[U-Boot] [PATCH] mpc83xx: don't shift pre-shifted ACR, SPCR, SCCR bitfield masks in cpu_init.c
commit c7190f028fa950d4d36b6d0b4bb3fc72602ec54c "mpc83xx: retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfields" incorrectly shifted <register>_<bitfield> (e.g. ACR_PIPE_DEP) values that were preshifted by their definition in mpc83xx.h.
this patch removes the unnecessary shifting for the newly utilized mask values in cpu_init.c, and prevents seemingly unrelated symptoms such as an mpc8379erdb board from locking up whilst performing a networking operation, e.g. a tftp.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/cpu/mpc83xx/cpu_init.c | 36 +++++++++++++++++----------------- 1 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 75b4522..f3b67ae 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -65,16 +65,16 @@ void cpu_init_f (volatile immap_t * im) { __be32 acr_mask = #ifdef CONFIG_SYS_ACR_PIPE_DEP /* Arbiter pipeline depth */ - (ACR_PIPE_DEP << ACR_PIPE_DEP_SHIFT) | + ACR_PIPE_DEP | #endif #ifdef CONFIG_SYS_ACR_RPTCNT /* Arbiter repeat count */ - (ACR_RPTCNT << ACR_RPTCNT_SHIFT) | + ACR_RPTCNT | #endif #ifdef CONFIG_SYS_ACR_APARK /* Arbiter address parking mode */ - (ACR_APARK << ACR_APARK_SHIFT) | + ACR_APARK | #endif #ifdef CONFIG_SYS_ACR_PARKM /* Arbiter parking master */ - (ACR_PARKM << ACR_PARKM_SHIFT) | + ACR_PARKM | #endif 0; __be32 acr_val = @@ -93,16 +93,16 @@ void cpu_init_f (volatile immap_t * im) 0; __be32 spcr_mask = #ifdef CONFIG_SYS_SPCR_OPT /* Optimize transactions between CSB and other dev */ - (SPCR_OPT << SPCR_OPT_SHIFT) | + SPCR_OPT | #endif #ifdef CONFIG_SYS_SPCR_TSECEP /* all eTSEC's Emergency priority */ - (SPCR_TSECEP << SPCR_TSECEP_SHIFT) | + SPCR_TSECEP | #endif #ifdef CONFIG_SYS_SPCR_TSEC1EP /* TSEC1 Emergency priority */ - (SPCR_TSEC1EP << SPCR_TSEC1EP_SHIFT) | + SPCR_TSEC1EP | #endif #ifdef CONFIG_SYS_SPCR_TSEC2EP /* TSEC2 Emergency priority */ - (SPCR_TSEC2EP << SPCR_TSEC2EP_SHIFT) | + SPCR_TSEC2EP | #endif 0; __be32 spcr_val = @@ -121,34 +121,34 @@ void cpu_init_f (volatile immap_t * im) 0; __be32 sccr_mask = #ifdef CONFIG_SYS_SCCR_ENCCM /* Encryption clock mode */ - (SCCR_ENCCM << SCCR_ENCCM_SHIFT) | + SCCR_ENCCM | #endif #ifdef CONFIG_SYS_SCCR_PCICM /* PCI & DMA clock mode */ - (SCCR_PCICM << SCCR_PCICM_SHIFT) | + SCCR_PCICM | #endif #ifdef CONFIG_SYS_SCCR_TSECCM /* all TSEC's clock mode */ - (SCCR_TSECCM << SCCR_TSECCM_SHIFT) | + SCCR_TSECCM | #endif #ifdef CONFIG_SYS_SCCR_TSEC1CM /* TSEC1 clock mode */ - (SCCR_TSEC1CM << SCCR_TSEC1CM_SHIFT) | + SCCR_TSEC1CM | #endif #ifdef CONFIG_SYS_SCCR_TSEC2CM /* TSEC2 clock mode */ - (SCCR_TSEC2CM << SCCR_TSEC2CM_SHIFT) | + SCCR_TSEC2CM | #endif #ifdef CONFIG_SYS_SCCR_TSEC1ON /* TSEC1 clock switch */ - (SCCR_TSEC1ON << SCCR_TSEC1ON_SHIFT) | + SCCR_TSEC1ON | #endif #ifdef CONFIG_SYS_SCCR_TSEC2ON /* TSEC2 clock switch */ - (SCCR_TSEC2ON << SCCR_TSEC2ON_SHIFT) | + SCCR_TSEC2ON | #endif #ifdef CONFIG_SYS_SCCR_USBMPHCM /* USB MPH clock mode */ - (SCCR_USBMPHCM << SCCR_USBMPHCM_SHIFT) | + SCCR_USBMPHCM | #endif #ifdef CONFIG_SYS_SCCR_USBDRCM /* USB DR clock mode */ - (SCCR_USBDRCM << SCCR_USBDRCM_SHIFT) | + SCCR_USBDRCM | #endif #ifdef CONFIG_SYS_SCCR_SATACM /* SATA controller clock mode */ - (SCCR_SATACM << SCCR_SATACM_SHIFT) | + SCCR_SATACM | #endif 0; __be32 sccr_val =
On Wed, 19 May 2010 17:06:46 -0500 Kim Phillips kim.phillips@freescale.com wrote:
applied.
Thanks,
Kim
Kim Phillips
