_MAC; + + /* Default to PHY_1_MODE if 0 (MAC_MODE) is + * read on some older 5700/5701 bootcode. + */ + if (tg3_asic_rev(tp) == ASIC_REV_5700 || + tg3_asic_rev(tp) == ASIC_REV_5701) + tp->led_ctrl = LED_CTRL_MODE_PHY_1; + + break; + + case SHASTA_EXT_LED_SHARED: + tp->led_ctrl = LED_CTRL_MODE_SHARED; + if (tg3_chip_rev_id(tp) != CHIPREV_ID_5750_A0 && + tg3_chip_rev_id(tp) != CHIPREV_ID_5750_A1) + tp->led_ctrl |= (LED_CTRL_MODE_PHY_1 | + LED_CTRL_MODE_PHY_2); + + if (tg3_flag(tp, 5717_PLUS) || + tg3_asic_rev(tp) == ASIC_REV_5762) + tp->led_ctrl |= LED_CTRL_BLINK_RATE_OVERRIDE | + LED_CTRL_BLINK_RATE_MASK; + + break; + + case SHASTA_EXT_LED_MAC: + tp->led_ctrl = LED_CTRL_MODE_SHASTA_MAC; + break; + + case SHASTA_EXT_LED_COMBO: + tp->led_ctrl = LED_CTRL_MODE_COMBO; + if (tg3_chip_rev_id(tp) != CHIPREV_ID_5750_A0) + tp->led_ctrl |= (LED_CTRL_MODE_PHY_1 | + LED_CTRL_MODE_PHY_2); + break; + } + + if (tg3_chip_rev(tp) == CHIPREV_5784_AX) + tp->led_ctrl = LED_CTRL_MODE_PHY_1; + + if (nic_cfg & NIC_SRAM_DATA_CFG_EEPROM_WP) { + tg3_flag_set(tp, EEPROM_WRITE_PROT); + } else { + tg3_flag_clear(tp, EEPROM_WRITE_PROT); + tg3_flag_set(tp, IS_NIC); + } + + if (nic_cfg & NIC_SRAM_DATA_CFG_ASF_ENABLE) { + printf("# Note: ASF not implemented.\n"); + } + + if (cfg2 & (1 << 17)) + tp->phy_flags |= TG3_PHYFLG_CAPACITIVE_COUPLING; + + /* serdes signal pre-emphasis in register 0x590 set by */ + /* bootcode if bit 18 is set */ + if (cfg2 & (1 << 18)) + tp->phy_flags |= TG3_PHYFLG_SERDES_PREEMPHASIS; + + if ((tg3_flag(tp, 57765_PLUS) || + (tg3_asic_rev(tp) == ASIC_REV_5784 && + tg3_chip_rev(tp) != CHIPREV_5784_AX)) && + (cfg2 & NIC_SRAM_DATA_CFG_2_APD_EN)) + tp->phy_flags |= TG3_PHYFLG_ENABLE_APD; + + if (cfg4 & NIC_SRAM_RGMII_INBAND_DISABLE) + tg3_flag_set(tp, RGMII_INBAND_DISABLE); + if (cfg4 & NIC_SRAM_RGMII_EXT_IBND_RX_EN) + tg3_flag_set(tp, RGMII_EXT_IBND_RX_EN); + if (cfg4 & NIC_SRAM_RGMII_EXT_IBND_TX_EN) + tg3_flag_set(tp, RGMII_EXT_IBND_TX_EN); + + if (cfg5 & NIC_SRAM_DISABLE_1G_HALF_ADV) + tp->phy_flags |= TG3_PHYFLG_DISABLE_1G_HD_ADV; + } +done: + return; +} + +static int tg3_issue_otp_command(struct tg3_priv *tp, u32 cmd) +{ + int i; + u32 val; + + tw32(OTP_CTRL, cmd | OTP_CTRL_OTP_CMD_START); + tw32(OTP_CTRL, cmd); + + /* Wait for up to 1 ms for command to execute. */ + for (i = 0; i < 100; i++) { + val = tr32(OTP_STATUS); + if (val & OTP_STATUS_CMD_DONE) + break; + udelay(10); + } + + return (val & OTP_STATUS_CMD_DONE) ? 0 : -EBUSY; +} + +/* Read the gphy configuration from the OTP region of the chip. The gphy + * configuration is a 32-bit value that straddles the alignment boundary. + * We do two 32-bit reads and then shift and merge the results. + */ +static u32 tg3_read_otp_phycfg(struct tg3_priv *tp) +{ + u32 bhalf_otp, thalf_otp; + + tw32(OTP_MODE, OTP_MODE_OTP_THRU_GRC); + + if (tg3_issue_otp_command(tp, OTP_CTRL_OTP_CMD_INIT)) + return 0; + + tw32(OTP_ADDRESS, OTP_ADDRESS_MAGIC1); + + if (tg3_issue_otp_command(tp, OTP_CTRL_OTP_CMD_READ)) + return 0; + + thalf_otp = tr32(OTP_READ_DATA); + + tw32(OTP_ADDRESS, OTP_ADDRESS_MAGIC2); + + if (tg3_issue_otp_command(tp, OTP_CTRL_OTP_CMD_READ)) + return 0; + + bhalf_otp = tr32(OTP_READ_DATA); + + return ((thalf_otp & 0x0000ffff) << 16) | (bhalf_otp >> 16); +} + +static void tg3_phy_init_link_config(struct tg3_priv *tp) +{ + u32 adv = ADVERTISED_Autoneg; + + if (!(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) { + if (!(tp->phy_flags & TG3_PHYFLG_DISABLE_1G_HD_ADV)) + adv |= ADVERTISED_1000baseT_Half; + adv |= ADVERTISED_1000baseT_Full; + } + + if (!(tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) + adv |= ADVERTISED_100baseT_Half | + ADVERTISED_100baseT_Full | + ADVERTISED_10baseT_Half | + ADVERTISED_10baseT_Full | + ADVERTISED_TP; + else + adv |= ADVERTISED_FIBRE; + + tp->link_config.advertising = adv; + tp->link_config.speed = SPEED_UNKNOWN; + tp->link_config.duplex = DUPLEX_UNKNOWN; + tp->link_config.autoneg = AUTONEG_ENABLE; + tp->link_config.active_speed = SPEED_UNKNOWN; + tp->link_config.active_duplex = DUPLEX_UNKNOWN; +} + +static int tg3_phy_probe(struct tg3_priv *tp) +{ + u32 hw_phy_id_1, hw_phy_id_2; + u32 hw_phy_id, hw_phy_id_masked; + int err; + + if (!(tp->phy_flags & TG3_PHYFLG_ANY_SERDES) && + !(tp->phy_flags & TG3_PHYFLG_10_100_ONLY)) + tp->phy_flags &= ~(TG3_PHYFLG_1G_ON_VAUX_OK | + TG3_PHYFLG_KEEP_LINK_ON_PWRDN); + + /* Reading the PHY ID register can conflict with ASF + * firmware access to the PHY hardware. + */ + err = 0; + /* Now read the physical PHY_ID from the chip and verify + * that it is sane. If it doesn't look good, we fall back + * to either the hard-coded table based PHY_ID and failing + * that the value found in the eeprom area. + */ + err |= tg3_readphy(tp, MII_PHYSID1, &hw_phy_id_1); + err |= tg3_readphy(tp, MII_PHYSID2, &hw_phy_id_2); + + hw_phy_id = (hw_phy_id_1 & 0xffff) << 10; + hw_phy_id |= (hw_phy_id_2 & 0xfc00) << 16; + hw_phy_id |= (hw_phy_id_2 & 0x03ff) << 0; + + hw_phy_id_masked = hw_phy_id & TG3_PHY_ID_MASK; + + if (!err && TG3_KNOWN_PHY_ID(hw_phy_id_masked)) { + tp->phy_id = hw_phy_id; + if (hw_phy_id_masked == TG3_PHY_ID_BCM8002) + tp->phy_flags |= TG3_PHYFLG_PHY_SERDES; + else + tp->phy_flags &= ~TG3_PHYFLG_PHY_SERDES; + } else { + if (tp->phy_id != TG3_PHY_ID_INVALID) { + /* Do nothing, phy ID already set up in + * tg3_get_eeprom_hw_cfg(). + */ + } else { + printf("# Tigon3 subsys vendor code not implemented.\n"); + return -ENODEV; + } + } + + tg3_phy_init_link_config(tp); + + if (!(tp->phy_flags & TG3_PHYFLG_KEEP_LINK_ON_PWRDN) && + !(tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) { + u32 bmsr, dummy; + + tg3_readphy(tp, MII_BMSR, &bmsr); + if (!tg3_readphy(tp, MII_BMSR, &bmsr) && + (bmsr & BMSR_LSTATUS)) + goto skip_phy_reset; + + err = tg3_phy_reset(tp); + if (err) + return err; + + tg3_phy_set_wirespeed(tp); + + if (!tg3_phy_copper_an_config_ok(tp, &dummy)) { + tg3_phy_autoneg_cfg(tp, tp->link_config.advertising); + + tg3_writephy(tp, MII_BMCR, + BMCR_ANENABLE | BMCR_ANRESTART); + } + } + +skip_phy_reset: + if ((tp->phy_id & TG3_PHY_ID_MASK) == TG3_PHY_ID_BCM5401) { + err = tg3_init_5401phy_dsp(tp); + if (err) + return err; + + err = tg3_init_5401phy_dsp(tp); + } + + return err; +} + +static void tg3_detect_asic_rev(struct tg3_priv *tp, u32 misc_ctrl_reg) +{ + tp->pci_chip_rev_id = misc_ctrl_reg >> MISC_HOST_CTRL_CHIPREV_SHIFT; + if (tg3_asic_rev(tp) == ASIC_REV_USE_PROD_ID_REG) { + u32 reg; + + /* All devices that use the alternate + * ASIC REV location have a CPMU. + */ + tg3_flag_set(tp, CPMU_PRESENT); + + if (tp->pci_device == TG3PCI_DEVICE_TIGON3_5717 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5717_C || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5718 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5719 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5720 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57767 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57764 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5762 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5725 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5727 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57787) + reg = TG3PCI_GEN2_PRODID_ASICREV; + else if (tp->pci_device == TG3PCI_DEVICE_TIGON3_57781 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57785 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57761 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57765 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57791 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57795 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57762 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57766 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57782 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_57786) + reg = TG3PCI_GEN15_PRODID_ASICREV; + else + reg = TG3PCI_PRODID_ASICREV; + + pci_read_config_dword(tp->devno, reg, &tp->pci_chip_rev_id); + } + + /* Wrong chip ID in 5752 A0. This code can be removed later + * as A0 is not in production. + */ + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5752_A0_HW) + tp->pci_chip_rev_id = CHIPREV_ID_5752_A0; + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5717_C0) + tp->pci_chip_rev_id = CHIPREV_ID_5720_A0; + + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) + tg3_flag_set(tp, 5717_PLUS); + + if (tg3_asic_rev(tp) == ASIC_REV_57765 || + tg3_asic_rev(tp) == ASIC_REV_57766) + tg3_flag_set(tp, 57765_CLASS); + + if (tg3_flag(tp, 57765_CLASS) || tg3_flag(tp, 5717_PLUS) || + tg3_asic_rev(tp) == ASIC_REV_5762) + tg3_flag_set(tp, 57765_PLUS); + + /* Intentionally exclude ASIC_REV_5906 */ + if (tg3_asic_rev(tp) == ASIC_REV_5755 || + tg3_asic_rev(tp) == ASIC_REV_5787 || + tg3_asic_rev(tp) == ASIC_REV_5784 || + tg3_asic_rev(tp) == ASIC_REV_5761 || + tg3_asic_rev(tp) == ASIC_REV_5785 || + tg3_asic_rev(tp) == ASIC_REV_57780 || + tg3_flag(tp, 57765_PLUS)) + tg3_flag_set(tp, 5755_PLUS); + + if (tg3_asic_rev(tp) == ASIC_REV_5780 || + tg3_asic_rev(tp) == ASIC_REV_5714) + tg3_flag_set(tp, 5780_CLASS); + + if (tg3_asic_rev(tp) == ASIC_REV_5750 || + tg3_asic_rev(tp) == ASIC_REV_5752 || + tg3_asic_rev(tp) == ASIC_REV_5906 || + tg3_flag(tp, 5755_PLUS) || + tg3_flag(tp, 5780_CLASS)) + tg3_flag_set(tp, 5750_PLUS); + + if (tg3_asic_rev(tp) == ASIC_REV_5705 || + tg3_flag(tp, 5750_PLUS)) + tg3_flag_set(tp, 5705_PLUS); +} + +static bool tg3_10_100_only_device(struct tg3_priv *tp) +{ + u32 grc_misc_cfg = tr32(GRC_MISC_CFG) & GRC_MISC_CFG_BOARD_ID_MASK; + + if ((tg3_asic_rev(tp) == ASIC_REV_5703 && + (grc_misc_cfg == 0x8000 || grc_misc_cfg == 0x4000)) || + (tp->phy_flags & TG3_PHYFLG_IS_FET)) + return true; +/* This will need to be changed before it will work with U-Boot. + if (ent->driver_data & TG3_DRV_DATA_FLAG_10_100_ONLY) { + if (tg3_asic_rev(tp) == ASIC_REV_5705) { + if (ent->driver_data & TG3_DRV_DATA_FLAG_5705_10_100) + return true; + } else { + return true; + } + } +*/ + return false; +} + +/* TODO: I have left workarounds for boards other than + * the 5718 for now to speed up development. Some + * may need to be re-added before delivery. */ +static int tg3_get_invariants(struct tg3_priv *tp/*, const struct pci_device_id *ent*/) +{ + u32 misc_ctrl_reg; + u32 pci_state_reg, grc_misc_cfg; + u32 val; + u16 pci_cmd; + int err; + + /* Force memory write invalidate off. If we leave it on, + * then on 5700_BX chips we have to enable a workaround. + * The workaround is to set the TG3PCI_DMA_RW_CTRL boundary + * to match the cacheline size. The Broadcom driver have this + * workaround but turns MWI off all the times so never uses + * it. This seems to suggest that the workaround is insufficient. + */ + pci_read_config_word(tp->devno, PCI_COMMAND, &pci_cmd); + pci_cmd &= ~PCI_COMMAND_INVALIDATE; + pci_write_config_word(tp->devno, PCI_COMMAND, pci_cmd); + + /* Important! -- Make sure register accesses are byteswapped + * correctly. Also, for those chips that require it, make + * sure that indirect register accesses are enabled before + * the first operation. + */ + pci_read_config_dword(tp->devno, TG3PCI_MISC_HOST_CTRL, + &misc_ctrl_reg); + tp->misc_host_ctrl |= (misc_ctrl_reg & + MISC_HOST_CTRL_CHIPREV); + pci_write_config_dword(tp->devno, TG3PCI_MISC_HOST_CTRL, + tp->misc_host_ctrl); + + tg3_detect_asic_rev(tp, misc_ctrl_reg); + + /* If we have 5702/03 A1 or A2 on certain ICH chipsets, + * we need to disable memory and use config. cycles + * only to access all registers. The 5702/03 chips + * can mistakenly decode the special cycles from the + * ICH chipsets as memory write cycles, causing corruption + * of register and memory space. Only certain ICH bridges + * will drive special cycles with non-zero data during the + * address phase which can fall within the 5703's address + * range. This is not an ICH bug as the PCI spec allows + * non-zero address during special cycles. However, only + * these ICH bridges are known to drive non-zero addresses + * during special cycles. + * + * Since special cycles do not cross PCI bridges, we only + * enable this workaround if the 5703 is on the secondary + * bus of these ICH bridges. + */ +#if 0 + if ((tg3_chip_rev_id(tp) == CHIPREV_ID_5703_A1) || + (tg3_chip_rev_id(tp) == CHIPREV_ID_5703_A2)) { + static struct tg3_dev_id { + u32 vendor; + u32 device; + u32 rev; + } ich_chipsets[] = { + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801AA_8, + PCI_ANY_ID }, + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801AB_8, + PCI_ANY_ID }, + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801BA_11, + 0xa }, + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801BA_6, + PCI_ANY_ID }, + { }, + }; + struct tg3_dev_id *pci_id = &ich_chipsets[0]; + struct pci_dev *bridge = NULL; + + while (pci_id->vendor != 0) { + bridge = pci_get_device(pci_id->vendor, pci_id->device, + bridge); + if (!bridge) { + pci_id++; + continue; + } + if (pci_id->rev != PCI_ANY_ID) { + if (bridge->revision > pci_id->rev) + continue; + } + if (bridge->subordinate && + (bridge->subordinate->number == + tp->pdev->bus->number)) { + tg3_flag_set(tp, ICH_WORKAROUND); + pci_dev_put(bridge); + break; + } + } + } + + if (tg3_asic_rev(tp) == ASIC_REV_5701) { + static struct tg3_dev_id { + u32 vendor; + u32 device; + } bridge_chipsets[] = { + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_PXH_0 }, + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_PXH_1 }, + { }, + }; + struct tg3_dev_id *pci_id = &bridge_chipsets[0]; + struct pci_dev *bridge = NULL; + + while (pci_id->vendor != 0) { + bridge = pci_get_device(pci_id->vendor, + pci_id->device, + bridge); + if (!bridge) { + pci_id++; + continue; + } + if (bridge->subordinate && + (bridge->subordinate->number <= + tp->pdev->bus->number) && + (bridge->subordinate->busn_res.end >= + tp->pdev->bus->number)) { + tg3_flag_set(tp, 5701_DMA_BUG); + pci_dev_put(bridge); + break; + } + } + } +#endif + + /* The EPB bridge inside 5714, 5715, and 5780 cannot support + * DMA addresses > 40-bit. This bridge may have other additional + * 57xx devices behind it in some 4-port NIC designs for example. + * Any tg3 device found behind the bridge will also need the 40-bit + * DMA workaround. + */ + if (tg3_flag(tp, 5780_CLASS)) { + tg3_flag_set(tp, 40BIT_DMA_BUG); + } +#if 0 + else { + struct pci_dev *bridge = NULL; + + do { + bridge = pci_get_device(PCI_VENDOR_ID_SERVERWORKS, + PCI_DEVICE_ID_SERVERWORKS_EPB, + bridge); + if (bridge && bridge->subordinate && + (bridge->subordinate->number <= + tp->pdev->bus->number) && + (bridge->subordinate->busn_res.end >= + tp->pdev->bus->number)) { + tg3_flag_set(tp, 40BIT_DMA_BUG); + pci_dev_put(bridge); + break; + } + } while (bridge); + } +#endif + + if (tg3_asic_rev(tp) == ASIC_REV_5704 || + tg3_asic_rev(tp) == ASIC_REV_5714) + printf("tg3_find_peer() not implemented.\n"); + + if (tg3_flag(tp, 5755_PLUS) || tg3_asic_rev(tp) == ASIC_REV_5906) + tg3_flag_set(tp, SHORT_DMA_BUG); + + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) + tg3_flag_set(tp, LRG_PROD_RING_CAP); + + pci_read_config_dword(tp->devno, TG3PCI_PCISTATE, &pci_state_reg); + + /* If we have an AMD 762 or VIA K8T800 chipset, write + * reordering to the mailbox registers done by the host + * controller can cause major troubles. We read back from + * every mailbox register write to force the writes to be + * posted to the chip in order. + */ +#if 0 + if (pci_dev_present(tg3_write_reorder_chipsets)) + tg3_flag_set(tp, MBOX_WRITE_REORDER); +#endif + + pci_read_config_byte(tp->devno, PCI_CACHE_LINE_SIZE, &tp->pci_cacheline_sz); + pci_read_config_byte(tp->devno, PCI_LATENCY_TIMER, &tp->pci_lat_timer); + if (tg3_asic_rev(tp) == ASIC_REV_5703 && tp->pci_lat_timer < 64) { + tp->pci_lat_timer = 64; + pci_write_config_byte(tp->devno, PCI_LATENCY_TIMER, tp->pci_lat_timer); + } + + if (tg3_chip_rev(tp) == CHIPREV_5700_BX) { + /* 5700 BX chips need to have their TX producer index + * mailboxes written twice to workaround a bug. + */ + tg3_flag_set(tp, TXD_MBOX_HWBUG); + } + + if ((pci_state_reg & PCISTATE_BUS_SPEED_HIGH) != 0) + tg3_flag_set(tp, PCI_HIGH_SPEED); + if ((pci_state_reg & PCISTATE_BUS_32BIT) != 0) + tg3_flag_set(tp, PCI_32BIT); + + /* Chip-specific fixup from Broadcom driver */ + if ((tg3_chip_rev_id(tp) == CHIPREV_ID_5704_A0) && + (!(pci_state_reg & PCISTATE_RETRY_SAME_DMA))) { + pci_state_reg |= PCISTATE_RETRY_SAME_DMA; + pci_write_config_dword(tp->devno, TG3PCI_PCISTATE, pci_state_reg); + } + + /* Default fast path register access methods */ + tp->read32 = tg3_read32; + tp->write32 = tg3_write32; + tp->read32_mbox = tg3_read32; + tp->write32_mbox = tg3_write32; + tp->write32_tx_mbox = tg3_write32; + tp->write32_rx_mbox = tg3_write32; + + /* Various workaround register access methods */ + if (tg3_flag(tp, PCIX_TARGET_HWBUG)) + tp->write32 = tg3_write_indirect_reg32; + else if (tg3_asic_rev(tp) == ASIC_REV_5701) { + /* + * Back to back register writes can cause problems on these + * chips, the workaround is to read back all reg writes + * except those to mailbox regs. + * + * See tg3_write_indirect_reg32(). + */ + tp->write32 = tg3_write_flush_reg32; + } + + if (tg3_flag(tp, TXD_MBOX_HWBUG) || tg3_flag(tp, MBOX_WRITE_REORDER)) { + tp->write32_tx_mbox = tg3_write32_tx_mbox; + if (tg3_flag(tp, MBOX_WRITE_REORDER)) + tp->write32_rx_mbox = tg3_write_flush_reg32; + } + + if (tg3_flag(tp, ICH_WORKAROUND)) { + tp->read32 = tg3_read_indirect_reg32; + tp->write32 = tg3_write_indirect_reg32; + tp->read32_mbox = tg3_read_indirect_mbox; + tp->write32_mbox = tg3_write_indirect_mbox; + tp->write32_tx_mbox = tg3_write_indirect_mbox; + tp->write32_rx_mbox = tg3_write_indirect_mbox; + +#if 0 + iounmap(tp->regs); +#endif + tp->regs = NULL; + + pci_read_config_word(tp->devno, PCI_COMMAND, &pci_cmd); + pci_cmd &= ~PCI_COMMAND_MEMORY; + pci_write_config_word(tp->devno, PCI_COMMAND, pci_cmd); + } + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + tp->read32_mbox = tg3_read32_mbox_5906; + tp->write32_mbox = tg3_write32_mbox_5906; + tp->write32_tx_mbox = tg3_write32_mbox_5906; + tp->write32_rx_mbox = tg3_write32_mbox_5906; + } + + if (tp->write32 == tg3_write_indirect_reg32 || + tg3_asic_rev(tp) == ASIC_REV_5701) + tg3_flag_set(tp, SRAM_USE_CONFIG); + + /* The memory arbiter has to be enabled in order for SRAM accesses + * to succeed. Normally on powerup the tg3 chip firmware will make + * sure it is enabled, but other entities such as system netboot + * code might disable it. + */ + val = tr32(MEMARB_MODE); + tw32(MEMARB_MODE, val | MEMARB_MODE_ENABLE); + + tp->pci_fn = PCI_FUNC(tp->devno) & 3; + + if (tg3_asic_rev(tp) == ASIC_REV_5704 || tg3_flag(tp, 5780_CLASS)) { + } else if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5719 || + tg3_asic_rev(tp) == ASIC_REV_5720) { + tg3_read_mem(tp, NIC_SRAM_CPMU_STATUS, &val); + if ((val & NIC_SRAM_CPMUSTAT_SIG_MSK) != NIC_SRAM_CPMUSTAT_SIG) + val = tr32(TG3_CPMU_STATUS); + + if (tg3_asic_rev(tp) == ASIC_REV_5717) + tp->pci_fn = (val & TG3_CPMU_STATUS_FMSK_5717) ? 1 : 0; + else + tp->pci_fn = (val & TG3_CPMU_STATUS_FMSK_5719) >> + TG3_CPMU_STATUS_FSHFT_5719; + } + + if (tg3_flag(tp, FLUSH_POSTED_WRITES)) { + tp->write32_tx_mbox = tg3_write_flush_reg32; + tp->write32_rx_mbox = tg3_write_flush_reg32; + } + + /* Get eeprom hw config before calling tg3_set_power_state(). + * In particular, the TG3_FLAG_IS_NIC flag must be + * determined before calling tg3_set_power_state() so that + * we know whether or not to switch out of Vaux power. + * When the flag is set, it means that GPIO1 is used for eeprom + * write protect and also implies that it is a LOM where GPIOs + * are not used to switch power. + */ + tg3_get_eeprom_hw_cfg(tp); + + /* Set up tp->grc_local_ctrl before calling + * tg3_pwrsrc_switch_to_vmain(). GPIO1 driven high + * will bring 5700's external PHY out of reset. + * It is also used as eeprom write protect on LOMs. + */ + tp->grc_local_ctrl = GRC_LCLCTRL_INT_ON_ATTN | GRC_LCLCTRL_AUTO_SEEPROM; + if (tg3_asic_rev(tp) == ASIC_REV_5700 || + tg3_flag(tp, EEPROM_WRITE_PROT)) + tp->grc_local_ctrl |= (GRC_LCLCTRL_GPIO_OE1 | + GRC_LCLCTRL_GPIO_OUTPUT1); + /* Unused GPIO3 must be driven as output on 5752 because there + * are no pull-up resistors on unused GPIO pins. + */ + else if (tg3_asic_rev(tp) == ASIC_REV_5752) + tp->grc_local_ctrl |= GRC_LCLCTRL_GPIO_OE3; + + if (tg3_asic_rev(tp) == ASIC_REV_5755 || + tg3_asic_rev(tp) == ASIC_REV_57780 || + tg3_flag(tp, 57765_CLASS)) + tp->grc_local_ctrl |= GRC_LCLCTRL_GPIO_UART_SEL; + + if (tp->pci_device == TG3PCI_DEVICE_TIGON3_5761 || + tp->pci_device == TG3PCI_DEVICE_TIGON3_5761S) { + /* Turn off the debug UART. */ + tp->grc_local_ctrl |= GRC_LCLCTRL_GPIO_UART_SEL; + if (tg3_flag(tp, IS_NIC)) + /* Keep VMain power. */ + tp->grc_local_ctrl |= GRC_LCLCTRL_GPIO_OE0 | + GRC_LCLCTRL_GPIO_OUTPUT0; + } + + if (tg3_asic_rev(tp) == ASIC_REV_5762) + tp->grc_local_ctrl |= + tr32(GRC_LOCAL_CTRL) & GRC_LCLCTRL_GPIO_UART_SEL; + + /* Switch out of Vaux if it is a NIC */ + tg3_pwrsrc_switch_to_vmain(tp); + + if (tg3_asic_rev(tp) == ASIC_REV_5906) + tp->phy_flags |= TG3_PHYFLG_IS_FET; + + /* A few boards don't want Ethernet@WireSpeed phy feature */ + if (tg3_asic_rev(tp) == ASIC_REV_5700 || + (tg3_asic_rev(tp) == ASIC_REV_5705 && + (tg3_chip_rev_id(tp) != CHIPREV_ID_5705_A0) && + (tg3_chip_rev_id(tp) != CHIPREV_ID_5705_A1)) || + (tp->phy_flags & TG3_PHYFLG_IS_FET) || + (tp->phy_flags & TG3_PHYFLG_ANY_SERDES)) + tp->phy_flags |= TG3_PHYFLG_NO_ETH_WIRE_SPEED; + + if (tg3_chip_rev(tp) == CHIPREV_5703_AX || + tg3_chip_rev(tp) == CHIPREV_5704_AX) + tp->phy_flags |= TG3_PHYFLG_ADC_BUG; + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5704_A0) + tp->phy_flags |= TG3_PHYFLG_5704_A0_BUG; + + if (tg3_flag(tp, 5705_PLUS) && + !(tp->phy_flags & TG3_PHYFLG_IS_FET) && + tg3_asic_rev(tp) != ASIC_REV_5785 && + tg3_asic_rev(tp) != ASIC_REV_57780 && + !tg3_flag(tp, 57765_PLUS)) { + if (tg3_asic_rev(tp) == ASIC_REV_5755 || + tg3_asic_rev(tp) == ASIC_REV_5787 || + tg3_asic_rev(tp) == ASIC_REV_5784 || + tg3_asic_rev(tp) == ASIC_REV_5761) { + if (tp->pci_device != TG3PCI_DEVICE_TIGON3_5756 && + tp->pci_device != TG3PCI_DEVICE_TIGON3_5722) + tp->phy_flags |= TG3_PHYFLG_JITTER_BUG; + if (tp->pci_device == TG3PCI_DEVICE_TIGON3_5755M) + tp->phy_flags |= TG3_PHYFLG_ADJUST_TRIM; + } else + tp->phy_flags |= TG3_PHYFLG_BER_BUG; + } + + if (tg3_asic_rev(tp) == ASIC_REV_5784 && + tg3_chip_rev(tp) != CHIPREV_5784_AX) { + tp->phy_otp = tg3_read_otp_phycfg(tp); + if (tp->phy_otp == 0) + tp->phy_otp = TG3_OTP_DEFAULT; + } + + if (tg3_flag(tp, CPMU_PRESENT)) + tp->mi_mode = MAC_MI_MODE_500KHZ_CONST; + else + tp->mi_mode = MAC_MI_MODE_BASE; + + tp->coalesce_mode = 0; + if (tg3_chip_rev(tp) != CHIPREV_5700_AX && + tg3_chip_rev(tp) != CHIPREV_5700_BX) + tp->coalesce_mode |= HOSTCC_MODE_32BYTE; + + /* Set these bits to enable statistics workaround. */ + if (tg3_asic_rev(tp) == ASIC_REV_5717 || + tg3_asic_rev(tp) == ASIC_REV_5762 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5719_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5720_A0) { + tp->coalesce_mode |= HOSTCC_MODE_ATTN; + tp->grc_mode |= GRC_MODE_IRQ_ON_FLOW_ATTN; + } + + if (tg3_asic_rev(tp) == ASIC_REV_5785 || + tg3_asic_rev(tp) == ASIC_REV_57780) { + printf("Error: USE_PHYLIB not implemented.\n"); + return -ENODEV; + } + + err = tg3_mdio_init(tp); + if (err) + return err; + + /* Initialize data/descriptor byte/word swapping. */ + val = tr32(GRC_MODE); + if (tg3_asic_rev(tp) == ASIC_REV_5720 || + tg3_asic_rev(tp) == ASIC_REV_5762) + val &= (GRC_MODE_BYTE_SWAP_B2HRX_DATA | + GRC_MODE_WORD_SWAP_B2HRX_DATA | + GRC_MODE_B2HRX_ENABLE | + GRC_MODE_HTX2B_ENABLE | + GRC_MODE_HOST_STACKUP); + else + val &= GRC_MODE_HOST_STACKUP; + + tw32(GRC_MODE, val | tp->grc_mode); + + tg3_switch_clocks(tp); + + /* Clear this out for sanity. */ + tw32(TG3PCI_MEM_WIN_BASE_ADDR, 0); + + /* Clear TG3PCI_REG_BASE_ADDR to prevent hangs. */ + tw32(TG3PCI_REG_BASE_ADDR, 0); + + pci_read_config_dword(tp->devno, TG3PCI_PCISTATE, &pci_state_reg); + if ((pci_state_reg & PCISTATE_CONV_PCI_MODE) == 0 && + !tg3_flag(tp, PCIX_TARGET_HWBUG)) { + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5701_A0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B0 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B2 || + tg3_chip_rev_id(tp) == CHIPREV_ID_5701_B5) { + void __iomem *sram_base; + + /* Write some dummy words into the SRAM status block + * area, see if it reads back correctly. If the return + * value is bad, force enable the PCIX workaround. + */ + sram_base = tp->regs + NIC_SRAM_WIN_BASE + NIC_SRAM_STATS_BLK; + + writel(0x00000000, sram_base); + writel(0x00000000, sram_base + 4); + writel(0xffffffff, sram_base + 4); + if (readl(sram_base) != 0x00000000) + tg3_flag_set(tp, PCIX_TARGET_HWBUG); + } + } + + udelay(50); + + grc_misc_cfg = tr32(GRC_MISC_CFG); + grc_misc_cfg &= GRC_MISC_CFG_BOARD_ID_MASK; + + if (tg3_asic_rev(tp) == ASIC_REV_5705 && + (grc_misc_cfg == GRC_MISC_CFG_BOARD_ID_5788 || + grc_misc_cfg == GRC_MISC_CFG_BOARD_ID_5788M)) + tg3_flag_set(tp, IS_5788); + + if (!tg3_flag(tp, IS_5788) && + tg3_asic_rev(tp) != ASIC_REV_5700) + tg3_flag_set(tp, TAGGED_STATUS); + if (tg3_flag(tp, TAGGED_STATUS)) { + tp->coalesce_mode |= (HOSTCC_MODE_CLRTICK_RXBD | + HOSTCC_MODE_CLRTICK_TXBD); + + tp->misc_host_ctrl |= MISC_HOST_CTRL_TAGGED_STATUS; + pci_write_config_dword(tp->devno, TG3PCI_MISC_HOST_CTRL, + tp->misc_host_ctrl); + } + + tp->mac_mode = 0; + + if (tg3_10_100_only_device(tp)) + tp->phy_flags |= TG3_PHYFLG_10_100_ONLY; + + err = tg3_phy_probe(tp); + if (err) { + printf("# phy probe failed, err %d\n", err); + } + + /* 5700 {AX,BX} chips have a broken status block link + * change bit implementation, so we must use the + * status register in those cases. + */ + if (tg3_asic_rev(tp) == ASIC_REV_5700) + tg3_flag_set(tp, USE_LINKCHG_REG); + else + tg3_flag_clear(tp, USE_LINKCHG_REG); + + /* For all SERDES we poll the MAC status register. */ + if (tp->phy_flags & TG3_PHYFLG_PHY_SERDES) + tg3_flag_set(tp, POLL_SERDES); + else + tg3_flag_clear(tp, POLL_SERDES); + + tp->rx_std_ring_mask = TG3_RX_PRODUCER_RING_SIZE - 1; + tp->rx_ret_ring_mask = TG3_RX_RETURN_RING_SIZE - 1; + + tp->rx_std_max_post = tp->rx_std_ring_mask + 1; + + /* Increment the rx prod index on the rx std ring by at most + * 8 for these chips to workaround hw errata. + */ + if (tg3_asic_rev(tp) == ASIC_REV_5750 || + tg3_asic_rev(tp) == ASIC_REV_5752 || + tg3_asic_rev(tp) == ASIC_REV_5755) + tp->rx_std_max_post = 8; + + if (tg3_flag(tp, ASPM_WORKAROUND)) + tp->pwrmgmt_thresh = tr32(PCIE_PWR_MGMT_THRESH) & + PCIE_PWR_MGMT_L1_THRESH_MSK; + + return err; +} + +static int tg3_get_device_address(struct tg3_priv *tp) +{ + u32 hi, lo, mac_offset; + int addr_ok = 0; + + mac_offset = 0x7c; + if (tg3_asic_rev(tp) == ASIC_REV_5704 || + tg3_flag(tp, 5780_CLASS)) { + if (tr32(TG3PCI_DUAL_MAC_CTRL) & DUAL_MAC_CTRL_ID) + mac_offset = 0xcc; + } else if (tg3_flag(tp, 5717_PLUS)) { + if (tp->pci_fn & 1) + mac_offset = 0xcc; + if (tp->pci_fn > 1) + mac_offset += 0x18c; + } else if (tg3_asic_rev(tp) == ASIC_REV_5906) { + mac_offset = 0x10; + } + + /* First try to get it from MAC address mailbox. */ + tg3_read_mem(tp, NIC_SRAM_MAC_ADDR_HIGH_MBOX, &hi); + if ((hi >> 16) == 0x484b) { + tp->mac_address[0] = (hi >> 8) & 0xff; + tp->mac_address[1] = (hi >> 0) & 0xff; + + tg3_read_mem(tp, NIC_SRAM_MAC_ADDR_LOW_MBOX, &lo); + tp->mac_address[2] = (lo >> 24) & 0xff; + tp->mac_address[3] = (lo >> 16) & 0xff; + tp->mac_address[4] = (lo >> 8) & 0xff; + tp->mac_address[5] = (lo >> 0) & 0xff; + + /* Some old bootcode may report a 0 MAC address in SRAM */ + addr_ok = is_valid_ether_addr(&tp->mac_address[0]); + } + if (!addr_ok) { + /* Note: NVRAM code removed. */ + /* Finally just fetch it out of the MAC control regs. */ + hi = tr32(MAC_ADDR_0_HIGH); + lo = tr32(MAC_ADDR_0_LOW); + + tp->mac_address[5] = lo & 0xff; + tp->mac_address[4] = (lo >> 8) & 0xff; + tp->mac_address[3] = (lo >> 16) & 0xff; + tp->mac_address[2] = (lo >> 24) & 0xff; + tp->mac_address[1] = hi & 0xff; + tp->mac_address[0] = (hi >> 8) & 0xff; + } + + if (!is_valid_ether_addr(&tp->mac_address[0])) + return -EINVAL; + + return 0; +} + +#define BOUNDARY_SINGLE_CACHELINE 1 +#define BOUNDARY_MULTI_CACHELINE 2 + +static u32 tg3_calc_dma_bndry(struct tg3_priv *tp, u32 val) +{ + int cacheline_size; + u8 byte; + int goal; + + pci_read_config_byte(tp->devno, PCI_CACHE_LINE_SIZE, &byte); + if (byte == 0) + cacheline_size = 1024; + else + cacheline_size = (int) byte * 4; + + /* On 5703 and later chips, the boundary bits have no + * effect. + */ + if (tg3_asic_rev(tp) != ASIC_REV_5700 && + tg3_asic_rev(tp) != ASIC_REV_5701) + goto out; + +#if defined(CONFIG_PPC64) || defined(CONFIG_IA64) || defined(CONFIG_PARISC) + goal = BOUNDARY_MULTI_CACHELINE; +#else +#if defined(CONFIG_SPARC64) || defined(CONFIG_ALPHA) + goal = BOUNDARY_SINGLE_CACHELINE; +#else + goal = 0; +#endif +#endif + + if (tg3_flag(tp, 57765_PLUS)) { + val = goal ? 0 : DMA_RWCTRL_DIS_CACHE_ALIGNMENT; + goto out; + } + + if (!goal) + goto out; + + /* PCI controllers on most RISC systems tend to disconnect + * when a device tries to burst across a cache-line boundary. + * Therefore, letting tg3 do so just wastes PCI bandwidth. + * + * Unfortunately, for PCI-E there are only limited + * write-side controls for this, and thus for reads + * we will still get the disconnects. We'll also waste + * these PCI cycles for both read and write for chips + * other than 5700 and 5701 which do not implement the + * boundary bits. + */ + switch (cacheline_size) { + case 16: + if (goal == BOUNDARY_SINGLE_CACHELINE) { + val |= (DMA_RWCTRL_READ_BNDRY_16 | + DMA_RWCTRL_WRITE_BNDRY_16); + break; + } + /* fallthrough */ + case 32: + if (goal == BOUNDARY_SINGLE_CACHELINE) { + val |= (DMA_RWCTRL_READ_BNDRY_32 | + DMA_RWCTRL_WRITE_BNDRY_32); + break; + } + /* fallthrough */ + case 64: + if (goal == BOUNDARY_SINGLE_CACHELINE) { + val |= (DMA_RWCTRL_READ_BNDRY_64 | + DMA_RWCTRL_WRITE_BNDRY_64); + break; + } + /* fallthrough */ + case 128: + if (goal == BOUNDARY_SINGLE_CACHELINE) { + val |= (DMA_RWCTRL_READ_BNDRY_128 | + DMA_RWCTRL_WRITE_BNDRY_128); + break; + } + /* fallthrough */ + case 256: + val |= (DMA_RWCTRL_READ_BNDRY_256 | + DMA_RWCTRL_WRITE_BNDRY_256); + break; + case 512: + val |= (DMA_RWCTRL_READ_BNDRY_512 | + DMA_RWCTRL_WRITE_BNDRY_512); + break; + case 1024: + default: + val |= (DMA_RWCTRL_READ_BNDRY_1024 | + DMA_RWCTRL_WRITE_BNDRY_1024); + break; + } + +out: + return val; +} + +static int tg3_do_test_dma(struct tg3_priv *tp, u32 *buf, dma_addr_t buf_dma, int size, bool to_device) +{ + struct tg3_internal_buffer_desc test_desc; + u32 sram_dma_descs; + int i, ret; + + sram_dma_descs = NIC_SRAM_DMA_DESC_POOL_BASE; + + tw32(FTQ_RCVBD_COMP_FIFO_ENQDEQ, 0); + tw32(FTQ_RCVDATA_COMP_FIFO_ENQDEQ, 0); + tw32(RDMAC_STATUS, 0); + tw32(WDMAC_STATUS, 0); + + tw32(BUFMGR_MODE, 0); + tw32(FTQ_RESET, 0); + + test_desc.addr_hi = ((u64) buf_dma) >> 32; + test_desc.addr_lo = buf_dma & 0xffffffff; + test_desc.nic_mbuf = 0x00002100; + test_desc.len = size; + + /* + * HP ZX1 was seeing test failures for 5701 cards running at 33Mhz + * the *second* time the tg3 driver was getting loaded after an + * initial scan. + * + * Broadcom tells me: + * ...the DMA engine is connected to the GRC block and a DMA + * reset may affect the GRC block in some unpredictable way... + * The behavior of resets to individual blocks has not been tested. + * + * Broadcom noted the GRC reset will also reset all sub-components. + */ + if (to_device) { + test_desc.cqid_sqid = (13 << 8) | 2; + + tw32_f(RDMAC_MODE, RDMAC_MODE_ENABLE); + udelay(40); + } else { + test_desc.cqid_sqid = (16 << 8) | 7; + + tw32_f(WDMAC_MODE, WDMAC_MODE_ENABLE); + udelay(40); + } + test_desc.flags = 0x00000005; + + for (i = 0; i < (sizeof(test_desc) / sizeof(u32)); i++) { + u32 val; + + val = *(((u32 *)&test_desc) + i); + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, + sram_dma_descs + (i * sizeof(u32))); + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_DATA, val); + } + pci_write_config_dword(tp->devno, TG3PCI_MEM_WIN_BASE_ADDR, 0); + + if (to_device) + tw32(FTQ_DMA_HIGH_READ_FIFO_ENQDEQ, sram_dma_descs); + else + tw32(FTQ_DMA_HIGH_WRITE_FIFO_ENQDEQ, sram_dma_descs); + + ret = -ENODEV; + for (i = 0; i < 40; i++) { + u32 val; + + if (to_device) + val = tr32(FTQ_RCVBD_COMP_FIFO_ENQDEQ); + else + val = tr32(FTQ_RCVDATA_COMP_FIFO_ENQDEQ); + if ((val & 0xffff) == sram_dma_descs) { + ret = 0; + break; + } + + udelay(100); + } + + return ret; +} + +#define TEST_BUFFER_SIZE 0x2000 + +#if 0 +static DEFINE_PCI_DEVICE_TABLE(tg3_dma_wait_state_chipsets) = { + { PCI_DEVICE(PCI_VENDOR_ID_APPLE, PCI_DEVICE_ID_APPLE_UNI_N_PCI15) }, + { }, +}; +#endif + +static int tg3_test_dma(struct tg3_priv *tp) +{ + dma_addr_t buf_dma; + u32 *buf, saved_dma_rwctrl; + int ret = 0; + + buf = dma_alloc_coherent(TEST_BUFFER_SIZE, &buf_dma); + if (!buf) { + ret = -ENOMEM; + goto out_nofree; + } + + tp->dma_rwctrl = ((0x7 << DMA_RWCTRL_PCI_WRITE_CMD_SHIFT) | + (0x6 << DMA_RWCTRL_PCI_READ_CMD_SHIFT)); + + tp->dma_rwctrl = tg3_calc_dma_bndry(tp, tp->dma_rwctrl); + + if (tg3_flag(tp, 57765_PLUS)) + goto out; + + if (tg3_asic_rev(tp) == ASIC_REV_5705 || + tg3_asic_rev(tp) == ASIC_REV_5750) + tp->dma_rwctrl |= 0x003f0000; + else + tp->dma_rwctrl |= 0x003f000f; + + if (tg3_flag(tp, ONE_DMA_AT_ONCE)) + tp->dma_rwctrl |= DMA_RWCTRL_ONE_DMA; + + if (tg3_asic_rev(tp) == ASIC_REV_5703 || + tg3_asic_rev(tp) == ASIC_REV_5704) + tp->dma_rwctrl &= 0xfffffff0; + + if (tg3_asic_rev(tp) == ASIC_REV_5700 || + tg3_asic_rev(tp) == ASIC_REV_5701) { + /* Remove this if it causes problems for some boards. */ + tp->dma_rwctrl |= DMA_RWCTRL_USE_MEM_READ_MULT; + + /* On 5700/5701 chips, we need to set this bit. + * Otherwise the chip will issue cacheline transactions + * to streamable DMA memory with not all the byte + * enables turned on. This is an error on several + * RISC PCI controllers, in particular sparc64. + * + */ + tp->dma_rwctrl |= DMA_RWCTRL_ASSERT_ALL_BE; + } + + tw32(TG3PCI_DMA_RW_CTRL, tp->dma_rwctrl); + + if (tg3_asic_rev(tp) != ASIC_REV_5700 && tg3_asic_rev(tp) != + ASIC_REV_5701) + goto out; + + /* It is best to perform DMA test with maximum write burst size + * to expose the 5700/5701 write DMA bug. + */ + saved_dma_rwctrl = tp->dma_rwctrl; + tp->dma_rwctrl &= ~DMA_RWCTRL_WRITE_BNDRY_MASK; + tw32(TG3PCI_DMA_RW_CTRL, tp->dma_rwctrl); + + while (1) { + u32 *p = buf, i; + + for (i = 0; i < TEST_BUFFER_SIZE / sizeof(u32); i++) + p[i] = i; + + /* Send the buffer to the chip. */ + ret = tg3_do_test_dma(tp, buf, buf_dma, TEST_BUFFER_SIZE, true); + if (ret) { + printf("# %s: Buffer write failed. err = %d\n", __func__, ret); + break; + } + + /* Now read it back. */ + ret = tg3_do_test_dma(tp, buf, buf_dma, TEST_BUFFER_SIZE, false); + if (ret) { + printf("# %s: Buffer read failed. err = %d\n", __func__, ret); + break; + } + + /* Verify it. */ + for (i = 0; i < TEST_BUFFER_SIZE / sizeof(u32); i++) { + if (p[i] == i) + continue; + + if ((tp->dma_rwctrl & DMA_RWCTRL_WRITE_BNDRY_MASK) != + DMA_RWCTRL_WRITE_BNDRY_16) { + tp->dma_rwctrl &= ~DMA_RWCTRL_WRITE_BNDRY_MASK; + tp->dma_rwctrl |= DMA_RWCTRL_WRITE_BNDRY_16; + tw32(TG3PCI_DMA_RW_CTRL, tp->dma_rwctrl); + break; + } else { + printf("# %s: Buffer corrupted on read back! (%d != %d)\n", + __func__, p[i], i); + ret = -ENODEV; + goto out; + } + } + + if (i == (TEST_BUFFER_SIZE / sizeof(u32))) { + /* Success. */ + ret = 0; + break; + } + } + if ((tp->dma_rwctrl & DMA_RWCTRL_WRITE_BNDRY_MASK) != + DMA_RWCTRL_WRITE_BNDRY_16) { + /* DMA test passed without adjusting DMA boundary, + * now look for chipsets that are known to expose the + * DMA bug without failing the test. + */ +#if 0 + if (pci_dev_present(tg3_dma_wait_state_chipsets)) { + tp->dma_rwctrl &= ~DMA_RWCTRL_WRITE_BNDRY_MASK; + tp->dma_rwctrl |= DMA_RWCTRL_WRITE_BNDRY_16; + } else { + /* Safe to use the calculated DMA boundary. */ + tp->dma_rwctrl = saved_dma_rwctrl; + } +#else + /* Safe to use the calculated DMA boundary. */ + tp->dma_rwctrl = saved_dma_rwctrl; +#endif + + tw32(TG3PCI_DMA_RW_CTRL, tp->dma_rwctrl); + } + +out: + free(buf); +out_nofree: + return ret; +} + +static void tg3_init_bufmgr_config(struct tg3_priv *tp) +{ + if (tg3_flag(tp, 57765_PLUS)) { + tp->bufmgr_config.mbuf_read_dma_low_water = + DEFAULT_MB_RDMA_LOW_WATER_5705; + tp->bufmgr_config.mbuf_mac_rx_low_water = + DEFAULT_MB_MACRX_LOW_WATER_57765; + tp->bufmgr_config.mbuf_high_water = + DEFAULT_MB_HIGH_WATER_57765; + + tp->bufmgr_config.mbuf_read_dma_low_water_jumbo = + DEFAULT_MB_RDMA_LOW_WATER_5705; + tp->bufmgr_config.mbuf_mac_rx_low_water_jumbo = + DEFAULT_MB_MACRX_LOW_WATER_JUMBO_57765; + tp->bufmgr_config.mbuf_high_water_jumbo = + DEFAULT_MB_HIGH_WATER_JUMBO_57765; + } else if (tg3_flag(tp, 5705_PLUS)) { + tp->bufmgr_config.mbuf_read_dma_low_water = + DEFAULT_MB_RDMA_LOW_WATER_5705; + tp->bufmgr_config.mbuf_mac_rx_low_water = + DEFAULT_MB_MACRX_LOW_WATER_5705; + tp->bufmgr_config.mbuf_high_water = + DEFAULT_MB_HIGH_WATER_5705; + if (tg3_asic_rev(tp) == ASIC_REV_5906) { + tp->bufmgr_config.mbuf_mac_rx_low_water = + DEFAULT_MB_MACRX_LOW_WATER_5906; + tp->bufmgr_config.mbuf_high_water = + DEFAULT_MB_HIGH_WATER_5906; + } + + tp->bufmgr_config.mbuf_read_dma_low_water_jumbo = + DEFAULT_MB_RDMA_LOW_WATER_JUMBO_5780; + tp->bufmgr_config.mbuf_mac_rx_low_water_jumbo = + DEFAULT_MB_MACRX_LOW_WATER_JUMBO_5780; + tp->bufmgr_config.mbuf_high_water_jumbo = + DEFAULT_MB_HIGH_WATER_JUMBO_5780; + } else { + tp->bufmgr_config.mbuf_read_dma_low_water = + DEFAULT_MB_RDMA_LOW_WATER; + tp->bufmgr_config.mbuf_mac_rx_low_water = + DEFAULT_MB_MACRX_LOW_WATER; + tp->bufmgr_config.mbuf_high_water = + DEFAULT_MB_HIGH_WATER; + + tp->bufmgr_config.mbuf_read_dma_low_water_jumbo = + DEFAULT_MB_RDMA_LOW_WATER_JUMBO; + tp->bufmgr_config.mbuf_mac_rx_low_water_jumbo = + DEFAULT_MB_MACRX_LOW_WATER_JUMBO; + tp->bufmgr_config.mbuf_high_water_jumbo = + DEFAULT_MB_HIGH_WATER_JUMBO; + } + + tp->bufmgr_config.dma_low_water = DEFAULT_DMA_LOW_WATER; + tp->bufmgr_config.dma_high_water = DEFAULT_DMA_HIGH_WATER; +} + +static int tg3_phy_copper_get_link(struct tg3_priv *tp) +{ + int i = 0; + u32 val; + + if (tg3_readphy(tp, MII_BMSR, &val)) + return -EIO; + + if (val & BMSR_LSTATUS) + return 0; + + printf("Waiting for PHY auto negotiation to complete"); + while (!(val & BMSR_ANEGCOMPLETE)) { + if (i > PHY_ANEG_TIMEOUT) { + printf(" TIMEOUT !\n"); + return -1; + } + + if (ctrlc()) { + puts(" user interrupt!\n"); + return -EINTR; + } + + if ((i++ % 500) == 0) + printf("."); + + udelay(1000); /* 1 ms */ + + if (tg3_readphy(tp, MII_BMSR, &val)) + return -EIO; + } + printf(" done\n"); + + return 0; +} + +static int tg3_phy_serdes_get_link(struct tg3_priv *tp) +{ + /* TODO: Probably need to look at one of SG_DIG_STATUS or + * MAC_MI_STAT but currently no hardware to test with. + */ + return 0; +} + +int tg3_init(struct eth_device *dev, bd_t *bis) +{ + struct tg3_priv *tp = dev->priv; + int err; + + if (tp->card_init_state == TG3_INIT_STATE_DONE) { + /* Initialization has already happened. Once init'd, + * we leave the card init'd so we do not need to re- + * do this */ + if ((tp->phy_flags & TG3_PHYFLG_PHY_SERDES) || + (tp->phy_flags & TG3_PHYFLG_MII_SERDES)) { + return tg3_phy_serdes_get_link(tp); + } else { + return tg3_phy_copper_get_link(tp); + } + } + + err = tg3_power_up(tp); + if (err) + printf("# Error: tgp_power_up failed [%d].\n", __LINE__); + + tg3_disable_ints(tp); + tg3_flag_clear(tp, INIT_COMPLETE); + + err = tg3_start(tp, !(tp->phy_flags & TG3_PHYFLG_KEEP_LINK_ON_PWRDN), true); + if (err) + printf("# Error: tg3_start failed [%d].\n", __LINE__); + + /* Init some TX stuff */ + tp->tx_buffer = dma_alloc_coherent(1536, &tp->tx_buffer_mapping); + + /* Init some RX stuff */ + tw32_rx_mbox(TG3_RX_STD_PROD_IDX_REG, tp->rx_producer); + + tp->card_init_state = TG3_INIT_STATE_DONE; + + return err; +} + +int tg3_send(struct eth_device *dev, void *packet, int length) +{ + struct tg3_priv *tp = dev->priv; + struct tg3_napi *tnapi = tp->napi; + + int i; + int tx_producer = tp->tx_producer; + + if (length > 1536) + printf("Error: Packet is more than 1536 bytes!\n"); + + memcpy(tp->tx_buffer, packet, length); + tg3_tx_set_bd(&tnapi->tx_ring[tx_producer], tp->tx_buffer_mapping, + length, TXD_FLAG_END | TXD_FLAG_COAL_NOW, 0, 0); + + /* Increment index and poke the card */ + tx_producer = (tx_producer + 1) % TG3_TX_RING_SIZE; + tw32_tx_mbox(tnapi->prodmbox, tx_producer); + + /* Wait for the card to take the packet... */ + for (i = 0; i < 100000; i++) { + if (tnapi->hw_status->idx[0].tx_consumer == tx_producer) + break; + udelay(10); + } + + tp->tx_producer = tx_producer; + + return 0; +} + +int tg3_write_hwaddr(struct eth_device *dev) +{ + int i; + struct tg3_priv *tp = dev->priv; + for (i = 0; i < 6; i++) + tp->mac_address[i] = dev->enetaddr[i]; + + __tg3_set_mac_addr(tp, false); + return 0; +} + +#define DMA_BIT_MASK(n) (((n) == 64) ? ~0ULL : ((1ULL<<(n))-1)) + +/* Initialize cards in advance so they are closer to ready when + * we actually want to use them */ +#define PRE_INIT_MAX 8 + +/* This function will search for and register all Tigon3 devices + * in the system. It will also initialize up to PRE_INIT_MAX + * Tigon3 devices in advance so that we do not have to wait as + * long before sending our first frame */ +int tg3_register(bd_t *bis) +{ + unsigned int i, j; + pci_dev_t devno; + int err; + struct eth_device *pre_init_list[PRE_INIT_MAX]; + int pre_init_list_count = 0; + + for (i = 0; (devno = pci_find_devices(tg3_supported, i)) >= 0; i++) { + struct tg3_priv *tp; + struct eth_device *dev; + u32 sndmbx, rcvmbx, intmbx; + u64 dma_mask, + __maybe_unused persist_dma_mask; + u32 val; + + tp = malloc(sizeof(*tp)); + if (tp == NULL) + return -ENOMEM; + + dev = malloc(sizeof(*dev)); + if (dev == NULL) { + free(tp); + return -ENOMEM; + } + + memset(dev, 0, sizeof(*dev)); + sprintf(dev->name, "Tigon3-%d", i); + + pci_read_config_dword(devno, PCI_BASE_ADDRESS_0, &val); + + dev->iobase = val; + dev->init = tg3_init; + dev->halt = tg3_halt; + dev->send = tg3_send; + dev->recv = tg3_recv; + dev->write_hwaddr = tg3_write_hwaddr; + dev->priv = tp; + + tp->devno = devno; + tp->card_init_state = TG3_INIT_STATE_NONE; + pci_read_config_word(devno, PCI_VENDOR_ID, &tp->pci_vendor); + pci_read_config_word(devno, PCI_DEVICE_ID, &tp->pci_device); + + if (tp->pci_vendor != 0x14e4 || tp->pci_device != 0x1656) + printf("Note: Driver untested with this card.\n"); + + eth_register(dev); + + /* Try to enable I/O accesses and bus-mastering */ + val = PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER; + pci_write_config_dword(tp->devno, PCI_COMMAND, val); + + /* Make sure it worked */ + pci_read_config_dword(tp->devno, PCI_COMMAND, &val); + if (!(val & PCI_COMMAND_MEMORY)) { + printf("# Can't enable I/O memory\n"); + continue; + } + if (!(val & PCI_COMMAND_MASTER)) { + printf("# Can't enable bus-mastering\n"); + continue; + } + + tp->rx_mode = TG3_DEF_RX_MODE; + tp->tx_mode = TG3_DEF_TX_MODE; + + /* The word/byte swap controls here control register access byte + * swapping. DMA data byte swapping is controlled in the GRC_MODE + * setting below. + */ + tp->misc_host_ctrl = MISC_HOST_CTRL_MASK_PCI_INT | + MISC_HOST_CTRL_WORD_SWAP | MISC_HOST_CTRL_INDIR_ACCESS | + MISC_HOST_CTRL_PCISTATE_RW; + + /* The NONFRM (non-frame) byte/word swap controls take effect on + * descriptor entries, anything which isn't packet data. + * + * The StrongARM chips on the board (one for tx, one for rx) are + * running in big-endian mode. + */ + tp->grc_mode = (GRC_MODE_WSWAP_DATA | GRC_MODE_BSWAP_DATA | + GRC_MODE_WSWAP_NONFRM_DATA); + +#ifdef __BIG_ENDIAN + tp->grc_mode |= GRC_MODE_BSWAP_NONFRM_DATA; +#endif + + tp->regs = pci_map_bar(tp->devno, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + + err = tg3_get_invariants(tp); + if (err) { + printf("# Problem fetching invariants of chip, aborting\n"); + continue; + } + + /* The EPB bridge inside 5714, 5715, and 5780 and any + * device behind the EPB cannot support DMA addresses > 40-bit. + * On 64-bit systems with IOMMU, use 40-bit dma_mask. + * On 64-bit systems without IOMMU, use 64-bit dma_mask and + * do DMA address check in tg3_start_xmit(). + */ + if (tg3_flag(tp, IS_5788)) { + persist_dma_mask = dma_mask = DMA_BIT_MASK(32); + } else if (tg3_flag(tp, 40BIT_DMA_BUG)) { + persist_dma_mask = dma_mask = DMA_BIT_MASK(40); +#ifdef CONFIG_HIGHMEM + dma_mask = DMA_BIT_MASK(64); +#endif + } else { + persist_dma_mask = dma_mask = DMA_BIT_MASK(64); + } + +#if 0 + /* Configure DMA attributes. */ + if (dma_mask > DMA_BIT_MASK(32)) { + err = pci_set_dma_mask(pdev, dma_mask); + if (!err) { + features |= NETIF_F_HIGHDMA; + err = pci_set_consistent_dma_mask(pdev, + persist_dma_mask); + if (err < 0) { + dev_err(&pdev->dev, "Unable to obtain 64 bit " + "DMA for consistent allocations\n"); + goto err_out_apeunmap; + } + } + } + if (err || dma_mask == DMA_BIT_MASK(32)) { + err = pci_set_dma_mask(pdev, DMA_BIT_MASK(32)); + if (err) { + dev_err(&pdev->dev, + "No usable DMA configuration, aborting\n"); + goto err_out_apeunmap; + } + } +#endif + + tg3_init_bufmgr_config(tp); + + if (tg3_chip_rev_id(tp) == CHIPREV_ID_5705_A1 && + !(tr32(TG3PCI_PCISTATE) & PCISTATE_BUS_SPEED_HIGH)) { + tg3_flag_set(tp, MAX_RXPEND_64); + } + + err = tg3_get_device_address(tp); + if (err) { + printf("# Could not obtain valid ethernet address, aborting\n"); + continue; + } + + /* + * Reset chip in case UNDI or EFI driver did not shutdown + * DMA self test will enable WDMAC and we'll see (spurious) + * pending DMA on the PCI bus at that point. + */ + if ((tr32(HOSTCC_MODE) & HOSTCC_MODE_ENABLE) || + (tr32(WDMAC_MODE) & WDMAC_MODE_ENABLE)) { + tw32(MEMARB_MODE, MEMARB_MODE_ENABLE); + tg3_halt__(tp, RESET_KIND_SHUTDOWN, 1); + } + + err = tg3_test_dma(tp); + if (err) { + printf("# DMA engine test failed, aborting\n"); + continue; + } + + intmbx = MAILBOX_INTERRUPT_0 + TG3_64BIT_REG_LOW; + rcvmbx = MAILBOX_RCVRET_CON_IDX_0 + TG3_64BIT_REG_LOW; + sndmbx = MAILBOX_SNDHOST_PROD_IDX_0 + TG3_64BIT_REG_LOW; + + struct tg3_napi *tnapi = &tp->napi[0]; + + tnapi->tp = tp; + tnapi->int_mbox = intmbx; + tnapi->consmbox = rcvmbx; + tnapi->prodmbox = sndmbx; + + for (j = 0; j < 6; j++) + dev->enetaddr[j] = tp->mac_address[j]; + + if (pre_init_list_count < PRE_INIT_MAX) + pre_init_list[pre_init_list_count++] = dev; + } + + /* Cards can take a little time to link up fully. To speed things + * up, we will init the cards now, so that we don't have to wait + * as long when calling tg3_init before sending a frame */ + for (i = 0; i < pre_init_list_count; i++) { + struct eth_device *dev = pre_init_list[i]; + struct tg3_priv *tp = dev->priv; + tp->card_init_state = TG3_INIT_STATE_PRE; + tg3_init(dev, NULL); + } + + return i; +} diff --git a/drivers/net/tg3.h b/drivers/net/tg3.h new file mode 100644 index 0000000..96e3619 --- /dev/null +++ b/drivers/net/tg3.h @@ -0,0 +1,3217 @@ +/* $Id: tg3.h,v 1.37.2.32 2002/03/11 12:18:18 davem Exp $ + * tg3.h: Definitions for Broadcom Tigon3 ethernet driver. + * + * Copyright (C) 2001, 2002, 2003, 2004 David S. Miller (davem@redhat.com) + * Copyright (C) 2001 Jeff Garzik (jgarzik@pobox.com) + * Copyright (C) 2004 Sun Microsystems Inc. + * Copyright (C) 2007-2014 Broadcom Corporation. + */ + +#ifndef _T3_H +#define _T3_H + +#define TG3_64BIT_REG_HIGH 0x00UL +#define TG3_64BIT_REG_LOW 0x04UL + +/* Descriptor block info. */ +#define TG3_BDINFO_HOST_ADDR 0x0UL /* 64-bit */ +#define TG3_BDINFO_MAXLEN_FLAGS 0x8UL /* 32-bit */ +#define BDINFO_FLAGS_USE_EXT_RECV 0x00000001 /* ext rx_buffer_desc */ +#define BDINFO_FLAGS_DISABLED 0x00000002 +#define BDINFO_FLAGS_MAXLEN_MASK 0xffff0000 +#define BDINFO_FLAGS_MAXLEN_SHIFT 16 +#define TG3_BDINFO_NIC_ADDR 0xcUL /* 32-bit */ +#define TG3_BDINFO_SIZE 0x10UL + +#define TG3_RX_STD_MAX_SIZE_5700 512 +#define TG3_RX_STD_MAX_SIZE_5717 2048 +#define TG3_RX_RET_MAX_SIZE_5700 1024 +#define TG3_RX_RET_MAX_SIZE_5705 512 +#define TG3_RX_RET_MAX_SIZE_5717 4096 + +#define TG3_RSS_INDIR_TBL_SIZE 128 + +/* First 256 bytes are a mirror of PCI config space. */ +#define TG3PCI_VENDOR 0x00000000 +#define TG3PCI_VENDOR_BROADCOM 0x14e4 +#define TG3PCI_DEVICE 0x00000002 +#define TG3PCI_DEVICE_TIGON3_1 0x1644 /* BCM5700 */ +#define TG3PCI_DEVICE_TIGON3_2 0x1645 /* BCM5701 */ +#define TG3PCI_DEVICE_TIGON3_3 0x1646 /* BCM5702 */ +#define TG3PCI_DEVICE_TIGON3_4 0x1647 /* BCM5703 */ +#define TG3PCI_DEVICE_TIGON3_5761S 0x1688 +#define TG3PCI_DEVICE_TIGON3_5761SE 0x1689 +#define TG3PCI_DEVICE_TIGON3_57780 0x1692 +#define TG3PCI_DEVICE_TIGON3_5787M 0x1693 +#define TG3PCI_DEVICE_TIGON3_57760 0x1690 +#define TG3PCI_DEVICE_TIGON3_57790 0x1694 +#define TG3PCI_DEVICE_TIGON3_57788 0x1691 +#define TG3PCI_DEVICE_TIGON3_5785_G 0x1699 /* GPHY */ +#define TG3PCI_DEVICE_TIGON3_5785_F 0x16a0 /* 10/100 only */ +#define TG3PCI_DEVICE_TIGON3_5717 0x1655 +#define TG3PCI_DEVICE_TIGON3_5717_C 0x1665 +#define TG3PCI_DEVICE_TIGON3_5718 0x1656 +#define TG3PCI_DEVICE_TIGON3_57781 0x16b1 +#define TG3PCI_DEVICE_TIGON3_57785 0x16b5 +#define TG3PCI_DEVICE_TIGON3_57761 0x16b0 +#define TG3PCI_DEVICE_TIGON3_57765 0x16b4 +#define TG3PCI_DEVICE_TIGON3_57791 0x16b2 +#define TG3PCI_DEVICE_TIGON3_57795 0x16b6 +#define TG3PCI_DEVICE_TIGON3_5719 0x1657 +#define TG3PCI_DEVICE_TIGON3_5720 0x165f +#define TG3PCI_DEVICE_TIGON3_57762 0x1682 +#define TG3PCI_DEVICE_TIGON3_57766 0x1686 +#define TG3PCI_DEVICE_TIGON3_57786 0x16b3 +#define TG3PCI_DEVICE_TIGON3_57782 0x16b7 +#define TG3PCI_DEVICE_TIGON3_5762 0x1687 +#define TG3PCI_DEVICE_TIGON3_5725 0x1643 +#define TG3PCI_DEVICE_TIGON3_5727 0x16f3 +#define TG3PCI_DEVICE_TIGON3_57764 0x1642 +#define TG3PCI_DEVICE_TIGON3_57767 0x1683 +#define TG3PCI_DEVICE_TIGON3_57787 0x1641 + +#define TG3PCI_DEVICE_TIGON3_5752 0x1600 +#define TG3PCI_DEVICE_TIGON3_5752M 0x1601 +#define TG3PCI_DEVICE_TIGON3_5700 0x1644 +#define TG3PCI_DEVICE_TIGON3_5701 0x1645 +#define TG3PCI_DEVICE_TIGON3_5702 0x1646 +#define TG3PCI_DEVICE_TIGON3_5703 0x1647 +#define TG3PCI_DEVICE_TIGON3_5704 0x1648 +#define TG3PCI_DEVICE_TIGON3_5704S_2 0x1649 +#define TG3PCI_DEVICE_TIGON3_5702FE 0x164d +#define TG3PCI_DEVICE_TIGON3_5705 0x1653 +#define TG3PCI_DEVICE_TIGON3_5705_2 0x1654 +#define TG3PCI_DEVICE_TIGON3_5719 0x1657 +#define TG3PCI_DEVICE_TIGON3_5721 0x1659 +#define TG3PCI_DEVICE_TIGON3_5722 0x165a +#define TG3PCI_DEVICE_TIGON3_5723 0x165b +#define TG3PCI_DEVICE_TIGON3_5705M 0x165d +#define TG3PCI_DEVICE_TIGON3_5705M_2 0x165e +#define TG3PCI_DEVICE_TIGON3_5714 0x1668 +#define TG3PCI_DEVICE_TIGON3_5714S 0x1669 +#define TG3PCI_DEVICE_TIGON3_5780 0x166a +#define TG3PCI_DEVICE_TIGON3_5780S 0x166b +#define TG3PCI_DEVICE_TIGON3_5705F 0x166e +#define TG3PCI_DEVICE_TIGON3_5754M 0x1672 +#define TG3PCI_DEVICE_TIGON3_5755M 0x1673 +#define TG3PCI_DEVICE_TIGON3_5756 0x1674 +#define TG3PCI_DEVICE_TIGON3_5750 0x1676 +#define TG3PCI_DEVICE_TIGON3_5751 0x1677 +#define TG3PCI_DEVICE_TIGON3_5715 0x1678 +#define TG3PCI_DEVICE_TIGON3_5715S 0x1679 +#define TG3PCI_DEVICE_TIGON3_5754 0x167a +#define TG3PCI_DEVICE_TIGON3_5755 0x167b +#define TG3PCI_DEVICE_TIGON3_5751M 0x167d +#define TG3PCI_DEVICE_TIGON3_5751F 0x167e +#define TG3PCI_DEVICE_TIGON3_5787F 0x167f +#define TG3PCI_DEVICE_TIGON3_5761E 0x1680 +#define TG3PCI_DEVICE_TIGON3_5761 0x1681 +#define TG3PCI_DEVICE_TIGON3_5764 0x1684 +#define TG3PCI_DEVICE_TIGON3_5787M 0x1693 +#define TG3PCI_DEVICE_TIGON3_5782 0x1696 +#define TG3PCI_DEVICE_TIGON3_5784 0x1698 +#define TG3PCI_DEVICE_TIGON3_5786 0x169a +#define TG3PCI_DEVICE_TIGON3_5787 0x169b +#define TG3PCI_DEVICE_TIGON3_5788 0x169c +#define TG3PCI_DEVICE_TIGON3_5789 0x169d +#define TG3PCI_DEVICE_TIGON3_5702X 0x16a6 +#define TG3PCI_DEVICE_TIGON3_5703X 0x16a7 +#define TG3PCI_DEVICE_TIGON3_5704S 0x16a8 +#define TG3PCI_DEVICE_TIGON3_5702A3 0x16c6 +#define TG3PCI_DEVICE_TIGON3_5703A3 0x16c7 +#define TG3PCI_DEVICE_TIGON3_5781 0x16dd +#define TG3PCI_DEVICE_TIGON3_5753 0x16f7 +#define TG3PCI_DEVICE_TIGON3_5753M 0x16fd +#define TG3PCI_DEVICE_TIGON3_5753F 0x16fe +#define TG3PCI_DEVICE_TIGON3_5901 0x170d +#define TG3PCI_DEVICE_TIGON3_5901_2 0x170e +#define TG3PCI_DEVICE_TIGON3_5906 0x1712 +#define TG3PCI_DEVICE_TIGON3_5906M 0x1713 + + +/* 0x04 --> 0x2c unused */ +#define TG3PCI_SUBVENDOR_ID_BROADCOM PCI_VENDOR_ID_BROADCOM +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95700A6 0x1644 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95701A5 0x0001 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95700T6 0x0002 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95700A9 0x0003 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95701T1 0x0005 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95701T8 0x0006 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95701A12 0x8008 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95703AX1 0x0009 +#define TG3PCI_SUBDEVICE_ID_BROADCOM_95703AX2 0x8009 +#define TG3PCI_SUBVENDOR_ID_3COM PCI_VENDOR_ID_3COM +#define TG3PCI_SUBDEVICE_ID_3COM_3C996T 0x1000 +#define TG3PCI_SUBDEVICE_ID_3COM_3C996BT 0x1006 +#define TG3PCI_SUBDEVICE_ID_3COM_3C996SX 0x1004 +#define TG3PCI_SUBDEVICE_ID_3COM_3C1000T 0x1007 +#define TG3PCI_SUBDEVICE_ID_3COM_3C940BR01 0x1008 +#define TG3PCI_SUBVENDOR_ID_DELL PCI_VENDOR_ID_DELL +#define TG3PCI_SUBDEVICE_ID_DELL_VIPER 0x00d1 +#define TG3PCI_SUBDEVICE_ID_DELL_JAGUAR 0x0106 +#define TG3PCI_SUBDEVICE_ID_DELL_MERLOT 0x0109 +#define TG3PCI_SUBDEVICE_ID_DELL_SLIM_MERLOT 0x010a +#define TG3PCI_SUBVENDOR_ID_COMPAQ PCI_VENDOR_ID_COMPAQ +#define TG3PCI_SUBDEVICE_ID_COMPAQ_BANSHEE 0x007c +#define TG3PCI_SUBDEVICE_ID_COMPAQ_BANSHEE_2 0x009a +#define TG3PCI_SUBDEVICE_ID_COMPAQ_CHANGELING 0x007d +#define TG3PCI_SUBDEVICE_ID_COMPAQ_NC7780 0x0085 +#define TG3PCI_SUBDEVICE_ID_COMPAQ_NC7780_2 0x0099 +#define TG3PCI_SUBVENDOR_ID_IBM PCI_VENDOR_ID_IBM +#define TG3PCI_SUBDEVICE_ID_IBM_5703SAX2 0x0281 +#define TG3PCI_SUBDEVICE_ID_ACER_57780_A 0x0601 +#define TG3PCI_SUBDEVICE_ID_ACER_57780_B 0x0612 +#define TG3PCI_SUBDEVICE_ID_LENOVO_5787M 0x3056 + +/* 0x30 --> 0x64 unused */ +#define TG3PCI_MSI_DATA 0x00000064 +/* 0x66 --> 0x68 unused */ +#define TG3PCI_MISC_HOST_CTRL 0x00000068 +#define MISC_HOST_CTRL_CLEAR_INT 0x00000001 +#define MISC_HOST_CTRL_MASK_PCI_INT 0x00000002 +#define MISC_HOST_CTRL_BYTE_SWAP 0x00000004 +#define MISC_HOST_CTRL_WORD_SWAP 0x00000008 +#define MISC_HOST_CTRL_PCISTATE_RW 0x00000010 +#define MISC_HOST_CTRL_CLKREG_RW 0x00000020 +#define MISC_HOST_CTRL_REGWORD_SWAP 0x00000040 +#define MISC_HOST_CTRL_INDIR_ACCESS 0x00000080 +#define MISC_HOST_CTRL_IRQ_MASK_MODE 0x00000100 +#define MISC_HOST_CTRL_TAGGED_STATUS 0x00000200 +#define MISC_HOST_CTRL_CHIPREV 0xffff0000 +#define MISC_HOST_CTRL_CHIPREV_SHIFT 16 + +#define CHIPREV_ID_5700_A0 0x7000 +#define CHIPREV_ID_5700_A1 0x7001 +#define CHIPREV_ID_5700_B0 0x7100 +#define CHIPREV_ID_5700_B1 0x7101 +#define CHIPREV_ID_5700_B3 0x7102 +#define CHIPREV_ID_5700_ALTIMA 0x7104 +#define CHIPREV_ID_5700_C0 0x7200 +#define CHIPREV_ID_5701_A0 0x0000 +#define CHIPREV_ID_5701_B0 0x0100 +#define CHIPREV_ID_5701_B2 0x0102 +#define CHIPREV_ID_5701_B5 0x0105 +#define CHIPREV_ID_5703_A0 0x1000 +#define CHIPREV_ID_5703_A1 0x1001 +#define CHIPREV_ID_5703_A2 0x1002 +#define CHIPREV_ID_5703_A3 0x1003 +#define CHIPREV_ID_5704_A0 0x2000 +#define CHIPREV_ID_5704_A1 0x2001 +#define CHIPREV_ID_5704_A2 0x2002 +#define CHIPREV_ID_5704_A3 0x2003 +#define CHIPREV_ID_5705_A0 0x3000 +#define CHIPREV_ID_5705_A1 0x3001 +#define CHIPREV_ID_5705_A2 0x3002 +#define CHIPREV_ID_5705_A3 0x3003 +#define CHIPREV_ID_5750_A0 0x4000 +#define CHIPREV_ID_5750_A1 0x4001 +#define CHIPREV_ID_5750_A3 0x4003 +#define CHIPREV_ID_5750_C2 0x4202 +#define CHIPREV_ID_5752_A0_HW 0x5000 +#define CHIPREV_ID_5752_A0 0x6000 +#define CHIPREV_ID_5752_A1 0x6001 +#define CHIPREV_ID_5714_A2 0x9002 +#define CHIPREV_ID_5906_A1 0xc001 +#define CHIPREV_ID_57780_A0 0x57780000 +#define CHIPREV_ID_57780_A1 0x57780001 +#define CHIPREV_ID_5717_A0 0x05717000 +#define CHIPREV_ID_5717_C0 0x05717200 +#define CHIPREV_ID_57765_A0 0x57785000 +#define CHIPREV_ID_5719_A0 0x05719000 +#define CHIPREV_ID_5720_A0 0x05720000 +#define CHIPREV_ID_5762_A0 0x05762000 + +#define ASIC_REV_5700 0x07 +#define ASIC_REV_5701 0x00 +#define ASIC_REV_5703 0x01 +#define ASIC_REV_5704 0x02 +#define ASIC_REV_5705 0x03 +#define ASIC_REV_5750 0x04 +#define ASIC_REV_5752 0x06 +#define ASIC_REV_5780 0x08 +#define ASIC_REV_5714 0x09 +#define ASIC_REV_5755 0x0a +#define ASIC_REV_5787 0x0b +#define ASIC_REV_5906 0x0c +#define ASIC_REV_USE_PROD_ID_REG 0x0f +#define ASIC_REV_5784 0x5784 +#define ASIC_REV_5761 0x5761 +#define ASIC_REV_5785 0x5785 +#define ASIC_REV_57780 0x57780 +#define ASIC_REV_5717 0x5717 +#define ASIC_REV_57765 0x57785 +#define ASIC_REV_5719 0x5719 +#define ASIC_REV_5720 0x5720 +#define ASIC_REV_57766 0x57766 +#define ASIC_REV_5762 0x5762 +#define CHIPREV_5700_AX 0x70 +#define CHIPREV_5700_BX 0x71 +#define CHIPREV_5700_CX 0x72 +#define CHIPREV_5701_AX 0x00 +#define CHIPREV_5703_AX 0x10 +#define CHIPREV_5704_AX 0x20 +#define CHIPREV_5704_BX 0x21 +#define CHIPREV_5750_AX 0x40 +#define CHIPREV_5750_BX 0x41 +#define CHIPREV_5784_AX 0x57840 +#define CHIPREV_5761_AX 0x57610 +#define CHIPREV_57765_AX 0x577650 +#define METAL_REV_A0 0x00 +#define METAL_REV_A1 0x01 +#define METAL_REV_B0 0x00 +#define METAL_REV_B1 0x01 +#define METAL_REV_B2 0x02 +#define TG3PCI_DMA_RW_CTRL 0x0000006c +#define DMA_RWCTRL_DIS_CACHE_ALIGNMENT 0x00000001 +#define DMA_RWCTRL_TAGGED_STAT_WA 0x00000080 +#define DMA_RWCTRL_CRDRDR_RDMA_MRRS_MSK 0x00000380 +#define DMA_RWCTRL_READ_BNDRY_MASK 0x00000700 +#define DMA_RWCTRL_READ_BNDRY_DISAB 0x00000000 +#define DMA_RWCTRL_READ_BNDRY_16 0x00000100 +#define DMA_RWCTRL_READ_BNDRY_128_PCIX 0x00000100 +#define DMA_RWCTRL_READ_BNDRY_32 0x00000200 +#define DMA_RWCTRL_READ_BNDRY_256_PCIX 0x00000200 +#define DMA_RWCTRL_READ_BNDRY_64 0x00000300 +#define DMA_RWCTRL_READ_BNDRY_384_PCIX 0x00000300 +#define DMA_RWCTRL_READ_BNDRY_128 0x00000400 +#define DMA_RWCTRL_READ_BNDRY_256 0x00000500 +#define DMA_RWCTRL_READ_BNDRY_512 0x00000600 +#define DMA_RWCTRL_READ_BNDRY_1024 0x00000700 +#define DMA_RWCTRL_WRITE_BNDRY_MASK 0x00003800 +#define DMA_RWCTRL_WRITE_BNDRY_DISAB 0x00000000 +#define DMA_RWCTRL_WRITE_BNDRY_16 0x00000800 +#define DMA_RWCTRL_WRITE_BNDRY_128_PCIX 0x00000800 +#define DMA_RWCTRL_WRITE_BNDRY_32 0x00001000 +#define DMA_RWCTRL_WRITE_BNDRY_256_PCIX 0x00001000 +#define DMA_RWCTRL_WRITE_BNDRY_64 0x00001800 +#define DMA_RWCTRL_WRITE_BNDRY_384_PCIX 0x00001800 +#define DMA_RWCTRL_WRITE_BNDRY_128 0x00002000 +#define DMA_RWCTRL_WRITE_BNDRY_256 0x00002800 +#define DMA_RWCTRL_WRITE_BNDRY_512 0x00003000 +#define DMA_RWCTRL_WRITE_BNDRY_1024 0x00003800 +#define DMA_RWCTRL_ONE_DMA 0x00004000 +#define DMA_RWCTRL_READ_WATER 0x00070000 +#define DMA_RWCTRL_READ_WATER_SHIFT 16 +#define DMA_RWCTRL_WRITE_WATER 0x00380000 +#define DMA_RWCTRL_WRITE_WATER_SHIFT 19 +#define DMA_RWCTRL_USE_MEM_READ_MULT 0x00400000 +#define DMA_RWCTRL_ASSERT_ALL_BE 0x00800000 +#define DMA_RWCTRL_PCI_READ_CMD 0x0f000000 +#define DMA_RWCTRL_PCI_READ_CMD_SHIFT 24 +#define DMA_RWCTRL_PCI_WRITE_CMD 0xf0000000 +#define DMA_RWCTRL_PCI_WRITE_CMD_SHIFT 28 +#define DMA_RWCTRL_WRITE_BNDRY_64_PCIE 0x10000000 +#define DMA_RWCTRL_WRITE_BNDRY_128_PCIE 0x30000000 +#define DMA_RWCTRL_WRITE_BNDRY_DISAB_PCIE 0x70000000 +#define TG3PCI_PCISTATE 0x00000070 +#define PCISTATE_FORCE_RESET 0x00000001 +#define PCISTATE_INT_NOT_ACTIVE 0x00000002 +#define PCISTATE_CONV_PCI_MODE 0x00000004 +#define PCISTATE_BUS_SPEED_HIGH 0x00000008 +#define PCISTATE_BUS_32BIT 0x00000010 +#define PCISTATE_ROM_ENABLE 0x00000020 +#define PCISTATE_ROM_RETRY_ENABLE 0x00000040 +#define PCISTATE_FLAT_VIEW 0x00000100 +#define PCISTATE_RETRY_SAME_DMA 0x00002000 +#define PCISTATE_ALLOW_APE_CTLSPC_WR 0x00010000 +#define PCISTATE_ALLOW_APE_SHMEM_WR 0x00020000 +#define PCISTATE_ALLOW_APE_PSPACE_WR 0x00040000 +#define TG3PCI_CLOCK_CTRL 0x00000074 +#define CLOCK_CTRL_CORECLK_DISABLE 0x00000200 +#define CLOCK_CTRL_RXCLK_DISABLE 0x00000400 +#define CLOCK_CTRL_TXCLK_DISABLE 0x00000800 +#define CLOCK_CTRL_ALTCLK 0x00001000 +#define CLOCK_CTRL_PWRDOWN_PLL133 0x00008000 +#define CLOCK_CTRL_44MHZ_CORE 0x00040000 +#define CLOCK_CTRL_625_CORE 0x00100000 +#define CLOCK_CTRL_FORCE_CLKRUN 0x00200000 +#define CLOCK_CTRL_CLKRUN_OENABLE 0x00400000 +#define CLOCK_CTRL_DELAY_PCI_GRANT 0x80000000 +#define TG3PCI_REG_BASE_ADDR 0x00000078 +#define TG3PCI_MEM_WIN_BASE_ADDR 0x0000007c +#define TG3PCI_REG_DATA 0x00000080 +#define TG3PCI_MEM_WIN_DATA 0x00000084 +#define TG3PCI_MISC_LOCAL_CTRL 0x00000090 +/* 0x94 --> 0x98 unused */ +#define TG3PCI_STD_RING_PROD_IDX 0x00000098 /* 64-bit */ +#define TG3PCI_RCV_RET_RING_CON_IDX 0x000000a0 /* 64-bit */ +/* 0xa8 --> 0xb8 unused */ +#define TG3PCI_DUAL_MAC_CTRL 0x000000b8 +#define DUAL_MAC_CTRL_CH_MASK 0x00000003 +#define DUAL_MAC_CTRL_ID 0x00000004 +#define TG3PCI_PRODID_ASICREV 0x000000bc +#define PROD_ID_ASIC_REV_MASK 0x0fffffff +/* 0xc0 --> 0xf4 unused */ + +#define TG3PCI_GEN2_PRODID_ASICREV 0x000000f4 +#define TG3PCI_GEN15_PRODID_ASICREV 0x000000fc +/* 0xf8 --> 0x200 unused */ + +#define TG3_CORR_ERR_STAT 0x00000110 +#define TG3_CORR_ERR_STAT_CLEAR 0xffffffff +/* 0x114 --> 0x200 unused */ + +/* Mailbox registers */ +#define MAILBOX_INTERRUPT_0 0x00000200 /* 64-bit */ +#define MAILBOX_INTERRUPT_1 0x00000208 /* 64-bit */ +#define MAILBOX_INTERRUPT_2 0x00000210 /* 64-bit */ +#define MAILBOX_INTERRUPT_3 0x00000218 /* 64-bit */ +#define MAILBOX_GENERAL_0 0x00000220 /* 64-bit */ +#define MAILBOX_GENERAL_1 0x00000228 /* 64-bit */ +#define MAILBOX_GENERAL_2 0x00000230 /* 64-bit */ +#define MAILBOX_GENERAL_3 0x00000238 /* 64-bit */ +#define MAILBOX_GENERAL_4 0x00000240 /* 64-bit */ +#define MAILBOX_GENERAL_5 0x00000248 /* 64-bit */ +#define MAILBOX_GENERAL_6 0x00000250 /* 64-bit */ +#define MAILBOX_GENERAL_7 0x00000258 /* 64-bit */ +#define MAILBOX_RELOAD_STAT 0x00000260 /* 64-bit */ +#define MAILBOX_RCV_STD_PROD_IDX 0x00000268 /* 64-bit */ +#define TG3_RX_STD_PROD_IDX_REG (MAILBOX_RCV_STD_PROD_IDX + \ + TG3_64BIT_REG_LOW) +#define MAILBOX_RCV_JUMBO_PROD_IDX 0x00000270 /* 64-bit */ +#define TG3_RX_JMB_PROD_IDX_REG (MAILBOX_RCV_JUMBO_PROD_IDX + \ + TG3_64BIT_REG_LOW) +#define MAILBOX_RCV_MINI_PROD_IDX 0x00000278 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_0 0x00000280 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_1 0x00000288 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_2 0x00000290 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_3 0x00000298 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_4 0x000002a0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_5 0x000002a8 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_6 0x000002b0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_7 0x000002b8 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_8 0x000002c0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_9 0x000002c8 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_10 0x000002d0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_11 0x000002d8 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_12 0x000002e0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_13 0x000002e8 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_14 0x000002f0 /* 64-bit */ +#define MAILBOX_RCVRET_CON_IDX_15 0x000002f8 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_0 0x00000300 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_1 0x00000308 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_2 0x00000310 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_3 0x00000318 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_4 0x00000320 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_5 0x00000328 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_6 0x00000330 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_7 0x00000338 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_8 0x00000340 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_9 0x00000348 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_10 0x00000350 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_11 0x00000358 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_12 0x00000360 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_13 0x00000368 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_14 0x00000370 /* 64-bit */ +#define MAILBOX_SNDHOST_PROD_IDX_15 0x00000378 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_0 0x00000380 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_1 0x00000388 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_2 0x00000390 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_3 0x00000398 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_4 0x000003a0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_5 0x000003a8 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_6 0x000003b0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_7 0x000003b8 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_8 0x000003c0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_9 0x000003c8 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_10 0x000003d0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_11 0x000003d8 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_12 0x000003e0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_13 0x000003e8 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_14 0x000003f0 /* 64-bit */ +#define MAILBOX_SNDNIC_PROD_IDX_15 0x000003f8 /* 64-bit */ + +/* MAC control registers */ +#define MAC_MODE 0x00000400 +#define MAC_MODE_RESET 0x00000001 +#define MAC_MODE_HALF_DUPLEX 0x00000002 +#define MAC_MODE_PORT_MODE_MASK 0x0000000c +#define MAC_MODE_PORT_MODE_TBI 0x0000000c +#define MAC_MODE_PORT_MODE_GMII 0x00000008 +#define MAC_MODE_PORT_MODE_MII 0x00000004 +#define MAC_MODE_PORT_MODE_NONE 0x00000000 +#define MAC_MODE_PORT_INT_LPBACK 0x00000010 +#define MAC_MODE_TAGGED_MAC_CTRL 0x00000080 +#define MAC_MODE_TX_BURSTING 0x00000100 +#define MAC_MODE_MAX_DEFER 0x00000200 +#define MAC_MODE_LINK_POLARITY 0x00000400 +#define MAC_MODE_RXSTAT_ENABLE 0x00000800 +#define MAC_MODE_RXSTAT_CLEAR 0x00001000 +#define MAC_MODE_RXSTAT_FLUSH 0x00002000 +#define MAC_MODE_TXSTAT_ENABLE 0x00004000 +#define MAC_MODE_TXSTAT_CLEAR 0x00008000 +#define MAC_MODE_TXSTAT_FLUSH 0x00010000 +#define MAC_MODE_SEND_CONFIGS 0x00020000 +#define MAC_MODE_MAGIC_PKT_ENABLE 0x00040000 +#define MAC_MODE_ACPI_ENABLE 0x00080000 +#define MAC_MODE_MIP_ENABLE 0x00100000 +#define MAC_MODE_TDE_ENABLE 0x00200000 +#define MAC_MODE_RDE_ENABLE 0x00400000 +#define MAC_MODE_FHDE_ENABLE 0x00800000 +#define MAC_MODE_KEEP_FRAME_IN_WOL 0x01000000 +#define MAC_MODE_APE_RX_EN 0x08000000 +#define MAC_MODE_APE_TX_EN 0x10000000 +#define MAC_STATUS 0x00000404 +#define MAC_STATUS_PCS_SYNCED 0x00000001 +#define MAC_STATUS_SIGNAL_DET 0x00000002 +#define MAC_STATUS_RCVD_CFG 0x00000004 +#define MAC_STATUS_CFG_CHANGED 0x00000008 +#define MAC_STATUS_SYNC_CHANGED 0x00000010 +#define MAC_STATUS_PORT_DEC_ERR 0x00000400 +#define MAC_STATUS_LNKSTATE_CHANGED 0x00001000 +#define MAC_STATUS_MI_COMPLETION 0x00400000 +#define MAC_STATUS_MI_INTERRUPT 0x00800000 +#define MAC_STATUS_AP_ERROR 0x01000000 +#define MAC_STATUS_ODI_ERROR 0x02000000 +#define MAC_STATUS_RXSTAT_OVERRUN 0x04000000 +#define MAC_STATUS_TXSTAT_OVERRUN 0x08000000 +#define MAC_EVENT 0x00000408 +#define MAC_EVENT_PORT_DECODE_ERR 0x00000400 +#define MAC_EVENT_LNKSTATE_CHANGED 0x00001000 +#define MAC_EVENT_MI_COMPLETION 0x00400000 +#define MAC_EVENT_MI_INTERRUPT 0x00800000 +#define MAC_EVENT_AP_ERROR 0x01000000 +#define MAC_EVENT_ODI_ERROR 0x02000000 +#define MAC_EVENT_RXSTAT_OVERRUN 0x04000000 +#define MAC_EVENT_TXSTAT_OVERRUN 0x08000000 +#define MAC_LED_CTRL 0x0000040c +#define LED_CTRL_LNKLED_OVERRIDE 0x00000001 +#define LED_CTRL_1000MBPS_ON 0x00000002 +#define LED_CTRL_100MBPS_ON 0x00000004 +#define LED_CTRL_10MBPS_ON 0x00000008 +#define LED_CTRL_TRAFFIC_OVERRIDE 0x00000010 +#define LED_CTRL_TRAFFIC_BLINK 0x00000020 +#define LED_CTRL_TRAFFIC_LED 0x00000040 +#define LED_CTRL_1000MBPS_STATUS 0x00000080 +#define LED_CTRL_100MBPS_STATUS 0x00000100 +#define LED_CTRL_10MBPS_STATUS 0x00000200 +#define LED_CTRL_TRAFFIC_STATUS 0x00000400 +#define LED_CTRL_MODE_MAC 0x00000000 +#define LED_CTRL_MODE_PHY_1 0x00000800 +#define LED_CTRL_MODE_PHY_2 0x00001000 +#define LED_CTRL_MODE_SHASTA_MAC 0x00002000 +#define LED_CTRL_MODE_SHARED 0x00004000 +#define LED_CTRL_MODE_COMBO 0x00008000 +#define LED_CTRL_BLINK_RATE_MASK 0x7ff80000 +#define LED_CTRL_BLINK_RATE_SHIFT 19 +#define LED_CTRL_BLINK_PER_OVERRIDE 0x00080000 +#define LED_CTRL_BLINK_RATE_OVERRIDE 0x80000000 +#define MAC_ADDR_0_HIGH 0x00000410 /* upper 2 bytes */ +#define MAC_ADDR_0_LOW 0x00000414 /* lower 4 bytes */ +#define MAC_ADDR_1_HIGH 0x00000418 /* upper 2 bytes */ +#define MAC_ADDR_1_LOW 0x0000041c /* lower 4 bytes */ +#define MAC_ADDR_2_HIGH 0x00000420 /* upper 2 bytes */ +#define MAC_ADDR_2_LOW 0x00000424 /* lower 4 bytes */ +#define MAC_ADDR_3_HIGH 0x00000428 /* upper 2 bytes */ +#define MAC_ADDR_3_LOW 0x0000042c /* lower 4 bytes */ +#define MAC_ACPI_MBUF_PTR 0x00000430 +#define MAC_ACPI_LEN_OFFSET 0x00000434 +#define ACPI_LENOFF_LEN_MASK 0x0000ffff +#define ACPI_LENOFF_LEN_SHIFT 0 +#define ACPI_LENOFF_OFF_MASK 0x0fff0000 +#define ACPI_LENOFF_OFF_SHIFT 16 +#define MAC_TX_BACKOFF_SEED 0x00000438 +#define TX_BACKOFF_SEED_MASK 0x000003ff +#define MAC_RX_MTU_SIZE 0x0000043c +#define RX_MTU_SIZE_MASK 0x0000ffff +#define MAC_PCS_TEST 0x00000440 +#define PCS_TEST_PATTERN_MASK 0x000fffff +#define PCS_TEST_PATTERN_SHIFT 0 +#define PCS_TEST_ENABLE 0x00100000 +#define MAC_TX_AUTO_NEG 0x00000444 +#define TX_AUTO_NEG_MASK 0x0000ffff +#define TX_AUTO_NEG_SHIFT 0 +#define MAC_RX_AUTO_NEG 0x00000448 +#define RX_AUTO_NEG_MASK 0x0000ffff +#define RX_AUTO_NEG_SHIFT 0 +#define MAC_MI_COM 0x0000044c +#define MI_COM_CMD_MASK 0x0c000000 +#define MI_COM_CMD_WRITE 0x04000000 +#define MI_COM_CMD_READ 0x08000000 +#define MI_COM_READ_FAILED 0x10000000 +#define MI_COM_START 0x20000000 +#define MI_COM_BUSY 0x20000000 +#define MI_COM_PHY_ADDR_MASK 0x03e00000 +#define MI_COM_PHY_ADDR_SHIFT 21 +#define MI_COM_REG_ADDR_MASK 0x001f0000 +#define MI_COM_REG_ADDR_SHIFT 16 +#define MI_COM_DATA_MASK 0x0000ffff +#define MAC_MI_STAT 0x00000450 +#define MAC_MI_STAT_LNKSTAT_ATTN_ENAB 0x00000001 +#define MAC_MI_STAT_10MBPS_MODE 0x00000002 +#define MAC_MI_MODE 0x00000454 +#define MAC_MI_MODE_CLK_10MHZ 0x00000001 +#define MAC_MI_MODE_SHORT_PREAMBLE 0x00000002 +#define MAC_MI_MODE_AUTO_POLL 0x00000010 +#define MAC_MI_MODE_500KHZ_CONST 0x00008000 +#define MAC_MI_MODE_BASE 0x000c0000 /* XXX magic values XXX */ +#define MAC_AUTO_POLL_STATUS 0x00000458 +#define MAC_AUTO_POLL_ERROR 0x00000001 +#define MAC_TX_MODE 0x0000045c +#define TX_MODE_RESET 0x00000001 +#define TX_MODE_ENABLE 0x00000002 +#define TX_MODE_FLOW_CTRL_ENABLE 0x00000010 +#define TX_MODE_BIG_BCKOFF_ENABLE 0x00000020 +#define TX_MODE_LONG_PAUSE_ENABLE 0x00000040 +#define TX_MODE_MBUF_LOCKUP_FIX 0x00000100 +#define TX_MODE_JMB_FRM_LEN 0x00400000 +#define TX_MODE_CNT_DN_MODE 0x00800000 +#define MAC_TX_STATUS 0x00000460 +#define TX_STATUS_XOFFED 0x00000001 +#define TX_STATUS_SENT_XOFF 0x00000002 +#define TX_STATUS_SENT_XON 0x00000004 +#define TX_STATUS_LINK_UP 0x00000008 +#define TX_STATUS_ODI_UNDERRUN 0x00000010 +#define TX_STATUS_ODI_OVERRUN 0x00000020 +#define MAC_TX_LENGTHS 0x00000464 +#define TX_LENGTHS_SLOT_TIME_MASK 0x000000ff +#define TX_LENGTHS_SLOT_TIME_SHIFT 0 +#define TX_LENGTHS_IPG_MASK 0x00000f00 +#define TX_LENGTHS_IPG_SHIFT 8 +#define TX_LENGTHS_IPG_CRS_MASK 0x00003000 +#define TX_LENGTHS_IPG_CRS_SHIFT 12 +#define TX_LENGTHS_JMB_FRM_LEN_MSK 0x00ff0000 +#define TX_LENGTHS_CNT_DWN_VAL_MSK 0xff000000 +#define MAC_RX_MODE 0x00000468 +#define RX_MODE_RESET 0x00000001 +#define RX_MODE_ENABLE 0x00000002 +#define RX_MODE_FLOW_CTRL_ENABLE 0x00000004 +#define RX_MODE_KEEP_MAC_CTRL 0x00000008 +#define RX_MODE_KEEP_PAUSE 0x00000010 +#define RX_MODE_ACCEPT_OVERSIZED 0x00000020 +#define RX_MODE_ACCEPT_RUNTS 0x00000040 +#define RX_MODE_LEN_CHECK 0x00000080 +#define RX_MODE_PROMISC 0x00000100 +#define RX_MODE_NO_CRC_CHECK 0x00000200 +#define RX_MODE_KEEP_VLAN_TAG 0x00000400 +#define RX_MODE_RSS_IPV4_HASH_EN 0x00010000 +#define RX_MODE_RSS_TCP_IPV4_HASH_EN 0x00020000 +#define RX_MODE_RSS_IPV6_HASH_EN 0x00040000 +#define RX_MODE_RSS_TCP_IPV6_HASH_EN 0x00080000 +#define RX_MODE_RSS_ITBL_HASH_BITS_7 0x00700000 +#define RX_MODE_RSS_ENABLE 0x00800000 +#define RX_MODE_IPV6_CSUM_ENABLE 0x01000000 +#define RX_MODE_IPV4_FRAG_FIX 0x02000000 +#define MAC_RX_STATUS 0x0000046c +#define RX_STATUS_REMOTE_TX_XOFFED 0x00000001 +#define RX_STATUS_XOFF_RCVD 0x00000002 +#define RX_STATUS_XON_RCVD 0x00000004 +#define MAC_HASH_REG_0 0x00000470 +#define MAC_HASH_REG_1 0x00000474 +#define MAC_HASH_REG_2 0x00000478 +#define MAC_HASH_REG_3 0x0000047c +#define MAC_RCV_RULE_0 0x00000480 +#define MAC_RCV_VALUE_0 0x00000484 +#define MAC_RCV_RULE_1 0x00000488 +#define MAC_RCV_VALUE_1 0x0000048c +#define MAC_RCV_RULE_2 0x00000490 +#define MAC_RCV_VALUE_2 0x00000494 +#define MAC_RCV_RULE_3 0x00000498 +#define MAC_RCV_VALUE_3 0x0000049c +#define MAC_RCV_RULE_4 0x000004a0 +#define MAC_RCV_VALUE_4 0x000004a4 +#define MAC_RCV_RULE_5 0x000004a8 +#define MAC_RCV_VALUE_5 0x000004ac +#define MAC_RCV_RULE_6 0x000004b0 +#define MAC_RCV_VALUE_6 0x000004b4 +#define MAC_RCV_RULE_7 0x000004b8 +#define MAC_RCV_VALUE_7 0x000004bc +#define MAC_RCV_RULE_8 0x000004c0 +#define MAC_RCV_VALUE_8 0x000004c4 +#define MAC_RCV_RULE_9 0x000004c8 +#define MAC_RCV_VALUE_9 0x000004cc +#define MAC_RCV_RULE_10 0x000004d0 +#define MAC_RCV_VALUE_10 0x000004d4 +#define MAC_RCV_RULE_11 0x000004d8 +#define MAC_RCV_VALUE_11 0x000004dc +#define MAC_RCV_RULE_12 0x000004e0 +#define MAC_RCV_VALUE_12 0x000004e4 +#define MAC_RCV_RULE_13 0x000004e8 +#define MAC_RCV_VALUE_13 0x000004ec +#define MAC_RCV_RULE_14 0x000004f0 +#define MAC_RCV_VALUE_14 0x000004f4 +#define MAC_RCV_RULE_15 0x000004f8 +#define MAC_RCV_VALUE_15 0x000004fc +#define RCV_RULE_DISABLE_MASK 0x7fffffff +#define MAC_RCV_RULE_CFG 0x00000500 +#define RCV_RULE_CFG_DEFAULT_CLASS 0x00000008 +#define MAC_LOW_WMARK_MAX_RX_FRAME 0x00000504 +/* 0x508 --> 0x520 unused */ +#define MAC_HASHREGU_0 0x00000520 +#define MAC_HASHREGU_1 0x00000524 +#define MAC_HASHREGU_2 0x00000528 +#define MAC_HASHREGU_3 0x0000052c +#define MAC_EXTADDR_0_HIGH 0x00000530 +#define MAC_EXTADDR_0_LOW 0x00000534 +#define MAC_EXTADDR_1_HIGH 0x00000538 +#define MAC_EXTADDR_1_LOW 0x0000053c +#define MAC_EXTADDR_2_HIGH 0x00000540 +#define MAC_EXTADDR_2_LOW 0x00000544 +#define MAC_EXTADDR_3_HIGH 0x00000548 +#define MAC_EXTADDR_3_LOW 0x0000054c +#define MAC_EXTADDR_4_HIGH 0x00000550 +#define MAC_EXTADDR_4_LOW 0x00000554 +#define MAC_EXTADDR_5_HIGH 0x00000558 +#define MAC_EXTADDR_5_LOW 0x0000055c +#define MAC_EXTADDR_6_HIGH 0x00000560 +#define MAC_EXTADDR_6_LOW 0x00000564 +#define MAC_EXTADDR_7_HIGH 0x00000568 +#define MAC_EXTADDR_7_LOW 0x0000056c +#define MAC_EXTADDR_8_HIGH 0x00000570 +#define MAC_EXTADDR_8_LOW 0x00000574 +#define MAC_EXTADDR_9_HIGH 0x00000578 +#define MAC_EXTADDR_9_LOW 0x0000057c +#define MAC_EXTADDR_10_HIGH 0x00000580 +#define MAC_EXTADDR_10_LOW 0x00000584 +#define MAC_EXTADDR_11_HIGH 0x00000588 +#define MAC_EXTADDR_11_LOW 0x0000058c +#define MAC_SERDES_CFG 0x00000590 +#define MAC_SERDES_CFG_EDGE_SELECT 0x00001000 +#define MAC_SERDES_STAT 0x00000594 +/* 0x598 --> 0x5a0 unused */ +#define MAC_PHYCFG1 0x000005a0 +#define MAC_PHYCFG1_RGMII_INT 0x00000001 +#define MAC_PHYCFG1_RXCLK_TO_MASK 0x00001ff0 +#define MAC_PHYCFG1_RXCLK_TIMEOUT 0x00001000 +#define MAC_PHYCFG1_TXCLK_TO_MASK 0x01ff0000 +#define MAC_PHYCFG1_TXCLK_TIMEOUT 0x01000000 +#define MAC_PHYCFG1_RGMII_EXT_RX_DEC 0x02000000 +#define MAC_PHYCFG1_RGMII_SND_STAT_EN 0x04000000 +#define MAC_PHYCFG1_TXC_DRV 0x20000000 +#define MAC_PHYCFG2 0x000005a4 +#define MAC_PHYCFG2_INBAND_ENABLE 0x00000001 +#define MAC_PHYCFG2_EMODE_MASK_MASK 0x000001c0 +#define MAC_PHYCFG2_EMODE_MASK_AC131 0x000000c0 +#define MAC_PHYCFG2_EMODE_MASK_50610 0x00000100 +#define MAC_PHYCFG2_EMODE_MASK_RT8211 0x00000000 +#define MAC_PHYCFG2_EMODE_MASK_RT8201 0x000001c0 +#define MAC_PHYCFG2_EMODE_COMP_MASK 0x00000e00 +#define MAC_PHYCFG2_EMODE_COMP_AC131 0x00000600 +#define MAC_PHYCFG2_EMODE_COMP_50610 0x00000400 +#define MAC_PHYCFG2_EMODE_COMP_RT8211 0x00000800 +#define MAC_PHYCFG2_EMODE_COMP_RT8201 0x00000000 +#define MAC_PHYCFG2_FMODE_MASK_MASK 0x00007000 +#define MAC_PHYCFG2_FMODE_MASK_AC131 0x00006000 +#define MAC_PHYCFG2_FMODE_MASK_50610 0x00004000 +#define MAC_PHYCFG2_FMODE_MASK_RT8211 0x00000000 +#define MAC_PHYCFG2_FMODE_MASK_RT8201 0x00007000 +#define MAC_PHYCFG2_FMODE_COMP_MASK 0x00038000 +#define MAC_PHYCFG2_FMODE_COMP_AC131 0x00030000 +#define MAC_PHYCFG2_FMODE_COMP_50610 0x00008000 +#define MAC_PHYCFG2_FMODE_COMP_RT8211 0x00038000 +#define MAC_PHYCFG2_FMODE_COMP_RT8201 0x00000000 +#define MAC_PHYCFG2_GMODE_MASK_MASK 0x001c0000 +#define MAC_PHYCFG2_GMODE_MASK_AC131 0x001c0000 +#define MAC_PHYCFG2_GMODE_MASK_50610 0x00100000 +#define MAC_PHYCFG2_GMODE_MASK_RT8211 0x00000000 +#define MAC_PHYCFG2_GMODE_MASK_RT8201 0x001c0000 +#define MAC_PHYCFG2_GMODE_COMP_MASK 0x00e00000 +#define MAC_PHYCFG2_GMODE_COMP_AC131 0x00e00000 +#define MAC_PHYCFG2_GMODE_COMP_50610 0x00000000 +#define MAC_PHYCFG2_GMODE_COMP_RT8211 0x00200000 +#define MAC_PHYCFG2_GMODE_COMP_RT8201 0x00000000 +#define MAC_PHYCFG2_ACT_MASK_MASK 0x03000000 +#define MAC_PHYCFG2_ACT_MASK_AC131 0x03000000 +#define MAC_PHYCFG2_ACT_MASK_50610 0x01000000 +#define MAC_PHYCFG2_ACT_MASK_RT8211 0x03000000 +#define MAC_PHYCFG2_ACT_MASK_RT8201 0x01000000 +#define MAC_PHYCFG2_ACT_COMP_MASK 0x0c000000 +#define MAC_PHYCFG2_ACT_COMP_AC131 0x00000000 +#define MAC_PHYCFG2_ACT_COMP_50610 0x00000000 +#define MAC_PHYCFG2_ACT_COMP_RT8211 0x00000000 +#define MAC_PHYCFG2_ACT_COMP_RT8201 0x08000000 +#define MAC_PHYCFG2_QUAL_MASK_MASK 0x30000000 +#define MAC_PHYCFG2_QUAL_MASK_AC131 0x30000000 +#define MAC_PHYCFG2_QUAL_MASK_50610 0x30000000 +#define MAC_PHYCFG2_QUAL_MASK_RT8211 0x30000000 +#define MAC_PHYCFG2_QUAL_MASK_RT8201 0x30000000 +#define MAC_PHYCFG2_QUAL_COMP_MASK 0xc0000000 +#define MAC_PHYCFG2_QUAL_COMP_AC131 0x00000000 +#define MAC_PHYCFG2_QUAL_COMP_50610 0x00000000 +#define MAC_PHYCFG2_QUAL_COMP_RT8211 0x00000000 +#define MAC_PHYCFG2_QUAL_COMP_RT8201 0x00000000 +#define MAC_PHYCFG2_50610_LED_MODES \ + (MAC_PHYCFG2_EMODE_MASK_50610 | \ + MAC_PHYCFG2_EMODE_COMP_50610 | \ + MAC_PHYCFG2_FMODE_MASK_50610 | \ + MAC_PHYCFG2_FMODE_COMP_50610 | \ + MAC_PHYCFG2_GMODE_MASK_50610 | \ + MAC_PHYCFG2_GMODE_COMP_50610 | \ + MAC_PHYCFG2_ACT_MASK_50610 | \ + MAC_PHYCFG2_ACT_COMP_50610 | \ + MAC_PHYCFG2_QUAL_MASK_50610 | \ + MAC_PHYCFG2_QUAL_COMP_50610) +#define MAC_PHYCFG2_AC131_LED_MODES \ + (MAC_PHYCFG2_EMODE_MASK_AC131 | \ + MAC_PHYCFG2_EMODE_COMP_AC131 | \ + MAC_PHYCFG2_FMODE_MASK_AC131 | \ + MAC_PHYCFG2_FMODE_COMP_AC131 | \ + MAC_PHYCFG2_GMODE_MASK_AC131 | \ + MAC_PHYCFG2_GMODE_COMP_AC131 | \ + MAC_PHYCFG2_ACT_MASK_AC131 | \ + MAC_PHYCFG2_ACT_COMP_AC131 | \ + MAC_PHYCFG2_QUAL_MASK_AC131 | \ + MAC_PHYCFG2_QUAL_COMP_AC131) +#define MAC_PHYCFG2_RTL8211C_LED_MODES \ + (MAC_PHYCFG2_EMODE_MASK_RT8211 | \ + MAC_PHYCFG2_EMODE_COMP_RT8211 | \ + MAC_PHYCFG2_FMODE_MASK_RT8211 | \ + MAC_PHYCFG2_FMODE_COMP_RT8211 | \ + MAC_PHYCFG2_GMODE_MASK_RT8211 | \ + MAC_PHYCFG2_GMODE_COMP_RT8211 | \ + MAC_PHYCFG2_ACT_MASK_RT8211 | \ + MAC_PHYCFG2_ACT_COMP_RT8211 | \ + MAC_PHYCFG2_QUAL_MASK_RT8211 | \ + MAC_PHYCFG2_QUAL_COMP_RT8211) +#define MAC_PHYCFG2_RTL8201E_LED_MODES \ + (MAC_PHYCFG2_EMODE_MASK_RT8201 | \ + MAC_PHYCFG2_EMODE_COMP_RT8201 | \ + MAC_PHYCFG2_FMODE_MASK_RT8201 | \ + MAC_PHYCFG2_FMODE_COMP_RT8201 | \ + MAC_PHYCFG2_GMODE_MASK_RT8201 | \ + MAC_PHYCFG2_GMODE_COMP_RT8201 | \ + MAC_PHYCFG2_ACT_MASK_RT8201 | \ + MAC_PHYCFG2_ACT_COMP_RT8201 | \ + MAC_PHYCFG2_QUAL_MASK_RT8201 | \ + MAC_PHYCFG2_QUAL_COMP_RT8201) +#define MAC_EXT_RGMII_MODE 0x000005a8 +#define MAC_RGMII_MODE_TX_ENABLE 0x00000001 +#define MAC_RGMII_MODE_TX_LOWPWR 0x00000002 +#define MAC_RGMII_MODE_TX_RESET 0x00000004 +#define MAC_RGMII_MODE_RX_INT_B 0x00000100 +#define MAC_RGMII_MODE_RX_QUALITY 0x00000200 +#define MAC_RGMII_MODE_RX_ACTIVITY 0x00000400 +#define MAC_RGMII_MODE_RX_ENG_DET 0x00000800 +/* 0x5ac --> 0x5b0 unused */ +#define SERDES_RX_CTRL 0x000005b0 /* 5780/5714 only */ +#define SERDES_RX_SIG_DETECT 0x00000400 +#define SG_DIG_CTRL 0x000005b0 +#define SG_DIG_USING_HW_AUTONEG 0x80000000 +#define SG_DIG_SOFT_RESET 0x40000000 +#define SG_DIG_DISABLE_LINKRDY 0x20000000 +#define SG_DIG_CRC16_CLEAR_N 0x01000000 +#define SG_DIG_EN10B 0x00800000 +#define SG_DIG_CLEAR_STATUS 0x00400000 +#define SG_DIG_LOCAL_DUPLEX_STATUS 0x00200000 +#define SG_DIG_LOCAL_LINK_STATUS 0x00100000 +#define SG_DIG_SPEED_STATUS_MASK 0x000c0000 +#define SG_DIG_SPEED_STATUS_SHIFT 18 +#define SG_DIG_JUMBO_PACKET_DISABLE 0x00020000 +#define SG_DIG_RESTART_AUTONEG 0x00010000 +#define SG_DIG_FIBER_MODE 0x00008000 +#define SG_DIG_REMOTE_FAULT_MASK 0x00006000 +#define SG_DIG_PAUSE_MASK 0x00001800 +#define SG_DIG_PAUSE_CAP 0x00000800 +#define SG_DIG_ASYM_PAUSE 0x00001000 +#define SG_DIG_GBIC_ENABLE 0x00000400 +#define SG_DIG_CHECK_END_ENABLE 0x00000200 +#define SG_DIG_SGMII_AUTONEG_TIMER 0x00000100 +#define SG_DIG_CLOCK_PHASE_SELECT 0x00000080 +#define SG_DIG_GMII_INPUT_SELECT 0x00000040 +#define SG_DIG_MRADV_CRC16_SELECT 0x00000020 +#define SG_DIG_COMMA_DETECT_ENABLE 0x00000010 +#define SG_DIG_AUTONEG_TIMER_REDUCE 0x00000008 +#define SG_DIG_AUTONEG_LOW_ENABLE 0x00000004 +#define SG_DIG_REMOTE_LOOPBACK 0x00000002 +#define SG_DIG_LOOPBACK 0x00000001 +#define SG_DIG_COMMON_SETUP (SG_DIG_CRC16_CLEAR_N | \ + SG_DIG_LOCAL_DUPLEX_STATUS | \ + SG_DIG_LOCAL_LINK_STATUS | \ + (0x2 << SG_DIG_SPEED_STATUS_SHIFT) | \ + SG_DIG_FIBER_MODE | SG_DIG_GBIC_ENABLE) +#define SG_DIG_STATUS 0x000005b4 +#define SG_DIG_CRC16_BUS_MASK 0xffff0000 +#define SG_DIG_PARTNER_FAULT_MASK 0x00600000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_PARTNER_ASYM_PAUSE 0x00100000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_PARTNER_PAUSE_CAPABLE 0x00080000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_PARTNER_HALF_DUPLEX 0x00040000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_PARTNER_FULL_DUPLEX 0x00020000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_PARTNER_NEXT_PAGE 0x00010000 /* If !MRADV_CRC16_SELECT */ +#define SG_DIG_AUTONEG_STATE_MASK 0x00000ff0 +#define SG_DIG_IS_SERDES 0x00000100 +#define SG_DIG_COMMA_DETECTOR 0x00000008 +#define SG_DIG_MAC_ACK_STATUS 0x00000004 +#define SG_DIG_AUTONEG_COMPLETE 0x00000002 +#define SG_DIG_AUTONEG_ERROR 0x00000001 +#define TG3_TX_TSTAMP_LSB 0x000005c0 +#define TG3_TX_TSTAMP_MSB 0x000005c4 +#define TG3_TSTAMP_MASK 0x7fffffffffffffffLL +/* 0x5c8 --> 0x600 unused */ +#define MAC_TX_MAC_STATE_BASE 0x00000600 /* 16 bytes */ +#define MAC_RX_MAC_STATE_BASE 0x00000610 /* 20 bytes */ +/* 0x624 --> 0x670 unused */ + +#define MAC_RSS_INDIR_TBL_0 0x00000630 + +#define MAC_RSS_HASH_KEY_0 0x00000670 +#define MAC_RSS_HASH_KEY_1 0x00000674 +#define MAC_RSS_HASH_KEY_2 0x00000678 +#define MAC_RSS_HASH_KEY_3 0x0000067c +#define MAC_RSS_HASH_KEY_4 0x00000680 +#define MAC_RSS_HASH_KEY_5 0x00000684 +#define MAC_RSS_HASH_KEY_6 0x00000688 +#define MAC_RSS_HASH_KEY_7 0x0000068c +#define MAC_RSS_HASH_KEY_8 0x00000690 +#define MAC_RSS_HASH_KEY_9 0x00000694 +/* 0x698 --> 0x6b0 unused */ + +#define TG3_RX_TSTAMP_LSB 0x000006b0 +#define TG3_RX_TSTAMP_MSB 0x000006b4 +/* 0x6b8 --> 0x6c8 unused */ + +#define TG3_RX_PTP_CTL 0x000006c8 +#define TG3_RX_PTP_CTL_SYNC_EVNT 0x00000001 +#define TG3_RX_PTP_CTL_DELAY_REQ 0x00000002 +#define TG3_RX_PTP_CTL_PDLAY_REQ 0x00000004 +#define TG3_RX_PTP_CTL_PDLAY_RES 0x00000008 +#define TG3_RX_PTP_CTL_ALL_V1_EVENTS (TG3_RX_PTP_CTL_SYNC_EVNT | \ + TG3_RX_PTP_CTL_DELAY_REQ) +#define TG3_RX_PTP_CTL_ALL_V2_EVENTS (TG3_RX_PTP_CTL_SYNC_EVNT | \ + TG3_RX_PTP_CTL_DELAY_REQ | \ + TG3_RX_PTP_CTL_PDLAY_REQ | \ + TG3_RX_PTP_CTL_PDLAY_RES) +#define TG3_RX_PTP_CTL_FOLLOW_UP 0x00000100 +#define TG3_RX_PTP_CTL_DELAY_RES 0x00000200 +#define TG3_RX_PTP_CTL_PDRES_FLW_UP 0x00000400 +#define TG3_RX_PTP_CTL_ANNOUNCE 0x00000800 +#define TG3_RX_PTP_CTL_SIGNALING 0x00001000 +#define TG3_RX_PTP_CTL_MANAGEMENT 0x00002000 +#define TG3_RX_PTP_CTL_RX_PTP_V2_L2_EN 0x00800000 +#define TG3_RX_PTP_CTL_RX_PTP_V2_L4_EN 0x01000000 +#define TG3_RX_PTP_CTL_RX_PTP_V2_EN (TG3_RX_PTP_CTL_RX_PTP_V2_L2_EN | \ + TG3_RX_PTP_CTL_RX_PTP_V2_L4_EN) +#define TG3_RX_PTP_CTL_RX_PTP_V1_EN 0x02000000 +#define TG3_RX_PTP_CTL_HWTS_INTERLOCK 0x04000000 +/* 0x6cc --> 0x800 unused */ + +#define MAC_TX_STATS_OCTETS 0x00000800 +#define MAC_TX_STATS_RESV1 0x00000804 +#define MAC_TX_STATS_COLLISIONS 0x00000808 +#define MAC_TX_STATS_XON_SENT 0x0000080c +#define MAC_TX_STATS_XOFF_SENT 0x00000810 +#define MAC_TX_STATS_RESV2 0x00000814 +#define MAC_TX_STATS_MAC_ERRORS 0x00000818 +#define MAC_TX_STATS_SINGLE_COLLISIONS 0x0000081c +#define MAC_TX_STATS_MULT_COLLISIONS 0x00000820 +#define MAC_TX_STATS_DEFERRED 0x00000824 +#define MAC_TX_STATS_RESV3 0x00000828 +#define MAC_TX_STATS_EXCESSIVE_COL 0x0000082c +#define MAC_TX_STATS_LATE_COL 0x00000830 +#define MAC_TX_STATS_RESV4_1 0x00000834 +#define MAC_TX_STATS_RESV4_2 0x00000838 +#define MAC_TX_STATS_RESV4_3 0x0000083c +#define MAC_TX_STATS_RESV4_4 0x00000840 +#define MAC_TX_STATS_RESV4_5 0x00000844 +#define MAC_TX_STATS_RESV4_6 0x00000848 +#define MAC_TX_STATS_RESV4_7 0x0000084c +#define MAC_TX_STATS_RESV4_8 0x00000850 +#define MAC_TX_STATS_RESV4_9 0x00000854 +#define MAC_TX_STATS_RESV4_10 0x00000858 +#define MAC_TX_STATS_RESV4_11 0x0000085c +#define MAC_TX_STATS_RESV4_12 0x00000860 +#define MAC_TX_STATS_RESV4_13 0x00000864 +#define MAC_TX_STATS_RESV4_14 0x00000868 +#define MAC_TX_STATS_UCAST 0x0000086c +#define MAC_TX_STATS_MCAST 0x00000870 +#define MAC_TX_STATS_BCAST 0x00000874 +#define MAC_TX_STATS_RESV5_1 0x00000878 +#define MAC_TX_STATS_RESV5_2 0x0000087c +#define MAC_RX_STATS_OCTETS 0x00000880 +#define MAC_RX_STATS_RESV1 0x00000884 +#define MAC_RX_STATS_FRAGMENTS 0x00000888 +#define MAC_RX_STATS_UCAST 0x0000088c +#define MAC_RX_STATS_MCAST 0x00000890 +#define MAC_RX_STATS_BCAST 0x00000894 +#define MAC_RX_STATS_FCS_ERRORS 0x00000898 +#define MAC_RX_STATS_ALIGN_ERRORS 0x0000089c +#define MAC_RX_STATS_XON_PAUSE_RECVD 0x000008a0 +#define MAC_RX_STATS_XOFF_PAUSE_RECVD 0x000008a4 +#define MAC_RX_STATS_MAC_CTRL_RECVD 0x000008a8 +#define MAC_RX_STATS_XOFF_ENTERED 0x000008ac +#define MAC_RX_STATS_FRAME_TOO_LONG 0x000008b0 +#define MAC_RX_STATS_JABBERS 0x000008b4 +#define MAC_RX_STATS_UNDERSIZE 0x000008b8 +/* 0x8bc --> 0xc00 unused */ + +/* Send data initiator control registers */ +#define SNDDATAI_MODE 0x00000c00 +#define SNDDATAI_MODE_RESET 0x00000001 +#define SNDDATAI_MODE_ENABLE 0x00000002 +#define SNDDATAI_MODE_STAT_OFLOW_ENAB 0x00000004 +#define SNDDATAI_STATUS 0x00000c04 +#define SNDDATAI_STATUS_STAT_OFLOW 0x00000004 +#define SNDDATAI_STATSCTRL 0x00000c08 +#define SNDDATAI_SCTRL_ENABLE 0x00000001 +#define SNDDATAI_SCTRL_FASTUPD 0x00000002 +#define SNDDATAI_SCTRL_CLEAR 0x00000004 +#define SNDDATAI_SCTRL_FLUSH 0x00000008 +#define SNDDATAI_SCTRL_FORCE_ZERO 0x00000010 +#define SNDDATAI_STATSENAB 0x00000c0c +#define SNDDATAI_STATSINCMASK 0x00000c10 +#define ISO_PKT_TX 0x00000c20 +/* 0xc24 --> 0xc80 unused */ +#define SNDDATAI_COS_CNT_0 0x00000c80 +#define SNDDATAI_COS_CNT_1 0x00000c84 +#define SNDDATAI_COS_CNT_2 0x00000c88 +#define SNDDATAI_COS_CNT_3 0x00000c8c +#define SNDDATAI_COS_CNT_4 0x00000c90 +#define SNDDATAI_COS_CNT_5 0x00000c94 +#define SNDDATAI_COS_CNT_6 0x00000c98 +#define SNDDATAI_COS_CNT_7 0x00000c9c +#define SNDDATAI_COS_CNT_8 0x00000ca0 +#define SNDDATAI_COS_CNT_9 0x00000ca4 +#define SNDDATAI_COS_CNT_10 0x00000ca8 +#define SNDDATAI_COS_CNT_11 0x00000cac +#define SNDDATAI_COS_CNT_12 0x00000cb0 +#define SNDDATAI_COS_CNT_13 0x00000cb4 +#define SNDDATAI_COS_CNT_14 0x00000cb8 +#define SNDDATAI_COS_CNT_15 0x00000cbc +#define SNDDATAI_DMA_RDQ_FULL_CNT 0x00000cc0 +#define SNDDATAI_DMA_PRIO_RDQ_FULL_CNT 0x00000cc4 +#define SNDDATAI_SDCQ_FULL_CNT 0x00000cc8 +#define SNDDATAI_NICRNG_SSND_PIDX_CNT 0x00000ccc +#define SNDDATAI_STATS_UPDATED_CNT 0x00000cd0 +#define SNDDATAI_INTERRUPTS_CNT 0x00000cd4 +#define SNDDATAI_AVOID_INTERRUPTS_CNT 0x00000cd8 +#define SNDDATAI_SND_THRESH_HIT_CNT 0x00000cdc +/* 0xce0 --> 0x1000 unused */ + +/* Send data completion control registers */ +#define SNDDATAC_MODE 0x00001000 +#define SNDDATAC_MODE_RESET 0x00000001 +#define SNDDATAC_MODE_ENABLE 0x00000002 +#define SNDDATAC_MODE_CDELAY 0x00000010 +/* 0x1004 --> 0x1400 unused */ + +/* Send BD ring selector */ +#define SNDBDS_MODE 0x00001400 +#define SNDBDS_MODE_RESET 0x00000001 +#define SNDBDS_MODE_ENABLE 0x00000002 +#define SNDBDS_MODE_ATTN_ENABLE 0x00000004 +#define SNDBDS_STATUS 0x00001404 +#define SNDBDS_STATUS_ERROR_ATTN 0x00000004 +#define SNDBDS_HWDIAG 0x00001408 +/* 0x140c --> 0x1440 */ +#define SNDBDS_SEL_CON_IDX_0 0x00001440 +#define SNDBDS_SEL_CON_IDX_1 0x00001444 +#define SNDBDS_SEL_CON_IDX_2 0x00001448 +#define SNDBDS_SEL_CON_IDX_3 0x0000144c +#define SNDBDS_SEL_CON_IDX_4 0x00001450 +#define SNDBDS_SEL_CON_IDX_5 0x00001454 +#define SNDBDS_SEL_CON_IDX_6 0x00001458 +#define SNDBDS_SEL_CON_IDX_7 0x0000145c +#define SNDBDS_SEL_CON_IDX_8 0x00001460 +#define SNDBDS_SEL_CON_IDX_9 0x00001464 +#define SNDBDS_SEL_CON_IDX_10 0x00001468 +#define SNDBDS_SEL_CON_IDX_11 0x0000146c +#define SNDBDS_SEL_CON_IDX_12 0x00001470 +#define SNDBDS_SEL_CON_IDX_13 0x00001474 +#define SNDBDS_SEL_CON_IDX_14 0x00001478 +#define SNDBDS_SEL_CON_IDX_15 0x0000147c +/* 0x1480 --> 0x1800 unused */ + +/* Send BD initiator control registers */ +#define SNDBDI_MODE 0x00001800 +#define SNDBDI_MODE_RESET 0x00000001 +#define SNDBDI_MODE_ENABLE 0x00000002 +#define SNDBDI_MODE_ATTN_ENABLE 0x00000004 +#define SNDBDI_MODE_MULTI_TXQ_EN 0x00000020 +#define SNDBDI_STATUS 0x00001804 +#define SNDBDI_STATUS_ERROR_ATTN 0x00000004 +#define SNDBDI_IN_PROD_IDX_0 0x00001808 +#define SNDBDI_IN_PROD_IDX_1 0x0000180c +#define SNDBDI_IN_PROD_IDX_2 0x00001810 +#define SNDBDI_IN_PROD_IDX_3 0x00001814 +#define SNDBDI_IN_PROD_IDX_4 0x00001818 +#define SNDBDI_IN_PROD_IDX_5 0x0000181c +#define SNDBDI_IN_PROD_IDX_6 0x00001820 +#define SNDBDI_IN_PROD_IDX_7 0x00001824 +#define SNDBDI_IN_PROD_IDX_8 0x00001828 +#define SNDBDI_IN_PROD_IDX_9 0x0000182c +#define SNDBDI_IN_PROD_IDX_10 0x00001830 +#define SNDBDI_IN_PROD_IDX_11 0x00001834 +#define SNDBDI_IN_PROD_IDX_12 0x00001838 +#define SNDBDI_IN_PROD_IDX_13 0x0000183c +#define SNDBDI_IN_PROD_IDX_14 0x00001840 +#define SNDBDI_IN_PROD_IDX_15 0x00001844 +/* 0x1848 --> 0x1c00 unused */ + +/* Send BD completion control registers */ +#define SNDBDC_MODE 0x00001c00 +#define SNDBDC_MODE_RESET 0x00000001 +#define SNDBDC_MODE_ENABLE 0x00000002 +#define SNDBDC_MODE_ATTN_ENABLE 0x00000004 +/* 0x1c04 --> 0x2000 unused */ + +/* Receive list placement control registers */ +#define RCVLPC_MODE 0x00002000 +#define RCVLPC_MODE_RESET 0x00000001 +#define RCVLPC_MODE_ENABLE 0x00000002 +#define RCVLPC_MODE_CLASS0_ATTN_ENAB 0x00000004 +#define RCVLPC_MODE_MAPOOR_AATTN_ENAB 0x00000008 +#define RCVLPC_MODE_STAT_OFLOW_ENAB 0x00000010 +#define RCVLPC_STATUS 0x00002004 +#define RCVLPC_STATUS_CLASS0 0x00000004 +#define RCVLPC_STATUS_MAPOOR 0x00000008 +#define RCVLPC_STATUS_STAT_OFLOW 0x00000010 +#define RCVLPC_LOCK 0x00002008 +#define RCVLPC_LOCK_REQ_MASK 0x0000ffff +#define RCVLPC_LOCK_REQ_SHIFT 0 +#define RCVLPC_LOCK_GRANT_MASK 0xffff0000 +#define RCVLPC_LOCK_GRANT_SHIFT 16 +#define RCVLPC_NON_EMPTY_BITS 0x0000200c +#define RCVLPC_NON_EMPTY_BITS_MASK 0x0000ffff +#define RCVLPC_CONFIG 0x00002010 +#define RCVLPC_STATSCTRL 0x00002014 +#define RCVLPC_STATSCTRL_ENABLE 0x00000001 +#define RCVLPC_STATSCTRL_FASTUPD 0x00000002 +#define RCVLPC_STATS_ENABLE 0x00002018 +#define RCVLPC_STATSENAB_ASF_FIX 0x00000002 +#define RCVLPC_STATSENAB_DACK_FIX 0x00040000 +#define RCVLPC_STATSENAB_LNGBRST_RFIX 0x00400000 +#define RCVLPC_STATS_INCMASK 0x0000201c +/* 0x2020 --> 0x2100 unused */ +#define RCVLPC_SELLST_BASE 0x00002100 /* 16 16-byte entries */ +#define SELLST_TAIL 0x00000004 +#define SELLST_CONT 0x00000008 +#define SELLST_UNUSED 0x0000000c +#define RCVLPC_COS_CNTL_BASE 0x00002200 /* 16 4-byte entries */ +#define RCVLPC_DROP_FILTER_CNT 0x00002240 +#define RCVLPC_DMA_WQ_FULL_CNT 0x00002244 +#define RCVLPC_DMA_HIPRIO_WQ_FULL_CNT 0x00002248 +#define RCVLPC_NO_RCV_BD_CNT 0x0000224c +#define RCVLPC_IN_DISCARDS_CNT 0x00002250 +#define RCVLPC_IN_ERRORS_CNT 0x00002254 +#define RCVLPC_RCV_THRESH_HIT_CNT 0x00002258 +/* 0x225c --> 0x2400 unused */ + +/* Receive Data and Receive BD Initiator Control */ +#define RCVDBDI_MODE 0x00002400 +#define RCVDBDI_MODE_RESET 0x00000001 +#define RCVDBDI_MODE_ENABLE 0x00000002 +#define RCVDBDI_MODE_JUMBOBD_NEEDED 0x00000004 +#define RCVDBDI_MODE_FRM_TOO_BIG 0x00000008 +#define RCVDBDI_MODE_INV_RING_SZ 0x00000010 +#define RCVDBDI_MODE_LRG_RING_SZ 0x00010000 +#define RCVDBDI_STATUS 0x00002404 +#define RCVDBDI_STATUS_JUMBOBD_NEEDED 0x00000004 +#define RCVDBDI_STATUS_FRM_TOO_BIG 0x00000008 +#define RCVDBDI_STATUS_INV_RING_SZ 0x00000010 +#define RCVDBDI_SPLIT_FRAME_MINSZ 0x00002408 +/* 0x240c --> 0x2440 unused */ +#define RCVDBDI_JUMBO_BD 0x00002440 /* TG3_BDINFO_... */ +#define RCVDBDI_STD_BD 0x00002450 /* TG3_BDINFO_... */ +#define RCVDBDI_MINI_BD 0x00002460 /* TG3_BDINFO_... */ +#define RCVDBDI_JUMBO_CON_IDX 0x00002470 +#define RCVDBDI_STD_CON_IDX 0x00002474 +#define RCVDBDI_MINI_CON_IDX 0x00002478 +/* 0x247c --> 0x2480 unused */ +#define RCVDBDI_BD_PROD_IDX_0 0x00002480 +#define RCVDBDI_BD_PROD_IDX_1 0x00002484 +#define RCVDBDI_BD_PROD_IDX_2 0x00002488 +#define RCVDBDI_BD_PROD_IDX_3 0x0000248c +#define RCVDBDI_BD_PROD_IDX_4 0x00002490 +#define RCVDBDI_BD_PROD_IDX_5 0x00002494 +#define RCVDBDI_BD_PROD_IDX_6 0x00002498 +#define RCVDBDI_BD_PROD_IDX_7 0x0000249c +#define RCVDBDI_BD_PROD_IDX_8 0x000024a0 +#define RCVDBDI_BD_PROD_IDX_9 0x000024a4 +#define RCVDBDI_BD_PROD_IDX_10 0x000024a8 +#define RCVDBDI_BD_PROD_IDX_11 0x000024ac +#define RCVDBDI_BD_PROD_IDX_12 0x000024b0 +#define RCVDBDI_BD_PROD_IDX_13 0x000024b4 +#define RCVDBDI_BD_PROD_IDX_14 0x000024b8 +#define RCVDBDI_BD_PROD_IDX_15 0x000024bc +#define RCVDBDI_HWDIAG 0x000024c0 +/* 0x24c4 --> 0x2800 unused */ + +/* Receive Data Completion Control */ +#define RCVDCC_MODE 0x00002800 +#define RCVDCC_MODE_RESET 0x00000001 +#define RCVDCC_MODE_ENABLE 0x00000002 +#define RCVDCC_MODE_ATTN_ENABLE 0x00000004 +/* 0x2804 --> 0x2c00 unused */ + +/* Receive BD Initiator Control Registers */ +#define RCVBDI_MODE 0x00002c00 +#define RCVBDI_MODE_RESET 0x00000001 +#define RCVBDI_MODE_ENABLE 0x00000002 +#define RCVBDI_MODE_RCB_ATTN_ENAB 0x00000004 +#define RCVBDI_STATUS 0x00002c04 +#define RCVBDI_STATUS_RCB_ATTN 0x00000004 +#define RCVBDI_JUMBO_PROD_IDX 0x00002c08 +#define RCVBDI_STD_PROD_IDX 0x00002c0c +#define RCVBDI_MINI_PROD_IDX 0x00002c10 +#define RCVBDI_MINI_THRESH 0x00002c14 +#define RCVBDI_STD_THRESH 0x00002c18 +#define RCVBDI_JUMBO_THRESH 0x00002c1c +/* 0x2c20 --> 0x2d00 unused */ + +#define STD_REPLENISH_LWM 0x00002d00 +#define JMB_REPLENISH_LWM 0x00002d04 +/* 0x2d08 --> 0x3000 unused */ + +/* Receive BD Completion Control Registers */ +#define RCVCC_MODE 0x00003000 +#define RCVCC_MODE_RESET 0x00000001 +#define RCVCC_MODE_ENABLE 0x00000002 +#define RCVCC_MODE_ATTN_ENABLE 0x00000004 +#define RCVCC_STATUS 0x00003004 +#define RCVCC_STATUS_ERROR_ATTN 0x00000004 +#define RCVCC_JUMP_PROD_IDX 0x00003008 +#define RCVCC_STD_PROD_IDX 0x0000300c +#define RCVCC_MINI_PROD_IDX 0x00003010 +/* 0x3014 --> 0x3400 unused */ + +/* Receive list selector control registers */ +#define RCVLSC_MODE 0x00003400 +#define RCVLSC_MODE_RESET 0x00000001 +#define RCVLSC_MODE_ENABLE 0x00000002 +#define RCVLSC_MODE_ATTN_ENABLE 0x00000004 +#define RCVLSC_STATUS 0x00003404 +#define RCVLSC_STATUS_ERROR_ATTN 0x00000004 +/* 0x3408 --> 0x3600 unused */ + +#define TG3_CPMU_DRV_STATUS 0x0000344c + +/* CPMU registers */ +#define TG3_CPMU_CTRL 0x00003600 +#define CPMU_CTRL_LINK_IDLE_MODE 0x00000200 +#define CPMU_CTRL_LINK_AWARE_MODE 0x00000400 +#define CPMU_CTRL_LINK_SPEED_MODE 0x00004000 +#define CPMU_CTRL_GPHY_10MB_RXONLY 0x00010000 +#define TG3_CPMU_LSPD_10MB_CLK 0x00003604 +#define CPMU_LSPD_10MB_MACCLK_MASK 0x001f0000 +#define CPMU_LSPD_10MB_MACCLK_6_25 0x00130000 +/* 0x3608 --> 0x360c unused */ + +#define TG3_CPMU_LSPD_1000MB_CLK 0x0000360c +#define CPMU_LSPD_1000MB_MACCLK_62_5 0x00000000 +#define CPMU_LSPD_1000MB_MACCLK_12_5 0x00110000 +#define CPMU_LSPD_1000MB_MACCLK_MASK 0x001f0000 +#define TG3_CPMU_LNK_AWARE_PWRMD 0x00003610 +#define CPMU_LNK_AWARE_MACCLK_MASK 0x001f0000 +#define CPMU_LNK_AWARE_MACCLK_6_25 0x00130000 +/* 0x3614 --> 0x361c unused */ + +#define TG3_CPMU_HST_ACC 0x0000361c +#define CPMU_HST_ACC_MACCLK_MASK 0x001f0000 +#define CPMU_HST_ACC_MACCLK_6_25 0x00130000 +/* 0x3620 --> 0x3630 unused */ + +#define TG3_CPMU_CLCK_ORIDE 0x00003624 +#define CPMU_CLCK_ORIDE_MAC_ORIDE_EN 0x80000000 + +#define TG3_CPMU_CLCK_ORIDE_ENABLE 0x00003628 +#define TG3_CPMU_MAC_ORIDE_ENABLE (1 << 13) + +#define TG3_CPMU_STATUS 0x0000362c +#define TG3_CPMU_STATUS_FMSK_5717 0x20000000 +#define TG3_CPMU_STATUS_FMSK_5719 0xc0000000 +#define TG3_CPMU_STATUS_FSHFT_5719 30 +#define TG3_CPMU_STATUS_LINK_MASK 0x180000 + +#define TG3_CPMU_CLCK_STAT 0x00003630 +#define CPMU_CLCK_STAT_MAC_CLCK_MASK 0x001f0000 +#define CPMU_CLCK_STAT_MAC_CLCK_62_5 0x00000000 +#define CPMU_CLCK_STAT_MAC_CLCK_12_5 0x00110000 +#define CPMU_CLCK_STAT_MAC_CLCK_6_25 0x00130000 +/* 0x3634 --> 0x365c unused */ + +#define TG3_CPMU_MUTEX_REQ 0x0000365c +#define CPMU_MUTEX_REQ_DRIVER 0x00001000 +#define TG3_CPMU_MUTEX_GNT 0x00003660 +#define CPMU_MUTEX_GNT_DRIVER 0x00001000 +#define TG3_CPMU_PHY_STRAP 0x00003664 +#define TG3_CPMU_PHY_STRAP_IS_SERDES 0x00000020 +#define TG3_CPMU_PADRNG_CTL 0x00003668 +#define TG3_CPMU_PADRNG_CTL_RDIV2 0x00040000 +/* 0x3664 --> 0x36b0 unused */ + +#define TG3_CPMU_EEE_MODE 0x000036b0 +#define TG3_CPMU_EEEMD_APE_TX_DET_EN 0x00000004 +#define TG3_CPMU_EEEMD_ERLY_L1_XIT_DET 0x00000008 +#define TG3_CPMU_EEEMD_SND_IDX_DET_EN 0x00000040 +#define TG3_CPMU_EEEMD_LPI_ENABLE 0x00000080 +#define TG3_CPMU_EEEMD_LPI_IN_TX 0x00000100 +#define TG3_CPMU_EEEMD_LPI_IN_RX 0x00000200 +#define TG3_CPMU_EEEMD_EEE_ENABLE 0x00100000 +#define TG3_CPMU_EEE_DBTMR1 0x000036b4 +#define TG3_CPMU_DBTMR1_PCIEXIT_2047US 0x07ff0000 +#define TG3_CPMU_DBTMR1_LNKIDLE_2047US 0x000007ff +#define TG3_CPMU_DBTMR1_LNKIDLE_MAX 0x0000ffff +#define TG3_CPMU_EEE_DBTMR2 0x000036b8 +#define TG3_CPMU_DBTMR2_APE_TX_2047US 0x07ff0000 +#define TG3_CPMU_DBTMR2_TXIDXEQ_2047US 0x000007ff +#define TG3_CPMU_EEE_LNKIDL_CTRL 0x000036bc +#define TG3_CPMU_EEE_LNKIDL_PCIE_NL0 0x01000000 +#define TG3_CPMU_EEE_LNKIDL_UART_IDL 0x00000004 +#define TG3_CPMU_EEE_LNKIDL_APE_TX_MT 0x00000002 +/* 0x36c0 --> 0x36d0 unused */ + +#define TG3_CPMU_EEE_CTRL 0x000036d0 +#define TG3_CPMU_EEE_CTRL_EXIT_16_5_US 0x0000019d +#define TG3_CPMU_EEE_CTRL_EXIT_36_US 0x00000384 +#define TG3_CPMU_EEE_CTRL_EXIT_20_1_US 0x000001f8 +/* 0x36d4 --> 0x3800 unused */ + +/* Mbuf cluster free registers */ +#define MBFREE_MODE 0x00003800 +#define MBFREE_MODE_RESET 0x00000001 +#define MBFREE_MODE_ENABLE 0x00000002 +#define MBFREE_STATUS 0x00003804 +/* 0x3808 --> 0x3c00 unused */ + +/* Host coalescing control registers */ +#define HOSTCC_MODE 0x00003c00 +#define HOSTCC_MODE_RESET 0x00000001 +#define HOSTCC_MODE_ENABLE 0x00000002 +#define HOSTCC_MODE_ATTN 0x00000004 +#define HOSTCC_MODE_NOW 0x00000008 +#define HOSTCC_MODE_FULL_STATUS 0x00000000 +#define HOSTCC_MODE_64BYTE 0x00000080 +#define HOSTCC_MODE_32BYTE 0x00000100 +#define HOSTCC_MODE_CLRTICK_RXBD 0x00000200 +#define HOSTCC_MODE_CLRTICK_TXBD 0x00000400 +#define HOSTCC_MODE_NOINT_ON_NOW 0x00000800 +#define HOSTCC_MODE_NOINT_ON_FORCE 0x00001000 +#define HOSTCC_MODE_COAL_VEC1_NOW 0x00002000 +#define HOSTCC_STATUS 0x00003c04 +#define HOSTCC_STATUS_ERROR_ATTN 0x00000004 +#define HOSTCC_RXCOL_TICKS 0x00003c08 +#define LOW_RXCOL_TICKS 0x00000032 +#define LOW_RXCOL_TICKS_CLRTCKS 0x00000014 +#define DEFAULT_RXCOL_TICKS 0x00000048 +#define HIGH_RXCOL_TICKS 0x00000096 +#define MAX_RXCOL_TICKS 0x000003ff +#define HOSTCC_TXCOL_TICKS 0x00003c0c +#define LOW_TXCOL_TICKS 0x00000096 +#define LOW_TXCOL_TICKS_CLRTCKS 0x00000048 +#define DEFAULT_TXCOL_TICKS 0x0000012c +#define HIGH_TXCOL_TICKS 0x00000145 +#define MAX_TXCOL_TICKS 0x000003ff +#define HOSTCC_RXMAX_FRAMES 0x00003c10 +#define LOW_RXMAX_FRAMES 0x00000005 +#define DEFAULT_RXMAX_FRAMES 0x00000008 +#define HIGH_RXMAX_FRAMES 0x00000012 +#define MAX_RXMAX_FRAMES 0x000000ff +#define HOSTCC_TXMAX_FRAMES 0x00003c14 +#define LOW_TXMAX_FRAMES 0x00000035 +#define DEFAULT_TXMAX_FRAMES 0x0000004b +#define HIGH_TXMAX_FRAMES 0x00000052 +#define MAX_TXMAX_FRAMES 0x000000ff +#define HOSTCC_RXCOAL_TICK_INT 0x00003c18 +#define DEFAULT_RXCOAL_TICK_INT 0x00000019 +#define DEFAULT_RXCOAL_TICK_INT_CLRTCKS 0x00000014 +#define MAX_RXCOAL_TICK_INT 0x000003ff +#define HOSTCC_TXCOAL_TICK_INT 0x00003c1c +#define DEFAULT_TXCOAL_TICK_INT 0x00000019 +#define DEFAULT_TXCOAL_TICK_INT_CLRTCKS 0x00000014 +#define MAX_TXCOAL_TICK_INT 0x000003ff +#define HOSTCC_RXCOAL_MAXF_INT 0x00003c20 +#define DEFAULT_RXCOAL_MAXF_INT 0x00000005 +#define MAX_RXCOAL_MAXF_INT 0x000000ff +#define HOSTCC_TXCOAL_MAXF_INT 0x00003c24 +#define DEFAULT_TXCOAL_MAXF_INT 0x00000005 +#define MAX_TXCOAL_MAXF_INT 0x000000ff +#define HOSTCC_STAT_COAL_TICKS 0x00003c28 +#define DEFAULT_STAT_COAL_TICKS 0x000f4240 +#define MAX_STAT_COAL_TICKS 0xd693d400 +#define MIN_STAT_COAL_TICKS 0x00000064 +/* 0x3c2c --> 0x3c30 unused */ +#define HOSTCC_STATS_BLK_HOST_ADDR 0x00003c30 /* 64-bit */ +#define HOSTCC_STATUS_BLK_HOST_ADDR 0x00003c38 /* 64-bit */ +#define HOSTCC_STATS_BLK_NIC_ADDR 0x00003c40 +#define HOSTCC_STATUS_BLK_NIC_ADDR 0x00003c44 +#define HOSTCC_FLOW_ATTN 0x00003c48 +#define HOSTCC_FLOW_ATTN_MBUF_LWM 0x00000040 +/* 0x3c4c --> 0x3c50 unused */ +#define HOSTCC_JUMBO_CON_IDX 0x00003c50 +#define HOSTCC_STD_CON_IDX 0x00003c54 +#define HOSTCC_MINI_CON_IDX 0x00003c58 +/* 0x3c5c --> 0x3c80 unused */ +#define HOSTCC_RET_PROD_IDX_0 0x00003c80 +#define HOSTCC_RET_PROD_IDX_1 0x00003c84 +#define HOSTCC_RET_PROD_IDX_2 0x00003c88 +#define HOSTCC_RET_PROD_IDX_3 0x00003c8c +#define HOSTCC_RET_PROD_IDX_4 0x00003c90 +#define HOSTCC_RET_PROD_IDX_5 0x00003c94 +#define HOSTCC_RET_PROD_IDX_6 0x00003c98 +#define HOSTCC_RET_PROD_IDX_7 0x00003c9c +#define HOSTCC_RET_PROD_IDX_8 0x00003ca0 +#define HOSTCC_RET_PROD_IDX_9 0x00003ca4 +#define HOSTCC_RET_PROD_IDX_10 0x00003ca8 +#define HOSTCC_RET_PROD_IDX_11 0x00003cac +#define HOSTCC_RET_PROD_IDX_12 0x00003cb0 +#define HOSTCC_RET_PROD_IDX_13 0x00003cb4 +#define HOSTCC_RET_PROD_IDX_14 0x00003cb8 +#define HOSTCC_RET_PROD_IDX_15 0x00003cbc +#define HOSTCC_SND_CON_IDX_0 0x00003cc0 +#define HOSTCC_SND_CON_IDX_1 0x00003cc4 +#define HOSTCC_SND_CON_IDX_2 0x00003cc8 +#define HOSTCC_SND_CON_IDX_3 0x00003ccc +#define HOSTCC_SND_CON_IDX_4 0x00003cd0 +#define HOSTCC_SND_CON_IDX_5 0x00003cd4 +#define HOSTCC_SND_CON_IDX_6 0x00003cd8 +#define HOSTCC_SND_CON_IDX_7 0x00003cdc +#define HOSTCC_SND_CON_IDX_8 0x00003ce0 +#define HOSTCC_SND_CON_IDX_9 0x00003ce4 +#define HOSTCC_SND_CON_IDX_10 0x00003ce8 +#define HOSTCC_SND_CON_IDX_11 0x00003cec +#define HOSTCC_SND_CON_IDX_12 0x00003cf0 +#define HOSTCC_SND_CON_IDX_13 0x00003cf4 +#define HOSTCC_SND_CON_IDX_14 0x00003cf8 +#define HOSTCC_SND_CON_IDX_15 0x00003cfc +#define HOSTCC_STATBLCK_RING1 0x00003d00 +/* 0x3d00 --> 0x3d80 unused */ + +#define HOSTCC_RXCOL_TICKS_VEC1 0x00003d80 +#define HOSTCC_TXCOL_TICKS_VEC1 0x00003d84 +#define HOSTCC_RXMAX_FRAMES_VEC1 0x00003d88 +#define HOSTCC_TXMAX_FRAMES_VEC1 0x00003d8c +#define HOSTCC_RXCOAL_MAXF_INT_VEC1 0x00003d90 +#define HOSTCC_TXCOAL_MAXF_INT_VEC1 0x00003d94 +/* 0x3d98 --> 0x4000 unused */ + +/* Memory arbiter control registers */ +#define MEMARB_MODE 0x00004000 +#define MEMARB_MODE_RESET 0x00000001 +#define MEMARB_MODE_ENABLE 0x00000002 +#define MEMARB_STATUS 0x00004004 +#define MEMARB_TRAP_ADDR_LOW 0x00004008 +#define MEMARB_TRAP_ADDR_HIGH 0x0000400c +/* 0x4010 --> 0x4400 unused */ + +/* Buffer manager control registers */ +#define BUFMGR_MODE 0x00004400 +#define BUFMGR_MODE_RESET 0x00000001 +#define BUFMGR_MODE_ENABLE 0x00000002 +#define BUFMGR_MODE_ATTN_ENABLE 0x00000004 +#define BUFMGR_MODE_BM_TEST 0x00000008 +#define BUFMGR_MODE_MBLOW_ATTN_ENAB 0x00000010 +#define BUFMGR_MODE_NO_TX_UNDERRUN 0x80000000 +#define BUFMGR_STATUS 0x00004404 +#define BUFMGR_STATUS_ERROR 0x00000004 +#define BUFMGR_STATUS_MBLOW 0x00000010 +#define BUFMGR_MB_POOL_ADDR 0x00004408 +#define BUFMGR_MB_POOL_SIZE 0x0000440c +#define BUFMGR_MB_RDMA_LOW_WATER 0x00004410 +#define DEFAULT_MB_RDMA_LOW_WATER 0x00000050 +#define DEFAULT_MB_RDMA_LOW_WATER_5705 0x00000000 +#define DEFAULT_MB_RDMA_LOW_WATER_JUMBO 0x00000130 +#define DEFAULT_MB_RDMA_LOW_WATER_JUMBO_5780 0x00000000 +#define BUFMGR_MB_MACRX_LOW_WATER 0x00004414 +#define DEFAULT_MB_MACRX_LOW_WATER 0x00000020 +#define DEFAULT_MB_MACRX_LOW_WATER_5705 0x00000010 +#define DEFAULT_MB_MACRX_LOW_WATER_5906 0x00000004 +#define DEFAULT_MB_MACRX_LOW_WATER_57765 0x0000002a +#define DEFAULT_MB_MACRX_LOW_WATER_JUMBO 0x00000098 +#define DEFAULT_MB_MACRX_LOW_WATER_JUMBO_5780 0x0000004b +#define DEFAULT_MB_MACRX_LOW_WATER_JUMBO_57765 0x0000007e +#define BUFMGR_MB_HIGH_WATER 0x00004418 +#define DEFAULT_MB_HIGH_WATER 0x00000060 +#define DEFAULT_MB_HIGH_WATER_5705 0x00000060 +#define DEFAULT_MB_HIGH_WATER_5906 0x00000010 +#define DEFAULT_MB_HIGH_WATER_57765 0x000000a0 +#define DEFAULT_MB_HIGH_WATER_JUMBO 0x0000017c +#define DEFAULT_MB_HIGH_WATER_JUMBO_5780 0x00000096 +#define DEFAULT_MB_HIGH_WATER_JUMBO_57765 0x000000ea +#define BUFMGR_RX_MB_ALLOC_REQ 0x0000441c +#define BUFMGR_MB_ALLOC_BIT 0x10000000 +#define BUFMGR_RX_MB_ALLOC_RESP 0x00004420 +#define BUFMGR_TX_MB_ALLOC_REQ 0x00004424 +#define BUFMGR_TX_MB_ALLOC_RESP 0x00004428 +#define BUFMGR_DMA_DESC_POOL_ADDR 0x0000442c +#define BUFMGR_DMA_DESC_POOL_SIZE 0x00004430 +#define BUFMGR_DMA_LOW_WATER 0x00004434 +#define DEFAULT_DMA_LOW_WATER 0x00000005 +#define BUFMGR_DMA_HIGH_WATER 0x00004438 +#define DEFAULT_DMA_HIGH_WATER 0x0000000a +#define BUFMGR_RX_DMA_ALLOC_REQ 0x0000443c +#define BUFMGR_RX_DMA_ALLOC_RESP 0x00004440 +#define BUFMGR_TX_DMA_ALLOC_REQ 0x00004444 +#define BUFMGR_TX_DMA_ALLOC_RESP 0x00004448 +#define BUFMGR_HWDIAG_0 0x0000444c +#define BUFMGR_HWDIAG_1 0x00004450 +#define BUFMGR_HWDIAG_2 0x00004454 +/* 0x4458 --> 0x4800 unused */ + +/* Read DMA control registers */ +#define RDMAC_MODE 0x00004800 +#define RDMAC_MODE_RESET 0x00000001 +#define RDMAC_MODE_ENABLE 0x00000002 +#define RDMAC_MODE_TGTABORT_ENAB 0x00000004 +#define RDMAC_MODE_MSTABORT_ENAB 0x00000008 +#define RDMAC_MODE_PARITYERR_ENAB 0x00000010 +#define RDMAC_MODE_ADDROFLOW_ENAB 0x00000020 +#define RDMAC_MODE_FIFOOFLOW_ENAB 0x00000040 +#define RDMAC_MODE_FIFOURUN_ENAB 0x00000080 +#define RDMAC_MODE_FIFOOREAD_ENAB 0x00000100 +#define RDMAC_MODE_LNGREAD_ENAB 0x00000200 +#define RDMAC_MODE_SPLIT_ENABLE 0x00000800 +#define RDMAC_MODE_BD_SBD_CRPT_ENAB 0x00000800 +#define RDMAC_MODE_SPLIT_RESET 0x00001000 +#define RDMAC_MODE_MBUF_RBD_CRPT_ENAB 0x00001000 +#define RDMAC_MODE_MBUF_SBD_CRPT_ENAB 0x00002000 +#define RDMAC_MODE_FIFO_SIZE_128 0x00020000 +#define RDMAC_MODE_FIFO_LONG_BURST 0x00030000 +#define RDMAC_MODE_JMB_2K_MMRR 0x00800000 +#define RDMAC_MODE_MULT_DMA_RD_DIS 0x01000000 +#define RDMAC_MODE_IPV4_LSO_EN 0x08000000 +#define RDMAC_MODE_IPV6_LSO_EN 0x10000000 +#define RDMAC_MODE_H2BNC_VLAN_DET 0x20000000 +#define RDMAC_STATUS 0x00004804 +#define RDMAC_STATUS_TGTABORT 0x00000004 +#define RDMAC_STATUS_MSTABORT 0x00000008 +#define RDMAC_STATUS_PARITYERR 0x00000010 +#define RDMAC_STATUS_ADDROFLOW 0x00000020 +#define RDMAC_STATUS_FIFOOFLOW 0x00000040 +#define RDMAC_STATUS_FIFOURUN 0x00000080 +#define RDMAC_STATUS_FIFOOREAD 0x00000100 +#define RDMAC_STATUS_LNGREAD 0x00000200 +/* 0x4808 --> 0x4890 unused */ + +#define TG3_RDMA_RSRVCTRL_REG2 0x00004890 +#define TG3_LSO_RD_DMA_CRPTEN_CTRL2 0x000048a0 + +#define TG3_RDMA_RSRVCTRL_REG 0x00004900 +#define TG3_RDMA_RSRVCTRL_FIFO_OFLW_FIX 0x00000004 +#define TG3_RDMA_RSRVCTRL_FIFO_LWM_1_5K 0x00000c00 +#define TG3_RDMA_RSRVCTRL_FIFO_LWM_MASK 0x00000ff0 +#define TG3_RDMA_RSRVCTRL_FIFO_HWM_1_5K 0x000c0000 +#define TG3_RDMA_RSRVCTRL_FIFO_HWM_MASK 0x000ff000 +#define TG3_RDMA_RSRVCTRL_TXMRGN_320B 0x28000000 +#define TG3_RDMA_RSRVCTRL_TXMRGN_MASK 0xffe00000 +/* 0x4904 --> 0x4910 unused */ + +#define TG3_LSO_RD_DMA_CRPTEN_CTRL 0x00004910 +#define TG3_LSO_RD_DMA_CRPTEN_CTRL_BLEN_BD_4K 0x00030000 +#define TG3_LSO_RD_DMA_CRPTEN_CTRL_BLEN_LSO_4K 0x000c0000 +#define TG3_LSO_RD_DMA_TX_LENGTH_WA_5719 0x02000000 +#define TG3_LSO_RD_DMA_TX_LENGTH_WA_5720 0x00200000 +/* 0x4914 --> 0x4be0 unused */ + +#define TG3_NUM_RDMA_CHANNELS 4 +#define TG3_RDMA_LENGTH 0x00004be0 + +/* Write DMA control registers */ +#define WDMAC_MODE 0x00004c00 +#define WDMAC_MODE_RESET 0x00000001 +#define WDMAC_MODE_ENABLE 0x00000002 +#define WDMAC_MODE_TGTABORT_ENAB 0x00000004 +#define WDMAC_MODE_MSTABORT_ENAB 0x00000008 +#define WDMAC_MODE_PARITYERR_ENAB 0x00000010 +#define WDMAC_MODE_ADDROFLOW_ENAB 0x00000020 +#define WDMAC_MODE_FIFOOFLOW_ENAB 0x00000040 +#define WDMAC_MODE_FIFOURUN_ENAB 0x00000080 +#define WDMAC_MODE_FIFOOREAD_ENAB 0x00000100 +#define WDMAC_MODE_LNGREAD_ENAB 0x00000200 +#define WDMAC_MODE_RX_ACCEL 0x00000400 +#define WDMAC_MODE_STATUS_TAG_FIX 0x20000000 +#define WDMAC_MODE_BURST_ALL_DATA 0xc0000000 +#define WDMAC_STATUS 0x00004c04 +#define WDMAC_STATUS_TGTABORT 0x00000004 +#define WDMAC_STATUS_MSTABORT 0x00000008 +#define WDMAC_STATUS_PARITYERR 0x00000010 +#define WDMAC_STATUS_ADDROFLOW 0x00000020 +#define WDMAC_STATUS_FIFOOFLOW 0x00000040 +#define WDMAC_STATUS_FIFOURUN 0x00000080 +#define WDMAC_STATUS_FIFOOREAD 0x00000100 +#define WDMAC_STATUS_LNGREAD 0x00000200 +/* 0x4c08 --> 0x5000 unused */ + +/* Per-cpu register offsets (arm9) */ +#define CPU_MODE 0x00000000 +#define CPU_MODE_RESET 0x00000001 +#define CPU_MODE_HALT 0x00000400 +#define CPU_STATE 0x00000004 +#define CPU_EVTMASK 0x00000008 +/* 0xc --> 0x1c reserved */ +#define CPU_PC 0x0000001c +#define CPU_INSN 0x00000020 +#define CPU_SPAD_UFLOW 0x00000024 +#define CPU_WDOG_CLEAR 0x00000028 +#define CPU_WDOG_VECTOR 0x0000002c +#define CPU_WDOG_PC 0x00000030 +#define CPU_HW_BP 0x00000034 +/* 0x38 --> 0x44 unused */ +#define CPU_WDOG_SAVED_STATE 0x00000044 +#define CPU_LAST_BRANCH_ADDR 0x00000048 +#define CPU_SPAD_UFLOW_SET 0x0000004c +/* 0x50 --> 0x200 unused */ +#define CPU_R0 0x00000200 +#define CPU_R1 0x00000204 +#define CPU_R2 0x00000208 +#define CPU_R3 0x0000020c +#define CPU_R4 0x00000210 +#define CPU_R5 0x00000214 +#define CPU_R6 0x00000218 +#define CPU_R7 0x0000021c +#define CPU_R8 0x00000220 +#define CPU_R9 0x00000224 +#define CPU_R10 0x00000228 +#define CPU_R11 0x0000022c +#define CPU_R12 0x00000230 +#define CPU_R13 0x00000234 +#define CPU_R14 0x00000238 +#define CPU_R15 0x0000023c +#define CPU_R16 0x00000240 +#define CPU_R17 0x00000244 +#define CPU_R18 0x00000248 +#define CPU_R19 0x0000024c +#define CPU_R20 0x00000250 +#define CPU_R21 0x00000254 +#define CPU_R22 0x00000258 +#define CPU_R23 0x0000025c +#define CPU_R24 0x00000260 +#define CPU_R25 0x00000264 +#define CPU_R26 0x00000268 +#define CPU_R27 0x0000026c +#define CPU_R28 0x00000270 +#define CPU_R29 0x00000274 +#define CPU_R30 0x00000278 +#define CPU_R31 0x0000027c +/* 0x280 --> 0x400 unused */ + +#define RX_CPU_BASE 0x00005000 +#define RX_CPU_MODE 0x00005000 +#define RX_CPU_STATE 0x00005004 +#define RX_CPU_PGMCTR 0x0000501c +#define RX_CPU_HWBKPT 0x00005034 +#define TX_CPU_BASE 0x00005400 +#define TX_CPU_MODE 0x00005400 +#define TX_CPU_STATE 0x00005404 +#define TX_CPU_PGMCTR 0x0000541c + +#define VCPU_STATUS 0x00005100 +#define VCPU_STATUS_INIT_DONE 0x04000000 +#define VCPU_STATUS_DRV_RESET 0x08000000 + +#define VCPU_CFGSHDW 0x00005104 +#define VCPU_CFGSHDW_WOL_ENABLE 0x00000001 +#define VCPU_CFGSHDW_WOL_MAGPKT 0x00000004 +#define VCPU_CFGSHDW_ASPM_DBNC 0x00001000 + +/* Mailboxes */ +#define GRCMBOX_BASE 0x00005600 +#define GRCMBOX_INTERRUPT_0 0x00005800 /* 64-bit */ +#define GRCMBOX_INTERRUPT_1 0x00005808 /* 64-bit */ +#define GRCMBOX_INTERRUPT_2 0x00005810 /* 64-bit */ +#define GRCMBOX_INTERRUPT_3 0x00005818 /* 64-bit */ +#define GRCMBOX_GENERAL_0 0x00005820 /* 64-bit */ +#define GRCMBOX_GENERAL_1 0x00005828 /* 64-bit */ +#define GRCMBOX_GENERAL_2 0x00005830 /* 64-bit */ +#define GRCMBOX_GENERAL_3 0x00005838 /* 64-bit */ +#define GRCMBOX_GENERAL_4 0x00005840 /* 64-bit */ +#define GRCMBOX_GENERAL_5 0x00005848 /* 64-bit */ +#define GRCMBOX_GENERAL_6 0x00005850 /* 64-bit */ +#define GRCMBOX_GENERAL_7 0x00005858 /* 64-bit */ +#define GRCMBOX_RELOAD_STAT 0x00005860 /* 64-bit */ +#define GRCMBOX_RCVSTD_PROD_IDX 0x00005868 /* 64-bit */ +#define GRCMBOX_RCVJUMBO_PROD_IDX 0x00005870 /* 64-bit */ +#define GRCMBOX_RCVMINI_PROD_IDX 0x00005878 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_0 0x00005880 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_1 0x00005888 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_2 0x00005890 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_3 0x00005898 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_4 0x000058a0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_5 0x000058a8 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_6 0x000058b0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_7 0x000058b8 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_8 0x000058c0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_9 0x000058c8 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_10 0x000058d0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_11 0x000058d8 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_12 0x000058e0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_13 0x000058e8 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_14 0x000058f0 /* 64-bit */ +#define GRCMBOX_RCVRET_CON_IDX_15 0x000058f8 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_0 0x00005900 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_1 0x00005908 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_2 0x00005910 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_3 0x00005918 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_4 0x00005920 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_5 0x00005928 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_6 0x00005930 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_7 0x00005938 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_8 0x00005940 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_9 0x00005948 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_10 0x00005950 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_11 0x00005958 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_12 0x00005960 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_13 0x00005968 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_14 0x00005970 /* 64-bit */ +#define GRCMBOX_SNDHOST_PROD_IDX_15 0x00005978 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_0 0x00005980 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_1 0x00005988 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_2 0x00005990 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_3 0x00005998 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_4 0x000059a0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_5 0x000059a8 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_6 0x000059b0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_7 0x000059b8 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_8 0x000059c0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_9 0x000059c8 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_10 0x000059d0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_11 0x000059d8 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_12 0x000059e0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_13 0x000059e8 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_14 0x000059f0 /* 64-bit */ +#define GRCMBOX_SNDNIC_PROD_IDX_15 0x000059f8 /* 64-bit */ +#define GRCMBOX_HIGH_PRIO_EV_VECTOR 0x00005a00 +#define GRCMBOX_HIGH_PRIO_EV_MASK 0x00005a04 +#define GRCMBOX_LOW_PRIO_EV_VEC 0x00005a08 +#define GRCMBOX_LOW_PRIO_EV_MASK 0x00005a0c +/* 0x5a10 --> 0x5c00 */ + +/* Flow Through queues */ +#define FTQ_RESET 0x00005c00 +/* 0x5c04 --> 0x5c10 unused */ +#define FTQ_DMA_NORM_READ_CTL 0x00005c10 +#define FTQ_DMA_NORM_READ_FULL_CNT 0x00005c14 +#define FTQ_DMA_NORM_READ_FIFO_ENQDEQ 0x00005c18 +#define FTQ_DMA_NORM_READ_WRITE_PEEK 0x00005c1c +#define FTQ_DMA_HIGH_READ_CTL 0x00005c20 +#define FTQ_DMA_HIGH_READ_FULL_CNT 0x00005c24 +#define FTQ_DMA_HIGH_READ_FIFO_ENQDEQ 0x00005c28 +#define FTQ_DMA_HIGH_READ_WRITE_PEEK 0x00005c2c +#define FTQ_DMA_COMP_DISC_CTL 0x00005c30 +#define FTQ_DMA_COMP_DISC_FULL_CNT 0x00005c34 +#define FTQ_DMA_COMP_DISC_FIFO_ENQDEQ 0x00005c38 +#define FTQ_DMA_COMP_DISC_WRITE_PEEK 0x00005c3c +#define FTQ_SEND_BD_COMP_CTL 0x00005c40 +#define FTQ_SEND_BD_COMP_FULL_CNT 0x00005c44 +#define FTQ_SEND_BD_COMP_FIFO_ENQDEQ 0x00005c48 +#define FTQ_SEND_BD_COMP_WRITE_PEEK 0x00005c4c +#define FTQ_SEND_DATA_INIT_CTL 0x00005c50 +#define FTQ_SEND_DATA_INIT_FULL_CNT 0x00005c54 +#define FTQ_SEND_DATA_INIT_FIFO_ENQDEQ 0x00005c58 +#define FTQ_SEND_DATA_INIT_WRITE_PEEK 0x00005c5c +#define FTQ_DMA_NORM_WRITE_CTL 0x00005c60 +#define FTQ_DMA_NORM_WRITE_FULL_CNT 0x00005c64 +#define FTQ_DMA_NORM_WRITE_FIFO_ENQDEQ 0x00005c68 +#define FTQ_DMA_NORM_WRITE_WRITE_PEEK 0x00005c6c +#define FTQ_DMA_HIGH_WRITE_CTL 0x00005c70 +#define FTQ_DMA_HIGH_WRITE_FULL_CNT 0x00005c74 +#define FTQ_DMA_HIGH_WRITE_FIFO_ENQDEQ 0x00005c78 +#define FTQ_DMA_HIGH_WRITE_WRITE_PEEK 0x00005c7c +#define FTQ_SWTYPE1_CTL 0x00005c80 +#define FTQ_SWTYPE1_FULL_CNT 0x00005c84 +#define FTQ_SWTYPE1_FIFO_ENQDEQ 0x00005c88 +#define FTQ_SWTYPE1_WRITE_PEEK 0x00005c8c +#define FTQ_SEND_DATA_COMP_CTL 0x00005c90 +#define FTQ_SEND_DATA_COMP_FULL_CNT 0x00005c94 +#define FTQ_SEND_DATA_COMP_FIFO_ENQDEQ 0x00005c98 +#define FTQ_SEND_DATA_COMP_WRITE_PEEK 0x00005c9c +#define FTQ_HOST_COAL_CTL 0x00005ca0 +#define FTQ_HOST_COAL_FULL_CNT 0x00005ca4 +#define FTQ_HOST_COAL_FIFO_ENQDEQ 0x00005ca8 +#define FTQ_HOST_COAL_WRITE_PEEK 0x00005cac +#define FTQ_MAC_TX_CTL 0x00005cb0 +#define FTQ_MAC_TX_FULL_CNT 0x00005cb4 +#define FTQ_MAC_TX_FIFO_ENQDEQ 0x00005cb8 +#define FTQ_MAC_TX_WRITE_PEEK 0x00005cbc +#define FTQ_MB_FREE_CTL 0x00005cc0 +#define FTQ_MB_FREE_FULL_CNT 0x00005cc4 +#define FTQ_MB_FREE_FIFO_ENQDEQ 0x00005cc8 +#define FTQ_MB_FREE_WRITE_PEEK 0x00005ccc +#define FTQ_RCVBD_COMP_CTL 0x00005cd0 +#define FTQ_RCVBD_COMP_FULL_CNT 0x00005cd4 +#define FTQ_RCVBD_COMP_FIFO_ENQDEQ 0x00005cd8 +#define FTQ_RCVBD_COMP_WRITE_PEEK 0x00005cdc +#define FTQ_RCVLST_PLMT_CTL 0x00005ce0 +#define FTQ_RCVLST_PLMT_FULL_CNT 0x00005ce4 +#define FTQ_RCVLST_PLMT_FIFO_ENQDEQ 0x00005ce8 +#define FTQ_RCVLST_PLMT_WRITE_PEEK 0x00005cec +#define FTQ_RCVDATA_INI_CTL 0x00005cf0 +#define FTQ_RCVDATA_INI_FULL_CNT 0x00005cf4 +#define FTQ_RCVDATA_INI_FIFO_ENQDEQ 0x00005cf8 +#define FTQ_RCVDATA_INI_WRITE_PEEK 0x00005cfc +#define FTQ_RCVDATA_COMP_CTL 0x00005d00 +#define FTQ_RCVDATA_COMP_FULL_CNT 0x00005d04 +#define FTQ_RCVDATA_COMP_FIFO_ENQDEQ 0x00005d08 +#define FTQ_RCVDATA_COMP_WRITE_PEEK 0x00005d0c +#define FTQ_SWTYPE2_CTL 0x00005d10 +#define FTQ_SWTYPE2_FULL_CNT 0x00005d14 +#define FTQ_SWTYPE2_FIFO_ENQDEQ 0x00005d18 +#define FTQ_SWTYPE2_WRITE_PEEK 0x00005d1c +/* 0x5d20 --> 0x6000 unused */ + +/* Message signaled interrupt registers */ +#define MSGINT_MODE 0x00006000 +#define MSGINT_MODE_RESET 0x00000001 +#define MSGINT_MODE_ENABLE 0x00000002 +#define MSGINT_MODE_ONE_SHOT_DISABLE 0x00000020 +#define MSGINT_MODE_MULTIVEC_EN 0x00000080 +#define MSGINT_STATUS 0x00006004 +#define MSGINT_STATUS_MSI_REQ 0x00000001 +#define MSGINT_FIFO 0x00006008 +/* 0x600c --> 0x6400 unused */ + +/* DMA completion registers */ +#define DMAC_MODE 0x00006400 +#define DMAC_MODE_RESET 0x00000001 +#define DMAC_MODE_ENABLE 0x00000002 +/* 0x6404 --> 0x6800 unused */ + +/* GRC registers */ +#define GRC_MODE 0x00006800 +#define GRC_MODE_UPD_ON_COAL 0x00000001 +#define GRC_MODE_BSWAP_NONFRM_DATA 0x00000002 +#define GRC_MODE_WSWAP_NONFRM_DATA 0x00000004 +#define GRC_MODE_BSWAP_DATA 0x00000010 +#define GRC_MODE_WSWAP_DATA 0x00000020 +#define GRC_MODE_BYTE_SWAP_B2HRX_DATA 0x00000040 +#define GRC_MODE_WORD_SWAP_B2HRX_DATA 0x00000080 +#define GRC_MODE_SPLITHDR 0x00000100 +#define GRC_MODE_NOFRM_CRACKING 0x00000200 +#define GRC_MODE_INCL_CRC 0x00000400 +#define GRC_MODE_ALLOW_BAD_FRMS 0x00000800 +#define GRC_MODE_NOIRQ_ON_SENDS 0x00002000 +#define GRC_MODE_NOIRQ_ON_RCV 0x00004000 +#define GRC_MODE_FORCE_PCI32BIT 0x00008000 +#define GRC_MODE_B2HRX_ENABLE 0x00008000 +#define GRC_MODE_HOST_STACKUP 0x00010000 +#define GRC_MODE_HOST_SENDBDS 0x00020000 +#define GRC_MODE_HTX2B_ENABLE 0x00040000 +#define GRC_MODE_TIME_SYNC_ENABLE 0x00080000 +#define GRC_MODE_NO_TX_PHDR_CSUM 0x00100000 +#define GRC_MODE_NVRAM_WR_ENABLE 0x00200000 +#define GRC_MODE_PCIE_TL_SEL 0x00000000 +#define GRC_MODE_PCIE_PL_SEL 0x00400000 +#define GRC_MODE_NO_RX_PHDR_CSUM 0x00800000 +#define GRC_MODE_IRQ_ON_TX_CPU_ATTN 0x01000000 +#define GRC_MODE_IRQ_ON_RX_CPU_ATTN 0x02000000 +#define GRC_MODE_IRQ_ON_MAC_ATTN 0x04000000 +#define GRC_MODE_IRQ_ON_DMA_ATTN 0x08000000 +#define GRC_MODE_IRQ_ON_FLOW_ATTN 0x10000000 +#define GRC_MODE_4X_NIC_SEND_RINGS 0x20000000 +#define GRC_MODE_PCIE_DL_SEL 0x20000000 +#define GRC_MODE_MCAST_FRM_ENABLE 0x40000000 +#define GRC_MODE_PCIE_HI_1K_EN 0x80000000 +#define GRC_MODE_PCIE_PORT_MASK (GRC_MODE_PCIE_TL_SEL | \ + GRC_MODE_PCIE_PL_SEL | \ + GRC_MODE_PCIE_DL_SEL | \ + GRC_MODE_PCIE_HI_1K_EN) +#define GRC_MISC_CFG 0x00006804 +#define GRC_MISC_CFG_CORECLK_RESET 0x00000001 +#define GRC_MISC_CFG_PRESCALAR_MASK 0x000000fe +#define GRC_MISC_CFG_PRESCALAR_SHIFT 1 +#define GRC_MISC_CFG_BOARD_ID_MASK 0x0001e000 +#define GRC_MISC_CFG_BOARD_ID_5700 0x0001e000 +#define GRC_MISC_CFG_BOARD_ID_5701 0x00000000 +#define GRC_MISC_CFG_BOARD_ID_5702FE 0x00004000 +#define GRC_MISC_CFG_BOARD_ID_5703 0x00000000 +#define GRC_MISC_CFG_BOARD_ID_5703S 0x00002000 +#define GRC_MISC_CFG_BOARD_ID_5704 0x00000000 +#define GRC_MISC_CFG_BOARD_ID_5704CIOBE 0x00004000 +#define GRC_MISC_CFG_BOARD_ID_5704_A2 0x00008000 +#define GRC_MISC_CFG_BOARD_ID_5788 0x00010000 +#define GRC_MISC_CFG_BOARD_ID_5788M 0x00018000 +#define GRC_MISC_CFG_BOARD_ID_AC91002A1 0x00018000 +#define GRC_MISC_CFG_EPHY_IDDQ 0x00200000 +#define GRC_MISC_CFG_KEEP_GPHY_POWER 0x04000000 +#define GRC_LOCAL_CTRL 0x00006808 +#define GRC_LCLCTRL_INT_ACTIVE 0x00000001 +#define GRC_LCLCTRL_CLEARINT 0x00000002 +#define GRC_LCLCTRL_SETINT 0x00000004 +#define GRC_LCLCTRL_INT_ON_ATTN 0x00000008 +#define GRC_LCLCTRL_GPIO_UART_SEL 0x00000010 /* 5755 only */ +#define GRC_LCLCTRL_USE_SIG_DETECT 0x00000010 /* 5714/5780 only */ +#define GRC_LCLCTRL_USE_EXT_SIG_DETECT 0x00000020 /* 5714/5780 only */ +#define GRC_LCLCTRL_GPIO_INPUT3 0x00000020 +#define GRC_LCLCTRL_GPIO_OE3 0x00000040 +#define GRC_LCLCTRL_GPIO_OUTPUT3 0x00000080 +#define GRC_LCLCTRL_GPIO_INPUT0 0x00000100 +#define GRC_LCLCTRL_GPIO_INPUT1 0x00000200 +#define GRC_LCLCTRL_GPIO_INPUT2 0x00000400 +#define GRC_LCLCTRL_GPIO_OE0 0x00000800 +#define GRC_LCLCTRL_GPIO_OE1 0x00001000 +#define GRC_LCLCTRL_GPIO_OE2 0x00002000 +#define GRC_LCLCTRL_GPIO_OUTPUT0 0x00004000 +#define GRC_LCLCTRL_GPIO_OUTPUT1 0x00008000 +#define GRC_LCLCTRL_GPIO_OUTPUT2 0x00010000 +#define GRC_LCLCTRL_EXTMEM_ENABLE 0x00020000 +#define GRC_LCLCTRL_MEMSZ_MASK 0x001c0000 +#define GRC_LCLCTRL_MEMSZ_256K 0x00000000 +#define GRC_LCLCTRL_MEMSZ_512K 0x00040000 +#define GRC_LCLCTRL_MEMSZ_1M 0x00080000 +#define GRC_LCLCTRL_MEMSZ_2M 0x000c0000 +#define GRC_LCLCTRL_MEMSZ_4M 0x00100000 +#define GRC_LCLCTRL_MEMSZ_8M 0x00140000 +#define GRC_LCLCTRL_MEMSZ_16M 0x00180000 +#define GRC_LCLCTRL_BANK_SELECT 0x00200000 +#define GRC_LCLCTRL_SSRAM_TYPE 0x00400000 +#define GRC_LCLCTRL_AUTO_SEEPROM 0x01000000 +#define GRC_TIMER 0x0000680c +#define GRC_RX_CPU_EVENT 0x00006810 +#define GRC_RX_CPU_DRIVER_EVENT 0x00004000 +#define GRC_RX_TIMER_REF 0x00006814 +#define GRC_RX_CPU_SEM 0x00006818 +#define GRC_REMOTE_RX_CPU_ATTN 0x0000681c +#define GRC_TX_CPU_EVENT 0x00006820 +#define GRC_TX_TIMER_REF 0x00006824 +#define GRC_TX_CPU_SEM 0x00006828 +#define GRC_REMOTE_TX_CPU_ATTN 0x0000682c +#define GRC_MEM_POWER_UP 0x00006830 /* 64-bit */ +#define GRC_EEPROM_ADDR 0x00006838 +#define EEPROM_ADDR_WRITE 0x00000000 +#define EEPROM_ADDR_READ 0x80000000 +#define EEPROM_ADDR_COMPLETE 0x40000000 +#define EEPROM_ADDR_FSM_RESET 0x20000000 +#define EEPROM_ADDR_DEVID_MASK 0x1c000000 +#define EEPROM_ADDR_DEVID_SHIFT 26 +#define EEPROM_ADDR_START 0x02000000 +#define EEPROM_ADDR_CLKPERD_SHIFT 16 +#define EEPROM_ADDR_ADDR_MASK 0x0000ffff +#define EEPROM_ADDR_ADDR_SHIFT 0 +#define EEPROM_DEFAULT_CLOCK_PERIOD 0x60 +#define EEPROM_CHIP_SIZE (64 * 1024) +#define GRC_EEPROM_DATA 0x0000683c +#define GRC_EEPROM_CTRL 0x00006840 +#define GRC_MDI_CTRL 0x00006844 +#define GRC_SEEPROM_DELAY 0x00006848 +/* 0x684c --> 0x6890 unused */ +#define GRC_VCPU_EXT_CTRL 0x00006890 +#define GRC_VCPU_EXT_CTRL_HALT_CPU 0x00400000 +#define GRC_VCPU_EXT_CTRL_DISABLE_WOL 0x20000000 +#define GRC_FASTBOOT_PC 0x00006894 /* 5752, 5755, 5787 */ + +#define TG3_EAV_REF_CLCK_LSB 0x00006900 +#define TG3_EAV_REF_CLCK_MSB 0x00006904 +#define TG3_EAV_REF_CLCK_CTL 0x00006908 +#define TG3_EAV_REF_CLCK_CTL_STOP 0x00000002 +#define TG3_EAV_REF_CLCK_CTL_RESUME 0x00000004 +#define TG3_EAV_CTL_TSYNC_GPIO_MASK (0x3 << 16) +#define TG3_EAV_CTL_TSYNC_WDOG0 (1 << 17) + +#define TG3_EAV_WATCHDOG0_LSB 0x00006918 +#define TG3_EAV_WATCHDOG0_MSB 0x0000691c +#define TG3_EAV_WATCHDOG0_EN (1 << 31) +#define TG3_EAV_WATCHDOG_MSB_MASK 0x7fffffff + +#define TG3_EAV_REF_CLK_CORRECT_CTL 0x00006928 +#define TG3_EAV_REF_CLK_CORRECT_EN (1 << 31) +#define TG3_EAV_REF_CLK_CORRECT_NEG (1 << 30) + +#define TG3_EAV_REF_CLK_CORRECT_MASK 0xffffff + +/* 0x692c --> 0x7000 unused */ + +/* NVRAM Control registers */ +#define NVRAM_CMD 0x00007000 +#define NVRAM_CMD_RESET 0x00000001 +#define NVRAM_CMD_DONE 0x00000008 +#define NVRAM_CMD_GO 0x00000010 +#define NVRAM_CMD_WR 0x00000020 +#define NVRAM_CMD_RD 0x00000000 +#define NVRAM_CMD_ERASE 0x00000040 +#define NVRAM_CMD_FIRST 0x00000080 +#define NVRAM_CMD_LAST 0x00000100 +#define NVRAM_CMD_WREN 0x00010000 +#define NVRAM_CMD_WRDI 0x00020000 +#define NVRAM_STAT 0x00007004 +#define NVRAM_WRDATA 0x00007008 +#define NVRAM_ADDR 0x0000700c +#define NVRAM_ADDR_MSK 0x00ffffff +#define NVRAM_RDDATA 0x00007010 +#define NVRAM_CFG1 0x00007014 +#define NVRAM_CFG1_FLASHIF_ENAB 0x00000001 +#define NVRAM_CFG1_BUFFERED_MODE 0x00000002 +#define NVRAM_CFG1_PASS_THRU 0x00000004 +#define NVRAM_CFG1_STATUS_BITS 0x00000070 +#define NVRAM_CFG1_BIT_BANG 0x00000008 +#define NVRAM_CFG1_FLASH_SIZE 0x02000000 +#define NVRAM_CFG1_COMPAT_BYPASS 0x80000000 +#define NVRAM_CFG1_VENDOR_MASK 0x03000003 +#define FLASH_VENDOR_ATMEL_EEPROM 0x02000000 +#define FLASH_VENDOR_ATMEL_FLASH_BUFFERED 0x02000003 +#define FLASH_VENDOR_ATMEL_FLASH_UNBUFFERED 0x00000003 +#define FLASH_VENDOR_ST 0x03000001 +#define FLASH_VENDOR_SAIFUN 0x01000003 +#define FLASH_VENDOR_SST_SMALL 0x00000001 +#define FLASH_VENDOR_SST_LARGE 0x02000001 +#define NVRAM_CFG1_5752VENDOR_MASK 0x03c00003 +#define NVRAM_CFG1_5762VENDOR_MASK 0x03e00003 +#define FLASH_5752VENDOR_ATMEL_EEPROM_64KHZ 0x00000000 +#define FLASH_5752VENDOR_ATMEL_EEPROM_376KHZ 0x02000000 +#define FLASH_5752VENDOR_ATMEL_FLASH_BUFFERED 0x02000003 +#define FLASH_5752VENDOR_ST_M45PE10 0x02400000 +#define FLASH_5752VENDOR_ST_M45PE20 0x02400002 +#define FLASH_5752VENDOR_ST_M45PE40 0x02400001 +#define FLASH_5755VENDOR_ATMEL_FLASH_1 0x03400001 +#define FLASH_5755VENDOR_ATMEL_FLASH_2 0x03400002 +#define FLASH_5755VENDOR_ATMEL_FLASH_3 0x03400000 +#define FLASH_5755VENDOR_ATMEL_FLASH_4 0x00000003 +#define FLASH_5755VENDOR_ATMEL_FLASH_5 0x02000003 +#define FLASH_5755VENDOR_ATMEL_EEPROM_64KHZ 0x03c00003 +#define FLASH_5755VENDOR_ATMEL_EEPROM_376KHZ 0x03c00002 +#define FLASH_5787VENDOR_ATMEL_EEPROM_64KHZ 0x03000003 +#define FLASH_5787VENDOR_ATMEL_EEPROM_376KHZ 0x03000002 +#define FLASH_5787VENDOR_MICRO_EEPROM_64KHZ 0x03000000 +#define FLASH_5787VENDOR_MICRO_EEPROM_376KHZ 0x02000000 +#define FLASH_5761VENDOR_ATMEL_MDB021D 0x00800003 +#define FLASH_5761VENDOR_ATMEL_MDB041D 0x00800000 +#define FLASH_5761VENDOR_ATMEL_MDB081D 0x00800002 +#define FLASH_5761VENDOR_ATMEL_MDB161D 0x00800001 +#define FLASH_5761VENDOR_ATMEL_ADB021D 0x00000003 +#define FLASH_5761VENDOR_ATMEL_ADB041D 0x00000000 +#define FLASH_5761VENDOR_ATMEL_ADB081D 0x00000002 +#define FLASH_5761VENDOR_ATMEL_ADB161D 0x00000001 +#define FLASH_5761VENDOR_ST_M_M45PE20 0x02800001 +#define FLASH_5761VENDOR_ST_M_M45PE40 0x02800000 +#define FLASH_5761VENDOR_ST_M_M45PE80 0x02800002 +#define FLASH_5761VENDOR_ST_M_M45PE16 0x02800003 +#define FLASH_5761VENDOR_ST_A_M45PE20 0x02000001 +#define FLASH_5761VENDOR_ST_A_M45PE40 0x02000000 +#define FLASH_5761VENDOR_ST_A_M45PE80 0x02000002 +#define FLASH_5761VENDOR_ST_A_M45PE16 0x02000003 +#define FLASH_57780VENDOR_ATMEL_AT45DB011D 0x00400000 +#define FLASH_57780VENDOR_ATMEL_AT45DB011B 0x03400000 +#define FLASH_57780VENDOR_ATMEL_AT45DB021D 0x00400002 +#define FLASH_57780VENDOR_ATMEL_AT45DB021B 0x03400002 +#define FLASH_57780VENDOR_ATMEL_AT45DB041D 0x00400001 +#define FLASH_57780VENDOR_ATMEL_AT45DB041B 0x03400001 +#define FLASH_5717VENDOR_ATMEL_EEPROM 0x02000001 +#define FLASH_5717VENDOR_MICRO_EEPROM 0x02000003 +#define FLASH_5717VENDOR_ATMEL_MDB011D 0x01000001 +#define FLASH_5717VENDOR_ATMEL_MDB021D 0x01000003 +#define FLASH_5717VENDOR_ST_M_M25PE10 0x02000000 +#define FLASH_5717VENDOR_ST_M_M25PE20 0x02000002 +#define FLASH_5717VENDOR_ST_M_M45PE10 0x00000001 +#define FLASH_5717VENDOR_ST_M_M45PE20 0x00000003 +#define FLASH_5717VENDOR_ATMEL_ADB011B 0x01400000 +#define FLASH_5717VENDOR_ATMEL_ADB021B 0x01400002 +#define FLASH_5717VENDOR_ATMEL_ADB011D 0x01400001 +#define FLASH_5717VENDOR_ATMEL_ADB021D 0x01400003 +#define FLASH_5717VENDOR_ST_A_M25PE10 0x02400000 +#define FLASH_5717VENDOR_ST_A_M25PE20 0x02400002 +#define FLASH_5717VENDOR_ST_A_M45PE10 0x02400001 +#define FLASH_5717VENDOR_ST_A_M45PE20 0x02400003 +#define FLASH_5717VENDOR_ATMEL_45USPT 0x03400000 +#define FLASH_5717VENDOR_ST_25USPT 0x03400002 +#define FLASH_5717VENDOR_ST_45USPT 0x03400001 +#define FLASH_5720_EEPROM_HD 0x00000001 +#define FLASH_5720_EEPROM_LD 0x00000003 +#define FLASH_5762_EEPROM_HD 0x02000001 +#define FLASH_5762_EEPROM_LD 0x02000003 +#define FLASH_5720VENDOR_M_ATMEL_DB011D 0x01000000 +#define FLASH_5720VENDOR_M_ATMEL_DB021D 0x01000002 +#define FLASH_5720VENDOR_M_ATMEL_DB041D 0x01000001 +#define FLASH_5720VENDOR_M_ATMEL_DB081D 0x01000003 +#define FLASH_5720VENDOR_M_ST_M25PE10 0x02000000 +#define FLASH_5720VENDOR_M_ST_M25PE20 0x02000002 +#define FLASH_5720VENDOR_M_ST_M25PE40 0x02000001 +#define FLASH_5720VENDOR_M_ST_M25PE80 0x02000003 +#define FLASH_5720VENDOR_M_ST_M45PE10 0x03000000 +#define FLASH_5720VENDOR_M_ST_M45PE20 0x03000002 +#define FLASH_5720VENDOR_M_ST_M45PE40 0x03000001 +#define FLASH_5720VENDOR_M_ST_M45PE80 0x03000003 +#define FLASH_5720VENDOR_A_ATMEL_DB011B 0x01800000 +#define FLASH_5720VENDOR_A_ATMEL_DB021B 0x01800002 +#define FLASH_5720VENDOR_A_ATMEL_DB041B 0x01800001 +#define FLASH_5720VENDOR_A_ATMEL_DB011D 0x01c00000 +#define FLASH_5720VENDOR_A_ATMEL_DB021D 0x01c00002 +#define FLASH_5720VENDOR_A_ATMEL_DB041D 0x01c00001 +#define FLASH_5720VENDOR_A_ATMEL_DB081D 0x01c00003 +#define FLASH_5720VENDOR_A_ST_M25PE10 0x02800000 +#define FLASH_5720VENDOR_A_ST_M25PE20 0x02800002 +#define FLASH_5720VENDOR_A_ST_M25PE40 0x02800001 +#define FLASH_5720VENDOR_A_ST_M25PE80 0x02800003 +#define FLASH_5720VENDOR_A_ST_M45PE10 0x02c00000 +#define FLASH_5720VENDOR_A_ST_M45PE20 0x02c00002 +#define FLASH_5720VENDOR_A_ST_M45PE40 0x02c00001 +#define FLASH_5720VENDOR_A_ST_M45PE80 0x02c00003 +#define FLASH_5720VENDOR_ATMEL_45USPT 0x03c00000 +#define FLASH_5720VENDOR_ST_25USPT 0x03c00002 +#define FLASH_5720VENDOR_ST_45USPT 0x03c00001 +#define NVRAM_CFG1_5752PAGE_SIZE_MASK 0x70000000 +#define FLASH_5752PAGE_SIZE_256 0x00000000 +#define FLASH_5752PAGE_SIZE_512 0x10000000 +#define FLASH_5752PAGE_SIZE_1K 0x20000000 +#define FLASH_5752PAGE_SIZE_2K 0x30000000 +#define FLASH_5752PAGE_SIZE_4K 0x40000000 +#define FLASH_5752PAGE_SIZE_264 0x50000000 +#define FLASH_5752PAGE_SIZE_528 0x60000000 +#define NVRAM_CFG2 0x00007018 +#define NVRAM_CFG3 0x0000701c +#define NVRAM_SWARB 0x00007020 +#define SWARB_REQ_SET0 0x00000001 +#define SWARB_REQ_SET1 0x00000002 +#define SWARB_REQ_SET2 0x00000004 +#define SWARB_REQ_SET3 0x00000008 +#define SWARB_REQ_CLR0 0x00000010 +#define SWARB_REQ_CLR1 0x00000020 +#define SWARB_REQ_CLR2 0x00000040 +#define SWARB_REQ_CLR3 0x00000080 +#define SWARB_GNT0 0x00000100 +#define SWARB_GNT1 0x00000200 +#define SWARB_GNT2 0x00000400 +#define SWARB_GNT3 0x00000800 +#define SWARB_REQ0 0x00001000 +#define SWARB_REQ1 0x00002000 +#define SWARB_REQ2 0x00004000 +#define SWARB_REQ3 0x00008000 +#define NVRAM_ACCESS 0x00007024 +#define ACCESS_ENABLE 0x00000001 +#define ACCESS_WR_ENABLE 0x00000002 +#define NVRAM_WRITE1 0x00007028 +/* 0x702c unused */ + +#define NVRAM_ADDR_LOCKOUT 0x00007030 +/* 0x7034 --> 0x7500 unused */ + +#define OTP_MODE 0x00007500 +#define OTP_MODE_OTP_THRU_GRC 0x00000001 +#define OTP_CTRL 0x00007504 +#define OTP_CTRL_OTP_PROG_ENABLE 0x00200000 +#define OTP_CTRL_OTP_CMD_READ 0x00000000 +#define OTP_CTRL_OTP_CMD_INIT 0x00000008 +#define OTP_CTRL_OTP_CMD_START 0x00000001 +#define OTP_STATUS 0x00007508 +#define OTP_STATUS_CMD_DONE 0x00000001 +#define OTP_ADDRESS 0x0000750c +#define OTP_ADDRESS_MAGIC1 0x000000a0 +#define OTP_ADDRESS_MAGIC2 0x00000080 +/* 0x7510 unused */ + +#define OTP_READ_DATA 0x00007514 +/* 0x7518 --> 0x7c04 unused */ + +#define PCIE_TRANSACTION_CFG 0x00007c04 +#define PCIE_TRANS_CFG_1SHOT_MSI 0x20000000 +#define PCIE_TRANS_CFG_LOM 0x00000020 +/* 0x7c08 --> 0x7d28 unused */ + +#define PCIE_PWR_MGMT_THRESH 0x00007d28 +#define PCIE_PWR_MGMT_L1_THRESH_MSK 0x0000ff00 +#define PCIE_PWR_MGMT_L1_THRESH_4MS 0x0000ff00 +#define PCIE_PWR_MGMT_EXT_ASPM_TMR_EN 0x01000000 +/* 0x7d2c --> 0x7d54 unused */ + +#define TG3_PCIE_LNKCTL 0x00007d54 +#define TG3_PCIE_LNKCTL_L1_PLL_PD_EN 0x00000008 +#define TG3_PCIE_LNKCTL_L1_PLL_PD_DIS 0x00000080 +/* 0x7d58 --> 0x7e70 unused */ + +#define TG3_PCIE_PHY_TSTCTL 0x00007e2c +#define TG3_PCIE_PHY_TSTCTL_PCIE10 0x00000040 +#define TG3_PCIE_PHY_TSTCTL_PSCRAM 0x00000020 + +#define TG3_PCIE_EIDLE_DELAY 0x00007e70 +#define TG3_PCIE_EIDLE_DELAY_MASK 0x0000001f +#define TG3_PCIE_EIDLE_DELAY_13_CLKS 0x0000000c +/* 0x7e74 --> 0x8000 unused */ + + +/* Alternate PCIE definitions */ +#define TG3_PCIE_TLDLPL_PORT 0x00007c00 +#define TG3_PCIE_DL_LO_FTSMAX 0x0000000c +#define TG3_PCIE_DL_LO_FTSMAX_MSK 0x000000ff +#define TG3_PCIE_DL_LO_FTSMAX_VAL 0x0000002c +#define TG3_PCIE_PL_LO_PHYCTL1 0x00000004 +#define TG3_PCIE_PL_LO_PHYCTL1_L1PLLPD_EN 0x00001000 +#define TG3_PCIE_PL_LO_PHYCTL5 0x00000014 +#define TG3_PCIE_PL_LO_PHYCTL5_DIS_L2CLKREQ 0x80000000 + +#define TG3_REG_BLK_SIZE 0x00008000 + +/* OTP bit definitions */ +#define TG3_OTP_AGCTGT_MASK 0x000000e0 +#define TG3_OTP_AGCTGT_SHIFT 1 +#define TG3_OTP_HPFFLTR_MASK 0x00000300 +#define TG3_OTP_HPFFLTR_SHIFT 1 +#define TG3_OTP_HPFOVER_MASK 0x00000400 +#define TG3_OTP_HPFOVER_SHIFT 1 +#define TG3_OTP_LPFDIS_MASK 0x00000800 +#define TG3_OTP_LPFDIS_SHIFT 11 +#define TG3_OTP_VDAC_MASK 0xff000000 +#define TG3_OTP_VDAC_SHIFT 24 +#define TG3_OTP_10BTAMP_MASK 0x0000f000 +#define TG3_OTP_10BTAMP_SHIFT 8 +#define TG3_OTP_ROFF_MASK 0x00e00000 +#define TG3_OTP_ROFF_SHIFT 11 +#define TG3_OTP_RCOFF_MASK 0x001c0000 +#define TG3_OTP_RCOFF_SHIFT 16 + +#define TG3_OTP_DEFAULT 0x286c1640 + + +/* Hardware Legacy NVRAM layout */ +#define TG3_NVM_VPD_OFF 0x100 +#define TG3_NVM_VPD_LEN 256 + +/* Hardware Selfboot NVRAM layout */ +#define TG3_NVM_HWSB_CFG1 0x00000004 +#define TG3_NVM_HWSB_CFG1_MAJMSK 0xf8000000 +#define TG3_NVM_HWSB_CFG1_MAJSFT 27 +#define TG3_NVM_HWSB_CFG1_MINMSK 0x07c00000 +#define TG3_NVM_HWSB_CFG1_MINSFT 22 + +#define TG3_EEPROM_MAGIC 0x669955aa +#define TG3_EEPROM_MAGIC_FW 0xa5000000 +#define TG3_EEPROM_MAGIC_FW_MSK 0xff000000 +#define TG3_EEPROM_SB_FORMAT_MASK 0x00e00000 +#define TG3_EEPROM_SB_FORMAT_1 0x00200000 +#define TG3_EEPROM_SB_REVISION_MASK 0x001f0000 +#define TG3_EEPROM_SB_REVISION_0 0x00000000 +#define TG3_EEPROM_SB_REVISION_2 0x00020000 +#define TG3_EEPROM_SB_REVISION_3 0x00030000 +#define TG3_EEPROM_SB_REVISION_4 0x00040000 +#define TG3_EEPROM_SB_REVISION_5 0x00050000 +#define TG3_EEPROM_SB_REVISION_6 0x00060000 +#define TG3_EEPROM_MAGIC_HW 0xabcd +#define TG3_EEPROM_MAGIC_HW_MSK 0xffff + +#define TG3_NVM_DIR_START 0x18 +#define TG3_NVM_DIR_END 0x78 +#define TG3_NVM_DIRENT_SIZE 0xc +#define TG3_NVM_DIRTYPE_SHIFT 24 +#define TG3_NVM_DIRTYPE_LENMSK 0x003fffff +#define TG3_NVM_DIRTYPE_ASFINI 1 +#define TG3_NVM_DIRTYPE_EXTVPD 20 +#define TG3_NVM_PTREV_BCVER 0x94 +#define TG3_NVM_BCVER_MAJMSK 0x0000ff00 +#define TG3_NVM_BCVER_MAJSFT 8 +#define TG3_NVM_BCVER_MINMSK 0x000000ff + +#define TG3_EEPROM_SB_F1R0_EDH_OFF 0x10 +#define TG3_EEPROM_SB_F1R2_EDH_OFF 0x14 +#define TG3_EEPROM_SB_F1R2_MBA_OFF 0x10 +#define TG3_EEPROM_SB_F1R3_EDH_OFF 0x18 +#define TG3_EEPROM_SB_F1R4_EDH_OFF 0x1c +#define TG3_EEPROM_SB_F1R5_EDH_OFF 0x20 +#define TG3_EEPROM_SB_F1R6_EDH_OFF 0x4c +#define TG3_EEPROM_SB_EDH_MAJ_MASK 0x00000700 +#define TG3_EEPROM_SB_EDH_MAJ_SHFT 8 +#define TG3_EEPROM_SB_EDH_MIN_MASK 0x000000ff +#define TG3_EEPROM_SB_EDH_BLD_MASK 0x0000f800 +#define TG3_EEPROM_SB_EDH_BLD_SHFT 11 + + +/* 32K Window into NIC internal memory */ +#define NIC_SRAM_WIN_BASE 0x00008000 + +/* Offsets into first 32k of NIC internal memory. */ +#define NIC_SRAM_PAGE_ZERO 0x00000000 +#define NIC_SRAM_SEND_RCB 0x00000100 /* 16 * TG3_BDINFO_... */ +#define NIC_SRAM_RCV_RET_RCB 0x00000200 /* 16 * TG3_BDINFO_... */ +#define NIC_SRAM_STATS_BLK 0x00000300 +#define NIC_SRAM_STATUS_BLK 0x00000b00 + +#define NIC_SRAM_FIRMWARE_MBOX 0x00000b50 +#define NIC_SRAM_FIRMWARE_MBOX_MAGIC1 0x4B657654 +#define NIC_SRAM_FIRMWARE_MBOX_MAGIC2 0x4861764b /* !dma on linkchg */ + +#define NIC_SRAM_DATA_SIG 0x00000b54 +#define NIC_SRAM_DATA_SIG_MAGIC 0x4b657654 /* ascii for 'KevT' */ + +#define NIC_SRAM_DATA_CFG 0x00000b58 +#define NIC_SRAM_DATA_CFG_LED_MODE_MASK 0x0000000c +#define NIC_SRAM_DATA_CFG_LED_MODE_MAC 0x00000000 +#define NIC_SRAM_DATA_CFG_LED_MODE_PHY_1 0x00000004 +#define NIC_SRAM_DATA_CFG_LED_MODE_PHY_2 0x00000008 +#define NIC_SRAM_DATA_CFG_PHY_TYPE_MASK 0x00000030 +#define NIC_SRAM_DATA_CFG_PHY_TYPE_UNKNOWN 0x00000000 +#define NIC_SRAM_DATA_CFG_PHY_TYPE_COPPER 0x00000010 +#define NIC_SRAM_DATA_CFG_PHY_TYPE_FIBER 0x00000020 +#define NIC_SRAM_DATA_CFG_WOL_ENABLE 0x00000040 +#define NIC_SRAM_DATA_CFG_ASF_ENABLE 0x00000080 +#define NIC_SRAM_DATA_CFG_EEPROM_WP 0x00000100 +#define NIC_SRAM_DATA_CFG_MINI_PCI 0x00001000 +#define NIC_SRAM_DATA_CFG_FIBER_WOL 0x00004000 +#define NIC_SRAM_DATA_CFG_NO_GPIO2 0x00100000 +#define NIC_SRAM_DATA_CFG_APE_ENABLE 0x00200000 + +#define NIC_SRAM_DATA_VER 0x00000b5c +#define NIC_SRAM_DATA_VER_SHIFT 16 + +#define NIC_SRAM_DATA_PHY_ID 0x00000b74 +#define NIC_SRAM_DATA_PHY_ID1_MASK 0xffff0000 +#define NIC_SRAM_DATA_PHY_ID2_MASK 0x0000ffff + +#define NIC_SRAM_FW_CMD_MBOX 0x00000b78 +#define FWCMD_NICDRV_ALIVE 0x00000001 +#define FWCMD_NICDRV_PAUSE_FW 0x00000002 +#define FWCMD_NICDRV_IPV4ADDR_CHG 0x00000003 +#define FWCMD_NICDRV_IPV6ADDR_CHG 0x00000004 +#define FWCMD_NICDRV_FIX_DMAR 0x00000005 +#define FWCMD_NICDRV_FIX_DMAW 0x00000006 +#define FWCMD_NICDRV_LINK_UPDATE 0x0000000c +#define FWCMD_NICDRV_ALIVE2 0x0000000d +#define FWCMD_NICDRV_ALIVE3 0x0000000e +#define NIC_SRAM_FW_CMD_LEN_MBOX 0x00000b7c +#define NIC_SRAM_FW_CMD_DATA_MBOX 0x00000b80 +#define NIC_SRAM_FW_ASF_STATUS_MBOX 0x00000c00 +#define NIC_SRAM_FW_DRV_STATE_MBOX 0x00000c04 +#define DRV_STATE_START 0x00000001 +#define DRV_STATE_START_DONE 0x80000001 +#define DRV_STATE_UNLOAD 0x00000002 +#define DRV_STATE_UNLOAD_DONE 0x80000002 +#define DRV_STATE_WOL 0x00000003 +#define DRV_STATE_SUSPEND 0x00000004 + +#define NIC_SRAM_FW_RESET_TYPE_MBOX 0x00000c08 + +#define NIC_SRAM_MAC_ADDR_HIGH_MBOX 0x00000c14 +#define NIC_SRAM_MAC_ADDR_LOW_MBOX 0x00000c18 + +#define NIC_SRAM_WOL_MBOX 0x00000d30 +#define WOL_SIGNATURE 0x474c0000 +#define WOL_DRV_STATE_SHUTDOWN 0x00000001 +#define WOL_DRV_WOL 0x00000002 +#define WOL_SET_MAGIC_PKT 0x00000004 + +#define NIC_SRAM_DATA_CFG_2 0x00000d38 + +#define NIC_SRAM_DATA_CFG_2_APD_EN 0x00004000 +#define SHASTA_EXT_LED_MODE_MASK 0x00018000 +#define SHASTA_EXT_LED_LEGACY 0x00000000 +#define SHASTA_EXT_LED_SHARED 0x00008000 +#define SHASTA_EXT_LED_MAC 0x00010000 +#define SHASTA_EXT_LED_COMBO 0x00018000 + +#define NIC_SRAM_DATA_CFG_3 0x00000d3c +#define NIC_SRAM_ASPM_DEBOUNCE 0x00000002 +#define NIC_SRAM_LNK_FLAP_AVOID 0x00400000 +#define NIC_SRAM_1G_ON_VAUX_OK 0x00800000 + +#define NIC_SRAM_DATA_CFG_4 0x00000d60 +#define NIC_SRAM_GMII_MODE 0x00000002 +#define NIC_SRAM_RGMII_INBAND_DISABLE 0x00000004 +#define NIC_SRAM_RGMII_EXT_IBND_RX_EN 0x00000008 +#define NIC_SRAM_RGMII_EXT_IBND_TX_EN 0x00000010 + +#define NIC_SRAM_CPMU_STATUS 0x00000e00 +#define NIC_SRAM_CPMUSTAT_SIG 0x0000362c +#define NIC_SRAM_CPMUSTAT_SIG_MSK 0x0000ffff + +#define NIC_SRAM_DATA_CFG_5 0x00000e0c +#define NIC_SRAM_DISABLE_1G_HALF_ADV 0x00000002 + +#define NIC_SRAM_RX_MINI_BUFFER_DESC 0x00001000 + +#define NIC_SRAM_DMA_DESC_POOL_BASE 0x00002000 +#define NIC_SRAM_DMA_DESC_POOL_SIZE 0x00002000 +#define NIC_SRAM_TX_BUFFER_DESC 0x00004000 /* 512 entries */ +#define NIC_SRAM_RX_BUFFER_DESC 0x00006000 /* 256 entries */ +#define NIC_SRAM_RX_JUMBO_BUFFER_DESC 0x00007000 /* 256 entries */ +#define NIC_SRAM_MBUF_POOL_BASE 0x00008000 +#define NIC_SRAM_MBUF_POOL_SIZE96 0x00018000 +#define NIC_SRAM_MBUF_POOL_SIZE64 0x00010000 +#define NIC_SRAM_MBUF_POOL_BASE5705 0x00010000 +#define NIC_SRAM_MBUF_POOL_SIZE5705 0x0000e000 + +#define TG3_SRAM_RXCPU_SCRATCH_BASE_57766 0x00030000 +#define TG3_SRAM_RXCPU_SCRATCH_SIZE_57766 0x00010000 +#define TG3_57766_FW_BASE_ADDR 0x00030000 +#define TG3_57766_FW_HANDSHAKE 0x0003fccc +#define TG3_SBROM_IN_SERVICE_LOOP 0x51 + +#define TG3_SRAM_RX_STD_BDCACHE_SIZE_5700 128 +#define TG3_SRAM_RX_STD_BDCACHE_SIZE_5755 64 +#define TG3_SRAM_RX_STD_BDCACHE_SIZE_5906 32 + +#define TG3_SRAM_RX_JMB_BDCACHE_SIZE_5700 64 +#define TG3_SRAM_RX_JMB_BDCACHE_SIZE_5717 16 + + +/* Currently this is fixed. */ +#define TG3_PHY_MII_ADDR 0x01 + + +/*** Tigon3 specific PHY MII registers. ***/ +#define MII_TG3_MMD_CTRL 0x0d /* MMD Access Control register */ +#define MII_TG3_MMD_CTRL_DATA_NOINC 0x4000 +#define MII_TG3_MMD_ADDRESS 0x0e /* MMD Address Data register */ + +#define MII_TG3_EXT_CTRL 0x10 /* Extended control register */ +#define MII_TG3_EXT_CTRL_FIFO_ELASTIC 0x0001 +#define MII_TG3_EXT_CTRL_LNK3_LED_MODE 0x0002 +#define MII_TG3_EXT_CTRL_FORCE_LED_OFF 0x0008 +#define MII_TG3_EXT_CTRL_TBI 0x8000 + +#define MII_TG3_EXT_STAT 0x11 /* Extended status register */ +#define MII_TG3_EXT_STAT_MDIX 0x2000 +#define MII_TG3_EXT_STAT_LPASS 0x0100 + +#define MII_TG3_RXR_COUNTERS 0x14 /* Local/Remote Receiver Counts */ +#define MII_TG3_DSP_RW_PORT 0x15 /* DSP coefficient read/write port */ +#define MII_TG3_DSP_CONTROL 0x16 /* DSP control register */ +#define MII_TG3_DSP_ADDRESS 0x17 /* DSP address register */ + +#define MII_TG3_DSP_TAP1 0x0001 +#define MII_TG3_DSP_TAP1_AGCTGT_DFLT 0x0007 +#define MII_TG3_DSP_TAP26 0x001a +#define MII_TG3_DSP_TAP26_ALNOKO 0x0001 +#define MII_TG3_DSP_TAP26_RMRXSTO 0x0002 +#define MII_TG3_DSP_TAP26_OPCSINPT 0x0004 +#define MII_TG3_DSP_AADJ1CH0 0x001f +#define MII_TG3_DSP_CH34TP2 0x4022 +#define MII_TG3_DSP_CH34TP2_HIBW01 0x01ff +#define MII_TG3_DSP_AADJ1CH3 0x601f +#define MII_TG3_DSP_AADJ1CH3_ADCCKADJ 0x0002 +#define MII_TG3_DSP_EXP1_INT_STAT 0x0f01 +#define MII_TG3_DSP_EXP8 0x0f08 +#define MII_TG3_DSP_EXP8_REJ2MHz 0x0001 +#define MII_TG3_DSP_EXP8_AEDW 0x0200 +#define MII_TG3_DSP_EXP75 0x0f75 +#define MII_TG3_DSP_EXP96 0x0f96 +#define MII_TG3_DSP_EXP97 0x0f97 + +#define MII_TG3_AUX_CTRL 0x18 /* auxiliary control register */ + +#define MII_TG3_AUXCTL_SHDWSEL_AUXCTL 0x0000 +#define MII_TG3_AUXCTL_ACTL_TX_6DB 0x0400 +#define MII_TG3_AUXCTL_ACTL_SMDSP_ENA 0x0800 +#define MII_TG3_AUXCTL_ACTL_EXTPKTLEN 0x4000 +#define MII_TG3_AUXCTL_ACTL_EXTLOOPBK 0x8000 + +#define MII_TG3_AUXCTL_SHDWSEL_PWRCTL 0x0002 +#define MII_TG3_AUXCTL_PCTL_WOL_EN 0x0008 +#define MII_TG3_AUXCTL_PCTL_100TX_LPWR 0x0010 +#define MII_TG3_AUXCTL_PCTL_SPR_ISOLATE 0x0020 +#define MII_TG3_AUXCTL_PCTL_CL_AB_TXDAC 0x0040 +#define MII_TG3_AUXCTL_PCTL_VREG_11V 0x0180 + +#define MII_TG3_AUXCTL_SHDWSEL_MISCTEST 0x0004 + +#define MII_TG3_AUXCTL_SHDWSEL_MISC 0x0007 +#define MII_TG3_AUXCTL_MISC_WIRESPD_EN 0x0010 +#define MII_TG3_AUXCTL_MISC_FORCE_AMDIX 0x0200 +#define MII_TG3_AUXCTL_MISC_RDSEL_SHIFT 12 +#define MII_TG3_AUXCTL_MISC_WREN 0x8000 + + +#define MII_TG3_AUX_STAT 0x19 /* auxiliary status register */ +#define MII_TG3_AUX_STAT_LPASS 0x0004 +#define MII_TG3_AUX_STAT_SPDMASK 0x0700 +#define MII_TG3_AUX_STAT_10HALF 0x0100 +#define MII_TG3_AUX_STAT_10FULL 0x0200 +#define MII_TG3_AUX_STAT_100HALF 0x0300 +#define MII_TG3_AUX_STAT_100_4 0x0400 +#define MII_TG3_AUX_STAT_100FULL 0x0500 +#define MII_TG3_AUX_STAT_1000HALF 0x0600 +#define MII_TG3_AUX_STAT_1000FULL 0x0700 +#define MII_TG3_AUX_STAT_100 0x0008 +#define MII_TG3_AUX_STAT_FULL 0x0001 + +#define MII_TG3_ISTAT 0x1a /* IRQ status register */ +#define MII_TG3_IMASK 0x1b /* IRQ mask register */ + +/* ISTAT/IMASK event bits */ +#define MII_TG3_INT_LINKCHG 0x0002 +#define MII_TG3_INT_SPEEDCHG 0x0004 +#define MII_TG3_INT_DUPLEXCHG 0x0008 +#define MII_TG3_INT_ANEG_PAGE_RX 0x0400 + +#define MII_TG3_MISC_SHDW 0x1c +#define MII_TG3_MISC_SHDW_WREN 0x8000 + +#define MII_TG3_MISC_SHDW_APD_WKTM_84MS 0x0001 +#define MII_TG3_MISC_SHDW_APD_ENABLE 0x0020 +#define MII_TG3_MISC_SHDW_APD_SEL 0x2800 + +#define MII_TG3_MISC_SHDW_SCR5_C125OE 0x0001 +#define MII_TG3_MISC_SHDW_SCR5_DLLAPD 0x0002 +#define MII_TG3_MISC_SHDW_SCR5_SDTL 0x0004 +#define MII_TG3_MISC_SHDW_SCR5_DLPTLM 0x0008 +#define MII_TG3_MISC_SHDW_SCR5_LPED 0x0010 +#define MII_TG3_MISC_SHDW_SCR5_SEL 0x1400 + +#define MII_TG3_TEST1 0x1e +#define MII_TG3_TEST1_TRIM_EN 0x0010 +#define MII_TG3_TEST1_CRC_EN 0x8000 + +/* Clause 45 expansion registers */ +#define TG3_CL45_D7_EEERES_STAT 0x803e +#define TG3_CL45_D7_EEERES_STAT_LP_100TX 0x0002 +#define TG3_CL45_D7_EEERES_STAT_LP_1000T 0x0004 + + +/* Fast Ethernet Tranceiver definitions */ +#define MII_TG3_FET_PTEST 0x17 +#define MII_TG3_FET_PTEST_TRIM_SEL 0x0010 +#define MII_TG3_FET_PTEST_TRIM_2 0x0002 +#define MII_TG3_FET_PTEST_FRC_TX_LINK 0x1000 +#define MII_TG3_FET_PTEST_FRC_TX_LOCK 0x0800 + +#define MII_TG3_FET_GEN_STAT 0x1c +#define MII_TG3_FET_GEN_STAT_MDIXSTAT 0x2000 + +#define MII_TG3_FET_TEST 0x1f +#define MII_TG3_FET_SHADOW_EN 0x0080 + +#define MII_TG3_FET_SHDW_MISCCTRL 0x10 +#define MII_TG3_FET_SHDW_MISCCTRL_MDIX 0x4000 + +#define MII_TG3_FET_SHDW_AUXMODE4 0x1a +#define MII_TG3_FET_SHDW_AUXMODE4_SBPD 0x0008 + +#define MII_TG3_FET_SHDW_AUXSTAT2 0x1b +#define MII_TG3_FET_SHDW_AUXSTAT2_APD 0x0020 + +/* Serdes PHY Register Definitions */ +#define SERDES_TG3_1000X_STATUS 0x14 +#define SERDES_TG3_SGMII_MODE 0x0001 +#define SERDES_TG3_LINK_UP 0x0002 +#define SERDES_TG3_FULL_DUPLEX 0x0004 +#define SERDES_TG3_SPEED_100 0x0008 +#define SERDES_TG3_SPEED_1000 0x0010 + +/* APE registers. Accessible through BAR1 */ +#define TG3_APE_GPIO_MSG 0x0008 +#define TG3_APE_GPIO_MSG_SHIFT 4 +#define TG3_APE_EVENT 0x000c +#define APE_EVENT_1 0x00000001 +#define TG3_APE_LOCK_REQ 0x002c +#define APE_LOCK_REQ_DRIVER 0x00001000 +#define TG3_APE_LOCK_GRANT 0x004c +#define APE_LOCK_GRANT_DRIVER 0x00001000 +#define TG3_APE_OTP_CTRL 0x00e8 +#define APE_OTP_CTRL_PROG_EN 0x200000 +#define APE_OTP_CTRL_CMD_RD 0x000000 +#define APE_OTP_CTRL_START 0x000001 +#define TG3_APE_OTP_STATUS 0x00ec +#define APE_OTP_STATUS_CMD_DONE 0x000001 +#define TG3_APE_OTP_ADDR 0x00f0 +#define APE_OTP_ADDR_CPU_ENABLE 0x80000000 +#define TG3_APE_OTP_RD_DATA 0x00f8 + +#define OTP_ADDRESS_MAGIC0 0x00000050 +#define TG3_OTP_MAGIC0_VALID(val) \ + ((((val) & 0xf0000000) == 0xa0000000) ||\ + (((val) & 0x0f000000) == 0x0a000000)) + +/* APE shared memory. Accessible through BAR1 */ +#define TG3_APE_SHMEM_BASE 0x4000 +#define TG3_APE_SEG_SIG 0x4000 +#define APE_SEG_SIG_MAGIC 0x41504521 +#define TG3_APE_FW_STATUS 0x400c +#define APE_FW_STATUS_READY 0x00000100 +#define TG3_APE_FW_FEATURES 0x4010 +#define TG3_APE_FW_FEATURE_NCSI 0x00000002 +#define TG3_APE_FW_VERSION 0x4018 +#define APE_FW_VERSION_MAJMSK 0xff000000 +#define APE_FW_VERSION_MAJSFT 24 +#define APE_FW_VERSION_MINMSK 0x00ff0000 +#define APE_FW_VERSION_MINSFT 16 +#define APE_FW_VERSION_REVMSK 0x0000ff00 +#define APE_FW_VERSION_REVSFT 8 +#define APE_FW_VERSION_BLDMSK 0x000000ff +#define TG3_APE_SEG_MSG_BUF_OFF 0x401c +#define TG3_APE_SEG_MSG_BUF_LEN 0x4020 +#define TG3_APE_HOST_SEG_SIG 0x4200 +#define APE_HOST_SEG_SIG_MAGIC 0x484f5354 +#define TG3_APE_HOST_SEG_LEN 0x4204 +#define APE_HOST_SEG_LEN_MAGIC 0x00000020 +#define TG3_APE_HOST_INIT_COUNT 0x4208 +#define TG3_APE_HOST_DRIVER_ID 0x420c +#define APE_HOST_DRIVER_ID_LINUX 0xf0000000 +#define APE_HOST_DRIVER_ID_MAGIC(maj, min) \ + (APE_HOST_DRIVER_ID_LINUX | (maj & 0xff) << 16 | (min & 0xff) << 8) +#define TG3_APE_HOST_BEHAVIOR 0x4210 +#define APE_HOST_BEHAV_NO_PHYLOCK 0x00000001 +#define TG3_APE_HOST_HEARTBEAT_INT_MS 0x4214 +#define APE_HOST_HEARTBEAT_INT_DISABLE 0 +#define APE_HOST_HEARTBEAT_INT_5SEC 5000 +#define TG3_APE_HOST_HEARTBEAT_COUNT 0x4218 +#define TG3_APE_HOST_DRVR_STATE 0x421c +#define TG3_APE_HOST_DRVR_STATE_START 0x00000001 +#define TG3_APE_HOST_DRVR_STATE_UNLOAD 0x00000002 +#define TG3_APE_HOST_DRVR_STATE_WOL 0x00000003 +#define TG3_APE_HOST_WOL_SPEED 0x4224 +#define TG3_APE_HOST_WOL_SPEED_AUTO 0x00008000 + +#define TG3_APE_EVENT_STATUS 0x4300 + +#define APE_EVENT_STATUS_DRIVER_EVNT 0x00000010 +#define APE_EVENT_STATUS_STATE_CHNGE 0x00000500 +#define APE_EVENT_STATUS_SCRTCHPD_READ 0x00001600 +#define APE_EVENT_STATUS_SCRTCHPD_WRITE 0x00001700 +#define APE_EVENT_STATUS_STATE_START 0x00010000 +#define APE_EVENT_STATUS_STATE_UNLOAD 0x00020000 +#define APE_EVENT_STATUS_STATE_WOL 0x00030000 +#define APE_EVENT_STATUS_STATE_SUSPEND 0x00040000 +#define APE_EVENT_STATUS_EVENT_PENDING 0x80000000 + +#define TG3_APE_PER_LOCK_REQ 0x8400 +#define APE_LOCK_PER_REQ_DRIVER 0x00001000 +#define TG3_APE_PER_LOCK_GRANT 0x8420 +#define APE_PER_LOCK_GRANT_DRIVER 0x00001000 + +/* APE convenience enumerations. */ +#define TG3_APE_LOCK_PHY0 0 +#define TG3_APE_LOCK_GRC 1 +#define TG3_APE_LOCK_PHY1 2 +#define TG3_APE_LOCK_PHY2 3 +#define TG3_APE_LOCK_MEM 4 +#define TG3_APE_LOCK_PHY3 5 +#define TG3_APE_LOCK_GPIO 7 + +#define TG3_EEPROM_SB_F1R2_MBA_OFF 0x10 +/* TODO: Can we use the SRAM instead of DMA? */ + +/* There are two ways to manage the TX descriptors on the tigon3. + * Either the descriptors are in host DMA'able memory, or they + * exist only in the cards on-chip SRAM. All 16 send bds are under + * the same mode, they may not be configured individually. + * + * This driver always uses host memory TX descriptors. + * + * To use host memory TX descriptors: + * 1) Set GRC_MODE_HOST_SENDBDS in GRC_MODE register. + * Make sure GRC_MODE_4X_NIC_SEND_RINGS is clear. + * 2) Allocate DMA'able memory. + * 3) In NIC_SRAM_SEND_RCB (of desired index) of on-chip SRAM: + * a) Set TG3_BDINFO_HOST_ADDR to DMA address of memory + * obtained in step 2 + * b) Set TG3_BDINFO_NIC_ADDR to NIC_SRAM_TX_BUFFER_DESC. + * c) Set len field of TG3_BDINFO_MAXLEN_FLAGS to number + * of TX descriptors. Leave flags field clear. + * 4) Access TX descriptors via host memory. The chip + * will refetch into local SRAM as needed when producer + * index mailboxes are updated. + * + * To use on-chip TX descriptors: + * 1) Set GRC_MODE_4X_NIC_SEND_RINGS in GRC_MODE register. + * Make sure GRC_MODE_HOST_SENDBDS is clear. + * 2) In NIC_SRAM_SEND_RCB (of desired index) of on-chip SRAM: + * a) Set TG3_BDINFO_HOST_ADDR to zero. + * b) Set TG3_BDINFO_NIC_ADDR to NIC_SRAM_TX_BUFFER_DESC + * c) TG3_BDINFO_MAXLEN_FLAGS is don't care. + * 3) Access TX descriptors directly in on-chip SRAM + * using normal {read,write}l(). (and not using + * pointer dereferencing of ioremap()'d memory like + * the broken Broadcom driver does) + * + * Note that BDINFO_FLAGS_DISABLED should be set in the flags field of + * TG3_BDINFO_MAXLEN_FLAGS of all unused SEND_RCB indices. + */ +struct tg3_tx_buffer_desc { + u32 addr_hi; + u32 addr_lo; + + u32 len_flags; +#define TXD_FLAG_TCPUDP_CSUM 0x0001 +#define TXD_FLAG_IP_CSUM 0x0002 +#define TXD_FLAG_END 0x0004 +#define TXD_FLAG_IP_FRAG 0x0008 +#define TXD_FLAG_JMB_PKT 0x0008 +#define TXD_FLAG_IP_FRAG_END 0x0010 +#define TXD_FLAG_HWTSTAMP 0x0020 +#define TXD_FLAG_VLAN 0x0040 +#define TXD_FLAG_COAL_NOW 0x0080 +#define TXD_FLAG_CPU_PRE_DMA 0x0100 +#define TXD_FLAG_CPU_POST_DMA 0x0200 +#define TXD_FLAG_ADD_SRC_ADDR 0x1000 +#define TXD_FLAG_CHOOSE_SRC_ADDR 0x6000 +#define TXD_FLAG_NO_CRC 0x8000 +#define TXD_LEN_SHIFT 16 + + u32 vlan_tag; +#define TXD_VLAN_TAG_SHIFT 0 +#define TXD_MSS_SHIFT 16 +}; + +#define TXD_ADDR 0x00UL /* 64-bit */ +#define TXD_LEN_FLAGS 0x08UL /* 32-bit (upper 16-bits are len) */ +#define TXD_VLAN_TAG 0x0cUL /* 32-bit (upper 16-bits are tag) */ +#define TXD_SIZE 0x10UL + +struct tg3_rx_buffer_desc { + u32 addr_hi; + u32 addr_lo; + + u32 idx_len; +#define RXD_IDX_MASK 0xffff0000 +#define RXD_IDX_SHIFT 16 +#define RXD_LEN_MASK 0x0000ffff +#define RXD_LEN_SHIFT 0 + + u32 type_flags; +#define RXD_TYPE_SHIFT 16 +#define RXD_FLAGS_SHIFT 0 + +#define RXD_FLAG_END 0x0004 +#define RXD_FLAG_MINI 0x0800 +#define RXD_FLAG_JUMBO 0x0020 +#define RXD_FLAG_VLAN 0x0040 +#define RXD_FLAG_ERROR 0x0400 +#define RXD_FLAG_IP_CSUM 0x1000 +#define RXD_FLAG_TCPUDP_CSUM 0x2000 +#define RXD_FLAG_IS_TCP 0x4000 +#define RXD_FLAG_PTPSTAT_MASK 0x0210 +#define RXD_FLAG_PTPSTAT_PTPV1 0x0010 +#define RXD_FLAG_PTPSTAT_PTPV2 0x0200 + + u32 ip_tcp_csum; +#define RXD_IPCSUM_MASK 0xffff0000 +#define RXD_IPCSUM_SHIFT 16 +#define RXD_TCPCSUM_MASK 0x0000ffff +#define RXD_TCPCSUM_SHIFT 0 + + u32 err_vlan; + +#define RXD_VLAN_MASK 0x0000ffff + +#define RXD_ERR_BAD_CRC 0x00010000 +#define RXD_ERR_COLLISION 0x00020000 +#define RXD_ERR_LINK_LOST 0x00040000 +#define RXD_ERR_PHY_DECODE 0x00080000 +#define RXD_ERR_ODD_NIBBLE_RCVD_MII 0x00100000 +#define RXD_ERR_MAC_ABRT 0x00200000 +#define RXD_ERR_TOO_SMALL 0x00400000 +#define RXD_ERR_NO_RESOURCES 0x00800000 +#define RXD_ERR_HUGE_FRAME 0x01000000 + +#define RXD_ERR_MASK (RXD_ERR_BAD_CRC | RXD_ERR_COLLISION | \ + RXD_ERR_LINK_LOST | RXD_ERR_PHY_DECODE | \ + RXD_ERR_MAC_ABRT | RXD_ERR_TOO_SMALL | \ + RXD_ERR_NO_RESOURCES | RXD_ERR_HUGE_FRAME) + + u32 reserved; + u32 opaque; +#define RXD_OPAQUE_INDEX_MASK 0x0000ffff +#define RXD_OPAQUE_INDEX_SHIFT 0 +#define RXD_OPAQUE_RING_STD 0x00010000 +#define RXD_OPAQUE_RING_JUMBO 0x00020000 +#define RXD_OPAQUE_RING_MINI 0x00040000 +#define RXD_OPAQUE_RING_MASK 0x00070000 +}; + + +/* We only use this when testing out the DMA engine + * at probe time. This is the internal format of buffer + * descriptors used by the chip at NIC_SRAM_DMA_DESCS. + */ +struct tg3_internal_buffer_desc { + u32 addr_hi; + u32 addr_lo; + u32 nic_mbuf; + /* XXX FIX THIS */ +#ifdef __BIG_ENDIAN + u16 cqid_sqid; + u16 len; +#else + u16 len; + u16 cqid_sqid; +#endif + u32 flags; + u32 __cookie1; + u32 __cookie2; + u32 __cookie3; +}; + +#define TG3_HW_STATUS_SIZE 0x50 +struct tg3_hw_status { + u32 status; +#define SD_STATUS_UPDATED 0x00000001 +#define SD_STATUS_LINK_CHG 0x00000002 +#define SD_STATUS_ERROR 0x00000004 + + u32 status_tag; + +#ifdef __BIG_ENDIAN + u16 rx_consumer; + u16 rx_jumbo_consumer; +#else + u16 rx_jumbo_consumer; + u16 rx_consumer; +#endif + +#ifdef __BIG_ENDIAN + u16 reserved; + u16 rx_mini_consumer; +#else + u16 rx_mini_consumer; + u16 reserved; +#endif + struct { +#ifdef __BIG_ENDIAN + u16 tx_consumer; + u16 rx_producer; +#else + u16 rx_producer; + u16 tx_consumer; +#endif + } idx[16]; +}; + +typedef struct { + u32 high, low; +} tg3_stat64_t; + +struct tg3_hw_stats { + u8 __reserved0[0x400-0x300]; + + /* Statistics maintained by Receive MAC. */ + tg3_stat64_t rx_octets; + u64 __reserved1; + tg3_stat64_t rx_fragments; + tg3_stat64_t rx_ucast_packets; + tg3_stat64_t rx_mcast_packets; + tg3_stat64_t rx_bcast_packets; + tg3_stat64_t rx_fcs_errors; + tg3_stat64_t rx_align_errors; + tg3_stat64_t rx_xon_pause_rcvd; + tg3_stat64_t rx_xoff_pause_rcvd; + tg3_stat64_t rx_mac_ctrl_rcvd; + tg3_stat64_t rx_xoff_entered; + tg3_stat64_t rx_frame_too_long_errors; + tg3_stat64_t rx_jabbers; + tg3_stat64_t rx_undersize_packets; + tg3_stat64_t rx_in_length_errors; + tg3_stat64_t rx_out_length_errors; + tg3_stat64_t rx_64_or_less_octet_packets; + tg3_stat64_t rx_65_to_127_octet_packets; + tg3_stat64_t rx_128_to_255_octet_packets; + tg3_stat64_t rx_256_to_511_octet_packets; + tg3_stat64_t rx_512_to_1023_octet_packets; + tg3_stat64_t rx_1024_to_1522_octet_packets; + tg3_stat64_t rx_1523_to_2047_octet_packets; + tg3_stat64_t rx_2048_to_4095_octet_packets; + tg3_stat64_t rx_4096_to_8191_octet_packets; + tg3_stat64_t rx_8192_to_9022_octet_packets; + + u64 __unused0[37]; + + /* Statistics maintained by Transmit MAC. */ + tg3_stat64_t tx_octets; + u64 __reserved2; + tg3_stat64_t tx_collisions; + tg3_stat64_t tx_xon_sent; + tg3_stat64_t tx_xoff_sent; + tg3_stat64_t tx_flow_control; + tg3_stat64_t tx_mac_errors; + tg3_stat64_t tx_single_collisions; + tg3_stat64_t tx_mult_collisions; + tg3_stat64_t tx_deferred; + u64 __reserved3; + tg3_stat64_t tx_excessive_collisions; + tg3_stat64_t tx_late_collisions; + tg3_stat64_t tx_collide_2times; + tg3_stat64_t tx_collide_3times; + tg3_stat64_t tx_collide_4times; + tg3_stat64_t tx_collide_5times; + tg3_stat64_t tx_collide_6times; + tg3_stat64_t tx_collide_7times; + tg3_stat64_t tx_collide_8times; + tg3_stat64_t tx_collide_9times; + tg3_stat64_t tx_collide_10times; + tg3_stat64_t tx_collide_11times; + tg3_stat64_t tx_collide_12times; + tg3_stat64_t tx_collide_13times; + tg3_stat64_t tx_collide_14times; + tg3_stat64_t tx_collide_15times; + tg3_stat64_t tx_ucast_packets; + tg3_stat64_t tx_mcast_packets; + tg3_stat64_t tx_bcast_packets; + tg3_stat64_t tx_carrier_sense_errors; + tg3_stat64_t tx_discards; + tg3_stat64_t tx_errors; + + u64 __unused1[31]; + + /* Statistics maintained by Receive List Placement. */ + tg3_stat64_t COS_rx_packets[16]; + tg3_stat64_t COS_rx_filter_dropped; + tg3_stat64_t dma_writeq_full; + tg3_stat64_t dma_write_prioq_full; + tg3_stat64_t rxbds_empty; + tg3_stat64_t rx_discards; + tg3_stat64_t rx_errors; + tg3_stat64_t rx_threshold_hit; + + u64 __unused2[9]; + + /* Statistics maintained by Send Data Initiator. */ + tg3_stat64_t COS_out_packets[16]; + tg3_stat64_t dma_readq_full; + tg3_stat64_t dma_read_prioq_full; + tg3_stat64_t tx_comp_queue_full; + + /* Statistics maintained by Host Coalescing. */ + tg3_stat64_t ring_set_send_prod_index; + tg3_stat64_t ring_status_update; + tg3_stat64_t nic_irqs; + tg3_stat64_t nic_avoided_irqs; + tg3_stat64_t nic_tx_threshold_hit; + + /* NOT a part of the hardware statistics block format. + * These stats are here as storage for tg3_periodic_fetch_stats(). + */ + tg3_stat64_t mbuf_lwm_thresh_hit; + + u8 __reserved4[0xb00-0x9c8]; +}; + +#if 0 +#define TG3_SD_NUM_RECS 3 +#define TG3_OCIR_LEN (sizeof(struct tg3_ocir)) +#define TG3_OCIR_SIG_MAGIC 0x5253434f +#define TG3_OCIR_FLAG_ACTIVE 0x00000001 + +#define TG3_TEMP_CAUTION_OFFSET 0xc8 +#define TG3_TEMP_MAX_OFFSET 0xcc +#define TG3_TEMP_SENSOR_OFFSET 0xd4 + + +struct tg3_ocir { + u32 signature; + u16 version_flags; + u16 refresh_int; + u32 refresh_tmr; + u32 update_tmr; + u32 dst_base_addr; + u16 src_hdr_offset; + u16 src_hdr_length; + u16 src_data_offset; + u16 src_data_length; + u16 dst_hdr_offset; + u16 dst_data_offset; + u16 dst_reg_upd_offset; + u16 dst_sem_offset; + u32 reserved1[2]; + u32 port0_flags; + u32 port1_flags; + u32 port2_flags; + u32 port3_flags; + u32 reserved2[1]; +}; +#endif + +/* 'mapping' is superfluous as the chip does not write into + * the tx/rx post rings so we could just fetch it from there. + * But the cache behavior is better how we are doing it now. + * + * This driver uses new build_skb() API : + * RX ring buffer contains pointer to kmalloc() data only, + * skb are built only after Hardware filled the frame. + */ + +/* Some definitions from ethtool.h */ +/* The forced speed, 10Mb, 100Mb, gigabit, 2.5Gb, 10GbE. */ +#define SPEED_10 10 +#define SPEED_100 100 +#define SPEED_1000 1000 +#define SPEED_2500 2500 +#define SPEED_10000 10000 +#define SPEED_UNKNOWN -1 +/* Duplex, half or full. */ +#define DUPLEX_HALF 0x00 +#define DUPLEX_FULL 0x01 +#define DUPLEX_UNKNOWN 0xff + +struct tg3_link_config { + /* Describes what we're trying to get. */ + u32 advertising; + u16 speed; + u8 duplex; + u8 autoneg; + u8 flowctrl; + + /* Describes what we actually have. */ + u8 active_flowctrl; + + u8 active_duplex; + u16 active_speed; + u32 rmt_adv; +}; + +struct tg3_bufmgr_config { + u32 mbuf_read_dma_low_water; + u32 mbuf_mac_rx_low_water; + u32 mbuf_high_water; + + u32 mbuf_read_dma_low_water_jumbo; + u32 mbuf_mac_rx_low_water_jumbo; + u32 mbuf_high_water_jumbo; + + u32 dma_low_water; + u32 dma_high_water; +}; + +struct tg3_rx_prodring_set { + u32 rx_std_prod_idx; + u32 rx_std_cons_idx; + struct tg3_rx_buffer_desc *rx_std; + dma_addr_t rx_std_mapping; +}; + +/* U-Boot doesn't use NAPI, although we store some useful stuff in + * this struct. Perhaps it should be renamed or merged into tg3_priv? */ +struct tg3_napi { + struct tg3_priv *tp; + struct tg3_hw_status *hw_status; + u32 int_mbox; + + u32 consmbox; + struct tg3_rx_prodring_set prodring; + struct tg3_rx_buffer_desc *rx_rcb; + + u32 prodmbox; + struct tg3_tx_buffer_desc *tx_ring; + + dma_addr_t status_mapping; + dma_addr_t rx_rcb_mapping; + dma_addr_t tx_desc_mapping; + +}; + +enum TG3_FLAGS { + TG3_FLAG_TAGGED_STATUS = 0, + TG3_FLAG_TXD_MBOX_HWBUG, + TG3_FLAG_USE_LINKCHG_REG, + TG3_FLAG_ERROR_PROCESSED, + TG3_FLAG_ENABLE_ASF, + TG3_FLAG_ASPM_WORKAROUND, + TG3_FLAG_POLL_SERDES, + TG3_FLAG_POLL_CPMU_LINK, + TG3_FLAG_MBOX_WRITE_REORDER, + TG3_FLAG_PCIX_TARGET_HWBUG, + TG3_FLAG_WOL_SPEED_100MB, + TG3_FLAG_WOL_ENABLE, + TG3_FLAG_EEPROM_WRITE_PROT, + TG3_FLAG_NVRAM, + TG3_FLAG_NVRAM_BUFFERED, + TG3_FLAG_SUPPORT_MSI, + TG3_FLAG_SUPPORT_MSIX, + TG3_FLAG_USING_MSI, + TG3_FLAG_USING_MSIX, + TG3_FLAG_PCIX_MODE, + TG3_FLAG_PCI_HIGH_SPEED, + TG3_FLAG_PCI_32BIT, + TG3_FLAG_SRAM_USE_CONFIG, + TG3_FLAG_TX_RECOVERY_PENDING, + TG3_FLAG_WOL_CAP, + TG3_FLAG_JUMBO_RING_ENABLE, + TG3_FLAG_PAUSE_AUTONEG, + TG3_FLAG_CPMU_PRESENT, + TG3_FLAG_40BIT_DMA_BUG, + TG3_FLAG_BROKEN_CHECKSUMS, + TG3_FLAG_JUMBO_CAPABLE, + TG3_FLAG_CHIP_RESETTING, + TG3_FLAG_INIT_COMPLETE, + TG3_FLAG_MAX_RXPEND_64, + TG3_FLAG_PCI_EXPRESS, /* BCM5785 + pci_is_pcie() */ + TG3_FLAG_ASF_NEW_HANDSHAKE, + TG3_FLAG_HW_AUTONEG, + TG3_FLAG_IS_NIC, + TG3_FLAG_FLASH, + TG3_FLAG_FW_TSO, + TG3_FLAG_HW_TSO_1, + TG3_FLAG_HW_TSO_2, + TG3_FLAG_HW_TSO_3, + TG3_FLAG_TSO_CAPABLE, + TG3_FLAG_TSO_BUG, + TG3_FLAG_ICH_WORKAROUND, + TG3_FLAG_1SHOT_MSI, + TG3_FLAG_NO_FWARE_REPORTED, + TG3_FLAG_NO_NVRAM_ADDR_TRANS, + TG3_FLAG_ENABLE_APE, + TG3_FLAG_PROTECTED_NVRAM, + TG3_FLAG_5701_DMA_BUG, + TG3_FLAG_USE_PHYLIB, + TG3_FLAG_MDIOBUS_INITED, + TG3_FLAG_LRG_PROD_RING_CAP, + TG3_FLAG_RGMII_INBAND_DISABLE, + TG3_FLAG_RGMII_EXT_IBND_RX_EN, + TG3_FLAG_RGMII_EXT_IBND_TX_EN, + TG3_FLAG_CLKREQ_BUG, + TG3_FLAG_NO_NVRAM, + TG3_FLAG_ENABLE_RSS, + TG3_FLAG_ENABLE_TSS, + TG3_FLAG_SHORT_DMA_BUG, + TG3_FLAG_USE_JUMBO_BDFLAG, + TG3_FLAG_L1PLLPD_EN, + TG3_FLAG_APE_HAS_NCSI, + TG3_FLAG_TX_TSTAMP_EN, + TG3_FLAG_4K_FIFO_LIMIT, + TG3_FLAG_5719_5720_RDMA_BUG, + TG3_FLAG_RESET_TASK_PENDING, + TG3_FLAG_PTP_CAPABLE, + TG3_FLAG_5705_PLUS, + TG3_FLAG_IS_5788, + TG3_FLAG_5750_PLUS, + TG3_FLAG_5780_CLASS, + TG3_FLAG_5755_PLUS, + TG3_FLAG_57765_PLUS, + TG3_FLAG_57765_CLASS, + TG3_FLAG_5717_PLUS, + TG3_FLAG_IS_SSB_CORE, + TG3_FLAG_FLUSH_POSTED_WRITES, + TG3_FLAG_ROBOSWITCH, + TG3_FLAG_ONE_DMA_AT_ONCE, + TG3_FLAG_RGMII_MODE, + + /* Add new flags before this comment and TG3_FLAG_NUMBER_OF_FLAGS */ + TG3_FLAG_NUMBER_OF_FLAGS, /* Last entry in enum TG3_FLAGS */ +}; + +struct tg3_priv { + pci_dev_t devno; + u32 (*read32)(struct tg3_priv *, u32); + void (*write32)(struct tg3_priv *, u32, u32); + u32 (*read32_mbox)(struct tg3_priv *, u32); + void (*write32_mbox)(struct tg3_priv *, u32, u32); + void __iomem *regs; + void __iomem *aperegs; + u16 pci_vendor; + u16 pci_device; + + u32 tx_producer; /* TX Ring */ + u32 rx_producer; /* RX Producer Ring */ + u32 rx_consumer; /* RX Return Ring */ + void *rx_buffer[TG3_RX_BUFFER_COUNT]; + int card_init_state; + + void (*write32_tx_mbox)(struct tg3_priv *, u32, u32); + + struct tg3_napi napi[1]; + void (*write32_rx_mbox)(struct tg3_priv *, u32, u32); + u32 rx_std_ring_mask; + u32 rx_ret_ring_mask; + u32 rx_pending; + u32 rx_std_max_post; + + unsigned long tg3_flags[DIV_ROUND_UP(TG3_FLAG_NUMBER_OF_FLAGS, 8 * sizeof(long))]; + /* 1 second counter for transient serdes link events */ + u32 serdes_counter; +#define SERDES_AN_TIMEOUT_5704S 2 +#define SERDES_PARALLEL_DET_TIMEOUT 1 +#define SERDES_AN_TIMEOUT_5714S 1 + + struct tg3_link_config link_config; + struct tg3_bufmgr_config bufmgr_config; + + /* cache h/w values, often passed straight to h/w */ + u32 rx_mode; + u32 tx_mode; + u32 mac_mode; + u32 mi_mode; + u32 misc_host_ctrl; + u32 grc_mode; + u32 grc_local_ctrl; + u32 dma_rwctrl; + u32 coalesce_mode; + u32 pwrmgmt_thresh; + + /* PCI block */ + u32 pci_chip_rev_id; + u16 pci_cmd; + u8 pci_cacheline_sz; + u8 pci_lat_timer; + + int pci_fn; + + u8 phy_addr; + /* PHY info */ + u32 phy_id; +#define TG3_PHY_ID_MASK 0xfffffff0 +#define TG3_PHY_ID_BCM5400 0x60008040 +#define TG3_PHY_ID_BCM5401 0x60008050 +#define TG3_PHY_ID_BCM5411 0x60008070 +#define TG3_PHY_ID_BCM5701 0x60008110 +#define TG3_PHY_ID_BCM5703 0x60008160 +#define TG3_PHY_ID_BCM5704 0x60008190 +#define TG3_PHY_ID_BCM5705 0x600081a0 +#define TG3_PHY_ID_BCM5750 0x60008180 +#define TG3_PHY_ID_BCM5752 0x60008100 +#define TG3_PHY_ID_BCM5714 0x60008340 +#define TG3_PHY_ID_BCM5780 0x60008350 +#define TG3_PHY_ID_BCM5755 0xbc050cc0 +#define TG3_PHY_ID_BCM5787 0xbc050ce0 +#define TG3_PHY_ID_BCM5756 0xbc050ed0 +#define TG3_PHY_ID_BCM5784 0xbc050fa0 +#define TG3_PHY_ID_BCM5761 0xbc050fd0 +#define TG3_PHY_ID_BCM5718C 0x5c0d8a00 +#define TG3_PHY_ID_BCM5718S 0xbc050ff0 +#define TG3_PHY_ID_BCM57765 0x5c0d8a40 +#define TG3_PHY_ID_BCM5719C 0x5c0d8a20 +#define TG3_PHY_ID_BCM5720C 0x5c0d8b60 +#define TG3_PHY_ID_BCM5762 0x85803780 +#define TG3_PHY_ID_BCM5906 0xdc00ac40 +#define TG3_PHY_ID_BCM8002 0x60010140 +#define TG3_PHY_ID_INVALID 0xffffffff + +#define PHY_ID_RTL8211C 0x001cc910 +#define PHY_ID_RTL8201E 0x00008200 + +#define TG3_PHY_ID_REV_MASK 0x0000000f +#define TG3_PHY_REV_BCM5401_B0 0x1 + + /* This macro assumes the passed PHY ID is + * already masked with TG3_PHY_ID_MASK. + */ +#define TG3_KNOWN_PHY_ID(X) \ + ((X) == TG3_PHY_ID_BCM5400 || (X) == TG3_PHY_ID_BCM5401 || \ + (X) == TG3_PHY_ID_BCM5411 || (X) == TG3_PHY_ID_BCM5701 || \ + (X) == TG3_PHY_ID_BCM5703 || (X) == TG3_PHY_ID_BCM5704 || \ + (X) == TG3_PHY_ID_BCM5705 || (X) == TG3_PHY_ID_BCM5750 || \ + (X) == TG3_PHY_ID_BCM5752 || (X) == TG3_PHY_ID_BCM5714 || \ + (X) == TG3_PHY_ID_BCM5780 || (X) == TG3_PHY_ID_BCM5787 || \ + (X) == TG3_PHY_ID_BCM5755 || (X) == TG3_PHY_ID_BCM5756 || \ + (X) == TG3_PHY_ID_BCM5906 || (X) == TG3_PHY_ID_BCM5761 || \ + (X) == TG3_PHY_ID_BCM5718C || (X) == TG3_PHY_ID_BCM5718S || \ + (X) == TG3_PHY_ID_BCM57765 || (X) == TG3_PHY_ID_BCM5719C || \ + (X) == TG3_PHY_ID_BCM5720C || (X) == TG3_PHY_ID_BCM5762 || \ + (X) == TG3_PHY_ID_BCM8002) + + u32 phy_flags; +#define TG3_PHYFLG_IS_LOW_POWER 0x00000001 +#define TG3_PHYFLG_IS_CONNECTED 0x00000002 +#define TG3_PHYFLG_USE_MI_INTERRUPT 0x00000004 +#define TG3_PHYFLG_USER_CONFIGURED 0x00000008 +#define TG3_PHYFLG_PHY_SERDES 0x00000010 +#define TG3_PHYFLG_MII_SERDES 0x00000020 +#define TG3_PHYFLG_ANY_SERDES (TG3_PHYFLG_PHY_SERDES | \ + TG3_PHYFLG_MII_SERDES) +#define TG3_PHYFLG_IS_FET 0x00000040 +#define TG3_PHYFLG_10_100_ONLY 0x00000080 +#define TG3_PHYFLG_ENABLE_APD 0x00000100 +#define TG3_PHYFLG_CAPACITIVE_COUPLING 0x00000200 +#define TG3_PHYFLG_NO_ETH_WIRE_SPEED 0x00000400 +#define TG3_PHYFLG_JITTER_BUG 0x00000800 +#define TG3_PHYFLG_ADJUST_TRIM 0x00001000 +#define TG3_PHYFLG_ADC_BUG 0x00002000 +#define TG3_PHYFLG_5704_A0_BUG 0x00004000 +#define TG3_PHYFLG_BER_BUG 0x00008000 +#define TG3_PHYFLG_SERDES_PREEMPHASIS 0x00010000 +#define TG3_PHYFLG_PARALLEL_DETECT 0x00020000 +#define TG3_PHYFLG_EEE_CAP 0x00040000 +#define TG3_PHYFLG_1G_ON_VAUX_OK 0x00080000 +#define TG3_PHYFLG_KEEP_LINK_ON_PWRDN 0x00100000 +#define TG3_PHYFLG_MDIX_STATE 0x00200000 +#define TG3_PHYFLG_DISABLE_1G_HD_ADV 0x00400000 + + u32 led_ctrl; + u32 phy_otp; + + u32 nic_sram_data_cfg; + u32 pci_clock_ctrl; + + struct tg3_hw_stats *hw_stats; + dma_addr_t stats_mapping; + + unsigned char mac_address[6]; + + void *tx_buffer; + dma_addr_t tx_buffer_mapping; +}; + +/* Accessor macros for chip and asic attributes + * + * nb: Using static inlines equivalent to the accessor macros generates + * larger object code with gcc 4.7. + * Using statement expression macros to check tp with + * typecheck(struct tg3 *, tp) also creates larger objects. + */ +#define tg3_chip_rev_id(tp) \ + ((tp)->pci_chip_rev_id) +#define tg3_asic_rev(tp) \ + ((tp)->pci_chip_rev_id >> 12) +#define tg3_chip_rev(tp) \ + ((tp)->pci_chip_rev_id >> 8) + +#endif /* !(_T3_H) */ diff --git a/include/netdev.h b/include/netdev.h index 34651ab..460fed8 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -84,6 +84,7 @@ int sunxi_gmac_initialize(bd_t *bis); int tsi108_eth_initialize(bd_t *bis); int uec_standard_init(bd_t *bis); int uli526x_initialize(bd_t *bis); +int tg3_register(bd_t *bis); int armada100_fec_register(unsigned long base_addr); int xilinx_axiemac_initialize(bd_t *bis, unsigned long base_addr, unsigned long dma_addr); @@ -141,6 +142,9 @@ static inline int pci_eth_init(bd_t *bis) #if defined(CONFIG_ULI526X) num += uli526x_initialize(bis); #endif +#if defined(CONFIG_TIGON3) + num += tg3_register(bis); +#endif
#endif /* CONFIG_PCI */ return num;
Chris Packham
