[U-Boot] Fix the Double defind for setenv on ARM platform
Hi all,
Today, I test s5p_goni board 1. I have found two issue: (1) Double defind setenv I found setenv defind in the file of include/common.h and arch/arm/include/asm/u-boot-arm.h. At the same time, common.h include u-boot-arm.h head file. (2) The type of parameters is inconsistent for the setenv: arch/arm/include/asm/u-boot-arm.h: setenv(char *,char *)
include/common.h: setenv(const char *,const char *)
When everyone build the board, the error information will be display as following: /home/seedshope/work/home-project/obj/u-boot/include2/asm/u-boot-arm.h:66: error: conflicting types for 'setenv'
I have test the patch for armv7 cpu to use command "./MAKEALL -a arm -c armv7". 2. The reproduce step as following (1) The build enviroment: u-boot is the source PATH and /home/seedshope/work/home-project/obj/u-boot is my object path. The cross compile version as following:
/usr/local/arm/arm-2009q3/bin/arm-none-linux-gnueabi-gcc -v
Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /scratch/julian/2009q3-respin-linux-lite/src/gcc-4.4/configure --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --target=arm-none-linux-gnueabi --enable-threads --disable-libmudflap --disable-libssp --disable-libstdcxx-pch --enable-extra-sgxxlite-multilibs --with-arch=armv5te --with-gnu-as --with-gnu-ld --with-specs='%{funwind-tables|fno-unwind-tables|mabi=*|ffreestanding|nostdlib:;:-funwind-tables} %{O2:%{!fno-remove-local-statics: -fremove-local-statics}} %{O*:%{O|O0|O1|O2|Os:;:%{!fno-remove-local-statics: -fremove-local-statics}}}' --enable-languages=c,c++ --enable-shared --disable-lto --enable-symvers=gnu --enable-__cxa_atexit --with-pkgversion='Sourcery G++ Lite 2009q3-67' --with-bugurl=https://support.codesourcery.com/GNUToolchain/ --disable-nls --prefix=/opt/codesourcery --with-sysroot=/opt/codesourcery/arm-none-linux-gnueabi/libc --with-build-sysroot=/scratch/julian/2009q3-respin-linux-lite/install/arm-none-linux-gnueabi/libc --with-gmp=/scratch/jul ian/2009q3-respin-linux-lite/obj/host-libs-2009q3-67-arm-none-linux-gnueabi-i686-pc-linux-gnu/usr --with-mpfr=/scratch/julian/2009q3-respin-linux-lite/obj/host-libs-2009q3-67-arm-none-linux-gnueabi-i686-pc-linux-gnu/usr --with-ppl=/scratch/julian/2009q3-respin-linux-lite/obj/host-libs-2009q3-67-arm-none-linux-gnueabi-i686-pc-linux-gnu/usr --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm' --with-cloog=/scratch/julian/2009q3-respin-linux-lite/obj/host-libs-2009q3-67-arm-none-linux-gnueabi-i686-pc-linux-gnu/usr --disable-libgomp --enable-poison-system-directories --with-build-time-tools=/scratch/julian/2009q3-respin-linux-lite/install/arm-none-linux-gnueabi/bin --with-build-time-tools=/scratch/julian/2009q3-respin-linux-lite/install/arm-none-linux-gnueabi/bin Thread model: posix gcc version 4.4.1 (Sourcery G++ Lite 2009q3-67)
(2) configure s5p_goni_board
make -C u-boot O=/home/seedshope/work/home-project/obj/u-boot CROSS_COMPILE=/usr/local/arm/arm-2009q3/bin/arm-none-linux-gnueabi- distclean
make: Entering directory `/home/seedshope/work/home-project/u-boot' rm -rf /home/seedshope/work/home-project/obj/u-boot/* make: Leaving directory `/home/seedshope/work/home-project/u-boot'
(3) build s5p_goni board
make: Entering directory `/home/seedshope/work/home-project/u-boot' Generating /home/seedshope/work/home-project/obj/u-boot/include/autoconf.mk Generating /home/seedshope/work/home-project/obj/u-boot/include/autoconf.mk.dep make: Leaving directory `/home/seedshope/work/home-project/u-boot' make: Entering directory `/home/seedshope/work/home-project/u-boot' /usr/local/arm/arm-2009q3/bin/arm-none-linux-gnueabi-gcc -DDO_DEPS_ONLY \ -g -Os -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x34800000 -I/home/seedshope/work/home-project/obj/u-boot/include2 -I/home/seedshope/work/home-project/obj/u-boot/include -I/home/seedshope/work/home-project/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/arm/arm-2009q3/bin/../lib/gcc/arm-none-linux-gnueabi/4.4.1/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mabi=aapcs-linux -mno-thumb-interwork -march=armv5 -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security \ -o /home/seedshope/work/home-project/obj/u-boot/lib/asm-offsets.s /home/seedshope/work/home-project/u-boot/lib/asm-offsets.c -c -S In file included from /home/seedshope/work/home-project/u-boot/include/common.h:276, from /home/seedshope/work/home-project/u-boot/lib/asm-offsets.c:18: /home/seedshope/work/home-project/obj/u-boot/include2/asm/u-boot-arm.h:66: error: conflicting types for 'setenv' /home/seedshope/work/home-project/u-boot/include/common.h:271: note: previous declaration of 'setenv' was here make: *** [/home/seedshope/work/home-project/obj/u-boot/lib/asm-offsets.s] Error 1 make: Leaving directory `/home/seedshope/work/home-project/u-boot'
setenv is defined common.h. We do not need re-defined it
Zhong hongbo bocui107@gmail.com --- arch/arm/include/asm/u-boot-arm.h | 8 -------- 1 files changed, 0 insertions(+), 8 deletions(-)
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index 3904027..e3fbb53 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -57,14 +57,6 @@ void dram_init_banksize (void); void setup_serial_tag (struct tag **params); void setup_revision_tag (struct tag **params);
-/* ------------------------------------------------------------ */ -/* Here is a list of some prototypes which are incompatible to */ -/* the U-Boot implementation */ -/* To be fixed! */ -/* ------------------------------------------------------------ */ -/* common/cmd_nvedit.c */ -int setenv (char *, char *); - /* cpu/.../interrupt.c */ int arch_interrupt_init (void); void reset_timer_masked (void);
Dear Zhong Hongbo,
Thanks, but there are some more function prototypes in this block which are actually bogus. I have a more complete cleanup patch ready, I'm running MAKEALL to test it right now.
Also remove bogus comment.
Signed-off-by: Zhong hongbo bocui107@gmail.com Changed commit message Signed-off-by: Wolfgang Denk wd@denx.de Cc: Albert Aribaud albert.aribaud@free.fr --- arch/arm/include/asm/u-boot-arm.h | 8 -------- 1 files changed, 0 insertions(+), 8 deletions(-)
Clean up some duplicated prototype declarations. Get rid of now useless AVR32 initcalls.h file.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Albert Aribaud albert.aribaud@free.fr Cc: Haavard Skinnemoen haavard.skinnemoen@atmel.com Cc: Graeme Russ graeme.russ@gmail.com --- arch/arm/include/asm/u-boot-arm.h | 3 --- arch/avr32/include/asm/initcalls.h | 30 ------------------------------ arch/avr32/lib/board.c | 1 - arch/x86/include/asm/u-boot-x86.h | 1 - include/common.h | 3 +++ 5 files changed, 3 insertions(+), 35 deletions(-) delete mode 100644 arch/avr32/include/asm/initcalls.h
diff --git a/arch/arm/include/asm/u-boot-arm.h b/arch/arm/include/asm/u-boot-arm.h index e3fbb53..d3308f7 100644 --- a/arch/arm/include/asm/u-boot-arm.h +++ b/arch/arm/include/asm/u-boot-arm.h @@ -63,7 +63,4 @@ void reset_timer_masked (void); ulong get_timer_masked (void); void udelay_masked (unsigned long usec);
-/* cpu/.../timer.c */ -int timer_init (void); - #endif /* _U_BOOT_ARM_H_ */ diff --git a/arch/avr32/include/asm/initcalls.h b/arch/avr32/include/asm/initcalls.h deleted file mode 100644 index 57a278b..0000000 --- a/arch/avr32/include/asm/initcalls.h +++ /dev/null @@ -1,30 +0,0 @@ -/* - * Copyright (C) 2005, 2006 Atmel Corporation - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#ifndef __ASM_AVR32_INITCALLS_H__ -#define __ASM_AVR32_INITCALLS_H__ - -#include <config.h> - -extern int cpu_init(void); -extern int timer_init(void); - -#endif /* __ASM_AVR32_INITCALLS_H__ */ diff --git a/arch/avr32/lib/board.c b/arch/avr32/lib/board.c index e69f8d1..65473a1 100644 --- a/arch/avr32/lib/board.c +++ b/arch/avr32/lib/board.c @@ -30,7 +30,6 @@ #include <miiphy.h> #endif
-#include <asm/initcalls.h> #include <asm/sections.h> #include <asm/arch/mmu.h>
diff --git a/arch/x86/include/asm/u-boot-x86.h b/arch/x86/include/asm/u-boot-x86.h index 944e1a2..4f0d2c7 100644 --- a/arch/x86/include/asm/u-boot-x86.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -36,7 +36,6 @@ typedef void (timer_fnc_t) (void); int register_timer_isr (timer_fnc_t *isr_func);
/* Architecture specific - can be in arch/x86/cpu/, arch/x86/lib/, or $(BOARD)/ */ -int timer_init(void); int dram_init_f(void);
/* cpu/.../interrupts.c */ diff --git a/include/common.h b/include/common.h index b994e70..12a1074 100644 --- a/include/common.h +++ b/include/common.h @@ -222,6 +222,9 @@ typedef void (interrupt_handler_t)(void *);
void hang (void) __attribute__ ((noreturn));
+int timer_init(void); +int cpu_init(void); + /* */ phys_size_t initdram (int); int display_options (void);
Dear Wolfgang Denk,
Applied, thanks.
Dear Albert,
I applied this directly, it is causing too much trouble to delay it any longer.
Hope this is OK with you.
please fix your git env. it is setting the author field to "seedshope" which clearly is incorrect. it should be your name. -mike
Mike Frysinger
Zhong Hongbo
